I use append and cmaple to run
originally can See result in real time even if open text file
but suddenly text file become 0KB
when I copy text file and paste
0 KB become 3 KB
but the program can not further output to text file and no error shown
I have a vector calculus question. I was given three points, p,q, and r, and I got Maple to calculate vectors pq and pr. I also got Maple to calculate the cross product vector, pq x pr. The problem says to draw the triangle formed by p,q, and r, as well as the cross product vector. I tried to use the polygonplot tool to plot the triangle formed by the three points, but I am confused as to how to get the cross product vector to appear on the plot with the triangle. What tool do I use to plot the triangle with the cross product vector on it, so I can have a picture of the cross product vector starting at p, showing that it is orthogonal to vector pq and pr?
Dear Community!
I'm struggleing with a problem long since. I highly appreciate any help with this theme.
The problem is the following:
- I have a set of points, what comes from a numerical solution of a complex, but periodical function. Therefore I have a set of points (X;Y). The points are doesn't matter, but in my case, it look like this:
I want to use the Fourier-method to approximate this points with a function.
The best result I could get is this:
But it is not acceptable due to the high inaccuracy at the starting, and finishing points (there is a diagram inaccuracy %):
I'm feel like, I'm doing something wrong. Unfortunately, I had no time to look deep into the math here. Can somebody tell me, that how can I get a better result, using this method?
Thank you very much for the help in advance.
Best regards
Dávid
Could anybody give me an idea of how I would go about ignoring the Christoffel symbols with coefficients of order Omega(r)^2 in the following code? Thanks.
with(Physics)
[`*`, `.`, Annihilation, AntiCommutator, Antisymmetrize, Assume, Bra, Bracket, Check, Christoffel, Coefficients, Commutator, CompactDisplay, Coordinates, Creation, D_, Dagger, Decompose, Define, Dgamma, Einstein, EnergyMomentum, Expand, ExteriorDerivative, Factor, FeynmanDiagrams, Fundiff, Geodesics, GrassmannParity, Gtaylor, Intc, Inverse, Ket, KillingVectors, KroneckerDelta, LeviCivita, Library, LieBracket, LieDerivative, Normal, Parameters, PerformOnAnticommutativeSystem, Projector, Psigma, Redefine, Ricci, Riemann, Setup, Simplify, SortProducts, SpaceTimeVector, StandardModel, SubstituteTensor, SubstituteTensorIndices, SumOverRepeatedIndices, Symmetrize, TensorArray, Tetrads, ThreePlusOne, ToFieldComponents, ToSuperfields, Trace, TransformCoordinates, Vectors, Weyl, `^`, dAlembertian, d_, diff, g_, gamma_]
Setup(metric = -exp(2*alpha(r))*%d_(t)^2+exp(2*beta(r))*%d_(r)^2+r^2*%d_(theta)^2+r^2*sin(theta)^2*(%d_(phi)-Omega(r)*%d_(t))^2)
[metric = {(1, 1) = -exp(2*alpha(r))+(-r^2*cos(theta)^2+r^2)*Omega(r)^2, (1, 4) = -r^2*sin(theta)^2*Omega(r), (2, 2) = exp(2*beta(r)), (3, 3) = r^2, (4, 4) = r^2*sin(theta)^2}]
g_[]
Physics:-g_[mu, nu] = Matrix(%id = 18446746171579097566)
Christoffel[nonzero]
Physics:-Christoffel[alpha, mu, nu] = {(1, 1, 2) = -(diff(alpha(r), r))*exp(2*alpha(r))-r*Omega(r)*(cos(theta)-1)*(cos(theta)+1)*(r*(diff(Omega(r), r))+Omega(r)), (1, 1, 3) = r^2*sin(theta)*Omega(r)^2*cos(theta), (1, 2, 1) = -(diff(alpha(r), r))*exp(2*alpha(r))-r*Omega(r)*(cos(theta)-1)*(cos(theta)+1)*(r*(diff(Omega(r), r))+Omega(r)), (1, 2, 4) = -(1/2)*r*sin(theta)^2*(r*(diff(Omega(r), r))+2*Omega(r)), (1, 3, 1) = r^2*sin(theta)*Omega(r)^2*cos(theta), (1, 3, 4) = -r^2*sin(theta)*Omega(r)*cos(theta), (1, 4, 2) = -(1/2)*r*sin(theta)^2*(r*(diff(Omega(r), r))+2*Omega(r)), (1, 4, 3) = -r^2*sin(theta)*Omega(r)*cos(theta), (2, 1, 1) = (diff(alpha(r), r))*exp(2*alpha(r))+r*Omega(r)*(cos(theta)-1)*(cos(theta)+1)*(r*(diff(Omega(r), r))+Omega(r)), (2, 1, 4) = (1/2)*r*sin(theta)^2*(r*(diff(Omega(r), r))+2*Omega(r)), (2, 2, 2) = (diff(beta(r), r))*exp(2*beta(r)), (2, 3, 3) = -r, (2, 4, 1) = (1/2)*r*sin(theta)^2*(r*(diff(Omega(r), r))+2*Omega(r)), (2, 4, 4) = -r*sin(theta)^2, (3, 1, 1) = -r^2*sin(theta)*Omega(r)^2*cos(theta), (3, 1, 4) = r^2*sin(theta)*Omega(r)*cos(theta), (3, 2, 3) = r, (3, 3, 2) = r, (3, 4, 1) = r^2*sin(theta)*Omega(r)*cos(theta), (3, 4, 4) = -r^2*sin(theta)*cos(theta), (4, 1, 2) = -(1/2)*r*sin(theta)^2*(r*(diff(Omega(r), r))+2*Omega(r)), (4, 1, 3) = -r^2*sin(theta)*Omega(r)*cos(theta), (4, 2, 1) = -(1/2)*r*sin(theta)^2*(r*(diff(Omega(r), r))+2*Omega(r)), (4, 2, 4) = r*sin(theta)^2, (4, 3, 1) = -r^2*sin(theta)*Omega(r)*cos(theta), (4, 3, 4) = r^2*sin(theta)*cos(theta), (4, 4, 2) = r*sin(theta)^2, (4, 4, 3) = r^2*sin(theta)*cos(theta)}
Download Christoffel.mw
Hi guys,
I'm trying to apply boundary condition on the seris i generated using Adomian decomposition. Could some one please check it for me?
u[0] := a1+a2*y:
w[0] := a3+a4*y:
theta[0] := a6*y+a5
phi[0] := a8*y+a7
A[1] := R*(diff(u[0], y))+A-Gr*(B*phi[0]+theta[0])/Ree+Ha^2*(alpha*u[0]+beta*w[0])/(alpha^2+beta^2)
R*a2+A-Gr*(a5+a6*y+B*(a7+a8*y))/Ree+Ha^2*(alpha*(a1+a2*y)+beta*(a3+a4*y))/(alpha^2+beta^2)
u[1] := int(A[1], y = 0 .. y)
(1/2)*(-Gr*(a6+B*a8)/Ree+Ha^2*(alpha*a2+beta*a4)/(alpha^2+beta^2))*y^2+R*a2*y+A*y-Gr*(a5+B*a7)*y/Ree+Ha^2*(alpha*a1+beta*a3)*y/(alpha^2+beta^2)
u[11] := int(u[1], y = 0 .. y)
(1/3)*(-(1/2)*Gr*(a6+B*a8)/Ree+(1/2)*Ha^2*(alpha*a2+beta*a4)/(alpha^2+beta^2))*y^3+(1/2)*(R*a2+A-Gr*(a5+B*a7)/Ree+Ha^2*(alpha*a1+beta*a3)/(alpha^2+beta^2))*y^2
u = u[0]+u[11]
u = a1+a2*y+(1/3)*(-(1/2)*Gr*(a6+B*a8)/Ree+(1/2)*Ha^2*(alpha*a2+beta*a4)/(alpha^2+beta^2))*y^3+(1/2)*(R*a2+A-Gr*(a5+B*a7)/Ree+Ha^2*(alpha*a1+beta*a3)/(alpha^2+beta^2))*y^2
A[2] := R*(diff(w[0], y))-Ha^2*(beta*u[0]-alpha*w[0])/(alpha^2+beta^2)
R*a4-Ha^2*(beta*(a1+a2*y)-alpha*(a3+a4*y))/(alpha^2+beta^2)
w[1] := int(A[2], y = 0 .. y)
-(1/2)*Ha^2*(beta*a2-alpha*a4)*y^2/(alpha^2+beta^2)+R*a4*y-Ha^2*(beta*a1-alpha*a3)*y/(alpha^2+beta^2)
w[11] := int(w[1], y = 0 .. y)
-(1/6)*Ha^2*(beta*a2-alpha*a4)*y^3/(alpha^2+beta^2)+(1/2)*(R*a4-Ha^2*(beta*a1-alpha*a3)/(alpha^2+beta^2))*y^2
w = w[0]+w[11]
w = a3+a4*y-(1/6)*Ha^2*(beta*a2-alpha*a4)*y^3/(alpha^2+beta^2)+(1/2)*(R*a4-Ha^2*(beta*a1-alpha*a3)/(alpha^2+beta^2))*y^2
A[3] := R*Pr*(diff(theta[0], y))-2*Br*((diff(u[0], y))^2+(diff(w[0], y))^2+M^2*C*(u[0]^2+w[0]^2))-gamma*R*Pr*theta[0]
R*Pr*a6-2*Br*(a2^2+a4^2+M^2*C*((a1+a2*y)^2+(a3+a4*y)^2))-gamma*R*Pr*(a5+a6*y)
theta[1] := int(A[3], y = 0 .. y)
-(2/3)*Br*M^2*C*(a2^2+a4^2)*y^3+(1/2)*(-2*Br*M^2*C*(2*a1*a2+2*a3*a4)-gamma*R*Pr*a6)*y^2+R*Pr*a6*y-2*Br*(a2^2+a4^2+M^2*C*(a1^2+a3^2))*y-gamma*R*Pr*a5*y
theta[11] := int(theta[1], y = 0 .. y)
-(1/6)*Br*M^2*C*(a2^2+a4^2)*y^4+(1/3)*(-Br*M^2*C*(2*a1*a2+2*a3*a4)-(1/2)*gamma*R*Pr*a6)*y^3+(1/2)*(R*Pr*a6-2*Br*(a2^2+a4^2+M^2*C*(a1^2+a3^2))-gamma*R*Pr*a5)*y^2
theta = theta[0]+theta[11]
theta = a5+a6*y-(1/6)*Br*M^2*C*(a2^2+a4^2)*y^4+(1/3)*(-Br*M^2*C*(2*a1*a2+2*a3*a4)-(1/2)*gamma*R*Pr*a6)*y^3+(1/2)*(R*Pr*a6-2*Br*(a2^2+a4^2+M^2*C*(a1^2+a3^2))-gamma*R*Pr*a5)*y^2
A[4] := R*Sc*(diff(phi[0], y))-K*Sc*phi[0]
R*Sc*a8-K*Sc*(a7+a8*y)
phi[1] := int(A[4], y = 0 .. y)
-(1/2)*K*Sc*a8*y^2+R*Sc*a8*y-K*Sc*a7*y
(14)
phi[11] := int(phi[1], y = 0 .. y)
-(1/6)*K*Sc*a8*y^3+(1/2)*(R*Sc*a8-K*Sc*a7)*y^2
(15)
phi = phi[0]+phi[11]
phi = a7+a8*y-(1/6)*K*Sc*a8*y^3+(1/2)*(R*Sc*a8-K*Sc*a7)*y^2
(16)
Download second_problem.mw
Hello MaplePrimes users
How do I find expressions of an integer as a sum of four squares in Maple?
Hi everyone,
Please, I really need your expertise advice(s) on what i am not doing right in the code attached below. I was actually writing the code on Multi-step DTM, but, instead of continuing from the last point, it starting all over again. Please, your expertise will save a soul here. Regard
MsDTM3.mw
I need to plot some correlation matrices C1, C2, ... and I use matrixplot for this.
I would like to use the same absolute scale (-1..+1) for all of them.
For instance is I decide to uses colorscheme=["blue", "white", "red"] I would like blue to correspond to value -1, white to value 0 and red to value 1.
Unfortunately colorscheme set to blue the cell with the mininum value (not necessarily -1) and to red the maximum one (not necessarily +1).
Here is an example
with(Statistics):
randomize():
N := 10:
P := 3:
A := Sample(Uniform(0, 1), [N, P]):
C := CorrelationMatrix(A):
matrixplot(
  C,
 heights=histogram,
 axes=frame,
​​​​​​​  gap=0.25,
​​​​​​​  color=((x,y)->(C[x,y]+1)/2),
​​​​​​​  orientation=[0, 0, 0],
​​​​​​​  lightmodel=none,
​​​​​​​  tickmarks=[[seq(i+1/2=A||i, i=1..P)], [seq(i+1/2=A||i, i=1..P)], default],
​​​​​​​  labels=[("")$3]​​​​​​​
​​​​​​​I also tried to use color=((x,y) -> (C[x, y]+1)/2) instead of colorscheme but here again matrixplot uses a local scale defined by the reange of the correlation matrix to plot.
I fixed this by using something like seq(seq(PLOT(POLYGONS(...), i=1..P), j=1..P) instead of matrixplot, but I think it is a shame to do so.
So my question: is it possible to force matrixplot not to use a scale defined by the matrix to plot, but a "user" scale?
PS: I'm using Maple 2015
I have some trouble solving the pde of:
ut + u^2*ux = u, u(x,0) = x, with x::real and t>0.
I think that I have 2 problems.
1.
The first part of the code I define u(x,t) with both the variable rp.
Then I define the variable q copying the definition of u(x,t).
When I try to insert q and u(x,t) in the initial equation - one is able to be reduced to one term while the other isn't.
So I'm not really sure what is happening here.
2.
When I use Maple's pdsolve() I get a result, but when I insert the answer in the initial equation - then it isn't correct.
I tried to show this in the last part of the code.
# ut + u^2*ux = u, u(x,0) = x
rp := (-1 + sqrt(1 + 4*exp(t)^2*t*x))/(2*exp(t)^2*t);
(1/2)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))/((exp(t))^2*t)
u := (x,t) -> rp*exp(t):
'u(x,t)' = u(x,t);
u(x, t) = (1/2)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))/(exp(t)*t)
q := (-1 + sqrt(1 + 4*exp(t)^2*t*x))/(2*exp(t)*t); # Copying the result from above and defining q the same
# Now doing the same operations on supposedly the same term, but one is able to be reduced with assumptions while the other isn't.
L_nothing := diff(u(x,t),t) + u(x,t)^2*diff(u(x,t),x) ;
L_real := diff(u(x,t),t) + u(x,t)^2*diff(u(x,t),x) assuming x::real;
L_t := diff(u(x,t),t) + u(x,t)^2*diff(u(x,t),x) assuming t>0;
L_all := diff(u(x,t),t) + u(x,t)^2*diff(u(x,t),x) assuming t>0, x::real;
(1/4)*(8*(exp(t))^2*t*x+4*(exp(t))^2*x)/((1+4*(exp(t))^2*t*x)^(1/2)*exp(t)*t)-(1/2)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))/(exp(t)*t)-(1/2)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))/(exp(t)*t^2)+(1/4)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))^2/(exp(t)*t^2*(1+4*(exp(t))^2*t*x)^(1/2))
(1/2)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))/(exp(t)*t)+(1/4)*(-1+(1+4*(exp(t))^2*t*x)^(1/2))^2/(exp(t)*t^2*(1+4*(exp(t))^2*t*x)^(1/2))
L_nothing := diff(q,t) + q^2*diff(q,x) ;
L_real := diff(q,t) + q^2*diff(q,x) assuming x::real;
L_t := diff(q,t) + q^2*diff(q,x) assuming t>0;
L_all := diff(q,t) + q^2*diff(q,x) assuming t>0, x::real;
pde := diff(u(x,t),t) + u(x,t)^2*diff(u(x,t),x) = u(x,t);
ic := u(x,0) = x;
diff(u(x, t), t)+u(x, t)^2*(diff(u(x, t), x)) = u(x, t)
u(x, 0) = x
pdsolve([pde, ic]);
u(x, t) = exp(t)*((2*exp(2*t)*x-2*x+1)^(1/2)-1)/(exp(2*t)-1)
u := (x,t) -> exp(t)*(sqrt(2*exp(2*t)*x - 2*x + 1) - 1)/(exp(2*t) - 1);
proc (x, t) options operator, arrow; exp(t)*(sqrt(2*exp(2*t)*x-2*x+1)-1)/(exp(2*t)-1) end proc
L := diff(u(x,t),t) + u(x,t)^2*diff(u(x,t),x) assuming t>0, x::real;
exp(t)*((2*exp(2*t)*x-2*x+1)^(1/2)-1)/(exp(2*t)-1)+2*exp(t)*exp(2*t)*x/((2*exp(2*t)*x-2*x+1)^(1/2)*(exp(2*t)-1))-2*exp(t)*((2*exp(2*t)*x-2*x+1)^(1/2)-1)*exp(2*t)/(exp(2*t)-1)^2+(1/2)*(exp(t))^3*((2*exp(2*t)*x-2*x+1)^(1/2)-1)^2*(2*exp(2*t)-2)/((exp(2*t)-1)^3*(2*exp(2*t)*x-2*x+1)^(1/2))
LL := simplify(L) = u(x,t)
exp(t)*(2*exp(2*t)*x-(2*exp(2*t)*x-2*x+1)^(1/2)-2*x+1)/((2*exp(2*t)*x-2*x+1)^(1/2)*(exp(2*t)-1)) = exp(t)*((2*exp(2*t)*x-2*x+1)^(1/2)-1)/(exp(2*t)-1)
evalb(LL)
# Obviously not correct solution... or what?
Download asol1-1.mw
I just  found what seems to be a serious problem and I am not able to figure if it is related to my own installation or not.
After I installed Physics 426 (Published on Sept 17, 2019) using the Maple GUI install button (which now works for my PC), I found I am not able to integrate basic things.
It seems to affect int when using some build in function with definite integration, but it could be others also. I need to test more.
Could someone see if they get same problem as well?
Could also someone please remind me of the library  commands to issue in order to remove current Physics version 426 and install earlier Physics version package, say 425, or any other version, so that  to see if this is related to version of a physics package or not?
version()
 User Interface: 1399874
         Kernel: 1399874
        Library: 1399874
1399874
interface(version)
`Standard Worksheet Interface, Maple 2019.1, Windows 10, May 21 2019 Build ID 1399874`
`The "Physics Updates" version in the MapleCloud is 426 and is the same as the version installed in this computer, created 2019, September 20, 23:28 hours, found in the directory C:\Users\me\maple\toolbox\2019\Physics Updates\lib\`
infolevel[int] := 3:
int(exp(x),x=0..1)
Definite Integration:   Integrating expression on x=0..1
Definite Integration:   Using the integrators [distribution, piecewise, series, o, polynomial, ln, lookup, cook, ratpoly, elliptic, elliptictrig, meijergspecial, improper, asymptotic, ftoc, ftocms, meijerg, contour]
LookUp Integrator:   unable to find the specified integral in the table
int/elliptic: trying elliptic integration
Integration Warning:   Integration method ftoc encountered an error in IntegrationTools:-Definite:-Main:
 mismatched multiple assignment of 2 variables on the left side and 1 value on the right side
Definite Integration:   Returning integral unevaluated.
int(exp(x), x = 0 .. 1)
int(sin(n*x),x=0..Pi)
int(sin(n*x), x = 0 .. Pi)
int(tan(x),x=0..Pi)
int(tan(x), x = 0 .. Pi)
int(cos(x),x=0..1)
int(cos(x), x = 0 .. 1)
int(sin(x),x=0 .. Pi)
int(sin(x), x = 0 .. Pi)
int(cos(x),x)
sin(x)
int(x,x=0 .. 1)
1/2
Download int_not_working.mw
@Torre
with(DifferentialGeometry);
with(Tensor);
with(LieAlgebras);
DGsetup([x, y], M);
g1 := evalDG(dx &t dx);
Christoffel(g1);
Error, (in DifferentialGeometry:-Tensor:-Christoffel) expected 1st argument to be a metric tensor. Received: _DG([["tensor", M, [["cov_bas", "cov_bas"], []]], [`...`]])
I still get an error.  I was able to succeed in another example (when I copied the whole maple example.
Somehow, I cannot get the correct syntax.
Any help would be welcome.  The only explanation is that somehow the definition of the neutral tensor operator is missing.
Why Maple 2019.1 gives an error when no initial conditions are given for the following heat PDE with periodic BC?
I am using Physics 426 (current version). On windows 10.
When adding ic as some arbitrary function f(x), then the error goes away. But no ic needs to be given to solve this PDE. The answer can be left using arbitrary constants in this case.
I also found that this seems to happen when the BC are periodic. When using the normal Dirichlet B.C. and omitting the initial conditions, the error went away.
Am I doing something wrong or is this a bug?
pde:=diff(u(x,t),t)=diff(u(x,t),x$2); #try with NO IC
bc:=u(-Pi,t)=u(Pi,t),D[1](u)(-Pi,t)=D[1](u)(Pi,t);
pdsolve([pde,bc],u(x,t))
diff(u(x, t), t) = diff(diff(u(x, t), x), x)
u(-Pi, t) = u(Pi, t), (D[1](u))(-Pi, t) = (D[1](u))(Pi, t)
Error, (in pdsolve/BC/2nd_order/Series/TwoBC) invalid boolean expression: NULL
pde:=diff(u(x,t),t)=diff(u(x,t),x$2)-u(x,t); #now try with IC
ic:=u(x,0)=f(x);
pdsolve([pde,bc,ic],u(x,t)); #solution is correct
diff(u(x, t), t) = diff(diff(u(x, t), x), x)-u(x, t)
u(x, 0) = f(x)
u(x, t) = exp(-t)*_C7[0]+Sum(exp(-t*(n^2+1))*(sin(n*x)*_C1[n]+cos(n*x)*_C7[n]), n = 1 .. infinity)
pde:=diff(u(x,t),t)=diff(u(x,t),x$2); #now try with NO IC, but not periodic BC
bc:=u(0,t)=1,u(Pi,t)=0;
pdsolve([pde,bc],u(x,t)); #solution is correct
u(0, t) = 1, u(Pi, t) = 0
u(x, t) = ((Sum(sin(n*x)*exp(-n^2*t)*_C1(n), n = 1 .. infinity))*Pi+Pi-x)/Pi
Download problem_09_20_2019.mw
I'm pretty annoyed with maple because when I try to create proc's it dooes not use tabbing or smart tabbing. This makes writing readable code a chore. Basically it's always screwing up alignment. (it wants to left justify things a lot)...
What's worse is that using the tab key takes one outside the proc rather than adding a tab, making one having to use spaces.
Any way to fix this?
I have an equation to solve
mu*f = (2*S1*f + S1*x)
where mu is scalar, f is vector, x is vector, S1 is a matrix. I need to solve this equation for f but S1 is matrix sow can I tell Maple that S1 is matrix? If we solve the equation with matrix we need to use matrices inverse. If we have to divide by matrix we use the product of the inverse of this matrix.
First 648 649 650 651 652 653 654 Last Page 650 of 2433
