Please help me for removing an error in my code.
"   restart:     NL:=960:    LL:=4:      BB:=0.6 :  T:=16:    MM:=NL*(LL+1):          for  NC  from 0 by 1 to MM-1  do       S:=BB+(2*Pi*NC/T)*I;          powerFactor := 0.05 * (sqrt(2.0) - 1.202081528);     powerTerm := sqrt(S)*sqrt(49*S^(2)+280*S+800)/sqrt(S+4);       preFactor := 1/((exp(sqrt(2.0)*powerTerm/10.0)-1.0)*S);       XS(NC+1):= preFactor * ((-exp(-powerFactor*powerTerm) + exp(powerFactor*powerTerm)) * exp(sqrt(2.0)*powerTerm/20.0));    end  do;    for  timeCounter from 0 by 1 to  NL-1  do     totalTerm:=0;     for KK from 0 to NL-1 do        for L from 0 to LL do           Term1:=Re(XS(KK+L*NL+1))+I*(Im(XS(KK+L*NL+1)));           Term2:=exp((timeCounter*KK*2*Pi/NL)*I);           totalTerm:=totalTerm+Term1*Term2;        end do     end do     XT(timeCounter+1):=((2.0/T)*exp(BB*timeCounter*T/NL)*(-0.5*Re(XS(1))+Re(totalTerm)));     TT(timeCounter+1):=(timeCounter*T)/NL;         end do    "
Error, invalid loop statement termination
"   restart:    NL:=960:  LL:=4:  BB:=0.6 :  T:=16:    MM:=NL*(LL+1):       for NC  from 0 by 1 to MM-1  do     S:=BB+(2*Pi*NC/T)*I;    powerFactor := 0.05 * (sqrt(2.0) - 1.202081528);   powerTerm := sqrt(S)*sqrt(49*S^2+280*S+800)/sqrt(S+4);    preFactor := 1/((exp(sqrt(2.0)*powerTerm/10.0)-1.0)*S);     XS(NC+1):= preFactor * ((-exp(-powerFactor*powerTerm) + exp(powerFactor*powerTerm)) * exp(sqrt(2.0)*powerTerm/20.0));    end  do;    for timeCounter from 0 by 1 to NL-1  do  totalTerm:=0;     for KK from 0 to NL-1 do        for L from 0 to LL do  Term1:=Re(XS(KK+L*NL+1))+I*(Im(XS(KK+L*NL+1)));  Term2:=exp((timeCounter*KK*2*Pi/NL)*I);  totalTerm:=totalTerm+Term1*Term2;        end do     end do   XT(timeCounter+1):=((2.0/T)*exp(BB*timeCounter*T/NL)*(-0.5*Re(XS(1))+Re(totalTerm)));   TT(timeCounter+1):=(timeCounter*T)/NL;      end do    "
Download
How I can write a code for the determination of Laplacian in a new form that is introduced in the maple code (First line).
FOR
Maple Worksheet - Error
Failed to load the worksheet //convert/FOR
Download FOR
How may I please use maple tools in communication engineering applications. May I please have any example model
There seems to be an issue with pdsolve, which is similar to https://mapleprimes.com/questions/222498-Issues-With-Pdsolve.
pdsolve([diff(u(x, t), t) = diff(u(x, t), x, x), u(x, 0) = 1, u(0, t) = 0, u(2, t) = 0]); # works
pdsolve([diff(u(t, x), t) = diff(u(t, x), x, x), u(0, x) = 1, u(t, 0) = 0, u(t, 2) = 0]); # swapped arguments, works
pdsolve([diff(u(x, t), t) = diff(u(x, t), x, x), u(x, 0) = 1, u(-1, t) = 0, u(1, t) = 0]); # translate by -1, works
pdsolve([diff(u(t, x), t) = diff(u(t, x), x, x), u(0, x) = 1, u(t, -1) = 0, u(t, 1) = 0]); # swapped arguments and translate by -1, doesn't work
The solution for the last example doesn't incorporate the initial condition correctly, while it is the same as the third example (except for swapped arguments). Not sure if this is still a problem in Maple 2019, though.
with(Physics);
with(LinearAlgebra);
N := 4;
Cf := Matrix(6, 6, (z, p) -> C[z, p, 1], shape = symmetric);
sigma[1] := Vector(6, [sigma[1, 1, 1], sigma[2, 2, 1], sigma[3, 3, 1], sigma[1, 2, 1], sigma[1, 3, 1], sigma[2, 3, 1]]);
varepsilon[1] := Vector(6, [varepsilon[1, 1, 1], varepsilon[2, 2, 1], varepsilon[3, 3, 1], gamma[1, 2, 1], gamma[1, 3, 1], gamma[2, 3, 1]]);
sigma[1] := Cf . (varepsilon[1]);
for i from 2 to N do
    C[i] := Matrix(6, 6, (z, p) -> C[z, p, i], shape = symmetric);
    sigma[i] := Vector(6, [sigma[1, 1, i], sigma[2, 2, i], sigma[3, 3, i], sigma[1, 2, i], sigma[1, 3, i], sigma[2, 3, i]]);
    varepsilon[i] := Vector(6, [varepsilon[1, 1, i], varepsilon[2, 2, i], varepsilon[3, 3, i], gamma[1, 2, i], gamma[1, 3, i], gamma[2, 3, i]]);
    sigma[i] := (C[i]) . (varepsilon[i]);
B[1] := 0;
for i to N do
    Parameters(epsilon11c, C[1, 1, i], C[1, 2, i], C[2, 2, i], C[2, 3, i], R[i], A[i], B[i + 1], P);
g[1](r);
ux[1] := (x, r) -> epsilon[1][1]*x + g[1](r);
ur[1] := r -> A[1]*r + B[1]*1/r;
varepsilon[1][1] := epsilon11c;
varepsilon[1][2] := r -> (A[1]*r + B[1]*1/r)*1/r;
varepsilon[1][3] := r -> diff(ur[1](r), r);
varepsilon[1][3](R[2]);
for i from 2 to N - 1 do
g[i](r);
ux[i] := (x, r) -> epsilon[i][1]*x + g[i](r);
ur[i] := r -> A[i]*r + B[i]*1/r;
varepsilon[i][1] := epsilon11c;
varepsilon[i][2] := r -> (A[i]*r + B[i]*1/r)*1/r;
varepsilon[i][3] := r -> diff(ur[i](r), r);
varepsilon[i][2](r); i;
i;
varepsilon[2][2](r);
Hi everyone,
I am currently writing a code on maple and I am finding difficulties in this section.
When I define the functions this way, the result I get from the loop "for" for varepsilon[i][2](r) is the same and doesnt depend on i value. I also tried to define it another way that would give me different results but I would end up with being unable to replace the variable "r" with its values (I would get r(R2)).
I would be grateful if you could advice me with this matter.
Thank you in advance.
How to do the partition of integer?
If I input:
>Partition(10,2)
then output is:
>[[1, 9], [2, 8], [3, 7], [4, 6],[5,5]]
"10" is the number that I want to part,and "2" means that there are "two" number's sum = 10
Sorry my Engilsh is not good,but I really need help.
no other restriction!!
Hi so the Maple 2017 software froze on the loading screen I have a MacBook Air 2018, I tried restarting my Mac but it says I have to Quit out of Maple 2017, however it isn't allowing me to do so, the software won't quit. Is there anyone that can help me out??? I would gladly appreciate it.
Hi everyone
Im new to MaplePrimes aswell as to Maple.
I have a task where i shoud plot the following shape (with a hole in the centre) using the plot3d function:
All i have accomplished in the last hours is the following file A1.0.mw:
As you can see i havent been able to get rid off the surface in the centre nor the spikes on the edge...
  • In order to fix the issue regarding the centre I assume I have to exclude the range -2..2 from x, but havent been able to do so.
  • Regarding the spikes on the edge Im honestly pretty much clueless why they appear in the first place.
After several hours of trying on my own, I really need your help please!
A1.0.mw
f := (x, y) -> ((((((x^2)+(y^2))^(1/2))-4))/(((((x^2)+(y^2))^(1/2))-2)*((((x^2)+(y^2))^(1/2))-6)))+15;
plot3d(f, -6..6, -sqrt(-x^2+36) .. sqrt(-x^2+36), grid=[400,400], view=0..30);
proc (x, y) options operator, arrow; ((y^2+x^2)^(1/2)-4)/(((y^2+x^2)^(1/2)-2)*((y^2+x^2)^(1/2)-6))+15 end proc
Download A1.0.mw
I want to figure out if the Student license offered by Maplesoft for Maple 2019 is perpetual or is just lasts for a year? If it lasts for just 12 months, is there another license I should get which isn't as expensive as the full license? I need it for my personal research.
Solve({(6*(-8*L*alpha^2*a[1]^3+2*L*a[1]^3-2*a[1]^3))*d-24*L*alpha^2*a[0]*a[1]^2+6*L*a[0]*a[1]^2-6*a[0]*a[1]^2+12*alpha^2*k^2*lambda*v*a[1]-12*alpha^2*k^2*lambda*a[1]-3*k^2*lambda*v*a[1]+3*k^2*lambda*a[1]+(3*(8*alpha^2*k^2*v^2*a[1]-16*alpha^2*k^2*v*a[1]+8*alpha^2*k^2*a[1]-2*k^2*v^2*a[1]+4*k^2*v*a[1]-2*k^2*a[1]))*d = 0, (-8*L*alpha^2*a[1]^3+2*L*a[1]^3-2*a[1]^3)*d^6+(-24*L*alpha^2*a[0]*a[1]^2+6*L*a[0]*a[1]^2-6*a[0]*a[1]^2)*d^5+(-24*L*alpha^2*a[0]^2*a[1]-24*L*alpha^2*a[1]^2*a[2]-4*alpha^4*a[1]+6*L*a[0]^2*a[1]+6*L*a[1]^2*a[2]-4*alpha^2*beta*a[1]+alpha^2*a[1]-6*a[0]^2*a[1]-6*a[1]^2*a[2]+beta*a[1])*d^4+(4*alpha^2*k^2*lambda*mu*a[1]-8*L*alpha^2*a[0]^3-48*L*alpha^2*a[0]*a[1]*a[2]-4*alpha^4*a[0]-k^2*lambda*mu*a[1]+2*L*a[0]^3+12*L*a[0]*a[1]*a[2]-4*alpha^2*beta*a[0]+alpha^2*a[0]-2*a[0]^3-12*a[0]*a[1]*a[2]+beta*a[0])*d^3+(-24*L*alpha^2*a[0]^2*a[2]-24*L*alpha^2*a[1]*a[2]^2-4*alpha^4*a[2]+6*L*a[0]^2*a[2]+6*L*a[1]*a[2]^2-4*alpha^2*beta*a[2]+alpha^2*a[2]-6*a[0]^2*a[2]-6*a[1]*a[2]^2+beta*a[2])*d^2+(-4*alpha^2*k^2*lambda*mu*a[2]-24*L*alpha^2*a[0]*a[2]^2+k^2*lambda*mu*a[2]+6*L*a[0]*a[2]^2-6*a[0]*a[2]^2)*d+8*alpha^2*k^2*mu^2*a[2]-2*a[2]^3-2*k^2*mu^2*a[2]-8*L*alpha^2*a[2]^3+2*L*a[2]^3 = 0, (6*(-8*L*alpha^2*a[1]^3+2*L*a[1]^3-2*a[1]^3))*d^5+(5*(-24*L*alpha^2*a[0]*a[1]^2+6*L*a[0]*a[1]^2-6*a[0]*a[1]^2))*d^4+(4*(-24*L*alpha^2*a[0]^2*a[1]-24*L*alpha^2*a[1]^2*a[2]-4*alpha^4*a[1]+6*L*a[0]^2*a[1]+6*L*a[1]^2*a[2]-4*alpha^2*beta*a[1]+alpha^2*a[1]-6*a[0]^2*a[1]-6*a[1]^2*a[2]+beta*a[1]))*d^3+(3*(4*alpha^2*k^2*lambda*mu*a[1]-8*L*alpha^2*a[0]^3-48*L*alpha^2*a[0]*a[1]*a[2]-4*alpha^4*a[0]-k^2*lambda*mu*a[1]+2*L*a[0]^3+12*L*a[0]*a[1]*a[2]-4*alpha^2*beta*a[0]+alpha^2*a[0]-2*a[0]^3-12*a[0]*a[1]*a[2]+beta*a[0]))*d^2+(4*alpha^2*k^2*lambda^2*a[1]+8*alpha^2*k^2*mu*v*a[1]-8*alpha^2*k^2*mu*a[1]-k^2*lambda^2*a[1]-2*k^2*mu*v*a[1]+2*k^2*mu*a[1])*d^3+(2*(-24*L*alpha^2*a[0]^2*a[2]-24*L*alpha^2*a[1]*a[2]^2-4*alpha^4*a[2]+6*L*a[0]^2*a[2]+6*L*a[1]*a[2]^2-4*alpha^2*beta*a[2]+alpha^2*a[2]-6*a[0]^2*a[2]-6*a[1]*a[2]^2+beta*a[2]))*d+12*alpha^2*k^2*lambda*mu*a[2]-24*L*alpha^2*a[0]*a[2]^2-3*k^2*lambda*mu*a[2]+6*L*a[0]*a[2]^2-6*a[0]*a[2]^2+(-4*alpha^2*k^2*lambda^2*a[2]-8*alpha^2*k^2*mu*v*a[2]+8*alpha^2*k^2*mu*a[2]+k^2*lambda^2*a[2]+2*k^2*mu*v*a[2]-2*k^2*mu*a[2])*d = 0, (15*(-8*L*alpha^2*a[1]^3+2*L*a[1]^3-2*a[1]^3))*d^2+(5*(-24*L*alpha^2*a[0]*a[1]^2+6*L*a[0]*a[1]^2-6*a[0]*a[1]^2))*d+(3*(12*alpha^2*k^2*lambda*v*a[1]-12*alpha^2*k^2*lambda*a[1]-3*k^2*lambda*v*a[1]+3*k^2*lambda*a[1]))*d+(3*(8*alpha^2*k^2*v^2*a[1]-16*alpha^2*k^2*v*a[1]+8*alpha^2*k^2*a[1]-2*k^2*v^2*a[1]+4*k^2*v*a[1]-2*k^2*a[1]))*d^2+8*alpha^2*k^2*mu*v*a[1]-6*a[0]^2*a[1]-6*a[1]^2*a[2]-4*alpha^4*a[1]+4*alpha^2*k^2*lambda^2*a[1]-8*alpha^2*k^2*mu*a[1]-2*k^2*mu*v*a[1]-24*L*alpha^2*a[0]^2*a[1]-24*L*alpha^2*a[1]^2*a[2]-k^2*lambda^2*a[1]+2*k^2*mu*a[1]+6*L*a[0]^2*a[1]+6*L*a[1]^2*a[2]-4*alpha^2*beta*a[1]+alpha^2*a[1]+beta*a[1] = 0, (15*(-8*L*alpha^2*a[1]^3+2*L*a[1]^3-2*a[1]^3))*d^4+(10*(-24*L*alpha^2*a[0]*a[1]^2+6*L*a[0]*a[1]^2-6*a[0]*a[1]^2))*d^3+(6*(-24*L*alpha^2*a[0]^2*a[1]-24*L*alpha^2*a[1]^2*a[2]-4*alpha^4*a[1]+6*L*a[0]^2*a[1]+6*L*a[1]^2*a[2]-4*alpha^2*beta*a[1]+alpha^2*a[1]-6*a[0]^2*a[1]-6*a[1]^2*a[2]+beta*a[1]))*d^2+(12*alpha^2*k^2*lambda*v*a[1]-12*alpha^2*k^2*lambda*a[1]-3*k^2*lambda*v*a[1]+3*k^2*lambda*a[1])*d^3+(3*(4*alpha^2*k^2*lambda*mu*a[1]-8*L*alpha^2*a[0]^3-48*L*alpha^2*a[0]*a[1]*a[2]-4*alpha^4*a[0]-k^2*lambda*mu*a[1]+2*L*a[0]^3+12*L*a[0]*a[1]*a[2]-4*alpha^2*beta*a[0]+alpha^2*a[0]-2*a[0]^3-12*a[0]*a[1]*a[2]+beta*a[0]))*d+(3*(4*alpha^2*k^2*lambda^2*a[1]+8*alpha^2*k^2*mu*v*a[1]-8*alpha^2*k^2*mu*a[1]-k^2*lambda^2*a[1]-2*k^2*mu*v*a[1]+2*k^2*mu*a[1]))*d^2+(-12*alpha^2*k^2*lambda*v*a[2]+12*alpha^2*k^2*lambda*a[2]+3*k^2*lambda*v*a[2]-3*k^2*lambda*a[2])*d+8*alpha^2*k^2*mu*v*a[2]-6*a[0]^2*a[2]-6*a[1]*a[2]^2-4*alpha^4*a[2]+4*alpha^2*k^2*lambda^2*a[2]-8*alpha^2*k^2*mu*a[2]-2*k^2*mu*v*a[2]-24*L*alpha^2*a[0]^2*a[2]-24*L*alpha^2*a[1]*a[2]^2-k^2*lambda^2*a[2]+2*k^2*mu*a[2]+6*L*a[0]^2*a[2]+6*L*a[1]*a[2]^2-4*alpha^2*beta*a[2]+alpha^2*a[2]+beta*a[2] = 0, (20*(-8*L*alpha^2*a[1]^3+2*L*a[1]^3-2*a[1]^3))*d^3+(10*(-24*L*alpha^2*a[0]*a[1]^2+6*L*a[0]*a[1]^2-6*a[0]*a[1]^2))*d^2+(4*(-24*L*alpha^2*a[0]^2*a[1]-24*L*alpha^2*a[1]^2*a[2]-4*alpha^4*a[1]+6*L*a[0]^2*a[1]+6*L*a[1]^2*a[2]-4*alpha^2*beta*a[1]+alpha^2*a[1]-6*a[0]^2*a[1]-6*a[1]^2*a[2]+beta*a[1]))*d+(8*alpha^2*k^2*v^2*a[1]-16*alpha^2*k^2*v*a[1]+8*alpha^2*k^2*a[1]-2*k^2*v^2*a[1]+4*k^2*v*a[1]-2*k^2*a[1])*d^3+(3*(4*alpha^2*k^2*lambda^2*a[1]+8*alpha^2*k^2*mu*v*a[1]-8*alpha^2*k^2*mu*a[1]-k^2*lambda^2*a[1]-2*k^2*mu*v*a[1]+2*k^2*mu*a[1]))*d+(3*(12*alpha^2*k^2*lambda*v*a[1]-12*alpha^2*k^2*lambda*a[1]-3*k^2*lambda*v*a[1]+3*k^2*lambda*a[1]))*d^2+(-8*alpha^2*k^2*v^2*a[2]+16*alpha^2*k^2*v*a[2]-8*alpha^2*k^2*a[2]+2*k^2*v^2*a[2]-4*k^2*v*a[2]+2*k^2*a[2])*d+4*alpha^2*k^2*lambda*v*a[2]+2*L*a[0]^3-4*alpha^4*a[0]-48*L*alpha^2*a[0]*a[1]*a[2]+4*alpha^2*k^2*lambda*mu*a[1]-4*alpha^2*k^2*lambda*a[2]-k^2*lambda*v*a[2]-k^2*lambda*mu*a[1]+12*L*a[0]*a[1]*a[2]+k^2*lambda*a[2]-8*L*alpha^2*a[0]^3-12*a[0]*a[1]*a[2]-4*alpha^2*beta*a[0]+alpha^2*a[0]+beta*a[0]-2*a[0]^3 = 0, 8*alpha^2*k^2*v^2*a[1]-8*L*alpha^2*a[1]^3-16*alpha^2*k^2*v*a[1]+8*alpha^2*k^2*a[1]-2*k^2*v^2*a[1]+2*L*a[1]^3+4*k^2*v*a[1]-2*k^2*a[1]-2*a[1]^3 = 0}, {alpha, a[0], a[1], a[2]});
     / /  /          2     3           3         3\
Solve|{ 6 \-8 L alpha  a[1]  + 2 L a[1]  - 2 a[1] / d
               2          2                2              2
   - 24 L alpha  a[0] a[1]  + 6 L a[0] a[1]  - 6 a[0] a[1]
             2  2                         2  2
   + 12 alpha  k  lambda v a[1] - 12 alpha  k  lambda a[1]
        2                    2                 /       2  2  2
   - 3 k  lambda v a[1] + 3 k  lambda a[1] + 3 \8 alpha  k  v  a[
               2  2                 2  2           2  2
  1] - 16 alpha  k  v a[1] + 8 alpha  k  a[1] - 2 k  v  a[1]
        2             2     \        /          2     3
   + 4 k  v a[1] - 2 k  a[1]/ d = 0, \-8 L alpha  a[1]
             3         3\  6
     /           2          2                2              2\  5
   + \-24 L alpha  a[0] a[1]  + 6 L a[0] a[1]  - 6 a[0] a[1] / d  +
  /           2     2                  2     2
  \-24 L alpha  a[0]  a[1] - 24 L alpha  a[1]  a[2]
            4                2                2
   - 4 alpha  a[1] + 6 L a[0]  a[1] + 6 L a[1]  a[2]
            2                  2              2
   - 4 alpha  beta a[1] + alpha  a[1] - 6 a[0]  a[1]
           2                 \  4   /       2  2
   - 6 a[1]  a[2] + beta a[1]/ d  + \4 alpha  k  lambda mu a[1]
              2     3             2
   - 8 L alpha  a[0]  - 48 L alpha  a[0] a[1] a[2]
            4         2                          3
   - 4 alpha  a[0] - k  lambda mu a[1] + 2 L a[0]
                                  2                  2
   + 12 L a[0] a[1] a[2] - 4 alpha  beta a[0] + alpha  a[0]
           3                                \  3   /
   - 2 a[0]  - 12 a[0] a[1] a[2] + beta a[0]/ d  + \
           2     2                  2          2          4
-24 L alpha  a[0]  a[2] - 24 L alpha  a[1] a[2]  - 4 alpha  a[2]
             2                     2          2
   + 6 L a[0]  a[2] + 6 L a[1] a[2]  - 4 alpha  beta a[2]
          2              2                   2            \  2
   + alpha  a[2] - 6 a[0]  a[2] - 6 a[1] a[2]  + beta a[2]/ d  +
  /        2  2                            2          2
  \-4 alpha  k  lambda mu a[2] - 24 L alpha  a[0] a[2]
      2                               2              2\
   + k  lambda mu a[2] + 6 L a[0] a[2]  - 6 a[0] a[2] / d
            2  2   2              3      2   2
   + 8 alpha  k  mu  a[2] - 2 a[2]  - 2 k  mu  a[2]
              2     3           3        /          2     3
   - 8 L alpha  a[2]  + 2 L a[2]  = 0, 6 \-8 L alpha  a[1]
             3         3\  5
       /           2          2                2              2\
   + 5 \-24 L alpha  a[0] a[1]  + 6 L a[0] a[1]  - 6 a[0] a[1] /
   4     /           2     2                  2     2
  d  + 4 \-24 L alpha  a[0]  a[1] - 24 L alpha  a[1]  a[2]
            4                2                2
            2                  2              2
           2                 \  3     /       2  2
   - 6 a[1]  a[2] + beta a[1]/ d  + 3 \4 alpha  k  lambda mu a[1]
              2     3             2
            4         2                          3
                                  2                  2
           3                                \  2   /       2  2
   - 2 a[0]  - 12 a[0] a[1] a[2] + beta a[0]/ d  + \4 alpha  k
        2               2  2                    2  2
  lambda  a[1] + 8 alpha  k  mu v a[1] - 8 alpha  k  mu a[1]
      2       2           2                2        \  3     /
   - k  lambda  a[1] - 2 k  mu v a[1] + 2 k  mu a[1]/ d  + 2 \
           2     2                  2          2          4
             2                     2          2
          2              2                   2            \
             2  2                            2          2
   + 12 alpha  k  lambda mu a[2] - 24 L alpha  a[0] a[2]
        2                               2              2   /
   - 3 k  lambda mu a[2] + 6 L a[0] a[2]  - 6 a[0] a[2]  + \
        2  2       2               2  2
-4 alpha  k  lambda  a[2] - 8 alpha  k  mu v a[2]
            2  2            2       2           2
   + 8 alpha  k  mu a[2] + k  lambda  a[2] + 2 k  mu v a[2]
        2        \           /          2     3           3
   - 2 k  mu a[2]/ d = 0, 15 \-8 L alpha  a[1]  + 2 L a[1]
           3\  2
   - 2 a[1] / d
       /           2          2                2              2\
   + 5 \-24 L alpha  a[0] a[1]  + 6 L a[0] a[1]  - 6 a[0] a[1] / d + 3
  /        2  2                         2  2
  \12 alpha  k  lambda v a[1] - 12 alpha  k  lambda a[1]
        2                    2            \       /       2  2  2
   - 3 k  lambda v a[1] + 3 k  lambda a[1]/ d + 3 \8 alpha  k  v
                 2  2                 2  2           2  2
  a[1] - 16 alpha  k  v a[1] + 8 alpha  k  a[1] - 2 k  v  a[1]
        2             2     \  2          2  2
   + 4 k  v a[1] - 2 k  a[1]/ d  + 8 alpha  k  mu v a[1]
           2              2               4
   - 6 a[0]  a[1] - 6 a[1]  a[2] - 4 alpha  a[1]
            2  2       2               2  2
   + 4 alpha  k  lambda  a[1] - 8 alpha  k  mu a[1]
        2                       2     2
   - 2 k  mu v a[1] - 24 L alpha  a[0]  a[1]
               2     2         2       2           2
   - 24 L alpha  a[1]  a[2] - k  lambda  a[1] + 2 k  mu a[1]
             2                2               2
   + 6 L a[0]  a[1] + 6 L a[1]  a[2] - 4 alpha  beta a[1]
          2                          /          2     3
   + alpha  a[1] + beta a[1] = 0, 20 \-8 L alpha  a[1]
             3         3\  3
        /           2          2                2              2\
   + 10 \-24 L alpha  a[0] a[1]  + 6 L a[0] a[1]  - 6 a[0] a[1] /
   2     /           2     2                  2     2
            4                2                2
            2                  2              2
           2                 \     /       2  2  2
   - 6 a[1]  a[2] + beta a[1]/ d + \8 alpha  k  v  a[1]
             2  2                 2  2           2  2
        2             2     \  3     /       2  2       2
   + 4 k  v a[1] - 2 k  a[1]/ d  + 3 \4 alpha  k  lambda  a[1]
            2  2                    2  2
      2       2           2                2        \       /
   - k  lambda  a[1] - 2 k  mu v a[1] + 2 k  mu a[1]/ d + 3 \12
       2  2                         2  2
        2                    2            \  2   /
   - 3 k  lambda v a[1] + 3 k  lambda a[1]/ d  + \
        2  2  2                2  2                 2  2
-8 alpha  k  v  a[2] + 16 alpha  k  v a[2] - 8 alpha  k  a[2]
        2  2           2             2     \
   + 2 k  v  a[2] - 4 k  v a[2] + 2 k  a[2]/ d
            2  2                         3          4
   + 4 alpha  k  lambda v a[2] + 2 L a[0]  - 4 alpha  a[0]
               2                         2  2
   - 48 L alpha  a[0] a[1] a[2] + 4 alpha  k  lambda mu a[1]
            2  2                2
   - 4 alpha  k  lambda a[2] - k  lambda v a[2]
      2                                         2
   - k  lambda mu a[1] + 12 L a[0] a[1] a[2] + k  lambda a[2]
              2     3                              2
   - 8 L alpha  a[0]  - 12 a[0] a[1] a[2] - 4 alpha  beta a[0]
          2                          3         /          2     3
   + alpha  a[0] + beta a[0] - 2 a[0]  = 0, 15 \-8 L alpha  a[1]
             3         3\  4
        /           2          2                2              2\
   3     /           2     2                  2     2
  d  + 6 \-24 L alpha  a[0]  a[1] - 24 L alpha  a[1]  a[2]
            4                2                2
            2                  2              2
           2                 \  2   /        2  2
   - 6 a[1]  a[2] + beta a[1]/ d  + \12 alpha  k  lambda v a[1]
             2  2                  2
   - 12 alpha  k  lambda a[1] - 3 k  lambda v a[1]
        2            \  3     /       2  2
   + 3 k  lambda a[1]/ d  + 3 \4 alpha  k  lambda mu a[1]
              2     3             2
            4         2                          3
                                  2                  2
           3                                \       /       2  2
   - 2 a[0]  - 12 a[0] a[1] a[2] + beta a[0]/ d + 3 \4 alpha  k
        2               2  2                    2  2
      2       2           2                2        \  2   /
   - k  lambda  a[1] - 2 k  mu v a[1] + 2 k  mu a[1]/ d  + \
         2  2                         2  2
-12 alpha  k  lambda v a[2] + 12 alpha  k  lambda a[2]
        2                    2            \
   + 3 k  lambda v a[2] - 3 k  lambda a[2]/ d
            2  2                   2                   2
   + 8 alpha  k  mu v a[2] - 6 a[0]  a[2] - 6 a[1] a[2]
            4               2  2       2
   - 4 alpha  a[2] + 4 alpha  k  lambda  a[2]
            2  2              2
   - 8 alpha  k  mu a[2] - 2 k  mu v a[2]
               2     2                  2          2
   - 24 L alpha  a[0]  a[2] - 24 L alpha  a[1] a[2]
      2       2           2                   2
   - k  lambda  a[2] + 2 k  mu a[2] + 6 L a[0]  a[2]
                  2          2                  2
   + 6 L a[1] a[2]  - 4 alpha  beta a[2] + alpha  a[2]
                           2  2  2                 2     3
   + beta a[2] = 0, 8 alpha  k  v  a[1] - 8 L alpha  a[1]
             2  2                 2  2           2  2
             3      2             2              3    \
   + 2 L a[1]  + 4 k  v a[1] - 2 k  a[1] - 2 a[1]  = 0 },
  {alpha, a[0], a[1], a[2]}|
Dear Users!
Hope you would be fine. I want to export .dat file from 2D plots in attached file. But facing some problem. Please have a look and try to fix it.
Many thanks
2._SP_alpha_varies.mw
Special request:
@Carl Love
@acer
@Kitonum
Maple is very good in solving PDE's. But this specific solution seems way too complicated when compared to Matematica solution, which I verified using Maple pdetest to be correct.
Is there a way to make Maple produce the simpler solution to this pde? simplify does nothing on the solution. May be by using a good HINT or such other option?
pde:=(a*y+b*x+c)*diff(w(x,y),x)-(b*y+k*x+s)*diff(w(x,y),y)=0;
(a*y+b*x+c)*(diff(w(x, y), x))-(b*y+k*x+s)*(diff(w(x, y), y)) = 0
sol:=pdsolve(pde,w(x,y))
w(x, y) = _F1(1/(a^3*k^2*y^2-2*a^2*b^2*k*y^2+2*a^2*b*k^2*x*y+a^2*k^3*x^2+a*b^4*y^2-4*a*b^3*k*x*y-2*a*b^2*k^2*x^2+2*b^5*x*y+b^4*k*x^2+2*a^2*c*k^2*y+2*a^2*k^2*s*x-4*a*b^2*c*k*y-4*a*b^2*k*s*x+2*b^4*c*y+2*b^4*s*x+a^2*k*s^2-a*b^2*s^2-2*a*b*c*k*s+a*c^2*k^2+2*b^3*c*s-b^2*c^2*k)^(1/2))
mma_solution := w(x,y)= _F1( (2*s*x+k*x^2+2*c*y+2*b*x*y+a*y^2)/a );
w(x, y) = _F1((a*y^2+2*b*x*y+k*x^2+2*c*y+2*s*x)/a)
pdetest(mma_solution,pde)
Here is screen shot showing the other solution
Download q1.mw
hello!
I'm new in Maple!!
I am try simulate the termal flux in composite material using heat equation and perfect contact between the materials. But I can't enter the fourier condiction and my code don't work!!
Any help??
> restart; with(plots); with(PDEtools); with(plottool
> eq1 := diff(u1(x, t), x, x) = k1*(diff(u1(x, t), t));
                    d  / d          \      / d          \
                   --- |--- u1(x, t)| = k1 |--- u1(x, t)|
                    dx \ dx         /      \ dt         /
> eq2 := diff(u2(x, t), x, x) = k1*(diff(u2(x, t), t));
                    d  / d          \      / d          \
                   --- |--- u2(x, t)| = k1 |--- u2(x, t)|
                    dx \ dx         /      \ dt         /
> L := 10; v1 := 20; v2 := 10; k1 = 10; k2 := 20;
                                     10
                                     20
                                     10
                                   k1 = 10
                                     20
> bc1 := u1(0, t) = v1, u1(x, 0) = 0;
                         u1(0, t) = 20, u1(x, 0) = 0
> bc2 := u2(0, t) = v2, u2(x, 0) = 0;
                         u2(0, t) = 10, u2(x, 0) = 0
> sol1 := pdsolve({bc1, eq1});
Warning: System is inconsistent
I would like to display a complete trigonometric circle.like the attached photo. How to do it? Thanks
TrigonometricCircle.mw
It is necessary that the expressions are combined in a new function. So as I'm trying not is obtained.
restart; x := 5; y := 10; f := proc (x, y) options operator, arrow; x+y end proc; f2 := proc (x, y) options operator, arrow; x^2+y^3 end proc; f3 := proc (x, y) options operator, arrow; f+f2 end proc; f3(x, y)
5
10
f+f2
Download testmaple.mw
First 692 693 694 695 696 697 698 Last Page 694 of 2433
