Suppose that we have a set of differential equations as follows
and we want to write the above equation as a matrix form  ( for convenience, Let upper limit of summations be 2, not infinity )
QUESTION: How to find the coefficients of Matrix Dif. equations (matrices M, C, K, f, D) by MAPLE? MY TRY: question.mw
We can find the matrices by hand as follows: (But how to derive the matrices directly from the equation in the first picture by Maple)
restart:with(LinearAlgebra):with(plots):interface(rtablesize=36):
with(Physics): #for KroneckerDelta
N:=2:
p:=2:
A:=Matrix(N,1):
B:=Matrix(N,1):
for n from 1 to N do
A(n,1):=diff(phi[n](t),t,t)+2*gamma*add(sin(n*Pi*v0*tau)*sin(j*v0*Pi*tau)*diff(phi[j](tau),tau,tau),j=1..N)+4*gamma*Pi*v0*add(j*sin(n*Pi*v0*tau)*cos(j*v0*Pi*tau)*diff(phi[j](tau),tau),j=1..N)+n^4*Pi^2*phi[n]-2*gamma*add( (j*Pi*v0^2)*sin(n*Pi*v0*tau)*sin(j*v0*Pi*tau)* phi[j](tau),j=1..N):
B:=Matrix(N,1):
B(n,1):=gamma*Pi^3/2*sin(n*Pi*v0*tau)+add( U[i](tau)*sin(n*Pi*eta[i]),i=1..p):
# in order to make ensure, let's look backwards
r:=2:
M:=Matrix(r,r):
C:=Matrix(r,r):
K:=Matrix(r,r):
for n from 1 to r do
for j from 1 to r do
M(n,j):=KroneckerDelta[n,j]+2*gamma*sin(n*Pi*v0*tau)*sin(j*Pi*v0*tau);
C(n,j):=4*gamma*Pi*v0*j*sin(n*Pi*v0*tau)*cos(j*Pi*v0*tau):
K(n,j):=n^4*Pi^2*KroneckerDelta[n,j]-2*gamma*(j*Pi*v0)^2*sin(n*Pi*v0*tau)*sin(j*Pi*v0*tau):
f:=Matrix(r,1):
X:=Matrix(r,1):
U:=Matrix(r,1):
f(n,1):=gamma*Pi^3/2*sin(n*Pi*v0*tau);
X(n,1):=phi[n](tau):
U(n,1):=u[n](tau):
DD:=Matrix(r,p):
for i from 1 to p do
DD(n,i):=sin(n*Pi*eta[i]);
 M*diff(X,tau,tau)+ C*diff(X,tau)+ K*X=f+DD.U;
quest.mw
Hi, I'm stuck on how to create a procedure, 'Arrange' that sorts a list of integers so that the numbers go from smallest to largest. So if I have a list such as: [3,6,1,9,0,4] ,
Arrange([3,6,1,9,0,4]) = [0,1,3,4,6,9]
I have a procedure that produces a sequence where we denote 'x' as the first number in the list, and returns: a list of all the numbers in the list less than x, x, a list of all the numbers greater than x.
i.e. returns: [1, 0], 3, [6, 9, 4]
Arrange := proc(L)
local L1,L2,n,x,i;
L1:=[];
L2:=[];
n:=nops(L):
if n=0 then
print('NULL')
elif n=1 then
return L[1];
elif n>1 then
x:= L[1];
for i from 2 to n do
if L[i] < x then
L1:=[L1[],L[i]]:
L2:=[L2[],L[i]]:
end if:
end if:
return L1,x,L2;
could anyone help on how I can expand on this to get the procedure that I want?
p.s. I know that there is already an inbuilt 'sort' function in Maple, but I'm trying to create the procedure myself!
Good day.
I have a problem with the numerical approximation of incomplete elliptic integrals of the first kind in the case when the argument and the modulus are complex numbers.
Let's consider an incomplete elliptic integral of the first kind EllipticF((a+I*b)*x, c+I*d), where a,b,c,d are arbitrary real numbers and x is very large number. Here is the code:
R0 := EllipticF((a+I*b)*x, c+I*d);
with(MultiSeries, series):
R1 := series(R0, x = infinity, 2);
a := .5; b := 1.75; c := 10; d := 12.5; x := 10^6;
evalf(R0); evalf(R1);
Below you can see that answers are different
.1680611942+.2058775337*I
-0.4563467782e-1-.3592094173*I+O(1/1000000000000000000)
While the same code for an incomplete elliptic integral of the second kind gives the correct approximation:
R00 := EllipticE((a+I*b)*x, c+I*d);
R11 := series(R00, x = infinity, 2);
evalf(R00); evalf(R11);
-1.687498740*10^7+2.374999011*10^7*I
-1.687501260*10^7+2.375000989*10^7*I+O(1/1000000)
What is the difference?
I have a question that concerns visualising the output of a simple matrix. For instance, take a 4 x 10 matrix in the example attached (rows are denoted by i and columns, j) with entries either 0 or 1. This gives the on/off relationship between any i and j. Let i and j denote 2-dimensional locations whose coordinates are known. The matrix gives the connections (1's) between both locations; 0's otherwise.
Can Maple output a map that visually represents the connections between nodes?
In the example here, I wish to plot location 2 (in i) connected to location 3 (in j), location 3 (in i) connected to location 1 (in j), and so on. Can I output a plot / map that presents the nodes with radiating / connecting arrows?
I'm hoping someone can help, since the matrix form is not quite appealing for a large number of entries.
Thanks for reading!
A := Matrix(4, 10, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (1, 8) = 0, (1, 9) = 0, (1, 10) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 1, (2, 4) = 1, (2, 5) = 0, (2, 6) = 1, (2, 7) = 0, (2, 8) = 0, (2, 9) = 0, (2, 10) = 1, (3, 1) = 1, (3, 2) = 1, (3, 3) = 0, (3, 4) = 0, (3, 5) = 1, (3, 6) = 0, (3, 7) = 1, (3, 8) = 1, (3, 9) = 1, (3, 10) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0, (4, 8) = 0, (4, 9) = 0, (4, 10) = 0})
Download Matrix_Plot_Question.mw
Hello dear freinds
when i solve the ode i found exponential solutions.i want to find trignometric solutions of an ode.
I am attaching maple file..
Thanks for ur cooperation.file.mw
the foolowing code is for contour plot at Delta =-12.71 but there is somthing coulnd understand not works
I dont know why this not work
Omega:=0:lambda:=1:
gamma1:=8*Pi:
gamma2:=0.002*Pi:
x1:=100*Pi:
omega2:=200*Pi:
gamma0:=0.2*Pi:
G:=20*Pi:
lambda1:=(1/(2*Pi))*(G*Omega*gamma0/(2*(0.25*gamma0^2+Delta^2))):
lambda2:=(1/(2*Pi))*(-G*Omega*Delta/((0.25*gamma0^2+Delta^2))):
lambda3:=(1/(2*Pi))*gamma1+lambda1:
lambda4:=(1/(2*Pi))*(lambda*Delta-G^2*Delta/(0.25*gamma0^2+Delta^2)):
lambda5:=(1/(2*Pi))*(2*x1^2*omega2/((omega2^2+gamma2^2))):
f:=epsilon=(lambda1+sqrt(-lambda2^2+Y^2*(lambda3^2+(lambda4-lambda5*Y^2)^2))):
implicitplot3d(f, epsilon=0..20,Y = 0 .. 1,Delta=-40*Pi..40*Pi, labels=[epsilon,X,Delta],tickmarks=[3,3,3],style=surface);
contourplot(solve(f,Delta),epsilon=-20..20,Y=0..1,contours=[-12.71],axes=boxed,thickness=2,color=black,font=[1,1,18],tickmarks=[2, 2],linestyle=1, numpoints=50000);
Dear Community,
I would like to have a 3D matrix, where each of the matrix elements is a collection of different kind of data, e.g. integers, real (float) numbers, logical variable, 1D vector of integers or reals, 1D vector of logical variables, etc. In other words I would like to store a collection of different data on a 3D grid. This collection is of course identical for all grid points, i.e. matrix elements. I experimented with DataFrames, but it did not allow me to use vectors. How could I realize such a structure in Maple? It is done quite easily in MATLAB e.g. with the "struct" command, or in FORTRAN with the "Type" command.
Many tx in advance,
best regards
Andras
HI all,
Let all variables be integers here.
I am trying to search 3 variables , "A","B",and "C" so that f(A*x2+B*x+C) factors into two binomials.
Here, f(y) = y2+y+19.
Choose a search space of 0<A<10 and 0<B<30 and 0<C<100.
I am having some trouble with my Maple code.
Here is how far I got -
Maple_coefficient_search_broken.mw
Maple_coefficient_search_broken.pdf
Matt
I want to visualize data provided by the Maximize command. The output I get is of the following form (example):
 [.358700275060090779, [p[0] = .192413186080606, p[1] = 0.906594292940704e-1, p[2] = 0.677108912885780e-1, p[3] = 0.609551830556988e-1, p[4] = 0.589744573790909e-1, p[5] = 0.585737058072817e-1, p[6] = 0.589744573787748e-1, p[7] = 0.609551830550955e-1, p[8] = 0.677108912877626e-1, p[9] = 0.906594292931833e-1, p[10] = .192413186079858]]
I want to plot the sequence p[0], ..., p[10] with the command LineChart (for example).
My question is: How to automatically "clean up" output as above so I can feed it to LineChart?
with(DifferentialGeometry): with(Tensor):
DGsetup([x1, x2, x3, x4], M)
g1 := evalDG(dx1dx3+dx2dx4-u22(dx3)^2-u11(dx4)^2+2*u12*dx3dx4)
C1 := Christoffel(g1)
^^^ This is my code, I know theres something wrong with the metric but I'm not sure what, any help would be appreciated thanks! (This code gives me no answer).
u11*u22-u12^2+u13+u24 = 0   - This is the original eq I was working off.
I need code for finding the order of convergence of helleys method its really urgent please help
Dear members,
Having learnt the use of parse, I tried making a document with module. The document works fine. But I could not not take the codes inside the ComboBoxes inside module UpdateExpr().
Also initialisation does not work since parse command is not allowed by maple here as can be seen by the output in MathContainer_fplusx below.
The document works fine after executing !!!.
Can any one help me avoid all the codes inside combobox except the UpdateExpr() code, please? Thanks.
Ramki.
Composition of Functions
Select f(x) and g(x)
 f(x)*is
  g(x)*is
(f+g)(x)
Download Composition_of_Functions_Doubt.mw
Does maple has an in-built command for levy distribution? Thank you.
First 719 720 721 722 723 724 725 Last Page 721 of 2433
