A002487 := proc (m) local a, b, n; option remember; a := 1; b := 0; n := m; while 0 < n do if type(n, odd) then b := a+b else a := a+b end if; n := floor((1/2)*n) end do; b end proc; listeinverse := proc (L::list) local i; [seq(op(nops(L)-i, L), i = 0 .. nops(L)-1)] end proc; Brocot := proc (n) local c, i, L, M, r; L := NULL; r := 2^n; L := [seq(A002487(i), i = 0 .. r)]; M := listeinverse(L); c[0] := 0, 1/cat(0); for i to r do c[i] := L[i]/M[i] end do; c[r+1] := 1/cat(0); return [seq(c[i], i = 1 .. r+1)], r+1 end proc; for i from 0 to 4 do B || i := Brocot(i) end do;
                              [   1]
                        B0 := [0, -], 2
                              [   0]
                             [      1]
                       B1 := [0, 1, -], 3
                             [      0]
                          [   1        1]
                    B2 := [0, -, 1, 2, -], 5
                          [   2        0]
                    [   1  1  2     3        1]
              B3 := [0, -, -, -, 1, -, 2, 3, -], 9
                    [   3  2  3     2        0]
       [   1  1  2  1  3  2  3     4  3  5     5        1]
 B4 := [0, -, -, -, -, -, -, -, 1, -, -, -, 2, -, 3, 4, -], 17
       [   4  3  5  2  5  3  4     3  2  3     2        0]
              rang := proc(M::list, a)  ...  end;;
                    /       1\
                rang|B2[1], -|;
                    \       2/
                / d        \
                |--- don(x)| t work;
                \ dx       /
F := proc (N) local a, b, L; L := NULL; L := sort([op({seq(seq(a/b, a = 0 .. b), b = 1 .. N)})]); return L, nops(L) end proc; F(1); F(2); F(3); F(4);
                           [0, 1], 2
                          [   1   ]
                          [0, -, 1], 3
                          [   2   ]
                       [   1  1  2   ]
                       [0, -, -, -, 1], 5
                       [   3  2  3   ]
                    [   1  1  1  2  3   ]
                    [0, -, -, -, -, -, 1], 7
                    [   4  3  2  3  4   ]
rang(F(3)[1], 2/3);
                        /[   1  1  2   ]  2\
                    rang|[0, -, -, -, 1], -|
                        \[   3  2  3   ]  3/
Hi everyone, I have some symbolic expressions as below:
local(Zeta);
Zeta := phi+(Ems+I*Eml)/(Ef-Ems-I*Eml)+(3*(1-phi))*((1-g)*alpha^2-(1/2)*g)/(alpha^2-1):
g := (1/2)*Pi*alpha:
Lambda := (1-phi)*((3*(alpha^2+.25))*g-2*alpha^2)/(alpha^2-1):
Ec := (Ems+I*Eml)/(1-(1/4)*phi*(1/Zeta+3/(Zeta+Lambda))):
a := simplify(Re(Ec)), assuming positive;
the output of the code maple gives me as 'a' is very long and boring! Therefore I want to make it shorter. Since (alpha<<1), I want to set a constraint as (alpha^(2 and more than 2)=0). How can I put that constraint on the output? thanks
sort(abs(z+a+b*i),z,descending) mean type z is sign + but print -z+5i-5
ran := rand(-5 .. 5); -1; a := ran(); -1; b := ran(); -1; sort(abs(b*i+a+z), z, descending)
abs(-z+5*i-5)
Can you help me?
Thank you very much.
Download abs.mw
help pls how to convert a data surface into a region:
surfdata([[1, 1, .69], [1, 2, .48], [2, 1, .37], [2, 2, .44]], axes = frame, labels = [x, y, z], filled = true)
I've tried to fill the volume below using the option "filled " without any results. I will appreciate any suggestion
After getting help from users on this list, I wrote an example on how to iterate a discrete map using a given initial condition as follows:
restart:with(ListTools):
NestList := proc (f, x, n::nonnegint, nprec::posint := 10) local R, k; R := rtable(0 .. n, [x]); Digits := nprec; for k to n do R[k] := expand(f(R[k-1])) end do; [seq(R)] end proc:
logistic := proc (x) options operator, arrow; 4*x*(1-x) end proc:
fp := [solve((logistic@@5)(x) = x, x)]:
cfp := allvalues(fp[5]);
nstep:=12:
p := nstep+50;
aaa := Flatten(map(`~`[Re], evalf(NestList(logistic, evalf(cfp), p))));
dat := [seq([i-nstep-1, aaa[i]], i = 1 .. p)];
plot(dat, style = pointline, symbol = solidcircle, symbolsize = 4, thickness = 0, view = [default, 0 .. 1]);
The result should be a period 5 and some chaotic data due to machine precision. However the trajectory ejected to infinity. I have tried with a different initial condition, say 0.1, and it worked just fine. Even if the precision is increased, the trajectory (orbit) will eventually eject to infinity.  I couldn't spot what is wrong.
I am running Maple 2017 on linux and on a mac.
Many thanks
Ed
I need help creating a proceadure that does the following:
It takes two lists of the same length N   (0<N<inf), one is the numerical pivote list P and the other is a symbolic target list S.
Lets say for the simple case of N=3 that we input:
P=[22.5,14.3,78.2]
S=[x[1],x[2],x[3]]
First the proceadure will sort the Pivote list P, which will result in a local variable Ps=[14.3,22.5,78.2]
Next it will generate the rearanged indices of S when it was transformed into Ps, meaning the sort indices rearangment from [1,2,3] in S into [2,1,3] in Ps. This will result in another local variable PSI=[2,1,3]
Finally, the proceadure will use PSI to rearange (sort by proxy) the target list P, which in this case will result in the folowing output of [x[2],x[1],x[3]], where x[i] can be either symbolic variable or numeric.
So what I need is to use numeric list P to sort a non numeric list S of the same size.
I'd appreciate any tips or usefule commands that I can use in this proceadure.
how to code matrix X properly? I want the index of element of matrix is obtained from set S. Since s = {1,5,6}, in matrix X, i should get x11,x15,x16 and so on.
Do you know how to solve this?
Thank you anyway
Hi people,
I could not find anything similar. I hope I do not repeat and that someone may help me on this one.
How can I most elegantly and quickly create a vector (array, matrix, ...) of individual time dependent variables in Maple 17? Something like
myArray := ( (elem_1_1(t), elem_2_1(t), ...), (elem_1_2(t), elem_2_2(t), ...), ... )
All suggetions appreciated.
the function rationalize simplify rational expression that contains complicated expression but in this example it doesn't work
rationalize(1/sqrt(x))
1/sqrt(x)
it gives to me the same expression why ?
N := int((x-Q)^m*f(x), x = Q .. infinity)
Cost := a*N
a*(int((x-Q)^m*f(x), x = Q .. infinity))
Dcost := diff(Cost, Q)
a*(int(-(x-Q)^m*m*f(x)/(x-Q), x = Q .. infinity))
Val := eval(Dcost, [m = 2, f(x) = 1/5000, co = 25, cs = 15])
-a*infinity
Download dummy.mw
How come I got this:
as an output of plot(sqrt(Pi/(2*x))*BesselJ(3+1/2, x), x = 0 .. 0.5e-1),
and got this:
for plot(sqrt(Pi/(2*x))*BesselJ(3+.5, x), x = 0 .. 0.5e-1).
Is 1/2 so much different from 0.5 to make Bessel function misbehave at small arguments?? Or is it just a bug?
Hello Please,
I have been have difficulty generation a random number from a regression model.
Could you please help me out?
For example; Suppose I want to generate random number from Possion model, I trying using the codes below but not working
 Please, help me edit it.
Jamiu Olumoh
What value of 'a' gives the best fit for the line y=3x+a to pts[[3,4],[5,6],[21,16]] ?
I'm getting errors using LinearFit from the Statistics package but maybe I'm not using it right.
pts1 := Vector([3, 5, 21]);
pts2 := Vector([4, 6, 16]);
with(Statistics);
L := LinearFit(3*x+a, pts1, pts2, a);
Hi everyone, I want to simplify a complex symbolic expression and then separate it to the real and imaginary part in maple. The expression is as below:
Ec := (Ems+I*Eml)*(1+((Ems+I*Eml)/Ef-1)*Zeta*phi/((Ems+I*Eml)/Ef+Zeta))/(1-((Ems+I*Eml)/Ef-1)*phi/((Ems+I*Eml)/Ef+Zeta));
All the constants are positive. Can anyone help?
I want to compute a limit via maple and that it will show me the way how to compute the limit.
The limit is:
\lim_{epsilon ->0, t\in [0,1]} 1/(exp((-1+(1-4*epsilon)^(0.5))/(2*epsilon))-exp((-1-(1-4*epsilon)^(0.5))/(2*epsilon)))*[exp((-1+(1-4*epsilon)^(0.5))/(2*epsilon)*t)-exp((-1-(1-4*epsilon)^(0.5))/(2*epsilon)*t)]/(exp(1-t)-exp(1-t/(epsilon)))
According to my book it should converge to 1.
I tried manually but got stuck.
First 726 727 728 729 730 731 732 Last Page 728 of 2433
