Some definition of n! where n are the negative integers is taken to be infinity. (this is Gamma function for negative integers).
https://en.wikipedia.org/wiki/Gamma_function
So 1/(-1)!  should be zero. And that is what Mathematica gives
But Maple does not like (-1)!, it gives division by zero, I assume because it is not using the above definition using Gamma function.  But then how come Maple is able to find correctly this sum
sum(1/factorial(n-1),n=0..infinity)
Which is exp(1).   The first term above, when n=0 is   1/(-1)!  which Maple does not like. Because if we take the first term as 1/infinity=0 then the sum is the same as if we had
sum(1/factorial(n-1),n=1..infinity)
And now it is exp(1) with no problem dealing with negative integer factorial.
Question is: Since Maple does not like negative integer factorial, how comes it accepted the above sum, whose first term contain negative integer factorial?
Just wondering how it did the above, that is all. When I solved this by hand, I used 1/(-1)! = 0 to be able to sum it.
Does anyone know of the simplest way to insert  a new line, or carriage return in a Maple Startup Script ?
I am brand new to Maple, so I really don't have a clue what I am doing, but essentially, I would like my new worksheet to start two lines down from the top.  I cannot seem to get the Startup Script to do this.
I have tried several things, and cannot find anything that works.
Any ideas ?
pellsolve := proc (D::posint) local P, Q, a, A, B, i; if type(sqrt(D), integer) then error "D must be a nonsquare integer" end if; P := 0; Q := 1; a := floor(sqrt(D)); A := 1, a; B := 0, 1; for i do P := a*Q-P; Q := (D-P^2)/Q; a := floor((P+sqrt(D))/Q); A := A[2], a*A[2]+A[1]; B := B[2], a*B[2]+B[1]; if Q = 1 and `mod`(i, 2) = 0 then break end if end do; return A[1], B[1] end proc;
pellsolve(107);
                            962, 93
isolve(x^2-107*y = 13);
       /                             2             \
      { x = 21 - 107 _Z1, y = 107 _Z1  - 42 _Z1 + 4 },
         /                             2               \
        { x = 86 - 107 _Z1, y = 107 _Z1  - 172 _Z1 + 69 }
genpellsolve := proc (D::posint, N::integer) local t, u, L1, L2, sols, x, y; if type(sqrt(D), integer) then error "D must be a nonsquare integer" end if; t, u := pellsolve(D); if 0 < N then L1 := 0; L2 := floor(sqrt((1/2)*N*(t-1)/D)) elif N < 0 then L1 := ceil(sqrt(-N/D)); L2 := floor(sqrt(-(1/2)*N*(t+1)/D)) else return {[0, 0]} end if; sols := {}; for y from L1 to L2 do x := sqrt(N+D*y^2); if type(x, integer) then sols := sols union {[x, y]}; if `mod`(x^2+D*y^2, N) <> 0 or `mod`(2*x*y, N) <> 0 then sols := sols union {[-x, y]} end if end if end do; DEBUG(); return sols end proc;
Debug inefficace
I have converted a single large worksheet into a workbook comprising many worksheets.  One of the worksheets contains start-up code.  Is that start-up code (which includes numerous subroutines/functions) automatically available/accessible/executable by all the other worksheets in the workbook?
Melvin
Is there any formula in maple to find simplex multipliers vector?
I have this animation that displays a particle's position after reflection from a shock (the blue plane). I want to add a line that shows the particle coming in and reflecting and have them animate sequentially, but I cannot figure out how. The line should travel along the b axis, but offset in the xi axis to end where the helix begins. Here is the code for the helix animation:
restart; with(VectorCalculus); with(Student[LinearAlgebra]); with(plots);
v[i] := 145000; thetabn := (1/8)*Pi; thetavn := (1/6)*Pi; k := 10; omegac := .5;
v[b] := cos(2*thetabn)/cos(thetabn); v[g] := sin(2*thetabn)/cos(thetabn);
n := `<,>`(k*cos(thetabn), k*sin(thetabn), 0);
vr:=
[v[b]*t, v[g]*sin(omegac*t)/omegac, v[g]*cos(omegac*t)/omegac];
lambda := v[i]*cos(thetavn)/cos(thetabn);
shockplot := PlanePlot(n, caption = "", planeoptions = [colour = blue, transparency = .5], normaloptions = [shape = cylindrical_arrow, colour = red]);
t1 := textplot3d([k*cos(thetabn), k*sin(thetabn), 0, 'n'], align = above);
display(plots[animate](plot3d, [[v[b]*t, v[g]*sin(omegac*t)/omegac, v[g]*cos(omegac*t)/omegac], t = 0 .. x], x = 0 .. 6*Pi, axes = normal, colour = red, labels = ["b", zeta, xi], thickness = 2, paraminfo = false), shockplot, t1, scaling = constrained, tickmarks = [0, 0, 0]);
The Question:
'Produce a list of the primes p between 2000 and 3000 for which both 2 and 3 generate Fpx '
I have my code for producing the list of primes between 2000 and 3000:
p:=nextprime(2000):
primes:=[]:
while p<=3000 do
  primes:=[primes[],p];
  p:=nextprime(p);
I also have  code for finding the order of a number in Fpx
findOrderOf:=proc(g,p)
 local gpwr, i;
  gpwr:=1:
for i from 1 to p-1 do
  gpwr:=gpwr*g mod p;
if (gpwr = 1) then:
return i;
end if:
but I don't know how to relate them or how to create the overall code - any advice would be very helpful!!
how to solve ((√1 + y′ ² )/dy')
Hello pdsolve experts:
Using Maple 2018.2.1 and Physics 292 on windows 10.
pde := diff(w(x,y),x)+ (arccot(x)^n *y^2 + y-  arccot(x)^n )*diff(w(x,y),y) = 0;
pdsolve(pde,w(x,y));
When I try
PDEtools:-charstrip(pde,w(x,y))
It does not generate error.
Should pdsolve have generated this error message instead of returning no solution?
I found that when lambda2 take a small value this integration cannot be evaluated by maple is there any command to solve this problem
lambda1 := 0.733e-1; lambda2 := 5.3344; alpha := 4.8492
X[6] := evalf(int((Z^(lambda2/lambda1))^2*ln(Z)^2/((Z-1+alpha)^2*(Z^(lambda2/lambda1)-1+alpha)^3), Z = 1 .. infinity, numeric));
Download ask.mw
Good day everyone,
I have a problem building the code attached below. The series is not substituting F[0](eta) and T[0](eta).
Please, anyone with useful information should contact.
HAM_build.mw
i have a problem to solve this system ?
The program was written in 2004 with maple 6. Now i'am working by maple 18. And i did'nt launch the program. painleve_test.zip
Thank you for your interest in advance.
Hi everybody:
I have 12 equations with 12 unknowns(c(1),c(2),...,c(12) and omega), I want to obtain c(1),c(2),...,c(12) and omega, how can I do it? The Maple file(solve.mw) is attached.
with regards...
solve.mw
First 731 732 733 734 735 736 737 Last Page 733 of 2433
