Maple currently can't integrate things like sin(x)^n or cos(x)^n. These have antiderivative in terms of  hypergeometric functions.
Is there a technical reason why Maple at version 18 still can't integrate these? Will it be able to in next version?
int(cos(x)^k, x)
int(sin(x)^k, x)
fyi, These are the antiderivatives
Same problem for tan(x)^n....  I am asking because Maple is able to solve many ODE's but some results contains unevaluated integrals such as the above.
When making this call to dsolve
ode:=diff(y(x),x)=1:
stopat(dsolve);
dsolve(ode,y(x));
Then in the debugger, I see that dsolve signature is
dsolve := proc(ODEs::{anything} := NULL,
                {atomizenames::truefalse := true, build::truefalse := false, type::name := 'none'})
When typing print(ODEs) inside the debugger, it gives "diff(y(x),x)=1" which is correct.
But where is the second argument I passed to dsolve in the above call, which is "y(x)" gone?  I also do print(_nparams) inside the debugger and Maple returns 1 and not 2.
I expected to see 2 since I passed in two arguments to dsolve.
dsolve actually works without passing y(x), as follows
dsolve(ode);
And it seems Maple figure inside what is the dependent variable.
But my question is, is the second argument being thrown away before calling dsolve? If not, why it does not show in the debugger?   Is there some other pre-processing being done between the time the user calls dsolve() and the time the debugger is called?
So i have beeing working with finite elements and i have the stifness matrix that i came with Maple as you can see here:
Ke := Matrix(4, 4, {(1, 1) = (12*I)*E/l^3, (1, 2) = (6*I)*E/l^2, (1, 3) = -(12*I)*E/l^3, (1, 4) = (6*I)*E/l^2, (2, 1) = (6*I)*E/l^2, (2, 2) = (4*I)*E/l, (2, 3) = -(6*I)*E/l^2, (2, 4) = (2*I)*E/l, (3, 1) = -(12*I)*E/l^3, (3, 2) = -(6*I)*E/l^2, (3, 3) = (12*I)*E/l^3, (3, 4) = -(6*I)*E/l^2, (4, 1) = (6*I)*E/l^2, (4, 2) = (2*I)*E/l, (4, 3) = -(6*I)*E/l^2, (4, 4) = (4*I)*E/l})
How can i re-write this matrix to put in this form:
Hi, everybody.
Is there a command or a way to assign an initial value to animate plot?
Trivial example:
animate(plot,[m*x,x=-10..10],m=-10..10)
but initial value for m would be m=1 so the initial render will present the line with slope 1.
As always, thank you all in advanced.
i have two ode equations, when try to solve, i face this error
any comment or help to solve this? ( or any simplifying comments to solve) . thnx in advance
A := 4263736263.736263:B := 11868131.86813187:C := 600146.5201465202:hr := 0.3e7:muz := 0.2632654643708247e-5:P:=1000:
1000
ode1 := diff(u(r), r, r)+(diff(u(r), r))/r-u(r)/r^2-B*(diff(w(r), r, r, r)+(diff(w(r), r, r))/r-(diff(w(r), r))/r^2)/A = 0;
diff(diff(u(r), r), r)+(diff(u(r), r))/r-u(r)/r^2-0.2783505155e-2*(diff(diff(diff(w(r), r), r), r))-0.2783505155e-2*(diff(diff(w(r), r), r))/r+0.2783505155e-2*(diff(w(r), r))/r^2 = 0
ode2 := C*(diff(w(r), r, r, r, r))+2*C*(diff(w(r), r, r, r))/r-(C/r^2+muz*hr^2)*(diff(w(r), r, r))+(C/r^3-muz*hr^2/r)*(diff(w(r), r))+muz*hr^2*w(r)/r^2-B*(diff(u(r), r, r, r))-2*B*(diff(u(r), r, r))/r+B*(diff(u(r), r))/r^2-B*u(r)/r^3 = P;
600146.5201465202*(diff(diff(diff(diff(w(r), r), r), r), r))+1200293.040*(diff(diff(diff(w(r), r), r), r))/r-(600146.5201465202/r^2+23693891.80)*(diff(diff(w(r), r), r))+(600146.5201465202/r^3-23693891.80/r)*(diff(w(r), r))+23693891.80*w(r)/r^2-11868131.86813187*(diff(diff(diff(u(r), r), r), r))-23736263.74*(diff(diff(u(r), r), r))/r+11868131.86813187*(diff(u(r), r))/r^2-11868131.86813187*u(r)/r^3 = 1000
ics := w(.2) = 0, (D(w))(.2) = 0, w(1) = 0, (D(w))(1) = 0, u(.2) = 0, u(1) = 0;
dsolve({ode1,ode2} union {ics},{w(r),u(r)},numeric)
Download zzv.mw
I want to plot the approximation of a surface by polynomials. The surface is given by (x,y,f(x,y)) where f(x,y) is given by the following expression
proc (x) options operator, arrow; (sum(i*cos((i+1)*(-2+4*x[1])+i), i = 1 .. 5))*(sum(i*cos((i+1)*(-2+4*x[2])+i), i = 1 .. 5)) end proc
with both variables varying in the interval [0,1]. Then, by using the Bernstein polynomials of two variables (see, for instance, this paper for details  https://www.sciencedirect.com/science/article/pii/0021904589900956), the graph of the resulting (plot3d) surface (x,y,p(x,y))  it is not even like to the original surfaces.
Please, see this PDF of what I have done:  plots.pdf
Some idea or suggestion?
numeric.mws
Dear Colleagues,
Please give advice - How correct in Maple can be solve the heat nonlinear equation system with perfect thermal contact conditions?
Using procedure dsolve (numeric) Maple cannot determine type of problem (initial or boundary).
initial/boundary conditions specified at too many points 1
Error, (in dsolve/numeric/type_check) cannot determine type of problem (initial or boundary), as conditions are given at 4 points
In attachment Maple file - numeric.
Maybe anyone can get a simple exaple of the maple code for numeric solution of this  task?
k1:=5; k2:=7;k3:=8; Q:=4;p:=0.001;l:=0.1; d:=0.6;
k1 := 5
k2 := 7
k3 := 8
Q := 4
p := 0.1e-2
l := .1
d := .6
Eq1:=(k1^2)*diff(T1(x),x$2)=0;
Eq1 := 25*(diff(T1(x), `$`(x, 2))) = 0
Eq2:=(k2^2)*diff(T2(x),x$2)=-Q*Dirac(x)+T2(x)^4;
Eq2 := 49*(diff(T2(x), `$`(x, 2))) = -4*Dirac(x)+T2(x)^4
Eq3:=(k3^2)*diff(T3(x),x$2)=0;
Eq3 := 64*(diff(T3(x), `$`(x, 2))) = 0
con1:=T1(0)=T2(0);con2:=T3(p)=T2(p); con3:=k1*(D(T1)(0))=Q-k2*(D(T2)(0)); con4:=k2*(D(T2)(p))=k3*(D(T3)(p)); con5:= T3(l)=300; con6:=T1(-d)=300;
con1 := T1(0) = T2(0)
con2 := T3(0.1e-2) = T2(0.1e-2)
con3 := 5*(D(T1))(0) = 4-7*(D(T2))(0)
con4 := 7*(D(T2))(0.1e-2) = 8*(D(T3))(0.1e-2)
con5 := T3(.1) = 300
con6 := T1(-.6) = 300
nsol:=dsolve({Eq1, Eq2, Eq3,con1,con2,con3,con4,con5,con6},{T1(x),T2(x),T3(x)}, numeric,bvp);
Download numeric.mws
I am brand new to Maple Cloud and Maple Player.
I have uploaded two worksheets to the cloud, and my wife has just installed Maple Player on her laptop.
In Maple Player, the second worksheet shows the shareable symbol but the first doesn't even thought I uploaded both in the same way by clicking on the upload symbol in the Maple Cloud palette. Why is the first worksheet not shareable?
When my wife displays the second worksheet she is able to move its sliders but they do not change the display as they do when I move the sliders within Maple2016. How can she change the display?
Here is a link to the second worksheet:
Cassinian_oval.mw
Say I have 2 matrices, in which the elements themselves are vectors.
I'm looking for a way to perform matrix multiplication on these so that rather than having the first element as x11y11+x12y21+x13y31
It would be x11.y11+x12.y21+x13.y31 where . is the dot product on the elements of each matrix.
I know I could write a procedure to do this manually but I was wondering if there's any pre-made operations (or modifiers on the Multiply operation) to do this.
How do I plot the optimal control functions in an optimal control problem ?
I have been working on Maxima and minima, I am able to extract the eigen values for the expression.
Based on following conditions I am able to find out the critical point is maxima or minima or saddle or inconsistant
If all the eigenvalues are positive, the point is a minimum.
If all the eigenvalues are all negative, it's a maximum.
If some eigenvalues are positive, some are negative, and none are zero, then it's a saddle point.
If any eigenvalues are zero, the test is inconclusive
I want to return all the critical points and their extrema.
just for example : For one perticular function I got a Eigen values as which I can find using sign function.
EigenValues := [[-.381966011250105+0.*I, -2.61803398874989+0.*I], [.414213562373095+0.*I, -2.41421356237309+0.*I]]
signDetails := [seq([seq(sign(EigenValues[i][j]), j = 1 .. nops(EigenValues[i]))], i = 1 .. nops(EigenValues))] #
 signDetails :=[[-1, -1], [1, -1]]
Now if I have a 0 in a list. Sign function returns 1 for 0, which is incorrect. How can I handle such conditions
if I have
EigenValues := [[-.381966011250105+0.*I, -2.61803398874989+0.*I], [.414213562373095+0.*I, -2.41421356237309+0.*I], [0, 2]]
I would like to have output [[-1, -1], [1, -1], [0, 1]],
I would like to know how is it possible return output based on above list
in this case my return shouble something like this [maxima, saddle, inconclusive].
Here is a simple procedure that works fine if entered using 1D Maple input
> Q:=proc(x)
sin(x)
but if you use 2D math input
> q:=proc(x)
sin(x);
Error, unterminated procedure
    Typesetting:-mambiguous(qAssignTypesetting:-mambiguous(
      procApplyFunction(x) sinApplyFunction(x),
      Typesetting:-merror("unterminated procedure")))
Error, unable to parse
    Typesetting:-mambiguous(  Typesetting:-mambiguous(end,
      Typesetting:-merror("unable to parse")) procsemi)
Ouch! But to confuse things further the following procedures may be entered using 2D math and work fine:
>H := proc (x) x^2*sin(x) end proc;
>K := proc (x) sin(x^2) end proc;
Doesn't make any sense to me. Perhaps 2D math is not ready for prime time?
Im trying to plot the graph of g := int(exp(-epsilon(x^4+x^2)), x = -10 .. 10), i want to see how the value of the integrand will change as we let epsilon tend towards infinity, but I am struggling to find a way to do this. Any help would be greatly appreciated.
So I have got the following integral:
Int((2*z+1)/(z-5)(z-1)^2,z)
around the square with corners 2, 2i, -2, -2i oriented counter-clockwise.
Do I need to tell Maple that z is complex? Do I need to manually parametrize z? Is Maple aware of Cauchy's theorem?
What is the quickest way of evaluating this sort of integrals.
I'm still a maple beginner and looking for a workable solution to the following problem. I have already solved these "by hand" and would now like to control them.
The following equation should be solved:
diff(u(x, t), t, t)-c^2*(diff(u(x, t), x, x))
The approach function would be for example:
u := a(x)*sin(k1*(-c*t+x))
It would be great if maple could give me the solution again in this example:
solution = -c^2*(d^2*a*sin(k1*(-c*t+x))/dx^2+2*d*a*k1*cos(k1*(-c*t+x))/dx)
How exactly do I do this best?
Thanks a lot!
Frank
First 737 738 739 740 741 742 743 Last Page 739 of 2433
