I found a case where pdetest fails when called after another call to pdetest. I am using Physics version 272 from the clould. Using Maple 2018.2.1 on windows 10
u:='u';x:='x';t:='t';
pde := diff(u(x, t), t) + diff(u(x, t),x) =0;
sol:=pdsolve(pde,u(x,t));
pdetest(sol,pde);
    #0  OK
#restart;
pde:=diff(u(x,t),t)+diff(u(x,t),x)=0;
bc:=u(0,t)=0;
ic:=u(x,0)=sin(x);
sol:=pdsolve([pde,ic,bc],u(x,t)) assuming x>0;
pdetest(sol,pde);
     #sol := u(x, t) = -sin(-x+t)*Heaviside(-t+x)   #OK
     #-Dirac(-t+x)*sin(x)*cos(t)+Dirac(-t+x)*cos(x)*sin(t)+
      Dirac(-x+t)*sin(x)*cos(t)-Dirac(-x+t)*cos(x)*sin(t)   #WRONG should be 0
If I run the above again, but with restart call in between active, so that all is cleared, then pdetest gives 0 as expected on the second pde, with the same solution
pdetest(sol,pde);
   #0   #OK
bc:=u(0,t)=0;
ic:=u(x,0)=sin(x);
pdetest(sol,pde);
   #0   #OK !!
can any one explain why this happens?  Is this a bug? It seems like pdetest caching problem. it remembers something from the last call and this affects the result it gives for the next call.
any work around?
Another GCD attempt. Why is there a parse problem? Thanks
"proc GCD3:=proc(n1,n2)    local r, a,b;    a:=n1; b:= n2;    while (a mod b) >0  do       r:=a mod b;      a:=b;      b:=r;   end do;    return b;  end proc;  "
Error, unable to parse
Download GCD3.mw
Any sugggestions gratefully received
I do know that Maple has a gcd command but I am just experimenting
GCD2.mw
"GED2:=proc(n1 ,n2)     local a,b;     option remember;     a:=n1:b:=n2:     if b = 0 then do         return a ;    else       return GED2(b, a mod b);    end if;  end proc;"
Error, unterminated procedure
Download GCD2.mw
In an expression I have several terms with different coefficients and permutations of them say
aS+bc + bS+cS- + cb + others etc
I want to order them the way I want, like, say
abcS+ + bcS+cS- +bc  etc
How can I do this?
Happy New Year!
I solve ode for simply DC motor system:
J:= 0.01;b:=0.1;K:= 0.01;R:=1;L:=1;
eq1:=J*diff(theta(t),t,t)+b*diff(theta(t),t)=K*i(t):
eq2:=L*diff(i(t),t)+R*i(t)=V-K*diff(theta(t),t):
ICs:= theta(0)=0, D(theta)(0) = 0, D(theta)(0) = 0, i(0) = 0:
sol:=dsolve({eq1,eq2,ICs},numeric,parameters=[V],output=listprocedure):
sol(parameters=[10]):
ode_x1:=sol[2];
ode_x1:=rhs(ode_x1);
ode_x2:=sol[3];
ode_x2:=rhs(ode_x2);
p1:=plot([ode_x1(t),ode_x2(t)],t=0..50,gridlines=true):
plots[display](array([p1]));
I have time wektor and input wektor V in csv file. How to change this code to simulate
ode solution ode_x1 and ode_x2 with data from file? Now I set V as
and t in
Best
Hello everybody.
This is my question. I tried to evaluate a list of polynomial over a list of values. Something like this:
eval([a*x, b*x], x = [p, q, t])
to get something like this:
[[a*p, a*q, a*t], [b*p, b*q, b*t]]
I know this method: eval~(a*x,x=~[p,q,t])  though this works for one polynomial over a list of values. Not precisely, what I am looking for.
I figured out a method that worked defining functions and with ‘apply’ and ‘map’. Here an example:
m:=t->3*2^t:
n:=t->(t+4)^2:
map(apply~,[m,n],[1,2,3]);
[[6, 12, 24], [25, 72, 147]]
However, how can I get this result using the ‘eval’ function.
Thank you all in advanced for any contribution.
restart; _local(gamma); _local(GAMMA); _local(Pi); _local(pi); _local(I); _local(D);
                               I
Warning, The imaginary unit, I, has been renamed _I
b := .45; mu[t] := 1.112; delta := .181; rho := 0.2e-1; beta[k] := .123; sigma := 0.9e-1; alpha := 0.312e-1; gamma := 0.14e-2; phi := .24; xi := .134; A[h] := .576; k[1] := 0.1e-2; beta[c] := 0.1e-1; mu[c] := 0.19e-2; eta := .557; z := .636; phi[c] := 0.57e-1;
                              0.45
                             1.112
                             0.181
                              0.02
                             0.123
                              0.09
                             0.0312
                             0.0014
                              0.24
                             0.134
                             0.576
                             0.001
                              0.01
                             0.0019
                             0.557
                             0.636
                             0.057
ODE1 := diff(B(T), T) = rho*b-mu[t]*B(T)-delta*B(T);
                  d
                 --- B(T) = 0.0090 - 1.293 B(T)
                  dT
ODE2 := diff(C(T), T) = delta*B(T)-mu[t]*C(T)+1-rho*b-beta[k]*C(T)*H(T)+sigma*C(T);
  d
 --- C(T) = 0.181 B(T) - 1.022 C(T) + 0.9910 - 0.123 C(T) H(T)
  dT
ODE3 := diff(D(T), T) = beta[k]*C(T)*H(T)-(mu[t]+alpha+gamma)*C(T)-phi*C(T);
       d
      --- D(T) = 0.123 C(T) H(T) - 1.1446 C(T) - phi C(T)
       dT
ODE4 := diff(E(T), T) = alpha*D(T)-xi*E(T)-mu[t]*E(T);
               d
              --- E(T) = 0.0312 D(T) - 1.246 E(T)
               dT
ODE5 := diff(F(T), T) = phi*D(T)+xi*E(T)-mu[t]*F(T)-sigma*C(T);
    d
   --- F(T) = phi D(T) + 0.134 E(T) - 1.112 F(T) - 0.09 C(T)
    dT
ODE6 := diff(G(T), T) = (1-k[1])*A[h]-beta[c]*G(T)*H(T)-mu[c]*H(T)-eta*J(T);
 d
--- G(T) = 0.575424 - 0.01 G(T) H(T) - 0.0019 H(T) - 0.557 J(T)
 dT
ODE7 := diff(H(T), T) = k[1]*A[h]+beta[c]*G(T)*H(T)-mu[c]*H(T)-z*H(T);
        d
       --- H(T) = 0.000576 + 0.01 G(T) H(T) - 0.6379 H(T)
        dT
ODE8 := diff(J(T), T) = z*H(T)-(phi[c]+eta)*J(T);
                d
               --- J(T) = 0.636 H(T) - 0.614 J(T)
                dT
ans := dsolve({ODE1, ODE2, ODE3, ODE4, ODE5, ODE6, ODE7, ODE8, B(0) = B0, C(0) = C0, D(0) = D0, E(0) = E0, F(0) = F0, G(0) = G0, H(0) = H0, J(0) = J0}, numeric, output = listprocedure);
    [T = proc(T)  ...  end;, B(T) = proc(T)  ...  end;,
      C(T) = proc(T)  ...  end;, D(T) = proc(T)  ...  end;,
      E(T) = proc(T)  ...  end;, F(T) = proc(T)  ...  end;,
      G(T) = proc(T)  ...  end;, H(T) = proc(T)  ...  end;,
      J(T) = proc(T)  ...  end;]
B0 := 100; C0 := 90; D0 := 45; E0 := 38; F0 := 100; G0 := 45; H0 := 50; J0 := 20;
                              100
                               90
                               45
                               38
                              100
                               45
                               50
                               20
ans := dsolve([ODE1, ODE2, ODE3, ODE4, ODE5, ODE6, ODE7, ODE8, B(0) = B0, C(0) = C0, D(0) = D0, E(0) = E0, F(0) = F0, G(0) = G0, H(0) = H0, J(0) = J0], numeric, output = listprocedure);
Error, (in f) unable to store 'HFloat(450.486)-HFloat(90.0)*phi' when datatype=float[8]
im trying to input this variable with value structure
> xxx := x[2, 0], x[2, 1], x[2, 2], x[1, 0], x[1, 1]
check the type
> whattype(xxx);
exprseq
but when i try to use Get tools from maplets package, its give me error
> xxx:=Get`('xxx1'::exprseq)
invalid argument(s): xxx1::exprseq
is it possible to passing exprseq from maplet input into procedure?
or is there another way to input it (xxx) ?
You are please to check maple file:    robust_rev1.mw
case close, many thanks @tomleslie and @vv
Might be a beginners trap...
How can I evaluate a constant expression or an expression/formula that contains several scientific constants without "Constantin'g' them out like in sample 2)??
1) Example:
Rb := (1/4)*alpha/(Pi*R[infinity])
'real' value of (Rb)??
1) This example works:
evalf(1-Constant(m[e])/Constant(m[p])) -- but it's awful with respect to the simple demand to just divide two known constants..
Can someone explain why it would be reported that degree(0,x)=-infinity, ldegree(0,x)=infinity;
How are these used in an argument?
Hi guys,
I have a formula such as f(x)=X^2
I want that the software ask value for x and then show the result of f(x)
thanks for any help.
T := K+F(xi)*F(xi);
                           K + F(xi)
U := alpha[0]+alpha[1]*(m+F(xi))+beta[1]/(m+F(xi))+alpha[2]*(m+F(xi))*(m+F(xi))+beta[2]/(m+F(xi))^2;
                                             beta[1]
          alpha[0] + alpha[1] (m + F(xi)) + ---------
                                            m + F(xi)
                                   2     beta[2]
             + alpha[2] (m + F(xi))  + ------------
                                       (m + F(xi))
diff(U, xi);
                                / d        \
                        beta[1] |---- F(xi)|
         / d        \           \ dxi      /
alpha[1] |---- F(xi)| - --------------------
         \ dxi      /                  2
                            (m + F(xi))
                                                     / d        \
                                           2 beta[2] |---- F(xi)|
                            / d        \             \ dxi      /
   + 2 alpha[2] (m + F(xi)) |---- F(xi)| - ----------------------
                            \ dxi      /                   3
                                                (m + F(xi))
d := alpha[1]*T-beta[1]*T/(m+F(xi))^2+2*alpha[2]*(m+F(xi))*T-2*beta[2]*T/(m+F(xi))^3;
                                /         2\
         /         2\   beta[1] \K + F(xi) /
alpha[1] \K + F(xi) / - --------------------
                            (m + F(xi))
                                                     /         2\
                            /         2\   2 beta[2] \K + F(xi) /
   + 2 alpha[2] (m + F(xi)) \K + F(xi) / - ----------------------
                                                (m + F(xi))
diff(d, xi);
                                                  / d        \
                                  2 beta[1] F(xi) |---- F(xi)|
                   / d        \                   \ dxi      /
  2 alpha[1] F(xi) |---- F(xi)| - ----------------------------
                   \ dxi      /                      2
                                          (m + F(xi))
                 /         2\ / d        \
       2 beta[1] \K + F(xi) / |---- F(xi)|
                              \ dxi      /
                  (m + F(xi))
                  / d        \ /         2\
     + 2 alpha[2] |---- F(xi)| \K + F(xi) /
                  \ dxi      /
                                    / d        \
     + 4 alpha[2] (m + F(xi)) F(xi) |---- F(xi)|
                                    \ dxi      /
                       / d        \
       4 beta[2] F(xi) |---- F(xi)|
                       \ dxi      /
               (m + F(xi))
                 /         2\ / d        \
       6 beta[2] \K + F(xi) / |---- F(xi)|
                              \ dxi      /
                             4
                  (m + F(xi))
collect(%, diff);
  /                                               /         2\
  |                   2 beta[1] F(xi)   2 beta[1] \K + F(xi) /
  |2 alpha[1] F(xi) - --------------- + ----------------------
  |                               2                     3
  \                    (m + F(xi))           (m + F(xi))
                  /         2\
     + 2 alpha[2] \K + F(xi) / + 4 alpha[2] (m + F(xi)) F(xi)
                                   /         2\\
       4 beta[2] F(xi)   6 beta[2] \K + F(xi) /| / d        \
     - --------------- + ----------------------| |---- F(xi)|
                   3                     4     | \ dxi      /
        (m + F(xi))           (m + F(xi))      /
S := (2*alpha[1]*F(xi)-2*beta[1]*F(xi)/(m+F(xi))^2+2*beta[1]*(K+F(xi)^2)/(m+F(xi))^3+2*alpha[2]*(K+F(xi)^2)+4*alpha[2]*(m+F(xi))*F(xi)-4*beta[2]*F(xi)/(m+F(xi))^3+6*beta[2]*(K+F(xi)^2)/(m+F(xi))^4)*T;
  /                                               /         2\
  |                               2                     3
                  /         2\
                                   /         2\\
       4 beta[2] F(xi)   6 beta[2] \K + F(xi) /| /         2\
     - --------------- + ----------------------| \K + F(xi) /
                   3                     4     |
expand((2*w*k*k)*beta*S-(2*A*k*k)*d-2*w*U+k*U*U);
      2                   2               2
-2 A k  alpha[1] K - 2 A k  alpha[1] F(xi)
          2               3
   - 4 A k  alpha[2] F(xi)  - 4 w alpha[2] F(xi) m
   + 2 k alpha[0] alpha[1] m + 2 k alpha[0] alpha[1] F(xi)
     2 k alpha[0] beta[1]                          2
   + -------------------- + 2 k alpha[0] alpha[2] m
          m + F(xi)
                                2   2 k alpha[0] beta[2]
   + 2 k alpha[0] alpha[2] F(xi)  + --------------------
                                        (m + F(xi))
                 2                         3
   + 2 k alpha[1]  m F(xi) + 2 k alpha[1] m  alpha[2]
                       3            2 k beta[1] beta[2]
   + 2 k alpha[1] F(xi)  alpha[2] + -------------------
                                       (m + F(xi))
                 2  3                     2  2      2
   + 4 k alpha[2]  m  F(xi) + 6 k alpha[2]  m  F(xi)
                 2      3                              2
   + 4 k alpha[2]  F(xi)  m - 2 w alpha[0] + k alpha[0]
          2                    3        2                2
   + 4 w k  beta alpha[1] F(xi)  + 4 w k  beta alpha[2] K
           2                    4   2 A k  beta[1] K
   + 12 w k  beta alpha[2] F(xi)  + ----------------
                                      (m + F(xi))
          2              2
     2 A k  beta[1] F(xi)         2
   + --------------------- - 4 A k  alpha[2] m K
         (m + F(xi))
          2                 2        2
   - 4 A k  alpha[2] m F(xi)  - 4 A k  alpha[2] F(xi) K
          2                  2              2
     4 A k  beta[2] K   4 A k  beta[2] F(xi)
                  3                    3
                                     2 k alpha[1] m beta[1]
   + 4 k alpha[0] alpha[2] F(xi) m + ----------------------
                                           m + F(xi)
   + 6 k alpha[1] m  alpha[2] F(xi)
                                  2   2 k alpha[1] m beta[2]
   + 6 k alpha[1] m alpha[2] F(xi)  + ----------------------
                                           (m + F(xi))
     2 k alpha[1] F(xi) beta[1]   2 k alpha[1] F(xi) beta[2]
             m + F(xi)                              2
                                         (m + F(xi))
                           2                             2
     2 k beta[1] alpha[2] m    2 k beta[1] alpha[2] F(xi)
            m + F(xi)                   m + F(xi)
                   2                             2
     2 k alpha[2] m  beta[2]   2 k alpha[2] F(xi)  beta[2]
                     2                           2
               2  2             2      2    k beta[1]
   + k alpha[1]  m  + k alpha[1]  F(xi)  + ------------
                                           (m + F(xi))
               2  4             2      4    k beta[2]
   + k alpha[2]  m  + k alpha[2]  F(xi)  + ------------
                                                      4
                                           (m + F(xi))
                                           2 w beta[1]
   - 2 w alpha[1] m - 2 w alpha[1] F(xi) - -----------
                                            m + F(xi)
                   2                     2   2 w beta[2]
   - 2 w alpha[2] m  - 2 w alpha[2] F(xi)  - ------------
                                             (m + F(xi))
          2                             2                     2
     4 w k  beta beta[1] F(xi) K   8 w k  beta beta[1] K F(xi)
                       2                              3
          2                           8 w k  beta beta[2] F(xi) K
   + 8 w k  beta alpha[2] F(xi) m K - ---------------------------
                                             (m + F(xi))
           2                     2
     24 w k  beta beta[2] K F(xi)         2
   + ----------------------------- + 4 w k  beta alpha[1] F(xi) K
                        4
             (m + F(xi))
          2                   3        2               2
     4 w k  beta beta[1] F(xi)    4 w k  beta beta[1] K
                       2                          3
          2                   4
     4 w k  beta beta[1] F(xi)          2                      2
   + -------------------------- + 16 w k  beta alpha[2] K F(xi)
            (m + F(xi))
                                          2                   3
          2                    3     8 w k  beta beta[2] F(xi)
   + 8 w k  beta alpha[2] F(xi)  m - --------------------------
                                            (m + F(xi))
           2               2         2                   4
     12 w k  beta beta[2] K    12 w k  beta beta[2] F(xi)
                     4                           4
     4 k beta[1] alpha[2] F(xi) m   4 k alpha[2] F(xi) m beta[2]
              m + F(xi)                                2
                                            (m + F(xi))
value(%);
      2                   2               2
          2               3
          m + F(xi)
                                        (m + F(xi))
                 2                         3
                                       (m + F(xi))
                 2  3                     2  2      2
                 2      3                              2
          2                    3        2                2
           2                    4   2 A k  beta[1] K
                                      (m + F(xi))
          2              2
         (m + F(xi))
          2                 2        2
          2                  2              2
                  3                    3
                                           m + F(xi)
                                           (m + F(xi))
             m + F(xi)                              2
                                         (m + F(xi))
                           2                             2
            m + F(xi)                   m + F(xi)
                   2                             2
                     2                           2
               2  2             2      2    k beta[1]
                                           (m + F(xi))
               2  4             2      4    k beta[2]
                                                      4
                                           (m + F(xi))
                                           2 w beta[1]
                                            m + F(xi)
                   2                     2   2 w beta[2]
                                             (m + F(xi))
          2                             2                     2
                       2                              3
                                             (m + F(xi))
           2                     2
                        4
             (m + F(xi))
          2                   3        2               2
                       2                          3
          2                   4
            (m + F(xi))
                                          2                   3
                                            (m + F(xi))
           2               2         2                   4
                     4                           4
              m + F(xi)                                2
                                            (m + F(xi))
expr := simplify(%);
      2                   2               2
          2               3
          m + F(xi)
                                        (m + F(xi))
                 2                         3
                                       (m + F(xi))
                 2  3                     2  2      2
                 2      3                              2
          2                    3        2                2
           2                    4   2 A k  beta[1] K
                                      (m + F(xi))
          2              2
         (m + F(xi))
          2                 2        2
          2                  2              2
                  3                    3
                                           m + F(xi)
                                           (m + F(xi))
             m + F(xi)                              2
                                         (m + F(xi))
                           2                             2
            m + F(xi)                   m + F(xi)
                   2                             2
                     2                           2
               2  2             2      2    k beta[1]
                                           (m + F(xi))
               2  4             2      4    k beta[2]
                                                      4
                                           (m + F(xi))
                                           2 w beta[1]
                                            m + F(xi)
                   2                     2   2 w beta[2]
                                             (m + F(xi))
          2                             2                     2
                       2                              3
                                             (m + F(xi))
           2                     2
                        4
             (m + F(xi))
          2                   3        2               2
                       2                          3
          2                   4
            (m + F(xi))
                                          2                   3
                                            (m + F(xi))
           2               2         2                   4
                     4                           4
              m + F(xi)                                2
                                            (m + F(xi))
temp := algsubs(m+F(xi) = freeze(m+F(xi)), numer(expr));
/        2            4                    2
\4 beta k  w freeze/R0  alpha[2] + 4 beta k  w freeze/R0 beta[1]
              2          \      4   /        2            5
   + 12 beta k  w beta[2]/ F(xi)  + \8 beta k  w freeze/R0  alpha
                2            4
  [2] + 4 beta k  w freeze/R0  alpha[1]
             2            2
   - 4 beta k  w freeze/R0  beta[1]
             2                    \      3   /          2
   - 8 beta k  w freeze/R0 beta[2]/ F(xi)  + \8 K beta k  w
           4                 2          5
  freeze/R0  alpha[2] - 4 A k  freeze/R0  alpha[2]
          2          4                 2          2
   - 2 A k  freeze/R0  alpha[1] + 2 A k  freeze/R0  beta[1]
          2                                  2
   + 8 w k  beta beta[1] K freeze/R0 + 24 w k  beta beta[2] K
          2                  \      2   /          2            5
   + 4 A k  beta[2] freeze/R0/ F(xi)  + \8 K beta k  w freeze/R0
                       2            4
  alpha[2] + 4 K beta k  w freeze/R0  alpha[1]
               2            2
   - 4 K beta k  w freeze/R0  beta[1]
               2                    \
   - 8 K beta k  w freeze/R0 beta[2]/ F(xi)
               2          8              6         2
   + k alpha[2]  freeze/R0  + k freeze/R0  alpha[1]
                  6                         5
   - 2 w freeze/R0  alpha[2] - 2 w freeze/R0  alpha[1]
              4           2              4
   + freeze/R0  k alpha[0]  - 2 freeze/R0  w alpha[0]
                                    7
   + 2 k alpha[1] alpha[2] freeze/R0
                  6
   + 2 k freeze/R0  alpha[0] alpha[2]
                  5
   + 2 k freeze/R0  alpha[0] alpha[1]
                  5
   + 2 k freeze/R0  alpha[2] beta[1]
                4
   + 2 freeze/R0  k alpha[1] beta[1]
                4
   + 2 freeze/R0  k alpha[2] beta[2]
   + 2 k freeze/R0  alpha[0] beta[1]
   + 2 k freeze/R0  alpha[1] beta[2]
   + 2 k freeze/R0  alpha[0] beta[2]
            2          5                       4    2
   - 4 A K k  freeze/R0  alpha[2] - 2 freeze/R0  A k  alpha[1] K
            2          2
   + 2 A K k  freeze/R0  beta[1]
                4    2                2
   + 4 freeze/R0  w k  beta alpha[2] K
          2               2                          3
   + 4 w k  beta beta[1] K  freeze/R0 - 2 w freeze/R0  beta[1]
                2        2                2
   + k freeze/R0  beta[1]  - 2 w freeze/R0  beta[2]
   + 4 A k  beta[2] K freeze/R0 + 2 k beta[1] beta[2] freeze/R0
              2         2               2
   + k beta[2]  + 12 w k  beta beta[2] K
thaw(collect(temp, freeze(m+F(xi)))/denom(expr));
     1       /          2            8
------------ \k alpha[2]  (m + F(xi))
           4
(m + F(xi))
                                      7              6 /
   + 2 k alpha[1] alpha[2] (m + F(xi))  + (m + F(xi))  \2 k alpha
                           2               \   /       3       2
  [0] alpha[2] + k alpha[1]  - 2 w alpha[2]/ + \8 F(xi)  beta k  w
  alpha[2] + 8 K F(xi) beta k  w alpha[2]
              2  2                   2
   - 4 A F(xi)  k  alpha[2] - 4 A K k  alpha[2]
   + 2 k alpha[0] alpha[1] + 2 k alpha[2] beta[1] - 2 w alpha[1]/
             5   /     2                    4
  (m + F(xi))  + \4 w k  beta alpha[2] F(xi)
          2                    3
     /          2                   2         \      2
   + \8 K beta k  w alpha[2] - 2 A k  alpha[1]/ F(xi)
          2                                   2
   + 4 w k  beta alpha[1] F(xi) K + k alpha[0]  - 2 w alpha[0]
   + 2 k alpha[1] beta[1] + 2 k alpha[2] beta[2]
          2                   2                2\            4
   - 2 A k  alpha[1] K + 4 w k  beta alpha[2] K / (m + F(xi))  +
  (2 k alpha[0] beta[1] + 2 k alpha[1] beta[2] - 2 w beta[1])
             3   /      2                   3
  (m + F(xi))  + \-4 w k  beta beta[1] F(xi)
          2                             2              2
   - 4 w k  beta beta[1] F(xi) K + 2 A k  beta[1] F(xi)
          2                                             2
   + 2 A k  beta[1] K + 2 k alpha[0] beta[2] + k beta[1]
                \            2   /     2                   4
   - 2 w beta[2]/ (m + F(xi))  + \4 w k  beta beta[1] F(xi)
          2                   3
   - 8 w k  beta beta[2] F(xi)
     /          2                  2        \      2
   + \8 K beta k  w beta[1] + 4 A k  beta[2]/ F(xi)
          2                             2               2
   - 8 w k  beta beta[2] F(xi) K + 4 w k  beta beta[1] K
          2                                \
   + 4 A k  beta[2] K + 2 k beta[1] beta[2]/ (m + F(xi))
           2                   4         2                     2
   + 12 w k  beta beta[2] F(xi)  + 24 w k  beta beta[2] K F(xi)
           2               2            2\
   + 12 w k  beta beta[2] K  + k beta[2] /
collect(%, F(xi));
     1       //         2                        2\      8   /
------------ \\12 beta k  w alpha[2] + k alpha[2] / F(xi)  + \56
           4
(m + F(xi))
        2                        2                   2
  beta k  m w alpha[2] + 4 beta k  w alpha[1] - 4 A k  alpha[2]
                   2                        \      7   /
   + 8 k m alpha[2]  + 2 k alpha[1] alpha[2]/ F(xi)  + \104 beta
   2  2                         2
  k  m  w alpha[2] + 16 K beta k  w alpha[2]
              2                      2
   + 16 beta k  m w alpha[1] - 20 A k  m alpha[2]
           2         2        2
   + 28 k m  alpha[2]  - 2 A k  alpha[1]
   + 14 k m alpha[1] alpha[2] + 2 k alpha[0] alpha[2]
               2               \      6   /             2  3
   + k alpha[1]  - 2 w alpha[2]/ F(xi)  + \56 k alpha[2]  m
   + 42 k alpha[1] alpha[2] m
         /                                  2               \
   + 6 m \2 k alpha[0] alpha[2] + k alpha[1]  - 2 w alpha[2]/
           2                3         2
   + 96 w k  beta alpha[2] m  + 40 w k  beta alpha[2] K m
           2           2          2
   - 40 A k  alpha[2] m  - 4 A K k  alpha[2]
   + 4 w k  beta alpha[1] K
       /          2                   2         \
   + 4 \8 K beta k  w alpha[2] - 2 A k  alpha[1]/ m
           2                2\      5   /             2  4
   + 24 w k  beta alpha[1] m / F(xi)  + \70 k alpha[2]  m
   + 70 k alpha[1] m  alpha[2]
         2 /                                  2               \
   + 15 m  \2 k alpha[0] alpha[2] + k alpha[1]  - 2 w alpha[2]/ + 5
  /        2
  \-4 A K k  alpha[2] + 2 k alpha[0] alpha[1]
   + 2 k alpha[2] beta[1] - 2 w alpha[1]/ m
           2                  2         2           3
   + 80 w k  beta alpha[2] K m  - 40 A k  alpha[2] m
           2                4        2                2
   + 44 w k  beta alpha[2] m  + 4 w k  beta alpha[2] K
          2                        2
   - 2 A k  alpha[1] K + k alpha[0]  + 2 k alpha[1] beta[1]
   + 2 k alpha[2] beta[2] - 2 w alpha[0]
   + 16 w k  beta alpha[1] K m
       /          2                   2         \  2
   + 6 \8 K beta k  w alpha[2] - 2 A k  alpha[1]/ m
           2                3        2
   + 16 w k  beta alpha[1] m  - 4 w k  beta beta[1] m
          2                2             \      4   /
   + 2 A k  beta[1] + 4 w k  beta beta[2]/ F(xi)  + \56 k
          2  5                           4
  alpha[2]  m  + 70 k alpha[1] alpha[2] m
         3 /                                  2               \
   + 20 m  \2 k alpha[0] alpha[2] + k alpha[1]  - 2 w alpha[2]/ + 10
  /        2
                                        \  2
           2                  3         2           4
   + 80 w k  beta alpha[2] K m  - 20 A k  alpha[2] m
          2                5     /   2       2
   + 8 w k  beta alpha[2] m  + 4 \4 K  beta k  w alpha[2]
            2                      2
   - 2 A K k  alpha[1] + k alpha[0]  + 2 k alpha[1] beta[1]
   + 2 k alpha[2] beta[2] - 2 w alpha[0]/ m
           2                  2
   + 24 w k  beta alpha[1] K m
       /          2                   2         \  3
          2                4
   + 4 w k  beta alpha[1] m  + 2 k alpha[0] beta[1]
                                               2               2
   + 2 k alpha[1] beta[2] - 2 w beta[1] - 4 w k  beta beta[1] m
          2                       2
   + 4 w k  beta beta[1] K + 4 A k  beta[1] m
          2                       2        \      3   /
   - 8 w k  beta beta[2] m + 4 A k  beta[2]/ F(xi)  + \28 k
          2  6                           5
  alpha[2]  m  + 42 k alpha[1] alpha[2] m
         4 /                                  2               \
   + 15 m  \2 k alpha[0] alpha[2] + k alpha[1]  - 2 w alpha[2]/ + 10
  /        2
                                        \  3
           2                  4        2           5     /   2
   + 40 w k  beta alpha[2] K m  - 4 A k  alpha[2] m  + 6 \4 K
        2                     2                      2
  beta k  w alpha[2] - 2 A K k  alpha[1] + k alpha[0]
   + 2 k alpha[1] beta[1] + 2 k alpha[2] beta[2] - 2 w alpha[0]/
   2         2                  3
  m  + 16 w k  beta alpha[1] K m
     /          2                   2         \  4
   + \8 K beta k  w alpha[2] - 2 A k  alpha[1]/ m
   + 3 (2 k alpha[0] beta[1] + 2 k alpha[1] beta[2] - 2 w beta[1]
             2                         2          2
  ) m - 8 w k  beta beta[1] K m + 2 A k  beta[1] m
          2                                             2
   - 2 w beta[2] + 16 w k  beta beta[2] K
     /          2                  2        \  \      2   /
   + \8 K beta k  w beta[1] + 4 A k  beta[2]/ m/ F(xi)  + \8 k
          2  7                           6
  alpha[2]  m  + 14 k alpha[1] alpha[2] m
        5 /                                  2               \
   + 6 m  \2 k alpha[0] alpha[2] + k alpha[1]  - 2 w alpha[2]/ + 5
  /        2
                                        \  4
          2                  5     /   2       2
   + 8 w k  beta alpha[2] K m  + 4 \4 K  beta k  w alpha[2]
            2                      2
                                        \  3
          2                  4
   + 4 w k  beta alpha[1] K m
     2     /       2                                           2
  ) m  + 2 \2 A K k  beta[1] + 2 k alpha[0] beta[2] + k beta[1]
                \          2                 2
   - 2 w beta[2]/ m - 4 w k  beta beta[1] K m
          2               2        2
   + 4 w k  beta beta[1] K  - 8 w k  beta beta[2] K m
          2                                \
   + 4 A k  beta[2] K + 2 k beta[1] beta[2]/ F(xi)
        8         2        7
   + k m  alpha[2]  + 2 k m  alpha[1] alpha[2]
      6 /                                  2               \   /
   + m  \2 k alpha[0] alpha[2] + k alpha[1]  - 2 w alpha[2]/ + \
-4 A K k  alpha[2] + 2 k alpha[0] alpha[1] + 2 k alpha[2] beta[1]
                 \  5   /   2       2
   - 2 w alpha[1]/ m  + \4 K  beta k  w alpha[2]
            2                      2
                                        \  4
   + (2 k alpha[0] beta[1] + 2 k alpha[1] beta[2] - 2 w beta[1])
   3   /       2                                           2
  m  + \2 A K k  beta[1] + 2 k alpha[0] beta[2] + k beta[1]
                \  2   /   2       2                    2
   - 2 w beta[2]/ m  + \4 K  beta k  w beta[1] + 4 A K k  beta[2]
                        \           2               2
   + 2 k beta[1] beta[2]/ m + 12 w k  beta beta[2] K
              2\
   + k beta[2] /
solve({k*m^8*alpha[2]^2+2*k*m^7*alpha[1]*alpha[2]+m^6*(2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2])+(-4*A*K*k^2*alpha[2]+2*k*alpha[0]*alpha[1]+2*k*alpha[2]*beta[1]-2*w*alpha[1])*m^5+(4*K^2*beta*k^2*w*alpha[2]-2*A*K*k^2*alpha[1]+k*alpha[0]^2+2*k*alpha[1]*beta[1]+2*k*alpha[2]*beta[2]-2*w*alpha[0])*m^4+(2*k*alpha[0]*beta[1]+2*k*alpha[1]*beta[2]-2*w*beta[1])*m^3+(2*A*K*k^2*beta[1]+2*k*alpha[0]*beta[2]+k*beta[1]^2-2*w*beta[2])*m^2+(4*K^2*beta*k^2*w*beta[1]+4*A*K*k^2*beta[2]+2*k*beta[1]*beta[2])*m+12*w*k^2*beta*beta[2]*K^2+k*beta[2]^2 = 0, 56*k*alpha[2]^2*m^3+42*k*alpha[1]*alpha[2]*m^2+6*m*(2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2])+96*w*k^2*beta*alpha[2]*m^3+40*w*k^2*beta*alpha[2]*K*m-40*A*k^2*alpha[2]*m^2-4*A*K*k^2*alpha[2]+2*k*alpha[0]*alpha[1]+2*k*alpha[2]*beta[1]-2*w*alpha[1]+4*w*k^2*beta*alpha[1]*K+(4*(8*K*beta*k^2*w*alpha[2]-2*A*k^2*alpha[1]))*m+24*w*k^2*beta*alpha[1]*m^2 = 0, 8*k*alpha[2]^2*m^7+14*k*alpha[1]*alpha[2]*m^6+6*m^5*(2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2])+(5*(-4*A*K*k^2*alpha[2]+2*k*alpha[0]*alpha[1]+2*k*alpha[2]*beta[1]-2*w*alpha[1]))*m^4+8*w*k^2*beta*alpha[2]*K*m^5+(4*(4*K^2*beta*k^2*w*alpha[2]-2*A*K*k^2*alpha[1]+k*alpha[0]^2+2*k*alpha[1]*beta[1]+2*k*alpha[2]*beta[2]-2*w*alpha[0]))*m^3+4*w*k^2*beta*alpha[1]*K*m^4+(3*(2*k*alpha[0]*beta[1]+2*k*alpha[1]*beta[2]-2*w*beta[1]))*m^2+(2*(2*A*K*k^2*beta[1]+2*k*alpha[0]*beta[2]+k*beta[1]^2-2*w*beta[2]))*m-4*w*k^2*beta*beta[1]*K*m^2+4*K^2*beta*k^2*w*beta[1]-8*w*k^2*beta*beta[2]*K*m+4*A*K*k^2*beta[2]+2*k*beta[1]*beta[2] = 0, 28*k*alpha[2]^2*m^6+42*k*alpha[1]*alpha[2]*m^5+15*m^4*(2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2])+(10*(-4*A*K*k^2*alpha[2]+2*k*alpha[0]*alpha[1]+2*k*alpha[2]*beta[1]-2*w*alpha[1]))*m^3+40*w*k^2*beta*alpha[2]*K*m^4-4*A*k^2*alpha[2]*m^5+(6*(4*K^2*beta*k^2*w*alpha[2]-2*A*K*k^2*alpha[1]+k*alpha[0]^2+2*k*alpha[1]*beta[1]+2*k*alpha[2]*beta[2]-2*w*alpha[0]))*m^2+16*w*k^2*beta*alpha[1]*K*m^3+(8*K*beta*k^2*w*alpha[2]-2*A*k^2*alpha[1])*m^4+(3*(2*k*alpha[0]*beta[1]+2*k*alpha[1]*beta[2]-2*w*beta[1]))*m-8*w*k^2*beta*beta[1]*K*m+2*A*k^2*beta[1]*m^2+2*A*K*k^2*beta[1]+2*k*alpha[0]*beta[2]+k*beta[1]^2-2*w*beta[2]+16*w*k^2*beta*beta[2]*K+(8*K*beta*k^2*w*beta[1]+4*A*k^2*beta[2])*m = 0, 56*k*alpha[2]^2*m^5+70*k*alpha[1]*alpha[2]*m^4+20*m^3*(2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2])+(10*(-4*A*K*k^2*alpha[2]+2*k*alpha[0]*alpha[1]+2*k*alpha[2]*beta[1]-2*w*alpha[1]))*m^2+80*w*k^2*beta*alpha[2]*K*m^3-20*A*k^2*alpha[2]*m^4+8*w*k^2*beta*alpha[2]*m^5+(4*(4*K^2*beta*k^2*w*alpha[2]-2*A*K*k^2*alpha[1]+k*alpha[0]^2+2*k*alpha[1]*beta[1]+2*k*alpha[2]*beta[2]-2*w*alpha[0]))*m+24*w*k^2*beta*alpha[1]*K*m^2+(4*(8*K*beta*k^2*w*alpha[2]-2*A*k^2*alpha[1]))*m^3+4*w*k^2*beta*alpha[1]*m^4+2*k*alpha[0]*beta[1]+2*k*alpha[1]*beta[2]-2*w*beta[1]-4*w*k^2*beta*beta[1]*m^2+4*K*beta*k^2*w*beta[1]+4*A*k^2*beta[1]*m-8*w*k^2*beta*beta[2]*m+4*A*k^2*beta[2] = 0, (0*k)*alpha[2]^2*m^4+70*k*alpha[1]*m^3*alpha[2]+15*m^2*(2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2])+(5*(-4*A*K*k^2*alpha[2]+2*k*alpha[0]*alpha[1]+2*k*alpha[2]*beta[1]-2*w*alpha[1]))*m+80*w*k^2*beta*alpha[2]*K*m^2-40*A*k^2*alpha[2]*m^3+44*w*k^2*beta*alpha[2]*m^4+4*K^2*beta*k^2*w*alpha[2]-2*A*K*k^2*alpha[1]+k*alpha[0]^2+2*k*alpha[1]*beta[1]+2*k*alpha[2]*beta[2]-2*w*alpha[0]+16*w*k^2*beta*alpha[1]*K*m+(6*(8*K*beta*k^2*w*alpha[2]-2*A*k^2*alpha[1]))*m^2+16*w*k^2*beta*alpha[1]*m^3-4*w*k^2*beta*beta[1]*m+2*A*k^2*beta[1]+4*w*k^2*beta*beta[2] = 0, 12*beta*k^2*w*alpha[2]+k*alpha[2]^2 = 0, 56*beta*k^2*m*w*alpha[2]+4*beta*k^2*w*alpha[1]-4*A*k^2*alpha[2]+8*k*m*alpha[2]^2+2*k*alpha[1]*alpha[2] = 0, 104*beta*k^2*m^2*w*alpha[2]+16*K*beta*k^2*w*alpha[2]+16*beta*k^2*m*w*alpha[1]-20*A*k^2*m*alpha[2]+28*k*m^2*alpha[2]^2-2*A*k^2*alpha[1]+14*k*m*alpha[1]*alpha[2]+2*k*alpha[0]*alpha[2]+k*alpha[1]^2-2*w*alpha[2] = 0}, {k, m, w, alpha[0], alpha[1], alpha[2], beta[1], beta[2]});
I am beginner to use MAPLE. I am trying write a mathematical variable such as x. I was trying to calculate simple mathematical equation like "3+5", it is ok. However, when I try to write a variable eqn like "x+4-3", Maple gives nothing. If I double press enter it skips this code without any blue answer.
Please help, I tried 2018.0 2018.0 and 2017 and no result.
Thank You
Atakan Zeybek
Given the 2 equations below...
-T*sin(theta(t)) = m*(diff(X(t), t, t)+L*(diff(theta(t), t, t))*cos(theta(t))-L*(diff(theta(t), t))^2*sin(theta(t)))
 T*cos(theta(t))-m*g = m*(diff(Y(t), t, t)+L*(diff(theta(t), t, t))*sin(theta(t))+L*(diff(theta(t), t))^2*cos(theta(t)))
which command(s) will eliminate T and m to give the ODE below?
 L*diff(theta(t), x, x)+(diff(X(t), x, x))*cos(theta)+(diff(Y(t), x, x)+g)*sin(theta) = 0
T := K+F(xi)*F(xi);
                           K + F(xi)
                                             beta[1]
                                            m + F(xi)
                                   2     beta[2]
                                       (m + F(xi))
diff(U, xi);
                                / d        \
         / d        \           \ dxi      /
         \ dxi      /                  2
                            (m + F(xi))
                                                     / d        \
                            / d        \             \ dxi      /
                            \ dxi      /                   3
                                                (m + F(xi))
                                /         2\
                            (m + F(xi))
                                                     /         2\
                                                (m + F(xi))
diff(d, xi);
                                                  / d        \
                   / d        \                   \ dxi      /
                   \ dxi      /                      2
                                          (m + F(xi))
                 /         2\ / d        \
                              \ dxi      /
                  (m + F(xi))
                  / d        \ /         2\
                  \ dxi      /
                                    / d        \
                                    \ dxi      /
                       / d        \
                       \ dxi      /
               (m + F(xi))
                 /         2\ / d        \
                              \ dxi      /
                             4
                  (m + F(xi))
collect(%, diff);
  /                                               /         2\
  |                               2                     3
                  /         2\
                                   /         2\\
                   3                     4     | \ dxi      /
  /                                               /         2\
  |                               2                     3
                  /         2\
                                   /         2\\
                   3                     4     |
      2                   2               2
          2               3
          m + F(xi)
                                        (m + F(xi))
                 2                         3
                                       (m + F(xi))
                 2  3                     2  2      2
                 2      3                              2
          2                    3        2                2
           2                    4   2 A k  beta[1] K
                                      (m + F(xi))
          2              2
         (m + F(xi))
          2                 2        2
          2                  2              2
                  3                    3
                                           m + F(xi)
                                           (m + F(xi))
             m + F(xi)                              2
                                         (m + F(xi))
                           2                             2
            m + F(xi)                   m + F(xi)
                   2                             2
                     2                           2
               2  2             2      2    k beta[1]
                                           (m + F(xi))
               2  4             2      4    k beta[2]
                                                      4
                                           (m + F(xi))
                                           2 w beta[1]
                                            m + F(xi)
                   2                     2   2 w beta[2]
                                             (m + F(xi))
          2                             2                     2
                       2                              3
                                             (m + F(xi))
           2                     2
                        4
             (m + F(xi))
          2                   3        2               2
                       2                          3
          2                   4
            (m + F(xi))
                                          2                   3
                                            (m + F(xi))
           2               2         2                   4
                     4                           4
              m + F(xi)                                2
                                            (m + F(xi))
value(%);
      2                   2               2
          2               3
          m + F(xi)
                                        (m + F(xi))
                 2                         3
                                       (m + F(xi))
                 2  3                     2  2      2
                 2      3                              2
          2                    3        2                2
           2                    4   2 A k  beta[1] K
                                      (m + F(xi))
          2              2
         (m + F(xi))
          2                 2        2
          2                  2              2
                  3                    3
                                           m + F(xi)
                                           (m + F(xi))
             m + F(xi)                              2
                                         (m + F(xi))
                           2                             2
            m + F(xi)                   m + F(xi)
                   2                             2
                     2                           2
               2  2             2      2    k beta[1]
                                           (m + F(xi))
               2  4             2      4    k beta[2]
                                                      4
                                           (m + F(xi))
                                           2 w beta[1]
                                            m + F(xi)
                   2                     2   2 w beta[2]
                                             (m + F(xi))
          2                             2                     2
                       2                              3
                                             (m + F(xi))
           2                     2
                        4
             (m + F(xi))
          2                   3        2               2
                       2                          3
          2                   4
            (m + F(xi))
                                          2                   3
                                            (m + F(xi))
           2               2         2                   4
                     4                           4
              m + F(xi)                                2
                                            (m + F(xi))
simplify(%);
      2                   2               2
          2               3
          m + F(xi)
                                        (m + F(xi))
                 2                         3
                                       (m + F(xi))
                 2  3                     2  2      2
                 2      3                              2
          2                    3        2                2
           2                    4   2 A k  beta[1] K
                                      (m + F(xi))
          2              2
         (m + F(xi))
          2                 2        2
          2                  2              2
                  3                    3
                                           m + F(xi)
                                           (m + F(xi))
             m + F(xi)                              2
                                         (m + F(xi))
                           2                             2
            m + F(xi)                   m + F(xi)
                   2                             2
                     2                           2
               2  2             2      2    k beta[1]
                                           (m + F(xi))
               2  4             2      4    k beta[2]
                                                      4
                                           (m + F(xi))
                                           2 w beta[1]
                                            m + F(xi)
                   2                     2   2 w beta[2]
                                             (m + F(xi))
          2                             2                     2
                       2                              3
                                             (m + F(xi))
           2                     2
                        4
             (m + F(xi))
          2                   3        2               2
                       2                          3
          2                   4
            (m + F(xi))
                                          2                   3
                                            (m + F(xi))
           2               2         2                   4
                     4                           4
              m + F(xi)                                2
                                            (m + F(xi))
collect(%, m+F(xi));
Error, (in collect) cannot collect m+F(xi)
First 741 742 743 744 745 746 747 Last Page 743 of 2433
