The help page of interface('longdelim') states:
If true, Maple control structures such as if, do, proc, and so on are displayed with the newer-style long ending delimiters such as end if, end do, end proc, and so on. If false, ending delimiters are displayed as fi, od, end, and so on
If I set interface('longdelim' = false):, the Maple Input
try f:=0 catch:end try;
can be converted into
via , but why is
use f=0 in f+1 end use;
still converted into
 instead of “use f = 0 in f + 1 end”?
According to the documentation,
the depends modifier can be used in declaration to indicate that a parameter's type depends on the value of another parameter, the seq modifier declares that multiple arguments of a specific type within a procedure invocation will be assigned to a single parameter, and if the depends modifier is used together with the seq modifier, the declaration must be written: .
So the code below works as expected:
f0 := proc(x::Not(2), y::2) [[x], [y]] end:
f0(1, 2);
                           [[1], [2]]
f0(2, 2);
Error, invalid input: f0 expects its 1st argument, x, to be of type Not(2), but received 2
The code below also works as expected:
f1 := proc(x::depends(Not(y)), y::2) [[x], [y]] end:
f1(1, 2);
                           [[1], [2]]
f1(2, 2);
Error, invalid input: f1 expects its 1st argument, x, to be of type Not(2), but received 2
The code below works as desired as well:
f2 := proc(x::seq(Not(2)), y::2) [[x], [y]] end:
f2(0, 1, 2);
                         [[0, 1], [2]]
f2(2, 1, 2);
                           [[], [2]]
However, the following code does not work:
f3 := proc(x::seq(depends(Not(y))), y::2) [[x], [y]] end:
f3(0, 1, 2);
Error, invalid input: NULL uses a 2nd argument, y (of type 2), which is missing
f3(2, 1, 2);
I believe that the output of  and  should be the same as that of  and  respectively. Did I miss something?
Hi everyone! I meet some code issue when editing a easy sum of geometric sequence as belows, I can write another procedure sum total, it can run. But I wanna also try the sequence (the middle code) but failed, and why nops can not work? Thanks!
myfac := proc (n::nonnegint) local out, i, a, q; a := [3]; q := 2; out := a[1]; for i from 0 to n do out := out*q^i end do; out end proc; myfac(4)
3072
sum(myfac[i], i = 0 .. nops(myfac))
myfac[0]+myfac[1]
sum(myfac[i], i = 0 .. 4)
myfac[0]+myfac[1]+myfac[2]+myfac[3]+myfac[4]
values := [seq(myfac(i), i = 0 .. nops(myfac))]; sum_values := sum(myfac(i), i = 0 .. nops(myfac)); values; sum_values
[3, 6]
Error, invalid input: myfac expects its 1st argument, n, to be of type nonnegint, but received i
[3, 6]
sum_values
sum_myfac := proc (n::nonnegint) local i, total; total := 0; for i from 0 to n do total := total+myfac(i) end do; total end proc; sum_myfac(3)
225
Download sum_of_geometric_sequence.mw
Hello everyone
Any one can help to plot a figure as follows
" A cross section of three colored basins of attraction on an (x, y)
plane at z = 0 and w = 0 for a = 2.48 and b = 0.5. Basins in green, red, and cyan leads to a strange attractor, a limit cycle, and a line equilibrium,
respectively. The yellow leads to unbounded orbits. " Where the system
xdot=y
ydot=z
zdot=w
wdot=-az-bw-y-xy.
and range of x=[-6,6] and y=[-3,6].
With the attached task I would like to learn how Maple handles polynomials and plots. For this I have chosen a task with an interesting history from 1593. Adriaan van Roomen posed it to F. Vieta, who solved it after a short consideration.
My questions are:
1.) How are very long terms entered and displayed in Maple in an appropriate manner?
2.) How are the graphs of several functions displayed in the same coordinate system?
3.) Which graphics settings must be selected for differentiable functions in order to obtain nice, rounded curves rather than angular ones from the numerical result?
4.) Can the apparently random oscillations of the curve at the end of the interval be suppressed?
5.) The curves for p(x) and sinnx(x) are theoretically identical, since p(x) is the trigonometric expansion of sinnx(x). Their graphs must therefore be identical. How can this be displayed?
6.) The polynomial has many real zeros. How can the zeros be clearly presented in a table?
AF_20240909.mw
This is an excersise in one of Mathematica's tutorials. The problem is to find from all persumtations of [1,2,3,4] those lists which has 2 in them before 3.
But the idea is that 2 can be anywhere before the 3, with possibly zero or more numbers between.
Will show how to do this in that other software, and ask if there is a way using Maple pattern matching or better way to do this in Maple better than what I did.
L=Permutations[{1,2,3,4}]
Cases[L,{___,2,___,3,___}]
gives
{{1, 2, 3, 4}, {1, 2, 4, 3}, {1, 4, 2, 3}, {2, 1, 3, 4},
{2, 1, 4,  3}, {2, 3, 1, 4}, {2, 3, 4, 1}, {2, 4, 1, 3},
{2, 4, 3, 1}, {4, 1,  2, 3}, {4, 2, 1, 3}, {4, 2, 3, 1}}
We see in all of the above, 2 is before 3.
In that other software, the ___ means there is zero or more things.  I could not find how to do this in Maple's pattern matching. So had to use has and then find the index of 2 and 3 in each list and check if the index of 2 is smaller than the index of 3. Which is kinda awakard and not as elegent as using a pattern, but it gives same result.
L:=combinat:-permute([1,2,3,4]);
map(X->`if`(has(X,2) and has(X,3) and ListTools:-Search(2,X)<ListTools:-Search(3,X),X,NULL) ,L);
Gives
[[1, 2, 3, 4], [1, 2, 4, 3], [1, 4, 2, 3], [2, 1, 3, 4],
[2, 1, 4, 3], [2, 3, 1, 4], [2, 3, 4, 1], [2, 4, 1, 3],
[2, 4, 3, 1], [4, 1, 2, 3], [4, 2, 1, 3], [4, 2, 3, 1]]
Can you suggest a way using either patmatch or applyrules in Maple to do the same?
Could this be done easier than what I did using evalindents without the need for pattern?
I find patterns easier to work with myself.
ps. converting each list to string, and then using regular expression or string matching, is not what I am looking for.
ps. the check in Maple code of has(X,2) and has(X,3) is not really needed here, since we know each list will have 2 and 3 in them. But I kept these to make it more general for other type of problems where these extra checks might be needed.
Hi everyone, is there any source of Maple competitions? Or related questions? I have a hard time finding books on this subject. I am very interested in Maple and hope to improve my Maple programming skills. In addition to frequently browsing this website, I encounter problems on the Internet sporadically, so I think starting with competition questions will be a quick way to improve.
just a simple question: Is it possible to write if statments in Mapleflow, like (this is just a simple example, not what I would like to code!):
a:= 2
b:=5
if ( a > b ) then c:=a else c:=b end if
and, if so, how to do it? I've tried the above code but got the error
"internal error: unhandled case IF in subsindents"
Good morning, please, could you tell me how to graph this solid of revolution using implicitplot and shade the intersection zone as seen in the graph.
x=y-y^2
x=y^2-3
Around x=2
can someone help me curve fitting these parameeters...i only got 1 for all of this 90As4.mw
with(Statistics)with(plots)with(Optimization)with(LinearAlgebra)
E[1] := 126*10^9E[2] := 11*10^9G[12] := 6.6*10^9G_0__12 := 10.1*10^9nu[12] := .28E_0__2 := 15.5*10^9
true_strain := [0, .406915, .710106, .989362, 1.28457, 1.53989, 1.86702, 2.21011, 2.625, 2.99202]; true_stress := [0, 46.0227*10^6, 81.8182*10^6, 109.091*10^6, 138.068*10^6, 163.636*10^6, 194.318*10^6, 219.886*10^6, 248.864*10^6, 267.614*10^6]; epsilon_dot := 10^(-4)
sigma_t := map(proc (epsilon) options operator, arrow; E[instantaneous]*(1-lambda[90*deg]*epsilon*(sum(P[i], i = 1 .. 10)-(sum(P[i]*exp(lambda[i]*epsilon/epsilon_dot), i = 1 .. 10)))/epsilon_dot)*epsilon end proc, true_strain)
obj := sum((sigma_t[i]-true_stress[i])^2, i = 1 .. 10)
indets(obj, name)
{E[instantaneous], P[1], P[2], P[3], P[4], P[5], P[6], P[7], P[8], P[9], P[10], lambda[1], lambda[2], lambda[3], lambda[4], lambda[5], lambda[6], lambda[7], lambda[8], lambda[9], lambda[10], lambda[90*deg]}
Optimization[Interactive](obj)
The solution was obtained with the following warning:
  no iterations performed as initial point satisfies first-order conditions
[Float(infinity), [E[instantaneous] = HFloat(1.0), P[1] = HFloat(1.0), P[2] = HFloat(1.0), P[3] = HFloat(1.0), P[4] = HFloat(1.0), P[5] = HFloat(1.0), P[6] = HFloat(1.0), P[7] = HFloat(1.0), P[8] = HFloat(1.0), P[9] = HFloat(1.0), P[10] = HFloat(1.0), lambda[1] = HFloat(1.0), lambda[2] = HFloat(1.0), lambda[3] = HFloat(1.0), lambda[4] = HFloat(1.0), lambda[5] = HFloat(1.0), lambda[6] = HFloat(1.0), lambda[7] = HFloat(1.0), lambda[8] = HFloat(1.0), lambda[9] = HFloat(1.0), lambda[10] = HFloat(1.0), lambda[90*deg] = HFloat(1.0)]]
Download 90As4.mw
I apologize for putting the equations in image format, but I thought that this way the community could better understand how to interpret the equations.
Below are 6 letters whose solution must be developed step by step so that the periodic extension of each one can then be done. I can solve all the letters by hand (solving in the notebook), but my big question is, how can I do the commands in Maple step by step so that I can solve them as if I were doing them by hand (look like in my notebool)? I need to check step by step. I would be extremely grateful for the help of any of you.
second part
Dear all, how can I get the 1st which is (2) or 2nd element which is (3) of xxx ?
Dear all, I'm struggeling with the regex and special characters in maple. The StringTools:-Subs works but StringTools:-RegSplit not. Why? I do have the same problem wird the double quotes.
I am trying to create the plot for the dynamics of the discrete Klein - the equation gives Gordon equation (DKG) with friction for t=0 and t=3000.
As you can see below, creating the plot for t=0 is pretty easy. However, for t=3000, I tried to create a procedure to produce the desired plots, but when I ran the code, nothing happened. The worksheets are evaluated all the time. There are no results.
I am studying  for my thesis  the dynamics of the discrete Klein - the equation gives Gordon equation (DKG) with friction:
diff(U(t), t, t)-K(`U__n+!`-2*U__n+`U__n-1`)+delta*U__n+(D(W))(U__n) = 0, beta > 0, delta > 0
In the above equation, W describes the potential function:
W(U__n) = -(1/2)*`&omega;__d`^2*U__n^2+(1/4)*beta*`&omega;__d`^2*U__n^4
to which every coupled unit U__nadheres. In Eq. (1), the variable U__n(t)is the unknown displacement of the oscillator occupying the
n-th position of the lattice, and is the discretization parameter. We denote by the distance between the oscillators of the lattice. The chain (DKG) contains linear damping with a damping coefficient, while β s the coefficient of the nonlinear cubic term.
For the DKG chain (1), we will consider the problem of initial-boundary values, with initial conditions
U__n(0) = `U__n,0` and U__n(0) = `U__n,1` and `in`(`U__n,1`, 2*real^(k+2))
and Dirichlet boundary conditions at the boundary points x__0 = -(1/2)*Land "`x__k+1`=L/(2),"that is,
U__0 = `U__k+1` and `U__k+1` = 0, t >= 0*3
Therefore, when necessary, we will use the short notation `&Delta;__d`or the one-dimensional discrete Laplacian
`U__&Delta;__d__U__n&in;&Zopf;` = `U__Error loading this structure.`-2*U__n+4*`U__n-1`
We investigate numerically the dynamics of the system (1)-(2)-(3). Our first aim is to conduct a numerical study of the property of Dynamic Stability of the system, which directly depends on the existence and linear stability of the branches of equilibrium points.
For the discussion of numerical results, it is also important to emphasize the role of the parameter `&omega;__d`By changing the time variable proc (t) options operator, arrow; 1/h end proc we rewrite Eq.(1) in the form
diff(U(t), t, t)-`&Delta;__d`*U(t)+(diff(delta(x), x))*U__n = `&Omega;__d`(-`&beta;U__n`^3+U__n)^2, t > 0, `&Omega;__d`^2 = h^2*`&omega;__d`^2, diff(delta(x), x) = `h&delta;`
The change in the scaling of the lattice parameter of the problem makes it important to comment here on the nature of the continuous and anti-continuous limit. For the anti-continuous limit, we need to consider the case in Eq. (1) where proc (`&omega;__d`) options operator, arrow; infinity end procIn the case of nonlinearity present in the governing equations, the continuous limit needs to be taken as well. On the other hand, for small values of the parameter, the system becomes significant. However, because of the model we consider, we take the asymptotic linear limit as
proc (`&omega;__d`) options operator, arrow; 0 end proc
We consider spatially extended initial conditions of the form:
U__n(0) = `U__n,0` and `U__n,0` = a*sin(`j&pi;hn`/L), j = 1, () .. K
where h = L/(K+1) is the distance of the grid and  a > 0 is the amplitude of the initial condition
We also assume zero initial velocity:
"(`U__n`(0)=`U__n,1`=0) "
t=0
restart; with(plots); a := 2; j := 2; L := 200; K := 99; h := L/(K+1); n := Vector([`$`(-(1/2)*L+h*i, i = 0 .. K+1)]); U_n0 := a*map(proc (x) options operator, arrow; sin(j*Pi*x/L) end proc, h*n)
plot([seq([n[i], U_n0[i]], i = 1 .. K+2)], style = point, color = blue, axes = boxed, gridlines, grid = [true, true], labelfont = [TIMES, 12])
Now I am trying to create plot for different values of a.
a = {2, 1.82, 1.85, 1.9, 1.95}, K = 99, L = 200, beta = 1, delta = 0.5e-1, `&omega;__d`^2 = 1
L := 200; K := 99; j := 2; omega_d := 1; beta := 1; delta := 0.5e-1
dt := 0.5e-1; tmax := 3000; tspan := [seq(0+dt*i, i = 0 .. trunc(tmax/dt))]
a := 1; U0 := a*map(proc (x) options operator, arrow; sin(j*Pi*h*x/L) end proc, n); U0[1] := 0; U0[K+2] := 0; Udot0 := Vector(K+2, 0)
discrete_laplacian := proc (U) local i, Laplacian; Laplacian := Vector(K+2); for i from 2 to K+1 do Laplacian[i] := U[i+1]-2*U[i]+U[i-1] end do; Laplacian[1] := 0; Laplacian[K+2] := 0; return Laplacian end proc
U := U0; Udot := Udot0; for t to num_steps do Lap := discrete_laplacian(U); Ucube := map(proc (x) options operator, arrow; x^3 end proc, U); for i from 2 to K+1 do Udot[i] := Udot[i]+dt*(2*omega_d^2*U[i]-beta*Ucube[i]-delta*Udot[i]+Lap[i]) end do; for i from 2 to K+1 do U[i] := dt*Udot[i]+U[i] end do; U[1] := 0; U[K+2] := 0; if `mod`(t, 1000) = 0 then plotU := plot(n, U, style = line, color = blue, title = cat("Displacement at t=", t*dt), labels = ["n", "Displacement"], grid = [true, true]); display(plotU) end if end do
My target is the following plots
Download Numerical_Simulation_of_discrete_Klein-Gordon_Equation.mw
This is an example of what I need to display in Maple:
Notation
Is it possible to display boundary-conditions in Maple like this?
I tried to experiment with maple but I cannot type the lower and upper boundaries on top of each other. Unfortunately, they are not vertically aligned if I try to use superscript and subscript at the end of the right square bracket.
I hope there is a hack or a way to deal with this problem.
I know that the notation is a bit weird but that is how our teachers want us to display the intermediate calculations when we have to deliver our assignments. I know I could skip this intermidiate process but it is a tradition in my country to show the intermidiary calculations like I showed in the link.
Best regards.
First 77 78 79 80 81 82 83 Last Page 79 of 2430
