Hi everyone, I need to use the integral calculation in MapleSim but there is no MapleSim Block to do it. So I create a Custom Component and using the integral calculation from Maple, the expression of the equation was done. But when I click Dimension analysis button, one error popped out as the photo. Have anyone got the same error before? How should I do to solve it? Thank you very much.
Assume a linear second order ode with constant coefficients as follows:
M*u''+C*u'+K*u=0
where the symbol (') denotes derivative with respect to time and M, C and K are positive real constants.
The initial conditions are u(0)=u0 and u'(0)=u'0.
Substituting u=exp(a*t) in the ODE to calculate characteristic equation, one has
M*a^2+C*a+K=0  ---> If 0<C<2sqrt(M*K) then u=exp(-C/(2M)*t)*(c1*sin(w*t)+c2*cos(W*t))
in which c1 and c2 can be obtained from initial conditions and W=sqrt(C^2-4*M*K)/2M.
For the case that C is imaginary number, assuming C=i*c yields
{a1,a2} ={ -(c/(2M) +sqrt(c^2+4*M*K)/2M)*i,(-c/(2M) +sqrt(c^2+4*M*K)/2M)*i }
where i is one of the square roots of -1.
Is it true to write u=c1*(sin(a1*t)+cos(a1*t))+c2*(sin(a2*t)+cos(a2*t)) ?
I solve two examples by Maple,
dsolve({diff(u(t), t, t)+0.1*(diff(u(t), t))+2*u(t)} union {u(0) = 1, (D(u))(0) =0.1});
dsolve({diff(u(t), t, t)+0.1*I*(diff(u(t), t))+2*u(t)} union {u(0) = 1, (D(u))(0) = 0.1});
Second example gives complex answer. Is it possible to get trigonometric answer with real constants c1 and c2?
Hi folks,
I've just now installed Maple player, and I find it crashes immediately when I run it:
Exception in thread "Request id 1" java.lang.UnsupportedOperationException: PERPIXEL_TRANSLUCENT translucency is not supported
        at java.awt.Window.setBackground(Window.java:3842)
        at java.awt.Frame.setBackground(Frame.java:988)
        at com.maplesoft.worksheet.application.WmiSplashScreen.<init>(Unknown Source)
        at com.maplesoft.worksheet.player.WmiPlayerStartupStrategy.showSplash(Unknown Source)
        at com.maplesoft.worksheet.application.WmiGenericStartupStrategy.doStartup(Unknown Source)
        at com.maplesoft.worksheet.player.WmiPlayerStartupStrategy.doStartup(Unknown Source)
        at com.maplesoft.application.Maple.doStartup(Unknown Source)
        at com.maplesoft.application.Application.startup(Unknown Source)
        at com.maplesoft.application.ServerProtocol$StartApplicationHandler.processCommand(Unknown Source)
        at com.maplesoft.application.ServerProtocol.executeCommand(Unknown Source)
        at com.maplesoft.application.ServerProtocol.processNextStep(Unknown Source)
        at com.maplesoft.application.ExchangeProtocol.executeProtocol(Unknown Source)
        at com.maplesoft.application.ApplicationManager$Listener.run(Unknown Source)
        at java.lang.Thread.run(Thread.java:748)
The operating system is CentOS 7 (64 bit).   Any idea how I can fix this?
Bryan
How to solve system of convolution equations in maple?
When x axis range is large, the graph display still small , how to expand the graph display in large size?
hi. i want to show steps of a limit solution, but maple says it is unbale to show. could anybody help?
int.mw
x1=ginseng, x2=grape, f1=preference;
> x1:=5;
> f1:=3.579167+3.537500*x1-2.645833*x2-0.250000*x1*x1-0.012500*x2*x1+0.175000*x2*x2;
> plot3d (f1, x2=3..7, labels=[grape, preference], axes=boxed);
Error, (in plot3d/expression) bad range arguments: .8 = 3 .. 7, labels = [grape, preference]
The error was found! Please help!!!
I want to solve the following inequality for "r".
Another question is that what I can say about the signature of "f(r)" and their derivatives for various positive "r"?
inequalitysolve.mw
I'm trying to solve this system of differential equation, coming from the iterative process of the Elastic Curve's  solution.
The problem is that Maple returns:
risultato12 := NULL
EDIT: i think the problem is related to the non-linear equations in the system.
Any suggestion?
Here is the file
https://1drv.ms/u/s!AuhHGe410qgOm1_PdEDqkO4J1YYp
The attach maple workshhet evaluates a set of values for different values of input parameters. Each time I want to change the input parameter I have to run the code. I tried to call the code using documenttools[runworksheet] option, but I could not get any output. How can I get the output for a set of input parameters by running the code once. For example similar to a for loop that gives multiple outputs for corresponding inputs.
Download Numerical-recursive.mw
1 .. Nonlinear*Fractional*KdV*equation
PDE1 := D[t]^alpha*u(x, t)-3*(u^2)[x]+u[xxx] = 0;
"u(x,0)=6*x         0<alpha<=1, t>0"
Error, missing operation
2.*linear*time*fractional*diffusion*equation
PDE2 := diff(u(x, t), [`$`(t, alpha)]) = diff(u(x, t), x, x)
diff(u(x, t), [`$`(t, alpha)]) = diff(diff(u(x, t), x), x)
"IC:= u(x,0):=sinx , 0<alpha<=1 , t>0"
Error, unable to parse
Download kdv.mw
Integral is not evaluated.
PROBLE_13.mw
When are we actually going to see the  computation of the Feynman integrals behind the expansion of the Scattering matrix, including dimensional regularization? It’s been at least 5 years since it was mentioned. Thank you.
How to not display y axis at origin and set color for different set of grid line
is it possible use more than one set of grid line at axis[1] and color different set of grid line ?
Why does the "textplot" command not work? I just want to write
af_eq := (3*alpha[2](t[1], t[2])*A^3*(1/8)-A*sigma)^2+(1/4)*alpha[1](t[1], t[2])^2*A^2 = (1/4)*f0^2
(.9701625000*A^3-A*sigma)^2+0.1892250000e-4*A^2 = 0.2500000000e-2
 alpha[1]:=0.0087;alpha[2]:=2.5871;f0:=f[0]
0.87e-2
2.5871
f[0]
with(plots, implicitplot,implicitplot3d):
 f0 :=0.1; alpha[1]:=0.0087;alpha[2]:=2.5871;
.1
0.87e-2
2.5871
p1:=implicitplot(af_eq, sigma = -1.2 .. 2, A = 0 .. 2,  numpoints = 20000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, A], labelfont = [SYMBOL, 16],color="Red",tickmarks=[9,12],thickness=2);
t11 := textplot([-.5, 1, ('typeset')("Peak ")])
t22 := textplot([-.5, 1.2, ('typeset')("Lower ")])
display({p1, t11, t22}, 'view' = [-1.2 .. 2, 0 .. 2])
display({INTERFACE_PLOT(CURVES(Array(1..533, 1..2, {(1, 1) = -1.2, (1, 2) = 0.41261628514026705e-1, (2, 1) = -1.19267089595802, (2, 2) = 0.41436198756000325e-1, (3, 1) = -1.177304965, (3, 2) = 0.421126115892303e-1, (4, 1) = -1.1716162095098475, (4, 2) = 0.422506861764233e-1, (5, 1) = -1.154609929, (5, 2) = 0.4301411176968256e-1, (6, 1) = -1.15065572020245, (6, 2) = 0.43111945839586496e-1, (7, 1) = -1.131914894, (7, 2) = 0.43970208782359216e-1, (8, 1) = -1.1297968229372144, (8, 2) = 0.4402364898520697e-1, (9, 1) = -1.109219858, (9, 2) = 0.4498540288188576e-1, (10, 1) = -1.1090476520622503, (10, 2) = 0.4498983531567732e-1, (11, 1) = -1.107255897400308, (11, 2) = 0.4507534125795398e-1, (12, 1) = -1.0879078190362412, (12, 2) = 0.45762044520275144e-1, (13, 1) = -1.086524823, (13, 2) = 0.4584204330226836e-1, (14, 1) = -1.0668118778091222, (14, 2) = 0.4655604788564336e-1, (15, 1) = -1.063829787, (15, 2) = 0.46732239917926216e-1, (16, 1) = -1.0458134297696844, (16, 2) = 0.47398459476371786e-1, (17, 1) = -1.041134752, (17, 2) = 0.47680941429942045e-1, (18, 1) = -1.0249206528034631, (18, 2) = 0.4829334053858219e-1, (19, 1) = -1.018439716, (19, 2) = 0.4869339171996856e-1, (20, 1) = -1.0041426074601278, (20, 2) = 0.4924518946361946e-1, (21, 1) = -.9957446809, (21, 2) = 0.4977543555747364e-1, (22, 1) = -.9834893501712454, (22, 2) = 0.50258999763314875e-1, (23, 1) = -.9730496454, (23, 2) = 0.50933603529112095e-1, (24, 1) = -.9629720697165176, (24, 2) = 0.51340327129402084e-1, (25, 1) = -.9503546099, (25, 2) = 0.52175210665447225e-1, (26, 1) = -.9426032443041934, (26, 2) = 0.52495367314293634e-1, (27, 1) = -.9276595745, (27, 2) = 0.5350847241501685e-1, (28, 1) = -.9223968240637509, (28, 2) = 0.5373104701962268e-1, (29, 1) = -.904964539, (29, 2) = 0.54942641007772866e-1, (30, 1) = -.9023684452269646, (30, 2) = 0.5505513019407443e-1, (31, 1) = -.8842890231953708, (31, 2) = 0.5634417657244248e-1, (32, 1) = -.882471433514145, (32, 2) = 0.56444441450089165e-1, (33, 1) = -.8822695036, (33, 2) = 0.5646133607037262e-1, (34, 1) = -.8621065795999284, (34, 2) = 0.5760145363158678e-1, (35, 1) = -.8595744681, (35, 2) = 0.57818901927070655e-1, (36, 1) = -.8419124936084817, (36, 2) = 0.58843257731947804e-1, (37, 1) = -.8368794326, (37, 2) = 0.5928720766251162e-1, (38, 1) = -.8219065800847545, (38, 2) = 0.6017849564985e-1, (39, 1) = -.8141843972, (39, 2) = 0.6087864450608002e-1, (40, 1) = -.8021085378104986, (40, 2) = 0.61616948530202054e-1, (41, 1) = -.7914893617000001, (41, 2) = 0.6260738724914124e-1, (42, 1) = -.7825407348396687, (42, 2) = 0.6316972283262606e-1, (43, 1) = -.7687943263, (43, 2) = 0.6448971141760913e-1, (44, 1) = -.7632286568027249, (44, 2) = 0.6484947300726429e-1, (45, 1) = -.7460992908, (45, 2) = 0.6654437839452494e-1, (46, 1) = -.7442014461311223, (46, 2) = 0.6667066927521469e-1, (47, 1) = -.7349676796965554, (47, 2) = 0.6761301188693097e-1, (48, 1) = -.7250191353657424, (48, 2) = 0.6841485321974146e-1, (49, 1) = -.7234042553, (49, 2) = 0.686035468015165e-1, (50, 1) = -.705669718317685, (50, 2) = 0.700760633323882e-1, (51, 1) = -.7007092199, (51, 2) = 0.7067435705037604e-1, (52, 1) = -.6866105755767743, (52, 2) = 0.7188140426155366e-1, (53, 1) = -.6780141844, (53, 2) = 0.7295274738625322e-1, (54, 1) = -.6678771808256976, (54, 2) = 0.7384848982400836e-1, (55, 1) = -.655319149, (55, 2) = 0.754674599729381e-1, (56, 1) = -.6495106707592542, (56, 2) = 0.7599774575453017e-1, (57, 1) = -.6326241135, (57, 2) = 0.7825239260246131e-1, (58, 1) = -.6315589756845804, (58, 2) = 0.7835297106772943e-1, (59, 1) = -.6277391487718638, (59, 2) = 0.7888184720141947e-1, (60, 1) = -.6131709001212667, (60, 2) = 0.8049151904367856e-1, (61, 1) = -.609929078, (61, 2) = 0.8099550675764658e-1, (62, 1) = -.5949431283071579, (62, 2) = 0.82709663097192e-1, (63, 1) = -.5872340426, (63, 2) = 0.8395380010864444e-1, (64, 1) = -.5771593458207257, (64, 2) = 0.8514826254396962e-1, (65, 1) = -.5645390071, (65, 2) = 0.8726565535792828e-1, (66, 1) = -.5598826301952126, (66, 2) = 0.8783863745506451e-1, (67, 1) = -.5466477717457469, (67, 2) = 0.9015068251590796e-1, (68, 1) = -.5429027363722535, (68, 2) = 0.9067639417566692e-1, (69, 1) = -.5418439717, (69, 2) = 0.9088082428176686e-1, (70, 1) = -.525438211198211, (70, 2) = 0.932735154457075e-1, (71, 1) = -.5191489362, (71, 2) = 0.9453954179978605e-1, (72, 1) = -.5085364269751652, (72, 2) = 0.9615005620174408e-1, (73, 1) = -.4964539007, (73, 2) = 0.98690349811486e-1, (74, 1) = -.49228531989480223, (74, 2) = 0.9934967965825986e-1, (75, 1) = -.4828779696583565, (75, 2) = .10141951783039646, (76, 1) = -.4761536559337748, (76, 2) = .10260861054556743, (77, 1) = -.4737588653, (77, 2) = .10318308525315915, (78, 1) = -.45980229473358625, (78, 2) = .1057584545215515, (79, 1) = -.4510638298, (79, 2) = .10795556563308807, (80, 1) = -.44419925540218685, (80, 2) = .10927986503153263, (81, 1) = -.43129528363204245, (81, 2) = .11268835314488496, (82, 1) = -.4292450733383884, (82, 2) = .11312345460527987, (83, 1) = -.4283687944, (83, 2) = .11337288827715172, (84, 1) = -.4136417731873337, (84, 2) = .11664473562278216, (85, 1) = -.4056737589, (85, 2) = .1190316816970865, (86, 1) = -.39892294617003593, (86, 2) = .12060518678954052, (87, 1) = -.3883197764493317, (87, 2) = .12395718845937345, (88, 1) = -.38478097643791653, (88, 2) = .12485206666651785, (89, 1) = -.3829787234, (89, 2) = .12545955656623853, (90, 1) = -.3701655445733497, (90, 2) = .12886385691632035, (91, 1) = -.360283688, (91, 2) = .13238598411727817, (92, 1) = -.3566256907997566, (92, 2) = .1334097072481441, (93, 1) = -.3518223503261959, (93, 2) = .13522602377386195, (94, 1) = -.34294832064369674, (94, 2) = .13788727617206284, (95, 1) = -.3375886525, (95, 2) = .14002654564846956, (96, 1) = -.32963179392161496, (96, 2) = .14254401577129194, (97, 1) = -.3203234022204043, (97, 2) = .14649485908835044, (98, 1) = -.31708364996467686, (98, 2) = .14758228280240912, (99, 1) = -.3148936171, (99, 2) = .14855538315508504, (100, 1) = -.3040756221878905, (100, 2) = .152392202338086, (101, 1) = -.2927343644310111, (101, 2) = .15776369440283894, (102, 1) = -.29242837387060233, (102, 2) = .15787779386102044, (103, 1) = -.2921985816, (103, 2) = .15799085607151853, (104, 1) = -.27980822039178344, (104, 2) = .16288030581168872, (105, 1) = -.2695035461, (105, 2) = .16829801787630116, (106, 1) = -.2687012698815751, (106, 2) = .1686341730537304, (107, 1) = -.2679955692761825, (107, 2) = .16903252971732743, (108, 1) = -.25671570471486266, (108, 2) = .17395177905157494, (109, 1) = -.2468085107, (109, 2) = .1797065768533967, (110, 1) = -.24618915759827734, (110, 2) = .1799938357439754, (111, 1) = -.24569751399889558, (111, 2) = .18030136503181593, (112, 1) = -.234711252197147, (112, 2) = .1855635116224447, (113, 1) = -.22531120720983766, (113, 2) = .19157020034630443, (114, 1) = -.22470969906676053, (114, 2) = .19186624520444495, (115, 1) = -.2241134752, (115, 2) = .19225384054606207, (116, 1) = -.21373098061891724, (116, 2) = .19768378388322616, (117, 1) = -.2063681856878516, (117, 2) = .20283903566079292, (118, 1) = -.2039828738151915, (118, 2) = .20411236192280288, (119, 1) = -.2014184398, (119, 2) = .20592718037588806, (120, 1) = -.19373268245291744, (120, 2) = .21029163844872187, (121, 1) = -.18874015086561913, (121, 2) = .21410787097528142, (122, 1) = -.18410270991055838, (122, 2) = .2167788741385519, (123, 1) = -.178723404, (123, 2) = .22090843768638282, (124, 1) = -.17469706345541725, (124, 2) = .2233774950738828, (125, 1) = -.1722931793144359, (125, 2) = .2253767062897699, (126, 1) = -.16504869095233385, (126, 2) = .2298555944062463, (127, 1) = -.15686805983835422, (127, 2) = .2366455416042584, (128, 1) = -.15649517505772623, (128, 2) = .2368773262473895, (129, 1) = -.156028369, (129, 2) = .2372631575176681, (130, 1) = -.14682063010740992, (130, 2) = .2433424302957317, (131, 1) = -.1417102960582741, (131, 2) = .2479143769187469, (132, 1) = -.1381149592957238, (132, 2) = .25028861237983796, (133, 1) = -.133333333, (133, 2) = .2545242814869516, (134, 1) = -.1294442151790709, (134, 2) = .25725213663706675, (135, 1) = -.12743611919656356, (135, 2) = .25918321223323537, (136, 1) = -.1204543821581433, (136, 2) = .26405722259767306, (137, 1) = -.11369992138863468, (137, 2) = .2704520475477239, (138, 1) = -.11242277539170835, (138, 2) = .2713380995784694, (139, 1) = -.110638298, (139, 2) = .2729998078233795, (140, 1) = -.10355267094561393, (140, 2) = .2782026348904638, (141, 1) = -.10006722127068785, (141, 2) = .2817208828622124, (142, 1) = -0.9514584237784214e-1, (142, 2) = .285297202023692, (143, 1) = -0.87943262e-1, (143, 2) = .2924110188714629, (144, 1) = -0.8748570429005592e-1, (144, 2) = .2927625256440507, (145, 1) = -0.8727416892689449e-1, (145, 2) = .2929897181767009, (146, 1) = -0.785523542708645e-1, (146, 2) = .29959565728269333, (147, 1) = -0.740919585476014e-1, (147, 2) = .30425855349118935, (148, 1) = -0.7055877748780234e-1, (148, 2) = .30689541740773857, (149, 1) = -0.65248227e-1, (149, 2) = .31229992058430617, (150, 1) = -0.6273030225245567e-1, (150, 2) = .3142771559104939, (151, 1) = -0.61598592849592335e-1, (151, 2) = .3155273888056779, (152, 1) = -0.5414040818996799e-1, (152, 2) = .32128082478839937, (153, 1) = -0.4898701835759752e-1, (153, 2) = .3267962241201664, (154, 1) = -0.4643995390754995e-1, (154, 2) = .3287261299274413, (155, 1) = -0.42553192e-1, (155, 2) = .33275877680169197, (156, 1) = -0.38439002281444e-1, (156, 2) = .33602222828907, (157, 1) = -0.3662195775650565e-1, (157, 2) = .33806505943465487, (158, 1) = -0.3008766444513611e-1, (158, 2) = .3431443484041197, (159, 1) = -0.24382821326249318e-1, (159, 2) = .34933389474914334, (160, 1) = -0.22597435004447088e-1, (160, 2) = .350694037292277, (161, 1) = -0.19858156e-1, (161, 2) = .3535654033913945, (162, 1) = -0.14402294216216275e-1, (162, 2) = .3578937142837456, (163, 1) = -0.12013117316234797e-1, (163, 2) = .36060273006363186, (164, 1) = -0.622011302278846e-2, (164, 2) = .36509982608262626, (165, 1) = -0.11839877590065755e-4, (165, 2) = .3718715653781204, (166, 1) = 0.11140442324859723e-2, (166, 2) = .37272700980767026, (167, 1) = 0.2836879e-2, (167, 2) = .37453754120042687, (168, 1) = 0.9539442998612369e-2, (168, 2) = .37981235618608405, (169, 1) = 0.12471862136413488e-1, (169, 2) = .38314040069260885, (170, 1) = 0.17593552274937967e-1, (170, 2) = .3870820601028604, (171, 1) = 0.24322526461584885e-1, (171, 2) = .3944092360070973, (172, 1) = 0.24803188362344877e-1, (172, 2) = .39477107286291974, (173, 1) = 0.25531915e-1, (173, 2) = .3955338697916218, (174, 1) = 0.335062673468198e-1, (174, 2) = .40171854170041466, (175, 1) = 0.37014291678273754e-1, (175, 2) = .40567807132158584, (176, 1) = 0.4145044194966337e-1, (176, 2) = .40904283164147737, (177, 1) = 0.4822695e-1, (177, 2) = .41636543331894244, (178, 1) = 0.4868354184062358e-1, (178, 2) = .41672019369946894, (179, 1) = 0.4887701409911159e-1, (179, 2) = .41694690663607437, (180, 1) = 0.57585490211736395e-1, (180, 2) = .4235689174894747, (181, 1) = 0.6174769966791911e-1, (181, 2) = .42821574195056283, (182, 1) = 0.6541944531650314e-1, (182, 2) = .43094793522725994, (183, 1) = 0.70921986e-1, (183, 2) = .4368186633545512, (184, 1) = 0.7304724678510621e-1, (184, 2) = .43842931501109567, (185, 1) = 0.7396019943512601e-1, (185, 2) = .4394845772650513, (186, 1) = 0.8183631766597962e-1, (186, 2) = .445334086012666, (187, 1) = 0.8676693593953405e-1, (187, 2) = .4507534125795398, (188, 1) = 0.895456800656217e-1, (188, 2) = .45277496797694916, (189, 1) = 0.93617021e-1, (189, 2) = .4570451177053588, (190, 1) = 0.976519360158512e-1, (190, 2) = .4600187792579097, (191, 1) = 0.99416929477154e-1, (191, 2) = .46202224789402835, (192, 1) = .1062933790402563, (192, 2) = .4669968525607602, (193, 1) = .11213417917275714, (193, 2) = .4732910832085168, (194, 1) = .1138541892628568, (194, 2) = .4745114957584093, (195, 1) = .116312057, (195, 2) = .47703613428218394, (196, 1) = .12252047690692286, (196, 2) = .48147723275079535, (197, 1) = .12529701307964758, (197, 2) = .4845599185230053, (198, 1) = .1309700005103384, (198, 2) = .4885506002031381, (199, 1) = .13788366184059767, (199, 2) = .4958287538374938, (200, 1) = .13835342735212108, (200, 2) = .4961533199493262, (201, 1) = .139007092, (201, 2) = .4968087037070055, (202, 1) = .14765154085433121, (202, 2) = .5028053346464606, (203, 1) = .1516185902721116, (203, 2) = .5070975891519823, (204, 1) = .1558618339342827, (204, 2) = .5099974881437597, (205, 1) = .161702128, (205, 2) = .5159840367863033, (206, 1) = .1637279091152927, (206, 2) = .5173605571579852, (207, 1) = .1646282007005304, (207, 2) = .5183664244664707, (208, 1) = .17302384141469207, (208, 2) = .5240136547053116, (209, 1) = .1783733301975982, (209, 2) = .5296352597809593, (210, 1) = .1809511075710633, (210, 2) = .5313463402491448, (211, 1) = .184397163, (211, 2) = .5347758673843621, (212, 1) = .18970544158166563, (212, 2) = .5382683593715557, (213, 1) = .19214114775476732, (213, 2) = .5409040950954478, (214, 1) = .19860179418727114, (214, 2) = .5451198616440438, (215, 1) = .2055331874841016, (215, 2) = .5521729304099363, (216, 1) = .2062113949315691, (216, 2) = .5526102787354239, (217, 1) = .207092199, (217, 2) = .5534591828667559, (218, 1) = .21589183116696975, (218, 2) = .559072457383739, (219, 1) = .22007477073408385, (219, 2) = .5634417657244248, (220, 1) = .22434211587152972, (220, 2) = .5661454469241968, (221, 1) = .229787234, (221, 2) = .571496213370795, (222, 1) = .23266837952887315, (222, 2) = .5732800170154938, (223, 1) = .23399442714162416, (223, 2) = .5747106010389132, (224, 1) = .24222012399064247, (224, 2) = .5798060953654851, (225, 1) = .24836062676969145, (225, 2) = .5859794363534018, (226, 1) = .25020042141128895, (226, 2) = .5871124491330668, (227, 1) = .252482269, (227, 2) = .589273049307657, (228, 1) = .2597424313480354, (228, 2) = .5936433611554566, (229, 1) = .2632296091285283, (229, 2) = .5972482716678903, (230, 1) = .268627251343733, (230, 2) = .6005005897498503, (231, 1) = .275177305, (231, 2) = .6068235073394961, (232, 1) = .2767501435257067, (232, 2) = .6077361406466814, (233, 1) = .27747928509885705, (233, 2) = .6085171069823787, (234, 1) = .2868282823399778, (234, 2) = .6140008467948312, (235, 1) = .29268317440858527, (235, 2) = .6197859422968672, (236, 1) = .2950611539460224, (236, 2) = .621181789127712, (237, 1) = .29787234, (237, 2) = .6237828738055657, (238, 1) = .30470771202533337, (238, 2) = .6276607895310221, (239, 1) = .3080442338751085, (239, 2) = .6310547776113558, (240, 1) = .31386021896895094, (240, 2) = .6343851027102586, (241, 1) = .320567376, (241, 2) = .6407088297539558, (242, 1) = .32211916787132777, (242, 2) = .6415530969499775, (243, 1) = .3228487179056557, (243, 2) = .6423236129258443, (244, 1) = .33248054500276564, (244, 2) = .6476771659080589, (245, 1) = .3386118692085989, (245, 2) = .6535924482403328, (246, 1) = .3407978634877382, (246, 2) = .6548161775732204, (247, 1) = .343262411, (247, 2) = .6570314897213996, (248, 1) = .3508446287475112, (248, 2) = .661096461894468, (249, 1) = .3546359007797546, (249, 2) = .6648612835548212, (250, 1) = .3600319250093263, (250, 2) = .6678035010276325, (251, 1) = .365957447, (251, 2) = .6732237390059193, (252, 1) = .3688368462646208, (252, 2) = .6747004019238337, (253, 1) = .3702239192889135, (253, 2) = .6761301188693097, (254, 1) = .3791492546224394, (254, 2) = .6808487854972249, (255, 1) = .3861585761515719, (255, 2) = .6873989541837983, (256, 1) = .3873587036056653, (256, 2) = .6880413579368305, (257, 1) = .388652482, (257, 2) = .6891640112408506, (258, 1) = .3980971549553082, (258, 2) = .693978197283823, (259, 1) = .40298345582235984, (259, 2) = .6986677894982867, (260, 1) = .4070635407336446, (260, 2) = .7007949257718565, (261, 1) = .411347518, (261, 2) = .7045689463020051, (262, 1) = .4168000919566763, (262, 2) = .7072292415477635, (263, 1) = .4195269055680354, (263, 2) = .7099366248127752, (264, 1) = .4267171541994851, (264, 2) = .7135739275398234, (265, 1) = .434042553, (265, 2) = .720146621419057, (266, 1) = .43514659757709373, (266, 2) = .7206572655124095, (267, 1) = .43567484315402083, (267, 2) = .7212054601272637, (268, 1) = .4462907805706877, (268, 2) = .7263926457193876, (269, 1) = .45291837534317614, (269, 2) = .7324742954417522, (270, 1) = .4548191941717477, (270, 2) = .7334268418659017, (271, 1) = .456737589, (271, 2) = .7350427489987656, (272, 1) = .4657454482301041, (272, 2) = .7392704307934455, (273, 1) = .4704855919998322, (273, 2) = .7437431307562408, (274, 1) = .47500097975326555, (274, 2) = .7459435886620713, (275, 1) = .479432624, (275, 2) = .7497296020037805, (276, 1) = .48502740953821216, (276, 2) = .7522339701755038, (277, 1) = .4878698906252109, (277, 2) = .7550119660707292, (278, 1) = .49517658026858413, (278, 2) = .7584634068506074, (279, 1) = .50212766, (279, 2) = .7645032029789738, (280, 1) = .5040607937056584, (280, 2) = .7653209365791069, (281, 1) = .5049997443662744, (281, 2) = .7662808013852177, (282, 1) = .5153315255414652, (282, 2) = .770993480857628, (283, 1) = .5227245793683305, (283, 2) = .7775496366997062, (284, 1) = .5237997600680374, (284, 2) = .7780575577179255, (285, 1) = .524822695, (285, 2) = .7788841000898876, (286, 1) = .5354475382749663, (286, 2) = .7835428860057199, (287, 1) = .5412514509644586, (287, 2) = .7888184720141946, (288, 1) = .5445046574686911, (288, 2) = .790314562156639, (289, 1) = .54751773, (289, 2) = .7927761880543321, (290, 1) = .55550136781708, (290, 2) = .7961231673391631, (291, 1) = .5597332323632616, (291, 2) = .8000873073286832, (292, 1) = .5652499252683637, (292, 2) = .8025515217453003, (293, 1) = .570212766, (293, 2) = .8066586160492114, (294, 1) = .5754631438836486, (294, 2) = .8087491564142599, (295, 1) = .5781453048989444, (295, 2) = .8113561426431717, (296, 1) = .5860328365683942, (296, 2) = .8147697898119349, (297, 1) = .592907801, (297, 2) = .8205452188994823, (298, 1) = .595294009427073, (298, 2) = .8214401466231459, (299, 1) = .5964585313092597, (299, 2) = .8226249779576602, (300, 1) = .6068505720798303, (300, 2) = .826970766702572, (301, 1) = .6149493967262228, (301, 2) = .8338938132721487, (302, 1) = .6152960882547098, (302, 2) = .8340461241604681, (303, 1) = .615602837, (303, 2) = .8342823494384282, (304, 1) = .6277003471280935, (304, 2) = .8391558347901904, (305, 1) = .634586980263822, (305, 2) = .8451626485866371, (306, 1) = .6365788163140643, (306, 2) = .8460162165772238, (307, 1) = .638297872, (307, 2) = .8473495095131948, (308, 1) = .6485796006637554, (308, 2) = .8513262658675382, (309, 1) = .6542976984806798, (309, 2) = .8564314839011257, (310, 1) = .6579346440462116, (310, 2) = .8579500130122263, (311, 1) = .660992908, (311, 2) = .8603408007729323, (312, 1) = .6694862555608323, (312, 2) = .8634830913095224, (313, 1) = .6740845680154212, (313, 2) = .8677003192156142, (314, 1) = .6793658353812425, (314, 2) = .8698463885637018, (315, 1) = .683687943, (315, 2) = .8732545977341006, (316, 1) = .6904190825708448, (316, 2) = .875626921307706, (317, 1) = .693952648692807, (317, 2) = .8789691545301026, (318, 1) = .7008751518850601, (318, 2) = .8817039726946972, (319, 1) = .706382979, (319, 2) = .8860882007726247, (320, 1) = .7113781885483458, (320, 2) = .8877577031315868, (321, 1) = .713909575205173, (321, 2) = .8902379898445911, (322, 1) = .7224658969751668, (322, 2) = .8935211245845451, (323, 1) = .729078014, (323, 2) = .8988375674599276, (324, 1) = .7323656611545182, (324, 2) = .8998743997090204, (325, 1) = .7339661408374847, (325, 2) = .9015068251590796, (326, 1) = .7441419439283317, (326, 2) = .9052959214878551, (327, 1) = .75177305, (327, 2) = .9114970574022645, (328, 1) = .753386388023518, (328, 2) = .9119745847980459, (329, 1) = .7541368874572347, (329, 2) = .9127756604735682, (330, 1) = .7659077216566863, (330, 2) = .9170261639316147, (331, 1) = .7744501856484342, (331, 2) = .9240444957880567, (332, 1) = .7744601960750015, (332, 2) = .9240484129001746, (333, 1) = .774468085, (333, 2) = .9240541013714942, (334, 1) = .7877681575335678, (334, 2) = .9287094053076951, (335, 1) = .7957172182599538, (335, 2) = .9353133311025451, (336, 1) = .7965330650864829, (336, 2) = .9356261742005842, (337, 1) = .79716312, (337, 2) = .936080699484523, (338, 1) = .8097285548305844, (338, 2) = .9403430128082535, (339, 1) = .8171562753475038, (339, 2) = .9465821664170336, (340, 1) = .8186940604962507, (340, 2) = .9471601783013103, (341, 1) = .819858156, (341, 2) = .9479999321997671, (342, 1) = .8317943967794406, (342, 2) = .951924263499235, (343, 1) = .8387760734722867, (343, 2) = .9578510017315222, (344, 1) = .8409439174159301, (344, 2) = .9586500592784633, (345, 1) = .842553191, (345, 2) = .959810168927121, (346, 1) = .8539710766679941, (346, 2) = .9634504795163603, (347, 1) = .8605850020698751, (347, 2) = .9691198370460106, (348, 1) = .8632830132204153, (348, 2) = .9700956306265937, (349, 1) = .865248227, (349, 2) = .971510267474046, (350, 1) = .8762635502921021, (350, 2) = .9749192001118532, (351, 1) = .8825907012207321, (351, 2) = .9803886723604991, (352, 1) = .8857112811423421, (352, 2) = .9814969246592965, (353, 1) = .887943262, (353, 2) = .9830997664847827, (354, 1) = .8986759377168452, (354, 2) = .9863283795283331, (355, 1) = .9047996119484298, (355, 2) = .9916575076749876, (356, 1) = .9082281437304152, (356, 2) = .9928542289115815, (357, 1) = .910638298, (357, 2) = .9945790775346728, (358, 1) = .9212110989477038, (358, 2) = .9976765977173254, (359, 1) = .9272165297213989, (359, 2) = 1.0029263429894761, (360, 1) = .9308324551784213, (360, 2) = 1.0041681115222423, (361, 1) = .933333333, (361, 2) = 1.0059496416213003, (362, 1) = .9438702380442304, (362, 2) = 1.0089632567653588, (363, 1) = .949844212001387, (363, 2) = 1.0141951783039647, (364, 1) = .953522478003855, (364, 2) = 1.0154394359888441, (365, 1) = .956028369, (365, 2) = 1.0172140432960195, (366, 1) = .9666525829003361, (366, 2) = 1.0201887401152931, (367, 1) = .9726830795635464, (367, 2) = 1.0254640136184532, (368, 1) = .9762958811079261, (368, 2) = 1.0266693590031566, (369, 1) = .978723404, (369, 2) = 1.0283760496847765, (370, 1) = .9895552018914029, (370, 2) = 1.031354503351201, (371, 1) = .9957310589233355, (371, 2) = 1.0367328489329415, (372, 1) = .999149780031767, (372, 2) = 1.0378593135733407, (373, 1) = 1.00141844, (373, 2) = 1.0394405769870803, (374, 1) = 1.0125729904835612, (374, 2) = 1.0424630810945201, (375, 1) = 1.0189835864889594, (375, 2) = 1.04800168424743, (376, 1) = 1.0220808003670416, (376, 2) = 1.0490109744153784, (377, 1) = 1.024113475, (377, 2) = 1.0504135678147535, (378, 1) = 1.0356988524633386, (378, 2) = 1.0535179968212385, (379, 1) = 1.0424337893357438, (379, 2) = 1.0592705195619185, (380, 1) = 1.0450851784713082, (380, 2) = 1.0601262111086482, (381, 1) = 1.046808511, (381, 2) = 1.0613018014790114, (382, 1) = 1.0589240547414969, (382, 2) = 1.0645235867946037, (383, 1) = 1.066072821889716, (383, 2) = 1.070539354876407, (384, 1) = 1.0681588735095535, (384, 2) = 1.0712070292310296, (385, 1) = 1.069503546, (385, 2) = 1.0721126412766457, (386, 1) = 1.0822387217064668, (386, 2) = 1.075484754349653, (387, 1) = 1.089890331132023, (387, 2) = 1.0818081901908956, (388, 1) = 1.0912976997549417, (388, 2) = 1.0822555075177238, (389, 1) = 1.092198581, (389, 2) = 1.0828537564788456, (390, 1) = 1.1056324005262812, (390, 2) = 1.0864066902000677, (391, 1) = 1.1138749962769963, (391, 2) = 1.093077025505384, (392, 1) = 1.1144974541713701, (392, 2) = 1.0932737334407032, (393, 1) = 1.114893617, (393, 2) = 1.0935328359522722, (394, 1) = 1.1290946279490863, (394, 2) = 1.0972945893111703, (395, 1) = 1.137588652, (395, 2) = 1.1040087778450944, (396, 1) = 1.1381189448722804, (396, 2) = 1.1040825528856542, (397, 1) = 1.1382976252316022, (397, 2) = 1.1043458608198726, (398, 1) = 1.1526154413745195, (398, 2) = 1.1081533986608973, (399, 1) = 1.160283688, (399, 2) = 1.114061863976062, (400, 1) = 1.1626887166406676, (400, 2) = 1.1144205198892787, (401, 1) = 1.1635755682837294, (401, 2) = 1.1156146961343612, (402, 1) = 1.1761857775141515, (402, 2) = 1.1189876181845066, (403, 1) = 1.182978723, (403, 2) = 1.1240813104807699, (404, 1) = 1.1872472084382308, (404, 2) = 1.1247640873798597, (405, 1) = 1.1889683767544652, (405, 2) = 1.1268835314488497, (406, 1) = 1.1997977474791757, (406, 2) = 1.1298011653373443, (407, 1) = 1.205673759, (407, 2) = 1.1340840937864276, (408, 1) = 1.2117662883460014, (408, 2) = 1.135127224486678, (409, 1) = 1.2144445468439158, (409, 2) = 1.138152366763338, (410, 1) = 1.2234447737614151, (410, 2) = 1.140597305630091, (411, 1) = 1.228368794, (411, 2) = 1.144083294651399, (412, 1) = 1.2362291531660143, (412, 2) = 1.1455182740122114, (413, 1) = 1.2399797785422537, (413, 2) = 1.1494212020778265, (414, 1) = 1.2471216182823794, (414, 2) = 1.1513786404630624, (415, 1) = 1.25106383, (415, 2) = 1.1540883094611614, (416, 1) = 1.2606281183030106, (416, 2) = 1.1559410519958653, (417, 1) = 1.2655566476735318, (417, 2) = 1.160690037392315, (418, 1) = 1.2708243119629206, (418, 2) = 1.1621471400095387, (419, 1) = 1.273758865, (419, 2) = 1.1641052903046392, (420, 1) = 1.2849622300061962, (420, 2) = 1.1663960317744106, (421, 1) = 1.2911638364917823, (421, 2) = 1.1719588727068035, (422, 1) = 1.2945500306394797, (422, 2) = 1.172904207252774, (423, 1) = 1.296453901, (423, 2) = 1.1741377080665396, (424, 1) = 1.3092350950435536, (424, 2) = 1.1768814225540378, (425, 1) = 1.3167951362796533, (425, 2) = 1.183227708021292, (426, 1) = 1.3182969272214577, (426, 2) = 1.1836507585524716, (427, 1) = 1.319148936, (427, 2) = 1.1841869312590947, (428, 1) = 1.333453118078561, (428, 2) = 1.187394044262778, (429, 1) = 1.341843972, (429, 2) = 1.194019298232287, (430, 1) = 1.3426819684234765, (430, 2) = 1.1940804504022253, (431, 1) = 1.3428900796612153, (431, 2) = 1.1944965433357806, (432, 1) = 1.3576241724453957, (432, 2) = 1.1979299873389633, (433, 1) = 1.364539007, (433, 2) = 1.2030898406011152, (434, 1) = 1.3689730100174544, (434, 2) = 1.2035637495367806, (435, 1) = 1.3704761526800113, (435, 2) = 1.2057653786502691, (436, 1) = 1.381756670449592, (436, 2) = 1.208485074740529, (437, 1) = 1.387234042, (437, 2) = 1.2123646582358045, (438, 1) = 1.3946219007750242, (438, 2) = 1.2133658979566908, (439, 1) = 1.3977235026021453, (439, 2) = 1.2170342139647574, (440, 1) = 1.4058589487232358, (440, 2) = 1.2190551676450483, (441, 1) = 1.409929078, (441, 2) = 1.2218024974264723, (442, 1) = 1.4198341416851132, (442, 2) = 1.223384857637459, (443, 1) = 1.424710097163719, (443, 2) = 1.228303049279246, (444, 1) = 1.4299388908262032, (444, 2) = 1.2296363508784427, (445, 1) = 1.432624113, (445, 2) = 1.2313699249485637, (446, 1) = 1.444742799426594, (446, 2) = 1.2335545563300023, (447, 1) = 1.4514999002120572, (447, 2) = 1.2395718845937345, (448, 1) = 1.4540037259972756, (448, 2) = 1.2402250355817566, (449, 1) = 1.455319149, (449, 2) = 1.241039933707554, (450, 1) = 1.469437327616466, (450, 2) = 1.2438305773916114, (451, 1) = 1.478014184, (451, 2) = 1.2507351573135137, (452, 1) = 1.4782183459056166, (452, 2) = 1.2507393467757069, (453, 1) = 1.4782495260993627, (453, 2) = 1.250840719908223, (454, 1) = 1.4939797273266915, (454, 2) = 1.2541821353915725, (455, 1) = 1.50070922, (455, 2) = 1.2591634293759488, (456, 1) = 1.505854401668368, (456, 2) = 1.2595548023931185, (457, 1) = 1.5073989986545766, (457, 2) = 1.2621095552227115, (458, 1) = 1.5184140673336533, (458, 2) = 1.2645873484052492, (459, 1) = 1.523404255, (459, 2) = 1.2680272225372362, (460, 1) = 1.5321117743460344, (460, 2) = 1.2690548194484306, (461, 1) = 1.5357599743722785, (461, 2) = 1.2733783905372, (462, 1) = 1.5427723399764979, (462, 2) = 1.2750303316569769, (463, 1) = 1.546099291, (463, 2) = 1.2771869700824743, (464, 1) = 1.5576306142422092, (464, 2) = 1.2789215425656928, (465, 1) = 1.5635942937038148, (465, 2) = 1.2846472258516886, (466, 1) = 1.5670781819213742, (466, 2) = 1.2854993481329704, (467, 1) = 1.568794326, (467, 2) = 1.2865535515161495, (468, 1) = 1.582717529208757, (468, 2) = 1.2890027306911938, (469, 1) = 1.5910736351356305, (469, 2) = 1.295916061166177, (470, 1) = 1.5913493223373487, (470, 2) = 1.2959855954861892, (471, 1) = 1.591489362, (471, 2) = 1.2960676181511386, (472, 1) = 1.6075374375301157, (472, 2) = 1.299216496332204, (473, 1) = 1.614184397, (473, 2) = 1.30413089367417, (474, 1) = 1.619775181255238, (474, 2) = 1.3044088872323383, (475, 1) = 1.6212249932841432, (475, 2) = 1.3071848964806656, (476, 1) = 1.6321866840782542, (476, 2) = 1.3095150009948273, (477, 1) = 1.636879432, (477, 2) = 1.3126893495058787, (478, 1) = 1.6464795204325755, (478, 2) = 1.313686970660639, (479, 1) = 1.650460475112204, (479, 2) = 1.318453731795154, (480, 1) = 1.6567251307455784, (480, 2) = 1.3198685218961923, (481, 1) = 1.659574468, (481, 2) = 1.32166074537656, (482, 1) = 1.6721809211460665, (482, 2) = 1.3234630462759958, (483, 1) = 1.6789306407562474, (483, 2) = 1.3297225671096424, (484, 1) = 1.6811917774360323, (484, 2) = 1.3302576934883668, (485, 1) = 1.682269503, (485, 2) = 1.3308954548933172, (486, 1) = 1.6973698232778063, (486, 2) = 1.3334935944274116, (487, 1) = 1.704964539, (487, 2) = 1.3394534244250287, (488, 1) = 1.7081500816800899, (488, 2) = 1.3394096751498963, (489, 1) = 1.708496655893026, (489, 2) = 1.340991402424131, (490, 1) = 1.7222705339674442, (490, 2) = 1.3436672389949957, (491, 1) = 1.727659574, (491, 2) = 1.3474175387258738, (492, 1) = 1.7362633447311187, (492, 2) = 1.347988181265451, (493, 1) = 1.7391255312858365, (493, 2) = 1.3522602377386195, (494, 1) = 1.746999930576139, (494, 2) = 1.3539259469254386, (495, 1) = 1.75035461, (495, 2) = 1.3560556866576374, (496, 1) = 1.7624943764568155, (496, 2) = 1.3575012775921975, (497, 1) = 1.7684820328348467, (497, 2) = 1.363529073053108, (498, 1) = 1.771624703972516, (498, 2) = 1.3642366033905395, (499, 1) = 1.773049645, (499, 2) = 1.3650773164483616, (500, 1) = 1.787947397080901, (500, 2) = 1.3674006821743552, (501, 1) = 1.795744681, (501, 2) = 1.3736934108737564, (502, 1) = 1.7982408043979758, (502, 2) = 1.3735585005633595, (503, 1) = 1.7982817067824142, (503, 2) = 1.3747979083675965, (504, 1) = 1.813015524786313, (504, 2) = 1.3774911986622067, (505, 1) = 1.818439716, (505, 2) = 1.3812734215805165, (506, 1) = 1.8272589509789168, (506, 2) = 1.38168770209003, (507, 1) = 1.8298930119727332, (507, 2) = 1.386066743682085, (508, 1) = 1.8378735238228332, (508, 2) = 1.3876860512368943, (509, 1) = 1.841134752, (509, 2) = 1.3897317178670505, (510, 1) = 1.853695160847097, (510, 2) = 1.391098920679872, (511, 1) = 1.8598377398631647, (511, 2) = 1.3973355789965733, (512, 1) = 1.8626106992395048, (512, 2) = 1.397940896380174, (513, 1) = 1.863829787, (513, 2) = 1.398645893407542, (514, 1) = 1.8792317204698494, (514, 2) = 1.4009568453979109, (515, 1) = 1.886524823, (515, 2) = 1.4067256516680482, (516, 1) = 1.8907900133376323, (516, 2) = 1.4064866062750874, (517, 1) = 1.8908897521944803, (517, 2) = 1.4086044143110619, (518, 1) = 1.9043628317265646, (518, 2) = 1.411016088458887, (519, 1) = 1.909219858, (519, 2) = 1.4142995395813438, (520, 1) = 1.9194103188649203, (520, 2) = 1.4148133488470087, (521, 1) = 1.9227626617096658, (521, 2) = 1.4198732496255504, (522, 1) = 1.9292857347586272, (522, 2) = 1.4211787136284815, (523, 1) = 1.931914893, (523, 2) = 1.4227704338717295, (524, 1) = 1.945646142157817, (524, 2) = 1.4243240659943255, (525, 1) = 1.9529091122156412, (525, 2) = 1.431142084940039, (526, 1) = 1.9540943988482649, (526, 2) = 1.4313980626956835, (527, 1) = 1.954609929, (527, 2) = 1.4316853020793843, (528, 1) = 1.9711006684096328, (528, 2) = 1.4342227228527038, (529, 1) = 1.977304964, (529, 2) = 1.438808256867013, (530, 1) = 1.9848990157466457, (530, 2) = 1.4386402226225583, (531, 1) = 1.9858894123366866, (531, 2) = 1.4424109202545274, (532, 1) = 1.9962153472752922, (532, 2) = 1.444290125393363, (533, 1) = 2.0, (533, 2) = 1.4466982421140733}, datatype = float[8], order = C_order, attributes = [source_rtable = (Array(1..1064, 1..2, {(1, 1) = 533.0, (1, 2) = .0, (2, 1) = -1.2, (2, 2) = 0.41261628514026705e-1, (3, 1) = -1.19267089595802, (3, 2) = 0.41436198756000325e-1, (4, 1) = -1.177304965, (4, 2) = 0.421126115892303e-1, (5, 1) = -1.1716162095098475, (5, 2) = 0.422506861764233e-1, (6, 1) = -1.154609929, (6, 2) = 0.4301411176968256e-1, (7, 1) = -1.15065572020245, (7, 2) = 0.43111945839586496e-1, (8, 1) = -1.131914894, (8, 2) = 0.43970208782359216e-1, (9, 1) = -1.1297968229372144, (9, 2) = 0.4402364898520697e-1, (10, 1) = -1.109219858, (10, 2) = 0.4498540288188576e-1, (11, 1) = -1.1090476520622503, (11, 2) = 0.4498983531567732e-1, (12, 1) = -1.107255897400308, (12, 2) = 0.4507534125795398e-1, (13, 1) = -1.0879078190362412, (13, 2) = 0.45762044520275144e-1, (14, 1) = -1.086524823, (14, 2) = 0.4584204330226836e-1, (15, 1) = -1.0668118778091222, (15, 2) = 0.4655604788564336e-1, (16, 1) = -1.063829787, (16, 2) = 0.46732239917926216e-1, (17, 1) = -1.0458134297696844, (17, 2) = 0.47398459476371786e-1, (18, 1) = -1.041134752, (18, 2) = 0.47680941429942045e-1, (19, 1) = -1.0249206528034631, (19, 2) = 0.4829334053858219e-1, (20, 1) = -1.018439716, (20, 2) = 0.4869339171996856e-1, (21, 1) = -1.0041426074601278, (21, 2) = 0.4924518946361946e-1, (22, 1) = -.9957446809, (22, 2) = 0.4977543555747364e-1, (23, 1) = -.9834893501712454, (23, 2) = 0.50258999763314875e-1, (24, 1) = -.9730496454, (24, 2) = 0.50933603529112095e-1, (25, 1) = -.9629720697165176, (25, 2) = 0.51340327129402084e-1, (26, 1) = -.9503546099, (26, 2) = 0.52175210665447225e-1, (27, 1) = -.9426032443041934, (27, 2) = 0.52495367314293634e-1, (28, 1) = -.9276595745, (28, 2) = 0.5350847241501685e-1, (29, 1) = -.9223968240637509, (29, 2) = 0.5373104701962268e-1, (30, 1) = -.904964539, (30, 2) = 0.54942641007772866e-1, (31, 1) = -.9023684452269646, (31, 2) = 0.5505513019407443e-1, (32, 1) = -.8842890231953708, (32, 2) = 0.5634417657244248e-1, (33, 1) = -.882471433514145, (33, 2) = 0.56444441450089165e-1, (34, 1) = -.8822695036, (34, 2) = 0.5646133607037262e-1, (35, 1) = -.8621065795999284, (35, 2) = 0.5760145363158678e-1, (36, 1) = -.8595744681, (36, 2) = 0.57818901927070655e-1, (37, 1) = -.8419124936084817, (37, 2) = 0.58843257731947804e-1, (38, 1) = -.8368794326, (38, 2) = 0.5928720766251162e-1, (39, 1) = -.8219065800847545, (39, 2) = 0.6017849564985e-1, (40, 1) = -.8141843972, (40, 2) = 0.6087864450608002e-1, (41, 1) = -.8021085378104986, (41, 2) = 0.61616948530202054e-1, (42, 1) = -.7914893617000001, (42, 2) = 0.6260738724914124e-1, (43, 1) = -.7825407348396687, (43, 2) = 0.6316972283262606e-1, (44, 1) = -.7687943263, (44, 2) = 0.6448971141760913e-1, (45, 1) = -.7632286568027249, (45, 2) = 0.6484947300726429e-1, (46, 1) = -.7460992908, (46, 2) = 0.6654437839452494e-1, (47, 1) = -.7442014461311223, (47, 2) = 0.6667066927521469e-1, (48, 1) = -.7349676796965554, (48, 2) = 0.6761301188693097e-1, (49, 1) = -.7250191353657424, (49, 2) = 0.6841485321974146e-1, (50, 1) = -.7234042553, (50, 2) = 0.686035468015165e-1, (51, 1) = -.705669718317685, (51, 2) = 0.700760633323882e-1, (52, 1) = -.7007092199, (52, 2) = 0.7067435705037604e-1, (53, 1) = -.6866105755767743, (53, 2) = 0.7188140426155366e-1, (54, 1) = -.6780141844, (54, 2) = 0.7295274738625322e-1, (55, 1) = -.6678771808256976, (55, 2) = 0.7384848982400836e-1, (56, 1) = -.655319149, (56, 2) = 0.754674599729381e-1, (57, 1) = -.6495106707592542, (57, 2) = 0.7599774575453017e-1, (58, 1) = -.6326241135, (58, 2) = 0.7825239260246131e-1, (59, 1) = -.6315589756845804, (59, 2) = 0.7835297106772943e-1, (60, 1) = -.6277391487718638, (60, 2) = 0.7888184720141947e-1, (61, 1) = -.6131709001212667, (61, 2) = 0.8049151904367856e-1, (62, 1) = -.609929078, (62, 2) = 0.8099550675764658e-1, (63, 1) = -.5949431283071579, (63, 2) = 0.82709663097192e-1, (64, 1) = -.5872340426, (64, 2) = 0.8395380010864444e-1, (65, 1) = -.5771593458207257, (65, 2) = 0.8514826254396962e-1, (66, 1) = -.5645390071, (66, 2) = 0.8726565535792828e-1, (67, 1) = -.5598826301952126, (67, 2) = 0.8783863745506451e-1, (68, 1) = -.5466477717457469, (68, 2) = 0.9015068251590796e-1, (69, 1) = -.5429027363722535, (69, 2) = 0.9067639417566692e-1, (70, 1) = -.5418439717, (70, 2) = 0.9088082428176686e-1, (71, 1) = -.525438211198211, (71, 2) = 0.932735154457075e-1, (72, 1) = -.5191489362, (72, 2) = 0.9453954179978605e-1, (73, 1) = -.5085364269751652, (73, 2) = 0.9615005620174408e-1, (74, 1) = -.4964539007, (74, 2) = 0.98690349811486e-1, (75, 1) = -.49228531989480223, (75, 2) = 0.9934967965825986e-1, (76, 1) = -.4828779696583565, (76, 2) = .10141951783039646, (77, 1) = -.4761536559337748, (77, 2) = .10260861054556743, (78, 1) = -.4737588653, (78, 2) = .10318308525315915, (79, 1) = -.45980229473358625, (79, 2) = .1057584545215515, (80, 1) = -.4510638298, (80, 2) = .10795556563308807, (81, 1) = -.44419925540218685, (81, 2) = .10927986503153263, (82, 1) = -.43129528363204245, (82, 2) = .11268835314488496, (83, 1) = -.4292450733383884, (83, 2) = .11312345460527987, (84, 1) = -.4283687944, (84, 2) = .11337288827715172, (85, 1) = -.4136417731873337, (85, 2) = .11664473562278216, (86, 1) = -.4056737589, (86, 2) = .1190316816970865, (87, 1) = -.39892294617003593, (87, 2) = .12060518678954052, (88, 1) = -.3883197764493317, (88, 2) = .12395718845937345, (89, 1) = -.38478097643791653, (89, 2) = .12485206666651785, (90, 1) = -.3829787234, (90, 2) = .12545955656623853, (91, 1) = -.3701655445733497, (91, 2) = .12886385691632035, (92, 1) = -.360283688, (92, 2) = .13238598411727817, (93, 1) = -.3566256907997566, (93, 2) = .1334097072481441, (94, 1) = -.3518223503261959, (94, 2) = .13522602377386195, (95, 1) = -.34294832064369674, (95, 2) = .13788727617206284, (96, 1) = -.3375886525, (96, 2) = .14002654564846956, (97, 1) = -.32963179392161496, (97, 2) = .14254401577129194, (98, 1) = -.3203234022204043, (98, 2) = .14649485908835044, (99, 1) = -.31708364996467686, (99, 2) = .14758228280240912, (100, 1) = -.3148936171, (100, 2) = .14855538315508504, (101, 1) = -.3040756221878905, (101, 2) = .152392202338086, (102, 1) = -.2927343644310111, (102, 2) = .15776369440283894, (103, 1) = -.29242837387060233, (103, 2) = .15787779386102044, (104, 1) = -.2921985816, (104, 2) = .15799085607151853, (105, 1) = -.27980822039178344, (105, 2) = .16288030581168872, (106, 1) = -.2695035461, (106, 2) = .16829801787630116, (107, 1) = -.2687012698815751, (107, 2) = .1686341730537304, (108, 1) = -.2679955692761825, (108, 2) = .16903252971732743, (109, 1) = -.25671570471486266, (109, 2) = .17395177905157494, (110, 1) = -.2468085107, (110, 2) = .1797065768533967, (111, 1) = -.24618915759827734, (111, 2) = .1799938357439754, (112, 1) = -.24569751399889558, (112, 2) = .18030136503181593, (113, 1) = -.234711252197147, (113, 2) = .1855635116224447, (114, 1) = -.22531120720983766, (114, 2) = .19157020034630443, (115, 1) = -.22470969906676053, (115, 2) = .19186624520444495, (116, 1) = -.2241134752, (116, 2) = .19225384054606207, (117, 1) = -.21373098061891724, (117, 2) = .19768378388322616, (118, 1) = -.2063681856878516, (118, 2) = .20283903566079292, (119, 1) = -.2039828738151915, (119, 2) = .20411236192280288, (120, 1) = -.2014184398, (120, 2) = .20592718037588806, (121, 1) = -.19373268245291744, (121, 2) = .21029163844872187, (122, 1) = -.18874015086561913, (122, 2) = .21410787097528142, (123, 1) = -.18410270991055838, (123, 2) = .2167788741385519, (124, 1) = -.178723404, (124, 2) = .22090843768638282, (125, 1) = -.17469706345541725, (125, 2) = .2233774950738828, (126, 1) = -.1722931793144359, (126, 2) = .2253767062897699, (127, 1) = -.16504869095233385, (127, 2) = .2298555944062463, (128, 1) = -.15686805983835422, (128, 2) = .2366455416042584, (129, 1) = -.15649517505772623, (129, 2) = .2368773262473895, (130, 1) = -.156028369, (130, 2) = .2372631575176681, (131, 1) = -.14682063010740992, (131, 2) = .2433424302957317, (132, 1) = -.1417102960582741, (132, 2) = .2479143769187469, (133, 1) = -.1381149592957238, (133, 2) = .25028861237983796, (134, 1) = -.133333333, (134, 2) = .2545242814869516, (135, 1) = -.1294442151790709, (135, 2) = .25725213663706675, (136, 1) = -.12743611919656356, (136, 2) = .25918321223323537, (137, 1) = -.1204543821581433, (137, 2) = .26405722259767306, (138, 1) = -.11369992138863468, (138, 2) = .2704520475477239, (139, 1) = -.11242277539170835, (139, 2) = .2713380995784694, (140, 1) = -.110638298, (140, 2) = .2729998078233795, (141, 1) = -.10355267094561393, (141, 2) = .2782026348904638, (142, 1) = -.10006722127068785, (142, 2) = .2817208828622124, (143, 1) = -0.9514584237784214e-1, (143, 2) = .285297202023692, (144, 1) = -0.87943262e-1, (144, 2) = .2924110188714629, (145, 1) = -0.8748570429005592e-1, (145, 2) = .2927625256440507, (146, 1) = -0.8727416892689449e-1, (146, 2) = .2929897181767009, (147, 1) = -0.785523542708645e-1, (147, 2) = .29959565728269333, (148, 1) = -0.740919585476014e-1, (148, 2) = .30425855349118935, (149, 1) = -0.7055877748780234e-1, (149, 2) = .30689541740773857, (150, 1) = -0.65248227e-1, (150, 2) = .31229992058430617, (151, 1) = -0.6273030225245567e-1, (151, 2) = .3142771559104939, (152, 1) = -0.61598592849592335e-1, (152, 2) = .3155273888056779, (153, 1) = -0.5414040818996799e-1, (153, 2) = .32128082478839937, (154, 1) = -0.4898701835759752e-1, (154, 2) = .3267962241201664, (155, 1) = -0.4643995390754995e-1, (155, 2) = .3287261299274413, (156, 1) = -0.42553192e-1, (156, 2) = .33275877680169197, (157, 1) = -0.38439002281444e-1, (157, 2) = .33602222828907, (158, 1) = -0.3662195775650565e-1, (158, 2) = .33806505943465487, (159, 1) = -0.3008766444513611e-1, (159, 2) = .3431443484041197, (160, 1) = -0.24382821326249318e-1, (160, 2) = .34933389474914334, (161, 1) = -0.22597435004447088e-1, (161, 2) = .350694037292277, (162, 1) = -0.19858156e-1, (162, 2) = .3535654033913945, (163, 1) = -0.14402294216216275e-1, (163, 2) = .3578937142837456, (164, 1) = -0.12013117316234797e-1, (164, 2) = .36060273006363186, (165, 1) = -0.622011302278846e-2, (165, 2) = .36509982608262626, (166, 1) = -0.11839877590065755e-4, (166, 2) = .3718715653781204, (167, 1) = 0.11140442324859723e-2, (167, 2) = .37272700980767026, (168, 1) = 0.2836879e-2, (168, 2) = .37453754120042687, (169, 1) = 0.9539442998612369e-2, (169, 2) = .37981235618608405, (170, 1) = 0.12471862136413488e-1, (170, 2) = .38314040069260885, (171, 1) = 0.17593552274937967e-1, (171, 2) = .3870820601028604, (172, 1) = 0.24322526461584885e-1, (172, 2) = .3944092360070973, (173, 1) = 0.24803188362344877e-1, (173, 2) = .39477107286291974, (174, 1) = 0.25531915e-1, (174, 2) = .3955338697916218, (175, 1) = 0.335062673468198e-1, (175, 2) = .40171854170041466, (176, 1) = 0.37014291678273754e-1, (176, 2) = .40567807132158584, (177, 1) = 0.4145044194966337e-1, (177, 2) = .40904283164147737, (178, 1) = 0.4822695e-1, (178, 2) = .41636543331894244, (179, 1) = 0.4868354184062358e-1, (179, 2) = .41672019369946894, (180, 1) = 0.4887701409911159e-1, (180, 2) = .41694690663607437, (181, 1) = 0.57585490211736395e-1, (181, 2) = .4235689174894747, (182, 1) = 0.6174769966791911e-1, (182, 2) = .42821574195056283, (183, 1) = 0.6541944531650314e-1, (183, 2) = .43094793522725994, (184, 1) = 0.70921986e-1, (184, 2) = .4368186633545512, (185, 1) = 0.7304724678510621e-1, (185, 2) = .43842931501109567, (186, 1) = 0.7396019943512601e-1, (186, 2) = .4394845772650513, (187, 1) = 0.8183631766597962e-1, (187, 2) = .445334086012666, (188, 1) = 0.8676693593953405e-1, (188, 2) = .4507534125795398, (189, 1) = 0.895456800656217e-1, (189, 2) = .45277496797694916, (190, 1) = 0.93617021e-1, (190, 2) = .4570451177053588, (191, 1) = 0.976519360158512e-1, (191, 2) = .4600187792579097, (192, 1) = 0.99416929477154e-1, (192, 2) = .46202224789402835, (193, 1) = .1062933790402563, (193, 2) = .4669968525607602, (194, 1) = .11213417917275714, (194, 2) = .4732910832085168, (195, 1) = .1138541892628568, (195, 2) = .4745114957584093, (196, 1) = .116312057, (196, 2) = .47703613428218394, (197, 1) = .12252047690692286, (197, 2) = .48147723275079535, (198, 1) = .12529701307964758, (198, 2) = .4845599185230053, (199, 1) = .1309700005103384, (199, 2) = .4885506002031381, (200, 1) = .13788366184059767, (200, 2) = .4958287538374938, (201, 1) = .13835342735212108, (201, 2) = .4961533199493262, (202, 1) = .139007092, (202, 2) = .4968087037070055, (203, 1) = .14765154085433121, (203, 2) = .5028053346464606, (204, 1) = .1516185902721116, (204, 2) = .5070975891519823, (205, 1) = .1558618339342827, (205, 2) = .5099974881437597, (206, 1) = .161702128, (206, 2) = .5159840367863033, (207, 1) = .1637279091152927, (207, 2) = .5173605571579852, (208, 1) = .1646282007005304, (208, 2) = .5183664244664707, (209, 1) = .17302384141469207, (209, 2) = .5240136547053116, (210, 1) = .1783733301975982, (210, 2) = .5296352597809593, (211, 1) = .1809511075710633, (211, 2) = .5313463402491448, (212, 1) = .184397163, (212, 2) = .5347758673843621, (213, 1) = .18970544158166563, (213, 2) = .5382683593715557, (214, 1) = .19214114775476732, (214, 2) = .5409040950954478, (215, 1) = .19860179418727114, (215, 2) = .5451198616440438, (216, 1) = .2055331874841016, (216, 2) = .5521729304099363, (217, 1) = .2062113949315691, (217, 2) = .5526102787354239, (218, 1) = .207092199, (218, 2) = .5534591828667559, (219, 1) = .21589183116696975, (219, 2) = .559072457383739, (220, 1) = .22007477073408385, (220, 2) = .5634417657244248, (221, 1) = .22434211587152972, (221, 2) = .5661454469241968, (222, 1) = .229787234, (222, 2) = .571496213370795, (223, 1) = .23266837952887315, (223, 2) = .5732800170154938, (224, 1) = .23399442714162416, (224, 2) = .5747106010389132, (225, 1) = .24222012399064247, (225, 2) = .5798060953654851, (226, 1) = .24836062676969145, (226, 2) = .5859794363534018, (227, 1) = .25020042141128895, (227, 2) = .5871124491330668, (228, 1) = .252482269, (228, 2) = .589273049307657, (229, 1) = .2597424313480354, (229, 2) = .5936433611554566, (230, 1) = .2632296091285283, (230, 2) = .5972482716678903, (231, 1) = .268627251343733, (231, 2) = .6005005897498503, (232, 1) = .275177305, (232, 2) = .6068235073394961, (233, 1) = .2767501435257067, (233, 2) = .6077361406466814, (234, 1) = .27747928509885705, (234, 2) = .6085171069823787, (235, 1) = .2868282823399778, (235, 2) = .6140008467948312, (236, 1) = .29268317440858527, (236, 2) = .6197859422968672, (237, 1) = .2950611539460224, (237, 2) = .621181789127712, (238, 1) = .29787234, (238, 2) = .6237828738055657, (239, 1) = .30470771202533337, (239, 2) = .6276607895310221, (240, 1) = .3080442338751085, (240, 2) = .6310547776113558, (241, 1) = .31386021896895094, (241, 2) = .6343851027102586, (242, 1) = .320567376, (242, 2) = .6407088297539558, (243, 1) = .32211916787132777, (243, 2) = .6415530969499775, (244, 1) = .3228487179056557, (244, 2) = .6423236129258443, (245, 1) = .33248054500276564, (245, 2) = .6476771659080589, (246, 1) = .3386118692085989, (246, 2) = .6535924482403328, (247, 1) = .3407978634877382, (247, 2) = .6548161775732204, (248, 1) = .343262411, (248, 2) = .6570314897213996, (249, 1) = .3508446287475112, (249, 2) = .661096461894468, (250, 1) = .3546359007797546, (250, 2) = .6648612835548212, (251, 1) = .3600319250093263, (251, 2) = .6678035010276325, (252, 1) = .365957447, (252, 2) = .6732237390059193, (253, 1) = .3688368462646208, (253, 2) = .6747004019238337, (254, 1) = .3702239192889135, (254, 2) = .6761301188693097, (255, 1) = .3791492546224394, (255, 2) = .6808487854972249, (256, 1) = .3861585761515719, (256, 2) = .6873989541837983, (257, 1) = .3873587036056653, (257, 2) = .6880413579368305, (258, 1) = .388652482, (258, 2) = .6891640112408506, (259, 1) = .3980971549553082, (259, 2) = .693978197283823, (260, 1) = .40298345582235984, (260, 2) = .6986677894982867, (261, 1) = .4070635407336446, (261, 2) = .7007949257718565, (262, 1) = .411347518, (262, 2) = .7045689463020051, (263, 1) = .4168000919566763, (263, 2) = .7072292415477635, (264, 1) = .4195269055680354, (264, 2) = .7099366248127752, (265, 1) = .4267171541994851, (265, 2) = .7135739275398234, (266, 1) = .434042553, (266, 2) = .720146621419057, (267, 1) = .43514659757709373, (267, 2) = .7206572655124095, (268, 1) = .43567484315402083, (268, 2) = .7212054601272637, (269, 1) = .4462907805706877, (269, 2) = .7263926457193876, (270, 1) = .45291837534317614, (270, 2) = .7324742954417522, (271, 1) = .4548191941717477, (271, 2) = .7334268418659017, (272, 1) = .456737589, (272, 2) = .7350427489987656, (273, 1) = .4657454482301041, (273, 2) = .7392704307934455, (274, 1) = .4704855919998322, (274, 2) = .7437431307562408, (275, 1) = .47500097975326555, (275, 2) = .7459435886620713, (276, 1) = .479432624, (276, 2) = .7497296020037805, (277, 1) = .48502740953821216, (277, 2) = .7522339701755038, (278, 1) = .4878698906252109, (278, 2) = .7550119660707292, (279, 1) = .49517658026858413, (279, 2) = .7584634068506074, (280, 1) = .50212766, (280, 2) = .7645032029789738, (281, 1) = .5040607937056584, (281, 2) = .7653209365791069, (282, 1) = .5049997443662744, (282, 2) = .7662808013852177, (283, 1) = .5153315255414652, (283, 2) = .770993480857628, (284, 1) = .5227245793683305, (284, 2) = .7775496366997062, (285, 1) = .5237997600680374, (285, 2) = .7780575577179255, (286, 1) = .524822695, (286, 2) = .7788841000898876, (287, 1) = .5354475382749663, (287, 2) = .7835428860057199, (288, 1) = .5412514509644586, (288, 2) = .7888184720141946, (289, 1) = .5445046574686911, (289, 2) = .790314562156639, (290, 1) = .54751773, (290, 2) = .7927761880543321, (291, 1) = .55550136781708, (291, 2) = .7961231673391631, (292, 1) = .5597332323632616, (292, 2) = .8000873073286832, (293, 1) = .5652499252683637, (293, 2) = .8025515217453003, (294, 1) = .570212766, (294, 2) = .8066586160492114, (295, 1) = .5754631438836486, (295, 2) = .8087491564142599, (296, 1) = .5781453048989444, (296, 2) = .8113561426431717, (297, 1) = .5860328365683942, (297, 2) = .8147697898119349, (298, 1) = .592907801, (298, 2) = .8205452188994823, (299, 1) = .595294009427073, (299, 2) = .8214401466231459, (300, 1) = .5964585313092597, (300, 2) = .8226249779576602, (301, 1) = .6068505720798303, (301, 2) = .826970766702572, (302, 1) = .6149493967262228, (302, 2) = .8338938132721487, (303, 1) = .6152960882547098, (303, 2) = .8340461241604681, (304, 1) = .615602837, (304, 2) = .8342823494384282, (305, 1) = .6277003471280935, (305, 2) = .8391558347901904, (306, 1) = .634586980263822, (306, 2) = .8451626485866371, (307, 1) = .6365788163140643, (307, 2) = .8460162165772238, (308, 1) = .638297872, (308, 2) = .8473495095131948, (309, 1) = .6485796006637554, (309, 2) = .8513262658675382, (310, 1) = .6542976984806798, (310, 2) = .8564314839011257, (311, 1) = .6579346440462116, (311, 2) = .8579500130122263, (312, 1) = .660992908, (312, 2) = .8603408007729323, (313, 1) = .6694862555608323, (313, 2) = .8634830913095224, (314, 1) = .6740845680154212, (314, 2) = .8677003192156142, (315, 1) = .6793658353812425, (315, 2) = .8698463885637018, (316, 1) = .683687943, (316, 2) = .8732545977341006, (317, 1) = .6904190825708448, (317, 2) = .875626921307706, (318, 1) = .693952648692807, (318, 2) = .8789691545301026, (319, 1) = .7008751518850601, (319, 2) = .8817039726946972, (320, 1) = .706382979, (320, 2) = .8860882007726247, (321, 1) = .7113781885483458, (321, 2) = .8877577031315868, (322, 1) = .713909575205173, (322, 2) = .8902379898445911, (323, 1) = .7224658969751668, (323, 2) = .8935211245845451, (324, 1) = .729078014, (324, 2) = .8988375674599276, (325, 1) = .7323656611545182, (325, 2) = .8998743997090204, (326, 1) = .7339661408374847, (326, 2) = .9015068251590796, (327, 1) = .7441419439283317, (327, 2) = .9052959214878551, (328, 1) = .75177305, (328, 2) = .9114970574022645, (329, 1) = .753386388023518, (329, 2) = .9119745847980459, (330, 1) = .7541368874572347, (330, 2) = .9127756604735682, (331, 1) = .7659077216566863, (331, 2) = .9170261639316147, (332, 1) = .7744501856484342, (332, 2) = .9240444957880567, (333, 1) = .7744601960750015, (333, 2) = .9240484129001746, (334, 1) = .774468085, (334, 2) = .9240541013714942, (335, 1) = .7877681575335678, (335, 2) = .9287094053076951, (336, 1) = .7957172182599538, (336, 2) = .9353133311025451, (337, 1) = .7965330650864829, (337, 2) = .9356261742005842, (338, 1) = .79716312, (338, 2) = .936080699484523, (339, 1) = .8097285548305844, (339, 2) = .9403430128082535, (340, 1) = .8171562753475038, (340, 2) = .9465821664170336, (341, 1) = .8186940604962507, (341, 2) = .9471601783013103, (342, 1) = .819858156, (342, 2) = .9479999321997671, (343, 1) = .8317943967794406, (343, 2) = .951924263499235, (344, 1) = .8387760734722867, (344, 2) = .9578510017315222, (345, 1) = .8409439174159301, (345, 2) = .9586500592784633, (346, 1) = .842553191, (346, 2) = .959810168927121, (347, 1) = .8539710766679941, (347, 2) = .9634504795163603, (348, 1) = .8605850020698751, (348, 2) = .9691198370460106, (349, 1) = .8632830132204153, (349, 2) = .9700956306265937, (350, 1) = .865248227, (350, 2) = .971510267474046, (351, 1) = .8762635502921021, (351, 2) = .9749192001118532, (352, 1) = .8825907012207321, (352, 2) = .9803886723604991, (353, 1) = .8857112811423421, (353, 2) = .9814969246592965, (354, 1) = .887943262, (354, 2) = .9830997664847827, (355, 1) = .8986759377168452, (355, 2) = .9863283795283331, (356, 1) = .9047996119484298, (356, 2) = .9916575076749876, (357, 1) = .9082281437304152, (357, 2) = .9928542289115815, (358, 1) = .910638298, (358, 2) = .9945790775346728, (359, 1) = .9212110989477038, (359, 2) = .9976765977173254, (360, 1) = .9272165297213989, (360, 2) = 1.0029263429894761, (361, 1) = .9308324551784213, (361, 2) = 1.0041681115222423, (362, 1) = .933333333, (362, 2) = 1.0059496416213003, (363, 1) = .9438702380442304, (363, 2) = 1.0089632567653588, (364, 1) = .949844212001387, (364, 2) = 1.0141951783039647, (365, 1) = .953522478003855, (365, 2) = 1.0154394359888441, (366, 1) = .956028369, (366, 2) = 1.0172140432960195, (367, 1) = .9666525829003361, (367, 2) = 1.0201887401152931, (368, 1) = .9726830795635464, (368, 2) = 1.0254640136184532, (369, 1) = .9762958811079261, (369, 2) = 1.0266693590031566, (370, 1) = .978723404, (370, 2) = 1.0283760496847765, (371, 1) = .9895552018914029, (371, 2) = 1.031354503351201, (372, 1) = .9957310589233355, (372, 2) = 1.0367328489329415, (373, 1) = .999149780031767, (373, 2) = 1.0378593135733407, (374, 1) = 1.00141844, (374, 2) = 1.0394405769870803, (375, 1) = 1.0125729904835612, (375, 2) = 1.0424630810945201, (376, 1) = 1.0189835864889594, (376, 2) = 1.04800168424743, (377, 1) = 1.0220808003670416, (377, 2) = 1.0490109744153784, (378, 1) = 1.024113475, (378, 2) = 1.0504135678147535, (379, 1) = 1.0356988524633386, (379, 2) = 1.0535179968212385, (380, 1) = 1.0424337893357438, (380, 2) = 1.0592705195619185, (381, 1) = 1.0450851784713082, (381, 2) = 1.0601262111086482, (382, 1) = 1.046808511, (382, 2) = 1.0613018014790114, (383, 1) = 1.0589240547414969, (383, 2) = 1.0645235867946037, (384, 1) = 1.066072821889716, (384, 2) = 1.070539354876407, (385, 1) = 1.0681588735095535, (385, 2) = 1.0712070292310296, (386, 1) = 1.069503546, (386, 2) = 1.0721126412766457, (387, 1) = 1.0822387217064668, (387, 2) = 1.075484754349653, (388, 1) = 1.089890331132023, (388, 2) = 1.0818081901908956, (389, 1) = 1.0912976997549417, (389, 2) = 1.0822555075177238, (390, 1) = 1.092198581, (390, 2) = 1.0828537564788456, (391, 1) = 1.1056324005262812, (391, 2) = 1.0864066902000677, (392, 1) = 1.1138749962769963, (392, 2) = 1.093077025505384, (393, 1) = 1.1144974541713701, (393, 2) = 1.0932737334407032, (394, 1) = 1.114893617, (394, 2) = 1.0935328359522722, (395, 1) = 1.1290946279490863, (395, 2) = 1.0972945893111703, (396, 1) = 1.137588652, (396, 2) = 1.1040087778450944, (397, 1) = 1.1381189448722804, (397, 2) = 1.1040825528856542, (398, 1) = 1.1382976252316022, (398, 2) = 1.1043458608198726, (399, 1) = 1.1526154413745195, (399, 2) = 1.1081533986608973, (400, 1) = 1.160283688, (400, 2) = 1.114061863976062, (401, 1) = 1.1626887166406676, (401, 2) = 1.1144205198892787, (402, 1) = 1.1635755682837294, (402, 2) = 1.1156146961343612, (403, 1) = 1.1761857775141515, (403, 2) = 1.1189876181845066, (404, 1) = 1.182978723, (404, 2) = 1.1240813104807699, (405, 1) = 1.1872472084382308, (405, 2) = 1.1247640873798597, (406, 1) = 1.1889683767544652, (406, 2) = 1.1268835314488497, (407, 1) = 1.1997977474791757, (407, 2) = 1.1298011653373443, (408, 1) = 1.205673759, (408, 2) = 1.1340840937864276, (409, 1) = 1.2117662883460014, (409, 2) = 1.135127224486678, (410, 1) = 1.2144445468439158, (410, 2) = 1.138152366763338, (411, 1) = 1.2234447737614151, (411, 2) = 1.140597305630091, (412, 1) = 1.228368794, (412, 2) = 1.144083294651399, (413, 1) = 1.2362291531660143, (413, 2) = 1.1455182740122114, (414, 1) = 1.2399797785422537, (414, 2) = 1.1494212020778265, (415, 1) = 1.2471216182823794, (415, 2) = 1.1513786404630624, (416, 1) = 1.25106383, (416, 2) = 1.1540883094611614, (417, 1) = 1.2606281183030106, (417, 2) = 1.1559410519958653, (418, 1) = 1.2655566476735318, (418, 2) = 1.160690037392315, (419, 1) = 1.2708243119629206, (419, 2) = 1.1621471400095387, (420, 1) = 1.273758865, (420, 2) = 1.1641052903046392, (421, 1) = 1.2849622300061962, (421, 2) = 1.1663960317744106, (422, 1) = 1.2911638364917823, (422, 2) = 1.1719588727068035, (423, 1) = 1.2945500306394797, (423, 2) = 1.172904207252774, (424, 1) = 1.296453901, (424, 2) = 1.1741377080665396, (425, 1) = 1.3092350950435536, (425, 2) = 1.1768814225540378, (426, 1) = 1.3167951362796533, (426, 2) = 1.183227708021292, (427, 1) = 1.3182969272214577, (427, 2) = 1.1836507585524716, (428, 1) = 1.319148936, (428, 2) = 1.1841869312590947, (429, 1) = 1.333453118078561, (429, 2) = 1.187394044262778, (430, 1) = 1.341843972, (430, 2) = 1.194019298232287, (431, 1) = 1.3426819684234765, (431, 2) = 1.1940804504022253, (432, 1) = 1.3428900796612153, (432, 2) = 1.1944965433357806, (433, 1) = 1.3576241724453957, (433, 2) = 1.1979299873389633, (434, 1) = 1.364539007, (434, 2) = 1.2030898406011152, (435, 1) = 1.3689730100174544, (435, 2) = 1.2035637495367806, (436, 1) = 1.3704761526800113, (436, 2) = 1.2057653786502691, (437, 1) = 1.381756670449592, (437, 2) = 1.208485074740529, (438, 1) = 1.387234042, (438, 2) = 1.2123646582358045, (439, 1) = 1.3946219007750242, (439, 2) = 1.2133658979566908, (440, 1) = 1.3977235026021453, (440, 2) = 1.2170342139647574, (441, 1) = 1.4058589487232358, (441, 2) = 1.2190551676450483, (442, 1) = 1.409929078, (442, 2) = 1.2218024974264723, (443, 1) = 1.4198341416851132, (443, 2) = 1.223384857637459, (444, 1) = 1.424710097163719, (444, 2) = 1.228303049279246, (445, 1) = 1.4299388908262032, (445, 2) = 1.2296363508784427, (446, 1) = 1.432624113, (446, 2) = 1.2313699249485637, (447, 1) = 1.444742799426594, (447, 2) = 1.2335545563300023, (448, 1) = 1.4514999002120572, (448, 2) = 1.2395718845937345, (449, 1) = 1.4540037259972756, (449, 2) = 1.2402250355817566, (450, 1) = 1.455319149, (450, 2) = 1.241039933707554, (451, 1) = 1.469437327616466, (451, 2) = 1.2438305773916114, (452, 1) = 1.478014184, (452, 2) = 1.2507351573135137, (453, 1) = 1.4782183459056166, (453, 2) = 1.2507393467757069, (454, 1) = 1.4782495260993627, (454, 2) = 1.250840719908223, (455, 1) = 1.4939797273266915, (455, 2) = 1.2541821353915725, (456, 1) = 1.50070922, (456, 2) = 1.2591634293759488, (457, 1) = 1.505854401668368, (457, 2) = 1.2595548023931185, (458, 1) = 1.5073989986545766, (458, 2) = 1.2621095552227115, (459, 1) = 1.5184140673336533, (459, 2) = 1.2645873484052492, (460, 1) = 1.523404255, (460, 2) = 1.2680272225372362, (461, 1) = 1.5321117743460344, (461, 2) = 1.2690548194484306, (462, 1) = 1.5357599743722785, (462, 2) = 1.2733783905372, (463, 1) = 1.5427723399764979, (463, 2) = 1.2750303316569769, (464, 1) = 1.546099291, (464, 2) = 1.2771869700824743, (465, 1) = 1.5576306142422092, (465, 2) = 1.2789215425656928, (466, 1) = 1.5635942937038148, (466, 2) = 1.2846472258516886, (467, 1) = 1.5670781819213742, (467, 2) = 1.2854993481329704, (468, 1) = 1.568794326, (468, 2) = 1.2865535515161495, (469, 1) = 1.582717529208757, (469, 2) = 1.2890027306911938, (470, 1) = 1.5910736351356305, (470, 2) = 1.295916061166177, (471, 1) = 1.5913493223373487, (471, 2) = 1.2959855954861892, (472, 1) = 1.591489362, (472, 2) = 1.2960676181511386, (473, 1) = 1.6075374375301157, (473, 2) = 1.299216496332204, (474, 1) = 1.614184397, (474, 2) = 1.30413089367417, (475, 1) = 1.619775181255238, (475, 2) = 1.3044088872323383, (476, 1) = 1.6212249932841432, (476, 2) = 1.3071848964806656, (477, 1) = 1.6321866840782542, (477, 2) = 1.3095150009948273, (478, 1) = 1.636879432, (478, 2) = 1.3126893495058787, (479, 1) = 1.6464795204325755, (479, 2) = 1.313686970660639, (480, 1) = 1.650460475112204, (480, 2) = 1.318453731795154, (481, 1) = 1.6567251307455784, (481, 2) = 1.3198685218961923, (482, 1) = 1.659574468, (482, 2) = 1.32166074537656, (483, 1) = 1.6721809211460665, (483, 2) = 1.3234630462759958, (484, 1) = 1.6789306407562474, (484, 2) = 1.3297225671096424, (485, 1) = 1.6811917774360323, (485, 2) = 1.3302576934883668, (486, 1) = 1.682269503, (486, 2) = 1.3308954548933172, (487, 1) = 1.6973698232778063, (487, 2) = 1.3334935944274116, (488, 1) = 1.704964539, (488, 2) = 1.3394534244250287, (489, 1) = 1.7081500816800899, (489, 2) = 1.3394096751498963, (490, 1) = 1.708496655893026, (490, 2) = 1.340991402424131, (491, 1) = 1.7222705339674442, (491, 2) = 1.3436672389949957, (492, 1) = 1.727659574, (492, 2) = 1.3474175387258738, (493, 1) = 1.7362633447311187, (493, 2) = 1.347988181265451, (494, 1) = 1.7391255312858365, (494, 2) = 1.3522602377386195, (495, 1) = 1.746999930576139, (495, 2) = 1.3539259469254386, (496, 1) = 1.75035461, (496, 2) = 1.3560556866576374, (497, 1) = 1.7624943764568155, (497, 2) = 1.3575012775921975, (498, 1) = 1.7684820328348467, (498, 2) = 1.363529073053108, (499, 1) = 1.771624703972516, (499, 2) = 1.3642366033905395, (500, 1) = 1.773049645, (500, 2) = 1.3650773164483616, (501, 1) = 1.787947397080901, (501, 2) = 1.3674006821743552, (502, 1) = 1.795744681, (502, 2) = 1.3736934108737564, (503, 1) = 1.7982408043979758, (503, 2) = 1.3735585005633595, (504, 1) = 1.7982817067824142, (504, 2) = 1.3747979083675965, (505, 1) = 1.813015524786313, (505, 2) = 1.3774911986622067, (506, 1) = 1.818439716, (506, 2) = 1.3812734215805165, (507, 1) = 1.8272589509789168, (507, 2) = 1.38168770209003, (508, 1) = 1.8298930119727332, (508, 2) = 1.386066743682085, (509, 1) = 1.8378735238228332, (509, 2) = 1.3876860512368943, (510, 1) = 1.841134752, (510, 2) = 1.3897317178670505, (511, 1) = 1.853695160847097, (511, 2) = 1.391098920679872, (512, 1) = 1.8598377398631647, (512, 2) = 1.3973355789965733, (513, 1) = 1.8626106992395048, (513, 2) = 1.397940896380174, (514, 1) = 1.863829787, (514, 2) = 1.398645893407542, (515, 1) = 1.8792317204698494, (515, 2) = 1.4009568453979109, (516, 1) = 1.886524823, (516, 2) = 1.4067256516680482, (517, 1) = 1.8907900133376323, (517, 2) = 1.4064866062750874, (518, 1) = 1.8908897521944803, (518, 2) = 1.4086044143110619, (519, 1) = 1.9043628317265646, (519, 2) = 1.411016088458887, (520, 1) = 1.909219858, (520, 2) = 1.4142995395813438, (521, 1) = 1.9194103188649203, (521, 2) = 1.4148133488470087, (522, 1) = 1.9227626617096658, (522, 2) = 1.4198732496255504, (523, 1) = 1.9292857347586272, (523, 2) = 1.4211787136284815, (524, 1) = 1.931914893, (524, 2) = 1.4227704338717295, (525, 1) = 1.945646142157817, (525, 2) = 1.4243240659943255, (526, 1) = 1.9529091122156412, (526, 2) = 1.431142084940039, (527, 1) = 1.9540943988482649, (527, 2) = 1.4313980626956835, (528, 1) = 1.954609929, (528, 2) = 1.4316853020793843, (529, 1) = 1.9711006684096328, (529, 2) = 1.4342227228527038, (530, 1) = 1.977304964, (530, 2) = 1.438808256867013, (531, 1) = 1.9848990157466457, (531, 2) = 1.4386402226225583, (532, 1) = 1.9858894123366866, (532, 2) = 1.4424109202545274, (533, 1) = 1.9962153472752922, (533, 2) = 1.444290125393363, (534, 1) = 2.0, (534, 2) = 1.4466982421140733, (535, 1) = 526.0, (535, 2) = .0, (536, 1) = 2.0, (536, 2) = 1.4244739827156567, (537, 1) = 1.9911033075589653, (537, 2) = 1.4242907514070708, (538, 1) = 1.988938650705044, (538, 2) = 1.4198732496255504, (539, 1) = 1.9807093349143547, (539, 2) = 1.4181828669716827, (540, 1) = 1.977304964, (540, 2) = 1.4160331741812382, (541, 1) = 1.9648820287133912, (541, 2) = 1.4147728124592622, (542, 1) = 1.959027218781368, (542, 2) = 1.4086044143110619, (543, 1) = 1.9560023497854198, (543, 2) = 1.4079130313491337, (544, 1) = 1.954609929, (544, 2) = 1.407093778608152, (545, 1) = 1.9395784885973428, (545, 2) = 1.404799185859197, (546, 1) = 1.931914893, (546, 2) = 1.3986085622329218, (547, 1) = 1.928904359550343, (547, 2) = 1.39883040840102, (548, 1) = 1.9289781087749505, (548, 2) = 1.3973355789965733, (549, 1) = 1.9146577797750053, (549, 2) = 1.3946354710242526, (550, 1) = 1.909219858, (550, 2) = 1.3908391897463857, (551, 1) = 1.9004045668329654, (551, 2) = 1.3904438272340855, (552, 1) = 1.8978224188044934, (552, 2) = 1.386066743682085, (553, 1) = 1.8899445415618423, (553, 2) = 1.3843687403392702, (554, 1) = 1.886524823, (554, 2) = 1.3821896337700932, (555, 1) = 1.8744218854832915, (555, 2) = 1.3808074167771593, (556, 1) = 1.8685816137392477, (556, 2) = 1.3747979083675965, (557, 1) = 1.8653646403537838, (557, 2) = 1.3740358029593618, (558, 1) = 1.863829787, (558, 2) = 1.3731158725532704, (559, 1) = 1.8492367832493735, (559, 2) = 1.3707749819494601, (560, 1) = 1.841134752, (560, 2) = 1.3641408226333422, (561, 1) = 1.8397125842073203, (561, 2) = 1.3642352263566444, (562, 1) = 1.8397367591753435, (562, 2) = 1.363529073053108, (563, 1) = 1.8244207805791843, (563, 2) = 1.360559276849738, (564, 1) = 1.818439716, (564, 2) = 1.3562672724894527, (565, 1) = 1.8110254109152697, (565, 2) = 1.3559416853755675, (566, 1) = 1.809020818176691, (566, 2) = 1.3522602377386195, (567, 1) = 1.7998166659481318, (567, 2) = 1.3502383625670864, (568, 1) = 1.795744681, (568, 2) = 1.3475540749180612, (569, 1) = 1.7849430638946275, (569, 2) = 1.3463547622483059, (570, 1) = 1.7801117243483229, (570, 2) = 1.340991402424131, (571, 1) = 1.775353465703897, (571, 2) = 1.3398474793166142, (572, 1) = 1.773049645, (572, 2) = 1.338414343894464, (573, 1) = 1.7597459628648964, (573, 2) = 1.3363282851910108, (574, 1) = 1.7522280308192448, (574, 2) = 1.3297225671096424, (575, 1) = 1.7509946966427923, (575, 2) = 1.3294047429263074, (576, 1) = 1.75035461, (576, 2) = 1.329022589019138, (577, 1) = 1.7349708310891567, (577, 2) = 1.3260922863698545, (578, 1) = 1.727659574, (578, 2) = 1.3204868328937538, (579, 1) = 1.7236730957967594, (579, 2) = 1.3204331500404713, (580, 1) = 1.7229922124727142, (580, 2) = 1.318453731795154, (581, 1) = 1.7104410065094402, (581, 2) = 1.3157344845911276, (582, 1) = 1.704964539, (582, 2) = 1.3118905530917053, (583, 1) = 1.6969052583294504, (583, 2) = 1.3111865956464948, (584, 1) = 1.694018500301522, (584, 2) = 1.3071848964806656, (585, 1) = 1.6860748102363234, (585, 2) = 1.3052954356943, (586, 1) = 1.682269503, (586, 2) = 1.302781757129747, (587, 1) = 1.671443358076547, (587, 2) = 1.3012916000993922, (588, 1) = 1.666210129027341, (588, 2) = 1.295916061166177, (589, 1) = 1.6618295456569196, (589, 2) = 1.2947963405428244, (590, 1) = 1.659574468, (590, 2) = 1.2933697167640108, (591, 1) = 1.6465768639073821, (591, 2) = 1.2911009657797783, (592, 1) = 1.639150180565863, (592, 2) = 1.2846472258516886, (593, 1) = 1.6376809442483673, (593, 2) = 1.2842492485350014, (594, 1) = 1.636879432, (594, 2) = 1.2837578743292788, (595, 1) = 1.6220445987487304, (595, 2) = 1.2807443757769872, (596, 1) = 1.614184397, (596, 2) = 1.2746018452353232, (597, 1) = 1.6118461393229677, (597, 2) = 1.27453941279098, (598, 1) = 1.6114235288020073, (598, 2) = 1.2733783905372, (599, 1) = 1.5977283947731353, (599, 2) = 1.2702805044646666, (600, 1) = 1.591489362, (600, 2) = 1.2657446870400284, (601, 1) = 1.5852977512180046, (601, 2) = 1.2651838945731189, (602, 1) = 1.5832236711199368, (602, 2) = 1.2621095552227115, (603, 1) = 1.5735673110698538, (603, 2) = 1.2597396104158076, (604, 1) = 1.568794326, (604, 2) = 1.2564429792756067, (605, 1) = 1.5599407443562279, (605, 2) = 1.2552368159480416, (606, 1) = 1.556026152778899, (606, 2) = 1.250840719908223, (607, 1) = 1.5495269984784494, (607, 2) = 1.2491387498041502, (608, 1) = 1.546099291, (608, 2) = 1.2468578812579338, (609, 1) = 1.535182178145666, (609, 2) = 1.2449925918737392, (610, 1) = 1.5295098125611863, (610, 2) = 1.2395718845937345, (611, 1) = 1.5255868482047577, (611, 2) = 1.2384881549454123, (612, 1) = 1.523404255, (612, 2) = 1.23707511358306, (613, 1) = 1.5107794318207515, (613, 2) = 1.2345716914417935, (614, 1) = 1.5034942567418703, (614, 2) = 1.228303049279246, (615, 1) = 1.501733951827784, (615, 2) = 1.227794236042835, (616, 1) = 1.50070922, (616, 2) = 1.2271440993390583, (617, 1) = 1.4866152102635843, (617, 2) = 1.224032355524897, (618, 1) = 1.478014184, (618, 2) = 1.217149211952106, (619, 1) = 1.4778022124114778, (619, 2) = 1.217139464867539, (620, 1) = 1.4777606373282246, (620, 2) = 1.2170342139647574, (621, 1) = 1.4626262403501513, (621, 2) = 1.2134060014921713, (622, 1) = 1.455319149, (622, 2) = 1.2078547697019821, (623, 1) = 1.4517950744326635, (623, 2) = 1.2075151981233596, (624, 1) = 1.4507046365167238, (624, 2) = 1.2057653786502691, (625, 1) = 1.4387756925124762, (625, 2) = 1.2027109161479812, (626, 1) = 1.432624113, (626, 2) = 1.1982123080436882, (627, 1) = 1.4267364807451404, (627, 2) = 1.1974199474315346, (628, 1) = 1.4244286978595704, (628, 2) = 1.1944965433357806, (629, 1) = 1.4150409545473424, (629, 2) = 1.191958327600048, (630, 1) = 1.409929078, (630, 2) = 1.1883239919873412, (631, 1) = 1.4022227595588657, (631, 2) = 1.1870541497768436, (632, 1) = 1.3987268310082337, (632, 2) = 1.183227708021292, (633, 1) = 1.3914076286686476, (633, 2) = 1.1811553843272589, (634, 1) = 1.387234042, (634, 2) = 1.1782493425217493, (635, 1) = 1.3780632919482505, (635, 2) = 1.1765124533487152, (636, 1) = 1.37347344499594, (636, 2) = 1.1719588727068035, (637, 1) = 1.367866355889432, (637, 2) = 1.170306733960648, (638, 1) = 1.364539007, (638, 2) = 1.1680248932702775, (639, 1) = 1.3541569256979031, (639, 2) = 1.165845084054061, (640, 1) = 1.348587928418191, (640, 2) = 1.160690037392315, (641, 1) = 1.3444110212265261, (641, 2) = 1.15941541256896, (642, 1) = 1.341843972, (642, 2) = 1.157673842442818, (643, 1) = 1.3304455297232454, (643, 2) = 1.1550809053212339, (644, 1) = 1.3240164906756169, (644, 2) = 1.1494212020778265, (645, 1) = 1.321037695711503, (645, 2) = 1.1484833704684132, (646, 1) = 1.319148936, (646, 2) = 1.147211174809095, (647, 1) = 1.3068938187415535, (647, 2) = 1.144237437711463, (648, 1) = 1.2997221959086767, (648, 2) = 1.138152366763338, (649, 1) = 1.2977439875556058, (649, 2) = 1.1375117961303092, (650, 1) = 1.296453901, (650, 2) = 1.1366465459173347, (651, 1) = 1.2834796131313542, (651, 2) = 1.13332569410127, (652, 1) = 1.2756791885562886, (652, 2) = 1.1268835314488497, (653, 1) = 1.2745286258483277, (653, 2) = 1.1265013197514835, (654, 1) = 1.273758865, (654, 2) = 1.1259859803155932, (655, 1) = 1.2601887540221648, (655, 2) = 1.1223527049459165, (656, 1) = 1.2518692036735433, (656, 2) = 1.1156146961343612, (657, 1) = 1.251391200200884, (657, 2) = 1.1154521460047564, (658, 1) = 1.25106383, (658, 2) = 1.1152329140746917, (659, 1) = 1.2370122765636609, (659, 2) = 1.1113229214240876, (660, 1) = 1.228368794, (660, 2) = 1.1044172956184994, (661, 1) = 1.2282561985478748, (661, 2) = 1.104401768184949, (662, 1) = 1.228219400830655, (662, 2) = 1.1043458608198726, (663, 1) = 1.213944773670436, (663, 2) = 1.100239028545551, (664, 1) = 1.205673759, (664, 2) = 1.0936890846262908, (665, 1) = 1.2047351883973787, (665, 2) = 1.093543056823949, (666, 1) = 1.2044019829083108, (666, 2) = 1.093077025505384, (667, 1) = 1.1909834145255507, (667, 2) = 1.0891024316539044, (668, 1) = 1.182978723, (668, 2) = 1.0827939352711333, (669, 1) = 1.1815001685111188, (669, 2) = 1.0825423413847006, (670, 1) = 1.1809446686984058, (670, 2) = 1.0818081901908956, (671, 1) = 1.168127360002674, (671, 2) = 1.0779135476816861, (672, 1) = 1.160283688, (672, 2) = 1.0717405842870162, (673, 1) = 1.1585137054744492, (673, 2) = 1.0714182096880918, (674, 1) = 1.1578230662035527, (674, 2) = 1.070539354876407, (675, 1) = 1.1453774186849566, (675, 2) = 1.066671974843357, (676, 1) = 1.137588652, (676, 2) = 1.0605322401402315, (677, 1) = 1.1357557424430424, (677, 2) = 1.0601806197641745, (678, 1) = 1.1350236496218176, (678, 2) = 1.0592705195619185, (679, 1) = 1.1227358774769616, (679, 2) = 1.0553765779218989, (680, 1) = 1.114893617, (680, 2) = 1.0491676138125858, (681, 1) = 1.1132184727687275, (681, 2) = 1.048833448712145, (682, 1) = 1.1125416881338954, (682, 2) = 1.04800168424743, (683, 1) = 1.100206453470804, (683, 2) = 1.04402551095152, (684, 1) = 1.092198581, (684, 2) = 1.0376413726323037, (685, 1) = 1.0909038821290058, (685, 2) = 1.0373757097330718, (686, 1) = 1.090380265059184, (686, 2) = 1.0367328489329415, (687, 1) = 1.0777943619131976, (687, 2) = 1.0326161846868382, (688, 1) = 1.069503546, (688, 2) = 1.0259441737705484, (689, 1) = 1.0688229794061808, (689, 2) = 1.0258019374359881, (690, 1) = 1.0685501256236416, (690, 2) = 1.0254640136184532, (691, 1) = 1.0555064881281093, (691, 2) = 1.0211451803659002, (692, 1) = 1.0469716898125523, (692, 2) = 1.0141951783039647, (693, 1) = 1.046880667327128, (693, 2) = 1.014159350301615, (694, 1) = 1.046808511, (694, 2) = 1.0141076478985103, (695, 1) = 1.033351687710956, (695, 2) = 1.0096081004231463, (696, 1) = 1.0252628814332816, (696, 2) = 1.0029263429894761, (697, 1) = 1.024624723220208, (697, 2) = 1.002672491354328, (698, 1) = 1.024113475, (698, 2) = 1.0023012116222338, (699, 1) = 1.011341245488748, (699, 2) = .9979993419555317, (700, 1) = 1.003792919952586, (700, 2) = .9916575076749876, (701, 1) = 1.0024800958736884, (701, 2) = .9911303604288496, (702, 1) = 1.00141844, (702, 2) = .990347988391207, (703, 1) = .9894895457449623, (703, 2) = .986311762539513, (704, 1) = .9825779362414616, (704, 2) = .9803886723604991, (705, 1) = .9804545632051322, (705, 2) = .9795290946102899, (706, 1) = .978723404, (706, 2) = .9782328345038035, (707, 1) = .9678150572724834, (707, 2) = .9745361918930388, (708, 1) = .9616387355042636, (708, 2) = .9691198370460106, (709, 1) = .9585575199877632, (709, 2) = .9678640299513497, (710, 1) = .956028369, (710, 2) = .9659370583298562, (711, 1) = .9463417771650928, (711, 2) = .9626607146637352, (712, 1) = .941002224424812, (712, 2) = .9578510017315222, (713, 1) = .9368004428570456, (713, 2) = .9561294671194472, (714, 1) = .933333333, (714, 2) = .9534372650958414, (715, 1) = .9251013980650025, (715, 2) = .9506695943104946, (716, 1) = .9207034744234053, (716, 2) = .9465821664170336, (717, 1) = .9151975492932625, (717, 2) = .9443183473931307, (718, 1) = .910638298, (718, 2) = .9407036914489233, (719, 1) = .9041366284069559, (719, 2) = .9385416248982998, (720, 1) = .9007887465811769, (720, 2) = .9353133311025451, (721, 1) = .8937667213815514, (721, 2) = .9324217910877455, (722, 1) = .887943262, (722, 2) = .9276977273948364, (723, 1) = .8835064475130456, (723, 2) = .9262475208891162, (724, 1) = .8813200377593083, (724, 2) = .9240444957880567, (725, 1) = .872530851370964, (725, 2) = .9204284319796654, (726, 1) = .865248227, (726, 2) = .9143681576975791, (727, 1) = .8632947276134568, (727, 2) = .9137456374709129, (728, 1) = .8623820935872071, (728, 2) = .9127756604735682, (729, 1) = .8515198241829798, (729, 2) = .9083234308025323, (730, 1) = .8435593410143423, (730, 2) = .9015068251590796, (731, 1) = .8430406342641067, (731, 2) = .9012647934712527, (732, 1) = .842553191, (732, 2) = .9008800413174176, (733, 1) = .8307735404071025, (733, 2) = .8960869758714283, (734, 1) = .824161567316569, (734, 2) = .8902379898445911, (735, 1) = .8219446059841776, (735, 2) = .8892019984366195, (736, 1) = .819858156, (736, 2) = .8875166371377279, (737, 1) = .8103466528515819, (737, 2) = .8836919301437991, (738, 1) = .8052044964684764, (738, 2) = .8789691545301026, (739, 1) = .8010605790389254, (739, 2) = .8770339373286575, (740, 1) = .79716312, (740, 2) = .8738049769674676, (741, 1) = .7903162855600842, (741, 2) = .8710999989133532, (742, 1) = .7867747520617678, (742, 2) = .8677003192156142, (743, 1) = .7804227859648487, (743, 2) = .8647436132876478, (744, 1) = .774468085, (744, 2) = .8596696922142488, (745, 1) = .7707951619749766, (745, 2) = .8582552116324018, (746, 1) = .7689940269302069, (746, 2) = .8564314839011257, (747, 1) = .7600774016030144, (747, 2) = .8523080987374554, (748, 1) = .7519527489292017, (748, 2) = .8451626485866371, (749, 1) = .7518646185972762, (749, 2) = .8451171817502704, (750, 1) = .75177305, (750, 2) = .8450411094820066, (751, 1) = .7400884619646595, (751, 2) = .8396955973401667, (752, 1) = .7337266241375471, (752, 2) = .8338938132721487, (753, 1) = .7314452912520957, (753, 2) = .8327183818915772, (754, 1) = .729078014, (754, 2) = .8306998773869667, (755, 1) = .7205476834143061, (755, 2) = .8268605691584815, (756, 1) = .7160965967789579, (756, 2) = .8226249779576602, (757, 1) = .7113196666467616, (757, 2) = .8201737493038852, (758, 1) = .706382979, (758, 2) = .8158408836828417, (759, 1) = .7015915470181767, (759, 2) = .8137352469514327, (760, 1) = .6992163473253025, (760, 2) = .8113561426431717, (761, 1) = .6915501515422662, (761, 2) = .8074522963011362, (762, 1) = .683687943, (762, 2) = .800322300445485, (763, 1) = .6834328093218127, (763, 2) = .8002139896361866, (764, 1) = .6833141825718329, (764, 2) = .8000873073286832, (765, 1) = .6722257026275095, (765, 2) = .7945098533710719, (766, 1) = .666182705462009, (766, 2) = .7888184720141946, (767, 1) = .6637428267323536, (767, 2) = .7874530464344094, (768, 1) = .660992908, (768, 2) = .7849913591902167, (769, 1) = .6534779375152647, (769, 2) = .7812810678719556, (770, 1) = .6496899776995608, (770, 2) = .7775496366997062, (771, 1) = .644316197262157, (771, 2) = .7745613393359887, (772, 1) = .638297872, (772, 2) = .7690036825296057, (773, 1) = .6355105844731543, (773, 2) = .7676647818071096, (774, 1) = .6341811182836439, (774, 2) = .7662808013852177, (775, 1) = .6253678043596442, (775, 2) = .7614321722014694, (776, 1) = .6186597067307184, (776, 2) = .7550119660707292, (777, 1) = .617281122104175, (777, 2) = .7541786420221122, (778, 1) = .615602837, (778, 2) = .7526252261613862, (779, 1) = .6070424655191824, (779, 2) = .7479936380675389, (780, 1) = .6027854174144771, (780, 2) = .7437431307562408, (781, 1) = .5983155896662373, (781, 2) = .7410579849871226, (782, 1) = .592907801, (782, 2) = .735896923526492, (783, 1) = .5895661050331924, (783, 2) = .734133557986227, (784, 1) = .5879883836302603, (784, 2) = .7324742954417522, (785, 1) = .5798972654713295, (785, 2) = .727665621225314, (786, 1) = .5733631050453268, (786, 2) = .7212054601272637, (787, 1) = .5719975592427472, (787, 2) = .7203192512660335, (788, 1) = .570212766, (788, 2) = .7185943042812164, (789, 1) = .5622031022959202, (789, 2) = .7139136875151968, (790, 1) = .5583459588718417, (790, 2) = .7099366248127752, (791, 1) = .5536334231886916, (791, 2) = .706899981056083, (792, 1) = .54751773, (792, 2) = .7008031525536433, (793, 1) = .5455148251633234, (793, 2) = .6996622979780093, (794, 1) = .544599187815543, (794, 2) = .6986677894982867, (795, 1) = .535933525051012, (795, 2) = .6931508949858032, (796, 1) = .5303684517932757, (796, 2) = .6873989541837983, (797, 1) = .52805483028933, (797, 2) = .6857940921384387, (798, 1) = .524822695, (798, 2) = .6825065836185034, (799, 1) = .5191355881287295, (799, 2) = .6789539554815134, (800, 1) = .5165200495468957, (800, 2) = .6761301188693097, (801, 1) = .5104838489595868, (801, 2) = .6719809947440405, (802, 1) = .5037065227716431, (802, 2) = .6648612835548212, (803, 1) = .5030744531999831, (803, 2) = .6643911694242421, (804, 1) = .50212766, (804, 2) = .6634002967289644, (805, 1) = .4937713816599637, (805, 2) = .6577416165631279, (806, 1) = .489970177749674, (806, 2) = .6535924482403328, (807, 1) = .4857333287063996, (807, 2) = .6504639401515313, (808, 1) = .479432624, (808, 2) = .6436714424848429, (809, 1) = .47826883617953786, (809, 2) = .6429014720606636, (810, 1) = .4777639778703708, (810, 2) = .6423236129258443, (811, 1) = .4692466374415245, (811, 2) = .6361124567487995, (812, 1) = .464715306341125, (812, 2) = .6310547776113558, (813, 1) = .46163883876106837, (813, 2) = .6286211450396212, (814, 1) = .456737589, (814, 2) = .6231592809571775, (815, 1) = .4539529959553716, (815, 2) = .6211685847583196, (816, 1) = .4527657375910921, (816, 2) = .6197859422968672, (817, 1) = .4454962033438965, (817, 2) = .6140988264238145, (818, 1) = .4406460830564382, (818, 2) = .6085171069823787, (819, 1) = .4382044492892413, (819, 2) = .6064505879480206, (820, 1) = .434042553, (820, 2) = .6016280155205744, (821, 1) = .43058012587184086, (821, 2) = .5989674812260884, (822, 1) = .4291434387800115, (822, 2) = .5972482716678903, (823, 1) = .42251993124854825, (823, 2) = .5917007990615119, (824, 1) = .417729738557723, (824, 2) = .5859794363534018, (825, 1) = .4154691584594022, (825, 2) = .5839329055786073, (826, 1) = .411347518, (826, 2) = .5789416642431693, (827, 1) = .4081417790662047, (827, 2) = .5763023563507877, (828, 1) = .40685698843391654, (828, 2) = .5747106010389132, (829, 1) = .40036501676645064, (829, 2) = .5688949404954204, (830, 1) = .3959898721858044, (830, 2) = .5634417657244248, (831, 1) = .3935035629996389, (831, 2) = .5610330437077612, (832, 1) = .388652482, (832, 2) = .5548656285662611, (833, 1) = .38669706522960096, (833, 2) = .5531438594945055, (834, 1) = .3859447608542921, (834, 2) = .5521729304099363, (835, 1) = .3791216358385784, (835, 2) = .5456364753627964, (836, 1) = .3755007197217316, (836, 2) = .5409040950954478, (837, 1) = .3724122424075985, (837, 2) = .5376990757404679, (838, 1) = .3663962141704621, (838, 2) = .5296352597809593, (839, 1) = .36626167748141636, (839, 2) = .5294841992872112, (840, 1) = .365957447, (840, 2) = .5290618718536209, (841, 1) = .3589270866689951, (841, 2) = .5218572306838131, (842, 1) = .3563911119386598, (842, 2) = .5183664244664707, (843, 1) = .3523411921307881, (843, 2) = .5138585096335031, (844, 1) = .3475763410686044, (844, 2) = .5070975891519823, (845, 1) = .3463204241960937, (845, 2) = .5055791845503632, (846, 1) = .343262411, (846, 2) = .5010627462948964, (847, 1) = .33997776672414115, (847, 2) = .4974596883309339, (848, 1) = .33885747758585916, (848, 2) = .4958287538374938, (849, 1) = .3334912752620174, (849, 2) = .48941161051056287, (850, 1) = .3302739327739975, (850, 2) = .4845599185230053, (851, 1) = .3275988903688647, (851, 2) = .48106853913389236, (852, 1) = .3226691295610866, (852, 2) = .4732910832085168, (853, 1) = .32212726070647435, (853, 2) = .4725165488724011, (854, 1) = .320567376, (854, 2) = .4699180992686062, (855, 1) = .31614031244913365, (855, 2) = .46422043123603707, (856, 1) = .3147740262555149, (856, 2) = .46202224789402835, (857, 1) = .31037894460051624, (857, 2) = .4558123054384781, (858, 1) = .307389166307087, (858, 2) = .4507534125795398, (859, 1) = .3050899005797395, (859, 2) = .4471696552528086, (860, 1) = .30081425435924125, (860, 2) = .4394845772650513, (861, 1) = .30015877253252304, (861, 2) = .43834928795920086, (862, 1) = .29787234, (862, 2) = .4339385683324954, (863, 1) = .29505396768163317, (863, 2) = .42961515699929875, (864, 1) = .294285937099235, (864, 2) = .42821574195056283, (865, 1) = .289979927222794, (865, 2) = .42086575055150777, (866, 1) = .2879683364055482, (866, 2) = .41694690663607437, (867, 1) = .28533723716042286, (867, 2) = .4119021643687819, (868, 1) = .2823839169547458, (868, 2) = .40567807132158584, (869, 1) = .28104810655639656, (869, 2) = .4027630242241447, (870, 1) = .2774323557066915, (870, 2) = .3944092360070973, (871, 1) = .2770622923605276, (871, 2) = .3934732774533573, (872, 1) = .275177305, (872, 2) = .3886224330081677, (873, 1) = .2730954300675954, (873, 2) = .3841741203905476, (874, 1) = .27264884815752155, (874, 2) = .38314040069260885, (875, 1) = .2692775766418348, (875, 2) = .37480097546005986, (876, 1) = .2681361937041559, (876, 2) = .3718715653781204, (877, 1) = .2658707131845269, (877, 2) = .3652237604293794, (878, 1) = .26427830458809737, (878, 2) = .36060273006363186, (879, 1) = .2628512923995288, (879, 2) = .3554541673091437, (880, 1) = .26103307650502455, (880, 2) = .34933389474914334, (881, 1) = .2602151085591518, (881, 2) = .3454942843821255, (882, 1) = .2583790599040295, (882, 2) = .33806505943465487, (883, 1) = .25797522734388845, (883, 2) = .3353376241062146, (884, 1) = .2563115818027797, (884, 2) = .3267962241201664, (885, 1) = .2561618533134669, (885, 2) = .3249691889194188, (886, 1) = .2548406555023418, (886, 2) = .3155273888056779, (887, 1) = .25482390795524557, (887, 2) = .31436468768669074, (888, 1) = .25399017830173903, (888, 2) = .30425855349118935, (889, 1) = .2540324198560064, (889, 2) = .30348885236760664, (890, 1) = .25379816516955517, (890, 2) = .2929897181767009, (891, 1) = .25388614843317464, (891, 2) = .2922926456479839, (892, 1) = .2543179291865148, (892, 2) = .2817208828622124, (893, 1) = .2545202670965599, (893, 2) = .2807089494631478, (894, 1) = .25562024450908266, (894, 2) = .2704520475477239, (895, 1) = .2561195389902087, (895, 2) = .2686460228067192, (896, 1) = .25779664402511665, (896, 2) = .25918321223323537, (897, 1) = .2589384240841701, (897, 2) = .25597751789512946, (898, 1) = .2609641349060644, (898, 2) = .2479143769187469, (899, 1) = .2633323283168315, (899, 2) = .24252696393584589, (900, 1) = .2652717850399755, (900, 2) = .2366455416042584, (901, 1) = .2698074896127803, (901, 2) = .2280429970710573, (902, 1) = .2709098736536363, (902, 2) = .2253767062897699, (903, 1) = .275177305, (903, 2) = .21849223799674822, (904, 1) = .2778464974250662, (904, 2) = .21410787097528142, (905, 1) = .27969197264738493, (905, 2) = .21186618920576533, (906, 1) = .2861175105459548, (906, 2) = .20283903566079292, (907, 1) = .29557280277763687, (907, 2) = .19271199661400557, (908, 1) = .2965132418244677, (908, 2) = .19157020034630443, (909, 1) = .29787234, (909, 2) = .19027905700641645, (910, 1) = .30858640456460823, (910, 2) = .18030136503181593, (911, 1) = .320567376, (911, 2) = .17111823894060285, (912, 1) = .3233936000500718, (912, 2) = .16903252971732743, (913, 1) = .33380849941301693, (913, 2) = .16245787411005008, (914, 1) = .3409728683902534, (914, 2) = .15776369440283894, (915, 1) = .343262411, (915, 2) = .15646098085156843, (916, 1) = .3619927797719418, (916, 2) = .14649485908835044, (917, 1) = .365957447, (917, 2) = .14460769739479326, (918, 1) = .3874307105314091, (918, 2) = .13522602377386195, (919, 1) = .388652482, (919, 2) = .13473597397431222, (920, 1) = .39226720244125857, (920, 2) = .13343119562904393, (921, 1) = .411347518, (921, 2) = .12624265343184352, (922, 1) = .41811489199958696, (922, 2) = .12395718845937345, (923, 1) = .434042553, (923, 2) = .11885568254370679, (924, 1) = .4559813235346288, (924, 2) = .11268835314488496, (925, 1) = .456737589, (925, 2) = .11248239911879865, (926, 1) = .4575201089288594, (926, 2) = .11229980612530018, (927, 1) = .479432624, (927, 2) = .1066280385612409, (928, 1) = .5014414507040604, (928, 2) = .10176024342110335, (929, 1) = .50212766, (929, 2) = .10159101181183777, (930, 1) = .5029434695501065, (930, 2) = .10141951783039646, (931, 1) = .524822695, (931, 2) = 0.9681559006866516e-1, (932, 1) = .5391167970429902, (932, 2) = 0.9432202351540864e-1, (933, 1) = .54751773, (933, 2) = 0.9262954125105491e-1, (934, 1) = .5623896654389151, (934, 2) = 0.9015068251590796e-1, (935, 1) = .570212766, (935, 2) = 0.8881116477846362e-1, (936, 1) = .5739378011018723, (936, 2) = 0.8830107941533168e-1, (937, 1) = .592907801, (937, 2) = 0.8517908727642112e-1, (938, 1) = .6065234070985486, (938, 2) = 0.8339008417045964e-1, (939, 1) = .615602837, (939, 2) = 0.8195170401453632e-1, (940, 1) = .6377472939243674, (940, 2) = 0.7915522742145756e-1, (941, 1) = .638297872, (941, 2) = 0.7907114751868707e-1, (942, 1) = .6398551881381657, (942, 2) = 0.7888184720141947e-1, (943, 1) = .660992908, (943, 2) = 0.7615081338848337e-1, (944, 1) = .6678543575310062, (944, 2) = 0.7547491062768943e-1, (945, 1) = .683687943, (945, 2) = 0.7349743216996951e-1, (946, 1) = .6971010217171747, (946, 2) = 0.7222181039318912e-1, (947, 1) = .706382979, (947, 2) = 0.7110000069881608e-1, (948, 1) = .7256160612386486, (948, 2) = 0.6933198590632368e-1, (949, 1) = .729078014, (949, 2) = 0.6892666337010679e-1, (950, 1) = .7438457920210871, (950, 2) = 0.6761301188693097e-1, (951, 1) = .75177305, (951, 2) = 0.6683611594160696e-1, (952, 1) = .7535956737769458, (952, 2) = 0.6670801891456182e-1, (953, 1) = .774468085, (953, 2) = 0.6472232728390571e-1, (954, 1) = .7812161402183493, (954, 2) = 0.6426237933894627e-1, (955, 1) = .79716312, (955, 2) = 0.6278840801049185e-1, (956, 1) = .8083734758911341, (956, 2) = 0.6204669974915798e-1, (957, 1) = .819858156, (957, 2) = 0.61014527603463105e-1, (958, 1) = .8351234529856626, (958, 2) = 0.6003328716924762e-1, (959, 1) = .842553191, (959, 2) = 0.5938351448292965e-1, (960, 1) = .8615137136585047, (960, 2) = 0.5819848585069487e-1, (961, 1) = .865248227, (961, 2) = 0.5788043897352475e-1, (962, 1) = .8875851496102942, (962, 2) = 0.56521991215322386e-1, (963, 1) = .887943262, (963, 2) = 0.5649227155600638e-1, (964, 1) = .8904439795715496, (964, 2) = 0.5634417657244248e-1, (965, 1) = .910638298, (965, 2) = 0.54962588520101656e-1, (966, 1) = .9136977197381818, (966, 2) = 0.5482507251619682e-1, (967, 1) = .933333333, (967, 2) = 0.5351421503996071e-1, (968, 1) = .9395846234589216, (968, 2) = 0.5324020429037071e-1, (969, 1) = .956028369, (969, 2) = 0.5216836985843239e-1, (970, 1) = .9652310042470181, (970, 2) = 0.5177476387676015e-1, (971, 1) = .978723404, (971, 2) = 0.5091560288418856e-1, (972, 1) = .9906602774552977, (972, 2) = 0.50417124456832746e-1, (973, 1) = 1.00141844, (973, 2) = 0.4974752787485673e-1, (974, 1) = 1.0158930833000845, (974, 2) = 0.4915703755350652e-1, (975, 1) = 1.024113475, (975, 2) = 0.486566822866521e-1, (976, 1) = 1.0409476715389645, (976, 2) = 0.4798544171741422e-1, (977, 1) = 1.046808511, (977, 2) = 0.4763640747098328e-1, (978, 1) = 1.0658402247947085, (978, 2) = 0.46894301368238155e-1, (979, 1) = 1.069503546, (979, 2) = 0.4668074729649577e-1, (980, 1) = 1.0905851349246953, (980, 2) = 0.45876470584761075e-1, (981, 1) = 1.092198581, (981, 2) = 0.4578436077646242e-1, (982, 1) = 1.1111848351566838, (982, 2) = 0.4507534125795398e-1, (983, 1) = 1.114893617, (983, 2) = 0.44905083699391446e-1, (984, 1) = 1.1152557450908316, (984, 2) = 0.4489553268668139e-1, (985, 1) = 1.137588652, (985, 2) = 0.4389062649757895e-1, (986, 1) = 1.1401056154633649, (986, 2) = 0.43825585727218376e-1, (987, 1) = 1.160283688, (987, 2) = 0.4293528705052992e-1, (988, 1) = 1.1648253542113527, (988, 2) = 0.42820253808689875e-1, (989, 1) = 1.182978723, (989, 2) = 0.4203456036548975e-1, (990, 1) = 1.1894251905376998, (990, 2) = 0.4187445710678828e-1, (991, 1) = 1.205673759, (991, 2) = 0.41184362359967745e-1, (992, 1) = 1.213914371652364, (992, 2) = 0.4098360459088213e-1, (993, 1) = 1.228368794, (993, 2) = 0.4038098382202394e-1, (994, 1) = 1.238301269657351, (994, 2) = 0.4014353888285073e-1, (995, 1) = 1.25106383, (995, 2) = 0.396210495985887e-1, (996, 1) = 1.262593481833544, (996, 2) = 0.3935048788162744e-1, (997, 1) = 1.273758865, (997, 2) = 0.38901483387146205e-1, (998, 1) = 1.2867979134456726, (998, 2) = 0.38601022839075017e-1, (999, 1) = 1.296453901, (999, 2) = 0.3821947629577932e-1, (1000, 1) = 1.3109208525076754, (1000, 2) = 0.3789202146828696e-1, (1001, 1) = 1.319148936, (1001, 2) = 0.3757245965586278e-1, (1002, 1) = 1.3349680353162894, (1002, 2) = 0.3722063571711219e-1, (1003, 1) = 1.341843972, (1003, 2) = 0.3695808056802551e-1, (1004, 1) = 1.3589447019797398, (1004, 2) = 0.3658426336804438e-1, (1005, 1) = 1.364539007, (1005, 2) = 0.36374180719152605e-1, (1006, 1) = 1.3828556486315, (1006, 2) = 0.3598052302745218e-1, (1007, 1) = 1.387234042, (1007, 2) = 0.35818777214814704e-1, (1008, 1) = 1.4067052723260158, (1008, 2) = 0.3540723198884571e-1, (1009, 1) = 1.409929078, (1009, 2) = 0.35290045816892116e-1, (1010, 1) = 1.4304976064159975, (1010, 2) = 0.3486238677776684e-1, (1011, 1) = 1.432624113, (1011, 2) = 0.3478630601600474e-1, (1012, 1) = 1.4542363615894265, (1012, 2) = 0.3434414567271531e-1, (1013, 1) = 1.455319149, (1013, 2) = 0.34306007506436205e-1, (1014, 1) = 1.4779249503290275, (1014, 2) = 0.3385081341171557e-1, (1015, 1) = 1.478014184, (1015, 2) = 0.3384771842762714e-1, (1016, 1) = 1.4800931491524252, (1016, 2) = 0.3380650594346549e-1, (1017, 1) = 1.50070922, (1017, 2) = 0.3325265234339798e-1, (1018, 1) = 1.5018525865546575, (1018, 2) = 0.3323878664237044e-1, (1019, 1) = 1.523404255, (1019, 2) = 0.3266837051208909e-1, (1020, 1) = 1.525752919786807, (1020, 2) = 0.3264031626694473e-1, (1021, 1) = 1.546099291, (1021, 2) = 0.3210965806346259e-1, (1022, 1) = 1.5495996408671964, (1022, 2) = 0.32068466491377026e-1, (1023, 1) = 1.568794326, (1023, 2) = 0.3157504464467998e-1, (1024, 1) = 1.5733958752845758, (1024, 2) = 0.3152168466891944e-1, (1025, 1) = 1.591489362, (1025, 2) = 0.3106316400094851e-1, (1026, 1) = 1.5971445269232973, (1026, 2) = 0.3099852956462712e-1, (1027, 1) = 1.614184397, (1027, 2) = 0.3057274542830451e-1, (1028, 1) = 1.6208482913503865, (1028, 2) = 0.3049766204929845e-1, (1029, 1) = 1.636879432, (1029, 2) = 0.30102605719973394e-1, (1030, 1) = 1.6445096785138358, (1030, 2) = 0.30017836413557424e-1, (1031, 1) = 1.659574468, (1031, 2) = 0.29651642095914425e-1, (1032, 1) = 1.668131024462252, (1032, 2) = 0.2955789272774493e-1, (1033, 1) = 1.682269503, (1033, 2) = 0.2921882578676087e-1, (1034, 1) = 1.6917145059595593, (1034, 2) = 0.29116749870986426e-1, (1035, 1) = 1.704964539, (1035, 2) = 0.28803196024584036e-1, (1036, 1) = 1.7152621549515952, (1036, 2) = 0.2869339912118584e-1, (1037, 1) = 1.727659574, (1037, 2) = 0.28403854860399393e-1, (1038, 1) = 1.7387758682999586, (1038, 2) = 0.28286898493906074e-1, (1039, 1) = 1.75035461, (1039, 2) = 0.28019962163713615e-1, (1040, 1) = 1.7622574194972205, (1040, 2) = 0.27896367448243663e-1, (1041, 1) = 1.773049645, (1041, 2) = 0.27650731342177423e-1, (1042, 1) = 1.7857084676476207, (1042, 2) = 0.2752098219759625e-1, (1043, 1) = 1.795744681, (1043, 2) = 0.2729542517380107e-1, (1044, 1) = 1.8091305661825445, (1044, 2) = 0.2715997133090622e-1, (1045, 1) = 1.818439716, (1045, 2) = 0.26953352255320633e-1, (1046, 1) = 1.8325251713760276, (1046, 2) = 0.26812611905930955e-1, (1047, 1) = 1.841134752, (1047, 2) = 0.2662386351086802e-1, (1048, 1) = 1.85589364849777, (1048, 2) = 0.2647822581272541e-1, (1049, 1) = 1.863829787, (1049, 2) = 0.26306349232121655e-1, (1050, 1) = 1.8792372800794723, (1050, 2) = 0.26156176500423615e-1, (1051, 1) = 1.886524823, (1051, 2) = 0.26000236139530727e-1, (1052, 1) = 1.9025572698611664, (1052, 2) = 0.25845865945916494e-1, (1053, 1) = 1.909219858, (1053, 2) = 0.2570498490549631e-1, (1054, 1) = 1.925854750222718, (1054, 2) = 0.25546731903369348e-1, (1055, 1) = 1.931914893, (1055, 2) = 0.25420087681626943e-1, (1056, 1) = 1.9491307877003698, (1056, 2) = 0.25258245338369206e-1, (1057, 1) = 1.954609929, (1057, 2) = 0.25145065956422477e-1, (1058, 1) = 1.9723863841858487, (1058, 2) = 0.24979908145105163e-1, (1059, 1) = 1.977304964, (1059, 2) = 0.2487946857940225e-1, (1060, 1) = 1.995622486030146, (1060, 2) = 0.24711250966684323e-1, (1061, 1) = 2.0, (1061, 2) = 0.2462286982602636e-1, (1062, 1) = .0, (1062, 2) = .0, (1063, 1) = .0, (1063, 2) = .0, (1064, 1) = .0, (1064, 2) = .0}, datatype = float[8], order = C_order))]), Array(1..526, 1..2, {(1, 1) = 2.0, (1, 2) = 1.4244739827156567, (2, 1) = 1.9911033075589653, (2, 2) = 1.4242907514070708, (3, 1) = 1.988938650705044, (3, 2) = 1.4198732496255504, (4, 1) = 1.9807093349143547, (4, 2) = 1.4181828669716827, (5, 1) = 1.977304964, (5, 2) = 1.4160331741812382, (6, 1) = 1.9648820287133912, (6, 2) = 1.4147728124592622, (7, 1) = 1.959027218781368, (7, 2) = 1.4086044143110619, (8, 1) = 1.9560023497854198, (8, 2) = 1.4079130313491337, (9, 1) = 1.954609929, (9, 2) = 1.407093778608152, (10, 1) = 1.9395784885973428, (10, 2) = 1.404799185859197, (11, 1) = 1.931914893, (11, 2) = 1.3986085622329218, (12, 1) = 1.928904359550343, (12, 2) = 1.39883040840102, (13, 1) = 1.9289781087749505, (13, 2) = 1.3973355789965733, (14, 1) = 1.9146577797750053, (14, 2) = 1.3946354710242526, (15, 1) = 1.909219858, (15, 2) = 1.3908391897463857, (16, 1) = 1.9004045668329654, (16, 2) = 1.3904438272340855, (17, 1) = 1.8978224188044934, (17, 2) = 1.386066743682085, (18, 1) = 1.8899445415618423, (18, 2) = 1.3843687403392702, (19, 1) = 1.886524823, (19, 2) = 1.3821896337700932, (20, 1) = 1.8744218854832915, (20, 2) = 1.3808074167771593, (21, 1) = 1.8685816137392477, (21, 2) = 1.3747979083675965, (22, 1) = 1.8653646403537838, (22, 2) = 1.3740358029593618, (23, 1) = 1.863829787, (23, 2) = 1.3731158725532704, (24, 1) = 1.8492367832493735, (24, 2) = 1.3707749819494601, (25, 1) = 1.841134752, (25, 2) = 1.3641408226333422, (26, 1) = 1.8397125842073203, (26, 2) = 1.3642352263566444, (27, 1) = 1.8397367591753435, (27, 2) = 1.363529073053108, (28, 1) = 1.8244207805791843, (28, 2) = 1.360559276849738, (29, 1) = 1.818439716, (29, 2) = 1.3562672724894527, (30, 1) = 1.8110254109152697, (30, 2) = 1.3559416853755675, (31, 1) = 1.809020818176691, (31, 2) = 1.3522602377386195, (32, 1) = 1.7998166659481318, (32, 2) = 1.3502383625670864, (33, 1) = 1.795744681, (33, 2) = 1.3475540749180612, (34, 1) = 1.7849430638946275, (34, 2) = 1.3463547622483059, (35, 1) = 1.7801117243483229, (35, 2) = 1.340991402424131, (36, 1) = 1.775353465703897, (36, 2) = 1.3398474793166142, (37, 1) = 1.773049645, (37, 2) = 1.338414343894464, (38, 1) = 1.7597459628648964, (38, 2) = 1.3363282851910108, (39, 1) = 1.7522280308192448, (39, 2) = 1.3297225671096424, (40, 1) = 1.7509946966427923, (40, 2) = 1.3294047429263074, (41, 1) = 1.75035461, (41, 2) = 1.329022589019138, (42, 1) = 1.7349708310891567, (42, 2) = 1.3260922863698545, (43, 1) = 1.727659574, (43, 2) = 1.3204868328937538, (44, 1) = 1.7236730957967594, (44, 2) = 1.3204331500404713, (45, 1) = 1.7229922124727142, (45, 2) = 1.318453731795154, (46, 1) = 1.7104410065094402, (46, 2) = 1.3157344845911276, (47, 1) = 1.704964539, (47, 2) = 1.3118905530917053, (48, 1) = 1.6969052583294504, (48, 2) = 1.3111865956464948, (49, 1) = 1.694018500301522, (49, 2) = 1.3071848964806656, (50, 1) = 1.6860748102363234, (50, 2) = 1.3052954356943, (51, 1) = 1.682269503, (51, 2) = 1.302781757129747, (52, 1) = 1.671443358076547, (52, 2) = 1.3012916000993922, (53, 1) = 1.666210129027341, (53, 2) = 1.295916061166177, (54, 1) = 1.6618295456569196, (54, 2) = 1.2947963405428244, (55, 1) = 1.659574468, (55, 2) = 1.2933697167640108, (56, 1) = 1.6465768639073821, (56, 2) = 1.2911009657797783, (57, 1) = 1.639150180565863, (57, 2) = 1.2846472258516886, (58, 1) = 1.6376809442483673, (58, 2) = 1.2842492485350014, (59, 1) = 1.636879432, (59, 2) = 1.2837578743292788, (60, 1) = 1.6220445987487304, (60, 2) = 1.2807443757769872, (61, 1) = 1.614184397, (61, 2) = 1.2746018452353232, (62, 1) = 1.6118461393229677, (62, 2) = 1.27453941279098, (63, 1) = 1.6114235288020073, (63, 2) = 1.2733783905372, (64, 1) = 1.5977283947731353, (64, 2) = 1.2702805044646666, (65, 1) = 1.591489362, (65, 2) = 1.2657446870400284, (66, 1) = 1.5852977512180046, (66, 2) = 1.2651838945731189, (67, 1) = 1.5832236711199368, (67, 2) = 1.2621095552227115, (68, 1) = 1.5735673110698538, (68, 2) = 1.2597396104158076, (69, 1) = 1.568794326, (69, 2) = 1.2564429792756067, (70, 1) = 1.5599407443562279, (70, 2) = 1.2552368159480416, (71, 1) = 1.556026152778899, (71, 2) = 1.250840719908223, (72, 1) = 1.5495269984784494, (72, 2) = 1.2491387498041502, (73, 1) = 1.546099291, (73, 2) = 1.2468578812579338, (74, 1) = 1.535182178145666, (74, 2) = 1.2449925918737392, (75, 1) = 1.5295098125611863, (75, 2) = 1.2395718845937345, (76, 1) = 1.5255868482047577, (76, 2) = 1.2384881549454123, (77, 1) = 1.523404255, (77, 2) = 1.23707511358306, (78, 1) = 1.5107794318207515, (78, 2) = 1.2345716914417935, (79, 1) = 1.5034942567418703, (79, 2) = 1.228303049279246, (80, 1) = 1.501733951827784, (80, 2) = 1.227794236042835, (81, 1) = 1.50070922, (81, 2) = 1.2271440993390583, (82, 1) = 1.4866152102635843, (82, 2) = 1.224032355524897, (83, 1) = 1.478014184, (83, 2) = 1.217149211952106, (84, 1) = 1.4778022124114778, (84, 2) = 1.217139464867539, (85, 1) = 1.4777606373282246, (85, 2) = 1.2170342139647574, (86, 1) = 1.4626262403501513, (86, 2) = 1.2134060014921713, (87, 1) = 1.455319149, (87, 2) = 1.2078547697019821, (88, 1) = 1.4517950744326635, (88, 2) = 1.2075151981233596, (89, 1) = 1.4507046365167238, (89, 2) = 1.2057653786502691, (90, 1) = 1.4387756925124762, (90, 2) = 1.2027109161479812, (91, 1) = 1.432624113, (91, 2) = 1.1982123080436882, (92, 1) = 1.4267364807451404, (92, 2) = 1.1974199474315346, (93, 1) = 1.4244286978595704, (93, 2) = 1.1944965433357806, (94, 1) = 1.4150409545473424, (94, 2) = 1.191958327600048, (95, 1) = 1.409929078, (95, 2) = 1.1883239919873412, (96, 1) = 1.4022227595588657, (96, 2) = 1.1870541497768436, (97, 1) = 1.3987268310082337, (97, 2) = 1.183227708021292, (98, 1) = 1.3914076286686476, (98, 2) = 1.1811553843272589, (99, 1) = 1.387234042, (99, 2) = 1.1782493425217493, (100, 1) = 1.3780632919482505, (100, 2) = 1.1765124533487152, (101, 1) = 1.37347344499594, (101, 2) = 1.1719588727068035, (102, 1) = 1.367866355889432, (102, 2) = 1.170306733960648, (103, 1) = 1.364539007, (103, 2) = 1.1680248932702775, (104, 1) = 1.3541569256979031, (104, 2) = 1.165845084054061, (105, 1) = 1.348587928418191, (105, 2) = 1.160690037392315, (106, 1) = 1.3444110212265261, (106, 2) = 1.15941541256896, (107, 1) = 1.341843972, (107, 2) = 1.157673842442818, (108, 1) = 1.3304455297232454, (108, 2) = 1.1550809053212339, (109, 1) = 1.3240164906756169, (109, 2) = 1.1494212020778265, (110, 1) = 1.321037695711503, (110, 2) = 1.1484833704684132, (111, 1) = 1.319148936, (111, 2) = 1.147211174809095, (112, 1) = 1.3068938187415535, (112, 2) = 1.144237437711463, (113, 1) = 1.2997221959086767, (113, 2) = 1.138152366763338, (114, 1) = 1.2977439875556058, (114, 2) = 1.1375117961303092, (115, 1) = 1.296453901, (115, 2) = 1.1366465459173347, (116, 1) = 1.2834796131313542, (116, 2) = 1.13332569410127, (117, 1) = 1.2756791885562886, (117, 2) = 1.1268835314488497, (118, 1) = 1.2745286258483277, (118, 2) = 1.1265013197514835, (119, 1) = 1.273758865, (119, 2) = 1.1259859803155932, (120, 1) = 1.2601887540221648, (120, 2) = 1.1223527049459165, (121, 1) = 1.2518692036735433, (121, 2) = 1.1156146961343612, (122, 1) = 1.251391200200884, (122, 2) = 1.1154521460047564, (123, 1) = 1.25106383, (123, 2) = 1.1152329140746917, (124, 1) = 1.2370122765636609, (124, 2) = 1.1113229214240876, (125, 1) = 1.228368794, (125, 2) = 1.1044172956184994, (126, 1) = 1.2282561985478748, (126, 2) = 1.104401768184949, (127, 1) = 1.228219400830655, (127, 2) = 1.1043458608198726, (128, 1) = 1.213944773670436, (128, 2) = 1.100239028545551, (129, 1) = 1.205673759, (129, 2) = 1.0936890846262908, (130, 1) = 1.2047351883973787, (130, 2) = 1.093543056823949, (131, 1) = 1.2044019829083108, (131, 2) = 1.093077025505384, (132, 1) = 1.1909834145255507, (132, 2) = 1.0891024316539044, (133, 1) = 1.182978723, (133, 2) = 1.0827939352711333, (134, 1) = 1.1815001685111188, (134, 2) = 1.0825423413847006, (135, 1) = 1.1809446686984058, (135, 2) = 1.0818081901908956, (136, 1) = 1.168127360002674, (136, 2) = 1.0779135476816861, (137, 1) = 1.160283688, (137, 2) = 1.0717405842870162, (138, 1) = 1.1585137054744492, (138, 2) = 1.0714182096880918, (139, 1) = 1.1578230662035527, (139, 2) = 1.070539354876407, (140, 1) = 1.1453774186849566, (140, 2) = 1.066671974843357, (141, 1) = 1.137588652, (141, 2) = 1.0605322401402315, (142, 1) = 1.1357557424430424, (142, 2) = 1.0601806197641745, (143, 1) = 1.1350236496218176, (143, 2) = 1.0592705195619185, (144, 1) = 1.1227358774769616, (144, 2) = 1.0553765779218989, (145, 1) = 1.114893617, (145, 2) = 1.0491676138125858, (146, 1) = 1.1132184727687275, (146, 2) = 1.048833448712145, (147, 1) = 1.1125416881338954, (147, 2) = 1.04800168424743, (148, 1) = 1.100206453470804, (148, 2) = 1.04402551095152, (149, 1) = 1.092198581, (149, 2) = 1.0376413726323037, (150, 1) = 1.0909038821290058, (150, 2) = 1.0373757097330718, (151, 1) = 1.090380265059184, (151, 2) = 1.0367328489329415, (152, 1) = 1.0777943619131976, (152, 2) = 1.0326161846868382, (153, 1) = 1.069503546, (153, 2) = 1.0259441737705484, (154, 1) = 1.0688229794061808, (154, 2) = 1.0258019374359881, (155, 1) = 1.0685501256236416, (155, 2) = 1.0254640136184532, (156, 1) = 1.0555064881281093, (156, 2) = 1.0211451803659002, (157, 1) = 1.0469716898125523, (157, 2) = 1.0141951783039647, (158, 1) = 1.046880667327128, (158, 2) = 1.014159350301615, (159, 1) = 1.046808511, (159, 2) = 1.0141076478985103, (160, 1) = 1.033351687710956, (160, 2) = 1.0096081004231463, (161, 1) = 1.0252628814332816, (161, 2) = 1.0029263429894761, (162, 1) = 1.024624723220208, (162, 2) = 1.002672491354328, (163, 1) = 1.024113475, (163, 2) = 1.0023012116222338, (164, 1) = 1.011341245488748, (164, 2) = .9979993419555317, (165, 1) = 1.003792919952586, (165, 2) = .9916575076749876, (166, 1) = 1.0024800958736884, (166, 2) = .9911303604288496, (167, 1) = 1.00141844, (167, 2) = .990347988391207, (168, 1) = .9894895457449623, (168, 2) = .986311762539513, (169, 1) = .9825779362414616, (169, 2) = .9803886723604991, (170, 1) = .9804545632051322, (170, 2) = .9795290946102899, (171, 1) = .978723404, (171, 2) = .9782328345038035, (172, 1) = .9678150572724834, (172, 2) = .9745361918930388, (173, 1) = .9616387355042636, (173, 2) = .9691198370460106, (174, 1) = .9585575199877632, (174, 2) = .9678640299513497, (175, 1) = .956028369, (175, 2) = .9659370583298562, (176, 1) = .9463417771650928, (176, 2) = .9626607146637352, (177, 1) = .941002224424812, (177, 2) = .9578510017315222, (178, 1) = .9368004428570456, (178, 2) = .9561294671194472, (179, 1) = .933333333, (179, 2) = .9534372650958414, (180, 1) = .9251013980650025, (180, 2) = .9506695943104946, (181, 1) = .9207034744234053, (181, 2) = .9465821664170336, (182, 1) = .9151975492932625, (182, 2) = .9443183473931307, (183, 1) = .910638298, (183, 2) = .9407036914489233, (184, 1) = .9041366284069559, (184, 2) = .9385416248982998, (185, 1) = .9007887465811769, (185, 2) = .9353133311025451, (186, 1) = .8937667213815514, (186, 2) = .9324217910877455, (187, 1) = .887943262, (187, 2) = .9276977273948364, (188, 1) = .8835064475130456, (188, 2) = .9262475208891162, (189, 1) = .8813200377593083, (189, 2) = .9240444957880567, (190, 1) = .872530851370964, (190, 2) = .9204284319796654, (191, 1) = .865248227, (191, 2) = .9143681576975791, (192, 1) = .8632947276134568, (192, 2) = .9137456374709129, (193, 1) = .8623820935872071, (193, 2) = .9127756604735682, (194, 1) = .8515198241829798, (194, 2) = .9083234308025323, (195, 1) = .8435593410143423, (195, 2) = .9015068251590796, (196, 1) = .8430406342641067, (196, 2) = .9012647934712527, (197, 1) = .842553191, (197, 2) = .9008800413174176, (198, 1) = .8307735404071025, (198, 2) = .8960869758714283, (199, 1) = .824161567316569, (199, 2) = .8902379898445911, (200, 1) = .8219446059841776, (200, 2) = .8892019984366195, (201, 1) = .819858156, (201, 2) = .8875166371377279, (202, 1) = .8103466528515819, (202, 2) = .8836919301437991, (203, 1) = .8052044964684764, (203, 2) = .8789691545301026, (204, 1) = .8010605790389254, (204, 2) = .8770339373286575, (205, 1) = .79716312, (205, 2) = .8738049769674676, (206, 1) = .7903162855600842, (206, 2) = .8710999989133532, (207, 1) = .7867747520617678, (207, 2) = .8677003192156142, (208, 1) = .7804227859648487, (208, 2) = .8647436132876478, (209, 1) = .774468085, (209, 2) = .8596696922142488, (210, 1) = .7707951619749766, (210, 2) = .8582552116324018, (211, 1) = .7689940269302069, (211, 2) = .8564314839011257, (212, 1) = .7600774016030144, (212, 2) = .8523080987374554, (213, 1) = .7519527489292017, (213, 2) = .8451626485866371, (214, 1) = .7518646185972762, (214, 2) = .8451171817502704, (215, 1) = .75177305, (215, 2) = .8450411094820066, (216, 1) = .7400884619646595, (216, 2) = .8396955973401667, (217, 1) = .7337266241375471, (217, 2) = .8338938132721487, (218, 1) = .7314452912520957, (218, 2) = .8327183818915772, (219, 1) = .729078014, (219, 2) = .8306998773869667, (220, 1) = .7205476834143061, (220, 2) = .8268605691584815, (221, 1) = .7160965967789579, (221, 2) = .8226249779576602, (222, 1) = .7113196666467616, (222, 2) = .8201737493038852, (223, 1) = .706382979, (223, 2) = .8158408836828417, (224, 1) = .7015915470181767, (224, 2) = .8137352469514327, (225, 1) = .6992163473253025, (225, 2) = .8113561426431717, (226, 1) = .6915501515422662, (226, 2) = .8074522963011362, (227, 1) = .683687943, (227, 2) = .800322300445485, (228, 1) = .6834328093218127, (228, 2) = .8002139896361866, (229, 1) = .6833141825718329, (229, 2) = .8000873073286832, (230, 1) = .6722257026275095, (230, 2) = .7945098533710719, (231, 1) = .666182705462009, (231, 2) = .7888184720141946, (232, 1) = .6637428267323536, (232, 2) = .7874530464344094, (233, 1) = .660992908, (233, 2) = .7849913591902167, (234, 1) = .6534779375152647, (234, 2) = .7812810678719556, (235, 1) = .6496899776995608, (235, 2) = .7775496366997062, (236, 1) = .644316197262157, (236, 2) = .7745613393359887, (237, 1) = .638297872, (237, 2) = .7690036825296057, (238, 1) = .6355105844731543, (238, 2) = .7676647818071096, (239, 1) = .6341811182836439, (239, 2) = .7662808013852177, (240, 1) = .6253678043596442, (240, 2) = .7614321722014694, (241, 1) = .6186597067307184, (241, 2) = .7550119660707292, (242, 1) = .617281122104175, (242, 2) = .7541786420221122, (243, 1) = .615602837, (243, 2) = .7526252261613862, (244, 1) = .6070424655191824, (244, 2) = .7479936380675389, (245, 1) = .6027854174144771, (245, 2) = .7437431307562408, (246, 1) = .5983155896662373, (246, 2) = .7410579849871226, (247, 1) = .592907801, (247, 2) = .735896923526492, (248, 1) = .5895661050331924, (248, 2) = .734133557986227, (249, 1) = .5879883836302603, (249, 2) = .7324742954417522, (250, 1) = .5798972654713295, (250, 2) = .727665621225314, (251, 1) = .5733631050453268, (251, 2) = .7212054601272637, (252, 1) = .5719975592427472, (252, 2) = .7203192512660335, (253, 1) = .570212766, (253, 2) = .7185943042812164, (254, 1) = .5622031022959202, (254, 2) = .7139136875151968, (255, 1) = .5583459588718417, (255, 2) = .7099366248127752, (256, 1) = .5536334231886916, (256, 2) = .706899981056083, (257, 1) = .54751773, (257, 2) = .7008031525536433, (258, 1) = .5455148251633234, (258, 2) = .6996622979780093, (259, 1) = .544599187815543, (259, 2) = .6986677894982867, (260, 1) = .535933525051012, (260, 2) = .6931508949858032, (261, 1) = .5303684517932757, (261, 2) = .6873989541837983, (262, 1) = .52805483028933, (262, 2) = .6857940921384387, (263, 1) = .524822695, (263, 2) = .6825065836185034, (264, 1) = .5191355881287295, (264, 2) = .6789539554815134, (265, 1) = .5165200495468957, (265, 2) = .6761301188693097, (266, 1) = .5104838489595868, (266, 2) = .6719809947440405, (267, 1) = .5037065227716431, (267, 2) = .6648612835548212, (268, 1) = .5030744531999831, (268, 2) = .6643911694242421, (269, 1) = .50212766, (269, 2) = .6634002967289644, (270, 1) = .4937713816599637, (270, 2) = .6577416165631279, (271, 1) = .489970177749674, (271, 2) = .6535924482403328, (272, 1) = .4857333287063996, (272, 2) = .6504639401515313, (273, 1) = .479432624, (273, 2) = .6436714424848429, (274, 1) = .47826883617953786, (274, 2) = .6429014720606636, (275, 1) = .4777639778703708, (275, 2) = .6423236129258443, (276, 1) = .4692466374415245, (276, 2) = .6361124567487995, (277, 1) = .464715306341125, (277, 2) = .6310547776113558, (278, 1) = .46163883876106837, (278, 2) = .6286211450396212, (279, 1) = .456737589, (279, 2) = .6231592809571775, (280, 1) = .4539529959553716, (280, 2) = .6211685847583196, (281, 1) = .4527657375910921, (281, 2) = .6197859422968672, (282, 1) = .4454962033438965, (282, 2) = .6140988264238145, (283, 1) = .4406460830564382, (283, 2) = .6085171069823787, (284, 1) = .4382044492892413, (284, 2) = .6064505879480206, (285, 1) = .434042553, (285, 2) = .6016280155205744, (286, 1) = .43058012587184086, (286, 2) = .5989674812260884, (287, 1) = .4291434387800115, (287, 2) = .5972482716678903, (288, 1) = .42251993124854825, (288, 2) = .5917007990615119, (289, 1) = .417729738557723, (289, 2) = .5859794363534018, (290, 1) = .4154691584594022, (290, 2) = .5839329055786073, (291, 1) = .411347518, (291, 2) = .5789416642431693, (292, 1) = .4081417790662047, (292, 2) = .5763023563507877, (293, 1) = .40685698843391654, (293, 2) = .5747106010389132, (294, 1) = .40036501676645064, (294, 2) = .5688949404954204, (295, 1) = .3959898721858044, (295, 2) = .5634417657244248, (296, 1) = .3935035629996389, (296, 2) = .5610330437077612, (297, 1) = .388652482, (297, 2) = .5548656285662611, (298, 1) = .38669706522960096, (298, 2) = .5531438594945055, (299, 1) = .3859447608542921, (299, 2) = .5521729304099363, (300, 1) = .3791216358385784, (300, 2) = .5456364753627964, (301, 1) = .3755007197217316, (301, 2) = .5409040950954478, (302, 1) = .3724122424075985, (302, 2) = .5376990757404679, (303, 1) = .3663962141704621, (303, 2) = .5296352597809593, (304, 1) = .36626167748141636, (304, 2) = .5294841992872112, (305, 1) = .365957447, (305, 2) = .5290618718536209, (306, 1) = .3589270866689951, (306, 2) = .5218572306838131, (307, 1) = .3563911119386598, (307, 2) = .5183664244664707, (308, 1) = .3523411921307881, (308, 2) = .5138585096335031, (309, 1) = .3475763410686044, (309, 2) = .5070975891519823, (310, 1) = .3463204241960937, (310, 2) = .5055791845503632, (311, 1) = .343262411, (311, 2) = .5010627462948964, (312, 1) = .33997776672414115, (312, 2) = .4974596883309339, (313, 1) = .33885747758585916, (313, 2) = .4958287538374938, (314, 1) = .3334912752620174, (314, 2) = .48941161051056287, (315, 1) = .3302739327739975, (315, 2) = .4845599185230053, (316, 1) = .3275988903688647, (316, 2) = .48106853913389236, (317, 1) = .3226691295610866, (317, 2) = .4732910832085168, (318, 1) = .32212726070647435, (318, 2) = .4725165488724011, (319, 1) = .320567376, (319, 2) = .4699180992686062, (320, 1) = .31614031244913365, (320, 2) = .46422043123603707, (321, 1) = .3147740262555149, (321, 2) = .46202224789402835, (322, 1) = .31037894460051624, (322, 2) = .4558123054384781, (323, 1) = .307389166307087, (323, 2) = .4507534125795398, (324, 1) = .3050899005797395, (324, 2) = .4471696552528086, (325, 1) = .30081425435924125, (325, 2) = .4394845772650513, (326, 1) = .30015877253252304, (326, 2) = .43834928795920086, (327, 1) = .29787234, (327, 2) = .4339385683324954, (328, 1) = .29505396768163317, (328, 2) = .42961515699929875, (329, 1) = .294285937099235, (329, 2) = .42821574195056283, (330, 1) = .289979927222794, (330, 2) = .42086575055150777, (331, 1) = .2879683364055482, (331, 2) = .41694690663607437, (332, 1) = .28533723716042286, (332, 2) = .4119021643687819, (333, 1) = .2823839169547458, (333, 2) = .40567807132158584, (334, 1) = .28104810655639656, (334, 2) = .4027630242241447, (335, 1) = .2774323557066915, (335, 2) = .3944092360070973, (336, 1) = .2770622923605276, (336, 2) = .3934732774533573, (337, 1) = .275177305, (337, 2) = .3886224330081677, (338, 1) = .2730954300675954, (338, 2) = .3841741203905476, (339, 1) = .27264884815752155, (339, 2) = .38314040069260885, (340, 1) = .2692775766418348, (340, 2) = .37480097546005986, (341, 1) = .2681361937041559, (341, 2) = .3718715653781204, (342, 1) = .2658707131845269, (342, 2) = .3652237604293794, (343, 1) = .26427830458809737, (343, 2) = .36060273006363186, (344, 1) = .2628512923995288, (344, 2) = .3554541673091437, (345, 1) = .26103307650502455, (345, 2) = .34933389474914334, (346, 1) = .2602151085591518, (346, 2) = .3454942843821255, (347, 1) = .2583790599040295, (347, 2) = .33806505943465487, (348, 1) = .25797522734388845, (348, 2) = .3353376241062146, (349, 1) = .2563115818027797, (349, 2) = .3267962241201664, (350, 1) = .2561618533134669, (350, 2) = .3249691889194188, (351, 1) = .2548406555023418, (351, 2) = .3155273888056779, (352, 1) = .25482390795524557, (352, 2) = .31436468768669074, (353, 1) = .25399017830173903, (353, 2) = .30425855349118935, (354, 1) = .2540324198560064, (354, 2) = .30348885236760664, (355, 1) = .25379816516955517, (355, 2) = .2929897181767009, (356, 1) = .25388614843317464, (356, 2) = .2922926456479839, (357, 1) = .2543179291865148, (357, 2) = .2817208828622124, (358, 1) = .2545202670965599, (358, 2) = .2807089494631478, (359, 1) = .25562024450908266, (359, 2) = .2704520475477239, (360, 1) = .2561195389902087, (360, 2) = .2686460228067192, (361, 1) = .25779664402511665, (361, 2) = .25918321223323537, (362, 1) = .2589384240841701, (362, 2) = .25597751789512946, (363, 1) = .2609641349060644, (363, 2) = .2479143769187469, (364, 1) = .2633323283168315, (364, 2) = .24252696393584589, (365, 1) = .2652717850399755, (365, 2) = .2366455416042584, (366, 1) = .2698074896127803, (366, 2) = .2280429970710573, (367, 1) = .2709098736536363, (367, 2) = .2253767062897699, (368, 1) = .275177305, (368, 2) = .21849223799674822, (369, 1) = .2778464974250662, (369, 2) = .21410787097528142, (370, 1) = .27969197264738493, (370, 2) = .21186618920576533, (371, 1) = .2861175105459548, (371, 2) = .20283903566079292, (372, 1) = .29557280277763687, (372, 2) = .19271199661400557, (373, 1) = .2965132418244677, (373, 2) = .19157020034630443, (374, 1) = .29787234, (374, 2) = .19027905700641645, (375, 1) = .30858640456460823, (375, 2) = .18030136503181593, (376, 1) = .320567376, (376, 2) = .17111823894060285, (377, 1) = .3233936000500718, (377, 2) = .16903252971732743, (378, 1) = .33380849941301693, (378, 2) = .16245787411005008, (379, 1) = .3409728683902534, (379, 2) = .15776369440283894, (380, 1) = .343262411, (380, 2) = .15646098085156843, (381, 1) = .3619927797719418, (381, 2) = .14649485908835044, (382, 1) = .365957447, (382, 2) = .14460769739479326, (383, 1) = .3874307105314091, (383, 2) = .13522602377386195, (384, 1) = .388652482, (384, 2) = .13473597397431222, (385, 1) = .39226720244125857, (385, 2) = .13343119562904393, (386, 1) = .411347518, (386, 2) = .12624265343184352, (387, 1) = .41811489199958696, (387, 2) = .12395718845937345, (388, 1) = .434042553, (388, 2) = .11885568254370679, (389, 1) = .4559813235346288, (389, 2) = .11268835314488496, (390, 1) = .456737589, (390, 2) = .11248239911879865, (391, 1) = .4575201089288594, (391, 2) = .11229980612530018, (392, 1) = .479432624, (392, 2) = .1066280385612409, (393, 1) = .5014414507040604, (393, 2) = .10176024342110335, (394, 1) = .50212766, (394, 2) = .10159101181183777, (395, 1) = .5029434695501065, (395, 2) = .10141951783039646, (396, 1) = .524822695, (396, 2) = 0.9681559006866516e-1, (397, 1) = .5391167970429902, (397, 2) = 0.9432202351540864e-1, (398, 1) = .54751773, (398, 2) = 0.9262954125105491e-1, (399, 1) = .5623896654389151, (399, 2) = 0.9015068251590796e-1, (400, 1) = .570212766, (400, 2) = 0.8881116477846362e-1, (401, 1) = .5739378011018723, (401, 2) = 0.8830107941533168e-1, (402, 1) = .592907801, (402, 2) = 0.8517908727642112e-1, (403, 1) = .6065234070985486, (403, 2) = 0.8339008417045964e-1, (404, 1) = .615602837, (404, 2) = 0.8195170401453632e-1, (405, 1) = .6377472939243674, (405, 2) = 0.7915522742145756e-1, (406, 1) = .638297872, (406, 2) = 0.7907114751868707e-1, (407, 1) = .6398551881381657, (407, 2) = 0.7888184720141947e-1, (408, 1) = .660992908, (408, 2) = 0.7615081338848337e-1, (409, 1) = .6678543575310062, (409, 2) = 0.7547491062768943e-1, (410, 1) = .683687943, (410, 2) = 0.7349743216996951e-1, (411, 1) = .6971010217171747, (411, 2) = 0.7222181039318912e-1, (412, 1) = .706382979, (412, 2) = 0.7110000069881608e-1, (413, 1) = .7256160612386486, (413, 2) = 0.6933198590632368e-1, (414, 1) = .729078014, (414, 2) = 0.6892666337010679e-1, (415, 1) = .7438457920210871, (415, 2) = 0.6761301188693097e-1, (416, 1) = .75177305, (416, 2) = 0.6683611594160696e-1, (417, 1) = .7535956737769458, (417, 2) = 0.6670801891456182e-1, (418, 1) = .774468085, (418, 2) = 0.6472232728390571e-1, (419, 1) = .7812161402183493, (419, 2) = 0.6426237933894627e-1, (420, 1) = .79716312, (420, 2) = 0.6278840801049185e-1, (421, 1) = .8083734758911341, (421, 2) = 0.6204669974915798e-1, (422, 1) = .819858156, (422, 2) = 0.61014527603463105e-1, (423, 1) = .8351234529856626, (423, 2) = 0.6003328716924762e-1, (424, 1) = .842553191, (424, 2) = 0.5938351448292965e-1, (425, 1) = .8615137136585047, (425, 2) = 0.5819848585069487e-1, (426, 1) = .865248227, (426, 2) = 0.5788043897352475e-1, (427, 1) = .8875851496102942, (427, 2) = 0.56521991215322386e-1, (428, 1) = .887943262, (428, 2) = 0.5649227155600638e-1, (429, 1) = .8904439795715496, (429, 2) = 0.5634417657244248e-1, (430, 1) = .910638298, (430, 2) = 0.54962588520101656e-1, (431, 1) = .9136977197381818, (431, 2) = 0.5482507251619682e-1, (432, 1) = .933333333, (432, 2) = 0.5351421503996071e-1, (433, 1) = .9395846234589216, (433, 2) = 0.5324020429037071e-1, (434, 1) = .956028369, (434, 2) = 0.5216836985843239e-1, (435, 1) = .9652310042470181, (435, 2) = 0.5177476387676015e-1, (436, 1) = .978723404, (436, 2) = 0.5091560288418856e-1, (437, 1) = .9906602774552977, (437, 2) = 0.50417124456832746e-1, (438, 1) = 1.00141844, (438, 2) = 0.4974752787485673e-1, (439, 1) = 1.0158930833000845, (439, 2) = 0.4915703755350652e-1, (440, 1) = 1.024113475, (440, 2) = 0.486566822866521e-1, (441, 1) = 1.0409476715389645, (441, 2) = 0.4798544171741422e-1, (442, 1) = 1.046808511, (442, 2) = 0.4763640747098328e-1, (443, 1) = 1.0658402247947085, (443, 2) = 0.46894301368238155e-1, (444, 1) = 1.069503546, (444, 2) = 0.4668074729649577e-1, (445, 1) = 1.0905851349246953, (445, 2) = 0.45876470584761075e-1, (446, 1) = 1.092198581, (446, 2) = 0.4578436077646242e-1, (447, 1) = 1.1111848351566838, (447, 2) = 0.4507534125795398e-1, (448, 1) = 1.114893617, (448, 2) = 0.44905083699391446e-1, (449, 1) = 1.1152557450908316, (449, 2) = 0.4489553268668139e-1, (450, 1) = 1.137588652, (450, 2) = 0.4389062649757895e-1, (451, 1) = 1.1401056154633649, (451, 2) = 0.43825585727218376e-1, (452, 1) = 1.160283688, (452, 2) = 0.4293528705052992e-1, (453, 1) = 1.1648253542113527, (453, 2) = 0.42820253808689875e-1, (454, 1) = 1.182978723, (454, 2) = 0.4203456036548975e-1, (455, 1) = 1.1894251905376998, (455, 2) = 0.4187445710678828e-1, (456, 1) = 1.205673759, (456, 2) = 0.41184362359967745e-1, (457, 1) = 1.213914371652364, (457, 2) = 0.4098360459088213e-1, (458, 1) = 1.228368794, (458, 2) = 0.4038098382202394e-1, (459, 1) = 1.238301269657351, (459, 2) = 0.4014353888285073e-1, (460, 1) = 1.25106383, (460, 2) = 0.396210495985887e-1, (461, 1) = 1.262593481833544, (461, 2) = 0.3935048788162744e-1, (462, 1) = 1.273758865, (462, 2) = 0.38901483387146205e-1, (463, 1) = 1.2867979134456726, (463, 2) = 0.38601022839075017e-1, (464, 1) = 1.296453901, (464, 2) = 0.3821947629577932e-1, (465, 1) = 1.3109208525076754, (465, 2) = 0.3789202146828696e-1, (466, 1) = 1.319148936, (466, 2) = 0.3757245965586278e-1, (467, 1) = 1.3349680353162894, (467, 2) = 0.3722063571711219e-1, (468, 1) = 1.341843972, (468, 2) = 0.3695808056802551e-1, (469, 1) = 1.3589447019797398, (469, 2) = 0.3658426336804438e-1, (470, 1) = 1.364539007, (470, 2) = 0.36374180719152605e-1, (471, 1) = 1.3828556486315, (471, 2) = 0.3598052302745218e-1, (472, 1) = 1.387234042, (472, 2) = 0.35818777214814704e-1, (473, 1) = 1.4067052723260158, (473, 2) = 0.3540723198884571e-1, (474, 1) = 1.409929078, (474, 2) = 0.35290045816892116e-1, (475, 1) = 1.4304976064159975, (475, 2) = 0.3486238677776684e-1, (476, 1) = 1.432624113, (476, 2) = 0.3478630601600474e-1, (477, 1) = 1.4542363615894265, (477, 2) = 0.3434414567271531e-1, (478, 1) = 1.455319149, (478, 2) = 0.34306007506436205e-1, (479, 1) = 1.4779249503290275, (479, 2) = 0.3385081341171557e-1, (480, 1) = 1.478014184, (480, 2) = 0.3384771842762714e-1, (481, 1) = 1.4800931491524252, (481, 2) = 0.3380650594346549e-1, (482, 1) = 1.50070922, (482, 2) = 0.3325265234339798e-1, (483, 1) = 1.5018525865546575, (483, 2) = 0.3323878664237044e-1, (484, 1) = 1.523404255, (484, 2) = 0.3266837051208909e-1, (485, 1) = 1.525752919786807, (485, 2) = 0.3264031626694473e-1, (486, 1) = 1.546099291, (486, 2) = 0.3210965806346259e-1, (487, 1) = 1.5495996408671964, (487, 2) = 0.32068466491377026e-1, (488, 1) = 1.568794326, (488, 2) = 0.3157504464467998e-1, (489, 1) = 1.5733958752845758, (489, 2) = 0.3152168466891944e-1, (490, 1) = 1.591489362, (490, 2) = 0.3106316400094851e-1, (491, 1) = 1.5971445269232973, (491, 2) = 0.3099852956462712e-1, (492, 1) = 1.614184397, (492, 2) = 0.3057274542830451e-1, (493, 1) = 1.6208482913503865, (493, 2) = 0.3049766204929845e-1, (494, 1) = 1.636879432, (494, 2) = 0.30102605719973394e-1, (495, 1) = 1.6445096785138358, (495, 2) = 0.30017836413557424e-1, (496, 1) = 1.659574468, (496, 2) = 0.29651642095914425e-1, (497, 1) = 1.668131024462252, (497, 2) = 0.2955789272774493e-1, (498, 1) = 1.682269503, (498, 2) = 0.2921882578676087e-1, (499, 1) = 1.6917145059595593, (499, 2) = 0.29116749870986426e-1, (500, 1) = 1.704964539, (500, 2) = 0.28803196024584036e-1, (501, 1) = 1.7152621549515952, (501, 2) = 0.2869339912118584e-1, (502, 1) = 1.727659574, (502, 2) = 0.28403854860399393e-1, (503, 1) = 1.7387758682999586, (503, 2) = 0.28286898493906074e-1, (504, 1) = 1.75035461, (504, 2) = 0.28019962163713615e-1, (505, 1) = 1.7622574194972205, (505, 2) = 0.27896367448243663e-1, (506, 1) = 1.773049645, (506, 2) = 0.27650731342177423e-1, (507, 1) = 1.7857084676476207, (507, 2) = 0.2752098219759625e-1, (508, 1) = 1.795744681, (508, 2) = 0.2729542517380107e-1, (509, 1) = 1.8091305661825445, (509, 2) = 0.2715997133090622e-1, (510, 1) = 1.818439716, (510, 2) = 0.26953352255320633e-1, (511, 1) = 1.8325251713760276, (511, 2) = 0.26812611905930955e-1, (512, 1) = 1.841134752, (512, 2) = 0.2662386351086802e-1, (513, 1) = 1.85589364849777, (513, 2) = 0.2647822581272541e-1, (514, 1) = 1.863829787, (514, 2) = 0.26306349232121655e-1, (515, 1) = 1.8792372800794723, (515, 2) = 0.26156176500423615e-1, (516, 1) = 1.886524823, (516, 2) = 0.26000236139530727e-1, (517, 1) = 1.9025572698611664, (517, 2) = 0.25845865945916494e-1, (518, 1) = 1.909219858, (518, 2) = 0.2570498490549631e-1, (519, 1) = 1.925854750222718, (519, 2) = 0.25546731903369348e-1, (520, 1) = 1.931914893, (520, 2) = 0.25420087681626943e-1, (521, 1) = 1.9491307877003698, (521, 2) = 0.25258245338369206e-1, (522, 1) = 1.954609929, (522, 2) = 0.25145065956422477e-1, (523, 1) = 1.9723863841858487, (523, 2) = 0.24979908145105163e-1, (524, 1) = 1.977304964, (524, 2) = 0.2487946857940225e-1, (525, 1) = 1.995622486030146, (525, 2) = 0.24711250966684323e-1, (526, 1) = 2.0, (526, 2) = 0.2462286982602636e-1}, datatype = float[8], order = C_order, attributes = [source_rtable = (Array(1..1064, 1..2, {(1, 1) = 533.0, (1, 2) = .0, (2, 1) = -1.2, (2, 2) = 0.41261628514026705e-1, (3, 1) = -1.19267089595802, (3, 2) = 0.41436198756000325e-1, (4, 1) = -1.177304965, (4, 2) = 0.421126115892303e-1, (5, 1) = -1.1716162095098475, (5, 2) = 0.422506861764233e-1, (6, 1) = -1.154609929, (6, 2) = 0.4301411176968256e-1, (7, 1) = -1.15065572020245, (7, 2) = 0.43111945839586496e-1, (8, 1) = -1.131914894, (8, 2) = 0.43970208782359216e-1, (9, 1) = -1.1297968229372144, (9, 2) = 0.4402364898520697e-1, (10, 1) = -1.109219858, (10, 2) = 0.4498540288188576e-1, (11, 1) = -1.1090476520622503, (11, 2) = 0.4498983531567732e-1, (12, 1) = -1.107255897400308, (12, 2) = 0.4507534125795398e-1, (13, 1) = -1.0879078190362412, (13, 2) = 0.45762044520275144e-1, (14, 1) = -1.086524823, (14, 2) = 0.4584204330226836e-1, (15, 1) = -1.0668118778091222, (15, 2) = 0.4655604788564336e-1, (16, 1) = -1.063829787, (16, 2) = 0.46732239917926216e-1, (17, 1) = -1.0458134297696844, (17, 2) = 0.47398459476371786e-1, (18, 1) = -1.041134752, (18, 2) = 0.47680941429942045e-1, (19, 1) = -1.0249206528034631, (19, 2) = 0.4829334053858219e-1, (20, 1) = -1.018439716, (20, 2) = 0.4869339171996856e-1, (21, 1) = -1.0041426074601278, (21, 2) = 0.4924518946361946e-1, (22, 1) = -.9957446809, (22, 2) = 0.4977543555747364e-1, (23, 1) = -.9834893501712454, (23, 2) = 0.50258999763314875e-1, (24, 1) = -.9730496454, (24, 2) = 0.50933603529112095e-1, (25, 1) = -.9629720697165176, (25, 2) = 0.51340327129402084e-1, (26, 1) = -.9503546099, (26, 2) = 0.52175210665447225e-1, (27, 1) = -.9426032443041934, (27, 2) = 0.52495367314293634e-1, (28, 1) = -.9276595745, (28, 2) = 0.5350847241501685e-1, (29, 1) = -.9223968240637509, (29, 2) = 0.5373104701962268e-1, (30, 1) = -.904964539, (30, 2) = 0.54942641007772866e-1, (31, 1) = -.9023684452269646, (31, 2) = 0.5505513019407443e-1, (32, 1) = -.8842890231953708, (32, 2) = 0.5634417657244248e-1, (33, 1) = -.882471433514145, (33, 2) = 0.56444441450089165e-1, (34, 1) = -.8822695036, (34, 2) = 0.5646133607037262e-1, (35, 1) = -.8621065795999284, (35, 2) = 0.5760145363158678e-1, (36, 1) = -.8595744681, (36, 2) = 0.57818901927070655e-1, (37, 1) = -.8419124936084817, (37, 2) = 0.58843257731947804e-1, (38, 1) = -.8368794326, (38, 2) = 0.5928720766251162e-1, (39, 1) = -.8219065800847545, (39, 2) = 0.6017849564985e-1, (40, 1) = -.8141843972, (40, 2) = 0.6087864450608002e-1, (41, 1) = -.8021085378104986, (41, 2) = 0.61616948530202054e-1, (42, 1) = -.7914893617000001, (42, 2) = 0.6260738724914124e-1, (43, 1) = -.7825407348396687, (43, 2) = 0.6316972283262606e-1, (44, 1) = -.7687943263, (44, 2) = 0.6448971141760913e-1, (45, 1) = -.7632286568027249, (45, 2) = 0.6484947300726429e-1, (46, 1) = -.7460992908, (46, 2) = 0.6654437839452494e-1, (47, 1) = -.7442014461311223, (47, 2) = 0.6667066927521469e-1, (48, 1) = -.7349676796965554, (48, 2) = 0.6761301188693097e-1, (49, 1) = -.7250191353657424, (49, 2) = 0.6841485321974146e-1, (50, 1) = -.7234042553, (50, 2) = 0.686035468015165e-1, (51, 1) = -.705669718317685, (51, 2) = 0.700760633323882e-1, (52, 1) = -.7007092199, (52, 2) = 0.7067435705037604e-1, (53, 1) = -.6866105755767743, (53, 2) = 0.7188140426155366e-1, (54, 1) = -.6780141844, (54, 2) = 0.7295274738625322e-1, (55, 1) = -.6678771808256976, (55, 2) = 0.7384848982400836e-1, (56, 1) = -.655319149, (56, 2) = 0.754674599729381e-1, (57, 1) = -.6495106707592542, (57, 2) = 0.7599774575453017e-1, (58, 1) = -.6326241135, (58, 2) = 0.7825239260246131e-1, (59, 1) = -.6315589756845804, (59, 2) = 0.7835297106772943e-1, (60, 1) = -.6277391487718638, (60, 2) = 0.7888184720141947e-1, (61, 1) = -.6131709001212667, (61, 2) = 0.8049151904367856e-1, (62, 1) = -.609929078, (62, 2) = 0.8099550675764658e-1, (63, 1) = -.5949431283071579, (63, 2) = 0.82709663097192e-1, (64, 1) = -.5872340426, (64, 2) = 0.8395380010864444e-1, (65, 1) = -.5771593458207257, (65, 2) = 0.8514826254396962e-1, (66, 1) = -.5645390071, (66, 2) = 0.8726565535792828e-1, (67, 1) = -.5598826301952126, (67, 2) = 0.8783863745506451e-1, (68, 1) = -.5466477717457469, (68, 2) = 0.9015068251590796e-1, (69, 1) = -.5429027363722535, (69, 2) = 0.9067639417566692e-1, (70, 1) = -.5418439717, (70, 2) = 0.9088082428176686e-1, (71, 1) = -.525438211198211, (71, 2) = 0.932735154457075e-1, (72, 1) = -.5191489362, (72, 2) = 0.9453954179978605e-1, (73, 1) = -.5085364269751652, (73, 2) = 0.9615005620174408e-1, (74, 1) = -.4964539007, (74, 2) = 0.98690349811486e-1, (75, 1) = -.49228531989480223, (75, 2) = 0.9934967965825986e-1, (76, 1) = -.4828779696583565, (76, 2) = .10141951783039646, (77, 1) = -.4761536559337748, (77, 2) = .10260861054556743, (78, 1) = -.4737588653, (78, 2) = .10318308525315915, (79, 1) = -.45980229473358625, (79, 2) = .1057584545215515, (80, 1) = -.4510638298, (80, 2) = .10795556563308807, (81, 1) = -.44419925540218685, (81, 2) = .10927986503153263, (82, 1) = -.43129528363204245, (82, 2) = .11268835314488496, (83, 1) = -.4292450733383884, (83, 2) = .11312345460527987, (84, 1) = -.4283687944, (84, 2) = .11337288827715172, (85, 1) = -.4136417731873337, (85, 2) = .11664473562278216, (86, 1) = -.4056737589, (86, 2) = .1190316816970865, (87, 1) = -.39892294617003593, (87, 2) = .12060518678954052, (88, 1) = -.3883197764493317, (88, 2) = .12395718845937345, (89, 1) = -.38478097643791653, (89, 2) = .12485206666651785, (90, 1) = -.3829787234, (90, 2) = .12545955656623853, (91, 1) = -.3701655445733497, (91, 2) = .12886385691632035, (92, 1) = -.360283688, (92, 2) = .13238598411727817, (93, 1) = -.3566256907997566, (93, 2) = .1334097072481441, (94, 1) = -.3518223503261959, (94, 2) = .13522602377386195, (95, 1) = -.34294832064369674, (95, 2) = .13788727617206284, (96, 1) = -.3375886525, (96, 2) = .14002654564846956, (97, 1) = -.32963179392161496, (97, 2) = .14254401577129194, (98, 1) = -.3203234022204043, (98, 2) = .14649485908835044, (99, 1) = -.31708364996467686, (99, 2) = .14758228280240912, (100, 1) = -.3148936171, (100, 2) = .14855538315508504, (101, 1) = -.3040756221878905, (101, 2) = .152392202338086, (102, 1) = -.2927343644310111, (102, 2) = .15776369440283894, (103, 1) = -.29242837387060233, (103, 2) = .15787779386102044, (104, 1) = -.2921985816, (104, 2) = .15799085607151853, (105, 1) = -.27980822039178344, (105, 2) = .16288030581168872, (106, 1) = -.2695035461, (106, 2) = .16829801787630116, (107, 1) = -.2687012698815751, (107, 2) = .1686341730537304, (108, 1) = -.2679955692761825, (108, 2) = .16903252971732743, (109, 1) = -.25671570471486266, (109, 2) = .17395177905157494, (110, 1) = -.2468085107, (110, 2) = .1797065768533967, (111, 1) = -.24618915759827734, (111, 2) = .1799938357439754, (112, 1) = -.24569751399889558, (112, 2) = .18030136503181593, (113, 1) = -.234711252197147, (113, 2) = .1855635116224447, (114, 1) = -.22531120720983766, (114, 2) = .19157020034630443, (115, 1) = -.22470969906676053, (115, 2) = .19186624520444495, (116, 1) = -.2241134752, (116, 2) = .19225384054606207, (117, 1) = -.21373098061891724, (117, 2) = .19768378388322616, (118, 1) = -.2063681856878516, (118, 2) = .20283903566079292, (119, 1) = -.2039828738151915, (119, 2) = .20411236192280288, (120, 1) = -.2014184398, (120, 2) = .20592718037588806, (121, 1) = -.19373268245291744, (121, 2) = .21029163844872187, (122, 1) = -.18874015086561913, (122, 2) = .21410787097528142, (123, 1) = -.18410270991055838, (123, 2) = .2167788741385519, (124, 1) = -.178723404, (124, 2) = .22090843768638282, (125, 1) = -.17469706345541725, (125, 2) = .2233774950738828, (126, 1) = -.1722931793144359, (126, 2) = .2253767062897699, (127, 1) = -.16504869095233385, (127, 2) = .2298555944062463, (128, 1) = -.15686805983835422, (128, 2) = .2366455416042584, (129, 1) = -.15649517505772623, (129, 2) = .2368773262473895, (130, 1) = -.156028369, (130, 2) = .2372631575176681, (131, 1) = -.14682063010740992, (131, 2) = .2433424302957317, (132, 1) = -.1417102960582741, (132, 2) = .2479143769187469, (133, 1) = -.1381149592957238, (133, 2) = .25028861237983796, (134, 1) = -.133333333, (134, 2) = .2545242814869516, (135, 1) = -.1294442151790709, (135, 2) = .25725213663706675, (136, 1) = -.12743611919656356, (136, 2) = .25918321223323537, (137, 1) = -.1204543821581433, (137, 2) = .26405722259767306, (138, 1) = -.11369992138863468, (138, 2) = .2704520475477239, (139, 1) = -.11242277539170835, (139, 2) = .2713380995784694, (140, 1) = -.110638298, (140, 2) = .2729998078233795, (141, 1) = -.10355267094561393, (141, 2) = .2782026348904638, (142, 1) = -.10006722127068785, (142, 2) = .2817208828622124, (143, 1) = -0.9514584237784214e-1, (143, 2) = .285297202023692, (144, 1) = -0.87943262e-1, (144, 2) = .2924110188714629, (145, 1) = -0.8748570429005592e-1, (145, 2) = .2927625256440507, (146, 1) = -0.8727416892689449e-1, (146, 2) = .2929897181767009, (147, 1) = -0.785523542708645e-1, (147, 2) = .29959565728269333, (148, 1) = -0.740919585476014e-1, (148, 2) = .30425855349118935, (149, 1) = -0.7055877748780234e-1, (149, 2) = .30689541740773857, (150, 1) = -0.65248227e-1, (150, 2) = .31229992058430617, (151, 1) = -0.6273030225245567e-1, (151, 2) = .3142771559104939, (152, 1) = -0.61598592849592335e-1, (152, 2) = .3155273888056779, (153, 1) = -0.5414040818996799e-1, (153, 2) = .32128082478839937, (154, 1) = -0.4898701835759752e-1, (154, 2) = .3267962241201664, (155, 1) = -0.4643995390754995e-1, (155, 2) = .3287261299274413, (156, 1) = -0.42553192e-1, (156, 2) = .33275877680169197, (157, 1) = -0.38439002281444e-1, (157, 2) = .33602222828907, (158, 1) = -0.3662195775650565e-1, (158, 2) = .33806505943465487, (159, 1) = -0.3008766444513611e-1, (159, 2) = .3431443484041197, (160, 1) = -0.24382821326249318e-1, (160, 2) = .34933389474914334, (161, 1) = -0.22597435004447088e-1, (161, 2) = .350694037292277, (162, 1) = -0.19858156e-1, (162, 2) = .3535654033913945, (163, 1) = -0.14402294216216275e-1, (163, 2) = .3578937142837456, (164, 1) = -0.12013117316234797e-1, (164, 2) = .36060273006363186, (165, 1) = -0.622011302278846e-2, (165, 2) = .36509982608262626, (166, 1) = -0.11839877590065755e-4, (166, 2) = .3718715653781204, (167, 1) = 0.11140442324859723e-2, (167, 2) = .37272700980767026, (168, 1) = 0.2836879e-2, (168, 2) = .37453754120042687, (169, 1) = 0.9539442998612369e-2, (169, 2) = .37981235618608405, (170, 1) = 0.12471862136413488e-1, (170, 2) = .38314040069260885, (171, 1) = 0.17593552274937967e-1, (171, 2) = .3870820601028604, (172, 1) = 0.24322526461584885e-1, (172, 2) = .3944092360070973, (173, 1) = 0.24803188362344877e-1, (173, 2) = .39477107286291974, (174, 1) = 0.25531915e-1, (174, 2) = .3955338697916218, (175, 1) = 0.335062673468198e-1, (175, 2) = .40171854170041466, (176, 1) = 0.37014291678273754e-1, (176, 2) = .40567807132158584, (177, 1) = 0.4145044194966337e-1, (177, 2) = .40904283164147737, (178, 1) = 0.4822695e-1, (178, 2) = .41636543331894244, (179, 1) = 0.4868354184062358e-1, (179, 2) = .41672019369946894, (180, 1) = 0.4887701409911159e-1, (180, 2) = .41694690663607437, (181, 1) = 0.57585490211736395e-1, (181, 2) = .4235689174894747, (182, 1) = 0.6174769966791911e-1, (182, 2) = .42821574195056283, (183, 1) = 0.6541944531650314e-1, (183, 2) = .43094793522725994, (184, 1) = 0.70921986e-1, (184, 2) = .4368186633545512, (185, 1) = 0.7304724678510621e-1, (185, 2) = .43842931501109567, (186, 1) = 0.7396019943512601e-1, (186, 2) = .4394845772650513, (187, 1) = 0.8183631766597962e-1, (187, 2) = .445334086012666, (188, 1) = 0.8676693593953405e-1, (188, 2) = .4507534125795398, (189, 1) = 0.895456800656217e-1, (189, 2) = .45277496797694916, (190, 1) = 0.93617021e-1, (190, 2) = .4570451177053588, (191, 1) = 0.976519360158512e-1, (191, 2) = .4600187792579097, (192, 1) = 0.99416929477154e-1, (192, 2) = .46202224789402835, (193, 1) = .1062933790402563, (193, 2) = .4669968525607602, (194, 1) = .11213417917275714, (194, 2) = .4732910832085168, (195, 1) = .1138541892628568, (195, 2) = .4745114957584093, (196, 1) = .116312057, (196, 2) = .47703613428218394, (197, 1) = .12252047690692286, (197, 2) = .48147723275079535, (198, 1) = .12529701307964758, (198, 2) = .4845599185230053, (199, 1) = .1309700005103384, (199, 2) = .4885506002031381, (200, 1) = .13788366184059767, (200, 2) = .4958287538374938, (201, 1) = .13835342735212108, (201, 2) = .4961533199493262, (202, 1) = .139007092, (202, 2) = .4968087037070055, (203, 1) = .14765154085433121, (203, 2) = .5028053346464606, (204, 1) = .1516185902721116, (204, 2) = .5070975891519823, (205, 1) = .1558618339342827, (205, 2) = .5099974881437597, (206, 1) = .161702128, (206, 2) = .5159840367863033, (207, 1) = .1637279091152927, (207, 2) = .5173605571579852, (208, 1) = .1646282007005304, (208, 2) = .5183664244664707, (209, 1) = .17302384141469207, (209, 2) = .5240136547053116, (210, 1) = .1783733301975982, (210, 2) = .5296352597809593, (211, 1) = .1809511075710633, (211, 2) = .5313463402491448, (212, 1) = .184397163, (212, 2) = .5347758673843621, (213, 1) = .18970544158166563, (213, 2) = .5382683593715557, (214, 1) = .19214114775476732, (214, 2) = .5409040950954478, (215, 1) = .19860179418727114, (215, 2) = .5451198616440438, (216, 1) = .2055331874841016, (216, 2) = .5521729304099363, (217, 1) = .2062113949315691, (217, 2) = .5526102787354239, (218, 1) = .207092199, (218, 2) = .5534591828667559, (219, 1) = .21589183116696975, (219, 2) = .559072457383739, (220, 1) = .22007477073408385, (220, 2) = .5634417657244248, (221, 1) = .22434211587152972, (221, 2) = .5661454469241968, (222, 1) = .229787234, (222, 2) = .571496213370795, (223, 1) = .23266837952887315, (223, 2) = .5732800170154938, (224, 1) = .23399442714162416, (224, 2) = .5747106010389132, (225, 1) = .24222012399064247, (225, 2) = .5798060953654851, (226, 1) = .24836062676969145, (226, 2) = .5859794363534018, (227, 1) = .25020042141128895, (227, 2) = .5871124491330668, (228, 1) = .252482269, (228, 2) = .589273049307657, (229, 1) = .2597424313480354, (229, 2) = .5936433611554566, (230, 1) = .2632296091285283, (230, 2) = .5972482716678903, (231, 1) = .268627251343733, (231, 2) = .6005005897498503, (232, 1) = .275177305, (232, 2) = .6068235073394961, (233, 1) = .2767501435257067, (233, 2) = .6077361406466814, (234, 1) = .27747928509885705, (234, 2) = .6085171069823787, (235, 1) = .2868282823399778, (235, 2) = .6140008467948312, (236, 1) = .29268317440858527, (236, 2) = .6197859422968672, (237, 1) = .2950611539460224, (237, 2) = .621181789127712, (238, 1) = .29787234, (238, 2) = .6237828738055657, (239, 1) = .30470771202533337, (239, 2) = .6276607895310221, (240, 1) = .3080442338751085, (240, 2) = .6310547776113558, (241, 1) = .31386021896895094, (241, 2) = .6343851027102586, (242, 1) = .320567376, (242, 2) = .6407088297539558, (243, 1) = .32211916787132777, (243, 2) = .6415530969499775, (244, 1) = .3228487179056557, (244, 2) = .6423236129258443, (245, 1) = .33248054500276564, (245, 2) = .6476771659080589, (246, 1) = .3386118692085989, (246, 2) = .6535924482403328, (247, 1) = .3407978634877382, (247, 2) = .6548161775732204, (248, 1) = .343262411, (248, 2) = .6570314897213996, (249, 1) = .3508446287475112, (249, 2) = .661096461894468, (250, 1) = .3546359007797546, (250, 2) = .6648612835548212, (251, 1) = .3600319250093263, (251, 2) = .6678035010276325, (252, 1) = .365957447, (252, 2) = .6732237390059193, (253, 1) = .3688368462646208, (253, 2) = .6747004019238337, (254, 1) = .3702239192889135, (254, 2) = .6761301188693097, (255, 1) = .3791492546224394, (255, 2) = .6808487854972249, (256, 1) = .3861585761515719, (256, 2) = .6873989541837983, (257, 1) = .3873587036056653, (257, 2) = .6880413579368305, (258, 1) = .388652482, (258, 2) = .6891640112408506, (259, 1) = .3980971549553082, (259, 2) = .693978197283823, (260, 1) = .40298345582235984, (260, 2) = .6986677894982867, (261, 1) = .4070635407336446, (261, 2) = .7007949257718565, (262, 1) = .411347518, (262, 2) = .7045689463020051, (263, 1) = .4168000919566763, (263, 2) = .7072292415477635, (264, 1) = .4195269055680354, (264, 2) = .7099366248127752, (265, 1) = .4267171541994851, (265, 2) = .7135739275398234, (266, 1) = .434042553, (266, 2) = .720146621419057, (267, 1) = .43514659757709373, (267, 2) = .7206572655124095, (268, 1) = .43567484315402083, (268, 2) = .7212054601272637, (269, 1) = .4462907805706877, (269, 2) = .7263926457193876, (270, 1) = .45291837534317614, (270, 2) = .7324742954417522, (271, 1) = .4548191941717477, (271, 2) = .7334268418659017, (272, 1) = .456737589, (272, 2) = .7350427489987656, (273, 1) = .4657454482301041, (273, 2) = .7392704307934455, (274, 1) = .4704855919998322, (274, 2) = .7437431307562408, (275, 1) = .47500097975326555, (275, 2) = .7459435886620713, (276, 1) = .479432624, (276, 2) = .7497296020037805, (277, 1) = .48502740953821216, (277, 2) = .7522339701755038, (278, 1) = .4878698906252109, (278, 2) = .7550119660707292, (279, 1) = .49517658026858413, (279, 2) = .7584634068506074, (280, 1) = .50212766, (280, 2) = .7645032029789738, (281, 1) = .5040607937056584, (281, 2) = .7653209365791069, (282, 1) = .5049997443662744, (282, 2) = .7662808013852177, (283, 1) = .5153315255414652, (283, 2) = .770993480857628, (284, 1) = .5227245793683305, (284, 2) = .7775496366997062, (285, 1) = .5237997600680374, (285, 2) = .7780575577179255, (286, 1) = .524822695, (286, 2) = .7788841000898876, (287, 1) = .5354475382749663, (287, 2) = .7835428860057199, (288, 1) = .5412514509644586, (288, 2) = .7888184720141946, (289, 1) = .5445046574686911, (289, 2) = .790314562156639, (290, 1) = .54751773, (290, 2) = .7927761880543321, (291, 1) = .55550136781708, (291, 2) = .7961231673391631, (292, 1) = .5597332323632616, (292, 2) = .8000873073286832, (293, 1) = .5652499252683637, (293, 2) = .8025515217453003, (294, 1) = .570212766, (294, 2) = .8066586160492114, (295, 1) = .5754631438836486, (295, 2) = .8087491564142599, (296, 1) = .5781453048989444, (296, 2) = .8113561426431717, (297, 1) = .5860328365683942, (297, 2) = .8147697898119349, (298, 1) = .592907801, (298, 2) = .8205452188994823, (299, 1) = .595294009427073, (299, 2) = .8214401466231459, (300, 1) = .5964585313092597, (300, 2) = .8226249779576602, (301, 1) = .6068505720798303, (301, 2) = .826970766702572, (302, 1) = .6149493967262228, (302, 2) = .8338938132721487, (303, 1) = .6152960882547098, (303, 2) = .8340461241604681, (304, 1) = .615602837, (304, 2) = .8342823494384282, (305, 1) = .6277003471280935, (305, 2) = .8391558347901904, (306, 1) = .634586980263822, (306, 2) = .8451626485866371, (307, 1) = .6365788163140643, (307, 2) = .8460162165772238, (308, 1) = .638297872, (308, 2) = .8473495095131948, (309, 1) = .6485796006637554, (309, 2) = .8513262658675382, (310, 1) = .6542976984806798, (310, 2) = .8564314839011257, (311, 1) = .6579346440462116, (311, 2) = .8579500130122263, (312, 1) = .660992908, (312, 2) = .8603408007729323, (313, 1) = .6694862555608323, (313, 2) = .8634830913095224, (314, 1) = .6740845680154212, (314, 2) = .8677003192156142, (315, 1) = .6793658353812425, (315, 2) = .8698463885637018, (316, 1) = .683687943, (316, 2) = .8732545977341006, (317, 1) = .6904190825708448, (317, 2) = .875626921307706, (318, 1) = .693952648692807, (318, 2) = .8789691545301026, (319, 1) = .7008751518850601, (319, 2) = .8817039726946972, (320, 1) = .706382979, (320, 2) = .8860882007726247, (321, 1) = .7113781885483458, (321, 2) = .8877577031315868, (322, 1) = .713909575205173, (322, 2) = .8902379898445911, (323, 1) = .7224658969751668, (323, 2) = .8935211245845451, (324, 1) = .729078014, (324, 2) = .8988375674599276, (325, 1) = .7323656611545182, (325, 2) = .8998743997090204, (326, 1) = .7339661408374847, (326, 2) = .9015068251590796, (327, 1) = .7441419439283317, (327, 2) = .9052959214878551, (328, 1) = .75177305, (328, 2) = .9114970574022645, (329, 1) = .753386388023518, (329, 2) = .9119745847980459, (330, 1) = .7541368874572347, (330, 2) = .9127756604735682, (331, 1) = .7659077216566863, (331, 2) = .9170261639316147, (332, 1) = .7744501856484342, (332, 2) = .9240444957880567, (333, 1) = .7744601960750015, (333, 2) = .9240484129001746, (334, 1) = .774468085, (334, 2) = .9240541013714942, (335, 1) = .7877681575335678, (335, 2) = .9287094053076951, (336, 1) = .7957172182599538, (336, 2) = .9353133311025451, (337, 1) = .7965330650864829, (337, 2) = .9356261742005842, (338, 1) = .79716312, (338, 2) = .936080699484523, (339, 1) = .8097285548305844, (339, 2) = .9403430128082535, (340, 1) = .8171562753475038, (340, 2) = .9465821664170336, (341, 1) = .8186940604962507, (341, 2) = .9471601783013103, (342, 1) = .819858156, (342, 2) = .9479999321997671, (343, 1) = .8317943967794406, (343, 2) = .951924263499235, (344, 1) = .8387760734722867, (344, 2) = .9578510017315222, (345, 1) = .8409439174159301, (345, 2) = .9586500592784633, (346, 1) = .842553191, (346, 2) = .959810168927121, (347, 1) = .8539710766679941, (347, 2) = .9634504795163603, (348, 1) = .8605850020698751, (348, 2) = .9691198370460106, (349, 1) = .8632830132204153, (349, 2) = .9700956306265937, (350, 1) = .865248227, (350, 2) = .971510267474046, (351, 1) = .8762635502921021, (351, 2) = .9749192001118532, (352, 1) = .8825907012207321, (352, 2) = .9803886723604991, (353, 1) = .8857112811423421, (353, 2) = .9814969246592965, (354, 1) = .887943262, (354, 2) = .9830997664847827, (355, 1) = .8986759377168452, (355, 2) = .9863283795283331, (356, 1) = .9047996119484298, (356, 2) = .9916575076749876, (357, 1) = .9082281437304152, (357, 2) = .9928542289115815, (358, 1) = .910638298, (358, 2) = .9945790775346728, (359, 1) = .9212110989477038, (359, 2) = .9976765977173254, (360, 1) = .9272165297213989, (360, 2) = 1.0029263429894761, (361, 1) = .9308324551784213, (361, 2) = 1.0041681115222423, (362, 1) = .933333333, (362, 2) = 1.0059496416213003, (363, 1) = .9438702380442304, (363, 2) = 1.0089632567653588, (364, 1) = .949844212001387, (364, 2) = 1.0141951783039647, (365, 1) = .953522478003855, (365, 2) = 1.0154394359888441, (366, 1) = .956028369, (366, 2) = 1.0172140432960195, (367, 1) = .9666525829003361, (367, 2) = 1.0201887401152931, (368, 1) = .9726830795635464, (368, 2) = 1.0254640136184532, (369, 1) = .9762958811079261, (369, 2) = 1.0266693590031566, (370, 1) = .978723404, (370, 2) = 1.0283760496847765, (371, 1) = .9895552018914029, (371, 2) = 1.031354503351201, (372, 1) = .9957310589233355, (372, 2) = 1.0367328489329415, (373, 1) = .999149780031767, (373, 2) = 1.0378593135733407, (374, 1) = 1.00141844, (374, 2) = 1.0394405769870803, (375, 1) = 1.0125729904835612, (375, 2) = 1.0424630810945201, (376, 1) = 1.0189835864889594, (376, 2) = 1.04800168424743, (377, 1) = 1.0220808003670416, (377, 2) = 1.0490109744153784, (378, 1) = 1.024113475, (378, 2) = 1.0504135678147535, (379, 1) = 1.0356988524633386, (379, 2) = 1.0535179968212385, (380, 1) = 1.0424337893357438, (380, 2) = 1.0592705195619185, (381, 1) = 1.0450851784713082, (381, 2) = 1.0601262111086482, (382, 1) = 1.046808511, (382, 2) = 1.0613018014790114, (383, 1) = 1.0589240547414969, (383, 2) = 1.0645235867946037, (384, 1) = 1.066072821889716, (384, 2) = 1.070539354876407, (385, 1) = 1.0681588735095535, (385, 2) = 1.0712070292310296, (386, 1) = 1.069503546, (386, 2) = 1.0721126412766457, (387, 1) = 1.0822387217064668, (387, 2) = 1.075484754349653, (388, 1) = 1.089890331132023, (388, 2) = 1.0818081901908956, (389, 1) = 1.0912976997549417, (389, 2) = 1.0822555075177238, (390, 1) = 1.092198581, (390, 2) = 1.0828537564788456, (391, 1) = 1.1056324005262812, (391, 2) = 1.0864066902000677, (392, 1) = 1.1138749962769963, (392, 2) = 1.093077025505384, (393, 1) = 1.1144974541713701, (393, 2) = 1.0932737334407032, (394, 1) = 1.114893617, (394, 2) = 1.0935328359522722, (395, 1) = 1.1290946279490863, (395, 2) = 1.0972945893111703, (396, 1) = 1.137588652, (396, 2) = 1.1040087778450944, (397, 1) = 1.1381189448722804, (397, 2) = 1.1040825528856542, (398, 1) = 1.1382976252316022, (398, 2) = 1.1043458608198726, (399, 1) = 1.1526154413745195, (399, 2) = 1.1081533986608973, (400, 1) = 1.160283688, (400, 2) = 1.114061863976062, (401, 1) = 1.1626887166406676, (401, 2) = 1.1144205198892787, (402, 1) = 1.1635755682837294, (402, 2) = 1.1156146961343612, (403, 1) = 1.1761857775141515, (403, 2) = 1.1189876181845066, (404, 1) = 1.182978723, (404, 2) = 1.1240813104807699, (405, 1) = 1.1872472084382308, (405, 2) = 1.1247640873798597, (406, 1) = 1.1889683767544652, (406, 2) = 1.1268835314488497, (407, 1) = 1.1997977474791757, (407, 2) = 1.1298011653373443, (408, 1) = 1.205673759, (408, 2) = 1.1340840937864276, (409, 1) = 1.2117662883460014, (409, 2) = 1.135127224486678, (410, 1) = 1.2144445468439158, (410, 2) = 1.138152366763338, (411, 1) = 1.2234447737614151, (411, 2) = 1.140597305630091, (412, 1) = 1.228368794, (412, 2) = 1.144083294651399, (413, 1) = 1.2362291531660143, (413, 2) = 1.1455182740122114, (414, 1) = 1.2399797785422537, (414, 2) = 1.1494212020778265, (415, 1) = 1.2471216182823794, (415, 2) = 1.1513786404630624, (416, 1) = 1.25106383, (416, 2) = 1.1540883094611614, (417, 1) = 1.2606281183030106, (417, 2) = 1.1559410519958653, (418, 1) = 1.2655566476735318, (418, 2) = 1.160690037392315, (419, 1) = 1.2708243119629206, (419, 2) = 1.1621471400095387, (420, 1) = 1.273758865, (420, 2) = 1.1641052903046392, (421, 1) = 1.2849622300061962, (421, 2) = 1.1663960317744106, (422, 1) = 1.2911638364917823, (422, 2) = 1.1719588727068035, (423, 1) = 1.2945500306394797, (423, 2) = 1.172904207252774, (424, 1) = 1.296453901, (424, 2) = 1.1741377080665396, (425, 1) = 1.3092350950435536, (425, 2) = 1.1768814225540378, (426, 1) = 1.3167951362796533, (426, 2) = 1.183227708021292, (427, 1) = 1.3182969272214577, (427, 2) = 1.1836507585524716, (428, 1) = 1.319148936, (428, 2) = 1.1841869312590947, (429, 1) = 1.333453118078561, (429, 2) = 1.187394044262778, (430, 1) = 1.341843972, (430, 2) = 1.194019298232287, (431, 1) = 1.3426819684234765, (431, 2) = 1.1940804504022253, (432, 1) = 1.3428900796612153, (432, 2) = 1.1944965433357806, (433, 1) = 1.3576241724453957, (433, 2) = 1.1979299873389633, (434, 1) = 1.364539007, (434, 2) = 1.2030898406011152, (435, 1) = 1.3689730100174544, (435, 2) = 1.2035637495367806, (436, 1) = 1.3704761526800113, (436, 2) = 1.2057653786502691, (437, 1) = 1.381756670449592, (437, 2) = 1.208485074740529, (438, 1) = 1.387234042, (438, 2) = 1.2123646582358045, (439, 1) = 1.3946219007750242, (439, 2) = 1.2133658979566908, (440, 1) = 1.3977235026021453, (440, 2) = 1.2170342139647574, (441, 1) = 1.4058589487232358, (441, 2) = 1.2190551676450483, (442, 1) = 1.409929078, (442, 2) = 1.2218024974264723, (443, 1) = 1.4198341416851132, (443, 2) = 1.223384857637459, (444, 1) = 1.424710097163719, (444, 2) = 1.228303049279246, (445, 1) = 1.4299388908262032, (445, 2) = 1.2296363508784427, (446, 1) = 1.432624113, (446, 2) = 1.2313699249485637, (447, 1) = 1.444742799426594, (447, 2) = 1.2335545563300023, (448, 1) = 1.4514999002120572, (448, 2) = 1.2395718845937345, (449, 1) = 1.4540037259972756, (449, 2) = 1.2402250355817566, (450, 1) = 1.455319149, (450, 2) = 1.241039933707554, (451, 1) = 1.469437327616466, (451, 2) = 1.2438305773916114, (452, 1) = 1.478014184, (452, 2) = 1.2507351573135137, (453, 1) = 1.4782183459056166, (453, 2) = 1.2507393467757069, (454, 1) = 1.4782495260993627, (454, 2) = 1.250840719908223, (455, 1) = 1.4939797273266915, (455, 2) = 1.2541821353915725, (456, 1) = 1.50070922, (456, 2) = 1.2591634293759488, (457, 1) = 1.505854401668368, (457, 2) = 1.2595548023931185, (458, 1) = 1.5073989986545766, (458, 2) = 1.2621095552227115, (459, 1) = 1.5184140673336533, (459, 2) = 1.2645873484052492, (460, 1) = 1.523404255, (460, 2) = 1.2680272225372362, (461, 1) = 1.5321117743460344, (461, 2) = 1.2690548194484306, (462, 1) = 1.5357599743722785, (462, 2) = 1.2733783905372, (463, 1) = 1.5427723399764979, (463, 2) = 1.2750303316569769, (464, 1) = 1.546099291, (464, 2) = 1.2771869700824743, (465, 1) = 1.5576306142422092, (465, 2) = 1.2789215425656928, (466, 1) = 1.5635942937038148, (466, 2) = 1.2846472258516886, (467, 1) = 1.5670781819213742, (467, 2) = 1.2854993481329704, (468, 1) = 1.568794326, (468, 2) = 1.2865535515161495, (469, 1) = 1.582717529208757, (469, 2) = 1.2890027306911938, (470, 1) = 1.5910736351356305, (470, 2) = 1.295916061166177, (471, 1) = 1.5913493223373487, (471, 2) = 1.2959855954861892, (472, 1) = 1.591489362, (472, 2) = 1.2960676181511386, (473, 1) = 1.6075374375301157, (473, 2) = 1.299216496332204, (474, 1) = 1.614184397, (474, 2) = 1.30413089367417, (475, 1) = 1.619775181255238, (475, 2) = 1.3044088872323383, (476, 1) = 1.6212249932841432, (476, 2) = 1.3071848964806656, (477, 1) = 1.6321866840782542, (477, 2) = 1.3095150009948273, (478, 1) = 1.636879432, (478, 2) = 1.3126893495058787, (479, 1) = 1.6464795204325755, (479, 2) = 1.313686970660639, (480, 1) = 1.650460475112204, (480, 2) = 1.318453731795154, (481, 1) = 1.6567251307455784, (481, 2) = 1.3198685218961923, (482, 1) = 1.659574468, (482, 2) = 1.32166074537656, (483, 1) = 1.6721809211460665, (483, 2) = 1.3234630462759958, (484, 1) = 1.6789306407562474, (484, 2) = 1.3297225671096424, (485, 1) = 1.6811917774360323, (485, 2) = 1.3302576934883668, (486, 1) = 1.682269503, (486, 2) = 1.3308954548933172, (487, 1) = 1.6973698232778063, (487, 2) = 1.3334935944274116, (488, 1) = 1.704964539, (488, 2) = 1.3394534244250287, (489, 1) = 1.7081500816800899, (489, 2) = 1.3394096751498963, (490, 1) = 1.708496655893026, (490, 2) = 1.340991402424131, (491, 1) = 1.7222705339674442, (491, 2) = 1.3436672389949957, (492, 1) = 1.727659574, (492, 2) = 1.3474175387258738, (493, 1) = 1.7362633447311187, (493, 2) = 1.347988181265451, (494, 1) = 1.7391255312858365, (494, 2) = 1.3522602377386195, (495, 1) = 1.746999930576139, (495, 2) = 1.3539259469254386, (496, 1) = 1.75035461, (496, 2) = 1.3560556866576374, (497, 1) = 1.7624943764568155, (497, 2) = 1.3575012775921975, (498, 1) = 1.7684820328348467, (498, 2) = 1.363529073053108, (499, 1) = 1.771624703972516, (499, 2) = 1.3642366033905395, (500, 1) = 1.773049645, (500, 2) = 1.3650773164483616, (501, 1) = 1.787947397080901, (501, 2) = 1.3674006821743552, (502, 1) = 1.795744681, (502, 2) = 1.3736934108737564, (503, 1) = 1.7982408043979758, (503, 2) = 1.3735585005633595, (504, 1) = 1.7982817067824142, (504, 2) = 1.3747979083675965, (505, 1) = 1.813015524786313, (505, 2) = 1.3774911986622067, (506, 1) = 1.818439716, (506, 2) = 1.3812734215805165, (507, 1) = 1.8272589509789168, (507, 2) = 1.38168770209003, (508, 1) = 1.8298930119727332, (508, 2) = 1.386066743682085, (509, 1) = 1.8378735238228332, (509, 2) = 1.3876860512368943, (510, 1) = 1.841134752, (510, 2) = 1.3897317178670505, (511, 1) = 1.853695160847097, (511, 2) = 1.391098920679872, (512, 1) = 1.8598377398631647, (512, 2) = 1.3973355789965733, (513, 1) = 1.8626106992395048, (513, 2) = 1.397940896380174, (514, 1) = 1.863829787, (514, 2) = 1.398645893407542, (515, 1) = 1.8792317204698494, (515, 2) = 1.4009568453979109, (516, 1) = 1.886524823, (516, 2) = 1.4067256516680482, (517, 1) = 1.8907900133376323, (517, 2) = 1.4064866062750874, (518, 1) = 1.8908897521944803, (518, 2) = 1.4086044143110619, (519, 1) = 1.9043628317265646, (519, 2) = 1.411016088458887, (520, 1) = 1.909219858, (520, 2) = 1.4142995395813438, (521, 1) = 1.9194103188649203, (521, 2) = 1.4148133488470087, (522, 1) = 1.9227626617096658, (522, 2) = 1.4198732496255504, (523, 1) = 1.9292857347586272, (523, 2) = 1.4211787136284815, (524, 1) = 1.931914893, (524, 2) = 1.4227704338717295, (525, 1) = 1.945646142157817, (525, 2) = 1.4243240659943255, (526, 1) = 1.9529091122156412, (526, 2) = 1.431142084940039, (527, 1) = 1.9540943988482649, (527, 2) = 1.4313980626956835, (528, 1) = 1.954609929, (528, 2) = 1.4316853020793843, (529, 1) = 1.9711006684096328, (529, 2) = 1.4342227228527038, (530, 1) = 1.977304964, (530, 2) = 1.438808256867013, (531, 1) = 1.9848990157466457, (531, 2) = 1.4386402226225583, (532, 1) = 1.9858894123366866, (532, 2) = 1.4424109202545274, (533, 1) = 1.9962153472752922, (533, 2) = 1.444290125393363, (534, 1) = 2.0, (534, 2) = 1.4466982421140733, (535, 1) = 526.0, (535, 2) = .0, (536, 1) = 2.0, (536, 2) = 1.4244739827156567, (537, 1) = 1.9911033075589653, (537, 2) = 1.4242907514070708, (538, 1) = 1.988938650705044, (538, 2) = 1.4198732496255504, (539, 1) = 1.9807093349143547, (539, 2) = 1.4181828669716827, (540, 1) = 1.977304964, (540, 2) = 1.4160331741812382, (541, 1) = 1.9648820287133912, (541, 2) = 1.4147728124592622, (542, 1) = 1.959027218781368, (542, 2) = 1.4086044143110619, (543, 1) = 1.9560023497854198, (543, 2) = 1.4079130313491337, (544, 1) = 1.954609929, (544, 2) = 1.407093778608152, (545, 1) = 1.9395784885973428, (545, 2) = 1.404799185859197, (546, 1) = 1.931914893, (546, 2) = 1.3986085622329218, (547, 1) = 1.928904359550343, (547, 2) = 1.39883040840102, (548, 1) = 1.9289781087749505, (548, 2) = 1.3973355789965733, (549, 1) = 1.9146577797750053, (549, 2) = 1.3946354710242526, (550, 1) = 1.909219858, (550, 2) = 1.3908391897463857, (551, 1) = 1.9004045668329654, (551, 2) = 1.3904438272340855, (552, 1) = 1.8978224188044934, (552, 2) = 1.386066743682085, (553, 1) = 1.8899445415618423, (553, 2) = 1.3843687403392702, (554, 1) = 1.886524823, (554, 2) = 1.3821896337700932, (555, 1) = 1.8744218854832915, (555, 2) = 1.3808074167771593, (556, 1) = 1.8685816137392477, (556, 2) = 1.3747979083675965, (557, 1) = 1.8653646403537838, (557, 2) = 1.3740358029593618, (558, 1) = 1.863829787, (558, 2) = 1.3731158725532704, (559, 1) = 1.8492367832493735, (559, 2) = 1.3707749819494601, (560, 1) = 1.841134752, (560, 2) = 1.3641408226333422, (561, 1) = 1.8397125842073203, (561, 2) = 1.3642352263566444, (562, 1) = 1.8397367591753435, (562, 2) = 1.363529073053108, (563, 1) = 1.8244207805791843, (563, 2) = 1.360559276849738, (564, 1) = 1.818439716, (564, 2) = 1.3562672724894527, (565, 1) = 1.8110254109152697, (565, 2) = 1.3559416853755675, (566, 1) = 1.809020818176691, (566, 2) = 1.3522602377386195, (567, 1) = 1.7998166659481318, (567, 2) = 1.3502383625670864, (568, 1) = 1.795744681, (568, 2) = 1.3475540749180612, (569, 1) = 1.7849430638946275, (569, 2) = 1.3463547622483059, (570, 1) = 1.7801117243483229, (570, 2) = 1.340991402424131, (571, 1) = 1.775353465703897, (571, 2) = 1.3398474793166142, (572, 1) = 1.773049645, (572, 2) = 1.338414343894464, (573, 1) = 1.7597459628648964, (573, 2) = 1.3363282851910108, (574, 1) = 1.7522280308192448, (574, 2) = 1.3297225671096424, (575, 1) = 1.7509946966427923, (575, 2) = 1.3294047429263074, (576, 1) = 1.75035461, (576, 2) = 1.329022589019138, (577, 1) = 1.7349708310891567, (577, 2) = 1.3260922863698545, (578, 1) = 1.727659574, (578, 2) = 1.3204868328937538, (579, 1) = 1.7236730957967594, (579, 2) = 1.3204331500404713, (580, 1) = 1.7229922124727142, (580, 2) = 1.318453731795154, (581, 1) = 1.7104410065094402, (581, 2) = 1.3157344845911276, (582, 1) = 1.704964539, (582, 2) = 1.3118905530917053, (583, 1) = 1.6969052583294504, (583, 2) = 1.3111865956464948, (584, 1) = 1.694018500301522, (584, 2) = 1.3071848964806656, (585, 1) = 1.6860748102363234, (585, 2) = 1.3052954356943, (586, 1) = 1.682269503, (586, 2) = 1.302781757129747, (587, 1) = 1.671443358076547, (587, 2) = 1.3012916000993922, (588, 1) = 1.666210129027341, (588, 2) = 1.295916061166177, (589, 1) = 1.6618295456569196, (589, 2) = 1.2947963405428244, (590, 1) = 1.659574468, (590, 2) = 1.2933697167640108, (591, 1) = 1.6465768639073821, (591, 2) = 1.2911009657797783, (592, 1) = 1.639150180565863, (592, 2) = 1.2846472258516886, (593, 1) = 1.6376809442483673, (593, 2) = 1.2842492485350014, (594, 1) = 1.636879432, (594, 2) = 1.2837578743292788, (595, 1) = 1.6220445987487304, (595, 2) = 1.2807443757769872, (596, 1) = 1.614184397, (596, 2) = 1.2746018452353232, (597, 1) = 1.6118461393229677, (597, 2) = 1.27453941279098, (598, 1) = 1.6114235288020073, (598, 2) = 1.2733783905372, (599, 1) = 1.5977283947731353, (599, 2) = 1.2702805044646666, (600, 1) = 1.591489362, (600, 2) = 1.2657446870400284, (601, 1) = 1.5852977512180046, (601, 2) = 1.2651838945731189, (602, 1) = 1.5832236711199368, (602, 2) = 1.2621095552227115, (603, 1) = 1.5735673110698538, (603, 2) = 1.2597396104158076, (604, 1) = 1.568794326, (604, 2) = 1.2564429792756067, (605, 1) = 1.5599407443562279, (605, 2) = 1.2552368159480416, (606, 1) = 1.556026152778899, (606, 2) = 1.250840719908223, (607, 1) = 1.5495269984784494, (607, 2) = 1.2491387498041502, (608, 1) = 1.546099291, (608, 2) = 1.2468578812579338, (609, 1) = 1.535182178145666, (609, 2) = 1.2449925918737392, (610, 1) = 1.5295098125611863, (610, 2) = 1.2395718845937345, (611, 1) = 1.5255868482047577, (611, 2) = 1.2384881549454123, (612, 1) = 1.523404255, (612, 2) = 1.23707511358306, (613, 1) = 1.5107794318207515, (613, 2) = 1.2345716914417935, (614, 1) = 1.5034942567418703, (614, 2) = 1.228303049279246, (615, 1) = 1.501733951827784, (615, 2) = 1.227794236042835, (616, 1) = 1.50070922, (616, 2) = 1.2271440993390583, (617, 1) = 1.4866152102635843, (617, 2) = 1.224032355524897, (618, 1) = 1.478014184, (618, 2) = 1.217149211952106, (619, 1) = 1.4778022124114778, (619, 2) = 1.217139464867539, (620, 1) = 1.4777606373282246, (620, 2) = 1.2170342139647574, (621, 1) = 1.4626262403501513, (621, 2) = 1.2134060014921713, (622, 1) = 1.455319149, (622, 2) = 1.2078547697019821, (623, 1) = 1.4517950744326635, (623, 2) = 1.2075151981233596, (624, 1) = 1.4507046365167238, (624, 2) = 1.2057653786502691, (625, 1) = 1.4387756925124762, (625, 2) = 1.2027109161479812, (626, 1) = 1.432624113, (626, 2) = 1.1982123080436882, (627, 1) = 1.4267364807451404, (627, 2) = 1.1974199474315346, (628, 1) = 1.4244286978595704, (628, 2) = 1.1944965433357806, (629, 1) = 1.4150409545473424, (629, 2) = 1.191958327600048, (630, 1) = 1.409929078, (630, 2) = 1.1883239919873412, (631, 1) = 1.4022227595588657, (631, 2) = 1.1870541497768436, (632, 1) = 1.3987268310082337, (632, 2) = 1.183227708021292, (633, 1) = 1.3914076286686476, (633, 2) = 1.1811553843272589, (634, 1) = 1.387234042, (634, 2) = 1.1782493425217493, (635, 1) = 1.3780632919482505, (635, 2) = 1.1765124533487152, (636, 1) = 1.37347344499594, (636, 2) = 1.1719588727068035, (637, 1) = 1.367866355889432, (637, 2) = 1.170306733960648, (638, 1) = 1.364539007, (638, 2) = 1.1680248932702775, (639, 1) = 1.3541569256979031, (639, 2) = 1.165845084054061, (640, 1) = 1.348587928418191, (640, 2) = 1.160690037392315, (641, 1) = 1.3444110212265261, (641, 2) = 1.15941541256896, (642, 1) = 1.341843972, (642, 2) = 1.157673842442818, (643, 1) = 1.3304455297232454, (643, 2) = 1.1550809053212339, (644, 1) = 1.3240164906756169, (644, 2) = 1.1494212020778265, (645, 1) = 1.321037695711503, (645, 2) = 1.1484833704684132, (646, 1) = 1.319148936, (646, 2) = 1.147211174809095, (647, 1) = 1.3068938187415535, (647, 2) = 1.144237437711463, (648, 1) = 1.2997221959086767, (648, 2) = 1.138152366763338, (649, 1) = 1.2977439875556058, (649, 2) = 1.1375117961303092, (650, 1) = 1.296453901, (650, 2) = 1.1366465459173347, (651, 1) = 1.2834796131313542, (651, 2) = 1.13332569410127, (652, 1) = 1.2756791885562886, (652, 2) = 1.1268835314488497, (653, 1) = 1.2745286258483277, (653, 2) = 1.1265013197514835, (654, 1) = 1.273758865, (654, 2) = 1.1259859803155932, (655, 1) = 1.2601887540221648, (655, 2) = 1.1223527049459165, (656, 1) = 1.2518692036735433, (656, 2) = 1.1156146961343612, (657, 1) = 1.251391200200884, (657, 2) = 1.1154521460047564, (658, 1) = 1.25106383, (658, 2) = 1.1152329140746917, (659, 1) = 1.2370122765636609, (659, 2) = 1.1113229214240876, (660, 1) = 1.228368794, (660, 2) = 1.1044172956184994, (661, 1) = 1.2282561985478748, (661, 2) = 1.104401768184949, (662, 1) = 1.228219400830655, (662, 2) = 1.1043458608198726, (663, 1) = 1.213944773670436, (663, 2) = 1.100239028545551, (664, 1) = 1.205673759, (664, 2) = 1.0936890846262908, (665, 1) = 1.2047351883973787, (665, 2) = 1.093543056823949, (666, 1) = 1.2044019829083108, (666, 2) = 1.093077025505384, (667, 1) = 1.1909834145255507, (667, 2) = 1.0891024316539044, (668, 1) = 1.182978723, (668, 2) = 1.0827939352711333, (669, 1) = 1.1815001685111188, (669, 2) = 1.0825423413847006, (670, 1) = 1.1809446686984058, (670, 2) = 1.0818081901908956, (671, 1) = 1.168127360002674, (671, 2) = 1.0779135476816861, (672, 1) = 1.160283688, (672, 2) = 1.0717405842870162, (673, 1) = 1.1585137054744492, (673, 2) = 1.0714182096880918, (674, 1) = 1.1578230662035527, (674, 2) = 1.070539354876407, (675, 1) = 1.1453774186849566, (675, 2) = 1.066671974843357, (676, 1) = 1.137588652, (676, 2) = 1.0605322401402315, (677, 1) = 1.1357557424430424, (677, 2) = 1.0601806197641745, (678, 1) = 1.1350236496218176, (678, 2) = 1.0592705195619185, (679, 1) = 1.1227358774769616, (679, 2) = 1.0553765779218989, (680, 1) = 1.114893617, (680, 2) = 1.0491676138125858, (681, 1) = 1.1132184727687275, (681, 2) = 1.048833448712145, (682, 1) = 1.1125416881338954, (682, 2) = 1.04800168424743, (683, 1) = 1.100206453470804, (683, 2) = 1.04402551095152, (684, 1) = 1.092198581, (684, 2) = 1.0376413726323037, (685, 1) = 1.0909038821290058, (685, 2) = 1.0373757097330718, (686, 1) = 1.090380265059184, (686, 2) = 1.0367328489329415, (687, 1) = 1.0777943619131976, (687, 2) = 1.0326161846868382, (688, 1) = 1.069503546, (688, 2) = 1.0259441737705484, (689, 1) = 1.0688229794061808, (689, 2) = 1.0258019374359881, (690, 1) = 1.0685501256236416, (690, 2) = 1.0254640136184532, (691, 1) = 1.0555064881281093, (691, 2) = 1.0211451803659002, (692, 1) = 1.0469716898125523, (692, 2) = 1.0141951783039647, (693, 1) = 1.046880667327128, (693, 2) = 1.014159350301615, (694, 1) = 1.046808511, (694, 2) = 1.0141076478985103, (695, 1) = 1.033351687710956, (695, 2) = 1.0096081004231463, (696, 1) = 1.0252628814332816, (696, 2) = 1.0029263429894761, (697, 1) = 1.024624723220208, (697, 2) = 1.002672491354328, (698, 1) = 1.024113475, (698, 2) = 1.0023012116222338, (699, 1) = 1.011341245488748, (699, 2) = .9979993419555317, (700, 1) = 1.003792919952586, (700, 2) = .9916575076749876, (701, 1) = 1.0024800958736884, (701, 2) = .9911303604288496, (702, 1) = 1.00141844, (702, 2) = .990347988391207, (703, 1) = .9894895457449623, (703, 2) = .986311762539513, (704, 1) = .9825779362414616, (704, 2) = .9803886723604991, (705, 1) = .9804545632051322, (705, 2) = .9795290946102899, (706, 1) = .978723404, (706, 2) = .9782328345038035, (707, 1) = .9678150572724834, (707, 2) = .9745361918930388, (708, 1) = .9616387355042636, (708, 2) = .9691198370460106, (709, 1) = .9585575199877632, (709, 2) = .9678640299513497, (710, 1) = .956028369, (710, 2) = .9659370583298562, (711, 1) = .9463417771650928, (711, 2) = .9626607146637352, (712, 1) = .941002224424812, (712, 2) = .9578510017315222, (713, 1) = .9368004428570456, (713, 2) = .9561294671194472, (714, 1) = .933333333, (714, 2) = .9534372650958414, (715, 1) = .9251013980650025, (715, 2) = .9506695943104946, (716, 1) = .9207034744234053, (716, 2) = .9465821664170336, (717, 1) = .9151975492932625, (717, 2) = .9443183473931307, (718, 1) = .910638298, (718, 2) = .9407036914489233, (719, 1) = .9041366284069559, (719, 2) = .9385416248982998, (720, 1) = .9007887465811769, (720, 2) = .9353133311025451, (721, 1) = .8937667213815514, (721, 2) = .9324217910877455, (722, 1) = .887943262, (722, 2) = .9276977273948364, (723, 1) = .8835064475130456, (723, 2) = .9262475208891162, (724, 1) = .8813200377593083, (724, 2) = .9240444957880567, (725, 1) = .872530851370964, (725, 2) = .9204284319796654, (726, 1) = .865248227, (726, 2) = .9143681576975791, (727, 1) = .8632947276134568, (727, 2) = .9137456374709129, (728, 1) = .8623820935872071, (728, 2) = .9127756604735682, (729, 1) = .8515198241829798, (729, 2) = .9083234308025323, (730, 1) = .8435593410143423, (730, 2) = .9015068251590796, (731, 1) = .8430406342641067, (731, 2) = .9012647934712527, (732, 1) = .842553191, (732, 2) = .9008800413174176, (733, 1) = .8307735404071025, (733, 2) = .8960869758714283, (734, 1) = .824161567316569, (734, 2) = .8902379898445911, (735, 1) = .8219446059841776, (735, 2) = .8892019984366195, (736, 1) = .819858156, (736, 2) = .8875166371377279, (737, 1) = .8103466528515819, (737, 2) = .8836919301437991, (738, 1) = .8052044964684764, (738, 2) = .8789691545301026, (739, 1) = .8010605790389254, (739, 2) = .8770339373286575, (740, 1) = .79716312, (740, 2) = .8738049769674676, (741, 1) = .7903162855600842, (741, 2) = .8710999989133532, (742, 1) = .7867747520617678, (742, 2) = .8677003192156142, (743, 1) = .7804227859648487, (743, 2) = .8647436132876478, (744, 1) = .774468085, (744, 2) = .8596696922142488, (745, 1) = .7707951619749766, (745, 2) = .8582552116324018, (746, 1) = .7689940269302069, (746, 2) = .8564314839011257, (747, 1) = .7600774016030144, (747, 2) = .8523080987374554, (748, 1) = .7519527489292017, (748, 2) = .8451626485866371, (749, 1) = .7518646185972762, (749, 2) = .8451171817502704, (750, 1) = .75177305, (750, 2) = .8450411094820066, (751, 1) = .7400884619646595, (751, 2) = .8396955973401667, (752, 1) = .7337266241375471, (752, 2) = .8338938132721487, (753, 1) = .7314452912520957, (753, 2) = .8327183818915772, (754, 1) = .729078014, (754, 2) = .8306998773869667, (755, 1) = .7205476834143061, (755, 2) = .8268605691584815, (756, 1) = .7160965967789579, (756, 2) = .8226249779576602, (757, 1) = .7113196666467616, (757, 2) = .8201737493038852, (758, 1) = .706382979, (758, 2) = .8158408836828417, (759, 1) = .7015915470181767, (759, 2) = .8137352469514327, (760, 1) = .6992163473253025, (760, 2) = .8113561426431717, (761, 1) = .6915501515422662, (761, 2) = .8074522963011362, (762, 1) = .683687943, (762, 2) = .800322300445485, (763, 1) = .6834328093218127, (763, 2) = .8002139896361866, (764, 1) = .6833141825718329, (764, 2) = .8000873073286832, (765, 1) = .6722257026275095, (765, 2) = .7945098533710719, (766, 1) = .666182705462009, (766, 2) = .7888184720141946, (767, 1) = .6637428267323536, (767, 2) = .7874530464344094, (768, 1) = .660992908, (768, 2) = .7849913591902167, (769, 1) = .6534779375152647, (769, 2) = .7812810678719556, (770, 1) = .6496899776995608, (770, 2) = .7775496366997062, (771, 1) = .644316197262157, (771, 2) = .7745613393359887, (772, 1) = .638297872, (772, 2) = .7690036825296057, (773, 1) = .6355105844731543, (773, 2) = .7676647818071096, (774, 1) = .6341811182836439, (774, 2) = .7662808013852177, (775, 1) = .6253678043596442, (775, 2) = .7614321722014694, (776, 1) = .6186597067307184, (776, 2) = .7550119660707292, (777, 1) = .617281122104175, (777, 2) = .7541786420221122, (778, 1) = .615602837, (778, 2) = .7526252261613862, (779, 1) = .6070424655191824, (779, 2) = .7479936380675389, (780, 1) = .6027854174144771, (780, 2) = .7437431307562408, (781, 1) = .5983155896662373, (781, 2) = .7410579849871226, (782, 1) = .592907801, (782, 2) = .735896923526492, (783, 1) = .5895661050331924, (783, 2) = .734133557986227, (784, 1) = .5879883836302603, (784, 2) = .7324742954417522, (785, 1) = .5798972654713295, (785, 2) = .727665621225314, (786, 1) = .5733631050453268, (786, 2) = .7212054601272637, (787, 1) = .5719975592427472, (787, 2) = .7203192512660335, (788, 1) = .570212766, (788, 2) = .7185943042812164, (789, 1) = .5622031022959202, (789, 2) = .7139136875151968, (790, 1) = .5583459588718417, (790, 2) = .7099366248127752, (791, 1) = .5536334231886916, (791, 2) = .706899981056083, (792, 1) = .54751773, (792, 2) = .7008031525536433, (793, 1) = .5455148251633234, (793, 2) = .6996622979780093, (794, 1) = .544599187815543, (794, 2) = .6986677894982867, (795, 1) = .535933525051012, (795, 2) = .6931508949858032, (796, 1) = .5303684517932757, (796, 2) = .6873989541837983, (797, 1) = .52805483028933, (797, 2) = .6857940921384387, (798, 1) = .524822695, (798, 2) = .6825065836185034, (799, 1) = .5191355881287295, (799, 2) = .6789539554815134, (800, 1) = .5165200495468957, (800, 2) = .6761301188693097, (801, 1) = .5104838489595868, (801, 2) = .6719809947440405, (802, 1) = .5037065227716431, (802, 2) = .6648612835548212, (803, 1) = .5030744531999831, (803, 2) = .6643911694242421, (804, 1) = .50212766, (804, 2) = .6634002967289644, (805, 1) = .4937713816599637, (805, 2) = .6577416165631279, (806, 1) = .489970177749674, (806, 2) = .6535924482403328, (807, 1) = .4857333287063996, (807, 2) = .6504639401515313, (808, 1) = .479432624, (808, 2) = .6436714424848429, (809, 1) = .47826883617953786, (809, 2) = .6429014720606636, (810, 1) = .4777639778703708, (810, 2) = .6423236129258443, (811, 1) = .4692466374415245, (811, 2) = .6361124567487995, (812, 1) = .464715306341125, (812, 2) = .6310547776113558, (813, 1) = .46163883876106837, (813, 2) = .6286211450396212, (814, 1) = .456737589, (814, 2) = .6231592809571775, (815, 1) = .4539529959553716, (815, 2) = .6211685847583196, (816, 1) = .4527657375910921, (816, 2) = .6197859422968672, (817, 1) = .4454962033438965, (817, 2) = .6140988264238145, (818, 1) = .4406460830564382, (818, 2) = .6085171069823787, (819, 1) = .4382044492892413, (819, 2) = .6064505879480206, (820, 1) = .434042553, (820, 2) = .6016280155205744, (821, 1) = .43058012587184086, (821, 2) = .5989674812260884, (822, 1) = .4291434387800115, (822, 2) = .5972482716678903, (823, 1) = .42251993124854825, (823, 2) = .5917007990615119, (824, 1) = .417729738557723, (824, 2) = .5859794363534018, (825, 1) = .4154691584594022, (825, 2) = .5839329055786073, (826, 1) = .411347518, (826, 2) = .5789416642431693, (827, 1) = .4081417790662047, (827, 2) = .5763023563507877, (828, 1) = .40685698843391654, (828, 2) = .5747106010389132, (829, 1) = .40036501676645064, (829, 2) = .5688949404954204, (830, 1) = .3959898721858044, (830, 2) = .5634417657244248, (831, 1) = .3935035629996389, (831, 2) = .5610330437077612, (832, 1) = .388652482, (832, 2) = .5548656285662611, (833, 1) = .38669706522960096, (833, 2) = .5531438594945055, (834, 1) = .3859447608542921, (834, 2) = .5521729304099363, (835, 1) = .3791216358385784, (835, 2) = .5456364753627964, (836, 1) = .3755007197217316, (836, 2) = .5409040950954478, (837, 1) = .3724122424075985, (837, 2) = .5376990757404679, (838, 1) = .3663962141704621, (838, 2) = .5296352597809593, (839, 1) = .36626167748141636, (839, 2) = .5294841992872112, (840, 1) = .365957447, (840, 2) = .5290618718536209, (841, 1) = .3589270866689951, (841, 2) = .5218572306838131, (842, 1) = .3563911119386598, (842, 2) = .5183664244664707, (843, 1) = .3523411921307881, (843, 2) = .5138585096335031, (844, 1) = .3475763410686044, (844, 2) = .5070975891519823, (845, 1) = .3463204241960937, (845, 2) = .5055791845503632, (846, 1) = .343262411, (846, 2) = .5010627462948964, (847, 1) = .33997776672414115, (847, 2) = .4974596883309339, (848, 1) = .33885747758585916, (848, 2) = .4958287538374938, (849, 1) = .3334912752620174, (849, 2) = .48941161051056287, (850, 1) = .3302739327739975, (850, 2) = .4845599185230053, (851, 1) = .3275988903688647, (851, 2) = .48106853913389236, (852, 1) = .3226691295610866, (852, 2) = .4732910832085168, (853, 1) = .32212726070647435, (853, 2) = .4725165488724011, (854, 1) = .320567376, (854, 2) = .4699180992686062, (855, 1) = .31614031244913365, (855, 2) = .46422043123603707, (856, 1) = .3147740262555149, (856, 2) = .46202224789402835, (857, 1) = .31037894460051624, (857, 2) = .4558123054384781, (858, 1) = .307389166307087, (858, 2) = .4507534125795398, (859, 1) = .3050899005797395, (859, 2) = .4471696552528086, (860, 1) = .30081425435924125, (860, 2) = .4394845772650513, (861, 1) = .30015877253252304, (861, 2) = .43834928795920086, (862, 1) = .29787234, (862, 2) = .4339385683324954, (863, 1) = .29505396768163317, (863, 2) = .42961515699929875, (864, 1) = .294285937099235, (864, 2) = .42821574195056283, (865, 1) = .289979927222794, (865, 2) = .42086575055150777, (866, 1) = .2879683364055482, (866, 2) = .41694690663607437, (867, 1) = .28533723716042286, (867, 2) = .4119021643687819, (868, 1) = .2823839169547458, (868, 2) = .40567807132158584, (869, 1) = .28104810655639656, (869, 2) = .4027630242241447, (870, 1) = .2774323557066915, (870, 2) = .3944092360070973, (871, 1) = .2770622923605276, (871, 2) = .3934732774533573, (872, 1) = .275177305, (872, 2) = .3886224330081677, (873, 1) = .2730954300675954, (873, 2) = .3841741203905476, (874, 1) = .27264884815752155, (874, 2) = .38314040069260885, (875, 1) = .2692775766418348, (875, 2) = .37480097546005986, (876, 1) = .2681361937041559, (876, 2) = .3718715653781204, (877, 1) = .2658707131845269, (877, 2) = .3652237604293794, (878, 1) = .26427830458809737, (878, 2) = .36060273006363186, (879, 1) = .2628512923995288, (879, 2) = .3554541673091437, (880, 1) = .26103307650502455, (880, 2) = .34933389474914334, (881, 1) = .2602151085591518, (881, 2) = .3454942843821255, (882, 1) = .2583790599040295, (882, 2) = .33806505943465487, (883, 1) = .25797522734388845, (883, 2) = .3353376241062146, (884, 1) = .2563115818027797, (884, 2) = .3267962241201664, (885, 1) = .2561618533134669, (885, 2) = .3249691889194188, (886, 1) = .2548406555023418, (886, 2) = .3155273888056779, (887, 1) = .25482390795524557, (887, 2) = .31436468768669074, (888, 1) = .25399017830173903, (888, 2) = .30425855349118935, (889, 1) = .2540324198560064, (889, 2) = .30348885236760664, (890, 1) = .25379816516955517, (890, 2) = .2929897181767009, (891, 1) = .25388614843317464, (891, 2) = .2922926456479839, (892, 1) = .2543179291865148, (892, 2) = .2817208828622124, (893, 1) = .2545202670965599, (893, 2) = .2807089494631478, (894, 1) = .25562024450908266, (894, 2) = .2704520475477239, (895, 1) = .2561195389902087, (895, 2) = .2686460228067192, (896, 1) = .25779664402511665, (896, 2) = .25918321223323537, (897, 1) = .2589384240841701, (897, 2) = .25597751789512946, (898, 1) = .2609641349060644, (898, 2) = .2479143769187469, (899, 1) = .2633323283168315, (899, 2) = .24252696393584589, (900, 1) = .2652717850399755, (900, 2) = .2366455416042584, (901, 1) = .2698074896127803, (901, 2) = .2280429970710573, (902, 1) = .2709098736536363, (902, 2) = .2253767062897699, (903, 1) = .275177305, (903, 2) = .21849223799674822, (904, 1) = .2778464974250662, (904, 2) = .21410787097528142, (905, 1) = .27969197264738493, (905, 2) = .21186618920576533, (906, 1) = .2861175105459548, (906, 2) = .20283903566079292, (907, 1) = .29557280277763687, (907, 2) = .19271199661400557, (908, 1) = .2965132418244677, (908, 2) = .19157020034630443, (909, 1) = .29787234, (909, 2) = .19027905700641645, (910, 1) = .30858640456460823, (910, 2) = .18030136503181593, (911, 1) = .320567376, (911, 2) = .17111823894060285, (912, 1) = .3233936000500718, (912, 2) = .16903252971732743, (913, 1) = .33380849941301693, (913, 2) = .16245787411005008, (914, 1) = .3409728683902534, (914, 2) = .15776369440283894, (915, 1) = .343262411, (915, 2) = .15646098085156843, (916, 1) = .3619927797719418, (916, 2) = .14649485908835044, (917, 1) = .365957447, (917, 2) = .14460769739479326, (918, 1) = .3874307105314091, (918, 2) = .13522602377386195, (919, 1) = .388652482, (919, 2) = .13473597397431222, (920, 1) = .39226720244125857, (920, 2) = .13343119562904393, (921, 1) = .411347518, (921, 2) = .12624265343184352, (922, 1) = .41811489199958696, (922, 2) = .12395718845937345, (923, 1) = .434042553, (923, 2) = .11885568254370679, (924, 1) = .4559813235346288, (924, 2) = .11268835314488496, (925, 1) = .456737589, (925, 2) = .11248239911879865, (926, 1) = .4575201089288594, (926, 2) = .11229980612530018, (927, 1) = .479432624, (927, 2) = .1066280385612409, (928, 1) = .5014414507040604, (928, 2) = .10176024342110335, (929, 1) = .50212766, (929, 2) = .10159101181183777, (930, 1) = .5029434695501065, (930, 2) = .10141951783039646, (931, 1) = .524822695, (931, 2) = 0.9681559006866516e-1, (932, 1) = .5391167970429902, (932, 2) = 0.9432202351540864e-1, (933, 1) = .54751773, (933, 2) = 0.9262954125105491e-1, (934, 1) = .5623896654389151, (934, 2) = 0.9015068251590796e-1, (935, 1) = .570212766, (935, 2) = 0.8881116477846362e-1, (936, 1) = .5739378011018723, (936, 2) = 0.8830107941533168e-1, (937, 1) = .592907801, (937, 2) = 0.8517908727642112e-1, (938, 1) = .6065234070985486, (938, 2) = 0.8339008417045964e-1, (939, 1) = .615602837, (939, 2) = 0.8195170401453632e-1, (940, 1) = .6377472939243674, (940, 2) = 0.7915522742145756e-1, (941, 1) = .638297872, (941, 2) = 0.7907114751868707e-1, (942, 1) = .6398551881381657, (942, 2) = 0.7888184720141947e-1, (943, 1) = .660992908, (943, 2) = 0.7615081338848337e-1, (944, 1) = .6678543575310062, (944, 2) = 0.7547491062768943e-1, (945, 1) = .683687943, (945, 2) = 0.7349743216996951e-1, (946, 1) = .6971010217171747, (946, 2) = 0.7222181039318912e-1, (947, 1) = .706382979, (947, 2) = 0.7110000069881608e-1, (948, 1) = .7256160612386486, (948, 2) = 0.6933198590632368e-1, (949, 1) = .729078014, (949, 2) = 0.6892666337010679e-1, (950, 1) = .7438457920210871, (950, 2) = 0.6761301188693097e-1, (951, 1) = .75177305, (951, 2) = 0.6683611594160696e-1, (952, 1) = .7535956737769458, (952, 2) = 0.6670801891456182e-1, (953, 1) = .774468085, (953, 2) = 0.6472232728390571e-1, (954, 1) = .7812161402183493, (954, 2) = 0.6426237933894627e-1, (955, 1) = .79716312, (955, 2) = 0.6278840801049185e-1, (956, 1) = .8083734758911341, (956, 2) = 0.6204669974915798e-1, (957, 1) = .819858156, (957, 2) = 0.61014527603463105e-1, (958, 1) = .8351234529856626, (958, 2) = 0.6003328716924762e-1, (959, 1) = .842553191, (959, 2) = 0.5938351448292965e-1, (960, 1) = .8615137136585047, (960, 2) = 0.5819848585069487e-1, (961, 1) = .865248227, (961, 2) = 0.5788043897352475e-1, (962, 1) = .8875851496102942, (962, 2) = 0.56521991215322386e-1, (963, 1) = .887943262, (963, 2) = 0.5649227155600638e-1, (964, 1) = .8904439795715496, (964, 2) = 0.5634417657244248e-1, (965, 1) = .910638298, (965, 2) = 0.54962588520101656e-1, (966, 1) = .9136977197381818, (966, 2) = 0.5482507251619682e-1, (967, 1) = .933333333, (967, 2) = 0.5351421503996071e-1, (968, 1) = .9395846234589216, (968, 2) = 0.5324020429037071e-1, (969, 1) = .956028369, (969, 2) = 0.5216836985843239e-1, (970, 1) = .9652310042470181, (970, 2) = 0.5177476387676015e-1, (971, 1) = .978723404, (971, 2) = 0.5091560288418856e-1, (972, 1) = .9906602774552977, (972, 2) = 0.50417124456832746e-1, (973, 1) = 1.00141844, (973, 2) = 0.4974752787485673e-1, (974, 1) = 1.0158930833000845, (974, 2) = 0.4915703755350652e-1, (975, 1) = 1.024113475, (975, 2) = 0.486566822866521e-1, (976, 1) = 1.0409476715389645, (976, 2) = 0.4798544171741422e-1, (977, 1) = 1.046808511, (977, 2) = 0.4763640747098328e-1, (978, 1) = 1.0658402247947085, (978, 2) = 0.46894301368238155e-1, (979, 1) = 1.069503546, (979, 2) = 0.4668074729649577e-1, (980, 1) = 1.0905851349246953, (980, 2) = 0.45876470584761075e-1, (981, 1) = 1.092198581, (981, 2) = 0.4578436077646242e-1, (982, 1) = 1.1111848351566838, (982, 2) = 0.4507534125795398e-1, (983, 1) = 1.114893617, (983, 2) = 0.44905083699391446e-1, (984, 1) = 1.1152557450908316, (984, 2) = 0.4489553268668139e-1, (985, 1) = 1.137588652, (985, 2) = 0.4389062649757895e-1, (986, 1) = 1.1401056154633649, (986, 2) = 0.43825585727218376e-1, (987, 1) = 1.160283688, (987, 2) = 0.4293528705052992e-1, (988, 1) = 1.1648253542113527, (988, 2) = 0.42820253808689875e-1, (989, 1) = 1.182978723, (989, 2) = 0.4203456036548975e-1, (990, 1) = 1.1894251905376998, (990, 2) = 0.4187445710678828e-1, (991, 1) = 1.205673759, (991, 2) = 0.41184362359967745e-1, (992, 1) = 1.213914371652364, (992, 2) = 0.4098360459088213e-1, (993, 1) = 1.228368794, (993, 2) = 0.4038098382202394e-1, (994, 1) = 1.238301269657351, (994, 2) = 0.4014353888285073e-1, (995, 1) = 1.25106383, (995, 2) = 0.396210495985887e-1, (996, 1) = 1.262593481833544, (996, 2) = 0.3935048788162744e-1, (997, 1) = 1.273758865, (997, 2) = 0.38901483387146205e-1, (998, 1) = 1.2867979134456726, (998, 2) = 0.38601022839075017e-1, (999, 1) = 1.296453901, (999, 2) = 0.3821947629577932e-1, (1000, 1) = 1.3109208525076754, (1000, 2) = 0.3789202146828696e-1, (1001, 1) = 1.319148936, (1001, 2) = 0.3757245965586278e-1, (1002, 1) = 1.3349680353162894, (1002, 2) = 0.3722063571711219e-1, (1003, 1) = 1.341843972, (1003, 2) = 0.3695808056802551e-1, (1004, 1) = 1.3589447019797398, (1004, 2) = 0.3658426336804438e-1, (1005, 1) = 1.364539007, (1005, 2) = 0.36374180719152605e-1, (1006, 1) = 1.3828556486315, (1006, 2) = 0.3598052302745218e-1, (1007, 1) = 1.387234042, (1007, 2) = 0.35818777214814704e-1, (1008, 1) = 1.4067052723260158, (1008, 2) = 0.3540723198884571e-1, (1009, 1) = 1.409929078, (1009, 2) = 0.35290045816892116e-1, (1010, 1) = 1.4304976064159975, (1010, 2) = 0.3486238677776684e-1, (1011, 1) = 1.432624113, (1011, 2) = 0.3478630601600474e-1, (1012, 1) = 1.4542363615894265, (1012, 2) = 0.3434414567271531e-1, (1013, 1) = 1.455319149, (1013, 2) = 0.34306007506436205e-1, (1014, 1) = 1.4779249503290275, (1014, 2) = 0.3385081341171557e-1, (1015, 1) = 1.478014184, (1015, 2) = 0.3384771842762714e-1, (1016, 1) = 1.4800931491524252, (1016, 2) = 0.3380650594346549e-1, (1017, 1) = 1.50070922, (1017, 2) = 0.3325265234339798e-1, (1018, 1) = 1.5018525865546575, (1018, 2) = 0.3323878664237044e-1, (1019, 1) = 1.523404255, (1019, 2) = 0.3266837051208909e-1, (1020, 1) = 1.525752919786807, (1020, 2) = 0.3264031626694473e-1, (1021, 1) = 1.546099291, (1021, 2) = 0.3210965806346259e-1, (1022, 1) = 1.5495996408671964, (1022, 2) = 0.32068466491377026e-1, (1023, 1) = 1.568794326, (1023, 2) = 0.3157504464467998e-1, (1024, 1) = 1.5733958752845758, (1024, 2) = 0.3152168466891944e-1, (1025, 1) = 1.591489362, (1025, 2) = 0.3106316400094851e-1, (1026, 1) = 1.5971445269232973, (1026, 2) = 0.3099852956462712e-1, (1027, 1) = 1.614184397, (1027, 2) = 0.3057274542830451e-1, (1028, 1) = 1.6208482913503865, (1028, 2) = 0.3049766204929845e-1, (1029, 1) = 1.636879432, (1029, 2) = 0.30102605719973394e-1, (1030, 1) = 1.6445096785138358, (1030, 2) = 0.30017836413557424e-1, (1031, 1) = 1.659574468, (1031, 2) = 0.29651642095914425e-1, (1032, 1) = 1.668131024462252, (1032, 2) = 0.2955789272774493e-1, (1033, 1) = 1.682269503, (1033, 2) = 0.2921882578676087e-1, (1034, 1) = 1.6917145059595593, (1034, 2) = 0.29116749870986426e-1, (1035, 1) = 1.704964539, (1035, 2) = 0.28803196024584036e-1, (1036, 1) = 1.7152621549515952, (1036, 2) = 0.2869339912118584e-1, (1037, 1) = 1.727659574, (1037, 2) = 0.28403854860399393e-1, (1038, 1) = 1.7387758682999586, (1038, 2) = 0.28286898493906074e-1, (1039, 1) = 1.75035461, (1039, 2) = 0.28019962163713615e-1, (1040, 1) = 1.7622574194972205, (1040, 2) = 0.27896367448243663e-1, (1041, 1) = 1.773049645, (1041, 2) = 0.27650731342177423e-1, (1042, 1) = 1.7857084676476207, (1042, 2) = 0.2752098219759625e-1, (1043, 1) = 1.795744681, (1043, 2) = 0.2729542517380107e-1, (1044, 1) = 1.8091305661825445, (1044, 2) = 0.2715997133090622e-1, (1045, 1) = 1.818439716, (1045, 2) = 0.26953352255320633e-1, (1046, 1) = 1.8325251713760276, (1046, 2) = 0.26812611905930955e-1, (1047, 1) = 1.841134752, (1047, 2) = 0.2662386351086802e-1, (1048, 1) = 1.85589364849777, (1048, 2) = 0.2647822581272541e-1, (1049, 1) = 1.863829787, (1049, 2) = 0.26306349232121655e-1, (1050, 1) = 1.8792372800794723, (1050, 2) = 0.26156176500423615e-1, (1051, 1) = 1.886524823, (1051, 2) = 0.26000236139530727e-1, (1052, 1) = 1.9025572698611664, (1052, 2) = 0.25845865945916494e-1, (1053, 1) = 1.909219858, (1053, 2) = 0.2570498490549631e-1, (1054, 1) = 1.925854750222718, (1054, 2) = 0.25546731903369348e-1, (1055, 1) = 1.931914893, (1055, 2) = 0.25420087681626943e-1, (1056, 1) = 1.9491307877003698, (1056, 2) = 0.25258245338369206e-1, (1057, 1) = 1.954609929, (1057, 2) = 0.25145065956422477e-1, (1058, 1) = 1.9723863841858487, (1058, 2) = 0.24979908145105163e-1, (1059, 1) = 1.977304964, (1059, 2) = 0.2487946857940225e-1, (1060, 1) = 1.995622486030146, (1060, 2) = 0.24711250966684323e-1, (1061, 1) = 2.0, (1061, 2) = 0.2462286982602636e-1, (1062, 1) = .0, (1062, 2) = .0, (1063, 1) = .0, (1063, 2) = .0, (1064, 1) = .0, (1064, 2) = .0}, datatype = float[8], order = C_order))]), COLOUR(RGB, 1.00000000, 0., 0.)), THICKNESS(2), AXESSTYLE(BOX), AXESTICKS(9, 12, FONT(SYMBOL, 14)), AXESLABELS(sigma, A, FONT(SYMBOL, 16))), textplot([-.5, 1, typeset("Peak ")]), textplot([-.5, 1.2, typeset("Lower ")])}, view = [-1.2 .. 2, 0 .. 2])
Download textplot_problem.mw
e some word inside the figure. Please help me
First 795 796 797 798 799 800 801 Last Page 797 of 2433
