This is my first question here!
I want to show weird things that can happen in numerical analysis. The example I use is the sum from i=1 to infinity of (1/i) (the harmonic series). In theory this series diverge but in practice it could converge.
I would want all the calculations to use floating point arithmetic with small mantissa (for instance m=1,2,3)). But the problem is I don't know how to fix mantissa in maple... I have the following fonction:
g := n -> evalf[m](sum(evalf[m](1/i),i=1..m))
but evalf just show significant digit without changing the mantissa....
I hope my question is clear! Thanks for your help!
Hi, I a have a question, if you can help me I would be pleased
Here is a problem:
for i from 1 to 4 do
 if A[i,i]=0 then break
  for l from i to 4 do
   A[i,l]=A[i,l]/A[i,i]:
   b[i,1]=b[i,1]/A[i,i]
  for j from i+1 to 4
   for k from i to 4 do
    A[j,k]=A[j,k]-A[j,i]*A[i,k]
   b[j,1]=b[j,1]-A[j,i]*b[i,1]
 fi:
I definited matrix A and b, but this for loop doesn't work.
Thank you for your help.
I worked on a document about 2 hours ago. And now when I try to open it, it is empty. I saved it in MapleCloud, and I have had it saved before. So today I opnened the saved file from MapleCloud, but now it is gone. How can I get it back!!? It happend to two of my most important files..
I found some strange behavior while usings tensors from Physics; I wanted to make sure I wasn't missing something here.
It seems that changing the metric (for instance, to +++-) causes raising and lowering problems. As an example:
with(Physics):
Setup(metric=`+++-`):
# Define our system of equations
Coordinates(X):
# Define tensors
{U[~mu] = [u(X),0,0,1],
A[~mu]=[0,0,0,n(X)]}:
Define(op(%)):
F[mu,nu]=d_[mu](A[nu]) - d_[nu](A[mu]):
Define(%):
# Multiply tensors
TensorArray(F[~0,~mu].U[mu]);
This produces
-diff(n(X),x1)*u(X)-2*diff(n(X),x4)
However, only the first term should be present. It seems that changing the mulitplication to F[0,~mu].U[mu] produces the correct output, as does removing the Setup call. Also, manually defining F produces the expected output; only defining it via A seems to generate the discrepancy.
Any idea if this is a bug or a feature?
I have a worksheet that illustrates a problem I have, How do I make this worksheet available on Mapleprimes?
PDE := diff(u(x, y), x, x)+diff(u(x, y), y, y)-6*x*y*(1-y)-2*x^3 = 0; BCsx := u(xL, y) = 0, u(xU, y) = y*(1-y); BCsy := u(x, yL) = 0, u(x, yU) = 0; solPDE := pdsolve({BCsx, BCsy, PDE}, u(x, y)); exactSol := unapply(rhs(%), x, y)
how i can write these boundary conditions for dsolve?
(diff(u(r), r))^(n-1)*(diff(r*(diff(u(r), r)), r))/r    be [finite] at r =0
and  u(0) = finite?
Thanks..
I can't seem to figure out how to use the Physics package within a procedure. In particular, I can't get tensors to be recognized within the body of the proc.
As an example, here's a short program that works correctly when not in a procedure:
with(Physics):
Coordinates(X,quiet):
d_[mu](X[~mu]);
# Returns 4; Correct
However, placing this code inside a proc causes the tensor X to not be recognized as a tensor:
Test := proc()
  uses Physics:
  d_[mu](X[~mu]);
Test();
# Returns 0; Wrong
Apparently, Physics:-Coordinates still defines the tensor X (as can be checked by calling Physics:-Define()). However, the derivative d_[mu] (X[~mu]) seems to be treating X as a standard symbol. Any idea how I would go about correcting this?
I have a procedure which works. ⊕(a,b) gives annwer.   a ⊕ b also gives answer. That was a surprise, discovered from a typing mistake. If b is negative is needs to be enclosed in delay evulation quotes.
2  questions
Can anyoone expllain this useful property? Any way around having to use delay evaluation quotes for negative numbers?
`⊕` := proc (a, b) (a+b)/(1-a*b) end proc
`⊕`(1, 2)
-3
`⊕`(1, 2)
-3
`⊕`(`⊕`(`⊕`(1, 2), '-5'), 4)
-32/9
`⊕`(1, 1/2)
`⊕`(1/2, '-1')
-1/3
`⊕`(0, h)
h
`⊕`(h, 0)
h
`⊕`(1/h, '-h')
(1/2)/h-(1/2)*h
`⊕`(1/h, -h)
(1/2)/h-(1/2)*h
-`⊕`(h, 1/h^2)
-(h+1/h^2)/(1-1/h)
(-h^3-1)/(h*(h-1))
Download Circle_Sum.mw
please, help me understand why the procedure does not see a variable.
If you do this, then everything works:
F := 8*y^2*(3*R^2+2*y^2)/r^4;
G := 24*R^2*y^4/r^6;
sigma := simplify(subs(r = sqrt(x^2+y^2), (1-k[1]+k[2])*R^2*(3-(3*R^2+18*y^2)/r^2+F-G)/(2*r^2)+k[2]*R^2*(1-2*y^2/r^2)/r^2)):
k[1] := E[2]*((3-nu[2])*E[1]+(5+nu[1])*E[2])/((E[1]+2*E[2])^2-(nu[2]*E[1]+(1-nu[1])*E[2])^2);
k[2] := E[2]*((3*nu[2]-1)*E[1]+(1-3*nu[1])*E[2])/((E[1]+2*E[2])^2-(nu[2]*E[1]+(1-nu[1])*E[2])^2);
nu[1] := 1/3; nu[2] := 1/3;
s := simplify(sigma);
si := proc (x, y) if R <= x^2+y^2 then -(3/2)*R^2*(-(1/3)*y^6+(R^2+(11/3)*x^2)*y^4+(-6*R^2*x^2+3*x^4)*y^2+R^2*x^4-x^6)*(E[1]-E[2])/((x^2+y^2)^4*(E[1]+2*E[2])) else E[2]*((3*nu[2]-1)*E[1]+(1-3*nu[1])*E[2])/((E[1]+2*E[2])^2-(nu[2]*E[1]+(1-nu[1])*E[2])^2) end if end proc:
R := 1; M := 5;
E[2] := (1/10)*E[1];
plot3d(si, -M .. M, -M .. M, axes = frame);
and we get a beautiful plot:
If inside the procedure after 'then' I try to enter the variable s, then the procedure does not see it .... global, local, return (s), value(s), inside the procedure or outside, Ive tried everything .... help plzl!
si := proc (x, y) if R <= x^2+y^2 then s else E[2]*((3*nu[2]-1)*E[1]+(1-3*nu[1])*E[2])/((E[1]+2*E[2])^2-(nu[2]*E[1]+(1-nu[1])*E[2])^2) end if end proc:
R := 1; M := 5
As the title states, i would like to have collection of the "last stored output and input" datatable that is globally stored ie happens whenever an exception occurs in a maple worksheet i am working on.
For example, suppose the following execution causes a fatal exception and the interface tells me to save and exit the worksheet then reopen it:
ExchangeRATE(MaplePrimes-Reputation-Points, Stack-Exchange-Reputation-Points)
Download MAPLE_HELPY.mw
I would like the data [ExchangeRate, [MaplePrimes-Reputation-Points, Stack-Exchange-Reputation-Points]] to be automatically stored in a csv or excel spreadsheet or even a .txt file will be fine
Basically i need incorparate a bit of code that tells maple to "give up" once the amount of computation time has reached a certain amount, because when i started using maple i got into this habit of just waiting for the output no matter what, and it has taken me a bit of time to realize that sane people are not happy to leave a dozen worksheets evaluating executions overnight while they sleep, and also this of course is related to the habits formed that result in my code often being sluggish.
I am guessing that i would just enclose the code intended to be executed in a "while" loop of some sort and will probably work out how to do it on my own, but i think because of the importance of this particular "behavioral habit" in the development of people younger than me using maple, i should post a question about it.
I am wondering if it is possible to judge whether a given function which has parameters ( like dimension) is integrable in a given interval. Thanks very much.
On the maple cloud, I see that current version is 38 for Physics
After I installed, I typed
It gives
  "......\maple\toolbox\2018\Physics Updates\lib\Physics Updates.maple", 2018, May 8, 17:49 hours
I was expecting to see "38".  Why does Physics:-Version(); does not give the version number as shown on Maple cloud? Using only a date for a version number is not a good idea. There should be a number there. (date can also be included, but a number should be the official version number).
Is there another command to use to obtain Version number "38"?
Does each package shown on cloud support packageName:-Version()? I tried this command on another package I have, but I got an error saying it does not Version()
OrthogonalExpansions:-Version();
Error, Version is not a command in the OrthogonalExpansions package
Yet, on cloud, it says the version number is "1" for the above package. What does the version number shown on the cloud then really mean?
How does one copy a drawing, and insert it in a different worksheet?  The fact is every time I attempt to copy a drawing, the computer beeps.
Thank You
First 832 833 834 835 836 837 838 Last Page 834 of 2434
