I am facing a problem, I have a system of nonlinear inequalities that has solutions for the sake of the example:
xy-1<0, x>0, y >= 1
Here we can just say that for any 1>x>0, the y for which it is satisfied are 1/x > y >=1, and in that sense it gives a depiction of the set of all (x,y) that satisfies the system. But I would rather like to know one particular solution say x=1/2, y=1 for example. Is there a way to generate a particular solution of such a system without having to write a procedure that tests all x,y with three digits after the comma within a given range?
f:=(x,y)->(e)^(-0.96374054* x) (sin(2 *Pi *y) )/(2 *Pi)((-0.96374054)^(2)-4* Pi^(2)) on [-0.5,1.5]2
I occasionally need single left quotes placed around the value of number.
Let's say x=3. Is there a command on x that will make x=`3`?
mapleatha
Let x = `3`. How do we get the number 3 out of x?
mapleatha
Here's something neat to be done in Maple.
This anaglyph or stereo image uses the red green glasses to make the model appear more 3 dimensional.  The static-non-stereo image of the animated plot below is done in maple by plot3d(sin(x*y)^2,x=-2..2,y=-2..2,scaling=constrained)
Anyone?
Why is this happening?
mapleatha
I have modeled a delta type parallel manipulator for performing CPR operation.
The model does 100 compressions per minute with a vertical displacement of 4-5 cm, which is the requirement of the CPR.
A rigid body is attached to the end effector and I need to model a human chest using a spring damper system.
The exists a spring-damper block in the 1D Mechanical translation category. I have previosly modeled a spring damper mechanical system using these blocks but I have never tried connecting these to a Multibody.
The spring and damper coefficients of a human chest are k=8350 N/m and c=500 Ns/m.
My model is here:
Can you help me model the human chest?
how to find infinitisimals of system of differential equations?
i have system of two dependent variables and two independent variables.
[-(diff(psi[2], x))+diff(psi[1], t, t)-2*n*(psi[1]^2+psi[2]^2)*psi[1]-beta*(diff(psi[1], x, t)) = 0,
diff(psi[1], x)+diff(psi[2], t, t)-2*n*(psi[1]^2+psi[2]^2)*psi[2]-beta*(diff(psi[2], x, t)) = 0]
Here is a possible situation tha appears very often in presentations:
How do I add a colon ":" after "ss3" in the second red line? And, while we are at it, how do I add the word "and" between ss2 and ss3?
Thank you all so much for your continuous and inexhaustible help!
mapleatha
Question:I've defined wave, but it's after that it gets sticky. This is my attempt:As you can see, not very fruitful. I have tried wave(x=-infinity..infinity, t=-infinity, infinity) which returns an error.
When i sub in wave(1,1) i get an answer, or any other number for that matter, but I'm not sure how to actually aswer this question.
Any and all help appreciated
Question: You will observe that the two curves intersect at one or more places in the displayed region. Use fsolve to find the (x; y) coordinates of all the points of intersection in this region.
In theory this question has a very simple answer, but i am struggling no end finding it.
P1 := y^2 = x^3+x^2
P2 := y = 2*x+1
This is what the graph looks like when plotted, and as we have already got the two equasions assigned as H and J, i just type in fsolve({P1,P2})?
Apparently not, as this returns {x = 4.048917340, y = 9.097834679}, which is correct, but is only one of three points of intersection, and just so happens to be the one not shown in my plot (although it is still a valid point of intersection) and i need the ones within the region i have set for the graph (x=-1..2 and y=-1..1).
How do i get maple to show me the two points of intersection i need using the fsolve command?
I've tried rearranging the equasions for y, rearranging for x, adding an option to solve for x [fsolve({P1,P2},x) but this returned an error] and am pretty stumped. For something so seemingly simple i dont really know where to turn.
Thank you :)
i have a matrix m[10,10] with some values, i want to PointPlot every rows with Explore command , here is my code:
Explore(PointPlot(m[a, 1 .. 10], [.1, .2, .3, .4, .5, .6, .7, .8, .9, 1]), parameters = [a = 1 .. 10])
but it does'nt work! how can i fix it?
thank you in advance
I have the following situation that I'm having trouble with . I am a total beginner in Maple, btw.
I have a long equation, involving a variable (x) , several other variables, and a function of x, F(x). A priory, this function is unspecified (its a probability density function, that may depend on whichever distribution it follows). I would like to have Maple operate on this function as if its a function of x, but without specifying. For example, lets say I have
x + yF(x)=0
I would like to derive it and have Maple return me
1 + yF'(x)=0
Is this possible?
restart; with(LinearAlgebra)
kernelopts(version); interface(version)
`Maple 2017.3, X86 64 WINDOWS, Sep 27 2017, Build ID 1265877`
`Standard Worksheet Interface, Maple 2017.3, Windows 10, September 27 2017 Build ID 1265877`
The following equation contains so many regularities, that it is tantalizing to find a compact matrix formulation.
I found a matrix expression, but it seems unnecessairy complex. Is there a Maple procedure that can help me to find a more concise matrix formulation?
eq1 := i2*i3*i4*(i2+i3+i4)+i1*i3*i4*(i1+i3+i4)+i1*i2*i4*(i1+i2+i4)+i1*i2*i3*(i1+i2+i3)
expand(eq1)
i1^2*i2*i3+i1^2*i2*i4+i1^2*i3*i4+i1*i2^2*i3+i1*i2^2*i4+i1*i2*i3^2+i1*i2*i4^2+i1*i3^2*i4+i1*i3*i4^2+i2^2*i3*i4+i2*i3^2*i4+i2*i3*i4^2
V := Matrix(4, 1, [i1, i2, i3, i4])
Matrix(%id = 18446745919887783806)
one := Matrix(4, 1, 1)
Matrix(%id = 18446745919887784886)
This matrix expression works, but seems overly complex. Using Maple, is there a way to simplify it?
Trace(MatrixScalarMultiply(one^%T.(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T))).convert(Diagonal(Adjoint(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T)))), Matrix), 1/2))-eq1
Alternatively, but also not very simple:
Trace(DiagonalMatrix(Diagonal(MatrixScalarMultiply(1/(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T))), (1/2)*Determinant(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T)))))).(KroneckerProduct(V^%T.one, IdentityMatrix(4))-DiagonalMatrix(V)))-eq1
Obviously, this does not help:
A, B := LinearAlgebra:-GenerateMatrix([eq1], [x])
Matrix(%id = 18446745919887762006), Vector[column](%id = 18446745919887761886)
Download Matrix_formulation.mw
When i input: i get returned.and with this i have no idea what im supposed to do. I dont understand what it means, how to correct it or how to actually answer the question using the information.
This is what i am returned with when i try to input a sequence using my previous result.
Could someone please put me on the right tracks and help me with this problem?
First 911 912 913 914 915 916 917 Last Page 913 of 2434
