I would like to plot the region of solution of the following system defined by some equations.
restart; with(Optimization);
inequal({-5 <= 4*y1+2*y2+3*y3, -2 <= 3*y1+5*y2+2*y3, -1 <= y1+2*y2+y3, 0 <= y2, y1 <= 0}, {y1, y2, y3}, color = "Nautical 1");
Many thanks for any help
I have the following Polynomial F. Computing the genus shows that this curve has negative genus and thus is reducible. But using AFactor doesn't produce a factorization. Any ideas?
with(algcurves):
F := z^9+(-3/2+(3/2*I)*sqrt(3))*y^3*z^6+(-3/2-(3/2*I)*sqrt(3))*x^3*z^6+(-3/2-(3/2*I)*sqrt(3))*y^6*z^3+(-3/2+(3/2*I)*sqrt(3))*x^6*z^3+y^9+(-3/2-(3/2*I)*sqrt(3))*x^3*y^6+(-3/2+(3/2*I)*sqrt(3))*x^6*y^3+x^9-3*(x*y*z)^3:
z:=1:
genus(F, x, y);
evala(AFactors(F));
Pls what is the maple code for the fourth order Runge-kutta method for five systems of ODE of several variables?
I want to be able to make arrows on my axis to indicate positive direction, since it is a requirement at my school. I would like to do it with the "plots" function.
Here is what I wish I had in maple http://imgur.com/a/OXi5t
Hi Mapleprimes,,,
We see Maple file.
We are aware of oeis.org/A103435/
sequence data
0 2
1 4
2 16
3 48
4 160
5 512
6 1664
7 5376
8 17408
9 56320
10 182272
11 589824
12 1908736
13 6176768
14 19988480
15 64684032
16 209321984
b103435
Where F(m)=2*F(m-1)+4*F(m-2).
Goal - to increase refereed database.
M.mw
Matthew Charles Anderson
Legislative Assistant
Oregon USA
Age 42.
5*x-7 = 3*x+2;
lhs(5*x-7 = 3*x+2) - rhs(5*x-7 = 3*x+2) = 0;
                          2 x - 9 = 0
                              [x]
isolate( 2*x-9 = 0, %ARG1 );
Error, (in isolate) 2*x-9 = 0 does not contain %ARG1
plz explain me what is this error?
If input a group of outputs which are binary numbers
can it simplify to give a logic that can output these outputs
If input ["1","1","2","2","2","77"]
output a graph such as
1 has 2 times
2 has 3 times
77 has 1 time
3.mw
There are 2 questions actually. The first as the title says is about taking the integral. I have 2 functions that were found numerically from the system of differential equations (see the file), and I need to take the integral of the expression that includes both of them. Maple gives me something like Int () = Int (), so it doesn't solve anything. Why can it be?
The second question is about varying the boundary conditions. If, for example, I have the system with the condition like R(x_0)=R_0, can I get the plot  of R(x,R_0)? In my case I need to vary conditions on R and mu (R(0)=R_0 and mu(0)=mu_0) and then get the plot of the integral in relation to R_0 and mu_0. Is it even possible?
I have two simple module's:
1) ------------------------------------------------------------------------
Point := proc(xx::float,yy::float)
    return module()
        local x := xx,y := yy;
        export ShowPoint,GetX,GetY;
        ShowPoint := proc()
            printf("Point X,Y -> [%f,%f]",x,y);
        GetX := proc()
            return x;
        GetY := proc()
            return y;
    end module:
2) ------------------------------------------------------------------------
PointMath := module()
    option package;
    export `+`;
    `+` := proc(a::Point(float,float),b::Point(float,float))
        option overload;
        Point(a:-GetX()+b:-GetX(),a:-GetY()+b:-GetY());
end module:
Next I use first module:
p1:=Point(1.2,1.4);
p2:=Point(1.0,2.0);
Finally I want to add above two points:
with(PointMath)
p2:=p1+p2
The results is:
p2:=p1+p2
Why is not called operator '+' and two points are not added?
Best,
Rariusz
How can I remove a subset containing a number from a partition?
eg S := [seq(2..5)]
P:=combinat:-setpartition(S, 2);
[[[2, 3], [4, 5]], [[2, 4], [3, 5]], [[2, 5], [3, 4]]]
I want to remove any partition involving 5
leaving
[[[2, 3]], [[2, 4]], [[3, 4]]]
i tried
remove(has,P,5)
Can someone answer why i get Float(undefined) while computing integral
Here is my example
alpha0 := .3;
.3
R := .1;
.1
sigma := 636;
636
Kfc := 101;
101
Ksc := 9;
9
E := 2*10^5;
200000
`&delta;th` := 2*10^(-7);
1/5000000
`&delta;c` := 0.8e-1*10^(-3);
0.8000000000e-4
p := 400;
400
`l&delta;z` := 12.1*10^(-3);
0.1210000000e-1
lKz := 20.3*10^(-3);
0.2030000000e-1
eta := 10^(-5);
1/100000
l0 := 0;
xi := p/sigma;
100/159
(14)
KImax := evalf(p*sqrt(Pi*l));
708.9815404*l^(1/2)
(15)
`N&delta;` := evalf(E*sigma*(int((-xi^2+1)*(-KImax^2+Kfc^2)/((KImax^2-Ksc^2)*((-R^4+1)*(KImax^2+Ksc^2)+eta*E*sigma)), l = l0 .. `l&delta;z`))/alpha0);
Float(undefined)
(16)
Download N.mw
"01000001" is A
how convert string of binary into a characters?
how to convert this string into 65 too?
with(QDifferenceEquations);
z := .8; q := .9;
                              0.8
                              0.9
QGAMMA(z, q);
Error, (in QDifferenceEquations:-QGAMMA) wrong type of arguments
How do we get the numerical result from Maple? It just only do algebraic calculation.
Primetable :=table[(2=b,3=c)]
so far, hard code in above code
is there a generic code for general
according alphabet order 5=d,7=e etc
First 985 986 987 988 989 990 991 Last Page 987 of 2434
