Hi all
I have 4 - 2a and (2x^2 - 2x + sqrt(2))^2. How to factor it become 2(2-a) and 2(sqrt(2)x^2 - sqrt(2)x + 1)^2 ?
Thanks you very much.
Hello people,
I am looking to use Maple and its loops, to develop the tensorial expressions in index notations such as this one:
My Sigma[11] is supposed to be a summation of the terms obtained when i then j are vary throughout the values, 1, 2 3
I am looking for a way of exporting a large number of Maple files (*.mw) into text files (*.txt) automatically. Here are two questions:
  • Is there a ready-made tool allowing to do this?
  • If not, is it possible to export a maple file to text from the command line interface?
Samuel
Hey guys,
I have this (6x1) matrix:
And I wish to factor a vector of the recurring terms out of it, this particular vector:
So that I end up with a (6x6) Matrix multiplied to that vector.
I get no output from the following
deqv := m*v(s)*(diff(v(s), s)) = m*g-k*v(s)^2
I have to write
solv := `assuming`([dsolve({deqv, v(0) = v__0}, v(s), implicit)], [v__0 > 0])
in order to get
-g*m/k-exp(-2*k*s/m)*(-g*m/k+v__0^2)+v(s)^2 = 0
and then I have to write my own function
It should be a piece of cake for maple to solve this!
Staffan
I was curious to know if one can extract a specific solution from a LPSolve routine.
As an example, consider the following output to a constrained linear problem. The objective value is 8 and the decision variable values (binary) are given.
Sol := [8, [w[1, 1] = 1., x[0, 0, 1] = 0, x[0, 1, 1] = 1, x[0, 2, 1] = 0, x[1, 0, 1] = 0, x[1, 1, 1] = 0, x[1, 2, 1] = 1, x[2, 0, 1] = 0, x[2, 1, 1] = 0, x[2, 2, 1] = 0, y[0, 0] = 0., y[0, 1] = 0., y[1, 1] = 2.]]
I am interested to know if we can isolate any variable value from this solution. I know that Sol[1] will return 8, and Sol[2] will return the remaining terms. But what if I wanted, say, x[1,2,1] alone?
Thanks for reading!
A bit of an annoyance.
typing 'numerator' / 'denominator' generates an error.  The first quote never gets automatically grouped as it should.
Two workarounds.  The first is to move to, and delete the first quote and re-enter it again in front of numerator.
The second is to use brackets, although one shouldn't have to.
I have this problem that my computer crashed during Maple 2016.1 to 2016.2 update.
Now it won't start at all.
I have tried reinstalling Maple several times, tried not updating to 2016.1 and running the program as vesion 2016.0.
I get this error in my eventlog, when I try to run the program.
Name of program errors: javaw.exe, version: 8.0.1020.14, timestamp: 0x576af3f4
Name of the module with error: nvSCPAPI64.dll, version: 7.17.13.7849, timestamp: 0x588218a5
Exception code: 0xc0000409
Displacement by mistake 0x0000000000034b2f
Process ID 0x166c
The program's start time 0x01d279add4515202
Program path: E: \ School Program Files \ Maple 2016 \ jre \ bin \ javaw.exe
Module path: C: \ Program Files (x86) \ NVIDIA Corporation \ 3D Vision \ nvSCPAPI64.dll
Report ID: d52f952d-8fd2-4130-890a-196e6a7bdc92
Full name of the program with the error:
Relatively application ID for program errors:
So as my titel suggests I need help to remove all files associated with Maple so I can install the program anew. It has worked fine for over a year so far. Only stopped working after that crash.
I have even tried installing the older version, Maple 2015 and it doesn't work either, so I am guessing the files which are corrupted aren't removed during a normal uninstall process, and they are shared among the versions of the program.
Thanks in advance :)
Hi everybody,
The sequence
    writeto(MyFile)
    showstat(Myproc)
keeps printing the result on the screen
How is it possible to redirected the output of showstat(Myproc) into a file ?
I've just started to use Maple 16, and I can't seem to get a neat result, when I use the solve function to solve 4 equations with 4 unknown constants.
I've posted my calculations.
How can I get a simpler result? I found a simplification command, but that didn't help
Where I made a mistake I got this error in for loop and how to fix it?
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received shareman
N := 5:
c__1 := Matrix([[c1__11, c1__12, 0], [c1__12, c1__22, 0], [0, 0, c1__66]]):
c__2 := Matrix([[c2__11, c2__12, 0], [c2__12, c2__22, 0], [0, 0, c2__66]]):
c__3 := Matrix([[c3__11, c3__12, 0], [c3__12, c3__22, 0], [0, 0, c3__66]]):
c__4 := Matrix([[c4__11, c4__12, 0], [c4__12, c4__22, 0], [0, 0, c4__66]]):
c__5 := Matrix([[c5__11, c5__12, 0], [c5__12, c5__22, 0], [0, 0, c5__66]]):
Q := Array(1 .. 3, 1 .. 3, 1 .. N):
A := Matrix([[0, 0, 0], [0, 0, 0], [0, 0, 0]]):
Z := Matrix([[h__1], [h__2], [h__3], [h__4], [h__5], [h__6]]):
for ii to 3 do for jj to 3 do Q(ii, jj, 1) := c__1(ii, jj); Q(ii, jj, 2) := c__2(ii, jj); Q(ii, jj, 3) := c__3(ii, jj); Q(ii, jj, 4) := c__4(ii, jj); Q(ii, jj, 5) := c__5(ii, jj) end do end do
"for i from 1  to 3 do for j from 1 to 3 do Ar:=0:for k from 1 to N do  Ar:=(Q (i,j,k)*(Z(k+1)-Z(k)))+Ar: end do A(i,j):=Ar: end do end do"
Error, invalid loop statement termination
Download quest.mw
Is there a problem with MaplePrime web site?   All my questions for the last 4 years, and answers are no longer available. All gone. I posted a question early today about sin(x) calling. one hr after that, I noticed all my questions and answers gone.
When I go to my user profile, it says I have zero questions, zero answer and zero post for the last 4 years. All the answers to my questions also got deleted, which is a shame if this happened. They have many useful information.
Any one else affected by this?
 I need help regarding this figure. i want to write both equations in maple 18. Second equation is related to first equation.So, please help me to write this code. I will be grateful.
I have a need to calculate base 2 math as would be done in an integrated circuit. Math will be done using 15 bit 2's complement mantissa and 8 bit exponent. (the exponent is always assumed to be negative) We need to perform multiplication and addition, where each internal operation is represented by such a number.
The goal is to best represent the errors associated with such calculations and export the resulting code to a hardware description language for implementation on an integrated circuit.
Is there a package in Maple that can do that? Any advice on how te proceed?
How to do for to built animation Cylinder inscribed in cone?( in optimization problem)
First 1048 1049 1050 1051 1052 1053 1054 Last Page 1050 of 2460
