Hi ,
I have recently got to know this software and its capabilities and was wondering if I can use it to start an initial systems design for an E-scooter as a first step (virtual validation). then feed this data to a designer which will design and cooperate with an engineer to realise the design again on this platform.
SO i have the range of my scooter , the weight it carries , the enviroment's average topography which i will be simplifying it at the first step to a 15% hill climb , and finally some dynamic/static restrictions... which i hope ican build upon . like adding chasis loads and analysis to data.
I want it to give me the cell number of the batteries , verify the loads and give me a electric-motor description .
this was the road map.
Thank you for your kind replies .
Is there a way to change the numeric formatting of 'Scientific' to use a cdot instead of a cross to represent multiplication?
I got a set of data imported from excel which is of the size 2001x2. I've use DataPlot to plot the graph of this data but I can't seem to find a way to integrate it. I've used BSplineCurve to make the discreate values continious but I cant seem to integrate this new curve. Can someone please give me a solution or an alternative way to find an approximative way to find the area under the curve.
Say I have a rational function
f:= q^4*(q^2+1)*((q^6+q^5-q^4-2*q^3+q+1)^6/q^13+(q^6+q^5-2*q^3-q^2+q+1)^6/q^25)/((1+q)^4*(-q^2+1)^2)
in a variable q, with big degrees in numerator and denominator. I happen to know that if I make a change of variable q=exp(Ix) this rational function can be written in the form
f(exp(Ix))=\sum_{k>0, n>=0} (coefficient(n,k)) sin^(2n-2)(kx/2), where this sum is finite.
I'm trying to find (1) what is the best way to simplify the rational function f and (2) how can I make the change of variable into these variables.
I managed to put the rational function in terms of cos(x) and sin(x), however after a day of calculations the computer couldn't simplify the expression.
For this I was using:  simplify(rationalize(convert(subs(q=exp(Ix),factor(rationalize(f))),trig)))
I appreciate any help.
Edit: Another way of getting this variables would be to force Maple to use multiple angle identities to write the powers of cosine(x) in terms of sin(kx). Is there any way to force this kind of simplification?
Suppose i have a message X encrypted using RSA with public code (n,e) and ascii (Here we treat the message as an array so don't worry about block-length) how would one go about writing a procedure that given a public key (n,e) with small n and a ciphertext message x will decrypt x. I have been looking online to see how we can get maple to take ascii into consideration but to no avail any help would be appreciated
Guys
I can't seem to work out how the cylinder in my animation won't extend to of the bottom of the sphere initially. and how to make it stop at the maximum volume coordinates.
cylinder_in_sphere_ani.mw
Dear friends! I am facing problem to solve the below system of ODEs numerically please find the mistake and correct it.
alpha := -1; R := 2; m := 2; Pr := 7; Le := 1.25; Nt := .2; Nb := .2; g := .5; K1 := .1; Q := .5
Eq1 := eta^3*(diff(F(eta), eta, eta, eta, eta))+alpha*(eta^4*(diff(F(eta), eta, eta, eta))+eta^3*(diff(F(eta), eta, eta))-eta^2*F(eta))-2*eta^2*(diff(F(eta), eta, eta, eta))+3*eta*(diff(F(eta), eta, eta))-3*(diff(F(eta), eta))+eta*R*(diff(F(eta), eta))^2-3*eta*R*F(eta)*(diff(F(eta), eta, eta))+3*R*F(eta)*(diff(F(eta), eta))+3*eta^2*R*F(eta)*(diff(F(eta), eta, eta, eta))-eta^2*(diff(F(eta), eta))*(diff(F(eta), eta, eta))-M^2*(eta^3*(diff(F(eta), eta, eta))-eta^2*(diff(F(eta), eta))); Eq2 := eta*(diff(G(eta), eta, eta))+alpha*Pr*eta^2*(diff(G(eta), eta))+R*Pr*F(eta)*(diff(G(eta), eta))+Nb*eta*(diff(G(eta), eta))*(diff(H(eta), eta))+Nt*eta*(diff(G(eta), eta))^2+diff(G(eta), eta)+Q*Pr*eta*G(eta) = 0; Eq3 := eta*(diff(H(eta), eta, eta))+alpha*Le*Pr*eta^2*(diff(H(eta), eta))+R*Le*Pr*F(eta)*(diff(H(eta), eta))+Nt*eta*(diff(G(eta), eta, eta))/Nb+Nt*(diff(G(eta), eta))/Nb+diff(H(eta), eta)-g*Le*Pr*eta*H(eta)-Le*Pr*K1*eta = 0;
IC1 := F(0) = 0, F(1) = 1, (D(F))(0) = 0, (D(F))(1) = 0, (D(G))(0) = 0, G(1) = 1, (D(H))(0) = 0, H(1) = lambda; dsys1 := {Eq1, Eq2, Eq3, IC1}; dsol1 := dsolve(dsys1, numeric, continuation = lambda, range = 0 .. 1);
dsol1x := subs(dsol1, F(eta));
dsol1y := subs(dsol1, G(eta)); dsol1z := subs(dsol1, H(eta));
With my best regards and sincerely.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
Hi all
I have 4 - 2a and (2x^2 - 2x + sqrt(2))^2. How to factor it become 2(2-a) and 2(sqrt(2)x^2 - sqrt(2)x + 1)^2 ?
Thanks you very much.
Hello people,
I am looking to use Maple and its loops, to develop the tensorial expressions in index notations such as this one:
My Sigma[11] is supposed to be a summation of the terms obtained when i then j are vary throughout the values, 1, 2 3
I am looking for a way of exporting a large number of Maple files (*.mw) into text files (*.txt) automatically. Here are two questions:
  • Is there a ready-made tool allowing to do this?
  • If not, is it possible to export a maple file to text from the command line interface?
Samuel
Hey guys,
I have this (6x1) matrix:
And I wish to factor a vector of the recurring terms out of it, this particular vector:
So that I end up with a (6x6) Matrix multiplied to that vector.
I get no output from the following
deqv := m*v(s)*(diff(v(s), s)) = m*g-k*v(s)^2
I have to write
solv := `assuming`([dsolve({deqv, v(0) = v__0}, v(s), implicit)], [v__0 > 0])
in order to get
-g*m/k-exp(-2*k*s/m)*(-g*m/k+v__0^2)+v(s)^2 = 0
and then I have to write my own function
It should be a piece of cake for maple to solve this!
Staffan
I was curious to know if one can extract a specific solution from a LPSolve routine.
As an example, consider the following output to a constrained linear problem. The objective value is 8 and the decision variable values (binary) are given.
Sol := [8, [w[1, 1] = 1., x[0, 0, 1] = 0, x[0, 1, 1] = 1, x[0, 2, 1] = 0, x[1, 0, 1] = 0, x[1, 1, 1] = 0, x[1, 2, 1] = 1, x[2, 0, 1] = 0, x[2, 1, 1] = 0, x[2, 2, 1] = 0, y[0, 0] = 0., y[0, 1] = 0., y[1, 1] = 2.]]
I am interested to know if we can isolate any variable value from this solution. I know that Sol[1] will return 8, and Sol[2] will return the remaining terms. But what if I wanted, say, x[1,2,1] alone?
Thanks for reading!
A bit of an annoyance.
typing 'numerator' / 'denominator' generates an error.  The first quote never gets automatically grouped as it should.
Two workarounds.  The first is to move to, and delete the first quote and re-enter it again in front of numerator.
The second is to use brackets, although one shouldn't have to.
I have this problem that my computer crashed during Maple 2016.1 to 2016.2 update.
Now it won't start at all.
I have tried reinstalling Maple several times, tried not updating to 2016.1 and running the program as vesion 2016.0.
I get this error in my eventlog, when I try to run the program.
Name of program errors: javaw.exe, version: 8.0.1020.14, timestamp: 0x576af3f4
Name of the module with error: nvSCPAPI64.dll, version: 7.17.13.7849, timestamp: 0x588218a5
Exception code: 0xc0000409
Displacement by mistake 0x0000000000034b2f
Process ID 0x166c
The program's start time 0x01d279add4515202
Program path: E: \ School Program Files \ Maple 2016 \ jre \ bin \ javaw.exe
Module path: C: \ Program Files (x86) \ NVIDIA Corporation \ 3D Vision \ nvSCPAPI64.dll
Report ID: d52f952d-8fd2-4130-890a-196e6a7bdc92
Full name of the program with the error:
Relatively application ID for program errors:
So as my titel suggests I need help to remove all files associated with Maple so I can install the program anew. It has worked fine for over a year so far. Only stopped working after that crash.
I have even tried installing the older version, Maple 2015 and it doesn't work either, so I am guessing the files which are corrupted aren't removed during a normal uninstall process, and they are shared among the versions of the program.
Thanks in advance :)
First 1051 1052 1053 1054 1055 1056 1057 Last Page 1053 of 2463
