I'm curious to know if anyone has written a procedure to optimize the VRP with time windows / constraints.
I have a system of ode's
restart:with(plots):
eq1:=((diff(f(x),x$3)))+f(x)*diff(f(x),x$2)-a*diff(f(x),x$1)^2=0;
eq2:=(diff(g(x),x$2))+b*f(x)*diff(g(x),x$1)=0;
bc1:=f(0)=0,D(f)(0)=1,D(f)(5)=0,g(0)=0.5,g(5)=0;
dsolve can solve it easily.
sol:=dsolve(subs(a=0.5,b=0.5,{bc1,eq1,eq2}), numeric):
Now I was to use the numerical data from the sol in the following expression
Expr:=a*f(x)+b*g'(x)+c*f'(x)*g(x) # at x=1:
to make a table of this form a  b  c  Expr, where a, b, c vary simultaneously between 0 and 1 by 0.2 producing data for Expr.
Any suggestions?
Hi everyone!
I have a question: what is the simpliest way to generate colorbar for spectrogram?
Now I use "valuesplit" to assign dependece "z"-value from color.
My programm. My test file: "Signal.txt".
filtered_spectrogram.mw
Signal.txt
P.S. I use Maple 2016.
Helle everybohy,
I need to setup a metric tensor in 3-d but with the varalble r, theta and phi.  So I try this:
>with(Physics); Setup(mathematicalnotation = true, dimension = 3)
>Setup(coordinates = spherical[r, theta, varphi], metric = M)
where M is the metric that I need to use.  But the last command does not work.  Il I don't write [r, theta, varphi], it work but it's r, theta and t.
Any hint on this please?
Mario Lemelin
mario.lemelin@cgocable.ca
all
I need your help  to give an answer to  this question
I would like to construct a matrix with condtion that comes in picture
How can i do this with maple????
my matrix is n+1*n+1
How to calculate this integral:
for k>0,m>0
Int(exp(-(1/2)*v/k)*v^3*exp((1/2)*v/m)*Ei(1, -(1000*I)*v+(1/2)*v/m), v = 0 .. infinity)
I'm  tried to take advantage of with(IntegrationTools) but I failed
and and I got a strange result ,like this:
Integral.mw
Can somebody execute this code on a powerful comp and report the result in MaplePrimes? That would be kind of her/him.
RealDomain:-solve(a^2+b^2+c^2+a*b+a*c+b*c-  (a+b-c)*sqrt(2*a*b+a*c+b*c)-(a+c-b)*sqrt(a*b+2*a*c+b*c)-(b+c-a)*sqrt(a*b+a*c+2*b*c));
Error, (in assuming) when calling '`resultant/modular2`'. Received: 'Maple was unable to allocate enough memory to complete this computation.  Please see ?alloc'
Download want_for_execution.mw
How do I convince MAPLE to simplify this Euclidean norm? > (D[1](P))(rho, theta, phi); Vector[column](%id = 230612588) > Norm(%, 2); / 2 2 2\ \|cos(phi) sin(theta)| + |sin(phi) sin(theta)| + |cos(theta)| /^ (1/2) > simplify(%, trig); / 2 2 2\ \|cos(phi) sin(theta)| + |sin(phi) sin(theta)| + |cos(theta)| /^ (1/2)
In the TransformTetrad command we can use some parameters, including nullrotationwithfixedl_. However, the nullrotationwithfixedl_ parameter requires another parameter E. How do I enter parameter E?
Denis.
> restart; with(VectorCalculus);
> P := proc (rho, theta, phi) options operator, arrow; `<,>`(rho*cos(phi)*sin(theta), rho*sin(phi)*sin(theta), rho*cos(theta)) end proc;
> r[1] := proc (t) options operator, arrow; P(2, (1/2)*Pi, t) end proc;
> F := VectorField(`<,>`(x, VectorCalculus[`+`](y, R), z), coords = cartesian[x, y, z]);
> F[1] := evalVF(F, r[1](t));
                Vector[column](%id = 255051836)
Error, invalid input: VectorCalculus:-evalVF expects its 1st argument, F, to be of type {procedure, Vector(algebraic)}, but received Vector(3, {(1) = Vector(3, {(1) = 2*cos(t), (2) = 2*sin(t)+R, (3) = 0}, attributes = [space = (module () local _origin, _coords, _coords_dim; export GetCoordinates, GetRootPoint, Vector; end module)]), (2) = y+R, (3) = z}, attributes = [vectorfield, coords = cartesian[x, y, z]])
Hey,
    I'm doing a little experimenting on Maple and I want to display 3 Matrixes side by side with text explaining what is what. I have a for cycle in which 5 sets of 3 matrixes are made. And my goal is to display each of the 5 sets.
How would I go about doing that? I've tried the following:
display(Array(print(cat("Matriz A", k, AA[k])), print(cat("Matriz B", k, BB[k])), print(cat("Matriz D", k, DD[k]))))
But with this I end up getting this instead of what I want:
http://i.imgur.com/p087Upr.png
Any ideas are welcome, thanks in advance.
Rafael.
I found the following:
Question:matrix multiplication element by element
Does this not apply to vectors?  If not what syntax is required?  I cannot seem to execute this simple operation which I can easily do in MATLAB.  If you have such a capability why is it not clearly documented in the HELP pages?
HI, I'm new to maple and am having trouble taking partial derivitives. I couldn't find anything in the documentation that seemed to resolve the situation, and can't be the first person to stumble through this part of Maple.
Namely, it seems like the exponential function causes an extra "ln()" term to show up in the solution. I've tried with e^(y) and exp^(y) but nothing seems to be working. When i use the same markup up in wolfram and matlab and Ti-CAS i get the "correct" solution.
I attached a screen showing my input and output.
thanks for any insight!
Dear Maple experts,
I would like to teach volume of solids generated by revolution of an area between two curves by washers & cylindrical shell methods uisng Maple technology to my students. In this regard, I request the Maple experts to provide easy commands to meet my requirement.
With thanks & best regards.
Mr.M.Anand
Associate Professor in Mathematics
How do i implement Runge-Kutta of order 6 for a sytem of boundary value problems on maple
First 1064 1065 1066 1067 1068 1069 1070 Last Page 1066 of 2463
