Given a polynomial expression I would like to obtain a list whose entries are the positive entries of the polynomial with multiplicity given by the coefficients:
Example:
Given the polynomial expression: p:=x^2*y-2*y*z+3*x^2+2*y-z
The positive terms are: x^2*y, 3*x^2, 2*y
Thus I would like to obtain the list L:=[x^2*y , x^2 , x^2 , x^2, y , y].
Notice x^2*y appears once since the coefficient is 1.
x^2 appears three times since the coefficient is 3.
y appears two times since the coefficient is 2.
Is there a way to divide two lists entry by entry. I mean the following:
L:=[2,4,6,3];
T:=[2,2,3,1];
L/T=[1,2,2,3]
Given a list of numbers, is there a command that returns the list whose entries are the absolute values of the original list? is there also one from the signum?
Ex: Given L:=[1,-1,-5,2,-3], I would like to obtain for the absolute value [1,1,5,2,3] and for the signum [1,-1,-1,1,-1].
Given a list I would like to find the position of the positive numbers. Ex: Given L:=[3,8,-5,1,-3,-7], I would like to have as a result P:=[1,2,4].
I want to avoid using a loop for this. Any suggestion?
I can read a .m file written using "save" command, However the variable list (pallete) doesn't get updated. Is there any way to see the list of variables and their values that has been read with "read" command from the .m file?
I need to solve the next ode:
diff(u(x, y), x) = -(2/3)*(3*h^3*nu+9*h^2*nu*y-12*nu*y^3+36*x^2*y+56*y^3)/h^3
diff(v(x, y), y) = (2/3)*(36*nu*x^2*y+56*nu*y^3+3*h^3+9*h^2*y-12*y^3)/h^3
diff(u(x, y), y)+diff(v(x, y), x) = -(6*(1+nu))*x*(h^2-4*y^2)/h^3
The inicial conditions are:
u(L, 0) = 0
v(L, 0) = 0
D[1]*u(L, 0) = 0
When I write on Maple this code, he give me a error:
with(PDEtools, casesplit, declare); declare((u, v)(x, y))
sys2 := [diff(u(x, y), x) = -(2/3)*(3*h^3*nu+9*h^2*nu*y-12*nu*y^3+36*x^2*y+56*y^3)/h^3, diff(v(x, y), y) = (2/3)*(36*nu*x^2*y+56*nu*y^3+3*h^3+9*h^2*y-12*y^3)/h^3, diff(u(x, y), y)+diff(v(x, y), x) = -(6*(1+nu))*x*(h^2-4*y^2)/h^3]
sol := pdsolve(sys2)
ics := u(L, 0) = 0, v(L, 0) = 0, D[1]*u(L, 0) = 0
pdsolve([sys2, ics]);
Why Maple can't solve this PDE?
I think that the problem is on sys2. But I don't know how to explain to Maple the function: diff(u(x, y), y)+diff(v(x, y), x) = -(6*(1+nu))*x*(h^2-4*y^2)/h^3; on the system of equations. I think the problem is there.
I'm so sorry by my bad english.
I need to solve this, anyone help me please.
Please I need some assistance on how to solve the below pde:
diff(c(x,t),t)=diff(c(x,t),x,x)-diff(c(x,t),x)-c(x,t)
I have my initial condition and 2 boundary conditions. I just need some clues on how to go about solving the problem. Thank you!
please i need assistance on how to go about contructing a 3d plot of the fuction below:
((Pi*BesselJ(1, x)*HermiteH(0, x)+2*BesselJ(0, x)-Pi*BesselJ(0, x)*BesselJ(1, x)*HermiteH(0, x))*exp(-x^2*D*t/`αk`)*BesselJ(0, x/chi)/BesselJ(1, x)^2)-M[0]*T[2]*`γgr`*exp(-T[g/T[0]]*(t-delta))
please i will appreciate a code or sort of syntax or guidline on how to do it,pls i want to plot the value of the function on the y axis, chai on the x axis and t[2] on the z axis.
M[0]=8,g=9.8,T[2]=300,500,700,900,gamma=1.17,r=1.15,T[g]=1.11111,T[0]=3.666667,t=5e-9,delta=0.002,x=3.478505,alpha=5.36,k=1.2,chi=0.22,0.23,0.24,0.25,r=1.15,D=7.46
In my calculations, I encounter with too small numbers, e.g. 0.4e-10. My question is that how can I make the maple to ignore these small numbers and considers them as zero and not to incorporate them into subsequent calculations???
when using jopenmaple, some maple command will cause jvm crash due to stack overflow exception, but has no trouble if issued in Maple GUI.
after some digging, i found that the stacklimit in Maple GUI is 130941. but if I use jopenmaple to invoke command "kernelopts(stacklimit);", the result is 893.  further more, if i try to increase stacklimit by issuing "kernelopts(stacklimit=894)", maple kenerl tells me that i cant increase it beyond hardlimit.
so here are my questions:
1. why are the two stacklimits different?
2. is there a way to increase the hardlimit so that i can increase the stacklimit when using java invoking maple commands?
some platform information:
OS: windows 7 64bit
JAVA: jdk1.7 64bit
thanks.
Hi, the fsolve works perfectly fine when otaining SOL2 below. However, as soon as I change the values of paramters (from 0 values in SOL2 to t_prof = .16, t_r = .16, t_w = .16 in SOL3) fsolve simplmy reproduces the eval results and would not solve! Please your help is highly appreciated. Thanks in advance!
eq1 := ((1-s)*w)^(1-gamma)*r^gamma-P_v = 0;
eq2 := (1-s)*w*H/M-(1-gamma)*P_v*q/phi = 0;
eq3 := r*(K+K_f)/M-gamma*P_v*q/phi = 0;
eq4 := prof-M*p_d*q+(1-s)*w*H+r*(K+K_f) = 0;
eq5 := -tau*y_x+q-y_d-y_g = 0;
eq6 := p_d-sigma*P_v/((sigma-1)*phi) = 0;
eq7 := y_d-M^(lambda-1)*Y*(p_d/P)^(-sigma) = 0;
eq8 := y_x-F_f*(tau*p_d)^(-sigma_x) = 0;
eq9 := y_f-M_f^(lambda-1)*Y*((1+z)*tau*p_f/P)^(-sigma) = 0;
eq10 := (G*alpha_g+Y)^(-alpha_c)/P-A*H^alpha_h/((1-t_w)*w) = 0;
eq11 := P*Y-(1-t_w)*w*H-(1-t_r)*r*K-(1-t_prof)*prof+T = 0;
eq12 := P*Y-M*p_d*y_d-M_f*(1+z)*tau*p_f*y_f = 0;
eq13 := (1-t_r)*r-r_f = 0;
eq14 := G-y_g*M^((lambda_g-1+sigma_g)/(sigma_g-1)) = 0;
eq15 := s*w*H+M*p_d*y_g-T-t_w*w*H-t_r*r*(K+K_f)-t_prof*prof-z*M_f*tau*p_f*y_f = 0;
SOL2 := fsolve(eval({eq1, eq10, eq11, eq12, eq13, eq14, eq15, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}, [A = 7.716049383, K = 3.2, K_f = 0, alpha_c = .8, alpha_g = .2, alpha_h = 4, lambda = .5, p_f = 1, phi = .625, s = 0, sigma = 5, sigma_g = 5, sigma_x = 5, t_prof = 0, t_r = 0, t_w = 0, tau = 1.1, y_d = 1, y_f = 1, y_g = .4, y_x = 1, z = 0, lambda_g = .5, gamma = .25, gamma = .25]), {F_f, G, H, M, M_f, P, P_v, T, Y, p_d, prof, q, r, r_f, w}, {F_f = 2 .. 4, G = .1 .. .4, H = .4 .. .8, M = .4 .. .6, M_f = .3 .. .7, P = .8 .. 2, P_v = .4 .. .8, T = -.2 .. .3, Y = .7 .. 3, p_d = .9 .. 1.6, prof = .1 .. .4, q = 1.5 .. 2.7, r = 0.4e-1 .. 0.9e-1, r_f = 0.4e-1 .. 0.9e-1, w = .8 .. 3});
SOL3 := fsolve(eval({eq1, eq10, eq11, eq12, eq13, eq14, eq15, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}, [A = 7.716049383, K = 3.2, K_f = 0, alpha_c = .8, alpha_g = .2, alpha_h = 4, lambda = .5, p_f = 1, phi = .625, s = 0, sigma = 5, sigma_g = 5, sigma_x = 5, t_prof = .16, t_r = .16, t_w = .16, tau = 1.1, y_d = 1, y_f = 1, y_g = .4, y_x = 1, z = 0, lambda_g = .5, gamma = .25, gamma = .25]), {F_f, G, H, M, M_f, P, P_v, T, Y, p_d, prof, q, r, r_f, w}, {F_f = 2 .. 4, G = .1 .. .4, H = .4 .. .8, M = .4 .. .6, M_f = .3 .. .7, P = .8 .. 2, P_v = .4 .. .8, T = -.2 .. .3, Y = .7 .. 3, p_d = .9 .. 1.6, prof = .1 .. .4, q = 1.5 .. 2.7, r = 0.4e-1 .. 0.9e-1, r_f = 0.4e-1 .. 0.9e-1, w = .8 .. 3});
I have started to use Maple 18 and I have found that my scale starts at 2.*10^16 for all functions I graph no matter if its 3D or 2D. Is there a way to change this scale?
Dear, my attached file take alot time to exicute the result, Please solve this problem. I am waiting your kind response.
Hirota_Bilinear_Method-3.mw
With my best regards and sincerely.
Muhammad Usman
PhD (Scholar) Mathematics
HITEC University, Taxila
Lecturer of Mathematics
Govt. Degree College Taxila Pakistan.
Visiting Lecturer of Mathematics
University of Wah, Pakistan.
Email: mughal1103@gmail.com
Mob #: +923152329276
1.
similar gap system, which function can output coset table ?
if find example below,
f := FreeGroup( "a", "b" );
g := f / [f.1^2, f.2^3, (f.1*f.2)^5];
tab := CosetTable(g, Subgroup(g, [g.1, g.2*g.1*g.2*g.1*g.2^-1]));
2.
if quotient group is for equivalence relations, what do relations [g.1, g.2*g.1*g.2*g.1*g.2^-1] for? which kind of relations is for input to subgroup parameter which is like relations?
3. equalivance relations in wiki mentioned is to partition cells, how do they satisfy symmetric, reflexive and transitive after partition? how to test these partition?
how to implement a free group with symmetric properties?
i find that equivalence relations = relexive, symmetric and transitive , is only these three ?
if implement symmetric properties, does it mean that adding equivalence relations to group?
how to implement free group with this?
i guess something like
g := f / [equivalence relations....];
First 1296 1297 1298 1299 1300 1301 1302 Last Page 1298 of 2470
