 I can't achieve this using StringTools:-RegSplit. The StringTools,Regular_Expressions documentation doesn't seem to address these functionalities.
My goal is to split the string at the occurences of "." that are somewhere between "]" and "["* yet not enclosed between the two digits, and to ignore all other occurences of "."
I want to get the unknown function whose Taylor expansion I have. For example, giving x - 1/6*x^3 + 1/120*x^5 - 1/5040*x^7 + 1/362880*x^9 will return sin(x). The following algorithm can be implemented for this simple function:
with(inttrans):
with(numapprox):
convert(taylor(sin(x),x, 10),polynom);
laplace(%, x, s1);
eval(%, s1=1/s2);
pade(%, s2, [3,3]);
eval(%, s2=1/s1);
invlaplace(%, s1, x);
But this approach does not lead to the correct solution for slightly more complex functions. For example, if I have the Taylor expansion of the function sin(x^2), I cannot reach the function sin(x^2) with the above algorithm. Note that before extracting the sin(x^2) function, this function is unknown to us and we only have its Taylor expansion:
with(inttrans):
with(numapprox):
convert(taylor(sin(x^2),x, 15),polynom);
laplace(%, x, s1);
eval(%, s1=1/s2);
pade(%, s2, [3,3]);
eval(%, s2=1/s1);
Also, the Taylor expansion of the simple function exp(-x^2) with the above algorithm is returned as a trigonometric function:
with(inttrans):
with(numapprox):
convert(taylor(exp(-x^2),x, 10),polynom);
laplace(%, x, s1);
eval(%, s1=1/s2);
pade(%, s2, [3,3]);
eval(%, s2=1/s1);
The importance of solving this problem becomes clear when we want to solve the differential equation or the set of differential equations by applying the ‘series’ option. If the variable t expresses time, it can never be obtained with a polynomial function u(t) in sufficiently large times. For example, the exact solution of the following differential equation is u(t)=exp(-a*t^2):
Order:=12;
ode:=t*diff(u(t),t,t)+8*diff(u(t),t)+18*a*t*u(t)=-4*a*t*u(t)*ln(u(t));
ic1:=u(0)=1;
ic2:=D(u)(0)=0;
dsolve({ode, ic1,ic2}, u(t), series);
Does anyone have an idea to extract the unknown function from its taylor expansion?
Best wishes
Don't see here the FunctionAdvisor , what is included for every choosen function.
How to obtain a clear plot of Zeta function
- via a total plot ?
- via partial plots ?
- further take circle in complex domain : complex plane ( riemann surface) , to be continued..
ComplexSurface := proc(complex_function, x_range, y_range, view_opt, orient_opt, grid_opt)
    local f, plot, combined_plot;
    # Define the complex function f(z)
    f := unapply(complex_function, z);
    # Call the FunctionAdvisor to provide plot recommendations
    FunctionAdvisor(f(z), z = x + I*y, 'view' = view_opt, 'orientation' = orient_opt, 'grid' = grid_opt);
    # Plot the complex surface
    plot := plot3d([evalc(Re(f(x + I*y))), evalc(Im(f(x + I*y)))], x = x_range, y = y_range, view = view_opt, orientation = orient_opt, grid = grid_opt, style = surface, title = sprintf("Plot of %a", complex_function));
    # Print the combined plot
    combined_plot := plot;
    #printf("Plot of the complex surface:\n");
    print(combined_plot);
    # Display additional messages
    printf("Procedure input:\n");
    printf("ComplexSurface(complex_function, x_range, y_range, view_opt, orient_opt, grid_opt)\n");
    printf("complex_function: The complex function to be plotted\n");
    printf("x_range: Range of the real axis\n");
    printf("y_range: Range of the imaginary axis\n");
    printf("view_opt: List of the form [x_min..x_max, y_min..y_max, z_min..z_max], determines the visible region\n");
    printf("orient_opt: List of the form [angle_x, angle_y], determines the viewing angle\n");
    printf("grid_opt: List of the form [x_grid, y_grid], determines the grid resolution\n");
    printf("\n");
    printf("Example usage:\n");
    printf("ComplexSurface(Zeta(z), -50..5, -5..5, [-50..50, -5..5, 0..15], [120, 60], [50, 50]);\n");
    printf("\n");
    printf("Where Zeta(z) is the complex function to be plotted, and the ranges, view options, orientation options, and grid options are specified accordingly.\n");
ComplexSurface(Zeta(z), -50..50, -5..5, [-50..50, -5..5, 0..15], [120, 60], [50, 50]);
Procedure input:
Example usage:
ComplexSurface(ln(z), -50..50, -5..5, [-50..50, -5..5, 0..15], [120, 60], [50, 50]);
Procedure input:
Example usage:
Download complex_oppervlak_zeta_functie_maple_primes.mw
This is new:
Maple 2024 frozen on opening recent files
Maple 2023 frozen on opening
Maple 2022 frozen on opening start page
Maple 2021 blinking
Maple 2020 opening start page
The above system state is constant for about 30 min. Maple sessions without start page are working. I can enter code but file opeing and saving does not work. The fact that Maple 2020 is also not working makes it unlikely that the Java environement is part of the problem.
I have several times restarted the system. The rest of the system is working.
Something happened to the system and I have no clue what is was and what I can do about it.
Any ideas or suggestions what I could try? Windows 10.
Not sure what  I did, but now  the typsetting rule assistant pops up every time I executre my document (twice!).  Searching the internet, I found that I should be able to turn it off by "expanding the blocks" (?) and then finding the call to this assistant.  Problem is, I can't find this "Expand block"  -- it is not under View it they claim it is in various posts.  Also, if I step through the worksheet, I can't find it ; it only pops up when I execute the entire worksheet.  I attached it here for someone to guide me on how to find where/why this is happening.
Thanks!coupled_network.mw
with(Syrup)
interface('displayprecision' = 4)
SyrupDefaults:-infolevel := 1; SyrupDefaults:-subscript_params := true
Circuit Netlist
ckt1
Definitions
Cp := 1/(`ω0p`^2*Lp)
1/(`ω0p`^2*Lp)
(1.2.1)
Cs := 1/(`ω0s`^2*Ls)
1/(`ω0s`^2*Ls)
(1.2.2)
M := k*sqrt(Ls*Lp)
k*(Ls*Lp)^(1/2)
(1.2.3)
assumptions := `and`(`and`(`and`(`and`(`and`(`and`(`ω0p` > 0, `ω0s` > 0), Lp > 0), Ls > 0), k > 0), Rp > 0), Rs > 0), omega > 0NULL
0 < `&omega;0p` and 0 < `&omega;0s` and 0 < Lp and 0 < Ls and 0 < k and 0 < Rp and 0 < Rs, 0 < omega
(1.2.4)
Simplifications
`&omega;0p` := `&omega;0p`
`&omega;0p`
(1.3.1)
`&omega;0s` := `&omega;0s`
`&omega;0s`
(1.3.2)
Rs := Rs
Rs
(1.3.3)
Rp := Rp
Rp
(1.3.4)
Lp := Lp
Lp
(1.3.5)
Ls := Ls
Ls
(1.3.6)
Not On Resonance
w := omega
omega
(1.3.1.1)
Solve System
sol, rest := `assuming`([Solve("ec:ckt1", analysis = ac, 'returnall')], [assumptions])
Solution
s := I*w
I*omega
(1.5.1)
vin := eval(v[N03], sol)
vin
(1.5.2)
Secondary Current
I2sol := `assuming`([simplify(eval(i[L2], rest))], [assumptions])
omega^3*k*Ls^(1/2)*Lp^(1/2)*vin/(Lp*Ls*(k-1)*(k+1)*omega^4+I*(Lp*Rs+Ls*Rp)*omega^3+(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega^2+I*(-Lp*Rs*`&omega;0p`^2-Ls*Rp*`&omega;0s`^2)*omega-Ls*Lp*`&omega;0p`^2*`&omega;0s`^2)
(1.5.3)
sol1 := solve(I2sol = I2, k)[1]
(1/2)*(Lp^(1/2)*Ls^(1/2)*vin*omega+(4*I2^2*Lp^2*Ls^2*omega^4-4*I2^2*Lp^2*Ls^2*omega^2*`&omega;0p`^2-4*I2^2*Lp^2*Ls^2*omega^2*`&omega;0s`^2+4*I2^2*Lp^2*Ls^2*`&omega;0p`^2*`&omega;0s`^2-(4*I)*I2^2*Lp^2*Ls*Rs*omega^3+(4*I)*I2^2*Lp^2*Ls*Rs*omega*`&omega;0p`^2-(4*I)*I2^2*Lp*Ls^2*Rp*omega^3+(4*I)*I2^2*Lp*Ls^2*Rp*omega*`&omega;0s`^2-4*I2^2*Lp*Ls*Rp*Rs*omega^2+Lp*Ls*vin^2*omega^2)^(1/2))/(I2*Lp*Ls*omega^2)
(1.5.4)
Coupling
kcoup := `assuming`([simplify(sol1)], [assumptions])
(1/2)*(vin*omega+(-4*(omega+`&omega;0p`)*I2^2*(omega-`&omega;0p`)*((-omega^2+`&omega;0s`^2)*Ls+I*Rs*omega)*Lp-4*(I*(omega+`&omega;0s`)*Rp*I2^2*(omega-`&omega;0s`)*Ls+omega*(I2^2*Rp*Rs-(1/4)*vin^2))*omega)^(1/2))/(Ls^(1/2)*Lp^(1/2)*I2*omega^2)
(1.5.5)
Zmutual
Zmutual := `assuming`([expand(abs(vin/I2sol))], [assumptions])
(Lp^2*Ls^2*k^4*omega^8-2*Lp^2*Ls^2*k^2*omega^8+2*Lp^2*Ls^2*k^2*omega^6*`&omega;0p`^2+2*Lp^2*Ls^2*k^2*omega^6*`&omega;0s`^2-2*Lp^2*Ls^2*k^2*omega^4*`&omega;0p`^2*`&omega;0s`^2+Lp^2*Ls^2*omega^8-2*Lp^2*Ls^2*omega^6*`&omega;0p`^2-2*Lp^2*Ls^2*omega^6*`&omega;0s`^2+Lp^2*Ls^2*omega^4*`&omega;0p`^4+4*Lp^2*Ls^2*omega^4*`&omega;0p`^2*`&omega;0s`^2+Lp^2*Ls^2*omega^4*`&omega;0s`^4-2*Lp^2*Ls^2*omega^2*`&omega;0p`^4*`&omega;0s`^2-2*Lp^2*Ls^2*omega^2*`&omega;0p`^2*`&omega;0s`^4+Lp^2*Ls^2*`&omega;0p`^4*`&omega;0s`^4+2*Lp*Ls*Rp*Rs*k^2*omega^6+Lp^2*Rs^2*omega^6-2*Lp^2*Rs^2*omega^4*`&omega;0p`^2+Lp^2*Rs^2*omega^2*`&omega;0p`^4+Ls^2*Rp^2*omega^6-2*Ls^2*Rp^2*omega^4*`&omega;0s`^2+Ls^2*Rp^2*omega^2*`&omega;0s`^4+Rp^2*Rs^2*omega^4)^(1/2)/(omega^3*k*Ls^(1/2)*Lp^(1/2))
(1.5.6)
plot([subs(L = 34*exp(1)-6*omega0 and 34*exp(1)-6*omega0 = 2*Pi*0.85e5, R = 0.1e-1, omega = 2*Pi*85000, Zmutual), subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, R = 0.1e-1, omega = 2*Pi*79000, Zmutual)], k = 0 .. 1, numpoints = 1000)
plot([subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*85000, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*85000, Zmutual), subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*85000, Rp = 0.1e-1, Rs = 0.1e-1, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*79000, Zmutual)], k = 0 .. 1, numpoints = 1000)
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, Zmutual), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
Primary Current
I1sol := `assuming`([simplify(eval(i[L1], rest))], [assumptions])
-I*omega*vin*(-Ls*omega^2+`&omega;0s`^2*Ls+I*Rs*omega)/(Lp*Ls*(k-1)*(k+1)*omega^4+I*(Lp*Rs+Ls*Rp)*omega^3+(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega^2+I*(-Lp*Rs*`&omega;0p`^2-Ls*Rp*`&omega;0s`^2)*omega-Ls*Lp*`&omega;0p`^2*`&omega;0s`^2)
(1.5.7)
at resonance
I1sol_res := simplify(eval(I1sol, [omega = omega0, `&omega;0s` = omega0, `&omega;0p` = omega0]))
vin*Rs/(Lp*Ls*k^2*omega0^2+Rp*Rs)
(1.5.8)
Self Impedance
Zpself := simplify(vin/I1sol)
(I*Lp*(k+1)*Ls*(k-1)*omega^4+(-Lp*Rs-Ls*Rp)*omega^3+I*(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega^2+(Lp*Rs*`&omega;0p`^2+Ls*Rp*`&omega;0s`^2)*omega-I*Lp*Ls*`&omega;0p`^2*`&omega;0s`^2)/(omega*(-Ls*omega^2+`&omega;0s`^2*Ls+I*Rs*omega))
(1.5.9)
at resonance
zpself_res := simplify(eval(Zpself, omega = omega0))
(I*Lp*(k+1)*Ls*(k-1)*omega0^4+(-Lp*Rs-Ls*Rp)*omega0^3+I*(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega0^2+(Lp*Rs*`&omega;0p`^2+Ls*Rp*`&omega;0s`^2)*omega0-I*Lp*Ls*`&omega;0p`^2*`&omega;0s`^2)/(omega0*(-Ls*omega0^2+`&omega;0s`^2*Ls+I*Rs*omega0))
(1.5.10)
Normalized
ZselfN := collect(simplify(`assuming`([expand(simplify(I2sol/I1sol))], [assumptions])), Ls)
I*omega^2*k*Ls^(1/2)*Lp^(1/2)/((-omega^2+`&omega;0s`^2)*Ls+I*Rs*omega)
(1.5.11)
Normalized Magnitude
`assuming`([MagZpselfN = simplify(eval(I2sol/I1sol, [`&omega;0p` = omega0, `&omega;0s` = omega0]))], [assumptions])
MagZpselfN = I*omega^2*k*Ls^(1/2)*Lp^(1/2)/(-Ls*omega^2+Ls*omega0^2+I*Rs*omega)
(1.5.12)
Plots
Zself as a function of Coupling Coefficient
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*85000, Zpself/Zmutual), k = 0 .. 1, numpoints = 1000)
plot(subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*85000, abs(Zpself/Zmutual)), k = 0 .. 1, numpoints = 1000)
Normalized - Off Resonance
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*79000, Zpself/Zmutual), k = 0 .. 1, numpoints = 1000)
plot(subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*79000, abs(Zpself/Zmutual)), k = 0 .. 1, numpoints = 1000)
Normalized, at a given coupling
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, Zpself/Zmutual), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
plot(subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, abs(Zpself/Zmutual)), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
Not Normalized, at a given coupling
plot(subs(Lp = 0.34e-4, Ls = 0.60e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, abs(Zpself)), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
Solution2
Download coupled_network.mw
Hello Maple community
I am trying to solve a system of equations, which is a little complicated.
eq1 := w = sqrt(a^2 - (a - y)^2);
eq2 := v + cot(t + arcsin(w/a)) = 0;
eq3 := u = (sqrt(c^2 - (c - z)^2) - v*x - w)/x^2;
eq4 := x = y + z + e;
eq5 := v + cot(T + arcsin((u*x^2 + v*x + w)/c)) + 2*u*x = 0;
eq6 := f = Pi/30*(6*u^2*x^5 + 15*u*v*x^4 + (20*u*w + 10*v^2)*x^3 + 30*v*w*x^2 + 30*x*w^2) - Pi/3*(-z^3 + 3*z^2*c - y^3 + 3*y^2*a);
sols := solve({eq1, eq2, eq3, eq4, eq5, eq6}, {u, v, w, x, y, z});
I tried solving it, but it is running for more than two hours now. I know that the system is very complicated, and Maple will take long to solve this. But my question is
1. Is it reasonable to take this long for this system of equations?
2. Can I speed it up in any way by using additional cores of my system or something? Can someone please tell me how I can achieve this?
Looking forward to any inputs the Community may have.
I have a sum in powers of  cosines : a0 + a1 cos(x) + a2 cos^2(x) + a3 cos^3(x) + ... + ak cos^k(x) . I want to transform it into a sum of the form : b0 + b1 cos(x) + b2 cos(2x)+  ... bk cos(kx). How can I do this in Maple?
How can I get the evaluation of integration inside if-statement?
Thanks for your help in advance,
#L:=1:sigma:=0.01:beta:=0.2:k0:=-100:
#For Free particle
Projectile := proc({L:=1,sigma:=0.01,beta:=0.2,k0:=-100},n_max) local x0,g,c:
 x0:= beta*L;
 g := unapply(exp(-(x-x0)^2/2/sigma^2),x);
 #c := int(g(x)^2,x=-L/2..L/2,numeric=true);
 ub := (L/2-x0)/sqrt(2)/sigma;
 lb := (-L/2-x0)/sqrt(2)/sigma;
 a := Pi*sqrt(2)*sigma/L;
 b := sqrt(2)*k0*sigma;
 c := Pi*x/L;
 d := k0*x0;
 eq1 := [cos(a*n*z)*cos(b*z)/e^(z^2),cos(a*n*z)*sin(b*z)/e^(z^2),sin(a*n*z)*cos(b*z)/e^(z^2),sin(a*n*z)*sin(b*z)/e^(z^2)];
 eq1 := map(f->unapply(f,n,z),eq1);
 eq2 := [cos(n*c)*cos(d),cos(n*c)*sin(d),sin(n*c)*cos(d),sin(n*c)*sin(d)];
 eq2 := map(f->unapply(f,n,z),eq2);
 for j from 1 to n_max do:
   if (is(j,odd)) then eq11 := int(eq1[1](j,z),z=lb..ub,numeric=true);
   else 0;
Warning, (in Projectile) `ub` is implicitly declared local
Warning, (in Projectile) `lb` is implicitly declared local
Warning, (in Projectile) `a` is implicitly declared local
Warning, (in Projectile) `b` is implicitly declared local
Warning, (in Projectile) `d` is implicitly declared local
Warning, (in Projectile) `eq1` is implicitly declared local
Warning, (in Projectile) `eq2` is implicitly declared local
Warning, (in Projectile) `j` is implicitly declared local
Warning, (in Projectile) `eq11` is implicitly declared local
Projectile(1);
int(cos(0.4442882938e-1*z)*cos(1.414213562*z)/e^(z^2), z = -49.49747467 .. 21.21320343)
Download SolnforProjectile_v3_3.mw
with(geometry);
_EnvHorizontalName := 'x';
_EnvVerticalName := 'y';
cb := color = blue;
t3 := thickness = 3;
l3 := linestyle = 3;
xA := 3;
yA := 0;
xB := -3;
yB := 0;
c := 6;
point(A, xA, yA);
point(B, xB, yB);
R := 5;
alpha := arctan(3/4);
evalf(%*180/Pi);
                          36.86989765
xH := (xA + xB)/2;
yH := (yA + yB)/2;
point(H, xH, yH);
xO1 := 0;
yO1 := 4;
point(O1, xO1, yO1);
xO2 := 0;
yO2 := -4;
point(O2, xO2, yO2);
segment(sAB, A, B);
segment(sHO, H, O1);
segment(sAO, A, O1);
segment(sBO, B, O1);
                              sAB
alpha1 := arctan((yO1 - yA)/(xO1 - xA));
beta := Pi + arctan((yO1 - yB)/(xO1 - xB));
AR1 := plottools[arc]([xO1, yO1], R, alpha1 .. beta, l3);
AR2 := plottools[arc]([xO2, yO2], R, -beta .. -alpha1, l3);
N := 80;
dt := (beta - alpha1)/(N - 1);
dr := draw({O1, O2, sAB, sHO, sAO(cb), sBO(cb)});
tex := textplot([[xA, yA - 0.5, "A"], [xB, yB - 0.5, "B"], [xO1, yO1 + 0.5, "O1"], [xO2, yO2 - 0.5, "O2"], [xH, yH - 0.5, "H"]]);
M1 := seq(plottools[disk]([R*cos(dt*t + alpha1) + xO1, R*sin(dt*t + alpha1) + yO1], 0.2, color = orange), t = 0 .. N);
M2 := seq(plottools[disk]([R*cos(dt*t + Pi + alpha1) + xO2, R*sin(dt*t + Pi + alpha1) + yO2], 0.2, color = orange), t = 0 .. N);
P1 := seq(plottools[polygon]([[R*cos(dt*t + alpha1) + xO1, R*sin(dt*t + alpha1) + yO1], [xA, yA], [xB, yB]], color = aquamarine, linestyle = dash), t = 0 .. N);
P2 := seq(plottools[polygon]([[R*cos(dt*t + Pi + alpha1) + xO1, R*sin(dt*t + Pi + alpha1) + yO1], [xA, yA], [xB, yB]], color = aquamarine, linestyle = dash), t = 0 .. N);
for t to N do
    E[t] := display(dr, tex, AR1, AR2, M1[t], P1[t]);
    F[t] := display(dr, tex, AR1, AR2, M2[t], P2[t]);
display([seq(E[t], t = 1 .. N), seq(F[t], t = 1 .. N)], insequence = true, axes = none, scaling = constrained, view = [-10 .. 10, -10 .. 10]);
NULL;
angle that does not turn on the lower arc. Thank you.
How to verify eq by using (2), (3) and (4)? Since lambda's, A's, B's and a are constant, but they appear as variables i.e., D[2](A1)..., (D[2] -> d/dt (derivative w.r.t 't')). Also q(n+1,t)- q(n,t) = a (const). Therefore, d/dt(q(n+1),t) - d/dt,(q(n,t))=0
verif_May24.mw
OS Linux
I have Maple 2022 open with a worksheet on a specific workspace.
I then move to a different workspace and want to start a new instance of maple for a new problem.
In command line I exacute
$]xmaple22 –standalone  filename.mw
Unfortunately when the new instance is started, the open maple instance on the first workspace is moved automatically to the second workspace together with the new instance opened, completely messing up the organization.
This is not expected behavior.
How can I make Maple execute absolutely independent instances of xmaple22 without indiscressionately and automatically moving existing open maple instances to the current workspace.
Severely annoying. Maple 9.5 e.g. does not have this behavior at all so Maple 2022 is a step backwards in this regard.
How do I programmatically control the zoom of a 3d plot ?
SEE THE ATTACHED MAPLESHEET. In the attached code, the 'zoom out' on the blue cylinder is not conserved when I saved the maplesheet but it doesn't change the essential question which is how does one control the zoom programmatically. If you yourself adjust the zoom of the blue cylinder and the run tabulate(), you will see how it resets the plots settings to some default set of values.
How_do_I_programmatically_control_the_zoom_in_a_3d_plot.mw
with(plots)
with(plottools)
with(DocumentTools)
Plot two cylinders with plottools and plot3d. Zoom out on the blue cylinder a little.
c1 := display(cylinder([1, 1, 1], 1, 3), orientation = [45, 70], scaling = constrained, color = red, size = [300, 300])
c2 := display(cylinder([1, 1, 1], 1, 3), orientation = [45, 70], scaling = constrained, color = blue, size = [300, 300])
Use tablate to embed the 3d plots in a visual array, for reasons not discussed here.
DocumentTools:-Tabulate([c1, c2], exterior = none, interior = none)
"Tabulate4"
Notice how the use of tabulate( ), changes the zoom of the individual plots to some default. There are two questions: 1. How do I programmatically control the zoom of a 3d plot with display( )? I don't want to have to click buttons with the mouse to arrive at my ideal zoom level. 2. How do I programmatically control the zoom of a 3d plot when using Tabulate( ) which envokes the default plot settings?
Below is a screenshot of the zoom buttons I want to control programmatically.
Download How_do_I_programmatically_control_the_zoom_in_a_3d_plot.mw
1. Plot two cylinders with plottools and plot3d. Zoom out on the blue cylinder a little.
2. Use tablate to embed the 3d plots in a visual array, for reasons not discussed here.
3. Notice how the use of tabulate( ), changes the zoom of the individual plots to some default. There are two questions: 1. How do I programmatically control the zoom of a 3d plot with display( )? I don't want to have to click buttons with the mouse to arrive at my ideal zoom level. 2. How do I programmatically control the zoom of a 3d plot when using Tabulate( ) which envokes the default plot settings
I learnt that MapleFlow (MF) was a product similar (and better) than MathCad (MC). I have a old copy of MC, v.11 (with Maple symbolic engine) and I compared it with MF from my engineering dep.
Can one kindly explain why Sum of a simple Matrix does not work, if the index is placed as exponent? Here what I did:
I have the following partial differential equation. I want all terms with 'diff' to be moved to the left side of the equation and all source terms to be moved to the right side of the equation.
diff(u(x, t), t, t) + 3 + 2*diff(u(x, t), t) + 4*t + x^2 + x^3/3 + diff(u(x, t), t, x, x) + diff(u(x, t), x, x, x, x) = x*t^2;
Is there a comprehensive solution for such purposes?
The desired result:
diff(u(x, t), t, t) + 2*diff(u(x, t), t) +  diff(u(x, t), t, x, x) + diff(u(x, t), x, x, x, x) = x*t^2-x^3/3 -x^2-4*t -3;
Can anyone guide me?
Best wishes,
Why Maple gives this error on solving first order linear ode using ODESteps?
26004
`The "Physics Updates" version in the MapleCloud is 1744 and is the same as the version installed in this computer, created 2024, April 17, 19:33 hours Pacific Time.`
ode:=diff(y(x),x)+x*y(x)=1;
ic:=y(0)=0;
dsolve([ode,ic]);
diff(y(x), x)+x*y(x) = 1
y(0) = 0
y(x) = -((1/2)*I)*exp(-(1/2)*x^2)*Pi^(1/2)*2^(1/2)*erf(((1/2)*I)*2^(1/2)*x)
Student:-ODEs:-ODESteps([ode,ic])
Error, (in Student:-ODEs:-OdeSolveOrder1) invalid input: too many and/or wrong type of arguments passed to solve; first unused argument is _C1
Download odesteps_fail_may_10_2024.mw
ps. also reported to Maplesoft customer support.
First 143 144 145 146 147 148 149 Last Page 145 of 2463
