f1 := expand((a1*x^2+b1*x+c1)^n);
f2 := a1*x^2+b1*x+c1;
solve([coeff(f1, x, 4) = coeff(f2, x, 4),
coeff(f1, x, 3) = coeff(f2, x, 3),
coeff(f1, x, 2) = coeff(f2, x, 2),
coeff(f1, x, 1) = coeff(f2, x, 1),
coeff(f1, x, 0) = coeff(f2, x, 0)], [a1,b1,c1,d1]);
hi,
i cant solve this
int(1/1-exp(a*x)*erfc(a*x))
Vector([a, b]);  <a, b>;  # Identical results
a:=[1, 2]:  b:=[3, 4]:
Vector([a, b]), <a, b>;   # Different results. Why?
I have a vector of lists, and each list is composed of indexed names.  For each list, I would like to assign all the indexed names in the list to the first variable of the list.  Right now, I'm trying to select the entries of the list using the op command and then assign one to the other, and get the following error:
Error, invalid left hand side in assignment
June_29.mw
how to convert decimal number into given decimal number like algebra
for example, convert 191.715 , given a=12.2, b=3.5
how to find this a^2 + b^3
Hello, I am a student typing up my homework assignments with maple, and I am takinng Inferential Statistics.  I can't figure out how to make the bar over a variable, so I can note the average.  It is just a line over a letter.  Kind of when notating a vector without the arrow.  It would be very helpful because I can't figure out how to make that symbol, it is not listed on the symbols list on the left side.
hi.i encountered this erroe  [Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system] with solving set of differential equation.please help me.thanks a lot
dsys3 := {`1`*h1(theta)+`1`*(diff(h1(theta), theta, theta))+`1`*(diff(h2(theta), theta))+`1`*(diff(h2(theta), theta, theta, theta))+`1`*h3(theta)+`1`*(diff(h3(theta), theta, theta))+`1`*(diff(h1(theta), theta, theta, theta, theta)) = 0, `1`*h2(theta)+`1`*(diff(h2(theta), theta, theta, theta, theta))+`1`*(diff(h2(theta), theta, theta))+`1`*(diff(h1(theta), theta))+`1`*(diff(h1(theta), theta, theta, theta))+`1`*(diff(h3(theta), theta))+`1`*(diff(h3(theta), theta, theta, theta)) = 0, h3(theta)^5*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h3(theta), theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h3(theta), theta, theta, theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+h1(theta)*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h1(theta), theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h2(theta), theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+(diff(h2(theta), theta, theta, theta))*h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+h3(theta)^4*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)+h3(theta)^4*(diff(h2(theta), theta, theta, theta, theta, theta, theta))*(`1`+ln(h3(theta))^2*`1`+2*ln(h3(theta))*`1`)-beta*h3(theta)^3*`1`-chi*ln(h3(theta))^2*`1`/kappa-chi*`1`/kappa-2*chi*ln(h3(theta))*`1`/kappa = 0, h1(0) = 0, h1(1) = 0, h2(0) = 0, h2(1) = 0, h3(0) = 1, h3(1) = 1, ((D@@1)(h1))(0) = 0, ((D@@1)(h1))(1) = 0, ((D@@1)(h2))(0) = 0, ((D@@1)(h2))(1) = 0, ((D@@1)(h3))(0) = 0, ((D@@1)(h3))(1) = 0, ((D@@2)(h3))(0) = 0, ((D@@2)(h3))(1) = 0}; dsol5 := dsolve(dsys3, 'maxmesh' = 600, numeric, output = listprocedure);
Let be given the complex number z  satisfying condition abs(z+3-2I)=3. I want to find the set of points representing the complex number w, knowing that w - z = 1 +3I. I tried
Restart:
assume(a::real, b::real,x::real, y::real);
z:=x+y*I;
w:=a+b*I;
abs(w-1-3*I+3-2*I)=3;
Edit
Restart:
Set:=abs(z+3-2*I):
w:=x+y*I;
sol:=solve(w - z =1+3*I,{z});
z1:=subs(sol,Set);
A:=abs(z1);
map(x->x^2,A=3);
I do have some m files and they containing procedures where i am interested in
How can i read those procedures in a m file
Hi Maple friends. :)
I would like to graph and solve: 2*sin(2 x)=1 for the interval 0<=x<=360. My textbook gives the answers of x=15, 75, 195 and 225.
But I get an error messages:
plot(2*sin(2*x) = 1, x = 0 .. 360);
Error, invalid input: plot expects its 1st argument, p, to be of type {array, list, rtable, set, algebraic, procedure, And(`module`, appliable)}, but received 2*sin(2*x) = 1
solve(2*sin(2*x) = 1, x = 0 .. 360);
Error, invalid input: too many and/or wrong type of arguments passed to solve; first unused argument is x = 0 .. 360
Any help would be appreciated! Thanks in advance.
x: =Matrix([[a1,a2],[a3,a4]])
after some calculation,
assign(%)
a1 etc have value,
how to make a1,a2,a3,a4 back to variable in maple 12?
How to calculate floor(10^(10^(10^(10^(10^(-10^10))))))? My simpleminded try is
Error, numeric exception: underflow
PS. I think that is about 10^(10^10).
m := Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]]);
m2 := Determinant(m-Matrix([[1,0,0],[0,1,0],[0,0,1]]));
1. which family of polynomials do m2 belong to?
2. how to analyze m2?
What´s the error here??????
Solução do Sistema de EDO's por Transformada de Laplace
with(inttrans):
eq1 := diff(x(t), t)+(2.2*x(t)*y(t)+0.5e-1*x(t)/(5+0.5e-1*t)) = 0;
diff(x(t), t)+2.2*x(t)*y(t)+0.5e-1*x(t)/(5+0.5e-1*t) = 0
eq2 := diff(y(t), t)+(2.2*x(t)*y(t)-(0.5e-1*(0.25e-1-y(t)))/(5+0.5e-1*t)) = 0;
diff(y(t), t)+2.2*x(t)*y(t)-0.5e-1*(0.25e-1-y(t))/(5+0.5e-1*t) = 0
eq3 := diff(z(t), t)-2.2*x(t)*y(t)+0.5e-1*z(t)/(5+0.5e-1*t) = 0;
EQ := [eq1, eq2, eq3]:
for i to 3 do La[i] := laplace(EQ[i], t, s) end do;
s*laplace(x(t), t, s)-1.*x(0.)+2.200000000*laplace(x(t)*y(t), t, s)+laplace(x(t)/(100.+t)^1., t, s) = 0.
-1.*y(0.)-0.2500000000e-1*(exp(100.*s))^1.*Ei(1., 100.*s)^1.+1.*s^1.*laplace(y(t), t, s)^1.+2.200000000*laplace(x(t)^1.*y(t)^1., t, s)+1.*laplace(y(t)^1./(100.+1.*t)^1., t, s) = 0.
s*laplace(z(t), t, s)-1.*z(0.)-2.200000000*laplace(x(t)*y(t), t, s)+laplace(z(t)/(100.+t)^1., t, s) = 0.
LL := subs({laplace(x(t), t, s) = X, laplace(y(t), t, s) = Y, laplace(z(t), t, s) = Z}, [La[1], La[2], La[3]]);
[s*X-1.*x(0.)+2.200000000*laplace(x(t)*y(t), t, s)+laplace(x(t)/(100.+t)^1., t, s) = 0., -1.*y(0.)-0.2500000000e-1*(exp(100.*s))^1.*Ei(1., 100.*s)^1.+1.*s^1.*Y^1.+2.200000000*laplace(x(t)*y(t), t, s)+1.*laplace(y(t)/(100.+t)^1., t, s) = 0., s*Z-1.*z(0.)-2.200000000*laplace(x(t)*y(t), t, s)+laplace(z(t)/(100.+t)^1., t, s) = 0.]
sol := solve(LL, [X, Y, Z]):
assign(sol):
SOLS[X, Y, Z]:
SOLT := map(invlaplace, [X, Y, Z], s, t);
[-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(x(_U1)/(100.+_U1), _U1 = 0. .. t))+x(0), -1.*(int(y(_U1)/(100.+_U1), _U1 = 0. .. t))-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))+y(0)+0.2500000000e-1*ln(1.+0.1000000000e-1*t), 2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(z(_U1)/(100.+_U1), _U1 = 0. .. t))+z(0)]
SOLTT := evalf(subs({x(0) = 0.5e-1, y(0) = 0, z(0) = 0}, SOLT));
[-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(x(_U1)/(100.+_U1), _U1 = 0. .. t))+0.5e-1, -1.*(int(y(_U1)/(100.+_U1), _U1 = 0. .. t))-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))+0.2500000000e-1*ln(1.+0.1000000000e-1*t), 2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))-1.*(int(z(_U1)/(100.+_U1), _U1 = 0. .. t))]
xx := evalc(Re(SOLTT[1]));
yy := evalc(Re(SOLTT[2]));
0.2500000000e-1*ln(abs(1.+0.1000000000e-1*t))-1.*(int(y(_U1)/(100.+_U1), _U1 = 0. .. t))-2.200000000*(int(x(_U1)*y(_U1), _U1 = 0. .. t))
zz := evalc(Re(SOLTT[3]));
plot([xx, yy, zz], t = 0 .. 500, legend = [x, y, z]);
Warning, expecting only range variable t in expression -2.200000000*int(x(_U1)*y(_U1),_U1 = 0. .. t)-1.*int(x(_U1)/(100.+_U1),_U1 = 0. .. t)+.5e-1 to be plotted but found names [_U1, x, y]
Download laplace.mw
Dear Friends
I have a problem in CPU time in MAPLE.
I write the codes in maple related to the nonlinear heat conduction problem in one dimension by Collocation method, but after 30 minutes no solution has been observed!!!
My codes are for N=4!, i.e., I have 25 equations with 25 unknowns!!!
If MAPLE can not solve this simple system, How can I solve 3 dimensional pdes by N=9,
In this case, I have 1000 equations with 1000 unknowns!!!
please help me and suggest me a fast iterative solver.
I should remark that my problem is stated in this paper
http://www.sciencedirect.com/science/article/pii/S1018364713000025
If there exist any other suitable method, I will be happy to receive any support.
With kind regards,
Emran Tohidi.
> restart;
> Digits := 20; N := 4; st := time(); u := sum(sum(a[m, n]*x^m*t^n, m = 0 .. N), n = 0 .. N); u := unapply(u, x, t); ut := diff(u(x, t), `$`(t, 1)); ut := unapply(ut, x, t); ku := simplify(1+u(x, t)^2); ku := unapply(ku, x, t); ux := diff(u(x, t), `$`(x, 1)); ux := unapply(ux, x, t); K := ku(x, t)*ux(x, t); K := unapply(K, x, t); Kx := diff(K(x, t), `$`(x, 1)); Kx := unapply(Kx, x, t); f := proc (x, t) options operator, arrow; x*exp(t)*(1-2*exp(2*t)) end proc;
> S1 := {seq(u(i/N, 0)-i/N = 0, i = 0 .. N)}; S2 := {seq(u(0, j/N) = 0, j = 1 .. N)}; S3 := {seq(u(1, j/N)+ux(1, j/N)-2*exp(j/N) = 0, j = 1 .. N)}; S4 := {seq(seq(Kx(i/N, j/N)+f(i/N, j/N)-ut(i/N, j/N) = 0, i = 1 .. N-1), j = 1 .. N)}; S := `union`(`union`(`union`(S1, S2), S3), S4); sol := DirectSearch:-SolveEquations([op(S)], tolerances = 10^(-4), evaluationlimit = 1000000);
> assign(sol);
> u(x, t);
> CPUTIME := time()-st;
plot3d(u(x, t) - x exp(t), x = 0 .. 1, t = 0 .. 1)
First 1450 1451 1452 1453 1454 1455 1456 Last Page 1452 of 2471
