Hello All,
From the list
t1 := [((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2+8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), -((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2+8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), ((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2-8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2))^(1/2), -((-4*Pi^2-beta^2+4*beta^2*Q^2*Pi^2-8*I*Pi^2*beta*Q)/(4*Pi^2+beta^2-4*beta^2*Q*Pi+4*beta^2*Q^2*Pi^2...
Im new to programming in maple and need some help.
I have this function, lets say it is f= x2 and i have a constant called c (lets say it is 2 for now)
I use the command subs, but this could be wrong.
i write :
subs(x=c,f)
The output the becomes 4, when i would like i to be 22 . Put in other words, how can I get maple NOT to calculate the result?
I am trying to use second quatized operators in the Maple Physics package.  These operators obey the commutation relations:
[psiA(x1),psiB(x2)] = Dirac(x1-x2) and [psiA(x1),psiC(x2)] = 0 for example.  The commutator therefore depends on the arguments of the operators.
Using:
> with(Physics);
> Setup(quantumoperators = {psiA,psiB,psiC},algebrarules={%Commutator(psiA(w),psiB(v)) = Dirac(w-v),%Commutator(psiA(w),psiC(v))=0})
I'm new to Maple and find some aspects of the syntax and UI confusing.  The manual isn't much help.  In the case of "e"...
1) If I type in:    evalf(e^1,10) by just typing the letter e from the keyboard, I get back the letter e.  But if I go into the palette and select the expression e^a, and put it in evalf that way (for a=1) I get back a numerical value for e.  I can see that one of these e's is italicized and one isn't...???
I have been using the pdesolve command to solve the heat conduction equation in an infinitely long cylinder, but now I need to incorporate the convection that occurs at the end surfaces, in the case of a short cylinder.
The following is the code I have been using:
>> PDE := diff(Theta(r, t), r, r)+(diff(Theta(r, t), r))/r = (diff(Theta(r, t), t))/alpha;
>> pdsolve(PDE);
I have tried to add...
The problem is, as said, how can i get a "math output" when having something typed into my package..
An example of this could be:
printf("\Your function is: x^2");
When typing it like this my output becomes x^2, I would like it to become x2 , how can I fix this?
- Slangers
how can i draw a polygon with labeled vertex by numbers which are inside of that polygon§
I have Maple 15.
I used one of the "Assistants" to solve a problem.
It offered me the command line code that would have solved the problem without the Assistant.
I saved that code to a file, and later tried to paste it into a new Worksheet.
It won't execute.  I can't convert it to anything that executes.
I assume Maple is viewing it as text, and not something that is executable.
sol1 := dsolve([diff(x(t),t) = y(t), diff(y(t),t) = -x(t), x(0) = 0, y(0) = 1...
L include kinetic energy
when F = diff( diff( L, dx), t) - diff(L,x)
i need to diff L with respect to dx, however, there is no dx in maple, how to do above equations?
with(DifferentialGeometry):
DGsetup([x],M):
ExteriorDerivative(x^2);
invalid frame: DGframe_data[0][1][2]
how to diff x^2 to get 2*x*dx with above command?
How come that I don't have a Maple Questioner Badge? 2886 people question Maple and I trust it unquestionably?
Even adiban who didn't post anything on this site, has it (as well as 10 other badges and a reputation of 1000).
I have a Pupil badge, which I couldn't get without asking a question - so I've asked at least 1 question.
Let's see if I get it after asking this question.
Alec
1.at parse(sprintf("%.3f",subs(x=1, pdf))); it error said number expected for floating point format
i need to copy the whole formula to pdf := something then it can calculate
2. also it can not plot
%%%% copyright by Martin Lee 2011%%%%%%%
l := [12, 14, 27, 35, 46, 49];
sl := gfun[listtoseries](l, x, egf);
g := convert(sl, ratpoly);
g := g - subs(x=0, g);
g := g/subs(x=1, g);
parse(sprintf("%.3f",subs(x=1, g)));
parse(sprintf("%.3f",subs(x=0.9, g)));
How to reserve dx when diff a formula
when i diff x^2 , need to be 2*x*dx but it only 2*x
How to reserve dx?
How do I create a symbolic sequence with a variable number of elements, so that later I can come back and set the number of elements to an integer? Maple has inert forms for many functions (e.g. Sum and sum), but there does not appear to be anything like "Seq" which would be the inert analogue of "seq".
Here are some of my attempts
  Ls:='seq'(a[j],j=2..p);
eval(Ls,p=5);
subs(p=5,Ls);
Ls:=seq(a[j],j=2..5);
Ls:='seq'(a[j],j=2..5);
I have this problem when I use assume and assign a value to an assumed parameter.
Example:
restart:assume(beta>0):
g:=int(Sum(5*sin(n*beta*x),n=1..5),x) ;
beta:=1;
g;
Normaly beta:=1 is replaced into g. The result obtained is function of beta and beta:=1 is not replaced.
Why beta:=1 is not replaced in g ?
Thanks for suggestion
First 1893 1894 1895 1896 1897 1898 1899 Last Page 1895 of 2460
