I have this piecewise function:
Mr := theta->piecewise(theta>=0 and theta<=(Pi/(2*p))-(beta/2),0,theta>(Pi/(2*p))-(beta/2) and theta<=(Pi/(2*p))+(beta/2),Br/mu0,theta>(Pi/(2*p))+(beta/2) and theta<=((3*Pi)/(2*p))-(beta/2),0,theta>((3*Pi)/(2*p))-(beta/2) and theta<=((3*Pi)/(2*p))+(beta/2),-Br/mu0,theta>((3*Pi)/(2*p))+(beta/2) and theta<=2*Pi/p,0);
I want to calculate the Fourier serie of this function without giving...
I use a simple for loop below to illustrate. For each loop through the index value I want to add the result of that loop to a list h. This is how I tried to do it but I can't quite get it because the value in h1 gets updated for each step through the for loop.
for i from 1 to 10 do
u[i]:=2*i;
h:=[]; h1:=[u[i],op(h)]
So after the for loop is terminated I want to be left with a list h:= ...
The coefficient of determination also known as R^2 tells how good a fit is. If R^2=1 the fit is perfect an if R^2=0 it's useless. But Maple don't have a native function to calculate R^2. I seached and found this:
http://www.mapleprimes.com/questions/40171-Determining-An-Equations-Accuracy
But it only describe how to calculate R^2 on a
Why does collect only work sometimes?
I will show with a simple example.  I can do this
a := 5*x^2-4*x+3;
                             a := 5 x2  - 4 x + 3
h := exp(x)*a+exp(x);
How to get the polynomial successfully why return error expect a series valuation 1, what do it mean?
l := [12,14,27,35,46,49];
sl := listtoseries(l,x,revogf);
convert(sl,ratpoly);
with(gfun):
gfun['maxdegcoeff'] := 50:
gfun['maxdegeqn'] := 2:
i use number of balls in each basket to get a list, but all functions return fail? where is wrong? and how to use correctly?
l := [0,0,0,2,0,0,0,0,1,1,0,1,0,1,1,0,0,0,0,0,0,1,0,0,1,0,1,1,0,1,1,0,1,0,2,0,0,0,1,0,0,0,0,0,1,1,0,1,1]:
listtoratpoly([1,1,2,3,5,8,13],z);
listtoalgeq(l,y(x));
l := [12,14,27,35,46,49,31];
listtohypergeom(l,z);
guessgf(l,z);
I'm modeling a magnetic field and I don't know how to plot the corresponding vector field:
For each point  M I have the vector B(M) as a list.
Could you explain me how to transform it as a "real vector" first and how to plot these vectors then??
Thanks in advance!
I've got a question about model integration process.
I've tried to solve quite complex mechanical model and this messages have appeared.
Computing initial conditions...
Iterate re-initialization...
done.
Simulating...
CreateDataRecord: using dsolve method=rosenbrock_dae
Generating configuration 1
Integrating configuration...
Re-initializing after event at t=4.94271387307997e-009...
How could we get module which contain this export, for example
I have
m1 := module export a; end module;
 temp := m:-a;
evalb(temp = a);
 # false
evalb(temp = m:-a);
 # true
 but how could I get back the module like this
temp2 := getModule(temp);
temp2;
 # m
evalb(temp2 = m) ;
# true
I'm trying to model a magnetic field with maple.
In order to do that, I compute a (huge) sum and integrals of real and posive numbers.
The problem is that for some points, when I compute the norm of this field I get an imaginary number with a very small imaginary part (egs -2, 27293.1844462+1.42305652280*10^(-84)*I ).
How can I get rid of it?
thx in advance
Can anyone explain this?
> A := Matrix(7, 7, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (2, 6) = 0, (2, 7) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0, (3, 6) = 0, (3, 7) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 0, (5, 6...
Mapleprimes has really painfully slowed down in the last day.  What's happened?
After I post this message mapleprimes will refresh and refresh a few times (not that it hasn't done that before) but now that it's slower again, it's quite frustrating, I can't post even check primes for at least 15 minutes after a post.  Back to the old days of primes 2 I guess.  I can't tell if mapleprimes making progress but it seems like were going backwards just as much as we go forwards.
Good afternoon.
I have a problem.
i want ot add the procedure friccion(x1q1(t), x2q1(t), 1) into the dynamic system equation, because the fricction change with the velocity.
I don´t know how can solve that
Please help me o give some ideas.
thank you
30-03-2011-robot-man.mw
My question is very easy I have a^2+b^2*a+b+1 and I want b^2*((a^2)/(b^2)+1/b^2+a)  how could I ask this to maple?
In particular my expression is
Hello.
I can't find a very "basic" tutorial about data file plotting and I have very simple questions.
Assume that we have a file that contains :
0.5 0.2
0.3 0.9
0.4 0.1
0.7 0.6
The first thing to do is to read data. I have no problems for that :
mydata:=readdata("test.txt",2)
Then
mydata=[[0.5,0.2],[0.3,0.9],[0.4,0.1],[0.7,0.6]]
Question n°1
First 1895 1896 1897 1898 1899 1900 1901 Last Page 1897 of 2460
