I need to use the flexible beam in my model. I want to know if the component's correctness can be guaranteed, but I can't find any correlative documents or thesis, only find an article titled "Dymola – Flexible Bodies library". Is the flexible beam in maplesim similar to this? based on the modelica library? applied the finite element method? Some detailed information is very helpful.
I have a little problem, I tried to find out the Temperature of the Electrons in a Plasma,
the cross section name is sigma and I'm working with noble gases and there Threshold energies.
In the end I wand to find out  T_e but there comes only "Warning, solutions may have been lost"
Can anyone help me please?
Thank you very much
greetings from munich
I want to solve this
2010.pdf
I'm dealing with a complicated expression:
exp((1/6)*kappa*R^2-0.5000000000e-1/R)*sqrt(x)-1+(1/2)*kappa*exp((1/6)*kappa*R^2-0.5000000000e-1/R)/(sqrt(x)*(1+coth(exp((1/6)*kappa*R^2-0.5000000000e-1/R)*sqrt(x))))-(1/6)*kappa*(exp((1/6)*kappa*R^2-0.5000000000e-1/R))^2+0.5000000000e-1/exp((1/6)*kappa*R^2-0.5000000000e-1/R) = 0.
I want to plot various graphs of kappa vs x for different values of R on one axis. How is this possible in Maple?...
Is there a possiblity to create custom multibody components with the custom component template? Is there another template available for this purpose, or do you propose another solution?
Thanks a lot,
Bernd
Can anyone help me convert this outdated maple code into something current? Particularity I need help finding the equivalent command to "stats:-empirical" as I can't even find documentation for it.
with(stats): with(linalg): with(StringTools):
P1:=matrix([[.6,.3,.1],[.4,.5,.1],[.3,.4,.3]]);
j:=1:  res:="S":
for i to 50 do
    j:=random[empirical[op(convert(row(P1,j),list))]]():
I appreciate that maple can solve equations so quickly, but i would like to solve the equation myself and only use the basic features of maple so that I can practice the theory. For example:
for the differential equation y'' + 3y' + 2y = 0
I would like to assume y = ce^rt then plug it in and get something like
c*(r^2*e^rt + 3r*e^rt + 2e^rt) = 0
maple runs into problems regarding:
-whether the parameters are functions or constants
Download problemexample.mw
Hello Maple wizards,
After reading the mapleprimes post http://www.mapleprimes.com/posts/36097-Add-Map-And-Seq on the hidden complexities of using thread-safe versions of add (Threads:-Add), I have been struggling to correct a problem similar to the "escaped k" problem described by Joel Riel...
I have a family of functions characterized by
f:=x^2+b*x+b*3;
I plotted some of them:
graph1:=x->subs(b=0,f):
graph2:=x->subs(b=2,f):
graph3:=x->subs(b=4,f):
plot([graph1(x),graph2(x),graph3(x)],x=-10..3,y=-5..15);
And now I want to draw a line through all maxima into the same diagram. The maxima have the coordinates (-1/2*b | -1/4*b^2+3*b). I managed to create a pointplot:
The help page mentions that filledregions=true, that regions defined by curves are filled with different colors
implicitplot({y = x^2, y = x+5}, x = -10 .. 10, y = -10 .. 10, numpoints = 5000, filledregions = true)
What I expected was that the region between the line and the curve would be a different colored region.
Hi friends,
I am running an application which consumes big memory (~2GB); and in the middle of calculation I got this error:
Kernel connection lost... and the message is:
Execution stopped: Memory allocation failed! Please see ?alloc for more details...
Please let me know how I can increase memory alocation capacity of maple (version: Maple 13)
Hi guys,
I am new to Maple, so forgive my ignorance!
I need to define the implicit function R:=exp[(L/2)-(m/2R)] for use. When I attempt this the normal way, I get a 'recursive argument' error. How can I get round this?
Jimmy
I tried to carry out an advanced plotting task and I am not even sure, if Maple is able to do that.
In a Cartesian coordinate system with axis x=1..100 and y=0..1, I wanted to plot three graphs at once and have the parameters n, p and rho to be interactive.
Here are the graphs:
(1) y=1-exp(-rho*x);  #depending on x and rho
(2) y=-(1-p)^n+(p/(1-p)+1)^n*(1-p)^n+(1-p)^(n-1)*((exp(rho)*(-1+p)-p)*((exp(rho)*(-1+p)-p)/(exp(rho)*(-1+p)))^(n-1)-exp(rho...
with the following input:
with(VectorCalculus);
X := r -> sqrt(2/Pi)*alpha*exp(-alpha^2*(r.r));
a_0:=a*<1/(2*sqrt(3) , 1/2>;
r:=<x,y>;
K:=<k_1, k_2>;
assume(alpha::real);
assume(alpha>0);
assume(k_1>0);
assume(k_2>0);
assume(k_1::real);
assume(k_2::real);
eq1:=int( X(r-a_0) , x=-infinity .. infinity);
Why is the ouput :
I am trying to create a semilogplot-type plot with the axis tickmarks labeled as a typeset version of "10^0","10^-1","10^-2", etc.
I have tried a few different approaches. If I used semilogplot, I don't seem to be able to get the descending order of exponents (0,-1,-2, etc.) as I go right on the x-axis. They are also not typeset.
I can get around the descending order rather easily by just using plot and doing some remapping of my functions....
First 2012 2013 2014 2015 2016 2017 2018 Last Page 2014 of 2463
