When you export a mw maplet file ****.mw  to a ****.maplet file, and when you launch this file ****.maplet with mapletviewer.exe, the following message appears at start: "Error launching maplet splash screen".
Kind regards,
ALS
I'm writing an animation of the Spiral of Theodorus. I'm trying to get it to display a composition of the triangles as it animates. If i change the code to insequence=false it displays them all at once, and doesn't animate. Here is the little bit of code I wrote:
g := sum(arctan(1/sqrt(n)), n = 1 .. i)
p := seq(plots[polygonplot]([[0, 0], [sqrt(k+1)*cos(subs(i = k, g)), sqrt(k+1)*sin(subs(i = k, g))], [sqrt(k)*cos(subs(i = k-1, g)), sqrt(k)*sin(subs(i = k-1, g))]], color = white), k = 1 .. 16); plots[display]([p], insequence = true);
HI, URGENT! pls help.
the monster is
f := int(x^2/(e^x-1), x = y .. infinity);
y is some finite positive number. My goal is to plot f against y
I've tried to use either evalf or ApproximateInt to get a number but failed. The error msg either says object is too big or maple can't allocate enough resource.
pls help!
Hi everybody
I want to plot the piecewise function:
f(x)={ -1<=x<=0,-1<=y<=0,  x+y
0<x>1, 0< y <1, 3xy
I write en maple:
k := proc (x, y) if -1 <= x and x <= 0 and -1 <= y and y <= 0 then x^2+y^2 else if 0 <= x and x <= 1 and 0 <= y and y <= 1 then 3*x*y end if end if end proc;
plot3d(k, x = -1 .. 1, y = -1 .. 1);
the PC's send me this message:
I got this code in Maple >restart: lambda[1] := 3; lambda[2] := 4; lambda[3] := 5; lambda[s] := lambda[1]+lambda[2]+lambda[3]; u := 20; deltat:= 1; c:=1; Q:=10; >MultivariateNormalSample := proc (Sigma, N) local A, R, d; d := LinearAlgebra[RowDimension](Sigma); R := Matrix(LinearAlgebra[LUDecomposition](evalf(Sigma), 'method' = 'Cholesky'), datatype = float[8]); A := Statistics[Sample](Normal(0, 1), d*N); A := ArrayTools[Alias](A, [1 .. d, 1 .. N]); rtable_options(A, subtype = Matrix); return R.A; end proc; >with(Statistics): U:=u;
Hello! I have been learning Maple recently. My teacher gave me the task to simulate the kinematics of heart ventricles with subsequent calculation of their volume.
Hi everyone.
I have a loop in which initial data of ODE is found on every iteration and is substituted to find new solution. The system is striking 1 or -1 and x'(t) changes its sign, to -x'(t)
I do it this way (k[i] stands for the values of time t):
Hi everyone.
Is there a way to display a table of all variables (name, type, dimensions), that I defined in my worksheets. Something like the workspace in MATLAB. Maybe also to edit the values in a fast way.
How do I change the dimension of the Visualization?
Imagine a simple pendulum
In the construction mode it looks like this:
But if I change the length of the RBF from 1 meter to 1cm it looks like this:
Hi, can anyone point out what I've done wrong in setting up this PDE solution: PDE:=diff(u(x,t),t$2)+diff(u(x,t),t)-diff(u(x,t),x$2)=sin(Pi*x/l); BCs:=u(0,t)=0,u(l,t)=0; ICs:=u(x,0)=0,D[2](u)(x,0)=0; ans := pdsolve([PDE,BCs,ICs],u(x,t)) assuming l
Hi colleagues,
How to determine if a point belongs to a plane, considering the uncertainties of the coordinates of the point?
I'm stuck in this task. I remember seeing a taks that makes this task, but does not take into account uncertainties;
Gracias
How can I have a 3d plot rotate?
Hello. There is a random value X with normal distribution and there is a function f=e^(r*X). So how can I get a variance for f? I'm doing T := Distribution(PDF = (proc (x) options operator, arrow; e^(r*piecewise(x
Am I using map correctly here?  And is this a good way to vary the size of points for a set of data?
a:=[[1,1,1],[2,2,1],[3,4,4.5],[2,1,2.4]]
b:=map(a->[a[1],a[2]],a)
c:=ListTools[Flatten](map(a->[a[3]],a))
d:=seq(pointplot(b[i],symbolsize=c[i]*10),i=1..nops(b))
display(d);
First 2026 2027 2028 2029 2030 2031 2032 Last Page 2028 of 2460
