Is there a way to display a table of all variables (name, type, dimensions), that I defined in my worksheets. Something like the workspace in MATLAB. Maybe also to edit the values in a fast way.
How do I change the dimension of the Visualization?
Imagine a simple pendulum
In the construction mode it looks like this:
But if I change the length of the RBF from 1 meter to 1cm it looks like this:
Hi, can anyone point out what I've done wrong in setting up this PDE solution: PDE:=diff(u(x,t),t$2)+diff(u(x,t),t)-diff(u(x,t),x$2)=sin(Pi*x/l); BCs:=u(0,t)=0,u(l,t)=0; ICs:=u(x,0)=0,D[2](u)(x,0)=0; ans := pdsolve([PDE,BCs,ICs],u(x,t)) assuming l
Hi colleagues,
How to determine if a point belongs to a plane, considering the uncertainties of the coordinates of the point?
I'm stuck in this task. I remember seeing a taks that makes this task, but does not take into account uncertainties;
Gracias
How can I have a 3d plot rotate?
Hello. There is a random value X with normal distribution and there is a function f=e^(r*X). So how can I get a variance for f? I'm doing T := Distribution(PDF = (proc (x) options operator, arrow; e^(r*piecewise(x
Am I using map correctly here?  And is this a good way to vary the size of points for a set of data?
a:=[[1,1,1],[2,2,1],[3,4,4.5],[2,1,2.4]]
b:=map(a->[a[1],a[2]],a)
c:=ListTools[Flatten](map(a->[a[3]],a))
d:=seq(pointplot(b[i],symbolsize=c[i]*10),i=1..nops(b))
display(d);
Please answer my question about my math lab class.
when I solve the equation about "     cos(2*theta)=1/2       "   by   " solve(cos(2*theta)=1/2,theta);"
I just get the answer "Pi/6" only
but I want the all root within "0 to 2*Pi"
How can I get the all root by limitting area of root??
One thing I am struggling to understand is the following:
If you have three randomvariables (similarities to the hat puzzle) then you
can get a positive expected value if you for example bet that r1 will be negative
when r2>0 and r3>0 and that r1 will be positive when r2<0 and r3<0. It follows
because the probability of getting [+,+,+] + [-.-.-] = 0.5^3+0.5^3=0.25. Which
means that the probability of success for our introduced betting strategy is 0.75.
Please would you help me how to make an animation of nonlinear waves, in other words, animation of solitons with Maple
I have a student who wants to compute points and add the points to a displayed graph as they are computed, without having new axes and a new graph created as additional points are added to the list. Something like an animation, but slightly different in its effect.
For example, suppose that 100 points will eventually be computed, but one wants the first seven points to be displayed even before the eighth is computed, and certainly long before the 100th point is computed.
How do I show the 126 different permutations of tic tac toe?
Hi! We just got the new Maple 14 and I'm having problem creating the resource file by using this command: "Maple14WindowsInstaller.exe -r". My steps are that I want Maple 14 to be the default application, no shortcut on the desktop and we are using a network server for our licenses. But, each time it gets to the installing part and seems to do nothing at all! In fact, once I let the installer run for 2 hours and it didn't installs anything. In other words, I can't create a resource file. I tried to run it on VMware workstation using Windows XP Pro SP3 French Edition, tried to run it on a normal computer running Windows XP Pro SP3 French Edition, etc. without any success. So any help will be greatly appreciated!
Thanks in advance for any help!
I have a set of points and 2 questions
Each point has different values associated with them.  I want each value of the points to be displayed as a specific symbolsize.  The only way I could figure out how to do that was to create a list of the points of one value and set it at a specific size, for example like this.
Suppose pointset a has value 1
a:=[[1,2],[3,4],[5,6],[4,4]]
and suppose pointset b has value 2
b:=[[2,2],[3,3],[4,4],[2,3]]
I think the only way to do what I want is this
I'm running OSX and Maple 14. Now when I do ]>? mod for example it (maple) is launching a Maplet (which crashes) in order to do something (perhaps bring up a Java version of the docs?). How do I disable this and get the old (text based) man pages back?
First 2030 2031 2032 2033 2034 2035 2036 Last Page 2032 of 2463
