How can I read a file that has " in the context correctly? (see the attached file)
Download 7845_not_good.txt
View file details
> read "notgood.txt";
Warning, incomplete quoted name;  use ` to end the name
on line 1, unexpected end of input
Error, while reading `notgood.txt`
I have attached a maple document with some questions.  Pleas answer in an attached document since my web browser of some reason cannot read maple-math in the forum.
By the way admin should take a look at the
question1:
DEtools[phaseportrait]
([diff(y(x),x)=-y(x)],y(x),x=-2.2,[[y(-2)=2],[y(-2)=1],[y(-2)=-2]],dirgrid=[17,17],arrows=LINE,axes=NORMAL);
This is the version in Maple 7?
After accessing to the help file,maybe it should be
with(DEtools):
phaseportrait(diff(y(x),x)=-y(x),y(x),x=-2.2,[[y(-2)=2],[y(-2)=1,[y(-2)=-2]],dirgrid=[17,17],arrows=LINE,axes=NORMAL);
but can't generate the resuls.
dirgrid seems not exist in the help.
question2:
for what value(s) of m the function is increasing (Xderivative > 0)/decreasing (Xderivative < 0):
m * log(x) / 2^m + (1-x^m) / (1+x)^m
I got some Matrix problems to ask:
First,
A:=Matrix(3,4,[[1,2,3],[4,5,6]]);
it will fill with '0's
A:=Matrix(3,4,[[1,2,3],[4,5,6]],fill=8);
it will fill with '8's
B:=Matrix(3,4,[1,2,3,4,5,6]);
B:=Matrix(3,4,[1,2,3,4,5,6],fill=8);
it does not fill
what's the proper way to do it?
Second,
A:=Matrix(3,4,[1,2,3,4,5,6]);
convert(A,listlist);
[[1, 2, 3, 4], [5, 6, 0, 0], [0, 0, 0, 0]]
what if I want to have ONE single list as
I have Maple 12, and not MapleSim.  Has anyone stumbled across something that "runs on top" of Maple that is similar to COMSOL Multiphysics that runs on top of MATLab?  I'd like to figure out (without writing the Maple code myself...) how to import some simple 3D geometries and run some (possibly symbolic, probably numeric) simulations of electromagnetic and heat flow phenomena.  COMSOL uses FEM.  Is this something MapleSim could do?  I don't need anything that'll do "real world" geometries (i.e.
BIFURCATION DIAGRAM PROCEDURE
*xexpr is the logistic function to be iterated (we always start off at x=1/2, which will eventually attract).
*[ra,rb] is the range of the parameter.
*acc is the number of points sampled in [ra,rb]
Bifurcation := proc(initialpoint,xexpr,ra,rb,acc)
   local p1,hr,A,L1,i,j,phi:
   global r,L2:
   hr := unapply(xexpr,x);
   A := Vector(600):
   L1 := Vector(acc*500):
I am trying to generate a non-singular Matrix.
> KeyMatrix:=Mod(127,RandomMatrix(n),integer);
> if Determinant(127,KeyMatrix)=0 then
> Return(KeyMatrix);
> fi;
Basically, it asks Maple to return to
again if the current one if not invertible.
however, i have confused myself with RETURN and return
which is should i use?
casper
What is the pattern in the following polynom: (how to generate them)
1:     12 n^2 + 12 n + 1
2:    300 n^3 + 450 n^2 + 160 n + 5
3:   840 n^4+1680 n^3+1030 n^2+190 n+3
4:  1260 n^5+3150 n^4+2730 n^3+945 n^2+107 n+1
5:  27720 n^6+83160 n^5+93030 n^4+47460 n^3+10689 n^2+819 n+5
I have an expression like; 0.7x + 5e-10y, which I would like to approximate to 0.7x.
Round won't work as it will also round the 0.7 down to zero.  I have tried using he Digits command, but it seems to only work half of the time.
Is there a simple command that can put a ceiling on a number like e-5, so that any number lower than that will not be returned?
Cheers;
Robert Ward
Hi all, This is probably a simple command, but I cannot figure it out. I am using the following to spit out some results from a system of ODEs, but I can't figure out how to label the individual columns t, H, W R, etc. Any suggestions? Thanks! > file := "/Desktop/Aquifer results2/comp60.txt"; try fd := fopen(file, 'WRITE', 'TEXT'); for tt from 0 to 945 do fprintf(fd, "%a %a %a %a %a %a\n", (eval([t, H(t), Weq, Req, price, total], sol2a(tt)))[]) end do finally close(file) end try; %; >
Curious as to why the whole line, during an animatecurve plot, "wiggles" as it's being animated.
A simple example
plots[animatecurve](sin(x),x=-Pi..Pi,frames=100);
Why is that?
I want to make an overloaded function with two possible behaviours.
If the function is called with a list as parameter it shoud make something; if it's called with TWO lists as parameters, it shoud make another thing.
I tried first something like:
I was just wondering about a smart way to diff a vectorfunction.  Lets say i want to diff this vector:
v:=<5*t+1, (1/2*(-10))*t^2+50>
When i try to diff v it says:
"Error, non-algebraic expressions cannot be differentiated"
I know it's possible do do by:
<diff(v[1],t),diff(v[2],t)>
But is there a better way?
/Simon Johansen
First 2111 2112 2113 2114 2115 2116 2117 Last Page 2113 of 2459
