I wanted to try this example of Maple's help, but it gives an error message:
with(algcurves);
f := y^2-x*(x^2-1);
plot_real_curve(f, x, y, showArrows = true);
Error, (in algcurves/CurvePlot:-PlotRealCurve) too many levels of recursion
I'm interested in passing programs from Fortran to Maple, I have some queations:
1) Is it true that maple can only understand functions, and doesn't understand subroutines?
2) If Fortran function uses commands like "exp" "max" etc, is it okay?
3) If Fortran function uses external libraries (.lib, .dll) do I need to combine then somehow with the dll file I'm preparing for Maple? How?
When I plot a parametric surface:
S5 := PositionVector([VectorCalculus[`*`](u, v), VectorCalculus[`+`](u, v), VectorCalculus[`+`](u, VectorCalculus[`-`](v))], cartesian[x, y, z])
VectorCalculus[PlotPositionVector](S5, u = VectorCalculus[`-`](1) .. 1, v = VectorCalculus[`-`](sqrt(VectorCalculus[`+`](1, VectorCalculus[`-`](u^2)))) .. sqrt(VectorCalculus[`+`](1, VectorCalculus[`-`](u^2))))
please help me here:
can we simplify the answer of the following command:
diff(arctan(sqrt(b*a)/b)/sqrt(b*a), `$`(b, n))
I used convert(problem,parfrac,x) and it gave me an error saying augment not a rational function.
(3x - 1) / x(x-1)
want to diplay it like this
A/X + b/(x-1) then coming up with the answer like this 1/x + 2/(x-1).
Newb to maple and this is my first post. Thanks
how can we find:
sum((5/2+2310*n^5+5775*n^4+5019*n^3+(3507/2)*n^2+(409/2)*n)/(27720*n^7+97020*n^6+132300*n^5+88200*n^4+29400*n^3+4410*n^2+210*n), n = 1 .. n-1)
Maple is giving answer which is very complex
we want to find:-
sum((5/2+25*n^2+25*n)/(300*n^4+600*n^3+360*n^2+60*n), n = 1 .. n-1)
maple gives me an answer which looks complex to me? can we simplify it further?
I'm trying to do this project but I keep getting an error message...does anyone have any ideas???
I find it much easier to enter equations in the Text mode (red bold text). In the past I found a UI setting that allowed me to stay in this mode, but now I can't remember where to find the option...so every time after I input a command, the next command is back in Math mode by default. How can I make it stay in Text entry mode all the time?
Hello, I have a function that produces different phase portraits as you change the variable x in the original equation. Im trying to find out at what values of x this change occurs...
So far I have determined the eigenvalues with regards to x and have run loops to find out roughly when this happens but i would like to be able to do this with either a procedure of perhaps dsolve or solve maybe?
So, given the eigenvalues, how would i go about doing this?
For a matrix W, the command limit(W^t,t=infinity) does not work.  Is there a way to evaluate this limit in maple ??
I knew that fsolve can solve equations by given an interval or a starting point. Like these
fsolve({x-y = 1, x+y = 1}, {x = 0 .. 1, y = 0 .. 1})
fsolve({x-y = 1, x+y = 1}, {x = 0, y = 1})
But what if I knew the interval for only one of the the variable?  After I run this code
S={v1=[-4 v2=[7 v3=[-3 v4=[-6 v5=[1 }
           -2       1        3        -6       3
           -1      -2        0        -1       4
Is there a way to check a function for positive definiteness or local
positive definiteness?
Eg:  v(x1, x2, t) = (x1^2 + x2^2)*exp(-t)
-Joel
we have the following series:
1/2-Pi/(4*sqrt(3)) = sum(1/((6*n)^2-1), n = 1 .. Infinity)
(5-Pi)*(1/4) = sum((-1)^(n+1)/(2*n+1), n = 1 .. Infinity) {***}
-1/5+(1/6)*Pi-(1/12)*sqrt(3)*log((2+sqrt(3))/(2-sqrt(3))) = sum((-1)^n/(6*n+5), n = 1 .. Infinity)
First 2176 2177 2178 2179 2180 2181 2182 Last Page 2178 of 2459
