Why solutions (5) and (6) are different? The solution (5) is obtained by putting f=0 of the series, while (6) is the result by taking limit at f->0.
check.mw
I want to know if it is possible to use the declare command from the PDETools package for a function
f(x,y,z)
and still, having the notation $\frac{\partial f}{\partial x}$ instead of $f_x$ for the Maple command %diff(f(x,y,z),x)
Thanks !
Kevin
recurssion.mw
"f(x,t) :=(|Psi|)^(2)"
proc (x, t) options operator, arrow, function_assign; abs(Psi)^2 end proc
" a(t):=piecewise(0<= t<=1,1.5*t,1<= t<=2,1.5*(2-t))"
proc (t) options operator, arrow, function_assign; piecewise(0 <= t and t <= 1, 1.5*t, 1 <= t and t <= 2, 1.5*(2-t)) end proc
" y[a](t):=piecewise(0<= t<=0.1,a(t),0.1<= t<=0.2,-a(t))"
proc (t) options operator, arrow, function_assign; piecewise(0 <= t and t <= .1, a(t), .1 <= t and t <= .2, -a(t)) end proc
"y(t):=y[a](t)+mu(t)"
proc (t) options operator, arrow, function_assign; y[a](t)+mu(t) end proc
"w(t):=&int;x(t)*f(x,t) &DifferentialD;x"
proc (t) options operator, arrow, function_assign; int(x(t)*f(x, t), x) end proc
" v(t):=y(t)-w(t)*w(t)"
proc (t) options operator, arrow, function_assign; y(t)-w(t)^2 end proc
diff(K(x, t), t) = beta*v(t)*f(x, t)
Error, (in y[a]) too many levels of recursion
"map(int, , t)"
Error, invalid function arguments
"map(int,,t)"
Here psi is a general wave function from schrodinger wave equation.
Download recurssion.mw
The problem comes from the link https://www.mapleprimes.com/questions/234398-Convert-Maple-Code-To-Python-#comment287424.
We know that when we compile a C or C ++ function, it generates an executable file.  Then we are free from source code.  For example. the function below returns a square matrix A where    "A[i, j]" is the distance from vertex i to vertex j in the graph G. My computer system is Windows.
// C Program for Floyd Warshall Algorithm
#include <stdio.h>
// Number of vertices in the graph
#define V 4
/* Define Infinite as a large enough
  value. This value will be used
  for vertices not connected to each other */
#define INF 99999
// A function to print the solution matrix
void printSolution(int dist[][V]);
// Solves the all-pairs shortest path
// problem using Floyd Warshall algorithm
void floydWarshall (int graph[][V]) {
    /* dist[][] will be the output matrix
      that will finally have the shortest
      distances between every pair of vertices */
    int dist[V][V], i, j, k;
    /* Initialize the solution matrix
      same as input graph matrix. Or
       we can say the initial values of
       shortest distances are based
       on shortest paths considering no
       intermediate vertex. */
    for (i = 0; i < V; i++)
        for (j = 0; j < V; j++)
            dist[i][j] = graph[i][j];
    /* Add all vertices one by one to
      the set of intermediate vertices.
      ---> Before start of an iteration, we
      have shortest distances between all
      pairs of vertices such that the shortest
      distances consider only the
      vertices in set {0, 1, 2, .. k-1} as
      ----> After the end of an iteration,
      vertex no. k is added to the set of
      intermediate vertices and the set
      becomes {0, 1, 2, .. k} */
    for (k = 0; k < V; k++) {
        // Pick all vertices as source one by one
        for (i = 0; i < V; i++) {
            // Pick all vertices as destination for the
            // above picked source
            for (j = 0; j < V; j++) {
                // If vertex k is on the shortest path from
                // i to j, then update the value of dist[i][j]
                if (dist[i][k] + dist[k][j] < dist[i][j])
                    dist[i][j] = dist[i][k] + dist[k][j];
    // Print the shortest distance matrix
    printSolution(dist);
/* A utility function to print solution */
void printSolution(int dist[][V]) {
    printf ("The following matrix shows the shortest distances"
            " between every pair of vertices \n");
    for (int i = 0; i < V; i++) {
        for (int j = 0; j < V; j++) {
            if (dist[i][j] == INF)
                printf("%7s", "INF");
                printf ("%7d", dist[i][j]);
        printf("\n");
// driver program to test above function
int main() {
    /* Let us create the following weighted graph
            10
       (0)------->(3)
      5 |          |
        |          | 1
       (1)------->(2)
            3           */
    int graph[V][V] = { {0,   5,  INF, 10},
        {INF, 0,   3, INF},
        {INF, INF, 0,   1},
        {INF, INF, INF, 0}
    // Print the solution
    floydWarshall(graph);
    return 0;
The above functions will be packaged as the disall.exe , and then we will move them anywhere in my computer and run it in Powershell.  We don't have to deal with the source code unless we want to change it.
I mean can Maple do something like that?
with(GraphTheory);
G := Graph([1, 2, 3, 4, 5], {{1, 2}, {1, 3}, {1, 4}, {1, 5}, {2, 3}, {2, 5}, {3, 4}, {4, 5}});
AllPairsDistance(G);
For exmaple, can I package the above code snippet into an exe file?
Given: f := (R1 + Rc)/(4*C*Rf*R1)
Where ...
R1 := 10^5
R2 := 300*10^3
R3 := 75*10^3
Rf := 10^4
Rc := R2
C := 10^(-6)
Now to find the value of "f" enter...
f=
and I get ...
25.000 + 2.500*10^(-4)*Rc
But ...if I enter ...
(R1 + Rc)/(4*C*Rf*R1) =
I get 100.000
Which I think is the correct answer.
Why isn't Maple Flow 2022 returning 100 when I ask for the value of "f" ?
I'm sure I'm doing something incorrect so maybe some kind soul will give me some guidance.
Thanks for any help.
PS - Is there an easy way to enter a set of equations from Maple Flow  2022... like the above... without having to copy and paste each one individually?
hallo evert body please how i do calculate this integral
in maple 18
ttp.pdf
int_{0}^{2\pi}(\cos^{i}(\theta)-\cos^{i+2}(\theta))d\theta
I want to extract the coefficients of Chebyshev of an arbitrary function, for example, exp(x). I know that we can use the following command to make a Chebyshev series expansion of exp(x):
chebyshev(exp(x),x);
the above returns the sum of nth Chebyshev polynomials multiplied by Chebyshev coefficients as the following:
1.26606587775201*T(0, x) + 1.13031820798497*T(1, x) + 0.271495339534077*T(2, x) + 0.0443368498486638*T(3, x) + 0.00547424044209371*T(4, x) + 0.000542926311913993*T(5, x) + 0.0000449773229542760*T(6, x) + 3.19843646244580*10^(-6)*T(7, x) + 1.99212480641582*10^(-7)*T(8, x) + 1.10367717095000*10^(-8)*T(9, x) + 5.50589697979079*10^(-10)*T(10, x)
I like to take the coefficients 1.266,1.1303, 0.2714, 0.04433, and so on. How can I do it?
Why GenerateMatrix produces wrong results?
N := 2:
a := 1:
with(ArrayTools):
Qa := [-0.5379667864e-1*(diff(tau[1, 1](t), t, t))+7.862351349*10^(-11)*tau[2, 1](t)-8.050993899*10^(-12)*(diff(tau[2, 1](t), t, t))+.1166068042*(diff(tau[1, 2](t), t))+2.181309895*10^(-11)*(diff(tau[2, 2](t), t))+.5309519363*tau[1, 1](t) = 0, -1.265965258*10^(-11)*(diff(tau[1, 1](t), t, t))+.4884414390*tau[2, 1](t)-0.4948946475e-1*(diff(tau[2, 1](t), t, t))+2.738892495*10^(-11)*(diff(tau[1, 2](t), t))+.1340883970*(diff(tau[2, 2](t), t))+1.246469610*10^(-10)*tau[1, 1](t) = 0, 3.649366137*10^(-10)*tau[2, 2](t)-9.135908950*10^(-12)*(diff(tau[2, 2](t), t, t))-5.160677740*10^(-11)*(diff(tau[2, 1](t), t))+1.953765755*tau[1, 2](t)-0.4948946473e-1*(diff(tau[1, 2](t), t, t))-.3476543209*(diff(tau[1, 1](t), t)) = 0, 2.246672656*tau[2, 2](t)-0.5690888318e-1*(diff(tau[2, 2](t), t, t))-.3198194887*(diff(tau[2, 1](t), t))+4.602903411*10^(-10)*tau[1, 2](t)-1.159417294*10^(-11)*(diff(tau[1, 2](t), t, t))-8.175817372*10^(-11)*(diff(tau[1, 1](t), t)) = 0]
Q1 := [seq(seq(diff(tau[i, j](t), t), i = 1 .. M), j = 1 .. N)]
[diff(tau[1, 1](t), t), diff(tau[2, 1](t), t), diff(tau[1, 2](t), t), diff(tau[2, 2](t), t)]
CR := GenerateMatrix(simplify(Qa), Q1)
CR := Matrix(4, 4, {(1, 1) = 0, (1, 2) = 0, (1, 3) = .1166068042, (1, 4) = 0.2181309895e-10, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0.2738892495e-10, (2, 4) = .1340883970, (3, 1) = -.3476543209, (3, 2) = -0.5160677740e-10, (3, 3) = 0, (3, 4) = 0, (4, 1) = -0.8175817372e-10, (4, 2) = -.3198194887, (4, 3) = 0, (4, 4) = 0}), Vector(4, {(1) = 0.5379667864e-1*(diff(diff(tau[1, 1](t), t), t))-0.7862351349e-10*tau[2, 1](t)+0.8050993899e-11*(diff(diff(tau[2, 1](t), t), t))-.5309519363*tau[1, 1](t), (2) = 0.1265965258e-10*(diff(diff(tau[1, 1](t), t), t))-.4884414390*tau[2, 1](t)+0.4948946475e-1*(diff(diff(tau[2, 1](t), t), t))-0.1246469610e-9*tau[1, 1](t), (3) = -0.3649366137e-9*tau[2, 2](t)+0.9135908950e-11*(diff(diff(tau[2, 2](t), t), t))-1.953765755*tau[1, 2](t)+0.4948946473e-1*(diff(diff(tau[1, 2](t), t), t)), (4) = -2.246672656*tau[2, 2](t)+0.5690888318e-1*(diff(diff(tau[2, 2](t), t), t))-0.4602903411e-9*tau[1, 2](t)+0.1159417294e-10*(diff(diff(tau[1, 2](t), t), t))})
Download GenMatrix.mw
I use Maple 2020 on a Windows 10 PC.
The command ssystem("CMD") enables to launch any Windows command accessible from the shell.
But how to launch a PowerShell command?
For instance ssystem("get-process") returns -1 (not surprising in fact for get-process is not a shell process).
How can I tell Maple that this command is to be found in the PowerShell ?
And even, I this possible for, in the ssystem help page, it's said that not all the command can be launched by ssystem
TIA
I have quite a big code with lot of functions how to convert all together to python in one go
Or any other way of advice
As recoding is difficult. Can you help with a small sample program with 2 simple functions returning values
Graph theory and it's algorithms, linear algebra , have used in my program codings mainly
In small function kind take to a create a small graph find allpairshortestpath
It would help to understand how it converts
Please help sorry to disturb in your busy schedule
I am just starting with Maple after using Mathcad for nearly 30 years. I want to recreate something I have used a lot in Mathcad: select certain rows in array based on a specified criterion. For example, I want to save just the rows that have a certain value in a certain column and save the new array for use later. I am slowly learning how to do it Maple--for instance, I learned that I need to change the variable printlevel if I want to get the output from nested loops.
I currently have the following code:
k := 1;
rows := RowDimension(M);
for i to rows do
   if M[i, 3] = "A" then
      row(out, k) := row(M, i);
       k := k + 1;
out;
This doesn't seem to work, though. When I try to display out, I just get the name out instead a matrix of values.
I would appreciate it if someone could give me some idea of what I am doing wrong (with Maple, that is).
John
I have the following summation to do,
d(l,m')=\sum_{N=-l'}^{l'}d(l',N,m')=d^{l'}_{00}(\dfrac{\pi}{2})d^{l'}_{0m'}(\dfrac{\pi}{2})f_{m'0}+\sum_{N=1}^{l'}((-1)^{l'}+1)d^{l'}_{0N}(\dfrac{\pi}{2})d^{l'}_{Nm'}(\dfrac{\pi}{2})f_{m'N}
where  d^{l'}_{0N} are the rotation matrix functions and  f_{m'N} is a piecewise function which takes a certain value at N=0, another value for N even and it takes 0 as a value for N odd.
The prblem is that I don't know how to write a summation for N even only so that in that case i can replace f_{m'N} by its expression for N even. The other way is to write f_{m'N} as a piecewise function but in that case, i don't know how to do it (I tried to use assuming N even ..) but got wrong answer.
Thank you for helping me solving my proble.
Best regards.
I'm trying to enter an equation (Navier-Stokes) in Maple using the Physics[Vectors] package. I am having trouble with the term
$(u\cdot \nabla) u$
but Maple returns an error when entering the commands :
( u_(t,x,y,z) . %Nabla) u_(t,x,y,z)
I tried other combinations of this without success, like :
( u_(t,x,y,z) . %Nabla)(u_(t,x,y,z))
( u_(t,x,y,z) %. %Nabla) u_(t,x,y,z)
( u_(t,x,y,z) %. %Nabla) (u_(t,x,y,z))
Could you please give me some help with this?
I have a small problem with the display of fraction and x_dot at the same time.
This the exemple :
with(Typesetting);
compactdisplay = flase;
Settings(typesetprime = false);
Settings(typesetdot = true);
diff(1/2*LongExpression*x(t), t);
The Results
when I choose the typesetting level : Extended. I got this result :
And when I choose the typesetting level : Maple Standrad. I got this result
What I  want to have is mix of both, it mean like this
Hi please, how can I pair two lists and form another list?
P := [.6286420119, -.6286420119, 0., 0., 0., 0., 0., 0., 0., 0., 0.]
Q = [2.106333379, 2.106333379, 4.654463885, 7.843624703, 10.99193295, 14.13546782, 17.27782732, 20.41978346, 23.56157073, 26.70327712, 29.84494078]
I want to pair them into something like this:
W := [ [.6286420119,2.106333379], [-.6286420119,  2.106333379] ... ]
Then use pointplot(W) and  display(seq(pointplot(W[j], j = 1 .. 20), insequence = true):
First 331 332 333 334 335 336 337 Last Page 333 of 2458
