Hi I have experienced another Maple 2021 error with those of my students who Maple 2021 Mac edition.
Lets say their have saved a .mw on their main drive and tries to open the file from inside Maple. Maple gives an error like "file cannot be opened - please try to another". This also happens when trying to open the file from outside Maple.
This never happens on the Windows version. So any idea what could be causing this ?
"D1(s,t) :=P- (alpha1-beta*S) +  alpha2 + beta2 *q(t)^();"
proc (s, t) options operator, arrow; P+beta*S-alpha1+alpha2+beta2*q(t) end proc
dem
ode1 := diff(q(t), t)+theta*q(t)/(1+N-t) = -D1(s, t)
diff(q(t), t)+theta*q(t)/(1+N-t) = -P-beta*S+alpha1-alpha2-beta2*q(t)
fn1 := q(t)
q(t)
ic1 := q(T) = 0
q(T) = 0
sol1 := simplify(dsolve({ic1, ode1}, fn1))
q(t) = (-S*beta-P+alpha1-alpha2)*(Int(exp(beta2*_z1)*(1+N-_z1)^(-theta), _z1 = T .. t))*exp(-beta2*t)*(1+N-t)^theta
Download data.mw
Hello all. I'm trying to solve the following first-order differential equation.
Please help in understanding why the equation (6) doesn't contain proper solution for the function q(t) on solving the ode1 with the given initial condition
How (can I?) display the value in a legend in Engineering format -- 10^3, 10^-6, etc?
Lres := 1/((2*Pi*freq)^2*Cres);
ftest := 10e6;
p1 := plot(eval(subs(freq = ftest, Lres)), Cres = 0.10000000 .. 0.10000000, labels = [Cres, 'Lres'], legend = ftest, color = red, title = 'Inductance*Value*as*a*Function*of*Resonant*Capacitance', axis = [gridlines = [default]]);
I would like the legend to display 10^6 rather than 1^7.
I've tried changing the default number format for the whole worksheet to Engineering, but that doesn't seem to apply to legends.
thank you.
I'd like to know, if it is possible to define any sort of range for parameters in NonlinearFit. E. g. I know that one of parameters should be somewhere between 0.2 - 0.4. I know there is a possibility of initalvalues, but using it doesn't lead into this range.
Hi. So my question is how can I get Square brackets on the phone app in calculations or is it possible?
In a french magazine written by High Schools teachers I found this problem:
let a, b, p, q four strictly positive integers such that a > b^2 and p > q+1;
find 4-tuples (a, b, p, q) such that
(a^2 - b^4) = p!/q!
Given the source of this problem I suspect that there is a trick to answering this question.
After some hours spent, I have found no general method to solve it, only a few solutions (first one and second one are almost obvious), for instance
rel := a^2 - b^4 = p!/q!:
eval(rel, [a= 5, b=1, q=1, p=4]);
eval(rel, [a=11, b=1, q=1, p=5]);
eval(rel, [a=71, b=1, q=1, p=7]);
eval(rel, [a= 2, b=1, q=2, p=3]);
eval(rel, [a=19, b=1, q=2, p=6]);
eval(rel, [a=21, b=3, q=2, p=6]);
Do you have any idea how to solve this problem?
Could it be handled by Maple (without a systematic exploration of a part of N^4)?
lets say we have one or two lines
y=2x-4 and y = -2x+4 is it possible to get Maple to illustrate the angle between these two lines in a plot? Or the angle of inclination in respect to the x-axes for them individually?
kindly help me to find the inverse Laplace of this function. I tried but maple leaves the integral unevaluated.
with(inttrans)
expr := exp(a-sqrt(a^2+b*s))/s
exp(a-(a^2+b*s)^(1/2))/s
`assuming`([invlaplace(expr, s, t)], [b > 0])
(1/2)*(b/Pi)^(1/2)*(int(exp(-a^2*_U1/b+a-(1/4)*b/_U1)/_U1^(3/2), _U1 = 0 .. t))
Download invrslplc.mw
how can revision of error in
u0 := proc (x) options operator, arrow; 1+2*x end proc; h := 0;
for k from 0 to 5 do U := proc (k, h) options operator, arrow; eval((diff(u0(x), [`$`(x, k)]))/factorial(k), x = 0) end proc end do;
m := h+1;
for k from 0 to 5 do U := proc (k, h) options operator, arrow; (sum(sum(U(r, h-s)*U(k-r, s), s = 0 .. h), r = 0 .. k)+(k+1)*U(k, h))/m end proc end do;
U(0, 1);
Error, (in U) too many levels of recursion
I have the following expression.
Ps = (x - 600)(15000 + 400*(y - 4000)/2000 + 15000*0.40*(850 - x)/100) - y
Maple will evaluate this to:
Screenshot:
Plotting these two in 2D on Desmos to demonstrate: https://www.desmos.com/calculator/tvp4rbzxzp
These two are not the same expression. Is Maple broken or am I doing something wrong?
Hello. Please help me solve the ODE system
ODU_v2.mw
with(linalg):
r1 := 1:
0.1111110000e-2
1920.000000+0.7407400000e-3*I
J := proc (n, x) options operator, arrow; BesselJ(n, x) end proc:
nsize := floor(2*k)+1;
n := 1; A1 := matrix([[(lambda(r)+2*mu(r))*r^2, 0], [0, mu(r)*r^2]]); B1 := matrix([[(diff(lambda(r), r)+2*(diff(mu(r), r)))*r^2+(lambda(r)+2*mu(r))*r, I*n*(lambda(r)+mu(r))*r], [I*n*(lambda(r)+mu(r))*r, (diff(mu(r), r))*r^2+mu(r)*r]]); C1 := matrix([[(diff(lambda(r), r))*r-lambda(r)-(n^2+2)*mu(r)+omega^2*rho(r)*r^2, I*n*((diff(lambda(r), r))*r-lambda(r)-3*mu(r))], [I*n*((diff(mu(r), r))*r+lambda(r)+3*mu(r)), -(diff(mu(r), r))*r-n^2*lambda(r)-(2*n^2+1)*mu(r)+omega^2*rho(r)*r^2]]); U := vector([U1(r), U2(r)]); DU := vector([diff(U1(r), r), diff(U2(r), r)]); D2U := vector([diff(U1(r), `$`(r, 2)), diff(U2(r), `$`(r, 2))]); T1 := multiply(A1, D2U); T2 := multiply(B1, DU); T3 := multiply(C1, U); prav := evalm(T1+T2+T3); pr1 := prav[1]; pr2 := prav[2]; p1 := evalc(Re(pr1)); p2 := evalc(Im(pr1)); p3 := evalc(Re(pr2)); p4 := evalc(Im(pr2)); WWVV := evalf(subs(x = k*r1, H(n, x)))*evalf(subs(x = k2*r1, H(n, x)))*n^2-evalf(subs(x = k*r1, DH(n, x)))*evalf(subs(x = k2*r1, DH(n, x)))*k*k2*r1^2; `αv1` := I*evalf(subs(x = k2*r1, DH(n, x)))*k2*omega*r1^2/WWVV; `αv2` := -evalf(subs(x = k2*r1, H(n, x)))*n*omega*r1/WWVV; `αv3` := (evalf(subs(x = k*r1, DJ(n, x)))*evalf(subs(x = k2*r1, DH(n, x)))*I^n*k*k2*r1^2-I^n*n^2*evalf(subs(x = k*r1, J(n, x)))*evalf(subs(x = k2*r1, H(n, x))))/WWVV; `αv4` := evalf(subs(x = k*r1, H(n, x)))*r1*n*omega/WWVV; `αv5` := -I*evalf(subs(x = k*r1, DH(n, x)))*r1^2*k*omega/WWVV; `αv6` := I*I^n*n*k*r1*(evalf(subs(x = k*r1, DJ(n, x)))*evalf(subs(x = k*r1, H(n, x)))-evalf(subs(x = k*r1, DH(n, x)))*evalf(subs(x = k*r1, J(n, x))))/WWVV; gv1 := rho1*(-evalf(subs(x = k*r1, D2H(n, x)))*k^2*r^2*(4*nu+3*xi)-3*evalf(subs(x = k*r1, DH(n, x)))*k*r1*xi+evalf(subs(x = k*r1, H(n, x)))*(-4*k^2*r1^2*nu-3*k^2*r1^2*xi+(3*I)*omega*r1^2-2*n^2*nu+3*n^2*xi))/(3*r1^2); gv2 := (6*rho1/(3*r1^2)*I)*n*nu*(evalf(subs(x = k2*r1, H(n, x)))-k2*r1*evalf(subs(x = k2*r1, DH(n, x)))); gv3 := rho1*(-I^n*evalf(subs(x = k*r1, D2J(n, x)))*k*r1^2*(4*nu+3*xi)+I^n*evalf(subs(x = k*r1, DJ(n, x)))*k*r1*(2*nu-3*xi)+I^n*evalf(subs(x = k*r1, J(n, x)))*(-4*k^2*r1^2*nu-3*k^2*r1^2*xi+(3*I)*omega*r1^2-2*n^2*nu+3*n^2*xi))/(3*r1^2); gv4 := (2*nu*rho1/r1^2*I)*n*(evalf(subs(x = k*r1, H(n, x)))-evalf(subs(x = k*r1, DH(n, x)))*k*r1); gv5 := nu*rho1*(evalf(subs(x = k2*r1, D2H(n, x)))*k2^2*r1^2-evalf(subs(x = k2*r1, D2H(n, x)))*k2*r1+evalf(subs(x = k2*r1, H(n, x)))*n^2)/r1^2; gv6 := (2*nu*rho1/r1^2*I)*n*I^n*(evalf(subs(x = k*r1, J(n, x)))-k*r1*evalf(subs(x = k*r1, DJ(n, x)))); E := matrix([[`αv1`*gv1+`αv4`*gv2+lambda(r1)/r1, `αv2`*gv1+`αv4`*gv2+I*n*lambda(r1)/r1], [`αv1`*gv4+`αv4`*gv5+I*n*mu(r1)/r1, `αv2`*gv4+`αv5`*gv5-mu(r1)/r1]]); G := vector([-gv1*`αv3`-gv2*`αv6`-gv3, -gv4*`αv3`-gv5*`αv6`-gv6]); e1 := (lambda2*n^2*evalf(subs(x = kl*r2, J(n, x)))-kl^2*r2^2*evalf(subs(x = kl*r2, D2J(n, x)))*(lambda2+2*mu2)-kl*lambda2*r2*evalf(subs(x = kl*r2, DJ(n, x))))/r2^2; e2 := (2*mu2*I)*n*(evalf(subs(x = kt*r2, J(n, x)))-kt*r2*evalf(subs(x = kt*r2, DJ(n, x))))/r2^2; e3 := (I*n*2)*(evalf(subs(x = kl*r2, J(n, x)))-kl*r2*evalf(subs(x = kl*r2, DJ(n, x))))/r2^2; e4 := (kt^2*r2^2*evalf(subs(x = kt*r2, D2J(n, x)))-kt*r2*evalf(subs(x = kt*r2, DJ(n, x)))+n^2*evalf(subs(x = kt*r2, J(n, x))))/r2^2; gamma1 := kt*r2*evalf(subs(x = kt*r2, DJ(n, x)))/WW; gamma2 := I*n*evalf(subs(x = kt*r2, J(n, x)))/WW; gamma3 := I*n*evalf(subs(x = kl*r2, J(n, x)))/WW; gamma4 := -kl*r2*evalf(subs(x = kl*r2, DJ(n, x)))/WW; WW := (kl*r2^2*evalf(subs(x = kl*r2, DJ(n, x)))*kt*evalf(subs(x = kt*r2, DJ(n, x)))-n^2*evalf(subs(x = kl*r2, J(n, x)))*evalf(subs(x = kt*r2, J(n, x))))/r2; F := matrix([[r2^2*(gamma1*e1+gamma3*e2+lambda(r2)/r2), r2^2*(gamma2*e1+gamma4*e2+I*n*lambda(r2)/r2)], [mu2*r2^2*(gamma1*e3+gamma3*e4+I*n*mu(r2)/(mu2*r2)), mu2*r2^2*(gamma2*e3+gamma4*e4-mu(r2)/(mu2*r2))]]); Ur1 := vector([U1(r1), U2(r1)]); Ur2 := vector([U1(r2), U2(r2)]); DUr1 := vector([Dx1(r1)+I*Dy1(r1), Dx2(r1)+I*Dy2(r1)]); DUr2 := vector([Dx1(r2)+I*Dy1(r2), Dx2(r2)+I*Dy2(r2)]); CCR1 := multiply(A1, DUr1); CCR2 := multiply(E, Ur1); CR := evalm(CCR1+CCR2); CCR11 := multiply(A1, DUr2); CCR22 := multiply(F, Ur2); CR2 := evalm(CCR11+CCR22); ggr1 := expand(evalc(Re(CR[1]))); ggr2 := expand(evalc(Im(CR[1]))); ggr3 := expand(evalc(Re(CR[2]))); ggr4 := expand(evalc(Im(CR[2]))); ggr5 := expand(evalc(Re(CR2[1]))); ggr6 := expand(evalc(Im(CR2[1]))); ggr7 := evalc(Re(CR2[2])); ggr8 := evalc(Im(CR2[2])); gr1 := subs(Dx1(r1) = (D(x1))(r1), Dx2(r1) = (D(x2))(r1), Dy1(r1) = (D(y1))(r1), Dy2(r1) = (D(y2))(r1), r = r1, ggr1); gr2 := subs(Dx1(r1) = (D(x1))(r1), Dx2(r1) = (D(x2))(r1), Dy1(r1) = (D(y1))(r1), Dy2(r1) = (D(y2))(r1), r = r1, ggr2); gr3 := subs(Dx1(r1) = (D(x1))(r1), Dx2(r1) = (D(x2))(r1), Dy1(r1) = (D(y1))(r1), Dy2(r1) = (D(y2))(r1), r = r1, ggr3); gr4 := subs(Dx1(r1) = (D(x1))(r1), Dx2(r1) = (D(x2))(r1), Dy1(r1) = (D(y1))(r1), Dy2(r1) = (D(y2))(r1), r = r1, ggr4); gr5 := subs(Dx1(r2) = (D(x1))(r2), Dx2(r2) = (D(x2))(r2), Dy1(r2) = (D(y1))(r2), Dy2(r2) = (D(y2))(r2), r = r2, ggr5); gr6 := subs(Dx1(r2) = (D(x1))(r2), Dx2(r2) = (D(x2))(r2), Dy1(r2) = (D(y1))(r2), Dy2(r2) = (D(y2))(r2), r = r2, ggr6); gr7 := subs(Dx1(r2) = (D(x1))(r2), Dx2(r2) = (D(x2))(r2), Dy1(r2) = (D(y1))(r2), Dy2(r2) = (D(y2))(r2), r = r2, ggr7); gr8 := subs(Dx1(r2) = (D(x1))(r2), Dx2(r2) = (D(x2))(r2), Dy1(r2) = (D(y1))(r2), Dy2(r2) = (D(y2))(r2), r = r2, ggr8); sys := p1 = 0, p2 = 0, p3 = 0, p4 = 0; Inits := gr3 = evalc(Re(G[2])), gr4 = evalc(Im(G[2])), gr1 = evalc(Re(G[1])), gr2 = evalc(Im(G[1])), gr5 = 0, gr6 = 0, gr7 = 0, gr8 = 0; dde := dsolve({Inits, sys}, numeric, [x1(r), x2(r), y1(r), y2(r)], method = bvp[trapdefer], 'maxmesh' = 5000)
5860000000.*r^2*(diff(diff(x1(r), r), r))+5860000000.*r*(diff(x1(r), r))-4880000000.*r*(diff(y2(r), r))+(-6840000000.+0.1972224000e11*r^3-0.1380556800e11*r^2)*x1(r)-(15217.76256*r^3-10652.43379*r^2)*y1(r)+6840000000.*y2(r) = 0, 5860000000.*r^2*(diff(diff(y1(r), r), r))+5860000000.*r*(diff(y1(r), r))+4880000000.*r*(diff(x2(r), r))+(15217.76256*r^3-10652.43379*r^2)*x1(r)+(-6840000000.+0.1972224000e11*r^3-0.1380556800e11*r^2)*y1(r)-6840000000.*x2(r) = 0, 980000000.0*r^2*(diff(diff(x2(r), r), r))-4880000000.*r*(diff(y1(r), r))+980000000.0*r*(diff(x2(r), r))-6840000000.*y1(r)+(-6840000000.+0.1972224000e11*r^3-0.1380556800e11*r^2)*x2(r)-(15217.76256*r^3-10652.43379*r^2)*y2(r) = 0, 980000000.0*r^2*(diff(diff(y2(r), r), r))+4880000000.*r*(diff(x1(r), r))+980000000.0*r*(diff(y2(r), r))+6840000000.*x1(r)+(15217.76256*r^3-10652.43379*r^2)*x2(r)+(-6840000000.+0.1972224000e11*r^3-0.1380556800e11*r^2)*y2(r) = 0
980000000.0*(D(x2))(1)-3407670.437*x1(1)-979699593.0*y1(1)-982493864.9*x2(1)+2501551.625*y2(1) = -1147.143928, 980000000.0*(D(y2))(1)+979699593.0*x1(1)-3407670.437*y1(1)-2501551.625*x2(1)-982493864.9*y2(1) = 522.0509891, 5860000000.*(D(x1))(1)+1012610130.*x1(1)+3433520814.*y1(1)-3395293.932*x2(1)-3899703885.*y2(1) = 1553476.957-0.8860949e-3*r^2, 5860000000.*(D(y1))(1)-3433520814.*x1(1)+1012610130.*y1(1)+3899703885.*x2(1)-3395293.932*y2(1) = 582234.6500+.6073438988*r^2, 3750400000.*(D(x1))(.8)-0.1805979289e11*x1(.8)-3057.354840*y1(.8)+182.8516896*x2(.8)+0.2220128109e11*y2(.8) = 0, 3750400000.*(D(y1))(.8)+3057.354840*x1(.8)-0.1805979289e11*y1(.8)-0.2220128109e11*x2(.8)+182.8516896*y2(.8) = 0, 627200000.0*(D(x2))(.8)-182.8520640*x1(.8)-0.2610528071e11*y1(.8)-0.2508771663e11*x2(.8)-607.0797125*y2(.8) = 0, 627200000.0*(D(y2))(.8)+0.2610528071e11*x1(.8)-182.8520640*y1(.8)+607.0797125*x2(.8)-0.2508771663e11*y2(.8) = 0
Error, (in dsolve/numeric/BVPSolve) unable to store '-HFloat(8.860193192958832e-4)+0.8860949e-3*r^2' when datatype=float[8]
Download ODU_v2.mw
f := x -> x^3 + 3^x;
complexplot3d(f, -15 - 22*I .. 15 + 22*I);
This gives good color graph however I would like to see it like the way this cat graphed it.
https://www.quora.com/How-do-I-solve-for-x-in-x-3-3-x-17
Ive got a question about the Dutch book again. They sure did their part on finding questions with answers you cannot find in the book (maybe in later chapters or the 2nd book "part 2"). Maybe to make sure you go to the teacher, so he sees you, and he is sure you did your part, and to get some interaction between the student and the teacher.
I guess you guys/girls are the teacher... Hahah :)
It is the 3rd question. It says: "given is the funtion y=f(x) ( see the photo for the function, "voor" means "for")
a. Draw the graph of y=f(x)
b. Draw with the help of the graph of y=f(x), a graph y=f(-x),y=-2f(x),y=f(x-1), and y=(2x)"
This paragraph is about shifting graphs of functions, and how to alter them. I know how it works, ive done that quite some time ago, but now in maple it is a new challange. Is there a way to get the funtion f(x) to adhere to the rules imposed on it by the text in the book? If that can be done, the answering of the questions will be a lot easier!
Greetings,
the function
Hallo, I would like to ask anyone have encountered this problem. I tried to update a matrix value using recurrence do but end up with "Error, recursive assignment". Here is the code. Any help is appreciated.
with(LinearAlgebra);
Nx := 200;
Nt := 200;
dx := 0.5e-2; dt := 0.2e-1;
A := Matrix(Nx, Nx);
for k to Nx do A[k, k] := -2.0 end do;
for j to Nx-1 do A[j+1, j] := 1.0 end do;
for j to Nx-1 do A[j, j+1] := 1.0 end do; A;
zeta := (.1*dt/dx)^2;
phi || 0 := Matrix(Nx, Nx);
fin := proc (t) options operator, arrow; cos(4*Pi*t) end proc;
phi || 0[(1/2)*Nx, (1/2)*Nx] := fin(0);
phi || 1 := (1/2)*zeta^2 . A . phi || 0; phi || 1[(1/2)*Nx, (1/2)*Nx] := fin(dt);
phinow := Matrix(Nx, Nx); phinext := Matrix(Nx, Nx); phibefore := Matrix(Nx, Nx);
phinow := phi || 1; phibefore := phi || 0;
for j from 2 to Nt do phinext := Zeta^2 . (A . phinow+phinow . A)+2.*phinow-phibefore; phi || j := Matrix(Nx, Nx); phinext[(1/2)*Nx, (1/2)*Nx] := fin(j*dt); phi || j := phinext; phibefore := phi || (j-1); phinow := phi || j end do;
for j to (1/5)*Nt do p || j := matrixplot(phi || j, heights = histogram, gap = 0.5e-2, labels = ["", "", ""]) end do;
plots[display](p || (1 .. 20), insequence = true);
I solve numerically an ODE system which depends on 25 parameters.
I want to know the maximum value of the time at which a specific event is triggered, when these parameters vary (independently the one of the other) within a 25 dimensional hyperbox.
To solve this maximization problem, which I assume is local1, I would like to use NLPSolve
The attached zip (I use Mac OSX) contains:
  • a file that gives a full description of the problem (the original ".pages" file and its export as pdf),
  • an m file wich contains the solution procedure plus a few other variables needed to solve the problem,
  • the mw file which contains:
    • the reading of the m file,
    • the procedure (OBJ) which returns the trigerring time,
    • many attemps to find its maximum value using NLPSolve.
None of my attempts at using NLPSolve gave me the expected answer
Could you help me to fix this?
mw_and_m_files.zip
1: Initializing a local method (see the explanation file) with different points gave me different optimizers but all of them led to rather close values of the objective function. Thus the problem is either global instead of local, or convergence might not be achieved for all the initialization points (but keep in mind that I'm not interested in the location of the minimizer(s) but in the maximum value of if the time when the event is triggered).
First 408 409 410 411 412 413 414 Last Page 410 of 2458
