It want to generate all the words from a NL-letter alphabet and whose lengths are at most LW.
I could not find any function in the combinat package do to that (at least without combining some of them, I'm using Maple 2015 right now); maybe the Iterator package has some features do to that?
For the moment I use this procedure (which generates a few words of length LW+1 I have to suppress)
G := proc(d)
 local n, wo:
  global W:
  while max(length~(W)) < d do
    wo := copy(W):
    for n from 1 to nops(L) do
      W := {W[], cat~(wo, L[n])[]};
    thisproc(d)
# Words of length not larger than LW which are made of at most NL letters
NL := 3:
L  := StringTools:-Char~([$65..65+NL-1]);
W  := L:
LW := 3:
G(3):
w3 := W;
                        ["A", "B", "C"]
{"A", "AA", "AAA", "AAB", "AAC", "AB", "ABA", "ABB", "ABC", "AC",
  "ACA", "ACB", "ACC", "B", "BA", "BAA", "BAB", "BAC", "BB",
  "BBA", "BBB", "BBC", "BC", "BCA", "BCB", "BCC", "C", "CA",
  "CAA", "CAB", "CAC", "CB", "CBA", "CBB", "CBC", "CC", "CCA",
  "CCB", "CCC"}
W  := L:
CodeTools:-Usage( G(12) ):
numelems(W);
memory used=0.62GiB, alloc change=422.58MiB, cpu time=13.70s, real time=8.37s, gc time=8.08s
                             797160
Words_Generator.mw
Do you have any idea to improve it from memory used and cpu time points of view)?
How should I find the roots for
5x^3-x^2+x-1=0
If I have a Polynomial of the form say
c1x^{a1} y^{b1} +c2x^{a2} y^{b2} +... +cnx^{an} y^{bn}
Now I want to form a list say of the form
L=[[[a1, b1], c1], [[a2, b2], c2],.... [[an, bn], cn]]
Kind help with a peice of code
Have the following integral to solve in Maple (2020):
Cap_Unit_Length := int((epsilon_0*epsilon_r*d*sqrt(1+(T*Pi*S)^2))/(epsilon_r*S*theta*tan(theta/2)+2*t),theta=0..Pi);
As Maple cannot find a closed expression, it returns the original input.  Is there any other approach in Maple I can use to attack this expression?  BTW, this is the expression for the distributed capacitance in a twisted wire pair.
Chris
I would like to make a function of two variables. It seems that what I can find online on how onthers do it, does not work with my. Can someone help? Here is the document, but it is very simple. eq_of_two_var.mw
I would like to plot two different functions
One constructed using piecewise and second function on the sme interval.
The code run without error but I am not sure that its true, since we have two different function but in the graph we can not see the difference betweem them
codexsqrr.mw
Thank you for your help
I have a problem using unapply to construct all functions defined in each intervals.
If I use unapply to construct only two peicewises fuctions the code work well, but otherwise there is someting missing
splineProb.mw
## using code like this, its run
ff:=unapply
                  ( piecewise
                    ( x < eval( Xlist[2], NaturalCoeffs),
                      expand( eval( S[1], NaturalCoeffs) ),
                                           expand( eval( S[3], NaturalCoeffs) )
                    x
but using code like
unapply
                  ( piecewise
                     ( x < eval( Xlist[3], NaturalCoeffs),
                      expand( eval( S[2], NaturalCoeffs) ),
                    x
does not run and return
Error, `;` unexpected
Hello, I was recently given a Calculus 3 assignment on Maple. Having no training or teaching, I watched videos and looked up possible routes to finding the solution. I have been working on this assignment the past couple days and could really use some help. The questions I am struggling with are posted below:
Equation given: r(t) = cos(t^3)i + sin(t^3)j + 2t^2 k
1. Use Maple to graph the tangent line at t = 0.8, and the path of the particle from t = 0 to t = pi/2 on the same graph. The line segment for the tangent line should be symmetric about the point of tangency.
2. Find the unit binormal vector when t = 0.8
3. Use Maple to find the normal vector when t = 0.8
4. Find the torsion when t = 0.8
5. Use Maple to graph the unit tangent vector at t = 0.8, the unit normal vector at t = 0.8, the binormal vector at t = 0.8, and the path of the particle from t = 0 to t = pi/2 on the same graph. All the vectors should have the particle's position at t = 0.8 for their initial point. (You are really graphin line segments of length 1.)
Let A a (linear) partial differential operator and f=f(x, y, t) a function of space (x, y) and time (t).
Let DXY=[a, b] x [c, d], DT=[0..e] and  dXY the boundary of DXY.
Is it possible, with Maple 2015, to solve numerically the pde Af=0 in the open domain  DXY * DT
with Dirichlet conditions on dXY and initial condition f(DXY, 0)?
It seems that the option 'numeric' of pdsolve doesn't work with more than 1 "non time" independent variable:
Error, (in pdsolve/numeric/process_PDEs) can only numerically solve PDE with two independent variables, got {t, x, y}
Nevertheles I seem to remember seeing this on Mapleprime (?)
If Maple 2015 can't do it, can Maple 2020?
  • Remark: Af=0 is the heat equation with rho=Cp=lambda=1.
    I guess I could code the alternate directions method to transform  Af=0 into a sequence Axf=0,  Ayf=0,  Axf=0 ... of 1D diffusion equations but I'm a little bit lazzy and I'm waiting for your feedback before doing this.
dear all
I hope to write taylor expansion with remainder lagrange ..That is taylor lagrange expansion of a given function.
I tried
series(cos(x),x=0,5)
or taylor(cos(x),x=0,5)
always the remainder written USING O(x^6)
I want the reminder depend on the derivative ..that is Lagrange Taylor expansion
Many thanks
with(ExcelTools);
data := Import("datatest.xlsx");
I get flotting point like 15.0 , 25.0  in my data
How can get or transform data to integer ( without floating point)  that is instead of 15.0  I would like if possible to obtain 15
Many thanks
Often times I run into calculations like these:
Where d denotes the exterior derivative. Now I know that it is possible to compute the exterior derivative of a function (using the DifferentialGeometry package). But is there a way to compute and simplify them with tensor products as above?
dear all
I need to plot many curves on the same  figure.
for j from 1 to 6 do
pf[i]:=plot(f, x = a[i]..a[i+1]);
end do
How change the following line so that I can plot many curves like 20 or more, using sequence or someting similar
display(pf[1], pf[2],pf[3],pf[4],pf[5],pf[6]})
many thinks
Dear maple users,
Greeting for the day.
I have some data in an excel file. How to plot the excel data in contours with labels.
Also, how to show the x-axis range =-1.5..1.5 and y-axis range = -0.5..1 with the contour sequence -2..2.
XLdat.xlsx
waiting for your reply.
Please see the figure for the model plot.
Hello friends,
I have an image in black and white and I wanted to compute and plot the intensity distribution histogram of it. So I did it with the command PlotHistogram, here's the output:
> PlotHistogram(Lena, 256)
I established the number of buckets to 256 but I don't see them at the x-asis, and I would like to see them for clarity as I don't understand the scale that is used by default. Could you help me achieve this and maybe also understand the scale used by default?
Thanks a lot.
First 476 477 478 479 480 481 482 Last Page 478 of 2469
