I am trying to expand a function f(t) in terms of fractional power series:
for example please see attached file tree.mw
f := proc (x) options operator, arrow; exp(x) end proc:
alpha := 1/2:
N := 10:
f_approximate := proc (x) options operator, arrow; sum(a[i]*x^`iα`, i = 0 .. N) end proc
Download tree.mw
Hello, to all,
On my computer I have installed Windows 7 Professional, Maple 2018.2.1 and
Physics:-Version()[2];
 2019, January 5, 13:32 hours, version in the MapleCloud: 276,
    version installed in this computer: 276
When I try to compute some examples from your poste "PDE_and_BC_during_2018.mw", I get an error in Example 8:
Example 8: This problem represents the temperature distribution in a thin circular plate whose lateral surfaces are insulated (Articolo example 6.9.2):
pde__8 := diff(u(r, theta, t), t) = (diff(u(r, theta, t), r)+r*(diff(u(r, theta, t), r, r))+(diff(u(r, theta, t), theta, theta))/r)/(25*r);
              d                    1   |/ d                \
   pde__8 := --- u(r, theta, t) = ---- ||--- u(r, theta, t)|
              dt                  25 r |\ dr               /
                                      2                  \
                                     d                   |
                                  -------- u(r, theta, t)|
          /  2                \          2               |
          | d                 |    dtheta                |
      + r |---- u(r, theta, t)| + -----------------------|
          |   2               |              r           |
          \ dr                /                          /
iv__8 := D[1]*u(1, theta, t) = 0, u(r, 0, t) = 0, u(r, Pi, t) = 0, u(r, theta, 0) = (r-(1/3)*r^3)*sin(theta);
   iv__8 := D[1] u(1, theta, t) = 0, u(r, 0, t) = 0,
                                       /    1  3\
     u(r, Pi, t) = 0, u(r, theta, 0) = |r - - r | sin(theta)
                                       \    3   /
pdsolve([pde__8, iv__8], u(r, theta, t), HINT = boundedseries(r = [0]));
Error, (in dsolve) cannot determine if this expression is true or false: not 0 <= -Pi
or I get no answer as in Example 10:
Example 10: A Laplace PDE with one homogeneous and three non-homogeneous conditions:
pde__10 := diff(u(x, y), x, x)+diff(u(x, y), y, y) = 0;
                    /  2         \   /  2         \
                    | d          |   | d          |
         pde__10 := |---- u(x, y)| + |---- u(x, y)| = 0
                    |   2        |   |   2        |
                    \ dx         /   \ dy         /
iv__10 := u(0, y) = 0, u(Pi, y) = sinh(Pi)*cos(y), u(x, 0) = sin(x), u(x, Pi) = -sinh(x);
      iv__10 := u(0, y) = 0, u(Pi, y) = sinh(Pi) cos(y),
pdsolve([pde__10, iv__10]);
There are also no answer as in Examle 10 in the Examples 15, 18, 19
Can you give me a hint,  what could be wrong?
With kind regards
Wolfgang Gellien
Hello everyone!
I am trying to calculate the Killing vectors for the metric below. For such, I used the packages DifferentialGeometry and Physics. However, I found different results these packages. Could someone explain why?
Thanks in advance!
killing_test1.mw
killing_test2.mw
So I was trying to create a shorthand for creating a plot of multiple arrows, with the arrow colour dependent on the magnitude of the vector.
I currently have a set of vectors, v, I want to display, and v[4] is the largest.
I know this could be done by creating an arrow plot for each vector seperately and then by combining them using display:
arrow1 := arrow( v[1], width=0.15,length=20,color=ColorTools:-Color( (norm(v[1])/norm(v[4]))*[0,0,1] ) );
arrow2 := arrow( v[2], width=0.15,length=20,color=ColorTools:-Color( (norm(v[2])/norm(v[4]))*[0,0,1] ) );
print(plots:-display([arrow1, arrow2, ...]));
But I was wondering if it could be done in a fashion similar to this:
arrows := arrow([seq(v[i], i=1..4)],width=0.15,length=20,color=ColorTools:-Color((norm(v[i])/norm(v[4]))*[0,0,1]));
print(arrows);
(btw: it works fine replacing the last i with 1, which draws all arrows nearly black, or with 4, which as you guessed, draws all arrows blue...)
Help appreciated!
Look I have actually purchased the software 3 time in total throughout my life, but i have no money at this point but i have a Linux OS now and i am enjoying learning how to use that, so i was wondering if there is a standard old verson that is open source and availble for a Linux install
Sum of -(2*((-1)^n-1))*sin(n*Pi*x)*exp(-Pi^2*n^2*t)/(Pi*n) from n=20??? Thank you very much
I try to use command "for a in 1,2 do Tangent(f, x = a) end do" in my Maplet but it does not work.
Here it is:
 [Button("Tangent line", Action( Evaluate(for a in 'solve(diff(func, x) = slp, x)' do 'MMLV1'='MathML[Export]('y'=Tangent(func,x=a))' end do)))],
And here is all code for my Maplet
> restart:with(Maplets[Elements]):with(Student[Calculus1]):  TL2:=Maplet([ ["Input function  f(x)=", TextField['func'](20)],[Button("Display function",Action(Evaluate('MMLV'='MathML[Export](func)')))],MathMLViewer['MMLV'](), ["Input slope", TextField['slp'](10)],  [Button("Tangent line", Action( Evaluate(for a in 'solve(diff(func, x) = slp, x)' do 'MMLV1'='MathML[Export]('y'=Tangent(func,x=a))' end do)))],   MathMLViewer['MMLV1']()   ]):  Maplets[Display](TL2):
I am trying to create an array whose elements are from another matrix. Suppose I have a matrix of n cross m dimension my array will have a dimension of 1 cross n*m. When I create  array I am getting error. The array contains only last element of matrix. The expected answer is given in attachment.
sigma.mw
Suppose there is a list with edges (L1): [{3,5},{4,3},{4,6},{3,2},{2,6}] and a list with vertices (L2): [1,5,4].
I would like to get a true-statement when a number of L2 appears in one of the edges of L1.
I tried the following:
for i in L1 do
ME:=member(i,L2):
print(ME):
This only gives false-statements. Could anyone help me?
I found a case where pdetest fails when called after another call to pdetest. I am using Physics version 272 from the clould. Using Maple 2018.2.1 on windows 10
u:='u';x:='x';t:='t';
pde := diff(u(x, t), t) + diff(u(x, t),x) =0;
sol:=pdsolve(pde,u(x,t));
pdetest(sol,pde);
    #0  OK
#restart;
pde:=diff(u(x,t),t)+diff(u(x,t),x)=0;
bc:=u(0,t)=0;
ic:=u(x,0)=sin(x);
sol:=pdsolve([pde,ic,bc],u(x,t)) assuming x>0;
pdetest(sol,pde);
     #sol := u(x, t) = -sin(-x+t)*Heaviside(-t+x)   #OK
     #-Dirac(-t+x)*sin(x)*cos(t)+Dirac(-t+x)*cos(x)*sin(t)+
      Dirac(-x+t)*sin(x)*cos(t)-Dirac(-x+t)*cos(x)*sin(t)   #WRONG should be 0
If I run the above again, but with restart call in between active, so that all is cleared, then pdetest gives 0 as expected on the second pde, with the same solution
pdetest(sol,pde);
   #0   #OK
bc:=u(0,t)=0;
ic:=u(x,0)=sin(x);
pdetest(sol,pde);
   #0   #OK !!
can any one explain why this happens?  Is this a bug? It seems like pdetest caching problem. it remembers something from the last call and this affects the result it gives for the next call.
any work around?
Another GCD attempt. Why is there a parse problem? Thanks
"proc GCD3:=proc(n1,n2)    local r, a,b;    a:=n1; b:= n2;    while (a mod b) >0  do       r:=a mod b;      a:=b;      b:=r;   end do;    return b;  end proc;  "
Error, unable to parse
Download GCD3.mw
Any sugggestions gratefully received
I do know that Maple has a gcd command but I am just experimenting
GCD2.mw
"GED2:=proc(n1 ,n2)     local a,b;     option remember;     a:=n1:b:=n2:     if b = 0 then do         return a ;    else       return GED2(b, a mod b);    end if;  end proc;"
Error, unterminated procedure
Download GCD2.mw
In an expression I have several terms with different coefficients and permutations of them say
aS+bc + bS+cS- + cb + others etc
I want to order them the way I want, like, say
abcS+ + bcS+cS- +bc  etc
How can I do this?
Happy New Year!
I solve ode for simply DC motor system:
J:= 0.01;b:=0.1;K:= 0.01;R:=1;L:=1;
eq1:=J*diff(theta(t),t,t)+b*diff(theta(t),t)=K*i(t):
eq2:=L*diff(i(t),t)+R*i(t)=V-K*diff(theta(t),t):
ICs:= theta(0)=0, D(theta)(0) = 0, D(theta)(0) = 0, i(0) = 0:
sol:=dsolve({eq1,eq2,ICs},numeric,parameters=[V],output=listprocedure):
sol(parameters=[10]):
ode_x1:=sol[2];
ode_x1:=rhs(ode_x1);
ode_x2:=sol[3];
ode_x2:=rhs(ode_x2);
p1:=plot([ode_x1(t),ode_x2(t)],t=0..50,gridlines=true):
plots[display](array([p1]));
I have time wektor and input wektor V in csv file. How to change this code to simulate
ode solution ode_x1 and ode_x2 with data from file? Now I set V as
and t in
Best
Hello everybody.
This is my question. I tried to evaluate a list of polynomial over a list of values. Something like this:
eval([a*x, b*x], x = [p, q, t])
to get something like this:
[[a*p, a*q, a*t], [b*p, b*q, b*t]]
I know this method: eval~(a*x,x=~[p,q,t])  though this works for one polynomial over a list of values. Not precisely, what I am looking for.
I figured out a method that worked defining functions and with ‘apply’ and ‘map’. Here an example:
m:=t->3*2^t:
n:=t->(t+4)^2:
map(apply~,[m,n],[1,2,3]);
[[6, 12, 24], [25, 72, 147]]
However, how can I get this result using the ‘eval’ function.
Thank you all in advanced for any contribution.
First 771 772 773 774 775 776 777 Last Page 773 of 2464
