M := -6*alpha*eta^2*mu*(lambda^2*mu+1)/`ϑ`+12*alpha*eta^2*lambda*mu^(3/2)*(sqrt(mu)*cot(A+sqrt(mu)*eta*(-t*(-alpha*eta^2*mu+f)+x))*lambda+1)/(`ϑ`*cot(A+sqrt(mu)*eta*(-t*(-alpha*eta^2*mu+f)+x)))-6*alpha*eta^2*mu*(sqrt(mu)*cot(A+sqrt(mu)*eta*(-t*(-alpha*eta^2*mu+f)+x))*lambda+1)^2/(`ϑ`*cot(A+sqrt(mu)*eta*(-t*(-alpha*eta^2*mu+f)+x))^2)+6*mu*eta^2*alpha*sqrt(sigma*(1+cot(A+sqrt(mu)*eta*(-t*(-alpha*eta^2*mu+f)+x))^2))/(sqrt(sigma)*theta*cot(A+sqrt(mu)*eta*(-t*(-alpha*eta^2*mu+f)+x))^2);
             2    /      2       \
  6 alpha eta  mu \lambda  mu + 1/
             ϑ
                /      (1/2)     /   /          2       \    \\
  ϑ cot\A + mu      eta \-t \-alpha eta  mu + f/ + x//
  /            2          (3/2) /  (1/2)    /
  \12 alpha eta  lambda mu      \mu      cot\A
       (1/2)     /   /          2       \    \\           \\
   + mu      eta \-t \-alpha eta  mu + f/ + x// lambda + 1// -
                /      (1/2)     /   /          2       \    \\
  /           2    /  (1/2)    /
  \6 alpha eta  mu \mu      cot\A
       (1/2)     /   /          2       \    \\           \  \
   + mu      eta \-t \-alpha eta  mu + f/ + x// lambda + 1/^2/ +
  |        2       |      |
  \6 mu eta  alpha \sigma \1
                                                       2\\      \/
        /      (1/2)     /   /          2       \    \\ ||      |
   + cot\A + mu      eta \-t \-alpha eta  mu + f/ + x// //^(1/2)/
  |     (1/2)
  \sigma      theta
                                                    2\
alpha := 2;
eta := 3;
mu := 1.5;
                              1.5
lambda := 2;
theta := 3;
sigma := .5;
                              0.5
b := .5;
                              0.5
f := 5;
                               5
y := 0;
plot3d([abs(M)], x = -3 .. 3, t = -3 .. 3);
How I can extract data about figure as matrix format.
I want to save data from figure as matrix for each curve in figure as i.e.,  x and y .
for example as this format.
fig10.mw
sol := Vector[column](4, [` 1001 x 4 `*Matrix, `Data Type: `*anything, `Storage: `*rectangular, `Order: `*Fortran_order])
hi everyone,
I am trying to find maxima for a multi variable function. As a first step I want to find out partial differentiation and equate each expression to zero.
Normally I would expect to solve these equations to get the variable value(s). But I came across a perticular function which cannot be solved as above explained.
Expression :=30*a*sin(theta)+80*cos(theta)*b
variable :=  {a, b, theta} # using indets(Expression,name)
PartialDifferentiationExpressions :={80*cos(theta), 30*sin(theta), 30*a*cos(theta)-80*sin(theta)*b}
How can I find the critical Points from these?
My approach is to find Hessian Matrix and ten find out maxima for the function(at which critical point it happens)
Note Edit: This is an example. I am writing a script which takes an equation as Input and solve for the maxima. Hence, I would like to know how to when this kind of situation arises. Thank You
How can i solve this system of equations:
{c*(N-k)*(1-exp(-p)) = p, -d*((k-N)*exp(-p)-k) = N, 0 < N, 0 < p, 1 < c, 1 < d, 1 < k}
N and P are variables and the others are constant numbers.
I used "solve" function but the results are:
piecewise(And(1 < c, 1 < d, 1 < k, 0 < -RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z)*d/((d-1)*c), 0 < -RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z)), [{N = d*k*(exp(RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z))-1)/(d*exp(RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z))-1), p = c*k*(d*exp(RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z))-d-exp(RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z))+1)/(d*exp(RootOf(exp(_Z)*c*d*k+exp(_Z)*_Z*d-exp(_Z)*c*k-c*d*k+c*k-_Z))-1)}], [])
Is it possible to export data from Maple to Excel where data are generated by Maple using Optimization:-LSSolve or DirectSearch:-SolveEquations function?
I have attached a file, where n is the primary variable. For n=1, 2, 3, .......... 20, I have got solution individually. But it is more time consuming event. Is it possible to use array or a vector for the variable n and solve equations at a time for all value of n and stored a excel file?
Any advice for me? @Preben Alsholm , @tomleslie or anybody
system_equations_(10.12.2008).mw
I've made calculation as array := function(array1,array2). Then summ of all array[i] all in one cycle. If I look in summ variable I see fu(0+fu() +.. agebraical representation. I tried evalf(summ). still algebraical. How to derive numerically?
I want to calculate the following summation for a,b;
when it is odd,
vanishes.
MY TRY:
J:=proc(a,b,c) local u,v,p,w;
p:=(a+b+c):
if p=2*k then
u:=b+c-a:
v:=c+a-b:
w:=a+b-c:
return (-1)^p*sqrt(binomial(2*u,u)*binomial(2*v,v)*binomial(2*w,w)/((2*p+1)*binomial(2*p,p)))
return 0
end if
aa:=2:bb:=4:
sum(J(aa,bb,cc)*J(aa,bb,cc)*sqrt(2*(2*aa+1)*(2*bb+1)*(2*cc+1))*psi[1,cc],cc=abs(bb-aa)..(aa+bb));
I am confused by solve and SolveEqutions and their options!
Solving same equation results different solutions.
Which  solution is correct and why?
How i can be sure one of the solutions is correct about the other equations?
I attached my code.
Test2_MaplePrimes.mw
Its difficult for me to explain what I'm looking for so I will try with an example:
Example 1
Is there anyway any function that will say for example the sum of squares of integers for a given n say n=4, 1^2 + 2^2 + 3^2 + 4^2 = 30 that will give the equation ((n^3)/3) + ((n^2)/2) + (n/6) that gives the sum for a given n?
It would be determined from the series 1^2 + 2^2 + 3^2 + 4^2 + ... or the equation for the elements 1^2, 2^2, 3^2, 4^2 the equation that gives the sum; in this case the well known ((n^3)/3) + ((n^2)/2) + (n/6) .
So far I've got FindSequenceFunction[{1, 4, 9, 16}, n] but this only finds the individual elements not an equation for the sum of them. Of course I already know the equation for producing the individual elements.
How can plot  f := proc (x, y) options operator, arrow; sin(x)*cos(y) end proc  as surface and contour (contour is project on surface)
I want to solve quadratic eqution involving more than 2 parameters...want to analize unique soltuions and real roots also want to plot the real and unique region on graphs ....thanx
the equation is -delta*(Q*S*alpha*b-a*alpha^2+M*c+b*delta) where alpha is the varible and rest are paramters
Hei!
In my Maple project I want to put a simple sin graph on top of an image. But how do I create a background image with a graph on top?
PI := proc (p, e, q) options operator, arrow; p*S(p, e, q)+v*(q-S(p, e, q))-w*q-g(e)+(w-c)*q end proc
S := proc (p, e, q) options operator, arrow; q-(int(F(x), x = 0 .. q)) end proc
PI(p, e, q)
p*(q-(int(F(x), x = 0 .. q)))+v*(int(F(x), x = 0 .. q))-w*q-g(e)+(w-c)*q
g := proc (e) options operator, arrow; (1/2)*mu*e^2 end proc
F := proc (x) options operator, arrow; int(f(x), x = 0 .. q) end proc
P := proc (p, e, q) options operator, arrow; simplify(eval(PI(p, e, q), [alpha = 50, w = 10, mu = 10, c = 5, v = 1, f(x) = 1/2])) end proc
Diff_p := diff(P(p, e, q), p)
q-(1/2)*q^2
Diff_e := diff(P(p, e, q), e)
-10*e
Diff_z := diff(P(p, e, q), q)
-p*q+p+q-5
Download Profit_code.mw
why i can not evaluate 29 polynomial. maple try to evaluate last 7hr, how many time required too solve it?
How to change the numbers shown in the diagram shapes from y=0.5- to rigth form y=-0.5a.mw
Download a.mw
First 779 780 781 782 783 784 785 Last Page 781 of 2464
