I use the plots:-shadebetween( ) command quite a bit to visualize volume under a surface over a planar rectangular region. Is there a way, using this same command, to see said volume over a non-rectangular region? For example, the region bounded above by z = x^2 + y^2, having a triangle base 0<=x<=1, 0<=y<=x. If this command does not allow for this, is there some other solution?
Not sure why I need to invoke the simplify command here, shouldn't the immediate simplification occur?
simplify(%)
However, it does work algebraically
My goal is to generate incremental values of a function to plot using dataplot. Why does the first example generate numeric values in the Vector and the second example does not?
fenq := f -> 2.1^(f+1):
pf := Vector(5, fenq)
                             [  4.41   ]
                              [  9.261  ]
                         pf := [ 19.4481 ]
                              [40.84101 ]
                             [85.766121]
fseqn := (Se, f) -> Se^(f+1):
psf := Vector(5, fsenq(2.1, j))
I can plot the first data set using dataplot(pf). I cannot plot the second data set.
Hi, I have been looking at various questions which are similar. But, I could not exactly what I am looking for.
https://www.mapleprimes.com/questions/99679-Removing-Elements-In-A-List
In the above link it is useful to remove elemets of specific type(identical in two lists). I am looking for removing elements from list with specific Index.
L := [1,1,a,c,1];
indexList:=[3,5]
Now based on IndexList I would like to remove the elements from L. That is I want to delete L[IndexList[1]] and L[indexList[2]]. I have tried to do it using
remove(has, L, L[indexList]);
It is working when there are no identitical elements. In my case it fails to delete exact exlemens.
subs(seq(A[indexList[i]] = NULL, i = 1 .. nops(indexList)), A); Both are working in same way. Not suitable when having identical elements in a list
How one could delete(remove) elements based on index??
I'm very new at maple and trying to understand its engine, but it is really hard sometimes when it doesn't make sense what it is doing. I have a function that gives me
com2(e,e,f)=eh+he
and then I would like to substitute eh into <1,0> and he into <0,1>, so I write
subs({eh=<1,0>, he=<0,1>}, com2(e,e,f))
which gives me the following answer
eh+he
Here comes the confusing part. When I plug in eh+he directly into the subs thing I get
<1,1>
Why are these two outputs different from each other? To clarify, why is subs({eh=<1,0>, he=<0,1>}, com2(e,e,f))=/=subs({eh=<1,0>, he=<0,1>}, eh+he)?
Is there a way to program this:
I have to write an equation like this (x1+x2)*(x1+x3)*(x2+x3)=0. Left side is a combination, k=2 and n=3 so the number of terms is 3. For small number of terms this is not a problem to type, but if I have x1,x2,x3,x4,x5,x6, the number of combinations is 15 so it is complicated. Is there a way how to program something like this in Maple or I have to do it manually?
I have two function :
And
A={g(R,L)=1}=
(I will call that L : L0=h(R))
So I want to represent f(A) in 3D
So I tried
It does not work, and I do not see how I could do otherwise...
Thank's in advance !
hi.
According to the fhgure attaceh how i can gain the equation (2-27) . I write the equation (2-26) in maple but I couldnot to gain that result.
If possible to reach equation via maple?
diff.mw
FC := (1/2)*W_m^2*(c1*x^2+c2*y^2)+(E.(h^2))*W_m^2*(sum(An*((sinh(n*Pi/lambda)+n*Pi*cosh(n*Pi/lambda)/lambda)*cosh(2*n*Pi*y/a)-2*n*Pi*y*sinh(n*Pi/lambda)*sinh(2*n*Pi*y/a)/a)*cos(2*n*Pi*x/a)/(n^2*(sinh(n*Pi/lambda)*cosh(n*Pi/lambda)+n*Pi/lambda))+Bn*((sinh(n*Pi*lambda)+n*Pi*lambda*cosh(n*Pi*lambda))*cosh(2*n*Pi*x/b)-2*n*Pi*x*sinh(n*Pi*lambda)*sinh(2*n*Pi*x/b)/b)*cos(2*n*Pi*y/b)/(lambda^2*n^2*(sinh(n*Pi*lambda)*cosh(n*Pi*lambda)+n*Pi*lambda)), n = 1 .. n))
S := diff(FC, x); SS := diff(S, x)
g := subs(x = (1/2)*a, SS)
coeff(g, sinh(n*Pi/lambda))
Download diff.mw
The command print placed within a while loop does not produce any printout. How do I  make MAPLE to produce  it?
I am trying to animate two variables in a 3D plot. Basically I would like to combine these two animations into one simultaneous animation:
animate(plot3d, [[y, x, (1/3)*Pi], x = 0 .. 2*Pi, y = 0 .. R, coords = spherical, scaling = constrained], R = 0 .. 5)
animate(plot3d, [[y, x, (1/3)*Pi], x = 0 .. p, y = 0 .. 5, coords = spherical, scaling = constrained], p = 0 .. 2*Pi)
so that both animations start and end simultaneously. Is this possible?
I appreciate your help forfinding the best fitting line for a discrete series.
Starting with 1978 as base year and counting by two's the five year overage global temperature. where
the temperature is given by the data : x[0],...,x[12]
1) Find the best  fitting line : x[n+1]=a*x[n]+b
2) Assuming we can extrapolate, find the predicted value x[30]
Fitting_best_line.mw
Many thanks for your help.
Hi everybody, i want to plot the intersection volume of three inequality, how can i do it?
d1:=3:d2:=3:d3:=5:
plots:-implicitplot3d([x^2+y^2+z^2<d1^2,(x-3)^2+y^2+z^2<d2^2,x^2+y^2+(z-4)^2<d1^2],x=-5..5,y=-5..5,z=-5..5,style= wireframe)
Download plot.mw
I am trying to solve the equation below. First method was subbing in all the parameters into the equation and the second method is plugging all the parameters straight into the equation. As you can see below, they give different results. Can someone please help me? I've been scratching my head for the past hr trying to figure out what am I doing wrong.
Method 1:
Y1 := P*b*x*(-b^2+l^2-x^2)/(6*l*E*I)
maxdeflection := subs(P = 60000, b = 2050, E = 16000, I = 3062827708, l = 6600, x = (50/3)*sqrt(47229), Y1)
=-(77224295347218906250/297)*sqrt(47229)
Method 2:
Y2 := (50/3)*(60000*2050)*sqrt(47229)*(6600^2-((50/3)*sqrt(47229))^2-2050^2)/(16000*(6*6600)*3062827708)
=(50426796875/1819319658552)*sqrt(47229)
Using Maple 2017.3, I ask for the roots of x3-x2-8x+8 and I get the following result:
roots(x^3-x^2-8*x+8);
                            [[1, 1]]
However, I know that (2*sqrt(2)) and -(2 * sqrt(2)) are also roots. Is this a bug or something I do not understand about the "roots" command?
Here's a slightly reduced form of a little module from some code that I posted recently:
KandR:= module()
local
   a, b, c, e, #parameters
   #procedure that lets user set parameter values:
   ModuleApply:= proc({
       a::algebraic:= KandR:-a, b::algebraic:= KandR:-b,
       c::algebraic:= KandR:-c, e::algebraic:= KandR:-e
   local k;
      for k to _noptions do thismodule[lhs(_options[k])]:= rhs(_options[k]) od;
      return
   end proc
end module:
The purpose of the module is simply to be a container for the four parameters and to provide a simple ModuleApply interface by which they can be set, reset, and/or unset.
I very often use a procedure parameter of a ModuleApply to set a local variable of same name in the module. Because of the name conflict, thismodule needs to be used in these situations. I see this as the primary use of thismodule. In the module above, the purpose of the line
is to avoid the need to explictly use the parameters yet a third time. First off, I am amazed that this works! I've had many disappointments with thismodule (which is essentially undocumented---its miniscule help page is nearly worthless). I am using Maple 2018, release 1. Another Maple 2018 user (not sure which release) reports that the above line gives an error (when executed) that thismodule's index must be a name.
Question 1: What's up with that?
[Edit: It's been determined that the problem was due to an unfortunate global assignment in that user's initialization file rather than different behavior of thismodule. So, I consider Question 1 to be completely answered, and it should be ignored.]
Question 2: The for loop is not entirely satisfying to me. Is there a better way?
[Status: Answered, see below.]
Question 3: Ideally, I'd like to explicity use the four parameters once, not two or three times. Is there a way? If I need to use a container for the parameters (such as a Record), to achieve that, I'd be happy to do that, and I wouldn't mind needing to invoke that container's name any number of times.
Note that op and exports can be applied to thismodule to extract the module's operands. I have found this occasionally useful.
Question 4: What are some other good uses for thismodule? The one and only example given on its help page seems ridiculous to me.
First 796 797 798 799 800 801 802 Last Page 798 of 2464
