In a plane, equilateral triangles D(i) with side lengths a(i)= 2*i−1, i = 1; 2; 3; ... are arranged along a straight line g in such a way that the "right" corner point of triangle D(k) coincides with the "left" corner point of triangle D(k+1) and that the third corner points all lie in the same half-plane generated by g. Determine the curve/function on which the third corner points lie!
Good afternoon.
I have a differential equation of non-integer degree and would like to know if it is possible to express a solution in terms of elementary or special-functions for certain values of the exponent, n>0.
For this equation, Maple provides an analytical solution for the exponent values n=0 and n=1, otherwise, there is no solution returned. I am particularly interested in the cases where n=1/2, 3/2, 2, 5/2, and 3
I am hoping that someone can help me resolve this - if a closed-form solution is not possible, then a numerical solution would also be welcome.
I have provided the details in the attached worksheet.
Thanks for reading!
MaplePrimes_Dec_19.mw
Given the center x1 of a circle in R^2 with radius d12, and a point p2 on the circle, so that d12=||p2-x1||, denote the points on the line segment from x1 to p2 as x1(t) = x1+t*v12, with t=0..d12, and v12 =( p2-x1)/d12.  I want to animate the points x1(t) moving along the line segment from x1 to p2 and the corresponding circles of decreasing radius, with center x(t) and radius d12-t, so that p2 remains on the circle.
I can animate the points along the line segment from x1 to p2 using ‘style=point, symbol=solidcircle’.
I would like to use plottools-circle, to plot the circles. I have also tried the following type commands for the circles of decreasing radius.
Plot([x1(1)+t*v12(1)+(d12-t)*cos(theta)*v12(1)+ (d12-t)*sin(theta)*u12(1), x1(2)+ +t*v12(2)+(d12-t)*d12*cos(theta)*v12(2)+(d12-t)*sin(theta)*u12(2), theta=0..2*PI]
where u12 is a unit vector orthogonal to v12.
I have not been able to combine the two plots into an animation. Thank you
On considère une ellipse x^2/a^2+y^2/b^2-1=0 et 2 sommets de cette ellipse A(a,0) et B(0,b). On imagine une hyperbole équilatère variable passant par les points O, A et B. Cette courbe rencontre l'ellipse en 2 autres points A1 et B1. Montrer que la droite A1B1 passe par un point fixe. Même avec l'intelligence artificielle, je ne parviens pas à résoudre ce problème. Pourriez-vous d'aider. Merci.
Machine translation by moderator:
We consider an ellipse x^2/a^2+y^2/b^2-1=0 and 2 vertices of this ellipse A(a,0) and B(0,b). We imagine a variable equilateral hyperbola passing through the points O, A and B. This curve meets the ellipse at 2 other points A1 and B1. Show that the line A1B1 passes through a fixed point. Even with artificial intelligence, I can't solve this problem. Could you help. Thank you.
I have this system
eq1 := diff(x(t), t)-(1/6)*(6*x(t)^3*y(t)+(2*y(t)^2-2)*x(t)^2+3*y(t)*(z(t)-2)*x(t)-2*y(t)^2+2)*sqrt(3) = 0;
eq2 := diff(y(t), t)-(1/6)*(y(t)-1)*sqrt(3)*(y(t)+1)*(6*x(t)^2+2*y(t)*x(t)+3*z(t)-2) = 0;
eq3 := diff(z(t), t)-(1/3)*z(t)*sqrt(3)*(6*y(t)*x(t)^2+2*x(t)*y(t)^2+3*z(t)*y(t)-2*x(t)-3*y(t)) = 0;
I solved it numerically using these ics
ics := x(0) = -0.01, y(0) = .99, z(0) = 0.01
sol1 := dsolve({ics, op(syst)}, {x(t), y(t), z(t)}, type = numeric, output = listprocedure)
I need to use the x(t), y(t), z(t) as follows
  X :=  eval(x(t), sol1)
  Y :=  eval(y(t), sol1)
Z :=  eval(z(t), sol1)
to solve the following system for P(t), Q(t), R(t) numerically
eq4 := diff(R(t), t)-P(t)*Z-(-2*(-Y^2+2)*X/sqrt(3)+sqrt(3)*(-2*X^2+Z+4/3)*Y)*R(t) = 0;
eq5 := diff(Q(t), t)-(2/3)*R(t)+2*((1/3)*Y+X)*P(t)/sqrt(3)-(-2*(-Y^2+2)*X/sqrt(3)+2*sqrt(3)*(X^2-(1/2)*Z-2/3)*X)*Q(t) = 0;
eq6 := diff(P(t), t)+(1/2)*R(t)+2*sqrt(3)*X*Q(t)+(2*(-Y^2+2)*X/sqrt(3)+sqrt(3)*(-2*X^2+Z+1)*Y)*P(t) = 0;
Any help please?
Hey Guys,
I have to solve multiple system of equations under some restrictions given as inequalities. Sometimes solve is not able to find the result in houres so I tryd to break the problem in half. So in the first step I just want to solve my 8 polynomial equations with 8 variables and in a second step I want so take the solutions, bring them together with the set of inequalities and solve it again. Since also some sets of equations are to hard for the simple solve command I got the advice from people of this plattform to try PolynomialSystem with the diffrent engines. However I have the feeling they make misstakes and now Im not sure If I can trust my results.
Attached you can find a file with an example. In the beginning I solve equations and restrictions together and there is a solutions. Then I tryd to solve only the equations with PolynomialSystem and the the four known engines and the eniges traditional and backsolve dont find the solution which as we saw before exist. When a soultions holds under restrictions it should always appear if I omit the restirctions. When I use the enige triade and groebner then the right solution is there.
However in some other cases it feels the other way round.
So to me it looks like no matter which engine I take, I can never 100% trust my results. Did I something wrong? Whats the reason for those mistakes? Furthermore backsolve gives me 7 solutions, but solutions 2 and 7 are the same. I also recognized, that there is a diffrence between putting in the variable vars as a list or a set. What happens, if I dont specify which engine should be used?
I am happy about any advice. Thank you in advance.
Felix
restart; equations := {-y*(m-p) = 0, ((-x-y+1)*k+x)*n+s*y-t = 0, (k-x-y)*t-k*p+y = 0, (-m+n+y)*x+m-1 = 0, -(x+y-1)*(p-t)*k+(-x-y+1)*t+x*p = 0, y^2+(-m-1)*y+1+x*(p-1) = 0, (-x-y+1)*t+(-m+1)*x+y*n+m-1 = 0, -k*n+s*x = 0}; restrictions := {0 < k, 0 < m, 0 < s, 0 < x, 0 < y, 0 < n+(t-1)*p, 0 < (m*y-1)*n+(1-p)*(m*x-m+1), 0 < (m*x-m-t+1)*p+m*y*(t-n), 1 < x+y, k < 1, m < 1, s < t, t < 1}; vars := indets(equations); evalf(solve(`union`(equations, restrictions), vars)); Sol_w := SolveTools:-PolynomialSystem(equations, vars); Sol_traditional := SolveTools:-PolynomialSystem(equations, vars, engine = traditional); nops([Sol_traditional]); Sol_backsolve := SolveTools:-PolynomialSystem(equations, vars, engine = backsolve); nops([Sol_backsolve]); Sol_triade_1 := SolveTools:-PolynomialSystem(equations, vars, engine = triade); nops([Sol_triade_1]); Sol_groebner := SolveTools:-PolynomialSystem(equations, vars, engine = groebner); nops([Sol_groebner])
{k, m, n, p, s, t, x, y}
{k = 0.536796024e-1, m = .241141717, n = .54019322, p = .241141717, s = 0.35770767e-1, t = .4477103163, x = .8106439941, y = .6370663217}
{k = 1, m = m, n = 1, p = 0, s = 1, t = 1, x = 1, y = 0}, {k = 1, m = 1, n = 0, p = 1, s = t, t = t, x = 0, y = 1}, {k = k, m = 1, n = 0, p = 1, s = 1, t = 1, x = 0, y = 1}, {k = 1, m = 1, n = 0, p = 1, s = 0, t = 0, x = x, y = 1}, {k = 1/3, m = -1, n = 3, p = -1, s = 2, t = 2, x = 1/2, y = 0}, {k = 1/3, m = -1, n = 2, p = -1, s = 2/3, t = 2, x = 1, y = -1}, {k = -(1/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4+(2/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3+(16/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(1/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-7/9, m = (4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(20/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(17/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+21*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-28/3, n = (11/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(53/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(55/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(152/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-61/3, p = (4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(20/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(17/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+21*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-28/3, s = -(8/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4+(40/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3+(35/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2-(127/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)+58/9, t = (1/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(8/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(7/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)+1/3, x = (1/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(8/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)+4/3, y = RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)}
{k = 1, m = m, n = 1, p = 0, s = 1, t = 1, x = 1, y = 0}, {k = 1/3, m = -1, n = 3, p = -1, s = 2, t = 2, x = 1/2, y = 0}, {k = k, m = 1, n = 0, p = 1, s = 1, t = 1, x = 0, y = 1}, {k = 1, m = 1, n = 0, p = 1, s = s, t = s, x = 0, y = 1}, {k = 1/3, m = -1, n = 2, p = -1, s = 2/3, t = 2, x = 1, y = -1}, {k = 1, m = 1, n = 0, p = 1, s = 0, t = 0, x = x, y = 1}
6
{k = 1, m = m, n = 1, p = 0, s = 1, t = 1, x = 1, y = 0}, {k = 1/3, m = -1, n = 3, p = -1, s = 2, t = 2, x = 1/2, y = 0}, {k = k, m = 1, n = 0, p = 1, s = 1, t = 1, x = 0, y = 1}, {k = 1, m = 1, n = 0, p = 1, s = s, t = s, x = 0, y = 1}, {k = 1/3, m = -1, n = 2, p = -1, s = 2/3, t = 2, x = 1, y = -1}, {k = 1, m = 1, n = 0, p = 1, s = 0, t = 0, x = x, y = 1}, {k = 1/3, m = -1, n = 3, p = -1, s = 2, t = 2, x = 1/2, y = 0}
7
{k = 1, m = 1, n = 0, p = 1, s = 0, t = 0, x = x, y = 1}, {k = 1, m = m, n = 1, p = 0, s = 1, t = 1, x = 1, y = 0}, {k = k, m = 1, n = 0, p = 1, s = 1, t = 1, x = 0, y = 1}, {k = 1, m = 1, n = 0, p = 1, s = t, t = t, x = 0, y = 1}, {k = -(1/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4+(2/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3+(16/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(1/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-7/9, m = (4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(20/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(17/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+21*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-28/3, n = (11/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(53/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(55/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(152/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-61/3, p = (4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(20/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(17/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+21*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-28/3, s = -(8/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4+(40/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3+(35/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2-(127/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)+58/9, t = (1/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(8/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(7/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)+1/3, x = (1/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-(4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3-(8/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2+(4/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)+4/3, y = RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)}, {k = 1/3, m = -1, n = 2, p = -1, s = 2/3, t = 2, x = 1, y = -1}, {k = 1/3, m = -1, n = 3, p = -1, s = 2, t = 2, x = 1/2, y = 0}
7
7
evalf(allvalues({k = -(1/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4+2*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/9)+16*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/9)+(1/9)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-7/9, m = 4*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4*(1/3)-20*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/3)-17*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/3)+21*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-28/3, n = 11*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4*(1/3)-53*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/3)-55*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/3)+152*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)*(1/3)-61/3, p = 4*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4*(1/3)-20*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/3)-17*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/3)+21*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)-28/3, s = -8*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4*(1/9)+40*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/9)+35*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/9)-127*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)*(1/9)+58/9, t = (1/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-4*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/3)-8*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/3)+7*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)*(1/3)+1/3, x = (1/3)*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^4-4*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^3*(1/3)-8*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)^2*(1/3)+4*RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)*(1/3)+4/3, y = RootOf(_Z^5-4*_Z^4-9*_Z^3+10*_Z^2+6*_Z-5)}))
{k = 0.536796024e-1, m = .241141717, n = .54019322, p = .241141717, s = 0.35770767e-1, t = .4477103163, x = .8106439941, y = .6370663217}, {k = .7943583912, m = 1.011543377, n = .16794280, p = 1.011543377, s = -.463558437, t = -.4040771797, x = -.287788440, y = .8837112597}, {k = -5.038767243, m = 3.694058367, n = 0.9373027e-1, p = 3.694058367, s = .299187114, t = 2.728412223, x = -1.578565716, y = 5.306977937}, {k = .2033642547, m = -26.40026363, n = -63.64948932, p = -26.40026363, s = 17.99511944, t = -2.562622110, x = -.719307867, y = -.8433142428}, {k = 2.542920564, m = -.546480183, n = 1.84762297, p = -.546480183, s = 1.244592174, t = .7905767063, x = 3.775017982, y = -1.984441276}
Can_I_trust_the_diffrent_eniges_of_Polynomial_Systems.mw
I have a simple question, but don't find a neat solution for it. I have 4 3d Vectors that result in the resulting Vector V5. I now want the unit vector of V5. How do I do it the most efficient way?
My attempt is in the file attached. I get the error message: "Error, (in rtable/Power) exponentiation operation not defined for Vectors"
Thanks a lot for your help.3d_vector.mw
Assuming I have a sumpro function written in Maple 2016. How can I implement it in C# and what is the process?
Please help me.
sumpro := proc (i) local a, b;
        a := (rand(1 .. 10))(); b := (rand(1 .. 10))();
        print("Sum of ", a, " and ", b, " is ", a+b)
save sumpro, "D://Sumpro.m"
sumpro := proc (i) local a, b; a := (rand(1 .. 10))(); b := (rand(1 .. 10))(); print("Sum of ", a, " and ", b, " is ", a+b) end proc:
Download mapleprime_sumpro_to_c.mw
This text is typed directly into the browser. I can now change the font size to something bigger. I can also change the font from Default to something else.
This text in Calibri 11 was pasted from Word. What do I have to do to change it to MaplePrimes default font (which I have used above)? Selecting default from
does not work because default is already selected when I put the cursor into the pasted text.
What is the default font type by the way? Can I change it permanetly?
All on Windows 10 and with Firefox.
If possible, please help me write the steps to solve the following equation.
By setting the coefficients of the same power (Yi) on both sides of equation equal, we solution get
I have some cubic and quartic equations with complex cofficients. Maple 2015 is able to solve these and returns the roots as labelled sets, so I can do things like "plot S[1]". I want to vary some parameters in the coefficients, and see what happens to the roots.
My problem is when I log out and then rerun the code, the labels 1,2,3,(4) are frequently attached to different roots than they were the first time. This is both unexpected and inconvenient. Is there any way to ensure that the same roots are always given the same labels?
[moderator: see also this Question from 2023]
l45 := (x + 7)(x - 1) = (1 + x)^2;
Error, (in solve) cannot solve for an unknown function with other operations in its arguments
This is my first time working with plotting data from a matrix. However, with the help of a friends on MaplePrimes, I learned how to plot the data in both Maple and MATLAB. Despite this, I am having trouble with visualization. When I change the delta value, my function experiences vibrations or noise, which is clearly visible in the plot. But when I change delta, I encounter errors with my matrix data. How can I fix this problem? and there is any way for get better visualization by Explore ? also How show this vibration or noise in 2D?
randomize():
local gamma;
gamma
currentdir(kernelopts(':-homedir'))
T3 := (B[1]*(tanh(2*n^2*(delta^2-w)*k*t/((k*n-1)*(k*n+1))+x)-1))^(1/(2*n))*exp(I*(-k*x+w*t+delta*W(t)-delta^2*t))
(B[1]*(tanh(2*n^2*(delta^2-w)*k*t/((k*n-1)*(k*n+1))+x)-1))^((1/2)/n)*exp(I*(-k*x+w*t+delta*W(t)-delta^2*t))
params := {B[1]=1,n=2,delta=1,w=1,k=3 };
{delta = 1, k = 3, n = 2, w = 1, B[1] = 1}
insert numerical values
solnum :=subs(params, T3);
(tanh(x)-1)^(1/4)*exp(I*(-3*x+W(t)))
CodeGeneration['Matlab']('(tanh(x)-1)^(1/4)*exp(I*(-3*x+W(t)))')
Warning, the function names {W} are not recognized in the target language
cg = ((tanh(x) - 0.1e1) ^ (0.1e1 / 0.4e1)) * exp(i * (-0.3e1 * x + W(t)));
N := 100:
use Finance in:
  Wiener := WienerProcess():
  P := PathPlot(Wiener(t), t = 0..10, timesteps = N, replications = 1):
end use:
W__points := plottools:-getdata(P)[1, -1]:
t_grid := convert(W__points[..,1], list):
x_grid := [seq(-2..2, 4/N)]:
T, X := map(mul, [selectremove(has, [op(expand(solnum))], t)])[]:
ST := unapply(eval(T, W(t)=w), w)~(W__points[.., 2]):
SX := evalf(unapply(X, x)~(x_grid)):
STX := Matrix(N$2, (it, ix) -> ST[it]*SX[ix]);
_rtable[36893490640185799852]
opts := axis[1]=[tickmarks=[seq(k=nprintf("%1.1f", t_grid[k]), k=1..N, 40)]],
        axis[2]=[tickmarks=[seq(k=nprintf("%1.1f", x_grid[k]), k=1..N, 40)]],
        style=surface:
DocumentTools:-Tabulate(
    plots:-matrixplot(Re~(STX), opts),
    plots:-matrixplot(Im~(STX), opts),
plots:-matrixplot(abs~(STX), opts)
  , width=60
"Tabulate"
MatlabFile := cat(currentdir(), "/ST2.txt"); ExportMatrix(MatlabFile, STX, target = MATLAB, format = rectangular, mode = ascii, format = entries)
421796
Download data-analysis.mw
After download MapleFlow 2024.2 "fsolve" return only one solution for a polynom of n-order.
Can I unchain by an hidden order?
A parallelogram is given in the Cartesian coordinate system. If the corner points of the parallelogram are connected to the midpoints of adjacent sides using lines, then the eight connecting lines form an octagon.
It must be proven that its area is one sixth of the parallelogram's area.
First 78 79 80 81 82 83 84 Last Page 80 of 2457
