int(int(x,y^4..16),y=0..2);
yields the output $\int_0^2\int_{y^4}^{16} x(x) dx dy$.
any one can help me to get the output of the plot in 3 rows and 2 columns here is my codes. thanks in advance.
  h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
  K1:=((4/h(z)^4)-(sin(alpha)/Gamma2)-h(z)^2+Nb*h(z)^4):
  lambda:=unapply(Int(K1,z=0..1), Gamma2):
  L1:=0.2:
  d1:=0.2:
  alpha:=Pi/6:
  display
  ( Vector[row]
    ( [ seq
        ( plot
          ( [ seq
              ( eval(lambda(Gamma2), Nb=j),
                j in [0.1,0.2,0.3]
            delta2=0.02..0.1,
            legend=[Nb=0.1,Nb=0.2,Nb=0.3],
            labels=[typeset(`δ1`), typeset(conjugate(`Δp`))],
            title=typeset("Effect of ", ''alpha'', " when ", Gamma,"2=", Gamma2)
          Gamma2 in [10,20,30,40,50,-10]
After run a batch to cmaple to run a prettyprint=0 and screenwidth=500
it use lprint in window
i set prettyprint=2
still can not set back to original print for matrix
Excel tool import can not be used in cmaple.exe
Plot the first 20 Fibonacci numbers.
I have this so far..
nums := [seq(i, i = 1 .. 20)]*with(combinat, fibonacci);
fibnums;
  here my loop; after  8 iteration maple couldnt solve the equations and give me this error .
Is there any method to garentee that fsolve could work intire the 1000 iteration
Download exp_new_for_alpha_more_than_22.mw
f[1] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(n, 1/R), sum(x[i], i = 1 .. n)), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, a[i]), x[i]), exp(VectorCalculus:-`*`(R, x[i]))), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(R, x[i])), -1), Q)), i = 1 .. n))):
f[2] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(m, 1/S), sum(y[j], j = 1 .. m)), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, b[j]), y[j]), exp(VectorCalculus:-`*`(y[j], S))), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(y[j], S)), -1), Q)), j = 1 .. m))):
f[3] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(n, m), sum(a[i], i = 1 .. n)), sum(b[j], j = 1 .. m)), 1/Q), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`+`(2, a[i]), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(R, x[i])), -1), Q)), i = 1 .. n))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`+`(2, b[j]), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(y[j], S)), -1), Q)), j = 1 .. m))):
E1[1] := 0.5e-1:
E2[1] := 0.5e-1:
E3[1] := 0.5e-1:
n := 45:
n := 45:
a := [seq(0, i = 1 .. 21), 2, 2, 1, seq(0, i = 1 .. 21)]:
K := 1000:
for so from 0 to K do W := GenerateUniform(n, 0, 1); for iii to n do vv[iii] := W[iii]^(1/(iii+sum(a[jjj], jjj = n-iii+1 .. n))) end do; for sss to n do uu[sss] := 1-product(vv[n-jjj+1], jjj = 1 .. sss); x[sss] := fsolve(1-3/(exp(.3*t)-(1-3)) = uu[sss], t = 0 .. infinity) end do; U := GenerateUniform(m, 0, 1); for ii to m do v[ii] := U[ii]^(1/(ii+sum(b[jj], jj = m-ii+1 .. m))) end do; for ss to m do u[ss] := 1-product(v[m-jj+1], jj = 1 .. ss); y[ss] := fsolve(1-3/(exp(.1*t)-(1-3)) = u[ss], t = 0 .. infinity) end do; c := describe[quartile[1]]([seq(x[i], i = 1 .. n)]); cc := describe[quartile[3]]([seq(x[i], i = 1 .. n)]); L := describe[quartile[1]]([seq(y[i], i = 1 .. m)]); LL := describe[quartile[3]]([seq(y[i], i = 1 .. m)]); R[1] := fsolve(9*exp(R*c)-exp(R*cc) = 8, R = 0 .. infinity); S[1] := fsolve(9*exp(S*L)-exp(S*LL) = 8, S = 0 .. infinity); Q[1] := 3*(exp(R[1]*c)-1+(exp(S[1]*L)-1))*(1/2); for h to 40 while `and`(`and`(`and`(`and`(`and`(abs(E1[h]) > 0.5e-3, abs(E2[h]) > 0.5e-3), abs(E3[h]) > 0.5e-3), Q[h] > 2), S[h] > 0), R[h] > 0) do Q[h+1] := fsolve(eval(f[3], {R = R[h], S = S[h]}) = 0, Q = 2 .. infinity); R[h+1] := fsolve(eval(f[1], Q = Q[h+1]) = 0, R = 0 .. infinity); S[h+1] := fsolve(eval(f[2], Q = Q[h+1]) = 0, S = 0 .. infinity); KK := Matrix([[R[h]], [S[h]], [Q[h]]]); E1[h+1] := abs(R[h+1]-R[h]); E2[h+1] := abs(S[h+1]-S[h]); E3[h+1] := abs(Q[h+1]-Q[h]) end do; A[so] := Determinant(KK[1]); B[so] := Determinant(KK[2]); C[so] := Determinant(KK[3]); P[so] := simplify(int(A[so]*C[so]^2*exp(A[so]*x)/((exp(A[so]*x)-1+C[so])^2*(exp(B[so]*x)-1+C[so])), x = 0 .. infinity, numeric)) end do
W := Vector(4, {(1) = ` 1 .. 45 `*Array, (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*C_order})
U := Vector(4, {(1) = ` 1 .. 45 `*Array, (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*C_order})
c := 2.251942600
cc := 6.413093396
L := 8.631577783
LL := 25.39584518
R[1] := .4287243564
S[1] := .1043333848
Q[1] := 4.630481096
A[0] := .4247642181
B[0] := .1149899971
C[0] := 6.627593396
P[0] := .8815279215
c := 2.918917328
cc := 5.547621812
L := 3.857225847
LL := 21.10240063
R[1] := .8018219086
S[1] := 0.5213484487e-1
Q[1] := 14.41300577
A[1] := .3666457947
B[1] := .1191082759
C[1] := 3.847329446
P[1] := .8226338823
c := 2.442365249
cc := 7.394009487
L := 4.713824874
LL := 24.79260797
R[1] := .3468711931
S[1] := 0.4792653690e-1
Q[1] := 2.379817029
A[2] := .2337020019
B[2] := 0.7824619488e-1
C[2] := 2.252708122
P[2] := .7880876611
c := 1.950620121
cc := 7.490968154
L := 7.989340649
LL := 22.40840798
R[1] := .2570696142
S[1] := .1248268277
Q[1] := 3.543022180
A[3] := .3254617069
B[3] := .1177911768
C[3] := 4.708933240
P[3] := .8124474245
c := 1.973241013
cc := 7.005418646
L := 6.495611086
LL := 22.94839275
R[1] := .3034319432
S[1] := 0.9318350072e-1
Q[1] := 2.477406387
A[4] := .3446953632
B[4] := .1065224704
C[4] := 4.241185270
P[4] := .8370643415
c := 1.839457984
cc := 7.186959772
L := 6.911480924
LL := 24.15316459
R[1] := .2619901249
S[1] := 0.8971740871e-1
Q[1] := 2.217385534
A[5] := .2889717346
B[5] := 0.8838227764e-1
C[5] := 2.965514897
P[5] := .8196572233
c := 2.075842156
cc := 6.451509594
L := 7.355551514
LL := 22.57154486
R[1] := .3857437868
S[1] := .1118795995
Q[1] := 3.756557664
A[6] := .3672067772
B[6] := .1169243938
C[6] := 4.269406267
P[6] := .8320277948
c := 2.052084434
cc := 5.954773664
L := 7.287571569
LL := 19.13650694
R[1] := .4519986760
S[1] := .1574582015
Q[1] := 5.517824640
A[7] := .3834726657
B[7] := .1300598692
C[7] := 4.443377611
P[7] := .8222904412
1.288903514
6.337860209
6.623173031
20.57453160
.2114575385
.1210220497
2.313450170
Error, (in fsolve) Q is in the equation, and is not solved for
a := [seq(A[i], i = 1 .. 1000)]:
for i to 1000 do aa_[i] := `if`(0 < P[i] and P[i] < 1, a[i], 0); bb_[i] := `if`(0 < P[i] and P[i] < 1, b[i], 0); cc_[i] := `if`(0 < P[i] and P[i] < 1, c[i], 0); gg_[i] := `if`(0 < P[i] and P[i] < 1, p[i], 0) end do:
Tau := [seq(aa_[i], i = 1 .. 1000)]:
rr := [seq(`if`(Tau[i] = 0, NULL, i), i = 1 .. 1000)]:
r := Tau[rr]:
1000
1000
1000
1000
lambda[1] := Mean([seq(r[i], i = 1 .. nops(r))]); lambda[2] := Mean([seq(s[i], i = 1 .. nops(s))]); alpha := Mean([seq(q[i], i = 1 .. nops(q))]); Pro := Mean([seq(w[i], i = 1 .. nops(w))]); Bi_ := .647737-Pro; ME_ := Bi_^2
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, a[i], 0) to floating-point
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, b[i], 0) to floating-point
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, c[i], 0) to floating-point
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, p[i], 0) to floating-point
.647737-Pro
(.647737-Pro)^2
I am calling a function (GTS2) multiple times with varying inputs, using the curry function, and i want to record how long/how much RAM the function takes with each input, and put those in seperate matrices that i can plot later
Sols3 := proc (H::algebraic, F::(list(algebraic)), i::posint, j::posint) options operator, arrow; GTS2(H, F, i, j) end proc;
n, m := 5, 4;
M=Matrix(n, m, curry(Sols3, H, F))
You can find all the functions required in this worksheet. The curried call to this function is in section 4.
MHD_cchf_2.mw
w := .572433:
for j to nops(N, m) do sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+w*x(f(eta)*(diff(diff(f(eta), eta), eta))-(m[j]*m[j])*(diff(f(eta), eta))-(diff(f(eta), eta))^2) = 0, y*(diff(diff(theta(eta), eta), eta))/(pr*z)-b*f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))-b*f(eta)^2*(diff(diff(theta(eta), eta), eta))+f(eta)*(diff(theta(eta), eta)) = 0, f(0) = N[j], (D(f))(0) = 1, (D(f))(20) = 0, theta(0) = 1, theta(20) = 0], numeric, method = bvp); plots[odeplot](sol1, [eta, ((D@@2)(f))(eta)], color = red); plots[odeplot](sol1, color = red); plots[odeplot](sol1, [eta, theta(eta)], color = K[j], linestyle = L[j]); fplt[j] := plots[odeplot](sol1, [eta, f(eta)], color = K[j], axes = boxed, linestyle = L[j]); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = box, linestyle = L[j]) end do; plots:-display([seq(fplt[j], j = 1 .. nops(N, m))]); plots:-display([seq(tplt[j], j = 1 .. nops(N, m))])
Error, invalid input: nops expects 1 argument, but received 2
Download MHD_cchf_2.mw
Respected sir, I try to plot graphs using two parameters once. But it showing the error as
can anybody do help in this regard?
I have a problem writing a program for the numerical solution of nonlinear volterra integral equation using the method of reproducing kernel space. I have my algorithm as well as the program I tried to write, though they are full of error messages. Please could anyone give me a clue on how to go about my challenges. The algorithm is as follows:
Step 1. Fix 𝑎 ≤ 𝑥 and 𝑡 ≤ 𝑏.
If 𝑡 ≤ 𝑥, set 𝑅𝑥(𝑡) = 1 − 𝑎 + 𝑡.
Else set 𝑅𝑥(𝑡) = 1 − 𝑎 + 𝑥.
Step 2. For 𝑖 = 1, 2, . . . , 𝑚 set 𝑥i = (𝑖 − 1)/(𝑚 − 1).
Set 𝜓i(𝑥) = 𝐿t𝑅𝑥(𝑡)|𝑡=𝑥i .
Step 3. Set 𝑢0(𝑥1) = 𝑢(𝑥1).
Step 4. For 𝑖 = 1, 2, . . . , 𝑚 set 𝛾ij = [𝜓-1]ij.
Step 5. 𝑛 = 1.
Step 6. Set Sn = Σ𝑛
𝑘=1 𝛾nk𝑢k-1(𝑥k).
Step 7. Set 𝑢n(𝑥) = Σ𝑛
𝑖=1 Si𝜓i(𝑥).
Step 8. If 𝑛 < 𝑚then set 𝑛 = 𝑛 + 1 and go to step 6.
Else stop.
how can i plot outside of an sphere? for example x^2+y^2+z^2>1 ? tnx for help
So I have this system of equations with which I am not sure if the result is the same or not using "series" and "limit" or what is going on here.
I hope it is clear what I mean.
restart; with(MathematicalFunctions); Assume(k__2H2O > 0, `k__HA+OH` > 0, `k__A+H2O` > 0, `k__H3O+OH` > 0, `k__HA+H2O` > 0, `k__H3O+A` > 0, HA__0 > 0, H2O > 0); sys := k__2H2O*H2O^2+`k__A+H2O`*H2O*(HA__0-HA)-(H3O*`k__H3O+OH`+HA*`k__HA+OH`)*OH = 0, k__2H2O*H2O^2+`k__HA+H2O`*H2O*HA-(`k__H3O+A`*(HA__0-HA)+`k__H3O+OH`*OH)*H3O = 0, (H2O*`k__HA+H2O`+OH*`k__HA+OH`)*HA-(H2O*`k__A+H2O`+H3O*`k__H3O+A`)*(HA__0-HA) = 0; sys := `~`[simplify]([eval(eval(sys, HA = HA__0+OH-H3O), HA__0 = x__HA0*H2O)]); sol := solve(sys, [OH, H3O]); sol := sol[1]; OH__sol := simplify(rhs(sol[1])); H3O__sol := simplify(rhs(sol[2])); simplify(OH__sol*H3O__sol); OHH3O := simplify(limit(%, `k__HA+OH` = 0)); series(OHH3O, x__HA0 = 0, 2); collect(convert(%, polynom), x__HA0, simplify, factor); r1 := limit(%, x__HA0 = 0); r2 := radnormal(limit(OHH3O, x__HA0 = 0)); simplify(r1-r2)
[`&Intersect`, `&Minus`, `&Union`, Assume, Coulditbe, Evalf, Get, Is, SearchFunction, Sequences, Series]
{H2O::(RealRange(Open(0), infinity))}, {HA__0::(RealRange(Open(0), infinity))}, {k__2H2O::(RealRange(Open(0), infinity))}, {`k__A+H2O`::(RealRange(Open(0), infinity))}, {`k__H3O+A`::(RealRange(Open(0), infinity))}, {`k__H3O+OH`::(RealRange(Open(0), infinity))}, {`k__HA+H2O`::(RealRange(Open(0), infinity))}, {`k__HA+OH`::(RealRange(Open(0), infinity))}
[-OH^2*`k__HA+OH`+((-x__HA0*`k__HA+OH`-`k__A+H2O`)*H2O+H3O*(`k__HA+OH`-`k__H3O+OH`))*OH+k__2H2O*H2O^2+`k__A+H2O`*H2O*H3O = 0, (x__HA0*`k__HA+H2O`+k__2H2O)*H2O^2+`k__HA+H2O`*(OH-H3O)*H2O+(-`k__H3O+A`*H3O+OH*(`k__H3O+A`-`k__H3O+OH`))*H3O = 0, H2O^2*x__HA0*`k__HA+H2O`+((x__HA0*`k__HA+OH`+`k__A+H2O`+`k__HA+H2O`)*OH-H3O*(`k__A+H2O`+`k__HA+H2O`))*H2O+(OH-H3O)*(H3O*`k__H3O+A`+OH*`k__HA+OH`) = 0]
-RootOf(-x__HA0*`k__A+H2O`^2*`k__HA+H2O`+k__2H2O^2*`k__H3O+A`-k__2H2O*`k__A+H2O`^2-k__2H2O*`k__A+H2O`*`k__HA+H2O`+(2*x__HA0*`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`-k__2H2O*`k__A+H2O`*`k__H3O+A`+k__2H2O*`k__A+H2O`*`k__H3O+OH`+k__2H2O*`k__H3O+OH`*`k__HA+H2O`)*_Z+(-x__HA0*`k__H3O+OH`^2*`k__HA+H2O`-k__2H2O*`k__H3O+A`*`k__H3O+OH`+`k__A+H2O`^2*`k__H3O+OH`+`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`)*_Z^2+(`k__A+H2O`*`k__H3O+A`*`k__H3O+OH`-`k__A+H2O`*`k__H3O+OH`^2-`k__H3O+OH`^2*`k__HA+H2O`)*_Z^3)*H2O^2*(-`k__A+H2O`*RootOf(-x__HA0*`k__A+H2O`^2*`k__HA+H2O`+k__2H2O^2*`k__H3O+A`-k__2H2O*`k__A+H2O`^2-k__2H2O*`k__A+H2O`*`k__HA+H2O`+(2*x__HA0*`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`-k__2H2O*`k__A+H2O`*`k__H3O+A`+k__2H2O*`k__A+H2O`*`k__H3O+OH`+k__2H2O*`k__H3O+OH`*`k__HA+H2O`)*_Z+(-x__HA0*`k__H3O+OH`^2*`k__HA+H2O`-k__2H2O*`k__H3O+A`*`k__H3O+OH`+`k__A+H2O`^2*`k__H3O+OH`+`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`)*_Z^2+(`k__A+H2O`*`k__H3O+A`*`k__H3O+OH`-`k__A+H2O`*`k__H3O+OH`^2-`k__H3O+OH`^2*`k__HA+H2O`)*_Z^3)+k__2H2O)/(-`k__H3O+OH`*RootOf(-x__HA0*`k__A+H2O`^2*`k__HA+H2O`+k__2H2O^2*`k__H3O+A`-k__2H2O*`k__A+H2O`^2-k__2H2O*`k__A+H2O`*`k__HA+H2O`+(2*x__HA0*`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`-k__2H2O*`k__A+H2O`*`k__H3O+A`+k__2H2O*`k__A+H2O`*`k__H3O+OH`+k__2H2O*`k__H3O+OH`*`k__HA+H2O`)*_Z+(-x__HA0*`k__H3O+OH`^2*`k__HA+H2O`-k__2H2O*`k__H3O+A`*`k__H3O+OH`+`k__A+H2O`^2*`k__H3O+OH`+`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`)*_Z^2+(`k__A+H2O`*`k__H3O+A`*`k__H3O+OH`-`k__A+H2O`*`k__H3O+OH`^2-`k__H3O+OH`^2*`k__HA+H2O`)*_Z^3)+`k__A+H2O`)
-(k__2H2O*`k__H3O+A`^2-2*`k__A+H2O`^2*`k__H3O+A`+`k__A+H2O`^2*`k__H3O+OH`-2*`k__A+H2O`*`k__H3O+A`*`k__HA+H2O`+2*`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`+`k__H3O+OH`*`k__HA+H2O`^2)*`k__A+H2O`*`k__HA+H2O`*H2O^2*x__HA0/((`k__A+H2O`*`k__H3O+A`-`k__A+H2O`*`k__H3O+OH`-`k__H3O+OH`*`k__HA+H2O`)*(k__2H2O*`k__H3O+A`^2-`k__A+H2O`^2*`k__H3O+OH`-2*`k__A+H2O`*`k__H3O+OH`*`k__HA+H2O`-`k__H3O+OH`*`k__HA+H2O`^2))-(k__2H2O*`k__H3O+A`-`k__A+H2O`^2-`k__A+H2O`*`k__HA+H2O`)*H2O^2*(`k__A+H2O`+`k__HA+H2O`)/(`k__H3O+A`*(`k__A+H2O`*`k__H3O+A`-`k__A+H2O`*`k__H3O+OH`-`k__H3O+OH`*`k__HA+H2O`))
k__2H2O*H2O^2/`k__H3O+OH`
-`k__A+H2O`*(-(`k__A+H2O`+`k__HA+H2O`)^2*`k__H3O+OH`+k__2H2O*`k__H3O+A`^2)*H2O^2/(`k__H3O+OH`*`k__H3O+A`*((-`k__A+H2O`-`k__HA+H2O`)*`k__H3O+OH`+`k__A+H2O`*`k__H3O+A`))
Download Mapleprimes_-_Ionproduct.mw
N:=4;alpha:=5*3.14/180;r:=10;Ha:=5;H:=1;
dsolve(diff(f(x),x,x,x));
Rf:=diff(f[m-1](x),x,x,x)+2*alpha*r*sum*(f[m-1-n](x)*diff(f[n](x),x),n=0..m-1)
+(4-Ha)*(alpha)^2*diff(f[m-1](x),x);
dsolve(diff(f[m](x),x,x,x)-CHI[m]*(diff(f[m-1](x),x,x,x))=h*H*Rf,f[m](x));
f[0](x):=1-x^2;
for m from 1 by 1 to N do
CHI[m]:='if'(m>1,1,0);
f[m](x):=int(int(int(CHI[m]*(diff(f[m-1](x),x,x,x))+h*H(diff(f[m-1](x),x,x,x))
+2*h*H*alpha*r*(sum(f[m-1-n](x)*(diff(f[n](x),x)),n=0..m-1))+4*h*H*alpha^2*
(diff(f[m-1](x),x))-h*H*alpha^2*(diff(f[m-1](x),x))*Ha,x),x)+_C1*x,x)+_C2*x+_C3;
s1:=evalf(subs(x=0,f[m](x)))=0;
s2:=evalf(subs(x=0,diff(f[m](x),x)))=0;
s1:=evalf(subs(x=1,f[m](x)))=0;
s:={s1,s2,s3}:
f[m](x):=simplify(subs(solve(s,{_C1,_C2,_C3}),f[m](x)));
f(x):=sum(f[1](x),1=0..N);
hh:=evalf(subs(x=1,diff(f(x),x))):
plot(hh,h=-1.5..-0.2);
A(x):=subs(h=-0.9,f(x));
plot(A(x),x=0..1);
A parameterization of the function i am studying this morning produced what seems to be not single valued on the domain i choose,
plot(floor((x+1)^2/x^2)-(x+1)^2, x = -10 .. 10, coords = logarithmic);
plot(floor((x+1)^2/x^2)-(x+1)^2, x = -10 .. 10, coords = logcosh);
but the cartesian is fine:
Dear Users!
I am facing problem to compare the coefficient of x^i*y^j for i, j =1..,Equations. Please my effort and fix the problem.
H1 := 3*y^4*a[1]^5*b[1]+6*y^4*a[1]^3*b[1]^3+3*y^4*a[1]*b[1]^5+6*x*y^3*a[1]^5+6*x*y^3*a[1]^4*b[1]+12*x*y^3*a[1]^3*b[1]^2+12*x*y^3*a[1]^2*b[1]^3+6*x*y^3*a[1]*b[1]^4+6*x*y^3*b[1]^5+6*y^3*a[1]^5*b[2]+6*y^3*a[1]^4*a[2]*b[1]+12*y^3*a[1]^3*b[1]^2*b[2]+12*y^3*a[1]^2*a[2]*b[1]^3+6*y^3*a[1]*b[1]^4*b[2]+6*y^3*a[2]*b[1]^5+18*x^2*y^2*a[1]^4+36*x^2*y^2*a[1]^2*b[1]^2+18*x^2*y^2*b[1]^4+18*x*y^2*a[1]^4*a[2]+18*x*y^2*a[1]^4*b[2]+36*x*y^2*a[1]^2*a[2]*b[1]^2+36*x*y^2*a[1]^2*b[1]^2*b[2]+18*x*y^2*a[2]*b[1]^4+18*x*y^2*b[1]^4*b[2]+18*y^2*a[1]^4*a[2]*b[2]+36*y^2*a[1]^2*a[2]*b[1]^2*b[2]+18*y^2*a[2]*b[1]^4*b[2]-5*delta*y^2*a[1]^4-8*delta*y^2*a[1]^3*b[1]-10*delta*y^2*a[1]^2*b[1]^2-8*delta*y^2*a[1]*b[1]^3-5*delta*y^2*b[1]^4+12*x^3*y*a[1]^3+12*x^3*y*a[1]^2*b[1]+12*x^3*y*a[1]*b[1]^2+12*x^3*y*b[1]^3+36*x^2*y*a[1]^3*a[2]+36*x^2*y*a[1]^2*b[1]*b[2]+36*x^2*y*a[1]*a[2]*b[1]^2+36*x^2*y*b[1]^3*b[2]+18*x*y*a[1]^3*a[2]^2+36*x*y*a[1]^3*a[2]*b[2]-18*x*y*a[1]^3*b[2]^2-18*x*y*a[1]^2*a[2]^2*b[1]+36*x*y*a[1]^2*a[2]*b[1]*b[2]+18*x*y*a[1]^2*b[1]*b[2]^2+18*x*y*a[1]*a[2]^2*b[1]^2+36*x*y*a[1]*a[2]*b[1]^2*b[2]-18*x*y*a[1]*b[1]^2*b[2]^2-18*x*y*a[2]^2*b[1]^3+36*x*y*a[2]*b[1]^3*b[2]+18*x*y*b[1]^3*b[2]^2+18*y*a[1]^3*a[2]^2*b[2]-6*y*a[1]^3*b[2]^3-6*y*a[1]^2*a[2]^3*b[1]+18*y*a[1]^2*a[2]*b[1]*b[2]^2+18*y*a[1]*a[2]^2*b[1]^2*b[2]-6*y*a[1]*b[1]^2*b[2]^3-6*y*a[2]^3*b[1]^3+18*y*a[2]*b[1]^3*b[2]^2-16*delta*x*y*a[1]^3-20*delta*x*y*a[1]^2*b[1]-20*delta*x*y*a[1]*b[1]^2-16*delta*x*y*b[1]^3-10*delta*y*a[1]^3*a[2]-6*delta*y*a[1]^3*b[2]-10*delta*y*a[1]^2*a[2]*b[1]-10*delta*y*a[1]^2*b[1]*b[2]-10*delta*y*a[1]*a[2]*b[1]^2-10*delta*y*a[1]*b[1]^2*b[2]-6*delta*y*a[2]*b[1]^3-10*delta*y*b[1]^3*b[2]+12*x^4*a[1]*b[1]+12*x^3*a[1]^2*a[2]-12*x^3*a[1]^2*b[2]+24*x^3*a[1]*a[2]*b[1]+24*x^3*a[1]*b[1]*b[2]-12*x^3*a[2]*b[1]^2+12*x^3*b[1]^2*b[2]+18*x^2*a[1]^2*a[2]^2-18*x^2*a[1]^2*b[2]^2+72*x^2*a[1]*a[2]*b[1]*b[2]-18*x^2*a[2]^2*b[1]^2+18*x^2*b[1]^2*b[2]^2+6*x*a[1]^2*a[2]^3+18*x*a[1]^2*a[2]^2*b[2]-18*x*a[1]^2*a[2]*b[2]^2-6*x*a[1]^2*b[2]^3-12*x*a[1]*a[2]^3*b[1]+36*x*a[1]*a[2]^2*b[1]*b[2]+36*x*a[1]*a[2]*b[1]*b[2]^2-12*x*a[1]*b[1]*b[2]^3-6*x*a[2]^3*b[1]^2-18*x*a[2]^2*b[1]^2*b[2]+18*x*a[2]*b[1]^2*b[2]^2+6*x*b[1]^2*b[2]^3+6*a[1]^2*a[2]^3*b[2]-6*a[1]^2*a[2]*b[2]^3-3*a[1]*a[2]^4*b[1]+18*a[1]*a[2]^2*b[1]*b[2]^2-3*a[1]*b[1]*b[2]^4-6*a[2]^3*b[1]^2*b[2]+6*a[2]*b[1]^2*b[2]^3-10*delta*x^2*a[1]^2-16*delta*x^2*a[1]*b[1]-10*delta*x^2*b[1]^2-16*delta*x*a[1]^2*a[2]-4*delta*x*a[1]^2*b[2]-16*delta*x*a[1]*a[2]*b[1]-16*delta*x*a[1]*b[1]*b[2]-4*delta*x*a[2]*b[1]^2-16*delta*x*b[1]^2*b[2]-5*delta*a[1]^2*a[2]^2-6*delta*a[1]^2*a[2]*b[2]+delta*a[1]^2*b[2]^2-2*delta*a[1]*a[2]^2*b[1]-12*delta*a[1]*a[2]*b[1]*b[2]-2*delta*a[1]*b[1]*b[2]^2+delta*a[2]^2*b[1]^2-6*delta*a[2]*b[1]^2*b[2]-5*delta*b[1]^2*b[2]^2+delta^2*a[1]^2+delta^2*a[1]*b[1]+delta^2*b[1]^2+16*y^2*a[1]^2+48*y^2*a[1]*b[1]+16*y^2*b[1]^2+80*x*y*a[1]+80*x*y*b[1]+32*y*a[1]*a[2]+48*y*a[1]*b[2]+48*y*a[2]*b[1]+32*y*b[1]*b[2]+80*x^2+80*x*a[2]+80*x*b[2]+16*a[2]^2+48*a[2]*b[2]+16*b[2]^2-8*delta;
Equation := 12;
for i from 0 to Equation do;
for j from 0 to Equation do;
C[i, j] := coeff(H1, x^i*y^j) = 0;
I got this error
Error, invalid input: coeff received 1, which is not valid for its 2nd argument, x
First 830 831 832 833 834 835 836 Last Page 832 of 2459
