Hello! I need to write some text (a string) and some data in a file on the hard drive. Something like
"Hello, it is me"
3.1415
These two things written in two different consecutives lines in a file called /home/PNL/test_file.txt
I have tried WriteString, WriteFile but I failed miserably. Thank you very much!
How to specify the number of digits shown in the output of CrossProduct?  I've tried specifying the number of digits with Digits:=5: but CrossProduct seems to ignore that. I thought maybe setting the CrossProduct datatype to float might help, but it didn't.
What do I need to do?
I don't know if this is a false memory, but I think that I saw once a command in Maple that make a list of all the assumptions that have been done i the output space. A command that could be named "ListAssumption()" and you would get that list. In fact, I was wondering if this list could be shown in the palettes "Variables." There could be, below the variables, another table with the first row the name of the letter that you made an assume on, and the second row (the value) would show the assumption.  Like this maybe:
Just to get an idea.  Do you think it would be a great idea?
Hello Everyone,
I am wondring if I can  find the StandardRepresentation of a subalgebra of simple Lie algebra?
For example I have this code:
with(DifferentialGeometry);
with(LieAlgebras);
with(Library);
with(LinearAlgebra);
G := SimpleLieAlgebraData("sl(6)", sl6);
DGsetup(G);
StandardRepresentation(sl6);
M3 := MinimalSubalgebra([e30, e35, e20]);
B3 := LieAlgebraData(M3, p62);
Query("Jacobi");
DGsetup(B3);
StandardRepresentation(p62);
Error, (in DifferentialGeometry:-LieAlgebras:-StandardRepresentation) expected a Lie algebra constructed by the procedure SimpleLieAlgebraData
For the first StandardRepresentation(sl6); it works becouse of the definition. Now what I want the same idea for the subalgebra. How can I do that?
Any idea why Maple returns empty string when asked for the latex of the Laplace of x(t)?  Am I doing anything wrong here? I do not see it
`The "Physics Updates" version in the MapleCloud is 1828 and is the same as the version installed in this computer, created 2024, November 18, 7:25 hours Pacific Time.`
libname;
e:=inttrans:-laplace(x(t),t,s)
laplace(x(t), t, s)
latex(e,'output'='string')
Download latex_of_laplace_nov_21_2024.mw
I was expecting something like this using another software
Did Maple always behave this way for Laplace? I do not have earlier version now to check.  Any workaround?
Is this a known error when using PDEtools:-Solve? I get no error using solve on same input, so thought to ask, just in case it should not happen.
For now, I will change my code to use solve for this.
I am basically solving two equations in Laplace domain for Y1(s) and Y2(s). But since there are initial conditions x(0) and y(0) in the equations, and Laplace has L(x(t),t,s)  then PDEtools:-Solve is not happy, as it sees x(t) and x(0) in same input.
But solve has no problem with this. Who is correct? solve or Solve?
libname;
sys:=[s*laplace(x(t),t,s)-x(0) = -3*laplace(x(t),t,s)+4*laplace(y(t),t,s)+1/(s^2+1), s*laplace(y(t),t,s)-y(0) = -2*laplace(x(t),t,s)+3*laplace(y(t),t,s)+1/s^2];
Ys:=[laplace(x(t),t,s), laplace(y(t),t,s)];
[s*laplace(x(t), t, s)-x(0) = -3*laplace(x(t), t, s)+4*laplace(y(t), t, s)+1/(s^2+1), s*laplace(y(t), t, s)-y(0) = -2*laplace(x(t), t, s)+3*laplace(y(t), t, s)+1/s^2]
[laplace(x(t), t, s), laplace(y(t), t, s)]
solve(sys,Ys);
[[laplace(x(t), t, s) = (x(0)*s^5+4*y(0)*s^4-3*x(0)*s^4+x(0)*s^3+4*y(0)*s^2-3*x(0)*s^2+s^3+s^2+4)/((s^4-1)*s^2), laplace(y(t), t, s) = (y(0)*s^5+3*y(0)*s^4-2*x(0)*s^4+y(0)*s^3+3*y(0)*s^2-2*x(0)*s^2+s^3+s^2+s+3)/((s^4-1)*s^2)]]
PDEtools:-Solve(sys,Ys)
Error, (in PDEtools:-Solve) found functions with same name but depending on different arguments in the given DE system: x(0), x(t). Specification of the dependent variables is required
Download differenece_between_solve_and_Solve_nov_20_2024.mw
I have an irreducible polynomial f (over the rationals) with degree n. When I ask for the roots (using solve(f=0)), Maple outputs a sequence of roots, and somehow distinguishes between them. How does it do this? I had assumed that, when working with a RootOf, Maple would just figure out it was supposed to work in Q[x]/< f >, the quotient of the polynomials with rational coefficients by the principle ideal generated by f. In this field, it doesn't matter which of the n roots of f is represented by x + < f >, since all the roots satisfy the same algebraic relations (from this field).
Given this, I'm really interested to know how Maple can somehow distinguish between the roots, enough to be able to use them to recover distinct solutions to a polynomial system (by substituting in the different roots of f). Does it somehow "choose" an embedding of Q[x]/< f > into the complex numbers?
Thanks in advance!
Any reason why the display of a fairly large plot in Maple 2024 (only show a print screen here)
be worst then the display of the same plot in Maple 2020
In 2024, it seams to be rasterized, while in 2020 it is still in vector form. Also the plot does not resize as well in 2024 compare to 2020. Any hint would help!
Maybe large plot are displayed in raster image, there is probably a setting somewhere in the documentation. When I export both are in vector format...
I am experimenting using the this format of  Vector( [Vector] ) to make projective vectors a different data type to Vectors. I don't want to use 1 x 3 or 3 x 1 matrices. The format holds some promise.
I would like to be able to copy the Maple format of Vector or Vector[column]    and Vector[row] for my varaition.
ProjVectoC and ProjVectorR    so ProjVector or ProjVector[column]   and ProjVector[row]
A secondary question  is on type checking (see previous question How to setup special type check in a procedure? - MaplePrimes  ). Would it be possible to have the type check return ProjVector[column] or ProjVector[row]?
The attached worksheet contains a procedure for factor reducing the vectors to to a minimal format of <x,y,z>. Also   Cross product and Dot product procedures to suit.
I am open to any efficiency improvements.
interface(rtablesize=50)
[10, 10]
FactReduce:=overload([
     proc(v::{list,Vector})
          option overload;
          description " removes linear factor from",
                      " a list, vector, matrix or expression";
          uses LinearAlgebra;
          local i, num,tgdc,dnm, V1;
          num:=`ifelse`(type(v,Vector),numelems(v),nops(v));
          dnm:=frontend(lcm, [seq(denom(v[i]),i=1..num)]);
          V1:=radnormal(v*~dnm);
          tgdc:=V1[1];
          for i from 2 to num do
               tgdc:=frontend(gcd, [tgdc, V1[i]]);
          return  simplify(V1/~tgdc);
     end proc,
     proc(M::{Matrix})
          option overload;
          uses LinearAlgebra;
          local i, num,r,c, tgdc,dnm, V1, Ml;
          r,c:=Dimension(M);
          num:=r*c;
          V1:=convert(M,list);
          dnm:=frontend(lcm, [seq(denom(V1[i]),i=1..num)]);
          Ml:=radnormal(dnm*~M);
          V1:=convert(Ml,list);#print((dnm,V1));
          tgdc:=V1[1];#print("xx")
          return  simplify(Ml/~tgdc);
     end proc,
     proc(l::{`+`,`*`,`=`, `symbol`,procedure},  {vars::list:=[:-x,:-y]})
          option overload;
          uses LinearAlgebra;
          local i, num,f1,f1a,lv,lr, tgdc,dnm, V1,Vs;
          f1 := `if`(l::procedure, l(vars[]), l);
               f1a:=`if`(f1::`=`,lhs(f1)-rhs(f1),f1)  ; # Remequal(f1);
          lr:=primpart(f1a,vars);
          return lr
end proc
ProjVectorC := proc(a, b, c)
local cfs, vectr;
description " A Projective Column (Line) Vector in Reduced format";
cfs := FactReduce([a, b, c]);
vectr := <[<cfs>]>;
ProjVectorR := proc(a, b, c)
local cfs, vectr;
description " A Projective Row (Point) Vector";
cfs := sign(c)*FactReduce([a, b, c]);
vectr := <[<cfs>^%T]>^%T;
`&otimes;` := proc(A, B)
local cp;
description "Cross Product of Projective Vectors in Reduced format";
cp :=sign(c)* FactReduce(LinearAlgebra:-`&x`(A[1], B[1]))^%T;
cp := ifelse(cp[3] <> 0, <[sign(cp[3]) *~ cp]>, cp); #makes sure format is [x,y,z] and not [x,y-z]
`&odot;` := proc(A, B)
description "Dot Product of Projective Vectors";
(A[1]) . (B[1]);
V := ProjVectorR(2, 4, -6); W := ProjVectorR(11, 7, 5); S := ProjVectorC(6, -18, 24)
Vector[column](%id = 36893490982610361748)
whattype(V); `~`[whattype](V)
Vector[row](%id = 36893490982610825812)
whattype(S); `~`[whattype](S)
Vector[column](%id = 36893490982626471436)
`~`[whattype](V[1])
Vector[row](%id = 36893490982558545668)
V[1] . V[1]
14
`&odot;`(V, V)
14
R := `&otimes;`(W, V)
Vector[column](%id = 36893490982630825980)
R := `&otimes;`(V, W)
Vector[column](%id = 36893490982630903548)
whattype(R)
Vector[column]
`~`[whattype](R)
Vector[column](%id = 36893490982598861396)
`~`[whattype](R[1])
Vector[column](%id = 36893490982598866092)
`&otimes;`(R, S)
Vector[column](%id = 36893490982624872076)
`&odot;`(R, S)
-85
(14)
`&odot;`(W, R)
`&odot;`(R, `<,>`([`<,>`(x, y, 1)]))
15-31*x+38*y
(16)
Download 2024-11-21_Q_Projective_Vector_Format.mw
The following is not a profound problem, and there is an obvious solution,
but it came up, and I would like to learn more about it.
Even though I recommend the add procedure when summing up individual entities,
my students keep showing me how smart the sum procedure is. Which makes
our worksheets more readable and reproducible for Maple users who are less frequent.
For example:
restart; Xlist := [1, 2, 3]; N := numelems(Xlist)
Using palette icon:
sum(Xlist[n], n = 1 .. N)
6
Cool!  Which means
6
But if we use the same palette icon for a vector
Xvector := convert(Xlist, Vector); sum(Xvector[n], n = 1 .. N)
Error, bad index into Vector
Because I believe this fails
Would someone please teach me how I can see why the sum of a list
works, but does the sum of a vector fail?
Download MaplePrimes_sum_list_vector.mw
On the website "Learning Physics using Maple" of professor Gould, in the example "Vectors: Calculation & Visualization". If you click on the PDF file under that title, you see an example of vectors in 2d.
But when you look at the solution, you see him use the vector v with an arrow to create a fucntional depending of two variables. Since he doesn't load any package, I cannot reproduce this notation to work. I am talking about this:
Is there a trick that I am not aware of in Maple?  The only way I know to have the arrow is to load the Physics package and the Vector package. And then you use the notation r_ to show r with an arrow.
I asked the question in the YouTube channel but did not receive any answer.  Too bad.
Thank you in advance for any help on that matter.
Hello everyone.
Please tell me how to take this integral.
int(1/((a^2 + x)^(3/2)*x), x = 0 .. infinity)
Assuming that a is greater than zero and real. Thanks in advance
Maple defaults to expressing output in terms of Cosines.
Is it possible to instruct maple to rather calculate the output  with Sine as the default ?
 hello
 how to get curve fitting parameters right?  is that any stragey to get a good estimate.
with(Statistics):with(plots):with(Optimization):with(LinearAlgebra):
# given data from strain rate curve
E_0[theta] := 7.883352314*10^9;
alpha[theta]:= 0.982
7883352314.
.982
# experimental creep data under 44 at 100 degree celcius
c_strain := Vector ([<<0>,<0.0284698>,<0.0533808>,<0.0782918>,<0.0996441>,<0.124555>,<0.142349>,<0.156584>,<0.16726>,<0.177936>,<0.181495>,<0.188612>,<0.192171>,<0.19573>,<0.19573>,<0.202847>,<0.206406>,<0.206406>,<0.209964>,<0.209964>,<0.209964>,<0.206406>,<0.209964>>]):
c_time := Vector ([<<0>,<0>,<0.048>,<0.192>,<0.352>,<0.544>,<0.704>,<0.896>,<1.088>,<1.312>,<1.52>,<1.76>,<1.984>,<2.208>,<2.464>,<2.736>,<3.088>,<3.392>,<3.664>,<4.016>,<4.352>,<4.592>,<4.832>>]):
sigma[0] := 44*10^6;
epsilon[0] := sigma[0]/E_0[theta];
44000000
0.5581381911e-2
# change vector to list
c_strain := convert(c_strain,list):
c_time := convert(c_time,list):
# extract zero from list
c_strain := c_strain [2..-1];
c_time := c_time [2..-1];
[0.284698e-1, 0.533808e-1, 0.782918e-1, 0.996441e-1, .124555, .142349, .156584, .16726, .177936, .181495, .188612, .192171, .19573, .19573, .202847, .206406, .206406, .209964, .209964, .209964, .206406, .209964]
[0, 0.48e-1, .192, .352, .544, .704, .896, 1.088, 1.312, 1.52, 1.76, 1.984, 2.208, 2.464, 2.736, 3.088, 3.392, 3.664, 4.016, 4.352, 4.592, 4.832]
# for further calculation need to know how many elements are in the list
M := nops(c_strain);
N := nops(c_time);
22
22
# constitutive equation
creep_strain := proc(t)
local i;
options operator, arrow;
epsilon[0]*(1 + alpha[theta]*add(-(B[i]*(-beta[i]*t + exp(-beta[i] *t) -1))/beta[i],i=1..3))
proc (t) local i; options operator, arrow; epsilon[0]*(1+alpha[theta]*add(-B[i]*(-beta[i]*t+exp(-beta[i]*t)-1)/beta[i], i = 1 .. 3)) end proc
#define objective function
Digits := 9:
obj := add(
           creep_strain(c_time[j])
           c_strain[j]
         )^2
         , j=1..N
# curve fitting
opt := NLPSolve(obj,
  beta[1] >= 0,
    beta[2] >= 0,
    beta[3] >= 0,
    B[1] >= 0, B[1]<= 0.2,
    B[2] >= 0, B[2] <= 0.3,
    B[3] >= 0, B[3] <= 0.4
[.467521159408790410, [B[1] = HFloat(0.19999999999999996), B[2] = HFloat(0.30000000000000004), B[3] = HFloat(0.4), beta[1] = HFloat(1.2600715880722035e-9), beta[2] = HFloat(5.152129055134073e-9), beta[3] = HFloat(5.057870561183067e-9)]]
# plot the result
display(
   ScatterPlot(c_time, c_strain, symbol=circle, color=blue),
  plot(eval(creep_strain(t), opt[2]), t=0.00..max(c_time), color=black)
Download at_44_Mpa_at_100C.mw
Why do maple not contract over inert differentials ?
The last command just return the defining equation and refuses to contract.
See example below
with(Physics);
g_[[5, 29, 1]];
eq1 := g_[~mu, ~nu]*Diff(w(r, theta), mu)*Diff(w(r, theta), nu);
SumOverRepeatedIndices(eq1);
However Check return empty coordinates, which is completely contradictory.
Check(eq1, all);
      The repeated indices per term are: ((...),(...),...)
        , the free indices are: (...)
                    [{}], {~mu, ~nu}
First 85 86 87 88 89 90 91 Last Page 87 of 2457
