Could someone help me with the following.  The syntax produces an unfinished graph with a warning.
> with(plots);
> z := polar(1.05, (1/10)*Pi);
> display(polarplot(1, color = grey, axis[radial] = [color = "Blue"]), complexplot(seq(evalc(z))^n,
n = 1 .. 21));
the graphic looks like this
The graphic should look like this
Thanks, any help appreciated.
Les
Pl. help me remove the equation labels or hide the equation labels in my doc enclosed. What should i do to prevent equation labels from forming in my document. Please refer last two rows in the table below from the document.
Thanks for helping.Ramakrishnan V
Conversion from ppm to % vol is 1ppm = 0.0001 %
Conversion from % vol to ppm is % = 10000*ppm
Avagadro's law between mass and volume is
"22.4 nm^(3)=1 kg mol; 22.4 lit = 1 g mol; at  101.325 kPa*(normal pressure) and (273+C ) K;"
ppm = 0.8205e-1*T*mg/(M*nm^3); mg/nm^3 = M*ppm/(0.8205e-1*T)
where T is abs temperature and M is molecular weight;
M/(0.08205T)]*ppm*((A/F)*EA+1) /ρex; Emission is mg/kg fuel
If SFC is x g/kWhr; then Mass flow of exhaust is  (x/1000)*[M/(0.08205T)]*ppm*((A/F)*EA+1) /ρex; Emission is mg/kWhr
If the distance covered per liter is DCL km/liter, then (SFC/1000)*(DCL)/`ρ__f`  is distance covered in km/kWhrNULL
[kg*km/(kWh*liter)*(liter/kg) = km/kWh]
1 g/cc = 1 kg/lit; 1kg/m3 = 1 g/lit; Fuel density`ρ__f`  is 0.77 kg/litNULL
Emission in mg/km = 0.77*Emission is mg/kg fuel/(km/liter fuel)
[(kg/liter*(mg/kg))*km/liter = mg/km]
SFC is in g/kWhr
Measured emission is  E in ppm  ``
Excess Air percentage is EA in per unit point
Molecular Weight of pollutant is M g/mol
Molecular weight of air = .21*32+.79*28 = 28.84 g/mol
SFC
       SFC := 200 g/kWh
`ρ__f`
rho__f
        `ρ__f` := .77   kg/liter
DCL
   DCL := 50    km/liter fuel
A/F
AFR := 14.5``
EA
EA := .1NULL
T__exh
T__exh
   T__exh := 450     K
`ρ__ex`
rho__ex
      `ρ__ex` := .457 kg/m3
c := (AFR*EA+1)/`ρ__ex` = 5.361050328
CO
CO2
HC
NO2
O2
N2
Air
M [g/mol]
M__co := 28
M__co2 := 44
M__hc := 17
M__no2 := 46
M__o2 := 32
M__n2 := 28
M__air := 28.84
Emission [% ] or[ppm]
E__co := 10
E__co2 := 10
E__hc := 110
                ppm
E__no2 := 10
                ppm
E__o2 := 10
E__n2 := 10
E__air := 10
Emission [mg/Nm3]
0.8205e-1*T__exh/M__co
1.318660714
0.8205e-1*T__exh/M__co2
.8391477273
0.8205e-1*T__exh/M__hc
2.171911765
0.8205e-1*T__exh/M__no2
.8026630435
0.8205e-1*T__exh/M__o2
1.153828125
0.8205e-1*T__exh/M__n2
1.318660714
0.8205e-1*T__exh/M__air
1.280253121
Emission
mg/kWh
k__1 := E__co*c/(1.318660714)
= 40.65526690NULL
k__2 := E__co*c/(.8391477273) = 63.88684799NULL
k__3 := E__co*c/(2.171911765)
 = 24.68355489NULL
k__4 := E__co*c/(.8026630435) = 66.79079562NULL
k__5 := E__co*c/(1.153828125)
 = 46.46316216NULL
k__6 := E__co*c/(1.318660714) = 40.65526690
k__7 := E__co*c/(1.280253121) = 41.87492489NULL
Emission
mg/kg fuel
k__1f := k__1*SFC
 = 8131.053380NULL
k__2f := k__2*SFC
 = 12777.36960  NULL
k__3f := k__3*SFC
4936.710978
k__4f := k__4*SFC =
13358.15912
k__5f := k__5*SFC
9292.632432
k__6f := k__6*SFC
 = 8131.053380 =
k__7f := k__7*SFC
 = 8374.984978
Emission
[mg/km]
Why in the above row, col2 and col3 have no equn nos?
What should i do to remove the equn numbers 11, 12 and 13?
Temperature of exhaust is in T K
Density of exhaust is say `ρ__ex` kg/m3
DCL is distance covered per kWh
SFC := 100*g/kWh; ppm := 4.3; EA := .2; M := 28; `ρ__ex` := .457; T = 400
100*g/kWh
(14)
Emission in g/kWhr is
Emission g/g of fuel = Emission in g/kWhr/SFC in g/kWhrper
Emission in mg/km = 0.77*Emission is mg/kg fuel*(km/liter fuel)
Download ppm_to_g_per_km_conversion.mw
hi . i want to solve a equation with newton method but i cant,
f(x):=x^2-3;
df(x):=diff(f(x),x);
x:=1;
for i from 2 to 5 by 1 do
    x:=x-(f(x)/df(x));
    print(x);
    end do
I want to save multiline string to a file. I am not sure Maple likes my string. Also when I look at the textfile after writing the string to it, the string does not look like what is expected. I given small example
First, created a "proc.mpl" in the folder. Here is the content of "proc.mpl"
process_file := proc()
local str;
str:="
   \\begin{align*}
     A =& B \\\\
       =& 3
   \\end{align*}
FileTools[Text][WriteString]("output.txt", str);
FileTools[Text][Close]("output.txt");
Then opened Maple, and from a worksheet, called the above proc() like this
currentdir("C:\\where_the_file_is");
read("proc.mpl");
Warning, incomplete string;  use " to end the string
process_file();
You see these warnings there. So how does one make a multiline string in Maple? Please tell me it is possible. Else this whole process will not work.
When I look at the "output.txt", where the string is written, this is what shows
   \begin{align*}
     A =& B \      =& 3
   \end{align*}
Which is wrong, I expected this
   \begin{align*}
     A =& B \\
        =& 3
   \end{align*}
I use \ to escape each \, since this is Latex code.
QUestions are:
1) Can one have multiline string in Maple? as in
line one
line two
With implied carriage return, just as it appears in the input?  I do this all the time in Mathematica.
2) Is something wrong with how I am saving the string to the file?
On a side note: I noticed I had to close the textfile to see the output in it. It looks like FileTools[Text][WriteString] does not flush the string autmatically to a otuput file after each write() which is a little annoying.
Using Maple 2017.3 on windows.
This is how the above is done in Mathematica
And this is "test.txt" which shows the output as expected
   \begin{align*}
     A =& B \\
       =& 3
   \end{align*}
I'd like to do the same in Maple.
How do I get underlined text -- axis labels and legend -- in plot command? Tried many ways, but could not succeed. I would appreciate any inputs.
Omkar
Hi, There is a problem in solving ODE using dsolve/numeric code.
Ba.mw
Hi, I do not understand how to solve errors in Maple on my project. My project is to solve Vehicle Routing Problem with Time Windows, and then the error is "Error, (in Optimization: -LPSolve) no feasible integer point found; use feasibilitytolerance option to adjust tolerance". I do not understand about feasibilitytolerance. Can anyone help me? Thankyou.
HASIL*MAPLE*UNTUK*KECAMATAN*COBLONGNULL
with(Optimization);
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize, NLPSolve, QPSolve]
with(linalg);
[BlockDiagonal, GramSchmidt, JordanBlock, LUdecomp, QRdecomp, Wronskian, addcol, addrow, adj, adjoint, angle, augment, backsub, band, basis, bezout, blockmatrix, charmat, charpoly, cholesky, col, coldim, colspace, colspan, companion, concat, cond, copyinto, crossprod, curl, definite, delcols, delrows, det, diag, diverge, dotprod, eigenvals, eigenvalues, eigenvectors, eigenvects, entermatrix, equal, exponential, extend, ffgausselim, fibonacci, forwardsub, frobenius, gausselim, gaussjord, geneqns, genmatrix, grad, hadamard, hermite, hessian, hilbert, htranspose, ihermite, indexfunc, innerprod, intbasis, inverse, ismith, issimilar, iszero, jacobian, jordan, kernel, laplacian, leastsqrs, linsolve, matadd, matrix, minor, minpoly, mulcol, mulrow, multiply, norm, normalize, nullspace, orthog, permanent, pivot, potential, randmatrix, randvector, rank, ratform, row, rowdim, rowspace, rowspan, rref, scalarmul, singularvals, smith, stackmatrix, submatrix, subvector, sumbasis, swapcol, swaprow, sylvester, toeplitz, trace, transpose, vandermonde, vecpotent, vectdim, vector, wronskian]
with(ExcelTools);
[Export, Import, WorkbookData]
with(CodeTools);
[CPUTime, DecodeName, EncodeName, Profiling, RealTime, Test, Usage]
c := convert(Import("C:\\Users\\VaniaMR\\Documents\\SEMANGAT SKRIPSI\\skripsi\\Bab-bab\\data Bandung Utara.xlsx", 6, "B2:I9"), matrix)
array( 1 .. 8, 1 .. 8, [( 5, 8 ) = (2.9), ( 4, 1 ) = (2.5), ( 2, 2 ) = (0.), ( 8, 3 ) = (3.1), ( 2, 4 ) = (1.9), ( 7, 5 ) = (3.7), ( 6, 6 ) = (0.), ( 3, 7 ) = (3.9), ( 6, 8 ) = (2.7), ( 5, 1 ) = (.28), ( 7, 3 ) = (3.9), ( 1, 2 ) = (3.2), ( 3, 4 ) = (3.7), ( 8, 5 ) = (2.9), ( 5, 6 ) = (.26), ( 2, 7 ) = (1.8), ( 3, 8 ) = (3.1), ( 6, 1 ) = (.25), ( 8, 2 ) = (1.1), ( 2, 3 ) = (2.8), ( 4, 4 ) = (0.), ( 5, 5 ) = (0.), ( 8, 6 ) = (2.7), ( 1, 7 ) = (3.5), ( 4, 8 ) = (2.3), ( 7, 1 ) = (3.5), ( 7, 2 ) = (1.8), ( 1, 3 ) = (4.1), ( 5, 4 ) = (2.7), ( 6, 5 ) = (.26), ( 7, 6 ) = (3.4), ( 8, 7 ) = (1.6), ( 1, 8 ) = (3.3), ( 8, 1 ) = (3.3), ( 6, 2 ) = (2.9), ( 4, 3 ) = (3.7), ( 6, 4 ) = (2.7), ( 3, 5 ) = (4.0), ( 2, 6 ) = (2.9), ( 7, 7 ) = (0.), ( 2, 8 ) = (1.1), ( 5, 2 ) = (3.1), ( 2, 1 ) = (3.2), ( 3, 3 ) = (0.), ( 7, 4 ) = (1.3), ( 4, 5 ) = (2.7), ( 1, 6 ) = (.25), ( 6, 7 ) = (3.4), ( 7, 8 ) = (1.6), ( 4, 2 ) = (1.9), ( 6, 3 ) = (3.8), ( 8, 4 ) = (2.3), ( 1, 1 ) = (0.), ( 1, 5 ) = (.28), ( 4, 6 ) = (2.7), ( 5, 7 ) = (3.7), ( 8, 8 ) = (0.), ( 3, 1 ) = (4.1), ( 3, 2 ) = (2.8), ( 5, 3 ) = (4.0), ( 1, 4 ) = (2.5), ( 2, 5 ) = (3.1), ( 3, 6 ) = (3.8), ( 4, 7 ) = (1.3)  ] )
t := convert(Import("C:\\Users\\VaniaMR\\Documents\\SEMANGAT SKRIPSI\\skripsi\\Bab-bab\\data Bandung Utara1.xlsx", 7, "B2:I9"), matrix)
array( 1 .. 8, 1 .. 8, [( 5, 8 ) = (9.0), ( 4, 1 ) = (8.0), ( 2, 2 ) = (0.), ( 8, 3 ) = (8.0), ( 2, 4 ) = (6.0), ( 7, 5 ) = (10.0), ( 6, 6 ) = (0.), ( 3, 7 ) = (9.0), ( 6, 8 ) = (7.0), ( 5, 1 ) = (2.0), ( 7, 3 ) = (9.0), ( 1, 2 ) = (9.0), ( 3, 4 ) = (12.0), ( 8, 5 ) = (9.0), ( 5, 6 ) = (2.0), ( 2, 7 ) = (4.0), ( 3, 8 ) = (8.0), ( 6, 1 ) = (2.0), ( 8, 2 ) = (3.0), ( 2, 3 ) = (7.0), ( 4, 4 ) = (0.), ( 5, 5 ) = (0.), ( 8, 6 ) = (7.0), ( 1, 7 ) = (10.0), ( 4, 8 ) = (6.0), ( 7, 1 ) = (10.0), ( 7, 2 ) = (4.0), ( 1, 3 ) = (11.0), ( 5, 4 ) = (9.0), ( 6, 5 ) = (2.0), ( 7, 6 ) = (8.0), ( 8, 7 ) = (3.0), ( 1, 8 ) = (9.0), ( 8, 1 ) = (9.0), ( 6, 2 ) = (8.0), ( 4, 3 ) = (12.0), ( 6, 4 ) = (9.0), ( 3, 5 ) = (12.0), ( 2, 6 ) = (8.0), ( 7, 7 ) = (0.), ( 2, 8 ) = (3.0), ( 5, 2 ) = (10.0), ( 2, 1 ) = (9.0), ( 3, 3 ) = (0.), ( 7, 4 ) = (4.0), ( 4, 5 ) = (9.0), ( 1, 6 ) = (2.0), ( 6, 7 ) = (8.0), ( 7, 8 ) = (3.0), ( 4, 2 ) = (6.0), ( 6, 3 ) = (10.0), ( 8, 4 ) = (6.0), ( 1, 1 ) = (0.), ( 1, 5 ) = (2.0), ( 4, 6 ) = (9.0), ( 5, 7 ) = (10.0), ( 8, 8 ) = (0.), ( 3, 1 ) = (11.0), ( 3, 2 ) = (7.0), ( 5, 3 ) = (12.0), ( 1, 4 ) = (8.0), ( 2, 5 ) = (10.0), ( 3, 6 ) = (10.0), ( 4, 7 ) = (4.0)  ] )
a := `<,>`(0, 0, 0, 0, 0, 0, 0, 0)
a := Vector(8, {(1) = 0, (2) = 0, (3) = 0, (4) = 0, (5) = 0, (6) = 0, (7) = 0, (8) = 0})
b := `<,>`(30, 30, 30, 30, 30, 30, 30, 30)
b := Vector(8, {(1) = 30, (2) = 30, (3) = 30, (4) = 30, (5) = 30, (6) = 30, (7) = 30, (8) = 30})
n := sqrt(numelems(c)):
{1, 2, 3, 4, 5, 6, 7, 8}
z := add(add(c[i, j]*x[i, j], j = N), i = N);
3.2*x[1, 2]+4.1*x[1, 3]+2.5*x[1, 4]+.28*x[1, 5]+.25*x[1, 6]+3.5*x[1, 7]+3.3*x[1, 8]+3.2*x[2, 1]+2.8*x[2, 3]+1.9*x[2, 4]+3.1*x[2, 5]+2.9*x[2, 6]+1.8*x[2, 7]+1.1*x[2, 8]+4.1*x[3, 1]+2.8*x[3, 2]+3.7*x[3, 4]+4.0*x[3, 5]+3.8*x[3, 6]+3.9*x[3, 7]+3.1*x[3, 8]+2.5*x[4, 1]+1.9*x[4, 2]+3.7*x[4, 3]+2.7*x[4, 5]+2.7*x[4, 6]+1.3*x[4, 7]+2.3*x[4, 8]+.28*x[5, 1]+3.1*x[5, 2]+4.0*x[5, 3]+2.7*x[5, 4]+.26*x[5, 6]+3.7*x[5, 7]+2.9*x[5, 8]+.25*x[6, 1]+2.9*x[6, 2]+3.8*x[6, 3]+2.7*x[6, 4]+.26*x[6, 5]+3.4*x[6, 7]+2.7*x[6, 8]+3.5*x[7, 1]+1.8*x[7, 2]+3.9*x[7, 3]+1.3*x[7, 4]+3.7*x[7, 5]+3.4*x[7, 6]+1.6*x[7, 8]+3.3*x[8, 1]+1.1*x[8, 2]+3.1*x[8, 3]+2.3*x[8, 4]+2.9*x[8, 5]+2.7*x[8, 6]+1.6*x[8, 7]
conx := seq(add(x[i, j], i = `minus`(N, {j})) = 1, j = N);
x[2, 1]+x[3, 1]+x[4, 1]+x[5, 1]+x[6, 1]+x[7, 1]+x[8, 1] = 1, x[1, 2]+x[3, 2]+x[4, 2]+x[5, 2]+x[6, 2]+x[7, 2]+x[8, 2] = 1, x[1, 3]+x[2, 3]+x[4, 3]+x[5, 3]+x[6, 3]+x[7, 3]+x[8, 3] = 1, x[1, 4]+x[2, 4]+x[3, 4]+x[5, 4]+x[6, 4]+x[7, 4]+x[8, 4] = 1, x[1, 5]+x[2, 5]+x[3, 5]+x[4, 5]+x[6, 5]+x[7, 5]+x[8, 5] = 1, x[1, 6]+x[2, 6]+x[3, 6]+x[4, 6]+x[5, 6]+x[7, 6]+x[8, 6] = 1, x[1, 7]+x[2, 7]+x[3, 7]+x[4, 7]+x[5, 7]+x[6, 7]+x[8, 7] = 1, x[1, 8]+x[2, 8]+x[3, 8]+x[4, 8]+x[5, 8]+x[6, 8]+x[7, 8] = 1
conV := seq(add(x[i, k], i = N)-add(x[k, j], j = N) = 0, k = N);
x[2, 1]+x[3, 1]+x[4, 1]+x[5, 1]+x[6, 1]+x[7, 1]+x[8, 1]-x[1, 2]-x[1, 3]-x[1, 4]-x[1, 5]-x[1, 6]-x[1, 7]-x[1, 8] = 0, x[1, 2]+x[3, 2]+x[4, 2]+x[5, 2]+x[6, 2]+x[7, 2]+x[8, 2]-x[2, 1]-x[2, 3]-x[2, 4]-x[2, 5]-x[2, 6]-x[2, 7]-x[2, 8] = 0, x[1, 3]+x[2, 3]+x[4, 3]+x[5, 3]+x[6, 3]+x[7, 3]+x[8, 3]-x[3, 1]-x[3, 2]-x[3, 4]-x[3, 5]-x[3, 6]-x[3, 7]-x[3, 8] = 0, x[1, 4]+x[2, 4]+x[3, 4]+x[5, 4]+x[6, 4]+x[7, 4]+x[8, 4]-x[4, 1]-x[4, 2]-x[4, 3]-x[4, 5]-x[4, 6]-x[4, 7]-x[4, 8] = 0, x[1, 5]+x[2, 5]+x[3, 5]+x[4, 5]+x[6, 5]+x[7, 5]+x[8, 5]-x[5, 1]-x[5, 2]-x[5, 3]-x[5, 4]-x[5, 6]-x[5, 7]-x[5, 8] = 0, x[1, 6]+x[2, 6]+x[3, 6]+x[4, 6]+x[5, 6]+x[7, 6]+x[8, 6]-x[6, 1]-x[6, 2]-x[6, 3]-x[6, 4]-x[6, 5]-x[6, 7]-x[6, 8] = 0, x[1, 7]+x[2, 7]+x[3, 7]+x[4, 7]+x[5, 7]+x[6, 7]+x[8, 7]-x[7, 1]-x[7, 2]-x[7, 3]-x[7, 4]-x[7, 5]-x[7, 6]-x[7, 8] = 0, x[1, 8]+x[2, 8]+x[3, 8]+x[4, 8]+x[5, 8]+x[6, 8]+x[7, 8]-x[8, 1]-x[8, 2]-x[8, 3]-x[8, 4]-x[8, 5]-x[8, 6]-x[8, 7] = 0
conz := add(x[i, 1], i = N) = 1;
x[1, 1]+x[2, 1]+x[3, 1]+x[4, 1]+x[5, 1]+x[6, 1]+x[7, 1]+x[8, 1] = 1
conD := add(x[1, j], j = N) = 1;
x[1, 1]+x[1, 2]+x[1, 3]+x[1, 4]+x[1, 5]+x[1, 6]+x[1, 7]+x[1, 8] = 1
(14)
conTW := seq(seq(y[i]-y[j]+max(b[i]+t[i, j]-a[j], 0)*x[i, j] <= b[i]-a[j], i = `minus`(N, {j})), j = N);
y[2]-y[1]+39.0*x[2, 1] <= 30, y[3]-y[1]+41.0*x[3, 1] <= 30, y[4]-y[1]+38.0*x[4, 1] <= 30, y[5]-y[1]+32.0*x[5, 1] <= 30, y[6]-y[1]+32.0*x[6, 1] <= 30, y[7]-y[1]+40.0*x[7, 1] <= 30, y[8]-y[1]+39.0*x[8, 1] <= 30, y[1]-y[2]+39.0*x[1, 2] <= 30, y[3]-y[2]+37.0*x[3, 2] <= 30, y[4]-y[2]+36.0*x[4, 2] <= 30, y[5]-y[2]+40.0*x[5, 2] <= 30, y[6]-y[2]+38.0*x[6, 2] <= 30, y[7]-y[2]+34.0*x[7, 2] <= 30, y[8]-y[2]+33.0*x[8, 2] <= 30, y[1]-y[3]+41.0*x[1, 3] <= 30, y[2]-y[3]+37.0*x[2, 3] <= 30, y[4]-y[3]+42.0*x[4, 3] <= 30, y[5]-y[3]+42.0*x[5, 3] <= 30, y[6]-y[3]+40.0*x[6, 3] <= 30, y[7]-y[3]+39.0*x[7, 3] <= 30, y[8]-y[3]+38.0*x[8, 3] <= 30, y[1]-y[4]+38.0*x[1, 4] <= 30, y[2]-y[4]+36.0*x[2, 4] <= 30, y[3]-y[4]+42.0*x[3, 4] <= 30, y[5]-y[4]+39.0*x[5, 4] <= 30, y[6]-y[4]+39.0*x[6, 4] <= 30, y[7]-y[4]+34.0*x[7, 4] <= 30, y[8]-y[4]+36.0*x[8, 4] <= 30, y[1]-y[5]+32.0*x[1, 5] <= 30, y[2]-y[5]+40.0*x[2, 5] <= 30, y[3]-y[5]+42.0*x[3, 5] <= 30, y[4]-y[5]+39.0*x[4, 5] <= 30, y[6]-y[5]+32.0*x[6, 5] <= 30, y[7]-y[5]+40.0*x[7, 5] <= 30, y[8]-y[5]+39.0*x[8, 5] <= 30, y[1]-y[6]+32.0*x[1, 6] <= 30, y[2]-y[6]+38.0*x[2, 6] <= 30, y[3]-y[6]+40.0*x[3, 6] <= 30, y[4]-y[6]+39.0*x[4, 6] <= 30, y[5]-y[6]+32.0*x[5, 6] <= 30, y[7]-y[6]+38.0*x[7, 6] <= 30, y[8]-y[6]+37.0*x[8, 6] <= 30, y[1]-y[7]+40.0*x[1, 7] <= 30, y[2]-y[7]+34.0*x[2, 7] <= 30, y[3]-y[7]+39.0*x[3, 7] <= 30, y[4]-y[7]+34.0*x[4, 7] <= 30, y[5]-y[7]+40.0*x[5, 7] <= 30, y[6]-y[7]+38.0*x[6, 7] <= 30, y[8]-y[7]+33.0*x[8, 7] <= 30, y[1]-y[8]+39.0*x[1, 8] <= 30, y[2]-y[8]+33.0*x[2, 8] <= 30, y[3]-y[8]+38.0*x[3, 8] <= 30, y[4]-y[8]+36.0*x[4, 8] <= 30, y[5]-y[8]+39.0*x[5, 8] <= 30, y[6]-y[8]+37.0*x[6, 8] <= 30, y[7]-y[8]+33.0*x[7, 8] <= 30
(15)
batasan1 := seq(a[i] <= y[i], i = N);
0 <= y[1], 0 <= y[2], 0 <= y[3], 0 <= y[4], 0 <= y[5], 0 <= y[6], 0 <= y[7], 0 <= y[8]
(16)
batasan2 := seq(y[i] <= b[i], i = N);
y[1] <= 30, y[2] <= 30, y[3] <= 30, y[4] <= 30, y[5] <= 30, y[6] <= 30, y[7] <= 30, y[8] <= 30
(17)
binaryvariables = {seq(seq(x[i, j], i = `minus`(N, {j})), j = N)};
binaryvariables = {x[1, 2], x[1, 3], x[1, 4], x[1, 5], x[1, 6], x[1, 7], x[1, 8], x[2, 1], x[2, 3], x[2, 4], x[2, 5], x[2, 6], x[2, 7], x[2, 8], x[3, 1], x[3, 2], x[3, 4], x[3, 5], x[3, 6], x[3, 7], x[3, 8], x[4, 1], x[4, 2], x[4, 3], x[4, 5], x[4, 6], x[4, 7], x[4, 8], x[5, 1], x[5, 2], x[5, 3], x[5, 4], x[5, 6], x[5, 7], x[5, 8], x[6, 1], x[6, 2], x[6, 3], x[6, 4], x[6, 5], x[6, 7], x[6, 8], x[7, 1], x[7, 2], x[7, 3], x[7, 4], x[7, 5], x[7, 6], x[7, 8], x[8, 1], x[8, 2], x[8, 3], x[8, 4], x[8, 5], x[8, 6], x[8, 7]}
(18)
conu := seq(seq(u[i]-u[j]+n*x[i, j] <= n-1, i = `minus`(N, {1, j})), j = `minus`(N, {1}));
u[3]-u[2]+8*x[3, 2] <= 7, u[4]-u[2]+8*x[4, 2] <= 7, u[5]-u[2]+8*x[5, 2] <= 7, u[6]-u[2]+8*x[6, 2] <= 7, u[7]-u[2]+8*x[7, 2] <= 7, u[8]-u[2]+8*x[8, 2] <= 7, u[2]-u[3]+8*x[2, 3] <= 7, u[4]-u[3]+8*x[4, 3] <= 7, u[5]-u[3]+8*x[5, 3] <= 7, u[6]-u[3]+8*x[6, 3] <= 7, u[7]-u[3]+8*x[7, 3] <= 7, u[8]-u[3]+8*x[8, 3] <= 7, u[2]-u[4]+8*x[2, 4] <= 7, u[3]-u[4]+8*x[3, 4] <= 7, u[5]-u[4]+8*x[5, 4] <= 7, u[6]-u[4]+8*x[6, 4] <= 7, u[7]-u[4]+8*x[7, 4] <= 7, u[8]-u[4]+8*x[8, 4] <= 7, u[2]-u[5]+8*x[2, 5] <= 7, u[3]-u[5]+8*x[3, 5] <= 7, u[4]-u[5]+8*x[4, 5] <= 7, u[6]-u[5]+8*x[6, 5] <= 7, u[7]-u[5]+8*x[7, 5] <= 7, u[8]-u[5]+8*x[8, 5] <= 7, u[2]-u[6]+8*x[2, 6] <= 7, u[3]-u[6]+8*x[3, 6] <= 7, u[4]-u[6]+8*x[4, 6] <= 7, u[5]-u[6]+8*x[5, 6] <= 7, u[7]-u[6]+8*x[7, 6] <= 7, u[8]-u[6]+8*x[8, 6] <= 7, u[2]-u[7]+8*x[2, 7] <= 7, u[3]-u[7]+8*x[3, 7] <= 7, u[4]-u[7]+8*x[4, 7] <= 7, u[5]-u[7]+8*x[5, 7] <= 7, u[6]-u[7]+8*x[6, 7] <= 7, u[8]-u[7]+8*x[8, 7] <= 7, u[2]-u[8]+8*x[2, 8] <= 7, u[3]-u[8]+8*x[3, 8] <= 7, u[4]-u[8]+8*x[4, 8] <= 7, u[5]-u[8]+8*x[5, 8] <= 7, u[6]-u[8]+8*x[6, 8] <= 7, u[7]-u[8]+8*x[7, 8] <= 7
(19)
Sol := Optimization[LPSolve](z, {conD, conTW, conV, conu, conx, conz, batasan1, batasan2}, binaryvariables = {seq(seq(x[i, j], i = `minus`(N, {j})), j = N)})
Error, (in Optimization:-LPSolve) no feasible integer point found; use feasibilitytolerance option to adjust tolerance
X := eval(Matrix(n, symbol = x), {Sol[2][], seq(x[i, i] = 0, i = 1 .. n)})
Error, invalid input: eval expects its 2nd argument, eqns, to be of type {integer, equation, set(equation)}, but received {Sol[2][], seq(x[i, i] = 0, i = 1 .. n)}
f := [1, 5, 6, 3, 2, 8, 7, 4, 1];
(20)
add(c[f[i], f[i+1]], i = 1 .. nops(f)-1);
13.64
(21)
Download dataayosemangat.mw
1. The general case (the first output) is fine, but the second output is wrong. Surprisingly, replacing series(ee, ...) with series(sqrt(1/x)*erf(sqrt(x)), ...) does something different:
ee := sqrt(1/x)*erf(sqrt(x));
series(ee, x = 0, 2);
% assuming x < 0;
             -2/sqrt(Pi)+2*x/(3*sqrt(Pi))+O(x^2)
series(ee, x = 0, 2) assuming x < 0; # wrong
              2/sqrt(Pi)-2*x/(3*sqrt(Pi))+O(x^2)
series(sqrt(1/x)*erf(sqrt(x)), x = 0, 2) assuming x < 0;
Error, (in assuming) when calling '`series/signum`'. Received: 'no series at 0'
2. Should Maple be able to handle nested discontinuities? The constant term here is incorrect, so the remainder is not O(z^2).
series(ln(I*ln(-1+z)), z = 0, 2);
         ln(Pi)-(1/2*I)*csgn(ln(-1+z))*(csgn(I*(-1+z))+1)*Pi-I*csgn(I*(-1+z))*z/Pi+O(z^2)
3. This is wrong (it would mean that I^z is unbounded for large positive z):
series(a^z, z = infinity, 2);
                exp((1/2*I)*z*(1-signum(a))*Pi)*abs(a)^z
I have a series with an integral inside the series.  I have worked the problem 2 different ways using sum vs Sum.  The integration variables are independent of the series variables so swapping the order of operation should not matter, but in the case, (S2), I do get a difference & I do not understand why.  The explanation fo INERT vs ACTIVE I do not think explains this.  The reason why I say this is because S1 the ACTIVE sum concurs with the INERT expressions S3 & S4.  S2 is swapping the order of operation for the ACTIVE sum does not yield the same result as the other 3 cases.  Why is this?  I am at a loss so including examples would be helpful to me.
swapping_orders_of_operation.mw
I can't undersand, how I can create linear actuator model in MapleSim and to add it in 3D-visualized project. (Like this, for example: http://www.hiwin.com/images/lai2_series_linear_actuator_large.jpg).
Can anyone share an example of such task or explain to me?
It is possible without electric motor and transmission.
An example of translational motion with a certain force will suffice.
Thank you in advance for your cooperation!
I'm writing this procedure to calculate a Julian date:
JD := proc (YY, MM, DD)
local A, B, z;
if MM = 1 or MM = 2 then
YY := YY-1; MM := MM+12
A := floor((1/100)*YY);
B := 2-A+floor((1/4)*A);
z := evalf(floor(365.25*YY)+floor(30.6001*(MM+1))+DD+1720994.5) end proc;
If I type:
JD(2018, 1, 11);  I get
Error, (in JD) illegal use of a formal parameter.
I cannot see where the illegal use is or why I get this message. I don't think I use anything out of the ordinary.
Could you help me please?
Hi all!
I'm totally new using Maple (just installed right now) and need to solve this ODE using Runge-Kutta 4th order scheme. I found there's an inbuilt function for it but I just don't know how to use it.
Can anyone please help me out with this? I'm a bit in a rush and don't have too much time for trial and errors approach.
Much appreciate any help.
Sometimes when I'm solving an equation I get the result in the form of a constant multiplied by zero, instead of just the number 0.
Is it possible to remove that option so I won't get a confusing answer? I've attached a picture of an example here
2.mw
416*(1-tanh(rho*y)^2)^2*tanh(rho*y)^3-272*(1-tanh(rho*y)^2)^3*tanh(rho*y)-32*tanh(rho*y)^5*(1-tanh(rho*y)^2)
Download 2.mw
Download 2.mw
 How can I collect these  for  simplest form
First 916 917 918 919 920 921 922 Last Page 918 of 2464
