Long time asker of minimization problems here.
Following on from my question on 2D packing.
I found this "solved" problem for packing 3D items efficiently. See Illustration 6.13
https://www.researchgate.net/file.PostFileLoader.html?id=59938b635b49527571134c33&assetKey=AS%3A527790252490752%401502846410852
Some discrepancies with constraint set-up (first one), number of variables and the optimized solution.
3DbinPack2.mw
When I export a worksheet table as HTML,MATH EXPRESSIONS: GIF the resulting .html file is 100% readable.
screenshot:
But when i send the html file to myself over email, I get gibberish
The (acer) code for the top is... .....Equation(Standings[id]:-mu &+- Standings[id]:-sigma....
and below opponents rating: ....Cell(Equation(thetable[id][':-losses'][r][1] &+- thetable[id][':-losses'][r][2],......
Anyone shed?
Given an expression such as (x^2+1)*y^3*exp(-x-y), how to "factor" it to product of the two functions, one in x only and the other in y only. These products in this example are
                  exp(-x)*(1+x^2)
                 exp(-y)*y^3
For reference, this was also asked at Mathematica site here
addition:
Is it possible to obtain these separated products in a list or a set to make them easier to get hold of after the call? something like
   myFactor(  (x^2+1)*y^3*exp(-x-y) , {x , y} )
will return
    { exp(-x)*(1+x^2) , exp(-y)*y^3 }
This is current test cases
funcs:=[
   arcsin(x)/(sqrt(1-x^2)*y^2),
   x*y,
   x^2+x^2*y,
   2*x+1,
   cos(2*x),
   y,
   (x-1)/y,
   ln(1+y^2),
   1-x+y^2-x*y^2,
   x^2+x^3*y,
   1/(x+y),
   (1+sqrt(x))/(1+sqrt(y)),
   (1-x^2+y^2-x^2*y^2)/x^2,
   2*x*y^2+3*x^2*y^2,
   3*exp(2*x)+2*y,
   (5*sqrt(x)-y)/x,
   2*x*y+3*x^2*exp(x^2),
   sqrt(1+x+y^2),
   1,
   1+x*y,
   -y+4*x^3*y,
   exp(x^2)+2*x*y,
   -(y-exp(x))/(x-2),
   arcsin(x)/((1-x^2)*y^2),
   -(y-exp(x))/(x-2),
   -y+4*x^3*y,
   (x^2*y+y)*y^3*exp(-x-y+1)*3^(-x-y)*sqrt(x^2*y-y),
    sqrt(1-y^2)/x,
    sqrt(1-y^2)/(2*sqrt(x)),
    sqrt(1-y^2)
This functions checks if expression is product separable or not
is_separable:=proc(f,x,y)
  #checks if f(x,y) is separable to X(x)*Y(y) or not
  #but do not do the separation. The separation is done by
  #another function I have
  if diff(simplify(diff( simplify(ln(f)),x)),y) = 0 then
     return(true);
     return(false);
  fi;
it used as
for z in funcs do
   is_separable(z,x,y);
od;
Ran into a problem with algsubs running a Maple 18 document in Maple 2017. algsubs was preforming differently i.e not working as expected. Took a while to find the cause of the problem. Eventually I had to force expansion of the equation in algsubs. This seems to have corrected the problem. Obviously there is some change in algsubs, expand, simplify or the general handling of equations.
The core of the issue has been copy/pasted here. The basic here was to substitute out higher powers of variables with expansions for them. I have had to keep resubstituting them to grind them out so to speak. That is what the outer loop "for k  to 4 do" does.  Is there a better approach to this?
Sorry the equations are long.
Phi[1] := -(1511177196098612514558714647834046383/500000000000000000000000)*c[1]*c[2]*c[3]+(4764394932763837723968661719158673989/500000000000000000000000)*c[1]*c[2]^2*c[3]-(48974299416348338546077047842762161/1953125000000000000000)*c[1]*c[2]*c[3]^2-(5085635885656392214549313960862455031/500000000000000000000000)*c[1]^3*c[2]*c[3]^2+(87673969018932725618864663083405835363/2000000000000000000000000)*c[1]^2*c[2]^2*c[3]^2-(2093185655935647767393163922515607377/250000000000000000000000)*c[1]^2*c[2]*c[3]^3+(12170321608542144831399295626059044317/500000000000000000000000)*c[1]^3*c[2]*c[3]-(343189185024839185618545460904560893/1000000000000000000000000)*c[2]*c[3]^5-(2866321162911682583500957049753781097/1000000000000000000000000)*c[2]^5*c[3]+(184308069187957387559226052285352439/250000000000000000000000)*c[1]*c[3]^5-(715225913992368014882881686578582809/500000000000000000000000)*c[1]*c[2]^5+(4040489597162629736027642540696875151/2000000000000000000000000)*c[1]^2*c[2]^4+(139227525604383655086769903378300659/100000000000000000000000)*c[1]^3*c[2]^3+(163387393857970897642857636291777051/160000000000000000000000)*c[1]^4*c[2]^2-(417445235256986215239393818106991431/500000000000000000000000)*c[2]^2*c[1]^3+(948114963853735461585064528233552579/400000000000000000000000)*c[2]*c[1]^4-(93072006318912891756492204361094923/125000000000000000000000)*c[1]*c[3]+(1995898943848949069803057567159842207/800000000000000000000000)*c[3]^4+(537311644942849878026609544896795133/1000000000000000000000000)*c[1]^4*c[3]^2-909866841150388380904899634772770421/4000000000000000000000000+(660993907242389999349112254792281961/500000000000000000000000)*c[1]^2*c[3]^4+(523410827717113681247945751839813109/1000000000000000000000000)*c[3]^6+(2259465818400338730103084699264245543/1000000000000000000000000)*c[3]^5+(1082946920677453124549545045823977727/2000000000000000000000000)*c[1]^2-(4919274703979704346573752367484033797/4000000000000000000000000)*c[2]^6+(1300019563584671523447574849341857781/500000000000000000000000)*c[1]^3+(36110317560249698883788806556696349/12500000000000000000000)*c[3]^3-(8437809271818921983461801790407635743/4000000000000000000000000)*c[2]^4+(57095607977886977184642361519871041/500000000000000000000000)*c[1]-(1270872036026468120018936809499343043/800000000000000000000000)*c[2]^2-(909217808994626290304559612991644919/2000000000000000000000000)*c[3]^2+(2112318431405814255156866835765327523/1000000000000000000000000)*c[2]^3+(2749994346684815510948473469174752891/2000000000000000000000000)*c[2]+(293199195953336151431483654518628873/1000000000000000000000000)*c[3]+(165213026344855082767051466797374837/250000000000000000000000)*c[1]^3*c[3]^3+(3260624808168703558651179567896933491/4000000000000000000000000)*c[2]^2*c[3]^4-(386052576060060681902734557073572943/100000000000000000000000)*c[2]^3*c[3]^3-(107009235225460916370507777043970299/25000000000000000000000)*c[3]^2*c[1]-(3231394763620963886010715384651882217/500000000000000000000000)*c[2]^2*c[3]+(35145835398694798048912638525215009/100000000000000000000000)*c[1]^2*c[3]+(7803343052265196041485214878980629051/1000000000000000000000000)*c[2]*c[3]^2+(189288825152449249458404847929369703/62500000000000000000000)*c[1]^3*c[3]-(4871994785359719832585509884671207153/2000000000000000000000000)*c[1]^2*c[3]^2+(58558364823327663531980325185901901/2000000000000000000000000)*c[2]^4*c[3]^2-(2317773688531328208056468858975686599/1000000000000000000000000)*c[1]^4*c[3]-(1669915098879452742488440319552731641/500000000000000000000000)*c[1]^3*c[3]^2-(15011058600087062921733483387686919/7812500000000000000000)*c[3]^3*c[1]^2+(1169182729261528164190296051207568641/100000000000000000000000)*c[1]^3*c[2]^2*c[3]-(157740655090120390159284572158164927/31250000000000000000000)*c[1]^2*c[2]^3*c[3]-(183365255906299886034375133997533947/200000000000000000000000)*c[1]^4*c[2]*c[3]-(1165143404662546296002444315349072801/250000000000000000000000)*c[3]^3*c[1]-(3296336480188764855306402409938209533/1000000000000000000000000)*c[1]^2*c[2]^2+(152747899477154250525105597218807401/250000000000000000000000)*c[1]*c[2]^3-(212592658048205871163088757892057257/500000000000000000000000)*c[1]^3*c[2]+(4337931572765691452788828145645599069/1000000000000000000000000)*c[1]^2*c[2]+(3537737673433831891767302195527965039/400000000000000000000000)*c[2]*c[3]^4+(480316592012903870043763990438657851/500000000000000000000000)*c[1]*c[2]+(22843972649088542115412239024590909/250000000000000000000000)*c[1]*c[2]^2-(856389613387869477950205168748983831/500000000000000000000000)*c[2]^4*c[1]+(1722555347740803424532696621717215237/1000000000000000000000000)*c[2]^3*c[1]^2-(144499150589442909602816206361447481/40000000000000000000000)*c[2]*c[3]-(194061918126254787383892983251574593/100000000000000000000000)*c[2]^3*c[3]+(5204448025876988429124502428654393139/200000000000000000000000)*c[2]^2*c[3]^2+(5262883150549147649811767803764524653/500000000000000000000000)*c[2]*c[3]^3-(379196897365189738663400845399061447/31250000000000000000000)*c[1]^2*c[2]*c[3]-(1694207671201139756922624870822235651/500000000000000000000000)*c[1]*c[2]^3*c[3]-(6110253070017904225754935085376853679/500000000000000000000000)*c[1]*c[2]*c[3]^3-(280236589455230355038315826990315481/3906250000000000000000)*c[1]*c[2]^2*c[3]^2-(7477289382587307992674345923473041949/500000000000000000000000)*c[1]^2*c[2]^2*c[3]+(4948966627646044695632183935923351329/200000000000000000000000)*c[1]^2*c[2]*c[3]^2-(4966745319691340957480030034809498199/500000000000000000000000)*c[1]*c[2]*c[3]^4+(2018962222027027892995525828937937413/500000000000000000000000)*c[1]*c[2]^4*c[3]-(720598685300164001334180650813607859/31250000000000000000000)*c[1]*c[2]^3*c[3]^2+(605831993217967477976312576302093979/500000000000000000000000)*c[1]*c[2]^2*c[3]^3+(413981637670159721373192388002157331/50000000000000000000000)*c[2]^2*c[3]^3+(18310612720332782696857869256581629427/1000000000000000000000000)*c[2]^3*c[3]^2-(487406702655062767043484605789181439/200000000000000000000000)*c[2]^4*c[3]-(48158487129731308189942466977703949/100000000000000000000000)*c[1]*c[3]^4+(2456220020408319082977325039346568859/2000000000000000000000000)*c[2]^5+(2048601809889523865959263173495194839/800000000000000000000000)*c[1]^4
-(5085635885656392214549313960862455031/500000000000000000000000)*c[1]^3*c[2]*c[3]^2+(165213026344855082767051466797374837/250000000000000000000000)*c[1]^3*c[3]^3-(6110253070017904225754935085376853679/500000000000000000000000)*c[1]*c[2]*c[3]^3-(1694207671201139756922624870822235651/500000000000000000000000)*c[1]*c[2]^3*c[3]-(280236589455230355038315826990315481/3906250000000000000000)*c[1]*c[2]^2*c[3]^2+(1995898943848949069803057567159842207/800000000000000000000000)*c[3]^4-(7477289382587307992674345923473041949/500000000000000000000000)*c[1]^2*c[2]^2*c[3]+(4948966627646044695632183935923351329/200000000000000000000000)*c[1]^2*c[2]*c[3]^2+(12170321608542144831399295626059044317/500000000000000000000000)*c[1]^3*c[2]*c[3]+(537311644942849878026609544896795133/1000000000000000000000000)*c[1]^4*c[3]^2+(660993907242389999349112254792281961/500000000000000000000000)*c[1]^2*c[3]^4-(15011058600087062921733483387686919/7812500000000000000000)*c[3]^3*c[1]^2-(1669915098879452742488440319552731641/500000000000000000000000)*c[1]^3*c[3]^2-(2317773688531328208056468858975686599/1000000000000000000000000)*c[1]^4*c[3]+(58558364823327663531980325185901901/2000000000000000000000000)*c[2]^4*c[3]^2-(386052576060060681902734557073572943/100000000000000000000000)*c[2]^3*c[3]^3+(3260624808168703558651179567896933491/4000000000000000000000000)*c[2]^2*c[3]^4-(4966745319691340957480030034809498199/500000000000000000000000)*c[1]*c[2]*c[3]^4-(2093185655935647767393163922515607377/250000000000000000000000)*c[1]^2*c[2]*c[3]^3+(87673969018932725618864663083405835363/2000000000000000000000000)*c[1]^2*c[2]^2*c[3]^2+(2456220020408319082977325039346568859/2000000000000000000000000)*c[2]^5+(605831993217967477976312576302093979/500000000000000000000000)*c[1]*c[2]^2*c[3]^3+(2018962222027027892995525828937937413/500000000000000000000000)*c[1]*c[2]^4*c[3]-(720598685300164001334180650813607859/31250000000000000000000)*c[1]*c[2]^3*c[3]^2-(157740655090120390159284572158164927/31250000000000000000000)*c[1]^2*c[2]^3*c[3]+(1169182729261528164190296051207568641/100000000000000000000000)*c[1]^3*c[2]^2*c[3]-(183365255906299886034375133997533947/200000000000000000000000)*c[1]^4*c[2]*c[3]+(413981637670159721373192388002157331/50000000000000000000000)*c[2]^2*c[3]^3+(18310612720332782696857869256581629427/1000000000000000000000000)*c[2]^3*c[3]^2-(487406702655062767043484605789181439/200000000000000000000000)*c[2]^4*c[3]-(48158487129731308189942466977703949/100000000000000000000000)*c[1]*c[3]^4-909866841150388380904899634772770421/4000000000000000000000000-(343189185024839185618545460904560893/1000000000000000000000000)*c[2]*c[3]^5-(2866321162911682583500957049753781097/1000000000000000000000000)*c[2]^5*c[3]+(184308069187957387559226052285352439/250000000000000000000000)*c[1]*c[3]^5-(715225913992368014882881686578582809/500000000000000000000000)*c[1]*c[2]^5+(4040489597162629736027642540696875151/2000000000000000000000000)*c[1]^2*c[2]^4+(139227525604383655086769903378300659/100000000000000000000000)*c[1]^3*c[2]^3+(163387393857970897642857636291777051/160000000000000000000000)*c[1]^4*c[2]^2-(417445235256986215239393818106991431/500000000000000000000000)*c[2]^2*c[1]^3+(948114963853735461585064528233552579/400000000000000000000000)*c[2]*c[1]^4-(93072006318912891756492204361094923/125000000000000000000000)*c[1]*c[3]-(107009235225460916370507777043970299/25000000000000000000000)*c[3]^2*c[1]-(3231394763620963886010715384651882217/500000000000000000000000)*c[2]^2*c[3]+(35145835398694798048912638525215009/100000000000000000000000)*c[1]^2*c[3]-(1511177196098612514558714647834046383/500000000000000000000000)*c[1]*c[2]*c[3]-(379196897365189738663400845399061447/31250000000000000000000)*c[1]^2*c[2]*c[3]+(4764394932763837723968661719158673989/500000000000000000000000)*c[1]*c[2]^2*c[3]-(48974299416348338546077047842762161/1953125000000000000000)*c[1]*c[2]*c[3]^2+(189288825152449249458404847929369703/62500000000000000000000)*c[1]^3*c[3]-(4871994785359719832585509884671207153/2000000000000000000000000)*c[1]^2*c[3]^2+(7803343052265196041485214878980629051/1000000000000000000000000)*c[2]*c[3]^2-(1165143404662546296002444315349072801/250000000000000000000000)*c[3]^3*c[1]+(152747899477154250525105597218807401/250000000000000000000000)*c[1]*c[2]^3-(212592658048205871163088757892057257/500000000000000000000000)*c[1]^3*c[2]-(3296336480188764855306402409938209533/1000000000000000000000000)*c[1]^2*c[2]^2+(3537737673433831891767302195527965039/400000000000000000000000)*c[2]*c[3]^4+(480316592012903870043763990438657851/500000000000000000000000)*c[1]*c[2]+(22843972649088542115412239024590909/250000000000000000000000)*c[1]*c[2]^2+(4337931572765691452788828145645599069/1000000000000000000000000)*c[1]^2*c[2]+(1722555347740803424532696621717215237/1000000000000000000000000)*c[2]^3*c[1]^2-(144499150589442909602816206361447481/40000000000000000000000)*c[2]*c[3]-(194061918126254787383892983251574593/100000000000000000000000)*c[2]^3*c[3]+(5204448025876988429124502428654393139/200000000000000000000000)*c[2]^2*c[3]^2+(5262883150549147649811767803764524653/500000000000000000000000)*c[2]*c[3]^3-(856389613387869477950205168748983831/500000000000000000000000)*c[2]^4*c[1]+(2048601809889523865959263173495194839/800000000000000000000000)*c[1]^4+(2259465818400338730103084699264245543/1000000000000000000000000)*c[3]^5-(4919274703979704346573752367484033797/4000000000000000000000000)*c[2]^6+(523410827717113681247945751839813109/1000000000000000000000000)*c[3]^6+(1300019563584671523447574849341857781/500000000000000000000000)*c[1]^3+(1082946920677453124549545045823977727/2000000000000000000000000)*c[1]^2-(8437809271818921983461801790407635743/4000000000000000000000000)*c[2]^4+(57095607977886977184642361519871041/500000000000000000000000)*c[1]-(909217808994626290304559612991644919/2000000000000000000000000)*c[3]^2+(36110317560249698883788806556696349/12500000000000000000000)*c[3]^3+(2112318431405814255156866835765327523/1000000000000000000000000)*c[2]^3-(1270872036026468120018936809499343043/800000000000000000000000)*c[2]^2+(2749994346684815510948473469174752891/2000000000000000000000000)*c[2]+(293199195953336151431483654518628873/1000000000000000000000000)*c[3]
sbeqmaple18 := -(133620348241512103024389238606621210701270437978007902034694023237073260168149917097493214861/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[1]*c[2]*c[3]-(427397189912936558418377271479338136447309205587597223797211081179178113476400993381098489721/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[1]^2*c[2]*c[3]+(1102137681365209966049661522260196061251652615091911984407508220134170665417853015572579701/4989174483127875760232264899515984835488042808054666500623346836657370659636810523198719556)*c[1]^2*c[2]*c[3]^2-(158471428405108868755437146379180798124657342277475484353205014415702555616469103363735511327/77332204488482074283600105942497764950064663524847330759661875968189245224370563109580153118)*c[1]*c[2]*c[3]^3+(817115548677586178176999469845338231148553546088142304637694244465443787954360440954129301453/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]*c[2]^3*c[3]-(4572218060433129377234623928181288017796186638571327007343438402760350393127688409792538349/6364790492879183068609062217489527979429190413567681544005092672278950224228029885562152520)*c[1]*c[2]^2*c[3]^2+(20346265967617436411596104563128584080430137430711683022609496382995515918197657317379944363/49891744831278757602322648995159848354880428080546665006233468366573706596368105231987195560)*c[1]^2*c[2]^2*c[3]+(208016972400027196793944088819230422204548262665116773980193340234026137945866600279953536/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^3-(432699312215829327337806480758181844319230996641895391402730118766138496046963090027211008/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^2-(494337568007024305736608300378398544426460760309559706537307404474086025765754019715374451/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]+(4077191474615102296268746376347213861136163543969925077134301932667132632969375565215573953/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(6595360005853618890089357169757351418832834915554886185780456365312485988154497840691725091/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(10047378588811324298485607808979467777799926446249731280503707510640847741332799492391073447/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(139791445008097421737720901971158461240524303965285317497137178934498285941370423565697280/3515100204021912467436368451931716588639302887493060489075539816735874782925934686799097869)*c[2]^4-(129714472390141880950845487790142661600884220061717223669011739770107674842204890822351509571/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^4*c[3]-(384886890512193361158377027871999599478478635960161702605834453677288126375999892321840306217/515548029923213828557334039616651766333764423498982205064412506454594968162470420730534354120)*c[3]^3*c[1]^2+(150156726849789255801961314435579159710030385513318078773084997147126129453950151260844619621/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]^3*c[3]^2-(16061633357475870789787943496408748360321959855562411166246657187182056859562892365868010816/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^3*c[3]^2+(7606842045457181514527010779395477233591226210623551478434718060925030725887587851415778432/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]^3+(20121091418877322556642191521187136191513294783890340944118935474813962844244585239489133273/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]*c[3]^4+(10242879445587123958774614170006859672375767796285179388084351529199573440898749176992814848/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^4*c[3]-(1585711878675521080236080038541706574157019553516581892508478130955662639833532974621310604539/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[3]^2*c[1]+(8379374322641295579078241009234157208857924859193966466172933813497458753550514651472114201/28120801632175299739490947615453732709114423099944483912604318533886998263407477494392782952)*c[1]*c[3]+(26677011478640862160716000206762529500762850636471009875403272198688871618125118516494749312/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]+(14883571935214146664599997879317530442506260052379431817791090709878790332204640880005078464/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]*c[3]^2-(221625654031822857827930508023637655229565601994580756927653228915837635840848416860143953663/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^3*c[3]-(874160859728658068609782790646364990624561838246644643337722534474420073620230398315372472451/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[3]+(423931577040542655468403184954248406159350044405651877114680737268229918396289657894741981303/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[3]^3*c[1]+(921227515040452585655802318663397410921614985328593249703099120458905102308518203545762517869/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[3]^2+(309393529298459736174338297848709255921318578394287858406146002867969763719068994052410097/7811333786715361038747485448737147974754006416651245531278977370524166184279854859553550820)*c[1]^3*c[2]-(21821851027037147588196231209213383337919403652194273171325833017655337944165810634234602279/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2+(4002401366417243294222536403760114379341463902959427528792772997688549169806035852834048525/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]*c[2]^3-(1325899622260625593585841022122799695109591583018109504218461687415601029923538108148281664/12888700748080345713933350990416294158344110587474555126610312661364874204061760518263358853)*c[2]*c[3]^4+(45844726189179231237869011102416723433349818381198441824612821734489598572669729427388302528/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^3*c[3]-(20421928646916357012792530439975288443277134608941961539187804752524386026055470821620271104/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(6282994797071592650483982709582719991183137886767342827254077022438563716812485894651421888/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]*c[3]^3+(723415193135677790752661486632005489149397023050808004436006920506926806872417481337254257/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]+(343118830109531861488608761254701087924413659239387205816120340789639325993897679196352863/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]*c[2]^2+(2796251530763911160857799986888871036642434723108232499398836932607680647966047283017539145/4686800272029216623248491269242288784852403849990747318767386422314499710567912915732130492)*c[1]^2*c[2]-(331129731505936461636172245437228852481652551502529371809457836235779746203247938833247424/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]*c[3]+(12003361868662501758213772237030367239167371134440765016518344013472749387226368014375625227/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[1]^3*c[2]*c[3]-(6075811497444619353406726559221366448695784161650858272593562461089568611443346788181632/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]+(162293319335725527008628173163673520153100045415267135968526707404387301107411554879580701607/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(111897000388465910375087117925637277937888666382295280513798524218535321044134420673906339073/45489532052048278990353003495586920558861566779321959270389338804817203073159154770341266540)*c[1]*c[2]*c[3]^2, (10446173777788037077753851113656349382088124139243462670212689080667182842596416112541191045/77332204488482074283600105942497764950064663524847330759661875968189245224370563109580153118)*c[1]*c[2]*c[3]+(125390172720124209342536890116246231052470819547149241954538610766123029006199726584990654541/154664408976964148567200211884995529900129327049694661519323751936378490448741126219160306236)*c[1]^2*c[2]*c[3]+(33287074449452040303682959002064180257077023639320141212169287536982699654325402430180870931/38666102244241037141800052971248882475032331762423665379830937984094622612185281554790076559)*c[1]^2*c[2]*c[3]^2-(78560133589381288399264346922210281001502023694743915356512233674946988939788488957452367887/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[1]*c[2]*c[3]^3+(276800460629481750407538530452129837409441700225954892846326171019617455569490977697691799187/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]*c[2]^3*c[3]+(1149250190067097502807289828766451414221301674758403129748010913013089378580869625708723477/57283114435912647617481559957405751814862713722109133896045834050510552018052268970059372680)*c[1]*c[2]^2*c[3]^2+(424055776930863458736638428273717729815976524669215432124587146985902029842046845909262545341/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[2]^2*c[3]+(128284672833904921442836957953858668844865562062764595358294074389751440656784301718383501/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[2]^3-(133423463149721544179038093402671875787975187069654314726566708868435274796679709377374389/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^2-(3451279466823380652066030641063246064505384810770979538832647133447348879916065053983180837/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]+(3758846244365291539770566219755004336845912204136666233104179049282927522729192154194814813/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(2264867872832125278126372385072177804599319711357725679623459009994869382890145441446131843/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(11415931224281509982644480032664943100333387292684829128875395173372289848439492691446921467/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(43104895674946003659834136503264923679326046763223946047540820071149465235943807727368365/3515100204021912467436368451931716588639302887493060489075539816735874782925934686799097869)*c[2]^4-(1454954689033218135995897396129370501094291445447572464509373819475558577861661382400564383/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^4*c[3]-(8701215660344837411698844897756882976866160396282416552994646522000835736474705834917122609/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[3]^3*c[1]^2+(30025361408715558929233233239972470931525211158911841183356235906506610382817050765446284423/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]^3*c[3]^2-(19810512158397864886753284182142233164007396690206622434436887445491707821755477095751432337/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^3*c[3]^2+(4691161648214331257250314958084487624269836143198889156540223354731777661209670948383043637/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^2*c[3]^3-(6494964683957929460385669206487755355426217657848298651942608320479958967415013393443767989/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]*c[3]^4+(3158406795834371606347557446082124288030648685724599805474035510095327919242961873300734859/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^4*c[3]-(1295033381811072666043711895620153434178629455308468890924371036754384491332456715724591122377/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[3]^2*c[1]+(8131326584910644659895828298592188014765855871428228759295026416733868982185495560346965951/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[3]+(16451790689187637333139775158678482922924208062761594363748208045250372447649359643194944217/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^2*c[3]+(18357484336778918600319470313841891220127738941021590646014454096190652064669814622954910123/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]*c[3]^2-(91494250407951590100007689219678605180434609403814252052450484855401324189936568695280166857/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^3*c[3]-(606552160482612542883554949188580848860763239541069667947631107922634334731663969494176142683/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[3]-(10203283597634033735869120771655387663769522855478691810311011890326499553290776791929669323/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[3]^3*c[1]+(246946525245798197836936651398311226613759544911379151565179084384925665970590999957344618749/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[3]^2+(23289930319130147518936876398219769977744607714156024697278725748071003402587673117815795/50395701849776522830628938378949341772606493010653196975993402390478491511482934577764844)*c[1]^3*c[2]-(38966524274307404391632698162379008154082123976800488624137102561044824704456346739769050259/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2+(7939101025030636198393594299136979308119010188754408794529583485990015487044317406000308499/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^3-(1635372318804888390812007607431218371121434678470151171941266951382089255608406287986626273/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[2]*c[3]^4+(56545152373711227964100823225079261561205003071084385372759782673347859806024596507555330071/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^3*c[3]-(6297131442882861973781938530022563124714984692692804118365567602488134204217421833263275432/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(7749482387518401607357062223631129812562276145311960370718626146218613948287696804750525591/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[2]*c[3]^3-(1648936357783383325174610977514247832129633314370003865970461306853327257795562812993886067/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]+(2607705874596369917407159569968689469486554073267214613835988513798722096012966328292094407/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(11014576595233077530650766455145584700740564834050140130915844085869412159406032038746493697/23434001360146083116242456346211443924262019249953736593836932111572498552839564578660652460)*c[1]^2*c[2]-(408417340005591620191881193172380206964909982950383908773546628376276553928860585949740343/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]*c[3]-(8389933126972180867147550846894044573343918926270594723221760431824624244970367444714113481/17184934330773794285244467987221725544458814116632740168813750215153165605415680691017811804)*c[1]^3*c[2]*c[3]-(3746970649352932490839434423311642945575927671699577201562623316216386561100815185867337/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[2]+(107525693948746592032023093832605054101715775947958081213294560006206995409036056076275242713/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(24407517609288774654935090842634453887700600704842920915286682681207698210898255658220934283/45489532052048278990353003495586920558861566779321959270389338804817203073159154770341266540)*c[1]*c[2]*c[3]^2, -(39595858365936660869650345849788605404512569404846452442565265488272099159924658098773950731/77332204488482074283600105942497764950064663524847330759661875968189245224370563109580153118)*c[1]*c[2]*c[3]+(31300432806539800714407875043857601747525773598588559835260835175279846025357973207186077348/38666102244241037141800052971248882475032331762423665379830937984094622612185281554790076559)*c[1]^2*c[2]*c[3]+(175677835243039175084364412642783545143584527733148913991919701945519137191409252360381723163/154664408976964148567200211884995529900129327049694661519323751936378490448741126219160306236)*c[1]^2*c[2]*c[3]^2+(1306090217276901062453148546257884103181754748667665457449362541879013096926897296119843253/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[1]*c[2]*c[3]^3+(501992600348760881133936896419376457878458188873013665111533008194482902790327646867202574429/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]*c[2]^3*c[3]+(23739955572564579414258230824653047197210912626424913170312468917531100521059008825562419169/57283114435912647617481559957405751814862713722109133896045834050510552018052268970059372680)*c[1]*c[2]^2*c[3]^2-(1130692835342815939160166524842725107939302092843385993437267194585247199147566816401360219513/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[2]^2*c[3]+(123822051574825075645873635927519228141329454922963319371573557378404629695815555109044981/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^3-(257564158998271969532518285387952134179796064744989627284099729577485039980114044019180218/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^2-(894989638551565461715520440704504615834301993547237038381788327332635393909192192798598989/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]+(2734294747701225066924953116853150865349266291979157824599586609802178177386461703834155546/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(201182545746738872318942152825848128421050246771155010551352109793903860924965887466476721/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4-(3346473567385992291769671680146143923517472040503794415142349602563493131845387398987280611/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(83210823202567192306610135238418235722426496746560279454009562491685193246793047593497130/3515100204021912467436368451931716588639302887493060489075539816735874782925934686799097869)*c[2]^4+(5395676916384690304001994539043755617305211301974434127866824930473488921443492832359033999/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^4*c[3]-(376508877841310480277732817583425765826930386883480830474576670742666950136247699246401385/3326116322085250506821509933010656556992028538703111000415564557771580439757873682132479704)*c[3]^3*c[1]^2-(2610978079232998531018746534698680828643835564575535610793898586462985531155788474496848497/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]^3*c[3]^2-(19121366598305976440374689701544621089116095524197760016507027262569964656742469712469251097/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^3*c[3]^2+(4527970853564946202071865300331861932719339967388672261905728212387233328305726522689586397/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]^3-(10820803647069191232557728915465923539919163670479656667550788764964281541356130184500258253/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]*c[3]^4+(6097071466587880783479549084033314306350514782017343589103187299037000098240885145508092358/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^4*c[3]-(709770720595777341138415198097531521587780156486423397749544380717766695746135327639586144889/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[3]^2*c[1]+(7574736574475927117128253762039035410672023414783506801490688626693247769808354093525349047/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[3]+(15879484510611200085400080653284818356226449385741436446009234845094514151406345812900745377/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]+(17718885055549094025108185539548114560681732309271079970213098531434258083225290166400732163/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]*c[3]^2+(2652590009000676587679603373516976149779411945534607521988763688889793590400692692250497331/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^3*c[3]+(2606640266867622414289604255560990719039826569363887866691858141417809448845554252917468239/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[3]-(60327466524765951213690310468629723416311084411472305083929405394513809212207370674686909211/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[3]^3*c[1]+(108691046009147974436259356432443049562943693303327463101739969862787662209232292253287508095/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[3]^2+(457196946326289130835966721862867143227922299571372935253319475774958456064429164585600965/1562266757343072207749497089747429594950801283330249106255795474104833236855970971910710164)*c[1]^3*c[2]+(13836797647137917193667918199546012020660316709165740371810687589094087699674219173851238787/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2+(387387223383836966707798602052140396702853676708641708961210157315529908519370510934722903/2267806583239943527378302227052720379767292185479393863919703107571532118016732055999417980)*c[1]*c[2]^3-(1578482847013831486466951475333875560862070631489735537971018989973287335642156114114350313/25777401496160691427866701980832588316688221174949110253220625322729748408123521036526717706)*c[2]*c[3]^4+(54578123939943877801965363124080584822697004665582892320781837223639850152592499925062515151/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^3*c[3]-(12156147996006234642314849272370859481465685813099534276201428838846268686196590798482949584/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(7479902210203061686799121857906277320882132188800800836370663670808082405846362553348680271/42962335826934485713111169968054313861147035291581850422034375537882914013539201727544529510)*c[2]*c[3]^3+(538420422155229302909266068750820947064880493477200170586998432726814588935974139068768341/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]+(714949414020529711072589257838178135538961580852582717585232936664563641657776116251042589/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(242778680615646908009221902698602808869691076665508732898846048278399189439400719425653249/755935527746647842459434075684240126589097395159797954639901035857177372672244018666472660)*c[1]^2*c[2]-(394209782206028143267628056649040085599855768289599056123478000103937071433185018821887983/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]*c[3]+(4296256743933752463123888801725347599416612515598107175428306910588975186966488297298514307/17184934330773794285244467987221725544458814116632740168813750215153165605415680691017811804)*c[1]^3*c[2]*c[3]-(3616625297039485563961656087848275613640444357631691479525127985386410959271254667486097/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]+(101304969889055620852686951330411201888459176057393003219143383282545145733336620204048963221/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(30259925730000619860678111657599596481341433261076954771797942132005401078960479305338575021/45489532052048278990353003495586920558861566779321959270389338804817203073159154770341266540)*c[1]*c[2]*c[3]^2, (4769742504596300257945124517548285619630775784821511457190334331383658072341026743363641393/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]*c[2]*c[3]+(1799769781500743026423035173453159497772177078868955696241644225657377695110199564753432959/7030200408043824934872736903863433177278605774986120978151079633471749565851869373598195738)*c[1]^2*c[2]*c[3]+(37927566211046531151265032259727944556136661594120404820095021188281903204802265019860128909/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]^2*c[2]*c[3]^2-(1294569619459348125397606255460379944293202186888621167834198548446317174183529969435161411/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]*c[3]^3+(7160132400116237262223973023565018247116519243495784234021779600686868954899691730917956927/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[1]*c[2]^3*c[3]-(700031917398218301930214003280464444225363491809491476055665504573393387291309761835040757/5207555857810240692498323632491431983169337611100830354185984913682777456186569906369033880)*c[1]*c[2]^2*c[3]^2-(73226841747581407704084741311950396028688379645749677607568576284974752263551458625357778781/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2*c[3]+(1655782280117194124282932800421325711186570495826514295737854091217777284203708372201362/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^3-(3444218255460840852950654484435590960924639191655687123178566359900477365796616126029636/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^2-(2090898390039545844251843632100066330134734229074253741909676494330295424167617066484808853/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]+(1897438899451378333317681314291141107884793005801483694052987621912195099873058638886365767/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(1455479806108690076619311906032124160835868467732055307275164650332033762002349048898977567/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(8277466376420132975101540722210797277259943184818770448213077689181478684117456315845191103/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(1112717846461429610966622695477423683390495536679926334675175272291980898986342391716260/113390329161997176368915111352636018988364609273969693195985155378576605900836602799970899)*c[2]^4+(1511261216447144258268868609865752515732930386347116768283006248273125963777836135222824703/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4*c[3]-(2916316059316423022683692198152544256334554422160565308451064860155122156902173438569638015/9373600544058433246496982538484577569704807699981494637534772844628999421135825831464260984)*c[3]^3*c[1]^2-(1604371897974993570095695330698013506600997873763972436875241547099715337616980265263547939/9373600544058433246496982538484577569704807699981494637534772844628999421135825831464260984)*c[1]^3*c[3]^2-(11622551579766410698391819507162800688556060264150183490871303816494044096691723044024727/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^3*c[3]^2+(5504478409184402815478945769914673124965256260177346227568160195299974030900746967094054/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^2*c[3]^3-(2750495424744203492323249246901097951763773144176656952191120537889657299218087853044313591/9373600544058433246496982538484577569704807699981494637534772844628999421135825831464260984)*c[1]*c[3]^4+(7411973118303971943721286752272819125624194553658610419604356305282137252813858635506356/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^4*c[3]-(47853006106200449951167569934680558636001586888321414961977880862455386958982110841796111123/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[3]^2*c[1]+(4906735476484408090252598431676565700257367676792330272232599009337661779624135121950798399/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[3]+(19304072942258345677236982866051590168752976232578997298557553992946020146759551309360414/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^2*c[3]+(10770080393329017522683046437192420669064728001918361530203362984912898435793502785793933/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]*c[3]^2+(8845655981953282907559956838776983705360273933575811187313958189835558338516632008532137357/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^3*c[3]-(60086682169422164576307950093663836556431133204918168064100381257587757255610229280759548317/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[3]-(12097206642896781233550047357745967804650704434830174121208212943751137580468562482414300017/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[3]^3*c[1]+(29577808655999836294728549708568456818869193346247874947697187406818185097828597008084294515/28120801632175299739490947615453732709114423099944483912604318533886998263407477494392782952)*c[1]^2*c[3]^2+(2472225182049198198119990305157981813930582808288901270213662096303378836642082006128911/5173068732924080158110917515719965546194706236192877835284090973857063698198579377187782)*c[1]^3*c[2]+(22712656245957212073902722167585450380155705827224348364104206204692485012739987870516504809/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2+(3148986854405510468281718446024327737408318461471646457467092677950469891473550936664382004/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[1]*c[2]^3-(959450163400984106446836435083691083743453846237834322734921393180515003475313900400583/37796776387332392122971703784212006329454869757989897731995051792858868633612200933323633)*c[2]*c[3]^4+(33174253386004305937694551026069239751889016448857142003345573043002597432561596978365441/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^3*c[3]-(14777757266300567083424157314952422325547754574986738269364710472238202064807249806049888/62994627312220653538286172973686677215758116263316496219991752988098114389353668222206055)*c[2]^2*c[3]^2-(4546513388713323575418404273999071350267830059176565526910345131868236069646071957695361/62994627312220653538286172973686677215758116263316496219991752988098114389353668222206055)*c[2]*c[3]^3-(1243347924175099304768618720451583547421102130284895066984028089856663753704776356737682587/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[1]*c[2]+(3523631039658031964770497282146617430856980193951598158502512945366545722150557894101725873/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(9054300668807359226130270203160578630229234981445803597795479241301358900659788503548332353/23434001360146083116242456346211443924262019249953736593836932111572498552839564578660652460)*c[1]^2*c[2]-(239612765300151442311264737761462002078476985129590387497714207843475100291936694467553/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]*c[3]+(280262028232205881761944378574446081612973585449057228099921380380214095356118786916571129/390566689335768051937374272436857398737700320832562276563948868526208309213992742977677541)*c[1]^3*c[2]*c[3]-(48362500899468913285152344467015184864363459561470725809665916034583983821100924013994/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]+(152063772863873174535927687453227439120231580504394221446157122329391397821657795350323049657/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(5474982547451867957133093696432992257371571689336233823645051537641591153911363733774188811/2067706002365830863197863795253950934493707580878270875926788127491691048779961580470057570)*c[1]*c[2]*c[3]^2, -(139618519754250896034828348377993451425937437322141528376887497373847313332093241880682687429/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]*c[2]*c[3]+(415456959100791724628257397355356158763251761331575796481781686805728523239378576226842490461/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[2]*c[3]+(198838980733348747968571123116915878054963658984717736182272917147562327114586297716263197431/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[2]*c[3]^2-(384248688393467299644370344704134581194087177697407187650282911659048589989520577339376453829/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]*c[2]*c[3]^3-(260371577768291618510378931904262047094313716489250794690767588368343977798766577831658235973/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]*c[2]^3*c[3]+(16387173857104365011549091311128240469458765025246202164975221761754534518686947030856217127/7160389304489080952185194994675718976857839215263641737005729256313819002256533621257421585)*c[1]*c[2]^2*c[3]^2+(375119784362858554661795322176373435986631930885633263738265291352785133122699163576988608619/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]^2*c[2]^2*c[3]+(2284126689949571512894893147991287713445190711126154638946801045118188827531649382406672511/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2]^3-(2375623576172357599126334841694149766115478697203073604396020827615712308033452285278724279/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[2]^2-(381052075477589988671438761530711563196759822622523058635447345525636287727663197727407793/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[1]+(1760827573639923276093314258692301941491205912354729727324645557233905603101070291528603854/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(147925376428159421030564171289637284487545496923726829003111640520196929773761240748915227/7811333786715361038747485448737147974754006416651245531278977370524166184279854859553550820)*c[1]^4-(407757838663484343203952335168098861651502065431029631601073894159191094316472117216279957/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]^2+(767488745955739546093795245417999125073048113987728494999104397825767075714556456913762015/7030200408043824934872736903863433177278605774986120978151079633471749565851869373598195738)*c[2]^4+(2551181125077914153583760781932676206282528307058435280759405320791323734154222600945458073/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[1]^4*c[3]-(5273423241688808114563585738089552687640745515405349088586379949749148699185904024675079865/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[3]^3*c[1]^2-(1841360373961936537190357212008288612400264298216628523679629059553236796323571398200708749/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[1]^3*c[3]^2-(352728962571807790457342569419613420716689779254033032558204775311394155888521807653161753707/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^3*c[3]^2+(83526794673495922645599954202561447453021315620591279495911744773052627201400656097139678007/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^2*c[3]^3-(4921477357471292233341592404935937926773633987633683220037578727042320422440541260361471481/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[1]*c[3]^4+(56235878384504265502282700313770682841171032130663948275065323438997964046578726394739069449/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^4*c[3]-(230677143338458366352118799943729133290931929945867683275712341965269368050229524460659751293/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[3]^2*c[1]+(2416888814220418565127253248038198864468210267474075007906873946259582608130388340409918419/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[3]+(292926453180349769364113380567602876373088742871554368183966929127802229430510244082033904387/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^2*c[3]+(326857597308272163924763765871255680182208975703289556552879860098038944037361153073784853353/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]*c[3]^2+(6886087830998974170758535467508882950640238737103357051127614173858276300537028570355066387/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[1]^3*c[3]-(41039056485226982405081866682180484453617194309435478592974518088479357634703934087916770747/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]^2*c[3]-(25187863838852262904383663733492780120102214986987550090340801649290531581381473003722740447/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[3]^3*c[1]+(50789884064777222924147403387986511949502118402813301117363601917890449049490106793145101365/154664408976964148567200211884995529900129327049694661519323751936378490448741126219160306236)*c[1]^2*c[3]^2+(663337036371183602950223127367378425420478338997299038706407494440901542374176394657036935/3124533514686144415498994179494859189901602566660498212511590948209666473711941943821420328)*c[1]^3*c[2]+(120582523920998114279902492735615455147980632646015852832251076580581828385109202622259419/465576185963167214229982576414796899157523561257359005175568187647135732837872143946900380)*c[1]^2*c[2]^2+(59184806256036015319151222411245992261514989407426780434353422688012245829570398800392889499/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^3-(29118034749352538733585652374698316208259112142275798385449525094496459599298918342515831003/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[2]*c[3]^4+(1006794411763303793672076100132687853145763749591393578047340610677908617754099734680505864781/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^3*c[3]-(56060656667192810759013653290677424472493719106627936805928410742244312534241668346291078876/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(137980626707781469242615552908394739061991220517535202475238660373299103611204680238819095501/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[2]*c[3]^3+(1691903294177779906240439472521936644210779512053793711487817041557493171480773807202814333/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]+(6770938087128238606572476269178087506346020958922581582715312049165820644815273093487529851/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(1587274920034823069206089183331700759410778498133788619493967726851001322246089640499271323/11717000680073041558121228173105721962131009624976868296918466055786249276419782289330326230)*c[1]^2*c[2]-(7271928332021489487881484033175461481623120834517311184639636977776514288252381846547865773/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]*c[3]+(11246929558274259634917481105099911102531474863582887406332658674100241811928562071832274163/34369868661547588570488935974443451088917628233265480337627500430306331210831361382035623608)*c[1]^3*c[2]*c[3]-(66715340793095368774237775327719868197962322308129656628146236132785949289651125430538707/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2]+(16885723665799987332163712745871545665555685420675249454533620503716840956596165252978512787/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2*c[3]-(12860314140028065770556700353879594091579579989510323848308276973607122900001988512029933633/90979064104096557980706006991173841117723133558643918540778677609634406146318309540682533080)*c[1]*c[2]*c[3]^2, (1185226163873991884284396184049071964061784307417164056402655486382656503492761345232433714557/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]*c[2]*c[3]-(317394401481144762510047801642514766536834218784342652590373599538657831838448566586154767533/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[2]*c[3]+(8235825227534767475336902186221231720859965606840023219916698943260039344218694778460036667879/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[2]*c[3]^2+(853806982839332797632288644659359074360548715767771766270933213946726105279164957531574417049/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]*c[2]*c[3]^3+(18670210363586700655446268561403233649695560632804938019393279571666969712172188841125445371043/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]*c[2]^3*c[3]-(631414266656087629480420459895162690491852382664387892255922184565987809460741453797742001171/114566228871825295234963119914811503629725427444218267792091668101021104036104537940118745360)*c[1]*c[2]^2*c[3]^2-(10660422020513417048110120060343615363363304020136288127335842951272535022166747315999004871343/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]^2*c[2]^2*c[3]+(14012042818561609679544607249564214818204251333651930922741014128167895120077220124145959949/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[2]^3-(5171567885441629068293316984113648026537042494482017942226368639230009853878454779936253441/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2]^2-(19811537003315631866158010162236085537373033733223709200067850852094552349793661426367468359/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]+(6300802439125125489775695840148921900383569219937058253976056210013229172647262093216438563/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(14970858109620906726196091450884983501816178057493687517621763313179863254791746020122411651/31245335146861444154989941794948591899016025666604982125115909482096664737119419438214203280)*c[1]^4+(3151703259819517880509989309391579136196843171642565059435990777386794301185012795218621689/9071226332959774109513208908210881519069168741917575455678812430286128472066928223997671920)*c[1]^2-(4406552731370191055142210381350773955611548646205156084888814254252334177105406712675808703/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[2]^4+(162324924099093361963545496834654031393834480848416734799817930619057253089726924014735435549/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[1]^4*c[3]-(309718587378951784418757257867869588975275722756256627773005808066882315720832096895050021845/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[3]^3*c[1]^2-(181045763565049298960200840205479273502159591972885705982735833188815788282000828902013619187/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[1]^3*c[3]^2+(200772377137421554619712152431803602530728883015511898904937929847446438202858683346470138207/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]^3*c[3]^2-(850065865148842671312124230686577485895880013711032174624097327404609930535394195972361551647/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^2*c[3]^3-(292632106453509598122822117916330058437606098656803459836573658596078363430772161969772109703/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[1]*c[3]^4-(2401954230134090297547736911711446267179264735520385791830560607294752222152857905656988311779/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^4*c[3]-(3632338536249793547247449607294273472695318318416147041778660424427559064956068989786588454859/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[3]^2*c[1]+(31177847320132027257193954570426653090621503583496749185472461791167415353667287671274252997/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[3]+(3923335358682793241034711728344504746929956001405841770304133963662352546063247459239140698173/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^2*c[3]+(3144939520573230888438801200006323323538876697659926823746677867120918084378218702493638145867/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]*c[3]^2+(1031039838933423521412325942941560084496080118696562795327178767943137454720598548293434614681/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[1]^3*c[3]-(7061333224220762235421002754762677919332894813641489328013809661440667379300558909435166164611/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]^2*c[3]-(1251426161327130922940222420265819281942558502736380666330074221046789532375989299041111190961/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[3]^3*c[1]+(3168318354057678404343900210354399708949892973353843026205805851574255189874092756863005407245/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[3]^2+(12422508961021805523604350906530048365911037188567215925561303784672059573295627063749118583/6249067029372288830997988358989718379803205133320996425023181896419332947423883887642840656)*c[1]^3*c[2]+(6015433289389856046348236876529009088514678517357703716855734214851246528399688373328273977/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]^2*c[2]^2+(17827848905957676681046914217378603225393890420988914501495463648616965885219603416515502211/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]^3+(67358899046791122684772035513994857135545106297691755954006873005331557015433627473397734863/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[2]*c[3]^4-(7486160104091362032820271785596905377011945474703436396944650526804622333744493963079757250721/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]^3*c[3]+(47206691403830334890862074748364150988961481299443456954950762305696109639871512474204158518/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2+(465878715596461049824638626384940813373859650611480140930592739823575600474214425375052644721/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[2]*c[3]^3-(43150647916050809970598570079692906470542498402579789126322290723102049859439394838587811783/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]-(310859381358311768307693543770047236023667099493571459967717542993345959342062999637192313/465576185963167214229982576414796899157523561257359005175568187647135732837872143946900380)*c[1]*c[2]^2+(14997756055969312433361540875332869456984686046436148795873898409473668859567556399471968289/46868002720292166232484912692422887848524038499907473187673864223144997105679129157321304920)*c[1]^2*c[2]-(535268853786225921847211292645478046089803276510813398932711912053098451984011027467874337167/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]*c[3]+(228890388449533706397913180714036862241110674326232053791139858474761578896892659609592968415/68739737323095177140977871948886902177835256466530960675255000860612662421662722764071247216)*c[1]^3*c[2]*c[3]-(1650477657700505229682995053541458838967414718337763377001908114316583322966197980472227873/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[2]+(821336101374772689551503018726625637262207191664870059188064155030299630574265665527475327971/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]^2*c[3]-(2479954359494898131934070417506477832799984318534561727729060822007494544837611791850324350477/181958128208193115961412013982347682235446267117287837081557355219268812292636619081365066160)*c[1]*c[2]*c[3]^2
-(158471428405108868755437146379180798124657342277475484353205014415702555616469103363735511327/77332204488482074283600105942497764950064663524847330759661875968189245224370563109580153118)*c[1]*c[2]*c[3]^3+(817115548677586178176999469845338231148553546088142304637694244465443787954360440954129301453/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]*c[2]^3*c[3]-(4572218060433129377234623928181288017796186638571327007343438402760350393127688409792538349/6364790492879183068609062217489527979429190413567681544005092672278950224228029885562152520)*c[1]*c[2]^2*c[3]^2+(20346265967617436411596104563128584080430137430711683022609496382995515918197657317379944363/49891744831278757602322648995159848354880428080546665006233468366573706596368105231987195560)*c[1]^2*c[2]^2*c[3]+(1102137681365209966049661522260196061251652615091911984407508220134170665417853015572579701/4989174483127875760232264899515984835488042808054666500623346836657370659636810523198719556)*c[1]^2*c[2]*c[3]^2+(12003361868662501758213772237030367239167371134440765016518344013472749387226368014375625227/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[1]^3*c[2]*c[3]-(384886890512193361158377027871999599478478635960161702605834453677288126375999892321840306217/515548029923213828557334039616651766333764423498982205064412506454594968162470420730534354120)*c[3]^3*c[1]^2+(150156726849789255801961314435579159710030385513318078773084997147126129453950151260844619621/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]^3*c[3]^2-(129714472390141880950845487790142661600884220061717223669011739770107674842204890822351509571/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^4*c[3]+(7606842045457181514527010779395477233591226210623551478434718060925030725887587851415778432/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]^3-(16061633357475870789787943496408748360321959855562411166246657187182056859562892365868010816/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^3*c[3]^2+(10242879445587123958774614170006859672375767796285179388084351529199573440898749176992814848/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^4*c[3]+(20121091418877322556642191521187136191513294783890340944118935474813962844244585239489133273/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]*c[3]^4+(8379374322641295579078241009234157208857924859193966466172933813497458753550514651472114201/28120801632175299739490947615453732709114423099944483912604318533886998263407477494392782952)*c[1]*c[3]-(1585711878675521080236080038541706574157019553516581892508478130955662639833532974621310604539/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[3]^2*c[1]+(26677011478640862160716000206762529500762850636471009875403272198688871618125118516494749312/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]-(874160859728658068609782790646364990624561838246644643337722534474420073620230398315372472451/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[3]-(133620348241512103024389238606621210701270437978007902034694023237073260168149917097493214861/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[1]*c[2]*c[3]-(427397189912936558418377271479338136447309205587597223797211081179178113476400993381098489721/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[1]^2*c[2]*c[3]+(162293319335725527008628173163673520153100045415267135968526707404387301107411554879580701607/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(111897000388465910375087117925637277937888666382295280513798524218535321044134420673906339073/45489532052048278990353003495586920558861566779321959270389338804817203073159154770341266540)*c[1]*c[2]*c[3]^2-(221625654031822857827930508023637655229565601994580756927653228915837635840848416860143953663/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^3*c[3]+(921227515040452585655802318663397410921614985328593249703099120458905102308518203545762517869/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[3]^2+(14883571935214146664599997879317530442506260052379431817791090709878790332204640880005078464/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]*c[3]^2+(423931577040542655468403184954248406159350044405651877114680737268229918396289657894741981303/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[3]^3*c[1]+(4002401366417243294222536403760114379341463902959427528792772997688549169806035852834048525/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]*c[2]^3+(309393529298459736174338297848709255921318578394287858406146002867969763719068994052410097/7811333786715361038747485448737147974754006416651245531278977370524166184279854859553550820)*c[1]^3*c[2]-(21821851027037147588196231209213383337919403652194273171325833017655337944165810634234602279/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2-(1325899622260625593585841022122799695109591583018109504218461687415601029923538108148281664/12888700748080345713933350990416294158344110587474555126610312661364874204061760518263358853)*c[2]*c[3]^4+(723415193135677790752661486632005489149397023050808004436006920506926806872417481337254257/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]+(343118830109531861488608761254701087924413659239387205816120340789639325993897679196352863/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]*c[2]^2+(2796251530763911160857799986888871036642434723108232499398836932607680647966047283017539145/4686800272029216623248491269242288784852403849990747318767386422314499710567912915732130492)*c[1]^2*c[2]-(331129731505936461636172245437228852481652551502529371809457836235779746203247938833247424/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]*c[3]+(45844726189179231237869011102416723433349818381198441824612821734489598572669729427388302528/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^3*c[3]-(20421928646916357012792530439975288443277134608941961539187804752524386026055470821620271104/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(6282994797071592650483982709582719991183137886767342827254077022438563716812485894651421888/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]*c[3]^3-(6595360005853618890089357169757351418832834915554886185780456365312485988154497840691725091/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(4077191474615102296268746376347213861136163543969925077134301932667132632969375565215573953/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3+(10047378588811324298485607808979467777799926446249731280503707510640847741332799492391073447/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(139791445008097421737720901971158461240524303965285317497137178934498285941370423565697280/3515100204021912467436368451931716588639302887493060489075539816735874782925934686799097869)*c[2]^4-(494337568007024305736608300378398544426460760309559706537307404474086025765754019715374451/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]+(208016972400027196793944088819230422204548262665116773980193340234026137945866600279953536/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^3-(432699312215829327337806480758181844319230996641895391402730118766138496046963090027211008/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^2-(6075811497444619353406726559221366448695784161650858272593562461089568611443346788181632/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2], -(78560133589381288399264346922210281001502023694743915356512233674946988939788488957452367887/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[1]*c[2]*c[3]^3+(276800460629481750407538530452129837409441700225954892846326171019617455569490977697691799187/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]*c[2]^3*c[3]+(1149250190067097502807289828766451414221301674758403129748010913013089378580869625708723477/57283114435912647617481559957405751814862713722109133896045834050510552018052268970059372680)*c[1]*c[2]^2*c[3]^2+(424055776930863458736638428273717729815976524669215432124587146985902029842046845909262545341/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[2]^2*c[3]+(33287074449452040303682959002064180257077023639320141212169287536982699654325402430180870931/38666102244241037141800052971248882475032331762423665379830937984094622612185281554790076559)*c[1]^2*c[2]*c[3]^2-(8389933126972180867147550846894044573343918926270594723221760431824624244970367444714113481/17184934330773794285244467987221725544458814116632740168813750215153165605415680691017811804)*c[1]^3*c[2]*c[3]-(8701215660344837411698844897756882976866160396282416552994646522000835736474705834917122609/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[3]^3*c[1]^2+(30025361408715558929233233239972470931525211158911841183356235906506610382817050765446284423/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]^3*c[3]^2-(1454954689033218135995897396129370501094291445447572464509373819475558577861661382400564383/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^4*c[3]+(4691161648214331257250314958084487624269836143198889156540223354731777661209670948383043637/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^2*c[3]^3-(19810512158397864886753284182142233164007396690206622434436887445491707821755477095751432337/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^3*c[3]^2+(3158406795834371606347557446082124288030648685724599805474035510095327919242961873300734859/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^4*c[3]-(6494964683957929460385669206487755355426217657848298651942608320479958967415013393443767989/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]*c[3]^4+(8131326584910644659895828298592188014765855871428228759295026416733868982185495560346965951/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[3]-(1295033381811072666043711895620153434178629455308468890924371036754384491332456715724591122377/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[3]^2*c[1]+(16451790689187637333139775158678482922924208062761594363748208045250372447649359643194944217/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^2*c[3]-(606552160482612542883554949188580848860763239541069667947631107922634334731663969494176142683/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[3]+(10446173777788037077753851113656349382088124139243462670212689080667182842596416112541191045/77332204488482074283600105942497764950064663524847330759661875968189245224370563109580153118)*c[1]*c[2]*c[3]+(125390172720124209342536890116246231052470819547149241954538610766123029006199726584990654541/154664408976964148567200211884995529900129327049694661519323751936378490448741126219160306236)*c[1]^2*c[2]*c[3]+(107525693948746592032023093832605054101715775947958081213294560006206995409036056076275242713/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(24407517609288774654935090842634453887700600704842920915286682681207698210898255658220934283/45489532052048278990353003495586920558861566779321959270389338804817203073159154770341266540)*c[1]*c[2]*c[3]^2-(91494250407951590100007689219678605180434609403814252052450484855401324189936568695280166857/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^3*c[3]+(246946525245798197836936651398311226613759544911379151565179084384925665970590999957344618749/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[3]^2+(18357484336778918600319470313841891220127738941021590646014454096190652064669814622954910123/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]*c[3]^2-(10203283597634033735869120771655387663769522855478691810311011890326499553290776791929669323/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[3]^3*c[1]+(7939101025030636198393594299136979308119010188754408794529583485990015487044317406000308499/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^3+(23289930319130147518936876398219769977744607714156024697278725748071003402587673117815795/50395701849776522830628938378949341772606493010653196975993402390478491511482934577764844)*c[1]^3*c[2]-(38966524274307404391632698162379008154082123976800488624137102561044824704456346739769050259/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2-(1635372318804888390812007607431218371121434678470151171941266951382089255608406287986626273/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[2]*c[3]^4-(1648936357783383325174610977514247832129633314370003865970461306853327257795562812993886067/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]+(2607705874596369917407159569968689469486554073267214613835988513798722096012966328292094407/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(11014576595233077530650766455145584700740564834050140130915844085869412159406032038746493697/23434001360146083116242456346211443924262019249953736593836932111572498552839564578660652460)*c[1]^2*c[2]-(408417340005591620191881193172380206964909982950383908773546628376276553928860585949740343/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]*c[3]+(56545152373711227964100823225079261561205003071084385372759782673347859806024596507555330071/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^3*c[3]-(6297131442882861973781938530022563124714984692692804118365567602488134204217421833263275432/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(7749482387518401607357062223631129812562276145311960370718626146218613948287696804750525591/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[2]*c[3]^3-(2264867872832125278126372385072177804599319711357725679623459009994869382890145441446131843/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(3758846244365291539770566219755004336845912204136666233104179049282927522729192154194814813/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3+(11415931224281509982644480032664943100333387292684829128875395173372289848439492691446921467/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(43104895674946003659834136503264923679326046763223946047540820071149465235943807727368365/3515100204021912467436368451931716588639302887493060489075539816735874782925934686799097869)*c[2]^4-(3451279466823380652066030641063246064505384810770979538832647133447348879916065053983180837/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]+(128284672833904921442836957953858668844865562062764595358294074389751440656784301718383501/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[2]^3-(133423463149721544179038093402671875787975187069654314726566708868435274796679709377374389/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^2-(3746970649352932490839434423311642945575927671699577201562623316216386561100815185867337/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[2], (1306090217276901062453148546257884103181754748667665457449362541879013096926897296119843253/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[1]*c[2]*c[3]^3+(501992600348760881133936896419376457878458188873013665111533008194482902790327646867202574429/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]*c[2]^3*c[3]+(23739955572564579414258230824653047197210912626424913170312468917531100521059008825562419169/57283114435912647617481559957405751814862713722109133896045834050510552018052268970059372680)*c[1]*c[2]^2*c[3]^2-(1130692835342815939160166524842725107939302092843385993437267194585247199147566816401360219513/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[2]^2*c[3]+(175677835243039175084364412642783545143584527733148913991919701945519137191409252360381723163/154664408976964148567200211884995529900129327049694661519323751936378490448741126219160306236)*c[1]^2*c[2]*c[3]^2+(4296256743933752463123888801725347599416612515598107175428306910588975186966488297298514307/17184934330773794285244467987221725544458814116632740168813750215153165605415680691017811804)*c[1]^3*c[2]*c[3]-(376508877841310480277732817583425765826930386883480830474576670742666950136247699246401385/3326116322085250506821509933010656556992028538703111000415564557771580439757873682132479704)*c[3]^3*c[1]^2-(2610978079232998531018746534698680828643835564575535610793898586462985531155788474496848497/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]^3*c[3]^2+(5395676916384690304001994539043755617305211301974434127866824930473488921443492832359033999/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^4*c[3]+(4527970853564946202071865300331861932719339967388672261905728212387233328305726522689586397/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]^3-(19121366598305976440374689701544621089116095524197760016507027262569964656742469712469251097/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^3*c[3]^2+(6097071466587880783479549084033314306350514782017343589103187299037000098240885145508092358/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^4*c[3]-(10820803647069191232557728915465923539919163670479656667550788764964281541356130184500258253/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[1]*c[3]^4+(7574736574475927117128253762039035410672023414783506801490688626693247769808354093525349047/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[3]-(709770720595777341138415198097531521587780156486423397749544380717766695746135327639586144889/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[3]^2*c[1]+(15879484510611200085400080653284818356226449385741436446009234845094514151406345812900745377/193330511221205185709000264856244412375161658812118326899154689920473113060926407773950382795)*c[2]^2*c[3]+(2606640266867622414289604255560990719039826569363887866691858141417809448845554252917468239/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]^2*c[3]-(39595858365936660869650345849788605404512569404846452442565265488272099159924658098773950731/77332204488482074283600105942497764950064663524847330759661875968189245224370563109580153118)*c[1]*c[2]*c[3]+(31300432806539800714407875043857601747525773598588559835260835175279846025357973207186077348/38666102244241037141800052971248882475032331762423665379830937984094622612185281554790076559)*c[1]^2*c[2]*c[3]+(101304969889055620852686951330411201888459176057393003219143383282545145733336620204048963221/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(30259925730000619860678111657599596481341433261076954771797942132005401078960479305338575021/45489532052048278990353003495586920558861566779321959270389338804817203073159154770341266540)*c[1]*c[2]*c[3]^2+(2652590009000676587679603373516976149779411945534607521988763688889793590400692692250497331/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[1]^3*c[3]+(108691046009147974436259356432443049562943693303327463101739969862787662209232292253287508095/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[3]^2+(17718885055549094025108185539548114560681732309271079970213098531434258083225290166400732163/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]*c[3]^2-(60327466524765951213690310468629723416311084411472305083929405394513809212207370674686909211/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[3]^3*c[1]+(387387223383836966707798602052140396702853676708641708961210157315529908519370510934722903/2267806583239943527378302227052720379767292185479393863919703107571532118016732055999417980)*c[1]*c[2]^3+(457196946326289130835966721862867143227922299571372935253319475774958456064429164585600965/1562266757343072207749497089747429594950801283330249106255795474104833236855970971910710164)*c[1]^3*c[2]+(13836797647137917193667918199546012020660316709165740371810687589094087699674219173851238787/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2-(1578482847013831486466951475333875560862070631489735537971018989973287335642156114114350313/25777401496160691427866701980832588316688221174949110253220625322729748408123521036526717706)*c[2]*c[3]^4+(538420422155229302909266068750820947064880493477200170586998432726814588935974139068768341/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]+(714949414020529711072589257838178135538961580852582717585232936664563641657776116251042589/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(242778680615646908009221902698602808869691076665508732898846048278399189439400719425653249/755935527746647842459434075684240126589097395159797954639901035857177372672244018666472660)*c[1]^2*c[2]-(394209782206028143267628056649040085599855768289599056123478000103937071433185018821887983/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]*c[3]+(54578123939943877801965363124080584822697004665582892320781837223639850152592499925062515151/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^3*c[3]-(12156147996006234642314849272370859481465685813099534276201428838846268686196590798482949584/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(7479902210203061686799121857906277320882132188800800836370663670808082405846362553348680271/42962335826934485713111169968054313861147035291581850422034375537882914013539201727544529510)*c[2]*c[3]^3-(201182545746738872318942152825848128421050246771155010551352109793903860924965887466476721/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(2734294747701225066924953116853150865349266291979157824599586609802178177386461703834155546/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(3346473567385992291769671680146143923517472040503794415142349602563493131845387398987280611/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(83210823202567192306610135238418235722426496746560279454009562491685193246793047593497130/3515100204021912467436368451931716588639302887493060489075539816735874782925934686799097869)*c[2]^4-(894989638551565461715520440704504615834301993547237038381788327332635393909192192798598989/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]+(123822051574825075645873635927519228141329454922963319371573557378404629695815555109044981/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^3-(257564158998271969532518285387952134179796064744989627284099729577485039980114044019180218/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2]^2-(3616625297039485563961656087848275613640444357631691479525127985386410959271254667486097/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[2], -(1294569619459348125397606255460379944293202186888621167834198548446317174183529969435161411/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]*c[3]^3+(7160132400116237262223973023565018247116519243495784234021779600686868954899691730917956927/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[1]*c[2]^3*c[3]-(700031917398218301930214003280464444225363491809491476055665504573393387291309761835040757/5207555857810240692498323632491431983169337611100830354185984913682777456186569906369033880)*c[1]*c[2]^2*c[3]^2-(73226841747581407704084741311950396028688379645749677607568576284974752263551458625357778781/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2*c[3]+(37927566211046531151265032259727944556136661594120404820095021188281903204802265019860128909/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]^2*c[2]*c[3]^2+(280262028232205881761944378574446081612973585449057228099921380380214095356118786916571129/390566689335768051937374272436857398737700320832562276563948868526208309213992742977677541)*c[1]^3*c[2]*c[3]-(2916316059316423022683692198152544256334554422160565308451064860155122156902173438569638015/9373600544058433246496982538484577569704807699981494637534772844628999421135825831464260984)*c[3]^3*c[1]^2-(1604371897974993570095695330698013506600997873763972436875241547099715337616980265263547939/9373600544058433246496982538484577569704807699981494637534772844628999421135825831464260984)*c[1]^3*c[3]^2+(1511261216447144258268868609865752515732930386347116768283006248273125963777836135222824703/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4*c[3]+(5504478409184402815478945769914673124965256260177346227568160195299974030900746967094054/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^2*c[3]^3-(11622551579766410698391819507162800688556060264150183490871303816494044096691723044024727/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^3*c[3]^2+(7411973118303971943721286752272819125624194553658610419604356305282137252813858635506356/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^4*c[3]-(2750495424744203492323249246901097951763773144176656952191120537889657299218087853044313591/9373600544058433246496982538484577569704807699981494637534772844628999421135825831464260984)*c[1]*c[3]^4+(4906735476484408090252598431676565700257367676792330272232599009337661779624135121950798399/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[3]-(47853006106200449951167569934680558636001586888321414961977880862455386958982110841796111123/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[3]^2*c[1]+(19304072942258345677236982866051590168752976232578997298557553992946020146759551309360414/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^2*c[3]-(60086682169422164576307950093663836556431133204918168064100381257587757255610229280759548317/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[3]+(4769742504596300257945124517548285619630775784821511457190334331383658072341026743363641393/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[1]*c[2]*c[3]+(1799769781500743026423035173453159497772177078868955696241644225657377695110199564753432959/7030200408043824934872736903863433177278605774986120978151079633471749565851869373598195738)*c[1]^2*c[2]*c[3]+(152063772863873174535927687453227439120231580504394221446157122329391397821657795350323049657/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^2*c[3]-(5474982547451867957133093696432992257371571689336233823645051537641591153911363733774188811/2067706002365830863197863795253950934493707580878270875926788127491691048779961580470057570)*c[1]*c[2]*c[3]^2+(8845655981953282907559956838776983705360273933575811187313958189835558338516632008532137357/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^3*c[3]+(29577808655999836294728549708568456818869193346247874947697187406818185097828597008084294515/28120801632175299739490947615453732709114423099944483912604318533886998263407477494392782952)*c[1]^2*c[3]^2+(10770080393329017522683046437192420669064728001918361530203362984912898435793502785793933/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]*c[3]^2-(12097206642896781233550047357745967804650704434830174121208212943751137580468562482414300017/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[3]^3*c[1]+(3148986854405510468281718446024327737408318461471646457467092677950469891473550936664382004/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[1]*c[2]^3+(2472225182049198198119990305157981813930582808288901270213662096303378836642082006128911/5173068732924080158110917515719965546194706236192877835284090973857063698198579377187782)*c[1]^3*c[2]+(22712656245957212073902722167585450380155705827224348364104206204692485012739987870516504809/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2*c[2]^2-(959450163400984106446836435083691083743453846237834322734921393180515003475313900400583/37796776387332392122971703784212006329454869757989897731995051792858868633612200933323633)*c[2]*c[3]^4-(1243347924175099304768618720451583547421102130284895066984028089856663753704776356737682587/17575501020109562337181842259658582943196514437465302445377699083679373914629673433995489345)*c[1]*c[2]+(3523631039658031964770497282146617430856980193951598158502512945366545722150557894101725873/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(9054300668807359226130270203160578630229234981445803597795479241301358900659788503548332353/23434001360146083116242456346211443924262019249953736593836932111572498552839564578660652460)*c[1]^2*c[2]-(239612765300151442311264737761462002078476985129590387497714207843475100291936694467553/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]*c[3]+(33174253386004305937694551026069239751889016448857142003345573043002597432561596978365441/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^3*c[3]-(14777757266300567083424157314952422325547754574986738269364710472238202064807249806049888/62994627312220653538286172973686677215758116263316496219991752988098114389353668222206055)*c[2]^2*c[3]^2-(4546513388713323575418404273999071350267830059176565526910345131868236069646071957695361/62994627312220653538286172973686677215758116263316496219991752988098114389353668222206055)*c[2]*c[3]^3-(1455479806108690076619311906032124160835868467732055307275164650332033762002349048898977567/15622667573430722077494970897474295949508012833302491062557954741048332368559709719107101640)*c[1]^4+(1897438899451378333317681314291141107884793005801483694052987621912195099873058638886365767/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3+(8277466376420132975101540722210797277259943184818770448213077689181478684117456315845191103/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]^2+(1112717846461429610966622695477423683390495536679926334675175272291980898986342391716260/113390329161997176368915111352636018988364609273969693195985155378576605900836602799970899)*c[2]^4-(2090898390039545844251843632100066330134734229074253741909676494330295424167617066484808853/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]+(1655782280117194124282932800421325711186570495826514295737854091217777284203708372201362/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^3-(3444218255460840852950654484435590960924639191655687123178566359900477365796616126029636/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2]^2-(48362500899468913285152344467015184864363459561470725809665916034583983821100924013994/566951645809985881844575556763180094941823046369848465979925776892883029504183013999854495)*c[2], -(384248688393467299644370344704134581194087177697407187650282911659048589989520577339376453829/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]*c[2]*c[3]^3-(260371577768291618510378931904262047094313716489250794690767588368343977798766577831658235973/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[1]*c[2]^3*c[3]+(16387173857104365011549091311128240469458765025246202164975221761754534518686947030856217127/7160389304489080952185194994675718976857839215263641737005729256313819002256533621257421585)*c[1]*c[2]^2*c[3]^2+(375119784362858554661795322176373435986631930885633263738265291352785133122699163576988608619/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]^2*c[2]^2*c[3]+(198838980733348747968571123116915878054963658984717736182272917147562327114586297716263197431/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[2]*c[3]^2+(11246929558274259634917481105099911102531474863582887406332658674100241811928562071832274163/34369868661547588570488935974443451088917628233265480337627500430306331210831361382035623608)*c[1]^3*c[2]*c[3]-(5273423241688808114563585738089552687640745515405349088586379949749148699185904024675079865/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[3]^3*c[1]^2-(1841360373961936537190357212008288612400264298216628523679629059553236796323571398200708749/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[1]^3*c[3]^2+(2551181125077914153583760781932676206282528307058435280759405320791323734154222600945458073/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[1]^4*c[3]+(83526794673495922645599954202561447453021315620591279495911744773052627201400656097139678007/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^2*c[3]^3-(352728962571807790457342569419613420716689779254033032558204775311394155888521807653161753707/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^3*c[3]^2+(56235878384504265502282700313770682841171032130663948275065323438997964046578726394739069449/386661022442410371418000529712488824750323317624236653798309379840946226121852815547900765590)*c[2]^4*c[3]-(4921477357471292233341592404935937926773633987633683220037578727042320422440541260361471481/51554802992321382855733403961665176633376442349898220506441250645459496816247042073053435412)*c[1]*c[3]^4+(2416888814220418565127253248038198864468210267474075007906873946259582608130388340409918419/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[3]-(230677143338458366352118799943729133290931929945867683275712341965269368050229524460659751293/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[3]^2*c[1]+(292926453180349769364113380567602876373088742871554368183966929127802229430510244082033904387/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^2*c[3]-(41039056485226982405081866682180484453617194309435478592974518088479357634703934087916770747/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[1]^2*c[3]-(139618519754250896034828348377993451425937437322141528376887497373847313332093241880682687429/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]*c[2]*c[3]+(415456959100791724628257397355356158763251761331575796481781686805728523239378576226842490461/309328817953928297134400423769991059800258654099389323038647503872756980897482252438320612472)*c[1]^2*c[2]*c[3]+(16885723665799987332163712745871545665555685420675249454533620503716840956596165252978512787/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2*c[3]-(12860314140028065770556700353879594091579579989510323848308276973607122900001988512029933633/90979064104096557980706006991173841117723133558643918540778677609634406146318309540682533080)*c[1]*c[2]*c[3]^2+(6886087830998974170758535467508882950640238737103357051127614173858276300537028570355066387/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[1]^3*c[3]+(50789884064777222924147403387986511949502118402813301117363601917890449049490106793145101365/154664408976964148567200211884995529900129327049694661519323751936378490448741126219160306236)*c[1]^2*c[3]^2+(326857597308272163924763765871255680182208975703289556552879860098038944037361153073784853353/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]*c[3]^2-(25187863838852262904383663733492780120102214986987550090340801649290531581381473003722740447/85924671653868971426222339936108627722294070583163700844068751075765828027078403455089059020)*c[3]^3*c[1]+(59184806256036015319151222411245992261514989407426780434353422688012245829570398800392889499/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]^3+(663337036371183602950223127367378425420478338997299038706407494440901542374176394657036935/3124533514686144415498994179494859189901602566660498212511590948209666473711941943821420328)*c[1]^3*c[2]+(120582523920998114279902492735615455147980632646015852832251076580581828385109202622259419/465576185963167214229982576414796899157523561257359005175568187647135732837872143946900380)*c[1]^2*c[2]^2-(29118034749352538733585652374698316208259112142275798385449525094496459599298918342515831003/103109605984642765711466807923330353266752884699796441012882501290918993632494084146106870824)*c[2]*c[3]^4+(1691903294177779906240439472521936644210779512053793711487817041557493171480773807202814333/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]*c[2]+(6770938087128238606572476269178087506346020958922581582715312049165820644815273093487529851/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]*c[2]^2+(1587274920034823069206089183331700759410778498133788619493967726851001322246089640499271323/11717000680073041558121228173105721962131009624976868296918466055786249276419782289330326230)*c[1]^2*c[2]-(7271928332021489487881484033175461481623120834517311184639636977776514288252381846547865773/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]*c[3]+(1006794411763303793672076100132687853145763749591393578047340610677908617754099734680505864781/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^3*c[3]-(56060656667192810759013653290677424472493719106627936805928410742244312534241668346291078876/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2-(137980626707781469242615552908394739061991220517535202475238660373299103611204680238819095501/171849343307737942852444679872217255444588141166327401688137502151531656054156806910178118040)*c[2]*c[3]^3-(147925376428159421030564171289637284487545496923726829003111640520196929773761240748915227/7811333786715361038747485448737147974754006416651245531278977370524166184279854859553550820)*c[1]^4+(1760827573639923276093314258692301941491205912354729727324645557233905603101070291528603854/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3-(407757838663484343203952335168098861651502065431029631601073894159191094316472117216279957/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[1]^2+(767488745955739546093795245417999125073048113987728494999104397825767075714556456913762015/7030200408043824934872736903863433177278605774986120978151079633471749565851869373598195738)*c[2]^4-(381052075477589988671438761530711563196759822622523058635447345525636287727663197727407793/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[1]+(2284126689949571512894893147991287713445190711126154638946801045118188827531649382406672511/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2]^3-(2375623576172357599126334841694149766115478697203073604396020827615712308033452285278724279/35151002040219124674363684519317165886393028874930604890755398167358747829259346867990978690)*c[2]^2-(66715340793095368774237775327719868197962322308129656628146236132785949289651125430538707/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2], (853806982839332797632288644659359074360548715767771766270933213946726105279164957531574417049/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]*c[2]*c[3]^3+(18670210363586700655446268561403233649695560632804938019393279571666969712172188841125445371043/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]*c[2]^3*c[3]-(631414266656087629480420459895162690491852382664387892255922184565987809460741453797742001171/114566228871825295234963119914811503629725427444218267792091668101021104036104537940118745360)*c[1]*c[2]^2*c[3]^2-(10660422020513417048110120060343615363363304020136288127335842951272535022166747315999004871343/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]^2*c[2]^2*c[3]+(8235825227534767475336902186221231720859965606840023219916698943260039344218694778460036667879/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[2]*c[3]^2+(228890388449533706397913180714036862241110674326232053791139858474761578896892659609592968415/68739737323095177140977871948886902177835256466530960675255000860612662421662722764071247216)*c[1]^3*c[2]*c[3]-(309718587378951784418757257867869588975275722756256627773005808066882315720832096895050021845/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[3]^3*c[1]^2-(181045763565049298960200840205479273502159591972885705982735833188815788282000828902013619187/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[1]^3*c[3]^2+(162324924099093361963545496834654031393834480848416734799817930619057253089726924014735435549/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[1]^4*c[3]-(850065865148842671312124230686577485895880013711032174624097327404609930535394195972361551647/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^2*c[3]^3+(200772377137421554619712152431803602530728883015511898904937929847446438202858683346470138207/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]^3*c[3]^2-(2401954230134090297547736911711446267179264735520385791830560607294752222152857905656988311779/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^4*c[3]-(292632106453509598122822117916330058437606098656803459836573658596078363430772161969772109703/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[1]*c[3]^4+(31177847320132027257193954570426653090621503583496749185472461791167415353667287671274252997/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[3]-(3632338536249793547247449607294273472695318318416147041778660424427559064956068989786588454859/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[3]^2*c[1]+(3923335358682793241034711728344504746929956001405841770304133963662352546063247459239140698173/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^2*c[3]-(7061333224220762235421002754762677919332894813641489328013809661440667379300558909435166164611/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]^2*c[3]+(1185226163873991884284396184049071964061784307417164056402655486382656503492761345232433714557/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]*c[2]*c[3]-(317394401481144762510047801642514766536834218784342652590373599538657831838448566586154767533/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[2]*c[3]+(821336101374772689551503018726625637262207191664870059188064155030299630574265665527475327971/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]^2*c[3]-(2479954359494898131934070417506477832799984318534561727729060822007494544837611791850324350477/181958128208193115961412013982347682235446267117287837081557355219268812292636619081365066160)*c[1]*c[2]*c[3]^2+(1031039838933423521412325942941560084496080118696562795327178767943137454720598548293434614681/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[1]^3*c[3]+(3168318354057678404343900210354399708949892973353843026205805851574255189874092756863005407245/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[3]^2+(3144939520573230888438801200006323323538876697659926823746677867120918084378218702493638145867/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]*c[3]^2-(1251426161327130922940222420265819281942558502736380666330074221046789532375989299041111190961/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[3]^3*c[1]+(17827848905957676681046914217378603225393890420988914501495463648616965885219603416515502211/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]^3+(12422508961021805523604350906530048365911037188567215925561303784672059573295627063749118583/6249067029372288830997988358989718379803205133320996425023181896419332947423883887642840656)*c[1]^3*c[2]+(6015433289389856046348236876529009088514678517357703716855734214851246528399688373328273977/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]^2*c[2]^2+(67358899046791122684772035513994857135545106297691755954006873005331557015433627473397734863/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[2]*c[3]^4-(43150647916050809970598570079692906470542498402579789126322290723102049859439394838587811783/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]-(310859381358311768307693543770047236023667099493571459967717542993345959342062999637192313/465576185963167214229982576414796899157523561257359005175568187647135732837872143946900380)*c[1]*c[2]^2+(14997756055969312433361540875332869456984686046436148795873898409473668859567556399471968289/46868002720292166232484912692422887848524038499907473187673864223144997105679129157321304920)*c[1]^2*c[2]-(535268853786225921847211292645478046089803276510813398932711912053098451984011027467874337167/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]*c[3]-(7486160104091362032820271785596905377011945474703436396944650526804622333744493963079757250721/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]^3*c[3]+(47206691403830334890862074748364150988961481299443456954950762305696109639871512474204158518/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2+(465878715596461049824638626384940813373859650611480140930592739823575600474214425375052644721/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[2]*c[3]^3-(14970858109620906726196091450884983501816178057493687517621763313179863254791746020122411651/31245335146861444154989941794948591899016025666604982125115909482096664737119419438214203280)*c[1]^4+(6300802439125125489775695840148921900383569219937058253976056210013229172647262093216438563/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3+(3151703259819517880509989309391579136196843171642565059435990777386794301185012795218621689/9071226332959774109513208908210881519069168741917575455678812430286128472066928223997671920)*c[1]^2-(4406552731370191055142210381350773955611548646205156084888814254252334177105406712675808703/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[2]^4-(19811537003315631866158010162236085537373033733223709200067850852094552349793661426367468359/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]+(14012042818561609679544607249564214818204251333651930922741014128167895120077220124145959949/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[2]^3-(5171567885441629068293316984113648026537042494482017942226368639230009853878454779936253441/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2]^2-(1650477657700505229682995053541458838967414718337763377001908114316583322966197980472227873/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[2]
for i to 6 do print(i, sbeqmaple18[i]) end do
6, (853806982839332797632288644659359074360548715767771766270933213946726105279164957531574417049/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]*c[2]*c[3]^3+(18670210363586700655446268561403233649695560632804938019393279571666969712172188841125445371043/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]*c[2]^3*c[3]-(631414266656087629480420459895162690491852382664387892255922184565987809460741453797742001171/114566228871825295234963119914811503629725427444218267792091668101021104036104537940118745360)*c[1]*c[2]^2*c[3]^2-(10660422020513417048110120060343615363363304020136288127335842951272535022166747315999004871343/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]^2*c[2]^2*c[3]+(8235825227534767475336902186221231720859965606840023219916698943260039344218694778460036667879/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[2]*c[3]^2+(228890388449533706397913180714036862241110674326232053791139858474761578896892659609592968415/68739737323095177140977871948886902177835256466530960675255000860612662421662722764071247216)*c[1]^3*c[2]*c[3]-(309718587378951784418757257867869588975275722756256627773005808066882315720832096895050021845/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[3]^3*c[1]^2-(181045763565049298960200840205479273502159591972885705982735833188815788282000828902013619187/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[1]^3*c[3]^2+(162324924099093361963545496834654031393834480848416734799817930619057253089726924014735435549/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[1]^4*c[3]-(850065865148842671312124230686577485895880013711032174624097327404609930535394195972361551647/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^2*c[3]^3+(200772377137421554619712152431803602530728883015511898904937929847446438202858683346470138207/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]^3*c[3]^2-(2401954230134090297547736911711446267179264735520385791830560607294752222152857905656988311779/773322044884820742836001059424977649500646635248473307596618759681892452243705631095801531180)*c[2]^4*c[3]-(292632106453509598122822117916330058437606098656803459836573658596078363430772161969772109703/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[1]*c[3]^4+(31177847320132027257193954570426653090621503583496749185472461791167415353667287671274252997/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[3]-(3632338536249793547247449607294273472695318318416147041778660424427559064956068989786588454859/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[3]^2*c[1]+(3923335358682793241034711728344504746929956001405841770304133963662352546063247459239140698173/1546644089769641485672002118849955299001293270496946615193237519363784904487411262191603062360)*c[2]^2*c[3]-(7061333224220762235421002754762677919332894813641489328013809661440667379300558909435166164611/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[1]^2*c[3]+(1185226163873991884284396184049071964061784307417164056402655486382656503492761345232433714557/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]*c[2]*c[3]-(317394401481144762510047801642514766536834218784342652590373599538657831838448566586154767533/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[2]*c[3]+(821336101374772689551503018726625637262207191664870059188064155030299630574265665527475327971/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]^2*c[3]-(2479954359494898131934070417506477832799984318534561727729060822007494544837611791850324350477/181958128208193115961412013982347682235446267117287837081557355219268812292636619081365066160)*c[1]*c[2]*c[3]^2+(1031039838933423521412325942941560084496080118696562795327178767943137454720598548293434614681/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[1]^3*c[3]+(3168318354057678404343900210354399708949892973353843026205805851574255189874092756863005407245/618657635907856594268800847539982119600517308198778646077295007745513961794964504876641224944)*c[1]^2*c[3]^2+(3144939520573230888438801200006323323538876697659926823746677867120918084378218702493638145867/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]*c[3]^2-(1251426161327130922940222420265819281942558502736380666330074221046789532375989299041111190961/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[3]^3*c[1]+(17827848905957676681046914217378603225393890420988914501495463648616965885219603416515502211/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]^3+(12422508961021805523604350906530048365911037188567215925561303784672059573295627063749118583/6249067029372288830997988358989718379803205133320996425023181896419332947423883887642840656)*c[1]^3*c[2]+(6015433289389856046348236876529009088514678517357703716855734214851246528399688373328273977/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]^2*c[2]^2+(67358899046791122684772035513994857135545106297691755954006873005331557015433627473397734863/206219211969285531422933615846660706533505769399592882025765002581837987264988168292213741648)*c[2]*c[3]^4-(43150647916050809970598570079692906470542498402579789126322290723102049859439394838587811783/281208016321752997394909476154537327091144230999444839126043185338869982634074774943927829520)*c[1]*c[2]-(310859381358311768307693543770047236023667099493571459967717542993345959342062999637192313/465576185963167214229982576414796899157523561257359005175568187647135732837872143946900380)*c[1]*c[2]^2+(14997756055969312433361540875332869456984686046436148795873898409473668859567556399471968289/46868002720292166232484912692422887848524038499907473187673864223144997105679129157321304920)*c[1]^2*c[2]-(535268853786225921847211292645478046089803276510813398932711912053098451984011027467874337167/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]*c[3]-(7486160104091362032820271785596905377011945474703436396944650526804622333744493963079757250721/3093288179539282971344004237699910598002586540993893230386475038727569808974822524383206124720)*c[2]^3*c[3]+(47206691403830334890862074748364150988961481299443456954950762305696109639871512474204158518/21481167913467242856555584984027156930573517645790925211017187768941457006769600863772264755)*c[2]^2*c[3]^2+(465878715596461049824638626384940813373859650611480140930592739823575600474214425375052644721/343698686615475885704889359744434510889176282332654803376275004303063312108313613820356236080)*c[2]*c[3]^3-(14970858109620906726196091450884983501816178057493687517621763313179863254791746020122411651/31245335146861444154989941794948591899016025666604982125115909482096664737119419438214203280)*c[1]^4+(6300802439125125489775695840148921900383569219937058253976056210013229172647262093216438563/5858500340036520779060614086552860981065504812488434148459233027893124638209891144665163115)*c[1]^3+(3151703259819517880509989309391579136196843171642565059435990777386794301185012795218621689/9071226332959774109513208908210881519069168741917575455678812430286128472066928223997671920)*c[1]^2-(4406552731370191055142210381350773955611548646205156084888814254252334177105406712675808703/14060400816087649869745473807726866354557211549972241956302159266943499131703738747196391476)*c[2]^4-(19811537003315631866158010162236085537373033733223709200067850852094552349793661426367468359/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[1]+(14012042818561609679544607249564214818204251333651930922741014128167895120077220124145959949/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[2]^3-(5171567885441629068293316984113648026537042494482017942226368639230009853878454779936253441/70302004080438249348727369038634331772786057749861209781510796334717495658518693735981957380)*c[2]^2-(1650477657700505229682995053541458838967414718337763377001908114316583322966197980472227873/140604008160876498697454738077268663545572115499722419563021592669434991317037387471963914760)*c[2]
tobesbstd := c[1]^5, c[2]*c[1]^4, c[2]^2*c[1]^3, c[2]^3*c[1]^2, c[2]^4*c[1], c[2]^5
`sbΦ`[1] := expand(Phi[1]); for k to 4 do for i to 6 do `sbΦ`[1] := simplify(algsubs(tobesbstd[i] = sbeqmaple18[i], expand(`sbΦ`[1]))) end do end do; simplify(`sbΦ`[1]); sort(expand(evalf(`sbΦ`[1])))
0.8563845992e12*c[1]^4*c[3]^2-0.6313141774e13*c[1]^3*c[2]*c[3]^2-0.6354715684e11*c[1]^3*c[3]^3+0.2627132195e14*c[1]^2*c[2]^2*c[3]^2+0.2716553725e13*c[1]^2*c[2]*c[3]^3+0.3603765866e12*c[1]^2*c[3]^4-0.1036688600e14*c[1]*c[2]^3*c[3]^2-0.2093632956e13*c[1]*c[2]^2*c[3]^3-0.7980272102e13*c[1]*c[2]*c[3]^4-0.1793078239e12*c[1]*c[3]^5-0.2398064774e13*c[2]^4*c[3]^2-0.3296302181e13*c[2]^3*c[3]^3+0.2268539730e12*c[2]^2*c[3]^4-0.1651925358e12*c[2]*c[3]^5+0.5234108277e12*c[3]^6-0.1570431099e13*c[1]^4*c[3]+0.2675951743e14*c[1]^3*c[2]*c[3]-0.2688211373e13*c[1]^3*c[3]^2-0.1822013620e14*c[1]^2*c[2]^2*c[3]+0.4803041092e14*c[1]^2*c[2]*c[3]^2-0.2160708281e13*c[1]^2*c[3]^3+0.6856980792e13*c[1]*c[2]^3*c[3]-0.7101414932e14*c[1]*c[2]^2*c[3]^2-0.1655524425e14*c[1]*c[2]*c[3]^3-0.5961014496e13*c[1]*c[3]^4-0.5192679722e13*c[2]^4*c[3]+0.1645086517e14*c[2]^3*c[3]^2+0.7230064640e13*c[2]^2*c[3]^3+0.1066159909e14*c[2]*c[3]^4+0.2259465818e13*c[3]^5+0.1363385651e13*c[1]^4+0.3879841781e13*c[1]^3*c[2]+0.9492169417e13*c[1]^3*c[3]-0.3235260145e13*c[1]^2*c[2]^2-0.1149191209e14*c[1]^2*c[2]*c[3]+0.7976577337e13*c[1]^2*c[3]^2+0.1108123656e13*c[1]*c[2]^3+0.1357750152e14*c[1]*c[2]^2*c[3]-0.5368513690e14*c[1]*c[2]*c[3]^2-0.1273922635e14*c[1]*c[3]^3-0.2913515776e13*c[2]^4-0.1002375646e14*c[2]^3*c[3]+0.3441726242e14*c[2]^2*c[3]^2+0.1481005758e14*c[2]*c[3]^3+0.2494873680e13*c[3]^4+0.5098816075e13*c[1]^3+0.5608530896e13*c[1]^2*c[2]-0.4919866665e13*c[1]^2*c[3]-0.9161406470e12*c[1]*c[2]^2+0.2615606058e13*c[1]*c[2]*c[3]-0.7167406052e13*c[1]*c[3]^2+0.2358024476e13*c[2]^3-0.3082256788e13*c[2]^2*c[3]+0.8862700156e13*c[2]*c[3]^2+0.2888825405e13*c[3]^3+0.1424020811e13*c[1]^2+0.5860374233e12*c[1]*c[2]-0.5732426902e12*c[1]*c[3]-0.1575644075e13*c[2]^2-0.3878420122e13*c[2]*c[3]-0.4546089044e12*c[3]^2-0.2340665027e12*c[1]+0.1358664031e13*c[2]+0.2931991960e12*c[3]-0.2274667103e12
Copy and pasted*Correct*answer
Download Maple18_algsubs_works.mw
I am using Maple 2017.3 on a laptop running Debian Linux with high resolution display (2560x1440). The fonts used in the menus are too small to be readable on my screen. I know how to change font size of math output/input, but how can I change the font size of menus? Currently, I am unable to use Maple because of this problem.
please need some brain power here to help me with this problem. I'm stacked here and I cannot find a solution.
I would like to find the intersection between a plane and a quadric surfaces. Please notice that the two equations are written like f(x,y) and g(x,z) respectively. My first problem is that I cannot visualize the two surfaces correctly as implicitplot3d of the quadric surfaces displays nothing in return.
I want then to find the centre of the ellipse and plot the point and the two surfaces all together in the same 3d plot. Somehow I canont make it. What is wrong with me?
I am pasting here my MWE.
Any kind of help would be really appreciated. Thank you so much.
Andrea
MWE_maple_help.mw
with(plottools):
with(Student:-MultivariateCalculus):
with(Student:-Precalculus):
with(geometry):
with( Optimization ):
my_plane := 2024.30587449691-.341275505799078*x-3.89936179341114*y;
my_quadric := -10595.4104931095+6.73749956241827*x+42.1022818380012*z-0.654818649508000e-1*x^2-0.421174257681115e-1*z^2;
my_quadric_plot_3d := implicitplot3d(my_quadric, x=-10000..10000,
                                       y = -100..100,
                                      z=-10000..10000,color="DodgerBlue"):
my_plane_plot_3d := implicitplot3d(my_plane, x=-10000..10000,
                                       y = -100..100,
                                      z=-10000..10000,color="DarkOrange"):
my_ellipse := CompleteSquare( subs(y = solve(z = my_plane, y), my_quadric));
-0.4211742577e-1*(z-499.8202178)^2-0.6548186495e-1*(x-51.44553815)^2+99.68250
ellipse(e1, my_ellipse, [x,z]):
XY_centre_e1     := coordinates(center(o,e1)):
my_center_point := [XY_centre_e1[1],XY_centre_e1[2],
                       subs(x=XY_centre_e1[1], y=XY_centre_e1[2], my_plane)]:
my_center_point_plot := pointplot3d(my_center_point, color = "red"):
display(my_center_point_plot, my_plane_plot_3d, my_quadric_plot_3d);
Download MWE_maple_help.mw
test1 := Matrix([[1,-1],[-1,1]]);
for i from 1 to 20 do
print(Eigenvectors(test1)[2]);
i run the same command 20 times, but sometimes left has negative 1 , sometimes right has negative 1
why position is like random , is my maple has virus?
the result are not consistent, i am learning quantum computation, will this influence the quantum computation and result?
i am doing up and down and change to a differential equation, Pauli equation
It seems only one Pauli equation
i find 3*3 matrix
has 3 different kinds of matrix
one is row 1 and row 2
second is row 1 and row 3
Third is row 2 and 3
column 1 is constant
Is there any one has the same experience to predict these 3 kind of matrix, and know what I mentioned?
I am writing questions in Maple T.A.  I want to call Matlab functions to generate answers and compare to the student's answers. I want to call both built-in functions and my own functions.  I notice that Maple has Matlab Link for this purpose.  Can it be used also within Maple T.A.?
Stig Larsson, Mathematical Sciences, Chalmers University of Technology, Sweden
What am I doing wrong here, or don't understand about Maple. I followed the 'IF' structure from Maple help. I am getting the wrong result.
a := 1:
b := 3:
if a > b then
    print(wrong)
    print(correct)
end if
                            correct
Is there a way to have Maple show me approximately how much time is left for a calculation?
lets say I wanted to calculate the new Mersenne Prime and check to see if it is prime..
type(2^(74207281)-1, prime)
This would no doubt take a long time to verify but that is not my concern.  I am simply concerned with whether or not I can see how long maple thinks it will take to perform this action
I would be in worksheet mode simply inputing a calculuation.
thanks.
Does any body have example of maple code for solving optimal control problem in deterministic model using Pontryagin's maximum (or minimum) principle?
how can solve this nonlinear integral eq?
How do I disable the black borders around each command line in worksheet mode? I've seen it at several occasions, but I don't know how to do it :)
I think it would make my worksheets look much better, especially when exporting them to PDF.
If you are unsure about what I meant, the black borders can be seen here: https://image.prntscr.com/image/Foc_EYldSXiqb9T_8wLuYA.png
Anybody have idea how to solve endemic equilibrium using maple?
dS/dt=(1−p)π+φV+δR−(μ+λ+ϑ)S
dV/dt=pπ+ϑS−(μ+ϵλ+φ)V
dC/dt=ρλS+ρϵλV+(1−q)ηI−(μ+β+χ)C
dI/dt=(1−ρ)λS+(1−ρ)ϵλV+χC−(μ+α+η)I
dR/dt=βC+qηI−(μ+δ)R
Or solve by hand?
Look at the following code:
M1 := (t,lambda1,k,lambda2) -> exp( -(1/2)*(log(1-2*lambda1*t) + k*log(1-2*lambda2*t)) )
int( diff(M1(z,2,9,1/2),z)/sqrt(abs(z)),z=-infinity..0 )/GAMMA(1/2)
simplify(%)
evalf(%)
returns:    -4.682354481-5.587737200*I
which cannot be true.
First 923 924 925 926 927 928 929 Last Page 925 of 2464
