I have a question about order reduction of PDES, can we reduce order of a pde equation from 4 to 2?(or any book recommend fot this);any suggestions?
For example the equation below where A and Q and Ex are constant
i have an expression, for example
y=0.0000125698-0.0000125698*cos(54x);
how can i factor this expression to show it like this
y=0.0000125698(1-cos(54x));
tnx for help
I'm new to maple and I'm trying to write code in worksheet mode with some source code I have, I don't understand some of the syntax though, like the next:
m,  mass
r,  radius
J=m*r^2; Inertia
m and r are variables, so does this syntax mean that after the comma I set a name or label to the variables? because I tried to follow the same logic with 2d input math but it doesn´t work.
Using the help page of DataSets,Reference (below) and executing the first few commands, how do you expand to view more rows and columns of bdata?
I am somewhat surprised to find that
PDEtools:-difforder(sin(diff(f(x),x)));
say, returns 1. Does that really make mathematical sense with diff(f(x),x) here being the argument of a function?
PS: I bumped into this issue because I was trying to write down some structured type, or some other matching criterium, that will return true for some scalarly quantity consisting of any number of functions and their derivatives if and only if all arguments to all functions have differential order zero. This criterium would exclude the above function, for instance.
Update: Just for the sake of completeness, or as a service to any visitor to this thread, the above was readily resolved as being due to a blunder of mine, see a comment of mine below. The thread, though, developed into a quite interesting one concerning issues with conserved currents, and related, in the case of Grassmann-odd quantities, issues that are at the time of writing still unresolved.
Hi, I am trying to solve two nonlinear simultaneous equations with two unknown variables T & W. The Range of one variable T is from 0 to 0.4
When I use fsolve command to solve it, it gives me a solution in which T value is more than the specified range so it is an invalid solution for me. When I specify the range of T from 0 to 0.4 in fsolve, it doesn't give any solution.
Solve command in maple also doesn't give any solution and just shows evaluating.
My question is how can I get all the roots of unknown variables (T & W), which can solve these two simultaneous equations.
The maple worksheet is attached.
.maple_simul.equation.mw
So, i have 3 vectors:
A=2i-3j+ak
B=bi+j-4k
C=3i+cj+2k
where a,b,c are constants.
such that A is perpedicular on B and C, and the scalar product B*C=2.I have to estimate this constants using an iterative algorithm on Maple and then solve the problem using predefined function from Maple and compare the results.If you have an idea pls let me know.Thank you.Sry if I wasn't clear.
hello. i want to write this functionT with  "for"loop. but i don't know
e.mw
friends ,
i want to solve an equation but maple result is " Root of .. " term , how can i get rid of that
eqqq.mw
Hi, There is a problem in solving ODE using dsolve/numeric code. You people would like to help me in resolving the error, here is in attached file,
Latif_paper.mw
In part of my program I defined variable Delta bar(`#mover(mi("Δ"),mo("-"))`), and used it and other parameters in a matrix named K (K=f(Delta_bar, x,y,...) then by using some mathematical operations, I initialled parameters to get my matrix named K.
Now I want to convert datatype of my matrix K with following command
M := Matrix(`~`[convert](K, float[8]), datatype = float[8]):
but receive following error:
Error, (in `convert/float`[8]) cannot handle unevaluated name ``#mover(mi("Δ"),mo("&uminus0;"))`` in evalhf
Do anyone know where the problem is?
Ok, so i have this functions
where f(x) represent urban population and g(x) represent the rural population.
And i have to implement an algortihm in Maple to find out after what period of time x the rural population will be with 20% bigger than urban population.
I'm new in Maple and is a little bit hard for me to implement algorithms in this program.If you can help me with any idea, i will really apreciate.Thank you :).
The following is the PDE I need to solve.
(x*y+1)*(diff(h(x, y), y, y, y))+(x+h(x, y))*(diff(h(x, y), y, y))-(diff(h(x, y), y))^2+k(x, y) = 0, (10.*(x*y+1))*(diff(k(x, y), y,y))+(10.*x+h(x,y))*(diff(k(x, y), y))-(diff(h(x, y), y))*k(x, y) = 0
This is the original boundary condition:
h(0, y) = f(y), h(x, 0) = 0, k(0, y) = g(y), k(x, 0) = 1, k(x, 25) = 0, (D[2](h))(x, 0) = 0, (D[2](h))(x, 25) = 0
After using pdsolve it come out the error:
pdsolve(eval(pde2, P = .1), pdebc4, numeric, [h(x, y), k(x, y)], spacestep = .1)
Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 0, got 2
If I remove one of the boundary condition when x=0, maybe h(0,y)=f(y), then the error will be this:
Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 0, got 1
However if I remove both when x=0, it come out this error:
Error, (in pdsolve/numeric) initial/boundary conditions must be defined at one or two points for each independent variable
May I know what is the problem of this equations?
P/S: I know its only differentiate with respect to y and is consider to be an ODE( I need more explantion on this please) and I'm still new to maple. Thanks!!
int(exp(I*x(2-y)),[x=-infinity..infinity, y=0..2]);
how to calculate this integral? where I is imaginary part?
I would like to solve the two dimensional heat equation in the square [-1,1]^2  using finite difference.
The following code  does not gives me the right answer.
  I appreciate any help
heat2dequation.mw
First 1001 1002 1003 1004 1005 1006 1007 Last Page 1003 of 2463
