I solved a complex PDE equation in maple but I can not plot the output.
The manner was like bellow:
PDE := [diff(A(z, t), z)+(1/2)*alpha*A(z, t)+(I*beta[2]*(1/2))*(diff(A(z, t), t, t))-(I*beta[3]*(1/6))*(diff(A(z, t), t, t, t))-I*(GAMMA(omega[0]))(abs(A(z, t))^2*A(z, t)) = 0];
IBC := {(D[2](A))(z, 1), A(0, t) = -sin(2*Pi*t), A(z, 0) = sin(2*Pi*z), (D[2](A))(z, 0) = 2*z};
pds := pdsolve(PDE, IBC, type = numeric, time = t, range = 0 .. 1);
pds:-plot3d(A(z, t)*conjugate(A(z, t)), t = 0 .. 1, z = 0 .. 10, shading = zhue, axes = boxed, labels = ["x", "t", "A(z,t)"], labelfont = [TIMES, ROMAN, 20], orientation = [-120, 40]);
It is solved but there is an error like:
Error, (in pdsolve/numeric/plot3d) unable to compute solution for z>INFO["failtime"]:
unable to store 11.2781250000000+4390.00000040000*I when datatype=float[8]
could you please help me?
what is the problem?
Hi everyone,
I seek for creating a discrete random variable with the following characteristics. Let i be an integer between 1 and 100. The random variable is an integer, among i-x, i-x+1, i-x+2..., i-1, i+1, i+2... i+x. For example, with i=20 and x=5, the random variable is an integer between 15 and 25; with i=23 (and again x=5), the random variable is an integer between 18 and 28; and with i=98, the random variable is an integer among 93, 94... 97 and then 99, 100, 1, 2, 3.
Each possible value has the same probability, that is, 1/2x.
Any tips? Thank you in advance.
I have a differential equation which it seems not be solvable. can anyone help me to solve?
difeq.mw
I am trying to evaluate the following double integral where hypergeom([x,1/2],[3/2],C) is gauss hypergeometric function 2f1. maple gives back it unevaluated. I doubt it may be due to slow convergence of hypergeometric function.
restart; x := (1/6)*Pi; evalf(int(evalf(int(cos(x)*hypergeom([x, 1/2], [3/2], sin(x)/(r*cos(x)+k-2*r*sin(x))^2)/(r*sin(x)^2+r*cos(x)+k)^4, k = 0 .. 10)), r = 1 .. 2))
Int(Int(.8660254040*hypergeom([.5000000000, .5235987758], [1.500000000], .5000000000/(-.1339745960*r+k)^2)/(1.116025404*r+k)^4, k = 0. .. 10.), r = 1. .. 2.)
Download DOUBLE_INT_2.mw
I have tried to compile a simple program looking for counterexamples to a conjecture by Goldbach that every odd number is a sum of a prime and twice a square. Stern gave the counterexamples 5777 and 5993 a long time ago, so this is mainly for instruction purposes.
My program
othergoldbachFCi:=proc(sieve::Array(1..10000,datatype=integer[4]))
   local i,j,M;
   M:=10000;
   for i from 1 to M do
      if(sieve[i] mod 2=0) then
         for j from 1 to iquo(M-i,2*i+1) do
            sieve[i+j*(2*i+1)]:=2*iquo(sieve[i+j*(2*i+1)],2)+1;
         for j from 1 to floor(sqrt(M-i)) do
            sieve[i+j*j]:=2+sieve[i+j*j] mod 2;
         if(sieve[i]<2) then
            printf("%d is a counterexample\n",2*i+1);
works fine and compiles without problems. (I have to pass the array for the sieve because compiled program cannot declare memory, and it has to be 4 bytes even though I only need to use the lower 2 bit).  But the compiled version breaks with
   Error, (in compiledOGi) array index out of bounds
already in the first instance of the for loop. After a lot of trial and error I found out that if I replaced the line
by
   temp:=iquo(sieve[i+j*j],2);
   sieve[i+j*j]:=2+(sieve[i+j*j]-2*temp);
then the problem goes away and the compiled version works beautifully. It is not enough to do the mod 2 computation in temp, and not enough to replace mod by iquo in one line.
This makes very little sense to me. Can anybody explain? I'm still using Maple 2016 and do not know if the issue has been resolved in Maple 2017.
Best,
Soren
The equation
                     -sqrt(k x) = sqrt(k x)
 is solved correctly by Maple:
solve(-sqrt(k*x) = sqrt(k*x));
                 {k = k, x = 0}, {k = 0, x = x}
However, the equation
                 -sqrt(k x) = sqrt(k x + k - 1)
 is apparently not solved correctly:
solve(-sqrt(k*x) = sqrt(k*x+k-1));
                         {k = 1, x = x}
The variable
                               x
 can not be arbitrary since this equation reduces to the former equation
-sqrt(k*x) = sqrt(k*x);
 when  k = 1
Maple should return something similar to (4) below.
eval(-sqrt(k*x), k = 1) = eval(sqrt(k*x+k-1), k = 1);
                          (1/2)    (1/2)
                        -x      = x
solve({-x^(1/2) = x^(1/2)});
                            {x = 0}
Can this be explained in some way, or is this a bug?
Hi everybody,
I am presently developing a MAPLE-based application and I need to trace its evolutions through a “version control process”.
For codes written in other languages I use to use GIT (it acts with text files and it has syntactic coloring for different languages).
I suspect the development teams routinely face this version control issue.
Could you advise me,  on the versioning tools you use ?
Great thanks in advance
Let be the number z so that |z+3-2*I| + |z-3-8*I| = 6*sqrt(2). Find min and max of the modulus of z. How can I find min and max of modulus of z with Maple.
Thank for your help!
right_file.mw
i want to start i from 0 ,1 ,2 , 3 but it does not work I rhink the defaul value is from 1 to 4. can we begin it with zero.
Hi every body,
I have a function "p(v,T)" which I evaluated its critical point. after calculating when I want to plot diagram of "p-v" for some values of "T" around critical value of "T" I expect the shape of diagram for "T" bigger and smaller than critical value of "T" be different. but it not happened. Are here anyone can help me? The function "p(v,T)" is in the file. if you want calculate critical point and check I am right or wrong. Thanks criticalpoint.mw
eq := diff(y(t), t, t)+9*y(t) = Dirac(t)
diff(diff(y(t), t), t)+9*y(t) = Dirac(t)
with(inttrans):
icon := y(0) = 0, (D(y))(0) = 0;
dsolve({eq, icon}, y(t), method = laplace);
y(t) = (1/3)*sin(3*t)
dsolve({eq, icon}, y(t));
y(t) = (1/3)*(Heaviside(t)-1/2)*sin(3*t)
Download Dirac_for_Primes.mw
I want to know is maple helpful to find a cjange coordinate to transform an old coordinate to a new coordinate? details are attached to the file:
changecoor.mw
Thanks guyz
Hi everyone,
I have a functional "L" which I want to solve Euler-Lagrange for it and then extermise that functionalexfun.mw by its equation of motions. I know the result must be same to a function like "A" but I cant obtain that. "a", "b" and "s" are constants and not important, I insist more on the shape of "A"
Thanks a lot
i am new user in maple .i want to calculate eigenvalues of a symmetrix matrix to find max or min value but i usually face a error code ' (in simpl/max) complex argument to max/min'
i know that a symmetrix matrix have real eigenvalues.
for example:
restart:with(LinearAlgebra):with(GraphTheory):interface(rtablesize=infinity):
SeidelMatrix:=proc(G::Graph) local J,B,A,S;
J:=Matrix(1..NumberOfVertices(G),1..NumberOfVertices(G),shape=constant[1]):
B:=IdentityMatrix(NumberOfVertices(G)):
A:=AdjacencyMatrix(G):
S:=J-B-MatrixScalarMultiply(A,2):
convert(S,Matrix,shape=symmetric,datatype=float):
return S:
E:=sort(eval(Eigenvalues(SeidelMatrix(CycleGraph(7)),output='list'))):
(min,max)(E);
Error, (in simpl/min) complex argument to max/min: (1/3)*(-28+(84*I)*3^(1/2))^(1/3)+(28/3)/(-28+(84*I)*3^(1/2))^(1/3)-1/3
I am trying to evaluate the following summation which gives the result 0. But I think answer is not correct.
restart; x := 0; evalf(Sum(Sum(x^(q-p), p = 0 .. q), q = 0 .. 10))
0.
Download zero.mw
First 1002 1003 1004 1005 1006 1007 1008 Last Page 1004 of 2463
