I am curious whether anyone here can come up with a way to simplify the expression x1 to 15*Pi/32 in fewer exact, symbolic steps. The following was performed in Maple 2016.2 for Linux.
x1 := arcsin(1/2*(2+(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2));
arcsin((1/2)*(2+(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2))
x2 := evalc(convert(x1,expln));
arctan((2+(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2)/(2-(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2))
x3 := convert(x2, expln);
((1/2)*I)*(ln(1-I*(2+(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2)/(2-(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2))-ln(1+I*(2+(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2)/(2-(2+(2+2^(1/2))^(1/2))^(1/2))^(1/2)))
# non-Pro wolframalpha can simplify x3 to 15*Pi/32 (but not x2 or x1).
x4 := combine(x3);
((1/2)*I)*ln(-(I*2^(1/2)*((2+2^(1/2))*(2+(2+2^(1/2))^(1/2)))^(1/2)+I*(2*2^(1/2)+4)^(1/2)+I*2^(1/2)+(-1+I))/(I*2^(1/2)*((2+2^(1/2))*(2+(2+2^(1/2))^(1/2)))^(1/2)+I*(2*2^(1/2)+4)^(1/2)+I*2^(1/2)+1+I))
x5 := simplify(x4);
((1/2)*I)*(-ln(2)+ln(-(2+(2+2^(1/2))^(1/2))^(1/2)*(I*2^(1/2)*(2+2^(1/2))^(1/2)-I*2^(1/2)+1-I)))
x6 := expand(x5);
-((1/2)*I)*ln(2)+((1/4)*I)*ln(2+(2+2^(1/2))^(1/2))+((1/2)*I)*ln(-I*2^(1/2)*(2+2^(1/2))^(1/2)+I*2^(1/2)+(-1+I))
x7 := combine(x6);
-((1/4)*I)*(ln(-(1/2)*(2+2^(1/2))^(1/2)*(I*2^(1/2)+(-1-I)))+(2*I)*Pi)
simplify(x7,constant);
(15/32)*Pi
# It's a pity that last step worked while this next is inadequate.
simplify(x7);
-((1/4)*I)*ln(-(2+2^(1/2))^(1/2)*(I*2^(1/2)+(-1-I)))+((1/4)*I)*ln(2)+(1/2)*Pi
# Another way, using x7
simplify(evalc(x7));
(15/32)*Pi
simplify(combine(expand(x7)));
(15/32)*Pi
Download simplify_example.mw
I am trying to solve system linear partial differential equations using command "pdsolve". I am surprised to see that the solution given by this command is not satisfying the system, instead, an additional constraint is obtained for an arbitrary function, is there something about "pdsolve" I am missing?
with(PDEtools):
DepVars := [f(x, y, t, u)]
[f(x, y, t, u)]
Sys := {diff(f(x, y, t, u), u, t)-(diff(f(x, y, t, u), x, y)) = 0, diff(f(x, y, t, u), u, u) = 0, diff(f(x, y, t, u), u, y) = 0, diff(f(x, y, t, u), x, u) = 0, diff(f(x, y, t, u), x, x) = 0, diff(f(x, y, t, u), y, y, y) = 0}
{diff(diff(f(x, y, t, u), t), u)-(diff(diff(f(x, y, t, u), x), y)) = 0, diff(diff(diff(f(x, y, t, u), y), y), y) = 0, diff(diff(f(x, y, t, u), u), u) = 0, diff(diff(f(x, y, t, u), u), x) = 0, diff(diff(f(x, y, t, u), u), y) = 0, diff(diff(f(x, y, t, u), x), x) = 0}
pdsolve(Sys)
{f(x, y, t, u) = (_F3(t)*y+_F4(t))*x+(_F3(t)+_C1)*u+(1/2)*_F7(t)*y^2+_F8(t)*y+_F9(t)}
f := proc (x, y, t, u) options operator, arrow; (_F3(t)*y+_F4(t))*x+(_F3(t)+_C1)*u+(1/2)*_F7(t)*y^2+_F8(t)*y+_F9(t) end proc
Sys
{0 = 0, diff(_F3(t), t)-_F3(t) = 0}
Download pdsolve_command.mw
Good day sirs,
I am trying to plot graphs on stream function but its given me a lot of multiple error using my codes. Anyone with useful information should please share.
Below is the code.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Test.mw .
Download Test.mw
HI Maple primes.  We try to make sense of 'rsolve' in the Maple world.  What is command for source code?
Matt
Can't understand what's wrond. This text from my academic books but it doesn't work on practice. Help please
plot3d(polygons([[0, 0, 0], [1, 0, 0], [1, 0, 0], [0, 1, 0]], [[0, 0, 0], [0, 1, 0], [0, 1, 1], [0, 0, 1]], [[1, 0, 0], [1, 1, 0], [1, 1, 1], [1, 0, 1]], [[0, 0, 0], [1, 0, 0], [1, 0, 1], [0, 0, 1]], [[0, 1, 0], [1, 1, 0], [1, 1, 1], [0, 1, 1]], [[0, 0, 1], [1, 0, 1], [1, 1, 1], [0, 1, 1]]), light(0, 0, 0.0, 0.7, 0.0), light(100, 45, 0.7, 0.0, 0.0), light(100, -45, 0.0, 0.0, 0.7), ambientlight(.4, .4, .4), title(cube), style(patch), color(zhue));
Error, (in plot3d) bad range arguments: light(0, 0, 0., .7, 0.), light(100, 45, .7, 0., 0.)
Hi Mapleprimes,
We know that '' rsolve '' is a recurrence equation solver.  It is more than an expression simplifier.
Congratulations to the Maple computer algebra team for creating such a great computer tool.  simply want to know more.
rsolve_on_May_16_2017.pdf
Surely there are many steps to determine the values to place.
Matt
I recently encontered a very strange result.
Lets define the procedure:
Fg := proc(x0,y0)
if (x0>=0)and(x0<=3) and (y0<=x0+2) and (y0>=x0-1) and (y0>=0) and (y0 <=3) then
return y0*(3-y0)*x0*(3-x0)*(x0+2-y0)*(y0-x0+1);
return 0;
end if:
The plot looks like needed:
plot3d('Fg'(x,y), x=0..3, y=0..3);
But integration returns weird result:
evalf(Int('Fg'(x,y), [x=0..1, y=0..2.1]));
7.888753239
evalf(Int('Fg'(x,y), [x=0..1, y=0..2.2]));
Error, (in evalf/int) when calling 'Fg'. Received: 'cannot determine if this expression is true or false: 0 <= x and x <= 3 and y <= x+2 and x-1 <= y and 0 <= y and y <= 3'
hi...i have a problem with pdsolve this equations?
please help me.
mt.mw
Failed to load the worksheet /maplenet/convert/mt.mw .
Download mt.mw
I have a expression p:=C*A+A, when i type this to maple, maple display into p:=A*C+A because commutative property of multiplication
but I dont want to do like that. How can I display into p:=C*A+A?
I have an important question regarding the symbolic toolbox from maple for matlab
I have declared three symbolic variables:
syms t;
x = sym('x(t)', 'real');
y = sym('y(t)', 'real');
z = sym('z(t)', 'real');
f = x + y + z;
Now i want to  calculate the derivation of f regarding the variable t:
df = diff (f, t);
The result should be
df = dx(t) / dt + dy(t) / dt + dz(t) / dt
but  instead i get the result df = 0. If i use the command diff (f) i get the result
df = dx(t) / dt
Does anyone know how to fix this problem?
Hi Guys,
got my last Problem solved :) Now i do have a new one...
restart; with(RealDomain); with(CodeGeneration); with(ExcelTools); with(plots);
dx1:=133;
dy1:=132;
n := 1;
for i to 256 do
for j to 256 do
r := evalf(sqrt((i-dx1)^2+(j-dy1)^2));
Ints := R0[i, j];
IntsR[n] := [r, Ints];
n := n+1
IntsR := [seq(IntsR[i], i = 1 .. n-1)]
The list IntsR consists of unsorted values doublets. Now it would be nice to get some sort of mean value of my Ints over r.  Didnt really find a solution for it until now... do you have any hint?
Hi, i'm working with some spectral acceleration data and i'm having troubles with a 'local' command on a Newmark method code i found on the internet. I'm not a maple expert so i wish someone could help me. i'm ussing maple 2015. Greetings
Newmark=proc(z0,u0,F0);  local beta,  dt, c, kg,a,b, N, i, dF, dz, du, dw, T, m, k ;        dt:=0.01;    T:=4;    N:=T/(dt);    gam:=0.5;    beta:=0.25;      m:=0.320;    k:=435;    c:=2;   z(0):=z0;   u(0):=u0;   F(0):=F0;   w(0):=(1/(m))*(F0-k*z0-c*u0);        t=vector(i,1);    t[1,1]=0;      for i from 2 to N do :  t(i,1)=t(i-1,1)+dt:  end do:           kg:=k+(gam*c)/(beta*dt)+m/(beta*dt*dt);    a:=m/(beta*dt)+(gam*c)/(beta);    b:=  (0.5*m)/(beta)+dt*((0.5*gam)/(beta)-1)*c;       for i from 2 to N do  dF(i):=diff(F,t)+a*u(i)+b*w(i);    dz(i):=(dF(i))/(kg);    du(i):=((gam*dz(i))/(beta*dt))-((gam*u(i-1))/(beta))+dt*(1-gam/(2*beta))*w(i-1);    dw(i):=((du(i))/(beta*dt*dt))-((u(i-1))/(beta*dt))-((w(i-1))/(2*beta));     z(i+1)=dz(i)+z(i);    u(i+1):=du(i)+u(i);    w(i+1):=dw(i)+w(i);     od;       plot([z(i), u(i), w(i)],x=0..50,y=-50..50);       end;
Consider substutition with use of a function:
subs(F(x,y)=f(x)+g(y), F(x,y));
As expected, Maple returns the proper answer:
f(x)+g(y)
But
subs(F(x,y)=f(x)+g(y), F(x,x));
returns
F(x,x)
How to force Maple recognize F as a function, in order to obtain
f(x)+g(x)
in return?
The functions algsubs, applyrule work in the same way.
Good day everyone,
I'm trying to convert a series solution back to its original function but its given me "Error, (in rsolve/linindex) invalid subscript selector".
Anyone with useful informations please.
Attached is the series below
theta := convert(a-(1/2)*beta*a^2*y^2+(1/12)*beta^2*a^3*y^4-(1/72)*beta^3*a^4*y^6+(1/504)*beta^4*a^5*y^8-(5/18144)*beta^5*a^6*y^10+(1/27216)*beta^6*a^7*y^12-(95/19813248)*beta^7*a^8*y^14+O(y^16), polynom);
     1       2  2   1      2  3  4   1      3  4  6
 a - - beta a  y  + -- beta  a  y  - -- beta  a  y
     2              12               72
       1      4  5  8     5       5  6  10     1       6  7  12
    + --- beta  a  y  - ----- beta  a  y   + ----- beta  a  y
      504               18144                27216
         95        7  8  14
    - -------- beta  a  y
      19813248
L := [seq(coeff(theta, y, n), n = 0 .. 14)];
  [        1       2     1      2  3       1      3  4
  [a, 0, - - beta a , 0, -- beta  a , 0, - -- beta  a , 0,
  [        2             12                72
     1      4  5         5       5  6       1       6  7
    --- beta  a , 0, - ----- beta  a , 0, ----- beta  a , 0,
    504                18144              27216
         95        7  8]
    - -------- beta  a ]
      19813248         ]
with(gfun);
rec := listtorec(L, u(n));
[ //      2     2  3         2     2  2          2     2  \
[{ \2151 a  beta  n  - 1434 a  beta  n  - 30592 a  beta  n/ u(n) +
  /             3                  2
  \2476 a beta n  - 137904 a beta n  + 207248 a beta n
   + 424320 a beta/ u(n + 2)
     /         3           2                      \
   + \-153660 n  - 322920 n  + 1803360 n + 2545920/ u(n + 4),
                               1       2          \      ]
  u(0) = a, u(1) = 0, u(2) = - - beta a , u(3) = 0 }, ogf]
                               2                  /      ]
rsolve(rec[1], u);
      / //      2     2  3         2     2  2          2     2  \
rsolve|{ \2151 a  beta  n  - 1434 a  beta  n  - 30592 a  beta  n/
         /             3                  2
  u(n) + \2476 a beta n  - 137904 a beta n  + 207248 a beta n
     /         3           2                      \
                               1       2          \    \
  u(0) = a, u(1) = 0, u(2) = - - beta a , u(3) = 0 }, u|
                               2                  /    /
sum(%*y^n, n = 0 .. infinity);
thanx
My subsection have so many lines of codes, sometimes I want to disable one subsection, is there simple way to disable one subsection? it is tedious to set # at each lines of the subsection.
Is there any way to say maple dont open specified subsection during the running?
First 1008 1009 1010 1011 1012 1013 1014 Last Page 1010 of 2460
