hi
how i can remove this error?
Error, (in pdsolve/numeric/process_IBCs) initial/boundary conditions can only contain derivatives which are normal to the boundary, got (D[1](H))(x, 0)
RR-steady.mw
"restart;beta:=1:k:=2:L:=1: W(t):=(Heaviside(t-1)-Heaviside(t-1.1)); theta:=3:   hR:=1 :hD(x):=hR+tan(theta)*(L-x) :W0:=2: f(x):=sqrt((hR^(2)+(W0)/(k)*(L^(2)-x^(2)))):t:=5:M:=2:theta:=20:"
proc (t) options operator, arrow; Heaviside(t-1)-Heaviside(t-1.1) end proc
PDE1 := diff(H(x, y), x, x)+diff(H(x, y), y, y)+2*W(t)/k = 0
diff(diff(H(x, y), x), x)+diff(diff(H(x, y), y), y) = 0
bcs1 := {H(L, y) = hR^2, (D[1](H))(0, y) = 0};
{H(1, y) = 1, (D[1](H))(0, y) = 0}
bcs2 := {H(x, M) = hD(x)^2, (D[1](H))(x, 0) = 0}
{H(x, 2) = (1+tan(20)*(1-x))^2, (D[1](H))(x, 0) = 0}
pdsolve(PDE1, `union`(bcs1, bcs2), numeric)
Download RR-steady.mw
I want to fit a curve to the function that you can see in the picture "maple4.png" (in the appendix) to determine two parameters. This works in Maple 2.
Unfortunately Maple 18 shows me an error. Can you help me with this problem?
Best regards
Hi everybody,
I have to solve a system  of 3 equations in 3 unknowns.
One equation is linear while the others are not because of some  sinh(cste*unknown) term.
More of this the unknowns must verify some constraints of inequality type (but always very simple ; for instance “unknown <= value”).
solve fails because of the sinh terms
fsolve fails due to the inequalities
What Maple procedure do you advise me to use to solve this system ?
(at this stage I think advices could be sufficient ; if I keep coming up against the problem I will submit you a more detailed question)
I'm trying to send data from Excel to Maple through Excel Add-in.
However, in Excel,  I can only create variables. I want to send these variables to Maple and access them in Maple.
I want to know how to send variables from Excel to Maple.
I look forward your tips.
I have a list of functions which looks like this:
RR:={F[l, m-2, n-1], F[l, m+2, n], F[l, m+2, n-1], F[l-1, m+1, n-2], ...}
I wish to remove the first and second arguments from the functions, so only leaving the third argument containing the n's. I then wish to group these remaining terms together to shorten the list. i.e.
RR:={F[n-1], F[n], F[n-2]}
I have used the 'subsop' command with 1 and 2 specified as NULL in a loop, but I was wondering if there is a better way to do it? I like to avoid loops where possible and use some inbuilt Maple magic to make it tidier and (usually) more efficient.
-Yeti
me-equations-1.mw
Hello everyone.
I have a problem with solving a system consisting of 5 odes with 10 boundary conditions.
The system is solved without the boundary conditions,but once the bc's come in, maple just goes into a calculation loop that never ends.
I left it to run for a good two minutes but nothing changed.
No error nothing.it just cant seem to solve it.
7th and 8th bc's do look alike but are actually different because they have different coefficients..right?
I would really appreciate any help.thanks
Heres my code
A__01 := -6.835541849*10^5*Pi
-683554.1849*Pi
A__02 := 0
A__03 := -1079.907024*Pi
-1079.907024*Pi
A__04 := -44089.46976*Pi
-44089.46976*Pi
A__05 := 2.638295324*10^10*Pi
0.2638295324e11*Pi
A__06 := 0
A__07 := 3.157131694*10^8*Pi
315713169.4*Pi
A__08 := 1.770427737*10^8*Pi
177042773.7*Pi
A__11 := 0
A__12 := 1.304761505*10^8*Pi
130476150.5*Pi
A__13 := 3.708191716*10^5*Pi
370819.1716*Pi
A__14 := 3.632098408*10^8*Pi
363209840.8*Pi
A__15 := 1.332096563*10^5*Pi
133209.6563*Pi
A__17 := 5.134419298*10^5*Pi
513441.9298*Pi
(14)
A__20 := 2.567209650*10^5*Pi
256720.9650*Pi
(15)
A__21 := 2.567209650*10^5*Pi
256720.9650*Pi
(16)
A__22 := -4.124879810*10^5*Pi
-412487.9810*Pi
(17)
A__23 := -39934.37232*Pi
-39934.37232*Pi
(18)
A__24 := -0.1955745297e-1*Pi
-0.1955745297e-1*Pi
(19)
A__25 := 0.5587843706e-2*Pi
0.5587843706e-2*Pi
(20)
A__26 := 0.4304557420e-1*Pi
0.4304557420e-1*Pi
(21)
A__27 := 0
A__28 := 4.174119248*10^8*Pi
417411924.8*Pi
(23)
A__29 := 3.215504392*10^9*Pi
3215504392.*Pi
(24)
A__31 := 6.447686284*10^7*Pi
64476862.84*Pi
(25)
A__32 := 2.609523010*10^8*Pi
260952301.0*Pi
(26)
A__33 := 0
A__34 := 0
A__35 := -0.1545526361e-2*Pi
-0.1545526361e-2*Pi
(29)
A__36 := -.2281415432*Pi
-.2281415432*Pi
(30)
I__1 := 1.506998916*10^10*Pi
0.1506998916e11*Pi
(31)
I__2 := 2.920855252*10^6*Pi
2920855.252*Pi
(32)
I__3 := 3.563472822*10^10*Pi
0.3563472822e11*Pi
(33)
I__4 := 1.233249995*10^6*Pi
1233249.995*Pi
(34)
I__5 := 8.659447618*10^9*Pi
8659447618.*Pi
(35)
I__6 := .1159229936*Pi
.1159229936*Pi
(36)
I__7 := -5.999289724*10^6*Pi
-5999289.724*Pi
(37)
I__8 := 5.413603800*10^9*Pi
5413603800.*Pi
(38)
I__9 := 1.460427626*10^6*PiNULL
1460427.626*Pi
(39)
I__10 := 0
I__11 := 2.920855252*10^6*Pi
2920855.252*Pi
(41)
I__12 := 4.219013140*10^6*Pi
4219013.140*Pi
(42)
I__13 := 1.233249995*10^6*Pi
1233249.995*Pi
(43)
I__14 := 9.976343380*10^6*Pi
9976343.380*Pi
(44)
I__15 := -2.271776306*10^5*Pi
-227177.6306*Pi
(45)
I__16 := -.6143918658*Pi
-.6143918658*Pi
(46)
I__17 := -9534.298223*Pi
-9534.298223*Pi
(47)
I__18 := 1.868000000*10^10*Pi
0.1868000000e11*Pi
(48)
I__19 := 6.000000000*10^7*Pi
60000000.00*Pi
(49)
I__20 := -.4556919660*Pi
-.4556919660*Pi
(50)
f1 := A__01+2*A__05*u(x)+A__26*p(x)+A__29*q(x)+A__31*s(x)-2*A__14*(diff(u(x), x, x))-A__17*(diff(s(x), x, x))-A__25*(diff(p(x), x))-A__28*(diff(q(x), x)) = 0
-683554.1849*Pi+0.5276590648e11*Pi*u(x)+0.4304557420e-1*Pi*p(x)+3215504392.*Pi*q(x)+64476862.84*Pi*s(x)-726419681.6*Pi*(diff(diff(u(x), x), x))-513441.9298*Pi*(diff(diff(s(x), x), x))-0.5587843706e-2*Pi*(diff(p(x), x))-417411924.8*Pi*(diff(q(x), x)) = 0
(51)
f2 := A__03+2*A__08*s(x)+(A__21-A__23)*(diff(q(x), x))+A__22*q(x)+A__31*u(x)+A__32*(diff(w(x), x))+(A__34-A__35)*(diff(p(x), x))+A__36*p(x)-2*A__13*(diff(s(x), x, x))-A__17*(diff(u(x), x, x)) = 0
-1079.907024*Pi+354085547.4*Pi*s(x)+296655.3373*Pi*(diff(q(x), x))-412487.9810*Pi*q(x)+64476862.84*Pi*u(x)+260952301.0*Pi*(diff(w(x), x))+0.1545526361e-2*Pi*(diff(p(x), x))-.2281415432*Pi*p(x)-741638.3432*Pi*(diff(diff(s(x), x), x))-513441.9298*Pi*(diff(diff(u(x), x), x)) = 0
(52)
f3 := 2*A__12*(diff(w(x), x, x))+A__32*(diff(s(x), x))+A__33*(diff(p(x), x, x)) = 0
260952301.0*Pi*(diff(diff(w(x), x), x))+260952301.0*Pi*(diff(s(x), x)) = 0
(53)
f4 := A__04+2*A__07*q(x)+A__22*s(x)+(A__23-A__21)*(diff(s(x), x))+A__24*p(x)+A__28*(diff(u(x), x))+A__29*u(x)-2*A__15*(diff(q(x), x, x))-A__20*(diff(w(x), x, x))-A__27*(diff(p(x), x, x)) = 0
-44089.46976*Pi+631426338.8*Pi*q(x)-412487.9810*Pi*s(x)-296655.3373*Pi*(diff(s(x), x))-0.1955745297e-1*Pi*p(x)+417411924.8*Pi*(diff(u(x), x))+3215504392.*Pi*u(x)-266419.3126*Pi*(diff(diff(q(x), x), x))-256720.9650*Pi*(diff(diff(w(x), x), x)) = 0
(54)
f5 := A__02+2*A__06*p(x)+A__24*q(x)+A__25*(diff(u(x), x))+A__26*u(x)+(A__35-A__34)*(diff(s(x), x))+A__36*s(x)-2*A__11*(diff(p(x), x, x))-A__27*(diff(q(x), x, x))-A__33*(diff(w(x), x, x)) = 0
-0.1955745297e-1*Pi*q(x)+0.5587843706e-2*Pi*(diff(u(x), x))+0.4304557420e-1*Pi*u(x)-0.1545526361e-2*Pi*(diff(s(x), x))-.2281415432*Pi*s(x) = 0
(55)
f := f1, f2, f3, f4, f5
-683554.1849*Pi+0.5276590648e11*Pi*u(x)+0.4304557420e-1*Pi*p(x)+3215504392.*Pi*q(x)+64476862.84*Pi*s(x)-726419681.6*Pi*(diff(diff(u(x), x), x))-513441.9298*Pi*(diff(diff(s(x), x), x))-0.5587843706e-2*Pi*(diff(p(x), x))-417411924.8*Pi*(diff(q(x), x)) = 0, -1079.907024*Pi+354085547.4*Pi*s(x)+296655.3373*Pi*(diff(q(x), x))-412487.9810*Pi*q(x)+64476862.84*Pi*u(x)+260952301.0*Pi*(diff(w(x), x))+0.1545526361e-2*Pi*(diff(p(x), x))-.2281415432*Pi*p(x)-741638.3432*Pi*(diff(diff(s(x), x), x))-513441.9298*Pi*(diff(diff(u(x), x), x)) = 0, 260952301.0*Pi*(diff(diff(w(x), x), x))+260952301.0*Pi*(diff(s(x), x)) = 0, -44089.46976*Pi+631426338.8*Pi*q(x)-412487.9810*Pi*s(x)-296655.3373*Pi*(diff(s(x), x))-0.1955745297e-1*Pi*p(x)+417411924.8*Pi*(diff(u(x), x))+3215504392.*Pi*u(x)-266419.3126*Pi*(diff(diff(q(x), x), x))-256720.9650*Pi*(diff(diff(w(x), x), x)) = 0, -0.1955745297e-1*Pi*q(x)+0.5587843706e-2*Pi*(diff(u(x), x))+0.4304557420e-1*Pi*u(x)-0.1545526361e-2*Pi*(diff(s(x), x))-.2281415432*Pi*s(x) = 0
(56)
b1 := u(0.5e-1) = 0
u(0.5e-1) = 0
(57)
b2 := s(0.5e-1) = 0
s(0.5e-1) = 0
(58)
b3 := w(0.5e-1) = 0
w(0.5e-1) = 0
(59)
b4 := q(0.5e-1) = 0
q(0.5e-1) = 0
(60)
b5 := p(0.5e-1) = 0
p(0.5e-1) = 0
(61)
b6 := p(.25) = 10
p(.25) = 10
(62)
b7 := I__1*(D(u))(.25)+I__2*(D(s))(.25)+I__3*u(.25)+I__4*s(.25)+I__5*q(.25)+I__6*p(.25)+I__7 = 0
0.1506998916e11*Pi*(D(u))(.25)+2920855.252*Pi*(D(s))(.25)+0.3563472822e11*Pi*u(.25)+1233249.995*Pi*s(.25)+8659447618.*Pi*q(.25)+.1159229936*Pi*p(.25)-5999289.724*Pi = 0
(63)
b8 := I__11*(D(u))(.25)+I__12*(D(s))(.25)+I__13*u(.25)+I__14*s(.25)+I__15*q(.25)+I__16*p(.25)+I__17 = 0
2920855.252*Pi*(D(u))(.25)+4219013.140*Pi*(D(s))(.25)+1233249.995*Pi*u(.25)+9976343.380*Pi*s(.25)-227177.6306*Pi*q(.25)-.6143918658*Pi*p(.25)-9534.298223*Pi = 0
(64)
b9 := I__8*s(.25)+I__8*(D(w))(.25)+I__9*(D(q))(.25)+I__10*(D(p))(.25) = 0
5413603800.*Pi*s(.25)+5413603800.*Pi*(D(w))(.25)+1460427.626*Pi*(D(q))(.25) = 0
(65)
b10 := I__18*s(0.5e-1)+I__18*(D(w))(0.5e-1)+I__19*(D(q))(0.5e-1)+I__20*(D(p))(0.5e-1) = 0
0.1868000000e11*Pi*s(0.5e-1)+0.1868000000e11*Pi*(D(w))(0.5e-1)+60000000.00*Pi*(D(q))(0.5e-1)-.4556919660*Pi*(D(p))(0.5e-1) = 0
(66)
bc := b1, b2, b3, b4, b5, b6, b7, b8, b9, b10
u(0.5e-1) = 0, s(0.5e-1) = 0, w(0.5e-1) = 0, q(0.5e-1) = 0, p(0.5e-1) = 0, p(.25) = 10, 0.1506998916e11*Pi*(D(u))(.25)+2920855.252*Pi*(D(s))(.25)+0.3563472822e11*Pi*u(.25)+1233249.995*Pi*s(.25)+8659447618.*Pi*q(.25)+.1159229936*Pi*p(.25)-5999289.724*Pi = 0, 2920855.252*Pi*(D(u))(.25)+4219013.140*Pi*(D(s))(.25)+1233249.995*Pi*u(.25)+9976343.380*Pi*s(.25)-227177.6306*Pi*q(.25)-.6143918658*Pi*p(.25)-9534.298223*Pi = 0, 5413603800.*Pi*s(.25)+5413603800.*Pi*(D(w))(.25)+1460427.626*Pi*(D(q))(.25) = 0, 0.1868000000e11*Pi*s(0.5e-1)+0.1868000000e11*Pi*(D(w))(0.5e-1)+60000000.00*Pi*(D(q))(0.5e-1)-.4556919660*Pi*(D(p))(0.5e-1) = 0
(67)
dsolve({f})
{p(x) = -(8348069854359562844158444947687051096236341151137912524314220251859518302979752075863711399491114303355727159464818873878118049666882586853655525810943213049175308691527282144198671705156405315206602082005476698250000/681384695121882013959665774575457025293276552134140462144317224809813638400658850960574519166869307475297566588656254581790292202187110433759810640316460147175047462827457254048717358546426320770069677796020553)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(34240844308626491610081019711889605294500000000000000/30208360982821581783994555050953960154213271)*_C2+(34240844308626491610081019711889605294500000000000000/30208360982821581783994555050953960154213271)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(36518476837721784214832841091680291686157228031274705355784632000216560989062326960722556132883385318459531352857105163506440586634389571544838959138967158839432026560041815075949903368195511128895239120457672524000000/681384695121882013959665774575457025293276552134140462144317224809813638400658850960574519166869307475297566588656254581790292202187110433759810640316460147175047462827457254048717358546426320770069677796020553)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+52890088411386067353098208563585262678159500000/30208360982821581783994555050953960154213271+(40481724547356470692649144601937771039268490028626499664808222488691797969949419789064234167367280240928268259342281851919996962141648735601651130392215247466791700508312504011524885277423232843331946409690109670000/227128231707294004653221924858485675097758850711380154048105741603271212800219616986858173055623102491765855529552084860596764067395703477919936880105486715725015820942485751349572452848808773590023225932006851)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(2678348281139371555723909271234184333434675500548299051769808252786097247836288900815739032022684126717657250786035442663482053931191700379311865059006620147884684100740588533231767968715948121334498160716584222500/227128231707294004653221924858485675097758850711380154048105741603271212800219616986858173055623102491765855529552084860596764067395703477919936880105486715725015820942485751349572452848808773590023225932006851)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^5*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(209187707180630961271277913183528709505420646327532250194860662732467541160038654744834169410430074383172678880446267564651011059016367505660215268401694911324789622169072892833018445175333936311950288862630000/227128231707294004653221924858485675097758850711380154048105741603271212800219616986858173055623102491765855529552084860596764067395703477919936880105486715725015820942485751349572452848808773590023225932006851)*(Sum((1/11770331150627020149080202360082902699372)*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(523535499791350128074924716767952178882367709808448685316679583994261067006997156685366259009381971777096987814006534310615919280226090261317456433508236701320831360000/7518720788474877362827383453807053170640129528155108053173359004982102061508452404831537725157338351148203869490094379903743912404883699950456145751641337726513228981)*(Sum((1/11770331150627020149080202360082902699372)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6)), q(x) = (1742285929005218423983758259465108110633000/30208360982821581783994555050953960154213271)*_C2+(1742285929005218423983758259465108110633000/30208360982821581783994555050953960154213271)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(24206810370440812994341329984370692199769333343936689758159855600642916795576585161376507481230407779242291861604745803611530996408979752049543310866592216091705608358463839395584654998551248659301268728150912533279/227128231707294004653221924858485675097758850711380154048105741603271212800219616986858173055623102491765855529552084860596764067395703477919936880105486715725015820942485751349572452848808773590023225932006851000000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(124968326820648119281015987587725426628193959737517840884316853932228462259290285201046562415043778496036693673780211984235049358581759191587305332131726120242250656054556262943017652958002462305110255214996110729/2271282317072940046532219248584856750977588507113801540481057416032712128002196169868581730556231024917658555295520848605967640673957034779199368801054867157250158209424857513495724528488087735900232259320068510000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+21516060937433367122316207062443146255651/3776045122852697722999319381369245019276658875+(191005515365978257870187163339514433229830365340711845404191506804283296607590044727718242405582382042819357644872248888430550154160980301404906624147647714756807705903659887076891291698496504949900048368434661/56782057926823501163305481214621418774439712677845038512026435400817803200054904246714543263905775622941463882388021215149191016848925869479984220026371678931253955235621437837393113212202193397505806483001712750000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(1693719726846501435956880959958841300518575631880855453523190967886058375769593466584009439325998040997488794796616687594433609260398944787147156536459782237453137127884812012247244137311677923031947635768046508621/22712823170729400465322192485848567509775885071138015404810574160327121280021961698685817305562310249176585552955208486059676406739570347791993688010548671572501582094248575134957245284880877359002322593200685100000000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^5*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(17940925996936806583951247887267381554949866439134810717209797986703498652902681107272818322144571510641767514862964693335388659231282181718830929343597164133246230045998753678136207621829810228869368554197507/5678205792682350116330548121462141877443971267784503851202643540081780320005490424671454326390577562294146388238802121514919101684892586947998422002637167893125395523562143783739311321220219339750580648300171275000000)*(Sum((1/11770331150627020149080202360082902699372)*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(567908464939172961231355489036541402733737796850300111306273961529395913970149222452779196019005114242503159152996473899945144440561390253454895636664836039930583/1879680197118719340706845863451763292660032382038777013293339751245525515377113101207884431289334587787050967372523594975935978101220924987614036437910334431628307245250000)*(Sum((1/11770331150627020149080202360082902699372)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6)), s(x) = -(3918813159698777715502166923069721158205512571/302083609828215817839945550509539601542132710000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(174620439239526835857404560179819737000000/30208360982821581783994555050953960154213271)*_C2-(174620439239526835857404560179819737000000/30208360982821581783994555050953960154213271)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(1714034799793319944095413685187634877345/30208360982821581783994555050953960154213271)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+2283212101460462861926073342355455735633/1208334439312863271359782202038158406168530840+(48439812575068172788774336960670460032103/60416721965643163567989110101907920308426542000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(277641280305013695575983750655335856629533429/30208360982821581783994555050953960154213271000000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^5*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(2942582787656755037270050590020725674843/7552090245705395445998638762738490038553317750000)*(Sum((1/11770331150627020149080202360082902699372)*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6)), u(x) = (1396606031141676012295170523175575548697397202166854601195992097744510459116360160456528214680283141976748172638290955133705525806193943772871697031526477895014238932800197609019868735240810708264200248314429817053947/27255387804875280558386630983018281011731062085365618485772688992392545536026354038422980766674772299011902663546250183271611688087484417350392425612658405887001898513098290161948694341857052830802787111840822120000000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(133893006950646474560943347871601514548450/30208360982821581783994555050953960154213271)*_C2-(133893006950646474560943347871601514548450/30208360982821581783994555050953960154213271)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(150210905771987315113287445716725747921352793513353432325254435815960237730402486565670340566270953708994816244770944321344720014098949574807054853803795775055176243504044545483355347907596212687529677460313078735203/272553878048752805583866309830182810117310620853656184857726889923925455360263540384229807666747722990119026635462501832716116880874844173503924256126584058870018985130982901619486943418570528308027871118408221200000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+951827418419631732876275586583649251867507/75520902457053954459986387627384900385533177500+(1845963057184294273759808752170530589094942068928956702270071698704239458298771666829595058878468747392052113718820431088429483970489703306684764204293985293969782966908841606633432317076148546679077753100868525957/4542564634145880093064438497169713501955177014227603080962114832065424256004392339737163461112462049835317110591041697211935281347914069558398737602109734314500316418849715026991449056976175471800464518640137020000000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(34847750890571220206222829902351407058377341199953006575361497114702337546335619195223288387017503082911181105526586395216849660727759673783044487705413148182890926215183091560305177049808326663105999610584089860751/908512926829176018612887699433942700391035402845520616192422966413084851200878467947432692222492409967063422118208339442387056269582813911679747520421946862900063283769943005398289811395235094360092903728027404000000000)*(Sum(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^5*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))+(370616025485372668039212908146602025322743515823542234470990594822792066449993618545567836950078501842998473681692784903269547857346337826299216974936579616784212669927765049685708895750207394302198529444637217/227128231707294004653221924858485675097758850711380154048105741603271212800219616986858173055623102491765855529552084860596764067395703477919936880105486715725015820942485751349572452848808773590023225932006851000000000)*(Sum((1/11770331150627020149080202360082902699372)*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6))-(1309734104967104168977128612980451194819550004115195374649919013159989148829122160704374955136332658860059361006314282684980503286005821583895872707371778109258609723/75187207884748773628273834538070531706401295281551080531733590049821020615084524048315377251573383511482038694900943799037439124048836999504561457516413377265132289810000000)*(Sum((1/11770331150627020149080202360082902699372)*(277641280305013695575983750655335856629533429*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^4+24219906287534086394387168480335230016051500*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^3-391881315969877771550216692306972115820551257100*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)^2-1714034799793319944095413685187634877345000000*RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)+30033740543582054948137150490774140417213271000000)*exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6)), w(x) = _C1+_C2*x+Sum(exp(RootOf(11770331150627020149080202360082902699372*_Z^6-277641280305013695575983750655335856629533429*_Z^4-24219906287534086394387168480335230016051500*_Z^3+391881315969877771550216692306972115820551257100*_Z^2+1714034799793319944095413685187634877345000000*_Z-30033740543582054948137150490774140417213271000000, index = _a)*x)*_C[_a], _a = 1 .. 6)}
(68)
dsolve({bc, f})
Download me-equations-1.mw
-683554.1849*Pi
A__02 := 0
-1079.907024*Pi
-44089.46976*Pi
0.2638295324e11*Pi
A__06 := 0
315713169.4*Pi
177042773.7*Pi
A__11 := 0
130476150.5*Pi
370819.1716*Pi
363209840.8*Pi
133209.6563*Pi
513441.9298*Pi
(14)
256720.9650*Pi
(15)
256720.9650*Pi
(16)
-412487.9810*Pi
(17)
-39934.37232*Pi
(18)
-0.1955745297e-1*Pi
(19)
0.5587843706e-2*Pi
(20)
0.4304557420e-1*Pi
(21)
A__27 := 0
417411924.8*Pi
(23)
3215504392.*Pi
(24)
64476862.84*Pi
(25)
260952301.0*Pi
(26)
A__33 := 0
A__34 := 0
-0.1545526361e-2*Pi
(29)
-.2281415432*Pi
(30)
0.1506998916e11*Pi
(31)
2920855.252*Pi
(32)
0.3563472822e11*Pi
(33)
1233249.995*Pi
(34)
8659447618.*Pi
(35)
.1159229936*Pi
(36)
-5999289.724*Pi
(37)
5413603800.*Pi
(38)
1460427.626*Pi
(39)
I__10 := 0
2920855.252*Pi
(41)
4219013.140*Pi
(42)
1233249.995*Pi
(43)
9976343.380*Pi
(44)
-227177.6306*Pi
(45)
-.6143918658*Pi
(46)
-9534.298223*Pi
(47)
0.1868000000e11*Pi
(48)
60000000.00*Pi
(49)
-.4556919660*Pi
(50)
(51)
(52)
(53)
(54)
(55)
(56)
b1 := u(0.5e-1) = 0
u(0.5e-1) = 0
(57)
b2 := s(0.5e-1) = 0
s(0.5e-1) = 0
(58)
b3 := w(0.5e-1) = 0
w(0.5e-1) = 0
(59)
b4 := q(0.5e-1) = 0
q(0.5e-1) = 0
(60)
b5 := p(0.5e-1) = 0
p(0.5e-1) = 0
(61)
b6 := p(.25) = 10
p(.25) = 10
(62)
(63)
(64)
(65)
(66)
(67)
dsolve({f})
(68)
dsolve({bc, f})
h
I can't for the life of me figure out how to do something which seems so simple.
I want to plot eigenvalues 2ℏ2 and 6ℏ2 with probabilities of 1/2 each on a histogram. That is, have the bottom of the histogram read the two discrete eigenvalues and the vertical axis read the probability.
How would I code this? I tried several times and got errors about the Histogram command expecting different data or being unable to interpret the input.
Thanks for helping with this seemingly simple request.
What's wrong here?
restart; with(PDEtools); PDE2 := diff(u(x, y, t), t$2) = diff(u(x, y, t), x$2)+diff(u(x, y, t), y$2); IBC2s := u(x, 0, t) = 0, u(x, 2, t) = 0, u(0, y, t) = 0, u(4, y, t) = 0, u(x, y, 0) = (.1*(-x^2+4*x))*(-y^2+2*y), (D[3](u))(x, y, 0) = 0; Sol2 := pdsolve({IBC2s, PDE2}); build(Sol2);
Error, invalid input: PDEtools:-build uses a 1st argument, ANS (of type {`=`, PDESolStruc}), which is mis
I need a mathematical system that finds the value of k that gives the z value bigger (for loop inside the slider). Moving the slider would seem  k=0.80621762 that give z: 2517.701824
k.mw
The for Statement calculates this mathematical sequence:
a=100
b=10
1)c=a-b
2)d=c*2-k2; k2=(b*2)
3)e=d*2-k3;k3=k2*2
4)f=e*2-k4;k4=k3*2
30) (...)
z=c+d+e+f+(...)
z=?
The paramiter 2 is k (i have to find the value that give me the maximum of z).
Hi, I have a procedure written on several lines on a worskheet in 2D. When I type shift+enter to insert a blank line at some place of the procedure, the blank line does not appear at the cursor, but at the end of the procedure.
This is annoying since I cannot add a line to make "readable" modifications in the procedure !
I am on LInux Fedora 26. Many thanks.
Hi I am getting this message while soliving my first order non-linear initial value problem.
please share me your thoughts
ode := dsolve({diff(y(x), x)-2*(diff(y(x), x))^3 = -2*x+2, y(0) = 1}, type = numeric, range = 0 .. .24);
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
Abbas
I have to first plot the some point like (-1,4), (0,3), (1,4) etc. and then I wish to know how I can connect them with a line.
I have to generate a random list of 30 elements and i have two variables: s, which is a counter for all the list which have got at least a repetition and variable n, for each list who has not repeated values, as in the code below.
I don't understand why, when i sum s and m i get a value which is not 100, why?
for i by 1 to 100 do
		list:=RandomTools[Generate](list(integer(range = 1 .. 365), 30));
		if numelems(FindRepetitions(lista)) >= 1 then
			s:=s+1;
		else		n:=n+1;
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
S[lambda] := sum(S[b]*lambda^b, b = 0 .. m); L[lambda] := sum(L[b]*lambda^b, b = 0 .. m); G[lambda] := subs(S(t) = S[lambda], G); G[lambda] := subs(L(t) = L[lambda], G[lambda]); G := G[lambda]; s := expand(G, lambda); ft := unapply(s, lambda); for i from 0 while i <= m do A1[i] := ((D@@i)(ft))(0)/factorial(i); print(A[i] = A1[i]) end do
A[0] = S[0]*L[0]
A[1] = L[0]*S[1]+L[1]*S[0]
A[2] = L[0]*S[2]+L[1]*S[1]+L[2]*S[0]
A[3] = L[0]*S[3]+L[1]*S[2]+L[2]*S[1]+L[3]*S[0]
A[4] = L[0]*S[4]+L[1]*S[3]+L[2]*S[2]+L[3]*S[1]+L[4]*S[0]
A[5] = L[0]*S[5]+L[1]*S[4]+L[2]*S[3]+L[3]*S[2]+L[4]*S[1]+L[5]*S[0]
A[6] = L[0]*S[6]+L[1]*S[5]+L[2]*S[4]+L[3]*S[3]+L[4]*S[2]+L[5]*S[1]+L[6]*S[0]
A[7] = S[5]*L[2]+S[2]*L[5]+S[1]*L[6]+S[0]*L[7]+S[4]*L[3]+S[3]*L[4]+S[6]*L[1]+S[7]*L[0]
A[8] = S[2]*L[6]+S[0]*L[8]+S[8]*L[0]+S[4]*L[4]+S[1]*L[7]+S[3]*L[5]+S[6]*L[2]+S[5]*L[3]+S[7]*L[1]
A[9] = S[6]*L[3]+S[9]*L[0]+S[4]*L[5]+S[2]*L[7]+S[3]*L[6]+S[8]*L[1]+S[0]*L[9]+S[1]*L[8]+S[7]*L[2]+S[5]*L[4]
A[10] = S[0]*L[10]+S[10]*L[0]+S[1]*L[9]+S[6]*L[4]+S[7]*L[3]+S[3]*L[7]+S[2]*L[8]+S[4]*L[6]+S[9]*L[1]+S[5]*L[5]+S[8]*L[2]
s[n+1] := (1-f)*alpha*(int(v__n, t = 0 .. t))-beta*c*(int(A__n, t = 0 .. t))-(`&theta;__1`+a+Pi)*(int(s__n, t = 0 .. t))
v[n+1] := `&theta;__1`*(int(s__n, t = 0 .. t))-((1-f)*alpha+f*`&theta;__2`+a+Pi)*(int(v__n, t = 0 .. t))
e[n+1] := `&beta;c`*(int(A__n, t = 0 .. t))-(delta+a+Pi)*(int(e__n, t = 0 .. t))
i[n+1] := delta*(int(e__n, t = 0 .. t))-(eta+a+Pi)*(int(i__n, t = 0 .. t))
r[n+1] := eta*(int(i__n, t = 0 .. t))+`f&theta;__2`*(int(v__n, t = 0 .. t))-(a+Pi)*(int(r__n, t = 0 .. t))
for n from 0 to 4 do  end do
(1-f)*alpha*v__n*t-beta*c*s__0*i__0*t-(`&theta;__1`+a+Pi)*s__n*t
"for n:=0, n=1, n=2, n=3, n=4:  `s__1, ``s__2__`, `s__3, ``s__4`,  `i__1`, `i__2, ``i__3`, `i__4`,   `r__1`, `r__2`, `r__3, ``r__4`:"
Error, unterminated for loop
"for n:=0, n=1, n=2, n=3, n=4:  `s__1, ` `s__2__`, `s__3, __3__, s__4`, `i__1__`, `i__2, ` `i__3`, `i__4`, `r__1`, `r__2`, `r__3, ` `r__4`:"
"and s(t)=`s__1_`+`s__2 __`+ `s__3, `+`s__4`,"
i(t) = i__1+`i__2, `+i__3+i__4, r(t) = r__1+r__2+r__3_+r__4
"but A[n]:=(1)/(n!) [((&DifferentialD;)^(n))/(&DifferentialD; lambda^(n)) ((&sum;)`s__k`lambda^(k))((&sum;)`i__k`lambda^(k)) ]() ? ()|() ? (lambda=0)"
Error, missing numerator
Typesetting:-mambiguous(Typesetting:-mrow(Typesetting:-mi("but", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("&InvisibleTimes;", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-msub(Typesetting:-mi("A", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mi("n", fontstyle = "italic", mathcolor = "#c800c8", mathvariant = "italic", placeholder = "true"), subscriptshift = "0"), Typesetting:-mo("&Assign;", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mfrac(Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mi("n", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("&excl;", accent = "false", fence = "false", largeop = "false", lspace = "0.1111111em", mathvariant = "normal", movablelimits = "false", rspace = "0.1111111em", separator = "false", stretchy = "false", symmetric = "false")), bevelled = "false", denomalign = "center", linethickness = "1", numalign = "center"), Typesetting:-mo("&InvisibleTimes;", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfrac(Typesetting:-msup(Typesetting:-mo("&DifferentialD;", accent = "unset", fence = "unset", largeop = "unset", lspace = "0.0em", mathvariant = "normal", movablelimits = "unset", rspace = "0.0em", separator = "unset", stretchy = "unset", symmetric = "unset"), Typesetting:-mi("n", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0"), Typesetting:-mrow(Typesetting:-mo("&DifferentialD;", accent = "unset", fence = "unset", largeop = "unset", lspace = "0.0em", mathvariant = "normal", movablelimits = "unset", rspace = "0.0em", separator = "unset", stretchy = "unset", symmetric = "unset"), Typesetting:-mo("&InvisibleTimes;", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-msup(Typesetting:-mi("&lambda;", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mi("n", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0")), bevelled = "false", denomalign = "center", linethickness = "1", numalign = "center"), Typesetting:-mo("&InvisibleTimes;", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-munderover(Typesetting:-mo("&sum;", accent = "unset", fence = "unset", largeop = "true", lspace = "0.0em", mathvariant = "normal", movablelimits = "true", rspace = "0.1666667em", separator = "unset", stretchy = "true", symmetric = "unset"), Typesetting:-mrow(Typesetting:-mi("k", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("&equals;", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("0", mathvariant = "normal")), Typesetting:-mn("4", mathvariant = "normal"), accent = "false", accentunder = "false"), Typesetting:-mi("`s__k`"), Typesetting:-msup(Typesetting:-mi("&lambda;", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mi("k", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0")), mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-munderover(Typesetting:-mo("&sum;", accent = "unset", fence = "unset", largeop = "true", lspace = "0.0em", mathvariant = "normal", movablelimits = "true", rspace = "0.1666667em", separator = "unset", stretchy = "true", symmetric = "unset"), Typesetting:-mrow(Typesetting:-mi("k", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("&equals;", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("0", mathvariant = "normal")), Typesetting:-mn("4", mathvariant = "normal"), accent = "false", accentunder = "false"), Typesetting:-mi("`i__k`"), Typesetting:-msup(Typesetting:-mi("&lambda;", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mi("k", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0")), mathvariant = "normal"), Typesetting:-mo("&InvisibleTimes;", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false")), open = "&lsqb;", close = "&rsqb;", mathvariant = "normal"), Typesetting:-mfrac(Typesetting:-mambiguous(Typesetting:-merror("?"), Typesetting:-merror("missing numerator")), Typesetting:-mphantom(Typesetting:-mrow(Typesetting:-mi("x", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("&equals;", accent = "unset", fence = "unset", largeop = "unset", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "unset", rspace = "0.2777778em", separator = "unset", stretchy = "unset", symmetric = "unset"), Typesetting:-mi("a", fontstyle = "italic", mathvariant = "italic")), constraints = "height-only"), bevelled = "false", denomalign = "center", linethickness = "0", numalign = "center"), Typesetting:-mo("&verbar;", accent = "unset", fence = "unset", largeop = "unset", lspace = "0.1111111em", mathvariant = "normal", movablelimits = "unset", rspace = "0.1111111em", separator = "unset", stretchy = "true", symmetric = "unset"), Typesetting:-mfrac(Typesetting:-mphantom(Typesetting:-mi("f(x)", fontstyle = "italic", mathvariant = "italic"), constraints = "height-only"), Typesetting:-mrow(Typesetting:-mi("&lambda;", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mo("&equals;", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("0", mathvariant = "normal")), bevelled = "false", denomalign = "center", linethickness = "0", numalign = "center")))
"Pls how can I write this Maple code to help me generate `s__1` ,`s__2__ _` ` ___` `s__3 `,`s__4` ; `i__1 `, `i__2__` ,`i__3 `, `i__4`  and `r__1 `, `r__2` , `r__3 `,`r__4`  and finally generate                       "
"s(t)=`s__1_`+`s__2 __`+ `s__3, `+`s__4`,"
"i(t)=`i__1`+ `i__2, `+`i__3`+ `i__4`,   r(t)= `r__1`+ `r__2`+ `r__3_`+`r__4`:  "?""
Download Adomian.Elisha2.mw
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
with(student)
G := S(t)*L(t)
S(t)*L(t)
m := 10
A[0] = S[0]*L[0]
I'am new to Maple and have some very basic questions. Maple can figure out that the exponential is positive.
> is(exp(x)>0) assuming x::real;
But it cannot figure out that a sum of exponentials is positive too:
> is(sum(exp(x*i),i=1..N)>0) assuming x::real,N::integer,N>1;
                                     FAIL
What am I doing wrong? Moreover, what's wrong with this statement:
> is(ln(a+b)-ln(a)=ln(1-b/a)) assuming a::real,b::real,a>0,b>0,b<a;
                                     FAIL
Finally, is there a way to declare a generic fuction f and assume that its image is always a positive real?
Nico
First 1023 1024 1025 1026 1027 1028 1029 Last Page 1025 of 2460
