I am looking for a numerical solver for a parabolic PDE (up to 2nd order derivatives but no mixed ones) on the spatio-temporal domain [X x Y x T], either as an external package or as MAPLE code.
I have coded the method of lines on the domain [X x T] and indeed also used pdsolve as a check for that case. However, pdsolve (numerical) cannot solve the PDEs on the domain [X x Y x T].  The run times and memory requirements for the latter case would of course be significantly greater.
I am about to code up the method of lines (in MAPLE) on the domain [X x Y x T], but am wondering whether there exist external FORTRAN or C code packages that would be faster if called up in MAPLE and whose results would then be post-pocessed in MAPLE.
Does anyone have any suggestions?
MRB
when trying to solve my equation I always get this error-message:
Error, (in DEtools/convertsys) invalid input: degree expects 1 or 2 arguments, but received 3
To solve, I use this one:
Anfangsbed := phi(0) = 0,  D(phi)(0) = 10;
Einst :=             range = 0..10,            #Integrationsgrenzen
                     relerr = 1e-3,            #Toleranz zur Bestimmung der Integrationsschrittweite
                     optimize = true,          #Optimierung der DGL
                     maxfun = 0,               #Anzahl der Integrationsschritte -- 0 = keine Obergrenze
                     output = operator,        #Lösungsfunktionausgabe: damit Definition als Funktion möglich
                     stiff = true:
Lösung_Bewgl := dsolve({Bewegungsgl_mit_Para, Anfangsbed}, numeric, Einst);
The equation to solve is this one: http://imgur.com/a/SFxI8
What am I doing wrong?
Edit:
This is the worksheet, problem is the last point.
WS.mw
hello,
I am trying to solve a set of equations using solve but it didn't get me any answer !
> eq1 := x[1]-x[2] = 0;
> eq2 := -x[1]+2*x[2]-x[3] = 0;
> eq3 := -x[2]+2*x[3]-x[4] = 0;
> eq4 := -x[3]+x[4]-t = 0;
> solve({eq1, eq2, eq3, eq4}, {x[1], x[2], x[3], x[4]});
there is no error massage or anything.
any help?
thank you,
Mahdi
Please help me to solve numerically and visualise the following time-delayed integro-differential equation (see also the file attached)
diff(x(t), t$2) = .8/(x(t)^3*exp((2*0.1e-1)*(int(1/x(t), t = 0 .. t-tau))))-1/x(t)^2 ,
with the initial conditions x(0) = 1, (D(x))(0) = 0, and tau=0.1 (variable parameter).
The expected solution is an oscillatory function.
Thanks for your time and advice!
IDE.mw
hi--how i can solve following equation?
Eq.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Eq.mw .
Download Eq.mw
I've implemented the optimal taxation model proposed in this paper using Maple.
But it never stops running and get stuck in the last line for integral computation. Any idea of what's wrong with that?
This is the last line:
Here is the full code.
How to find infinitesimals of a system of pdes? I can find out for a single pde but not able able to solve for system of pdes with several dependent and independent variables. Can anyone please provide me the code for that or give some clue. Thanks
I have a task. Draw a cylinder of a certain diameter and length. And there is a table of values with points inside this cylinder. How to display the points inside the cylinder (the table of values has 3 parameters - angle (sin (a)), radius (R), length?
I am trying to do fsolve in a range (-7..14), however, it gives no solution.
But when I solve the same equations with solve (after removing all the Imaginary solutions), I get two results, one of them is in the range (-7..14).
I even expanded the range of fsolve, say (-10..20), but still got no solution...
This is just getting weirder and weirder. Attached kindly find the Maple file, note that the first solve takes about 1 minute (on my laptop: CPU i7 + MEM 8G + SSD).
fsolve_In_Range.mw
i have a Problem with maple. I have written this simple procedure
myPi_1:=proc(r)
local i,l;
l:=0;
for i from 1 to floor(r) do
    if isprime(i) and (i mod 4 = 1) then
        l:=l+1;
return l;
When i use it like this
k := myPi_1(80);
it works
But when i triy to plot it
plot(myPi_1(t), t = 0 .. 500, numpoints = 500, thickness = 2, color = black);
i get this message
Warning, expecting only range variable t in expression myPi_1(t) to be plotted but found name myPi_1
And no plot
Thank you for any Help
I want to calculate the following integral numerically with required precision.
First, the functions are defined:
G1:=-0.9445379894;
f:= (x) -> 0.9/abs(x-0.4)^(1/3)+0.1/abs(x-0.6)^(1/2);
U1 := unapply(-exp(-x)*(evalf(Int(f(t)*exp(t), t = 0 .. x))+G1)/2-exp(x)*(evalf(Int(f(t)*exp(-t), t = 0 .. x))+G1)/2, x);
U:= unapply(-exp(x)/2*(evalf(Int(f(t)*exp(-t),t=0..x))+G1)+exp(-x)/2*(evalf(Int(f(t)*exp(t),t=0..x))+G1), x);
Next, I calculate the integral in numerical form:
evalf(Int(U1(x)^2+U(x)^2-2*f(x)*U(x), x=0..1, digits=4, method = _Gquad));
If I specify digits=4, Maple return the answer -0.4291
If I use digits=5 or larger, Maple return someting like this
Is it possible to increase precision of calculation?
Please help me on this :
restart; with(PDETools), with(plots)
n := .3:
Eq1 := (1-n)*(diff(f(x, y), `$`(y, 3)))+(1+x*cot(x))*f(x, y)*(diff(f(x, y), `$`(y, 2)))-(diff(f(x, y), y))/Da+(diff(f(x, y), y))^2+n*We*(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), `$`(y, 3)))+sin(x)*(theta(x, y)+phi(x, y))/x = x*((diff(f(x, y), y))*(diff(f(x, y), y, x))+(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), x))):
Eq2 := (diff(theta(x, y), `$`(y, 2)))/Pr+Nt*(diff(theta(x, y), y))^2/Pr+Nb*(diff(phi(x, y), y))*(diff(theta(x, y), y))/Pr+(1+x*cot(x))*f(x, y)*(diff(theta(x, y), y)) = x*((diff(f(x, y), y))*(diff(theta(x, y), x))+(diff(theta(x, y), y))*(diff(f(x, y), x))):
Eq3 := Nb*(diff(phi(x, y), `$`(y, 2)))/(tau*Pr)+Nt*(diff(theta(x, y), `$`(y, 2)))/(tau*Pr)+(1+x*cot(x))*f(x, y)*(diff(phi(x, y), y)) = x*((diff(f(x, y), y))*(diff(phi(x, y), x))+(diff(phi(x, y), y))*(diff(f(x, y), x))):
ValWe := [0, 5, 10]:
bcs := {Nb*(D[2](phi))(x, 0)+Nt*(D[2](theta))(x, 0) = 0, f(0, y) = ((1/12)*y)^2*(6-8*((1/12)*y)+3*((1/12)*y)^2), f(x, 0) = 0, phi(0, y) = -.5*y, phi(x, 12) = 0, theta(0, y) = (1-(1/12)*y)^2, theta(x, 0) = 1, theta(x, 12) = 0, (D[2](f))(x, 0) = Da^(1/2)*(D[2, 2](f))(x, 0)+Da*(D[2, 2, 2](f))(x, 0), (D[2](f))(x, 12) = 0}:
pdsys := {Eq1, Eq2, Eq3}:
p1 := ans[1]:-plot(theta(x, y), x = 1, color = blue):
plots[display]({p1, p2, p3})
Download untitle_2_(1).mw
S[1] := .51-.67030*t+.4644645000*t^2-.2542824350*t^3+.1337509523*t^4
S[2] := .29-.37330*t+.2539795000*t^2-.1337383850*t^3+0.6737783824e-1*t^4
S[3] := 0.6e-1-0.6280e-1*t+0.3392700000e-1*t^2-0.7715060000e-2*t^3-0.2012235525e-2*t^4
V[1] := .14+.18480*t-.3482570000*t^2+.2511604200*t^3-.1217312553*t^4
V[2] := .37-0.9810e-1*t-.1638085000*t^2+.1665366350*t^3-0.8847577175e-1*t^4
V[3] := .59-.36870*t+0.126205000e-1*t^2+0.8559214500e-1*t^3-0.5666617885e-1*t^4
Iota[1] := 0.8e-1-.1000*t+0.6280600000e-1*t^2-0.2652762667e-1*t^3+0.8545290360e-2*t^4:
E[1] := 0.2040e-2*t-0.3584600000e-2*t^2+0.3405427000e-2*t^3-0.2270144502e-2*t^4:
R[n] := 0.5e-1+0.715e-1*t-0.1627750000e-1*t^2-0.3034627500e-1*t^3+0.2606816769e-1*t^4:
> Pls let someone help me plot S1;S2,S3 using Maple.
Download FINAL_RESULT.mw
To select a piece from a list, for example:
lst:=[1,2,3,4,5,6]
I want to get the list piece from second place to fifth place: [2,3,4,5].
Is there a function?
How do cylinder (3D plot) from Excel file(csv)?
I have table in the Excel:
Angel(A)  length(cylinder) Function(sin(A)*EXP(1-L/1000)
1                 5                          0,05
2               10                          0,1
360         1000                      0
Please help me..
First 1022 1023 1024 1025 1026 1027 1028 Last Page 1024 of 2463
