I have a list of coefficients each assigned a triple of indices. E.g. CF_{x,y,z}. These indicies are also able to take other values between +-2. E.g. CF_{x+2,y-1,z} or CF_{x,y-2,z+1} as examples. I have a working loop that cycles through the list of these coefficients and I am able to call a particular one by specifying the triple of indicies. This script has been attached:
triple_index_script.mw
I would like to modify this script to have more control over single indexes. As an example, say I want to add up all the coefficients which have z as a subscript (so not z+1,z-2 etc...) and I don't care what the x and y subscripts are; I want to be able to call that sum using the same notation in the script but with a single index. e.g. (using a new example function called RR_MapZ):
RR_MapZ[0]; ## This would return the sum of all coefficients that had z in their subscript
and this would return the sum of all the coefficients which have subscript Z. If I wanted to add up all the coefficients which had index Z+1 I would do:
RR_MapN[1]; ## This would return the sum of all coefficients that had z+1 in their subscript
What would be the most efficient way to do this?
-Yeti
Is there a command in Maple to produce a table of z values given F(z) where F is the CDF of the Standard Normal Distribution? I know of the command ProbabilityTable to generate a table of z, F(z) values.  What I would really like is F, Inv(F) table of values. I guess  I could write my own code to do this but was wondering if there is an easier way to do this.
How can i convert each column of a matrix(30X10) in a list?
Hi everybody
In the attached file, when I run the code an error appears while calculating "omegaL1" parameter. The dimensions of the matrices are correct but the source of error is unknown to me. Can anyone help me?
R2_Link_2D.mw
a=100
b=10
1)c=a-b
2)d=c*2-k2; k2=(b*2)
3)e=d*2-k3;k3=k2*2
4)f=e*2-k4;k4=k3*2
30) (...)
z=c+d+e+f+(...)
z=?
I need a for Statement that calculates this mathematical sequence.
I'm trying to use subs to substitute an unknown variable with a number in a Matrix
My Matrix is called values and I have the following
change := f2:
subs(change = 5, values):
This does nothing but when I have the following, it works as expected (All f2 in the Matrix values are replaced with 5)
subs(f2,values):
I'm wondering if its trying to find and replace 'change'. If this is the case how can I get it to use whats assigned to the variable. (I've tried eval(change) but that doesn't work either)
Many thanks
Hi everybody,
Here is a very simple question :
I have two strictly positive reals r and s and the expression
a := r^2 – r*s + s^2
Obviously a is strictly positive too
But I’m not capable to prove this with Maple (2016, Windows 7), even after having declared r and s both positive which, I thought, would have prevent Maple to consider them as potentially complex.
I failed in using "is", "coulditbe", "use RealDomain ..." and so on
Totally distressed I tried to do something simpler ... which ultimately appeared still more upsetting
assume(r, ‘positive’):
coulditbe(r, ‘complex’) ;    # the answer is (surprising ?) true
I'm probably doing some mistake bigger than I but I don't find it !
Could you be compassionate enough to enlight me !!!
Mammoth thanks in advance
Is there any convenient tool to convert Maple worksheet to Matlab m file, until today?
hello i was wondering is it possible to find the standard error of the coefficents in the NonlinearFit function within the statistical package? or in any other package for that matter?
does someone have angorithme that can find it?
i've searched around the internet and it does not seem like maple employs this function at all?
hope someone can help:)
HI,
I would like to plot the ODE system in phase transition (3d)
I try this
var:={x1(t),x2(t),x3(t)}:
dsys:={diff(x1(t),t)=x1(t), diff(x2(t),t)=x2(t), diff(x3(t),t)=x3(t)};
   / d                  d                  d               \
  { --- x1(t) = x1(t), --- x2(t) = x2(t), --- x3(t) = x3(t) }
   \ dt                 dt                 dt              /
res:=dsolve(dsys);
  {x1(t) = _C3 exp(t), x2(t) = _C2 exp(t), x3(t) = _C1 exp(t)}
plot3d(res,x1(t)=0..1,x2(t)=0..1,axes=boxed,font=[1,1,18],view=[0..0.6,0..1,-5..0]);
This must have a simple answer but I have been unable to figure it out after many attempts.
I am trying to create a Clifford algebra, and then use the results in the multiplication table "MT". The multiplication table elements are correct as displayed, but I don't know how to access the results in the table (i.e. the products of the basis elements).  For example, trying to access the table results as matrix elements like MT[2,3] doesn't work, presumably because it is not a matrix. In other words, I need a matrix that contains the same information as the multiplication table.
DGsetup([x, y, z], M);
I12 := Matrix([[-1, 0, 0], [0, -1, 0], [0, 0, -1]]);
AD3b := AlgebraLibraryData("Clifford(3)", Cl3Q, quadraticform = I12);
DGsetup(AD3b, '[e0, e1, e2, e3, e12, e13, e23, e123]', '[omega]');
MT := MultiplicationTable(Cl3Q, "AlgebraTable");
hello, i have problem here.
> restart;
> with(linalg);
> NULL;
> fungsi1 := sum(d1[h]+b1[h], h = 1 .. 7);
> fungsi2 := sum(sum(d2[h, t]+b2[h, t], t = 1 .. 23), h = 1 .. 7);
> fungsi3 := sum(sum(d3[h, t]+b3[h, t], t = 1 .. 23), h = 1 .. 7);
> fungsi4 := sum(d4[k]+b4[k], k = 1 .. 3);
> fungsi := fungsi1+fungsi2+fungsi3+fungsi4;
> NULL;
> NULL;
> k1 := seq(sum(X[h, t], t = 1 .. 23) >= 9, h = 1 .. 6);
> k2 := seq(sum(Y[h, t], t = 1 .. 23) >= 2, h = 1 .. 6);
> k3 := seq(sum(Z[h, t], t = 1 .. 23) >= 2, h = 1 .. 6);
> NULL;
> k4 := seq(seq(X[h, t]+Y[h, t]+Z[h, t] <= 1, h = 1 .. 6), t = 1 .. 23);
> NULL;
> k5 := seq(seq(Z[h, t]+Z[h+1, t] <= 1, h = 1 .. 6), t = 1 .. 23);
> NULL;
> k6 := seq(sum(X[h, t]+Y[h, t]+Z[h, t], t = 1 .. 23) >= 5, h = 1 .. 7);
> k7 := seq(sum(X[h, t]+Y[h, t]+Z[h, t], t = 1 .. 23) <= 6, h = 1 .. 7);
> NULL;
> k8 := seq(sum(X[h, t], t = 1 .. 23)+b1[h]-d1[h] <= 15, h = 1 .. 6);
> k9 := seq(sum(Y[h, t], t = 1 .. 23)+b1[h]-d1[h] <= 4, h = 1 .. 6);
> k10 := seq(sum(Z[h, t], t = 1 .. 23)+b1[h]-d1[h] <= 4, h = 1 .. 6);
> NULL;
> k11 := seq(seq(Y[h, t]+Y[h+1, t]+b2[h, t]-d2[h, t] <= 1, t = 1 .. 23), h = 1 .. 6);
> NULL;
> k12 := seq(seq(Z[h, t]+Z[h+1, t]+b3[h, t]-d3[h, t] <= 1, t = 1 .. 23), h = 1 .. 6);
> NULL;
> k13 := sum(X[7, t], t = 1 .. 23)+b4[1]-d4[1] = 2;
> k14 := sum(Y[7, t], t = 1 .. 23)+b4[1]-d4[1] = 2;
> k15 := sum(Z[7, t], t = 1 .. 23)+b4[1]-d4[1] = 2;
> with(Optimization);
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize,
  NLPSolve, QPSolve]
> CodeTools:-Usage(LPSolve(fungsi, {k1, k10, k11, k12, k13, k14, k15, k2, k3, k4, k5, k6, k7, k8, k9}, assume = {integer, nonnegative}));
Error, (in Optimization:-LPSolve) no feasible point found for LP subproblem
why it can be? please i need help.
I have a list of univariate polynomials
P:=[x^2-7*x+10, x^2, x^2+2*x+1]
How do I get the gcd of all of these?
It doesn't like it when I do the following:
igcd(P)
any idea for my problem?
> k1 := sum(X[h, t], t = 1 .. 23) >= 9;
9 <= X[h, 1] + X[h, 2] + X[h, 3] + X[h, 4] + X[h, 5] + X[h, 6]
   + X[h, 7] + X[h, 8] + X[h, 9] + X[h, 10] + X[h, 11] + X[h, 12]
   + X[h, 13] + X[h, 14] + X[h, 15] + X[h, 16] + X[h, 17]
   + X[h, 18] + X[h, 19] + X[h, 20] + X[h, 21] + X[h, 22]
   + X[h, 23], h = 1 .. 6
why 'h' still 'h'. from my textbooks the formula must be like this :
hello, For the P, and A arrays which depend on i,j, it always gives me index out of range i dont know whats wrong, any help, and thank you
N:=4000;
g:=Array(0..N):
g[0]:=0:
g[1]:=-2.47:
g[2]:=-2.33:
g[3]:=0.205:
g[4]:=2.99:
g[5]:=2.66:
g[6]:=2.65:
g[7]:=2.59:
g[8]:=2.5:
g[9]:=2.42:
g[10]:=2.37:
g[11]:=2.37:
g[12]:=2.39:
g[13]:=2.42:
g[14]:=2.43:
g[15]:=2.42:
g[16]:=2.4:
g[17]:=2.39:
g[18]:=2.39:
g[19]:=2.39:
g[20]:=2.38:
g[21]:=2.37:
g[22]:=2.36:
g[23]:=2.35:
g[24]:=2.34:
g[25]:=2.34:
g[26]:=2.34:
g[27]:=2.35:
g[28]:=2.37:
g[29]:=2.38:
g[30]:=2.4:
g[31]:=2.41:
g[32]:=2.41:
g[33]:=2.4:
g[34]:=2.4:
g[35]:=2.4:
g[36]:=2.4:
g[37]:=2.4:
g[38]:=2.39:
g[39]:=2.36:
g[40]:=2.32:
g[41]:=2.29:
g[42]:=2.29:
g[43]:=2.35:
g[44]:=2.44:
g[45]:=2.53:
g[46]:=2.61:
g[47]:=2.68:
g[48]:=2.69:
g[49]:=2.59:
g[50]:=2.38:
g[51]:=2.13:
g[52]:=1.89:
g[53]:=1.68:
g[54]:=1.52:
g[55]:=1.55:
g[56]:=1.83:
g[57]:=2.26:
g[58]:=2.57:
g[59]:=2.56:
g[60]:=2.31:
g[61]:=2.12:
g[62]:=2.14:
g[63]:=2.36:
g[64]:=2.67:
g[65]:=2.94:
g[66]:=3.14:
g[67]:=3.27:
g[68]:=3.26:
g[69]:=3.03:
g[70]:=2.66:
g[71]:=2.41:
g[72]:=2.4:
g[73]:=2.55:
g[74]:=2.7:
g[75]:=2.75:
g[76]:=2.7:
g[77]:=2.54:
g[78]:=2.24:
g[79]:=1.84:
g[80]:=1.4:
g[81]:=0.959:
g[82]:=0.488:
g[83]:=-0.0341:
g[84]:=-0.501:
g[85]:=-0.776:
g[86]:=-0.866:
g[87]:=-0.959:
g[88]:=-1.28:
g[89]:=-1.9:
g[90]:=-2.68:
g[91]:=-3.42:
g[92]:=-3.84:
g[93]:=-3.72:
g[94]:=-3.22:
g[95]:=-2.66:
g[96]:=-2.26:
g[97]:=-1.99:
g[98]:=-1.73:
g[99]:=-1.38:
g[100]:=-1.14:
g[101]:=-1.3:
g[102]:=-1.92:
g[103]:=-2.8:
g[104]:=-3.81:
g[105]:=-4.84:
g[106]:=-5.75:
g[107]:=-6.53:
g[108]:=-7.28:
g[109]:=-8.12:
g[110]:=-8.86:
g[111]:=-9.17:
g[112]:=-8.96:
g[113]:=-8.51:
g[114]:=-7.96:
g[115]:=-7.17:
g[116]:=-6.13:
g[117]:=-5.21:
g[118]:=-4.77:
g[119]:=-4.31:
g[120]:=-2.46:
g[121]:=1.47:
g[122]:=6.76:
g[123]:=12:
g[124]:=15.4:
g[125]:=15.6:
g[126]:=13.2:
g[127]:=10.4:
g[128]:=8.38:
g[129]:=7.39:
g[130]:=6.55:
g[131]:=5.13:
g[132]:=3.07:
g[133]:=0.816:
g[134]:=-1.26:
g[135]:=-3.08:
g[136]:=-4.81:
g[137]:=-6.62:
g[138]:=-8.57:
g[139]:=-10.8:
g[140]:=-13.3:
g[141]:=-16.2:
g[142]:=-19.4:
g[143]:=-22.5:
g[144]:=-25.6:
g[145]:=-28.7:
g[146]:=-31.9:
g[147]:=-34.4:
g[148]:=-34.6:
g[149]:=-32:
g[150]:=-27.9:
g[151]:=-24.1:
g[152]:=-21.2:
g[153]:=-19.9:
g[154]:=-20.4:
g[155]:=-21.8:
g[156]:=-22.9:
g[157]:=-22.8:
g[158]:=-21.8:
g[159]:=-20.8:
g[160]:=-20.8:
g[161]:=-22.4:
g[162]:=-25.1:
g[163]:=-28.1:
g[164]:=-30.5:
g[165]:=-29.5:
g[166]:=-19.3:
g[167]:=1.66:
g[168]:=28:
g[169]:=51.6:
g[170]:=64.3:
g[171]:=63.9:
g[172]:=56.7:
g[173]:=50.9:
g[174]:=50.1:
g[175]:=52.3:
g[176]:=54:
g[177]:=53.3:
g[178]:=51.1:
g[179]:=49.5:
g[180]:=49.7:
g[181]:=50.9:
g[182]:=52.3:
g[183]:=53.3:
g[184]:=53.9:
g[185]:=53.7:
g[186]:=51.7:
g[187]:=47.8:
g[188]:=43:
g[189]:=38.4:
g[190]:=34.5:
g[191]:=30.7:
g[192]:=26.7:
g[193]:=22:
g[194]:=16.3:
g[195]:=9.68:
g[196]:=2.8:
g[197]:=-3.9:
g[198]:=-10.4:
g[199]:=-16.8:
g[200]:=-23.4:
g[201]:=-30.2:
g[202]:=-37.3:
g[203]:=-44.4:
g[204]:=-51.5:
g[205]:=-58.6:
g[206]:=-65.7:
g[207]:=-72.8:
g[208]:=-80:
g[209]:=-87.3:
g[210]:=-94.3:
g[211]:=-100:
g[212]:=-105:
g[213]:=-109:
g[214]:=-113:
g[215]:=-118:
g[216]:=-121:
g[217]:=-119:
g[218]:=-112:
g[219]:=-101:
g[220]:=-85.5:
g[221]:=-56.1:
g[222]:=-2.21:
g[223]:=63.7:
g[224]:=105:
g[225]:=103:
g[226]:=75.8:
g[227]:=51.8:
g[228]:=43.7:
g[229]:=46.7:
g[230]:=49.8:
g[231]:=45.7:
g[232]:=34.5:
g[233]:=20.4:
g[234]:=8.14:
g[235]:=-0.137:
g[236]:=-5.49:
g[237]:=-10.4:
g[238]:=-16.5:
g[239]:=-24.1:
g[240]:=-32.1:
g[241]:=-39.9:
g[242]:=-47.1:
g[243]:=-53.9:
g[244]:=-61.4:
g[245]:=-66.6:
g[246]:=-52.7:
g[247]:=-1.11:
g[248]:=70.1:
g[249]:=114:
g[250]:=109:
g[251]:=74.9:
g[252]:=44.3:
g[253]:=32.3:
g[254]:=33.8:
g[255]:=36.1:
g[256]:=30.6:
g[257]:=16.7:
g[258]:=-0.342:
g[259]:=-9.66:
g[260]:=1.07:
g[261]:=32.7:
g[262]:=69.1:
g[263]:=88.7:
g[264]:=84.5:
g[265]:=68:
g[266]:=54.6:
g[267]:=50.7:
g[268]:=53:
g[269]:=55.3:
g[270]:=53.3:
g[271]:=47.4:
g[272]:=40:
g[273]:=33.5:
g[274]:=28.5:
g[275]:=24.5:
g[276]:=20.6:
g[277]:=16.2:
g[278]:=11.3:
g[279]:=6.23:
g[280]:=1.22:
g[281]:=-3.65:
g[282]:=-7.83:
g[283]:=-8.87:
g[284]:=-4.33:
g[285]:=4.63:
g[286]:=14.4:
g[287]:=22.7:
g[288]:=29.4:
g[289]:=34.8:
g[290]:=37:
g[291]:=34.6:
g[292]:=29.4:
g[293]:=24.2:
g[294]:=20.5:
g[295]:=17.7:
g[296]:=14.7:
g[297]:=10.5:
g[298]:=5.18:
g[299]:=-0.647:
g[300]:=-6.32:
g[301]:=-11.6:
g[302]:=-16.5:
g[303]:=-21.7:
g[304]:=-25.6:
g[305]:=-23.5:
g[306]:=-11.1:
g[307]:=7.15:
g[308]:=19.6:
g[309]:=18.9:
g[310]:=8.58:
g[311]:=-2.33:
g[312]:=-8.51:
g[313]:=-10.4:
g[314]:=-11.4:
g[315]:=-14.4:
g[316]:=-19.9:
g[317]:=-26.7:
g[318]:=-33.4:
g[319]:=-39.3:
g[320]:=-44.4:
g[321]:=-49.6:
g[322]:=-53.8:
g[323]:=-49.2:
g[324]:=-28.9:
g[325]:=-4.53:
g[326]:=4.71:
g[327]:=-4.79:
g[328]:=-21.6:
g[329]:=-34.2:
g[330]:=-39.2:
g[331]:=-40.3:
g[332]:=-42.5:
g[333]:=-48:
g[334]:=-56.3:
g[335]:=-65.8:
g[336]:=-73:
g[337]:=-62.1:
g[338]:=-15:
g[339]:=49.3:
g[340]:=84:
g[341]:=72.5:
g[342]:=38.5:
g[343]:=11.1:
g[344]:=1.37:
g[345]:=2.99:
g[346]:=3.92:
g[347]:=-3.22:
g[348]:=-16.2:
g[349]:=-18.8:
g[350]:=6.13:
g[351]:=48:
g[352]:=75:
g[353]:=72.6:
g[354]:=53.2:
g[355]:=36:
g[356]:=30:
g[357]:=32.1:
g[358]:=34.8:
g[359]:=33.2:
g[360]:=26.7:
g[361]:=18.2:
g[362]:=10.4:
g[363]:=4.38:
g[364]:=2.37:
g[365]:=8.7:
g[366]:=20.5:
g[367]:=27.3:
g[368]:=24.6:
g[369]:=16.4:
g[370]:=9.09:
g[371]:=5.53:
g[372]:=4.69:
g[373]:=4.03:
g[374]:=1.66:
g[375]:=-2.77:
g[376]:=-8.32:
g[377]:=-13.8:
g[378]:=-18.6:
g[379]:=-22.6:
g[380]:=-24.2:
g[381]:=-21.2:
g[382]:=-13.8:
g[383]:=-5.19:
g[384]:=2.38:
g[385]:=8.13:
g[386]:=10.7:
g[387]:=8.33:
g[388]:=2.13:
g[389]:=-4.66:
g[390]:=-9.94:
g[391]:=-13.8:
g[392]:=-17.8:
g[393]:=-23:
g[394]:=-29.6:
g[395]:=-36.9:
g[396]:=-43.9:
g[397]:=-50.5:
g[398]:=-56.7:
g[399]:=-63.1:
g[400]:=-66.5:
g[401]:=-59:
g[402]:=-37.3:
g[403]:=-9.47:
g[404]:=9.1:
g[405]:=9.64:
g[406]:=-2.45:
g[407]:=-15.2:
g[408]:=-20.7:
g[409]:=-16.5:
g[410]:=-4.85:
g[411]:=7.56:
g[412]:=12.9:
g[413]:=8.73:
g[414]:=-0.484:
g[415]:=-8.54:
g[416]:=-12.7:
g[417]:=-14.3:
g[418]:=-15.8:
g[419]:=-18.8:
g[420]:=-23.5:
g[421]:=-29:
g[422]:=-34.5:
g[423]:=-39.6:
g[424]:=-44.3:
g[425]:=-48.8:
g[426]:=-53.4:
g[427]:=-58.3:
g[428]:=-63.5:
g[429]:=-68.9:
g[430]:=-73.7:
g[431]:=-76.4:
g[432]:=-76.5:
g[433]:=-75.5:
g[434]:=-74.9:
g[435]:=-74.7:
g[436]:=-72.9:
g[437]:=-68.3:
g[438]:=-57.3:
g[439]:=-28.8:
g[440]:=17.2:
g[441]:=53:
g[442]:=55.7:
g[443]:=33.2:
g[444]:=7.89:
g[445]:=-5.27:
g[446]:=-1.9:
g[447]:=15.4:
g[448]:=38.2:
g[449]:=57.3:
g[450]:=70.2:
g[451]:=80:
g[452]:=88.9:
g[453]:=93.4:
g[454]:=89.5:
g[455]:=79.8:
g[456]:=69.6:
g[457]:=61.7:
g[458]:=55.5:
g[459]:=49.1:
g[460]:=41.2:
g[461]:=31.3:
g[462]:=19.9:
g[463]:=7.78:
g[464]:=-4.19:
g[465]:=-15.6:
g[466]:=-26.6:
g[467]:=-37.6:
g[468]:=-49.1:
g[469]:=-61:
g[470]:=-68.7:
g[471]:=-60.1:
g[472]:=-29.1:
g[473]:=8.5:
g[474]:=27.2:
g[475]:=18.6:
g[476]:=-3.9:
g[477]:=-22.6:
g[478]:=-30.5:
g[479]:=-31.5:
g[480]:=-32.9:
g[481]:=-39:
g[482]:=-49.7:
g[483]:=-61.9:
g[484]:=-73.1:
g[485]:=-82.5:
g[486]:=-91.3:
g[487]:=-98:
g[488]:=-88.7:
g[489]:=-46.4:
g[490]:=19.2:
g[491]:=70.2:
g[492]:=79.6:
g[493]:=57.1:
g[494]:=31:
g[495]:=19.5:
g[496]:=22.2:
g[497]:=28.4:
g[498]:=29.3:
g[499]:=27.6:
g[500]:=35.1:
g[501]:=56.4:
g[502]:=79.4:
g[503]:=88:
g[504]:=79.8:
g[505]:=65.7:
g[506]:=55.8:
g[507]:=52.7:
g[508]:=52.7:
g[509]:=51.5:
g[510]:=47.1:
g[511]:=40.2:
g[512]:=32.7:
g[513]:=26.1:
g[514]:=20.6:
g[515]:=16.6:
g[516]:=17.3:
g[517]:=25.6:
g[518]:=39.1:
g[519]:=50.9:
g[520]:=54.8:
g[521]:=50.9:
g[522]:=44.7:
g[523]:=41:
g[524]:=40.2:
g[525]:=39:
g[526]:=34.8:
g[527]:=27.6:
g[528]:=19.5:
g[529]:=11.8:
g[530]:=4.68:
g[531]:=-0.0161:
g[532]:=9.3:
g[533]:=37.8:
g[534]:=65:
g[535]:=69.6:
g[536]:=54.1:
g[537]:=34.7:
g[538]:=23.1:
g[539]:=20.1:
g[540]:=20:
g[541]:=17.2:
g[542]:=10.2:
g[543]:=0.472:
g[544]:=-9.3:
g[545]:=-17.7:
g[546]:=-24.7:
g[547]:=-31:
g[548]:=-34.7:
g[549]:=-32.6:
g[550]:=-25:
g[551]:=-15.5:
g[552]:=-7.16:
g[553]:=-1.03:
g[554]:=1.54:
g[555]:=-1.08:
g[556]:=-7.59:
g[557]:=-14.6:
g[558]:=-19.9:
g[559]:=-23.7:
g[560]:=-27.6:
g[561]:=-32.4:
g[562]:=-38.3:
g[563]:=-44.7:
g[564]:=-50.8:
g[565]:=-56.5:
g[566]:=-61.9:
g[567]:=-67.4:
g[568]:=-71.8:
g[569]:=-71:
g[570]:=-61.1:
g[571]:=-44.7:
g[572]:=-27.7:
g[573]:=-14.2:
g[574]:=-6.32:
g[575]:=-5.46:
g[576]:=-9.79:
g[577]:=-14.9:
g[578]:=-17.9:
g[579]:=-18.8:
g[580]:=-18.7:
g[581]:=-17:
g[582]:=-12.3:
g[583]:=-5.34:
g[584]:=1.89:
g[585]:=7.48:
g[586]:=9.51:
g[587]:=7.82:
g[588]:=4.95:
g[589]:=3.97:
g[590]:=5.77:
g[591]:=8.87:
g[592]:=11.1:
g[593]:=11.1:
g[594]:=8.66:
g[595]:=5.36:
g[596]:=2.49:
g[597]:=-0.111:
g[598]:=-3.4:
g[599]:=-7.77:
g[600]:=-12.8:
g[601]:=-17.9:
g[602]:=-21.7:
g[603]:=-21.5:
g[604]:=-15.8:
g[605]:=-6.93:
g[606]:=1.75:
g[607]:=9.28:
g[608]:=15.2:
g[609]:=16.6:
g[610]:=11.8:
g[611]:=3.52:
g[612]:=-4.39:
g[613]:=-9.82:
g[614]:=-11.1:
g[615]:=-6.99:
g[616]:=0.81:
g[617]:=7.51:
g[618]:=8.73:
g[619]:=4.22:
g[620]:=-2.33:
g[621]:=-7.29:
g[622]:=-9.73:
g[623]:=-10.9:
g[624]:=-12.5:
g[625]:=-15.4:
g[626]:=-18.5:
g[627]:=-18:
g[628]:=-12:
g[629]:=-3.51:
g[630]:=3.22:
g[631]:=6.59:
g[632]:=6.58:
g[633]:=4:
g[634]:=0.643:
g[635]:=-1.98:
g[636]:=-3.5:
g[637]:=-3.73:
g[638]:=-2.21:
g[639]:=0.696:
g[640]:=3.58:
g[641]:=4.88:
g[642]:=4.02:
g[643]:=1.95:
g[644]:=0.0841:
g[645]:=-0.892:
g[646]:=-1.25:
g[647]:=-1.64:
g[648]:=-2.3:
g[649]:=-2.27:
g[650]:=0.0121:
g[651]:=4.64:
g[652]:=10.2:
g[653]:=15.2:
g[654]:=18.1:
g[655]:=17.1:
g[656]:=12.8:
g[657]:=8.43:
g[658]:=6.61:
g[659]:=7.11:
g[660]:=8.06:
g[661]:=7.98:
g[662]:=6.73:
g[663]:=4.88:
g[664]:=2.29:
g[665]:=-1.86:
g[666]:=-6.19:
g[667]:=-6.82:
g[668]:=-2.23:
g[669]:=4.36:
g[670]:=7.94:
g[671]:=6.53:
g[672]:=2.75:
g[673]:=0.394:
g[674]:=0.916:
g[675]:=3.2:
g[676]:=5.36:
g[677]:=6.23:
g[678]:=5.49:
g[679]:=3.49:
g[680]:=1.11:
g[681]:=-0.89:
g[682]:=-2.58:
g[683]:=-4.5:
g[684]:=-6.98:
g[685]:=-9.84:
g[686]:=-13:
g[687]:=-17.3:
g[688]:=-23.2:
g[689]:=-29.9:
g[690]:=-33.4:
g[691]:=-28.9:
g[692]:=-16.2:
g[693]:=-0.548:
g[694]:=11.9:
g[695]:=16.1:
g[696]:=11.8:
g[697]:=3.92:
g[698]:=-2.09:
g[699]:=-4.64:
g[700]:=-5.35:
g[701]:=-5.34:
g[702]:=-3.44:
g[703]:=1.12:
g[704]:=7.1:
g[705]:=12.9:
g[706]:=17.9:
g[707]:=20.8:
g[708]:=20:
g[709]:=15.5:
g[710]:=9.94:
g[711]:=5.28:
g[712]:=1.89:
g[713]:=-0.953:
g[714]:=-3.84:
g[715]:=-6.99:
g[716]:=-10.4:
g[717]:=-14:
g[718]:=-16.3:
g[719]:=-14.9:
g[720]:=-9.28:
g[721]:=-1.49:
g[722]:=5.8:
g[723]:=10.5:
g[724]:=10.9:
g[725]:=7.56:
g[726]:=3.53:
g[727]:=2.19:
g[728]:=4.12:
g[729]:=7.22:
g[730]:=8.73:
g[731]:=7.34:
g[732]:=3.96:
g[733]:=0.423:
g[734]:=-2.1:
g[735]:=-3.63:
g[736]:=-4.85:
g[737]:=-6.41:
g[738]:=-8.49:
g[739]:=-10.4:
g[740]:=-10.7:
g[741]:=-8.43:
g[742]:=-4.69:
g[743]:=-0.914:
g[744]:=1.41:
g[745]:=0.512:
g[746]:=-4.07:
g[747]:=-10.5:
g[748]:=-16.6:
g[749]:=-20.8:
g[750]:=-21.6:
g[751]:=-17.8:
g[752]:=-10.9:
g[753]:=-4.25:
g[754]:=-0.36:
g[755]:=0.405:
g[756]:=-0.0522:
g[757]:=0.143:
g[758]:=0.59:
g[759]:=-0.0456:
g[760]:=-1.35:
g[761]:=-2.32:
g[762]:=-3.25:
g[763]:=-5.04:
g[764]:=-7.79:
g[765]:=-10.9:
g[766]:=-13.9:
g[767]:=-16.6:
g[768]:=-19.2:
g[769]:=-21.4:
g[770]:=-22.1:
g[771]:=-20.8:
g[772]:=-18.3:
g[773]:=-15.9:
g[774]:=-14.6:
g[775]:=-15.7:
g[776]:=-19.7:
g[777]:=-25.4:
g[778]:=-30.2:
g[779]:=-30:
g[780]:=-22.8:
g[781]:=-14.2:
g[782]:=-10.1:
g[783]:=-10.1:
g[784]:=-8.82:
g[785]:=-3.18:
g[786]:=4.5:
g[787]:=10.1:
g[788]:=12.2:
g[789]:=12.4:
g[790]:=12.9:
g[791]:=14.3:
g[792]:=16:
g[793]:=17.2:
g[794]:=17.8:
g[795]:=18:
g[796]:=17.7:
g[797]:=17.5:
g[798]:=17.1:
g[799]:=14.8:
g[800]:=8.49:
g[801]:=-1.31:
g[802]:=-9.26:
g[803]:=-8.91:
g[804]:=-0.172:
g[805]:=11.3:
g[806]:=20.6:
g[807]:=25.1:
g[808]:=23.9:
g[809]:=18.5:
g[810]:=13.1:
g[811]:=11:
g[812]:=12:
g[813]:=13.8:
g[814]:=14.4:
g[815]:=13.6:
g[816]:=12.2:
g[817]:=10.8:
g[818]:=10.1:
g[819]:=9.88:
g[820]:=9.77:
g[821]:=9.73:
g[822]:=10.1:
g[823]:=10.9:
g[824]:=12:
g[825]:=12.9:
g[826]:=12.8:
g[827]:=11.2:
g[828]:=8.59:
g[829]:=5.79:
g[830]:=3.15:
g[831]:=0.335:
g[832]:=-2.89:
g[833]:=-6.47:
g[834]:=-10.1:
g[835]:=-12.9:
g[836]:=-14.1:
g[837]:=-14:
g[838]:=-13.7:
g[839]:=-13.8:
g[840]:=-14.3:
g[841]:=-14.7:
g[842]:=-14.6:
g[843]:=-14:
g[844]:=-13.3:
g[845]:=-12.7:
g[846]:=-11.8:
g[847]:=-10.4:
g[848]:=-8.32:
g[849]:=-6.42:
g[850]:=-5.85:
g[851]:=-6.9:
g[852]:=-8.74:
g[853]:=-10.5:
g[854]:=-11.6:
g[855]:=-5.92:
g[856]:=14.4:
g[857]:=41.3:
g[858]:=58.8:
g[859]:=62.2:
g[860]:=57:
g[861]:=50.2:
g[862]:=46.5:
g[863]:=46.3:
g[864]:=47.1:
g[865]:=46.6:
g[866]:=43.6:
g[867]:=38.9:
g[868]:=33.8:
g[869]:=29.3:
g[870]:=25.5:
g[871]:=22.2:
g[872]:=18.7:
g[873]:=15:
g[874]:=10.9:
g[875]:=6.83:
g[876]:=3.01:
g[877]:=0.584:
g[878]:=0.781:
g[879]:=3.23:
g[880]:=6.21:
g[881]:=8.11:
g[882]:=7.52:
g[883]:=3.9:
g[884]:=-1.48:
g[885]:=-6.5:
g[886]:=-9.18:
g[887]:=-8.13:
g[888]:=-4.42:
g[889]:=-2:
g[890]:=-4.7:
g[891]:=-12.3:
g[892]:=-21.4:
g[893]:=-28.9:
g[894]:=-34.5:
g[895]:=-39.3:
g[896]:=-45:
g[897]:=-52.1:
g[898]:=-60.5:
g[899]:=-67.7:
g[900]:=-61.7:
g[901]:=-28.7:
g[902]:=20.3:
g[903]:=52:
g[904]:=49.6:
g[905]:=26.3:
g[906]:=4.48:
g[907]:=-4.32:
g[908]:=0.198:
g[909]:=14.8:
g[910]:=32.6:
g[911]:=42.7:
g[912]:=39.9:
g[913]:=29.3:
g[914]:=19.6:
g[915]:=16.2:
g[916]:=19.8:
g[917]:=26.1:
g[918]:=27.6:
g[919]:=20.6:
g[920]:=8.04:
g[921]:=-4.76:
g[922]:=-15.5:
g[923]:=-25.5:
g[924]:=-36.5:
g[925]:=-49.2:
g[926]:=-62:
g[927]:=-67:
g[928]:=-55.8:
g[929]:=-32.3:
g[930]:=-12.7:
g[931]:=-8.4:
g[932]:=-16.1:
g[933]:=-23.6:
g[934]:=-21.6:
g[935]:=-10.7:
g[936]:=2.9:
g[937]:=13.6:
g[938]:=20.2:
g[939]:=24.9:
g[940]:=30:
g[941]:=36.1:
g[942]:=42.1:
g[943]:=46.6:
g[944]:=48.1:
g[945]:=44.5:
g[946]:=36.1:
g[947]:=25.7:
g[948]:=16.2:
g[949]:=8.28:
g[950]:=0.997:
g[951]:=-6.82:
g[952]:=-16:
g[953]:=-27.1:
g[954]:=-40.2:
g[955]:=-54.7:
g[956]:=-63.8:
g[957]:=-52.9:
g[958]:=-19.3:
g[959]:=14.4:
g[960]:=25.4:
g[961]:=14.7:
g[962]:=-1.59:
g[963]:=-10.3:
g[964]:=-9.55:
g[965]:=-4.89:
g[966]:=-2.44:
g[967]:=-5.39:
g[968]:=-14:
g[969]:=-25.6:
g[970]:=-33.6:
g[971]:=-28.9:
g[972]:=-9.55:
g[973]:=15.5:
g[974]:=32.1:
g[975]:=31.4:
g[976]:=17.4:
g[977]:=2.52:
g[978]:=-4.19:
g[979]:=-2.38:
g[980]:=2.19:
g[981]:=4.06:
g[982]:=1.51:
g[983]:=-4.48:
g[984]:=-12.1:
g[985]:=-19.1:
g[986]:=-24:
g[987]:=-26.5:
g[988]:=-28.2:
g[989]:=-30.4:
g[990]:=-32:
g[991]:=-30.8:
g[992]:=-26.5:
g[993]:=-20.5:
g[994]:=-14:
g[995]:=-7.2:
g[996]:=-1.6:
g[997]:=0.226:
g[998]:=-0.668:
g[999]:=0.785:
g[1000]:=7.5:
g[1001]:=16.9:
g[1002]:=22.5:
g[1003]:=19.6:
g[1004]:=10.1:
g[1005]:=-0.641:
g[1006]:=-8.79:
g[1007]:=-14.4:
g[1008]:=-18.8:
g[1009]:=-19.4:
g[1010]:=-12.2:
g[1011]:=-0.675:
g[1012]:=6.93:
g[1013]:=7.2:
g[1014]:=2.66:
g[1015]:=-1.49:
g[1016]:=-1.26:
g[1017]:=3.52:
g[1018]:=9.92:
g[1019]:=15:
g[1020]:=17.7:
g[1021]:=17.6:
g[1022]:=15.2:
g[1023]:=11.8:
g[1024]:=8.78:
g[1025]:=6.68:
g[1026]:=4.69:
g[1027]:=1.13:
g[1028]:=-4.71:
g[1029]:=-11.9:
g[1030]:=-19.1:
g[1031]:=-25.7:
g[1032]:=-31.9:
g[1033]:=-38.1:
g[1034]:=-43.5:
g[1035]:=-44.1:
g[1036]:=-37.2:
g[1037]:=-25:
g[1038]:=-11.5:
g[1039]:=1.13:
g[1040]:=11.8:
g[1041]:=17.8:
g[1042]:=16.5:
g[1043]:=9.72:
g[1044]:=4.57:
g[1045]:=8.11:
g[1046]:=21.2:
g[1047]:=37.1:
g[1048]:=45.9:
g[1049]:=42.2:
g[1050]:=29.9:
g[1051]:=16.9:
g[1052]:=8.27:
g[1053]:=3.56:
g[1054]:=-0.0378:
g[1055]:=-4.1:
g[1056]:=-8.68:
g[1057]:=-13.5:
g[1058]:=-18.2:
g[1059]:=-21.1:
g[1060]:=-19.5:
g[1061]:=-13.6:
g[1062]:=-6:
g[1063]:=0.0102:
g[1064]:=3.06:
g[1065]:=4.09:
g[1066]:=5.13:
g[1067]:=7.37:
g[1068]:=10.1:
g[1069]:=11.4:
g[1070]:=10.6:
g[1071]:=9.51:
g[1072]:=10.7:
g[1073]:=14.6:
g[1074]:=19.6:
g[1075]:=24:
g[1076]:=27.5:
g[1077]:=30.2:
g[1078]:=31.4:
g[1079]:=29.2:
g[1080]:=23.9:
g[1081]:=17.4:
g[1082]:=11.8:
g[1083]:=7.21:
g[1084]:=2.77:
g[1085]:=-1.71:
g[1086]:=-4.37:
g[1087]:=-3.65:
g[1088]:=-0.845:
g[1089]:=1.46:
g[1090]:=2.13:
g[1091]:=1.7:
g[1092]:=2.16:
g[1093]:=6.28:
g[1094]:=12.6:
g[1095]:=14.9:
g[1096]:=10.4:
g[1097]:=2.15:
g[1098]:=-5.42:
g[1099]:=-10.5:
g[1100]:=-14.2:
g[1101]:=-17.8:
g[1102]:=-22.2:
g[1103]:=-26.6:
g[1104]:=-28.6:
g[1105]:=-25.1:
g[1106]:=-16.7:
g[1107]:=-6.68:
g[1108]:=2.1:
g[1109]:=9.2:
g[1110]:=15.1:
g[1111]:=18.5:
g[1112]:=17.4:
g[1113]:=13.1:
g[1114]:=8.28:
g[1115]:=4.73:
g[1116]:=2.26:
g[1117]:=-0.191:
g[1118]:=-3.44:
g[1119]:=-7.58:
g[1120]:=-12.2:
g[1121]:=-15.8:
g[1122]:=-14.8:
g[1123]:=-7.43:
g[1124]:=3.6:
g[1125]:=13.5:
g[1126]:=19.3:
g[1127]:=21.9:
g[1128]:=23.7:
g[1129]:=25.5:
g[1130]:=26.2:
g[1131]:=25.3:
g[1132]:=23.6:
g[1133]:=21.8:
g[1134]:=20.1:
g[1135]:=18.3:
g[1136]:=16.2:
g[1137]:=14.2:
g[1138]:=12.2:
g[1139]:=10.4:
g[1140]:=9.69:
g[1141]:=11.8:
g[1142]:=16.8:
g[1143]:=22.6:
g[1144]:=26.6:
g[1145]:=28.9:
g[1146]:=31.7:
g[1147]:=36.9:
g[1148]:=42.1:
g[1149]:=43.1:
g[1150]:=39.1:
g[1151]:=33.1:
g[1152]:=28.2:
g[1153]:=25.1:
g[1154]:=23.2:
g[1155]:=21.6:
g[1156]:=19.7:
g[1157]:=17.2:
g[1158]:=14.4:
g[1159]:=11.6:
g[1160]:=8.78:
g[1161]:=5.39:
g[1162]:=1.33:
g[1163]:=-3.07:
g[1164]:=-7.39:
g[1165]:=-11.5:
g[1166]:=-15.4:
g[1167]:=-19.3:
g[1168]:=-23:
g[1169]:=-26.3:
g[1170]:=-29.3:
g[1171]:=-32.2:
g[1172]:=-35.3:
g[1173]:=-38.4:
g[1174]:=-41.3:
g[1175]:=-43.4:
g[1176]:=-44.5:
g[1177]:=-45.2:
g[1178]:=-46:
g[1179]:=-47.2:
g[1180]:=-48.6:
g[1181]:=-50:
g[1182]:=-51.9:
g[1183]:=-55.2:
g[1184]:=-60:
g[1185]:=-65.4:
g[1186]:=-70.5:
g[1187]:=-75.4:
g[1188]:=-79:
g[1189]:=-76.6:
g[1190]:=-63.1:
g[1191]:=-40.9:
g[1192]:=-18.8:
g[1193]:=-3.43:
g[1194]:=5.83:
g[1195]:=13.5:
g[1196]:=21:
g[1197]:=25.6:
g[1198]:=25.7:
g[1199]:=23.5:
g[1200]:=23:
g[1201]:=26.9:
g[1202]:=34.8:
g[1203]:=43.4:
g[1204]:=50.1:
g[1205]:=52.7:
g[1206]:=50.5:
g[1207]:=45.5:
g[1208]:=40.8:
g[1209]:=37.9:
g[1210]:=36.3:
g[1211]:=34.6:
g[1212]:=32.1:
g[1213]:=30.1:
g[1214]:=30.2:
g[1215]:=32.2:
g[1216]:=34.5:
g[1217]:=35.5:
g[1218]:=35.4:
g[1219]:=34.7:
g[1220]:=34.2:
g[1221]:=34.2:
g[1222]:=34.5:
g[1223]:=35:
g[1224]:=35.3:
g[1225]:=35.5:
g[1226]:=35.3:
g[1227]:=33.3:
g[1228]:=27.3:
g[1229]:=16.6:
g[1230]:=3.76:
g[1231]:=-6.96:
g[1232]:=-11.6:
g[1233]:=-10.4:
g[1234]:=-7.95:
g[1235]:=-9.25:
g[1236]:=-15:
g[1237]:=-20.7:
g[1238]:=-20.6:
g[1239]:=-14:
g[1240]:=-7.43:
g[1241]:=-6.92:
g[1242]:=-12.5:
g[1243]:=-19.9:
g[1244]:=-25.3:
g[1245]:=-26.8:
g[1246]:=-23.8:
g[1247]:=-18.5:
g[1248]:=-13.5:
g[1249]:=-10.3:
g[1250]:=-8.11:
g[1251]:=-6.62:
g[1252]:=-7.15:
g[1253]:=-10.7:
g[1254]:=-15.9:
g[1255]:=-19.8:
g[1256]:=-19.1:
g[1257]:=-14.1:
g[1258]:=-9.55:
g[1259]:=-9.11:
g[1260]:=-12.2:
g[1261]:=-15.1:
g[1262]:=-14.1:
g[1263]:=-8.91:
g[1264]:=-3.03:
g[1265]:=0.303:
g[1266]:=0.874:
g[1267]:=1.01:
g[1268]:=2.88:
g[1269]:=5.53:
g[1270]:=6.35:
g[1271]:=4.72:
g[1272]:=2.02:
g[1273]:=-0.318:
g[1274]:=-1.88:
g[1275]:=-2.72:
g[1276]:=-2.11:
g[1277]:=0.676:
g[1278]:=5.01:
g[1279]:=9.58:
g[1280]:=13.4:
g[1281]:=15.2:
g[1282]:=13.6:
g[1283]:=9.04:
g[1284]:=3.58:
g[1285]:=-1.18:
g[1286]:=-5.5:
g[1287]:=-10.1:
g[1288]:=-14.4:
g[1289]:=-17:
g[1290]:=-17.8:
g[1291]:=-17.7:
g[1292]:=-17.6:
g[1293]:=-17.9:
g[1294]:=-18.1:
g[1295]:=-18.1:
g[1296]:=-17.7:
g[1297]:=-15.7:
g[1298]:=-11.3:
g[1299]:=-6.52:
g[1300]:=-4.72:
g[1301]:=-6.41:
g[1302]:=-9.66:
g[1303]:=-12.7:
g[1304]:=-15:
g[1305]:=-16.7:
g[1306]:=-18.5:
g[1307]:=-20.3:
g[1308]:=-21.6:
g[1309]:=-22:
g[1310]:=-22.5:
g[1311]:=-24.3:
g[1312]:=-27.9:
g[1313]:=-31.5:
g[1314]:=-33.2:
g[1315]:=-33.9:
g[1316]:=-34.4:
g[1317]:=-31.8:
g[1318]:=-22.7:
g[1319]:=-9.62:
g[1320]:=0.983:
g[1321]:=5.6:
g[1322]:=6.39:
g[1323]:=7.26:
g[1324]:=9.96:
g[1325]:=13.9:
g[1326]:=17.6:
g[1327]:=19.6:
g[1328]:=18.9:
g[1329]:=16.1:
g[1330]:=12.7:
g[1331]:=10.1:
g[1332]:=9.03:
g[1333]:=8.12:
g[1334]:=3.93:
g[1335]:=-5.52:
g[1336]:=-15:
g[1337]:=-15.3:
g[1338]:=-3.94:
g[1339]:=12.3:
g[1340]:=23.2:
g[1341]:=22.2:
g[1342]:=11.6:
g[1343]:=-0.593:
g[1344]:=-8.88:
g[1345]:=-13.1:
g[1346]:=-15.5:
g[1347]:=-14.9:
g[1348]:=-7.36:
g[1349]:=6.71:
g[1350]:=22.9:
g[1351]:=35.9:
g[1352]:=39.8:
g[1353]:=31.8:
g[1354]:=16.6:
g[1355]:=3.63:
g[1356]:=-1.67:
g[1357]:=-0.978:
g[1358]:=0.976:
g[1359]:=2.5:
g[1360]:=4.58:
g[1361]:=7.53:
g[1362]:=10.6:
g[1363]:=13.2:
g[1364]:=14.5:
g[1365]:=14.1:
g[1366]:=12.6:
g[1367]:=11.3:
g[1368]:=11:
g[1369]:=11.2:
g[1370]:=10.6:
g[1371]:=8.22:
g[1372]:=4.79:
g[1373]:=2.05:
g[1374]:=1.03:
g[1375]:=0.672:
g[1376]:=-1.12:
g[1377]:=-4.88:
g[1378]:=-9.08:
g[1379]:=-12.1:
g[1380]:=-14.4:
g[1381]:=-18.6:
g[1382]:=-27.5:
g[1383]:=-38.4:
g[1384]:=-42.6:
g[1385]:=-33.9:
g[1386]:=-16.2:
g[1387]:=2.39:
g[1388]:=16.9:
g[1389]:=27.7:
g[1390]:=35.8:
g[1391]:=39.2:
g[1392]:=36.9:
g[1393]:=31.9:
g[1394]:=27.6:
g[1395]:=25:
g[1396]:=23.3:
g[1397]:=20.8:
g[1398]:=17:
g[1399]:=12.2:
g[1400]:=7.4:
g[1401]:=3.33:
g[1402]:=0.377:
g[1403]:=-1.82:
g[1404]:=-4.29:
g[1405]:=-8.44:
g[1406]:=-14.4:
g[1407]:=-17.5:
g[1408]:=-10.9:
g[1409]:=5.05:
g[1410]:=20.2:
g[1411]:=25.8:
g[1412]:=22.7:
g[1413]:=18.4:
g[1414]:=18.4:
g[1415]:=22.3:
g[1416]:=25:
g[1417]:=23.2:
g[1418]:=17.8:
g[1419]:=10.9:
g[1420]:=2.09:
g[1421]:=-9.25:
g[1422]:=-20.6:
g[1423]:=-28.6:
g[1424]:=-33.4:
g[1425]:=-37.5:
g[1426]:=-43:
g[1427]:=-50:
g[1428]:=-55.6:
g[1429]:=-55.6:
g[1430]:=-50.1:
g[1431]:=-41.9:
g[1432]:=-32.3:
g[1433]:=-21.2:
g[1434]:=-10.4:
g[1435]:=-2.45:
g[1436]:=3.02:
g[1437]:=7.29:
g[1438]:=9.13:
g[1439]:=6.9:
g[1440]:=1.74:
g[1441]:=-3.81:
g[1442]:=-8.37:
g[1443]:=-12.2:
g[1444]:=-16.1:
g[1445]:=-19.7:
g[1446]:=-19.7:
g[1447]:=-13.5:
g[1448]:=-3.98:
g[1449]:=3.23:
g[1450]:=6.45:
g[1451]:=7.51:
g[1452]:=7.11:
g[1453]:=5.17:
g[1454]:=2.59:
g[1455]:=0.296:
g[1456]:=-0.852:
g[1457]:=0.163:
g[1458]:=3.32:
g[1459]:=7.07:
g[1460]:=9.78:
g[1461]:=11.1:
g[1462]:=12:
g[1463]:=14:
g[1464]:=17.9:
g[1465]:=22.9:
g[1466]:=27.7:
g[1467]:=30.4:
g[1468]:=28.2:
g[1469]:=21.1:
g[1470]:=12.9:
g[1471]:=7.3:
g[1472]:=5.13:
g[1473]:=4.31:
g[1474]:=2.67:
g[1475]:=-0.109:
g[1476]:=-2.8:
g[1477]:=-4.37:
g[1478]:=-4.91:
g[1479]:=-5.19:
g[1480]:=-6.34:
g[1481]:=-9.56:
g[1482]:=-14.3:
g[1483]:=-16.3:
g[1484]:=-10.8:
g[1485]:=1.97:
g[1486]:=17.1:
g[1487]:=28.5:
g[1488]:=30.7:
g[1489]:=23.3:
g[1490]:=12.4:
g[1491]:=3.87:
g[1492]:=-0.282:
g[1493]:=-2.15:
g[1494]:=-4.79:
g[1495]:=-9.52:
g[1496]:=-14.4:
g[1497]:=-15.5:
g[1498]:=-11.4:
g[1499]:=-4.66:
g[1500]:=1.77:
g[1501]:=6.67:
g[1502]:=9.76:
g[1503]:=9.61:
g[1504]:=5.14:
g[1505]:=-2:
g[1506]:=-8.95:
g[1507]:=-14.2:
g[1508]:=-18.1:
g[1509]:=-22.1:
g[1510]:=-26.9:
g[1511]:=-30.2:
g[1512]:=-28.8:
g[1513]:=-22.5:
g[1514]:=-14.3:
g[1515]:=-6.63:
g[1516]:=0.11:
g[1517]:=5.45:
g[1518]:=8.36:
g[1519]:=9.22:
g[1520]:=9.47:
g[1521]:=9.55:
g[1522]:=9.05:
g[1523]:=7.77:
g[1524]:=5.91:
g[1525]:=3.57:
g[1526]:=0.405:
g[1527]:=-3.96:
g[1528]:=-7.94:
g[1529]:=-8.16:
g[1530]:=-3.51:
g[1531]:=3.55:
g[1532]:=10:
g[1533]:=14.8:
g[1534]:=18.2:
g[1535]:=19.6:
g[1536]:=17.8:
g[1537]:=13.4:
g[1538]:=8.53:
g[1539]:=4.64:
g[1540]:=1.6:
g[1541]:=-1.47:
g[1542]:=-4.32:
g[1543]:=-4.66:
g[1544]:=-1.06:
g[1545]:=3.8:
g[1546]:=5.06:
g[1547]:=1.01:
g[1548]:=-5.75:
g[1549]:=-11.8:
g[1550]:=-15.8:
g[1551]:=-18.6:
g[1552]:=-21:
g[1553]:=-22.5:
g[1554]:=-22:
g[1555]:=-19.5:
g[1556]:=-16.6:
g[1557]:=-14.1:
g[1558]:=-12.9:
g[1559]:=-13.8:
g[1560]:=-17:
g[1561]:=-21.3:
g[1562]:=-25.3:
g[1563]:=-28.2:
g[1564]:=-28.4:
g[1565]:=-23.3:
g[1566]:=-13.1:
g[1567]:=-1.27:
g[1568]:=8.52:
g[1569]:=14.9:
g[1570]:=19.1:
g[1571]:=23.3:
g[1572]:=26.3:
g[1573]:=25.4:
g[1574]:=20.1:
g[1575]:=13.4:
g[1576]:=8:
g[1577]:=4.86:
g[1578]:=2.86:
g[1579]:=0.4:
g[1580]:=-2.28:
g[1581]:=-2.62:
g[1582]:=0.997:
g[1583]:=7.17:
g[1584]:=13.5:
g[1585]:=18.7:
g[1586]:=21.4:
g[1587]:=20.4:
g[1588]:=16.3:
g[1589]:=11.5:
g[1590]:=7.6:
g[1591]:=4.87:
g[1592]:=2.4:
g[1593]:=-0.664:
g[1594]:=-4.06:
g[1595]:=-5.98:
g[1596]:=-4.96:
g[1597]:=-1.7:
g[1598]:=1.96:
g[1599]:=4.67:
g[1600]:=6.1:
g[1601]:=7.2:
g[1602]:=9.52:
g[1603]:=13.1:
g[1604]:=15.3:
g[1605]:=13.3:
g[1606]:=7.74:
g[1607]:=1.38:
g[1608]:=-3.76:
g[1609]:=-7.32:
g[1610]:=-10.2:
g[1611]:=-13.5:
g[1612]:=-17.1:
g[1613]:=-20.4:
g[1614]:=-22.9:
g[1615]:=-24.6:
g[1616]:=-24.5:
g[1617]:=-21.4:
g[1618]:=-15.8:
g[1619]:=-9.14:
g[1620]:=-0.631:
g[1621]:=11.1:
g[1622]:=24.5:
g[1623]:=33.6:
g[1624]:=33.3:
g[1625]:=25.4:
g[1626]:=16.1:
g[1627]:=10.2:
g[1628]:=7.52:
g[1629]:=5.7:
g[1630]:=2.46:
g[1631]:=-2.78:
g[1632]:=-9.18:
g[1633]:=-14.7:
g[1634]:=-15.8:
g[1635]:=-11.1:
g[1636]:=-5.08:
g[1637]:=-3.33:
g[1638]:=-7.03:
g[1639]:=-12.7:
g[1640]:=-16.3:
g[1641]:=-15.7:
g[1642]:=-12.2:
g[1643]:=-8.5:
g[1644]:=-6.52:
g[1645]:=-6.53:
g[1646]:=-7.52:
g[1647]:=-8.29:
g[1648]:=-8.05:
g[1649]:=-6.31:
g[1650]:=-2.95:
g[1651]:=1.34:
g[1652]:=5.45:
g[1653]:=8.83:
g[1654]:=11.8:
g[1655]:=14.2:
g[1656]:=14.4:
g[1657]:=11.8:
g[1658]:=7.42:
g[1659]:=3.29:
g[1660]:=0.0889:
g[1661]:=-2.61:
g[1662]:=-5.02:
g[1663]:=-5.42:
g[1664]:=-1.62:
g[1665]:=5.26:
g[1666]:=11.1:
g[1667]:=13.3:
g[1668]:=12.7:
g[1669]:=11.9:
g[1670]:=12.3:
g[1671]:=13:
g[1672]:=12.2:
g[1673]:=10:
g[1674]:=7.97:
g[1675]:=7.13:
g[1676]:=7.23:
g[1677]:=7.44:
g[1678]:=7.24:
g[1679]:=6.24:
g[1680]:=3.76:
g[1681]:=0.545:
g[1682]:=-0.739:
g[1683]:=1.19:
g[1684]:=4.93:
g[1685]:=8.11:
g[1686]:=8.42:
g[1687]:=4.86:
g[1688]:=-1.13:
g[1689]:=-7.36:
g[1690]:=-13:
g[1691]:=-18.4:
g[1692]:=-24.2:
g[1693]:=-30.2:
g[1694]:=-35.2:
g[1695]:=-37.3:
g[1696]:=-36:
g[1697]:=-32.8:
g[1698]:=-29.8:
g[1699]:=-27.1:
g[1700]:=-23.4:
g[1701]:=-17.7:
g[1702]:=-10.9:
g[1703]:=-4.8:
g[1704]:=-0.486:
g[1705]:=2.49:
g[1706]:=5.12:
g[1707]:=7.08:
g[1708]:=7.2:
g[1709]:=5.41:
g[1710]:=2.9:
g[1711]:=0.69:
g[1712]:=-0.997:
g[1713]:=-2.53:
g[1714]:=-4.32:
g[1715]:=-6.47:
g[1716]:=-8.19:
g[1717]:=-7.76:
g[1718]:=-4.49:
g[1719]:=0.354:
g[1720]:=5.03:
g[1721]:=8.76:
g[1722]:=11.9:
g[1723]:=15.1:
g[1724]:=18.8:
g[1725]:=22.8:
g[1726]:=26.4:
g[1727]:=27.9:
g[1728]:=26:
g[1729]:=21.9:
g[1730]:=17.8:
g[1731]:=14.6:
g[1732]:=12.3:
g[1733]:=9.95:
g[1734]:=7.09:
g[1735]:=3.64:
g[1736]:=0.644:
g[1737]:=0.116:
g[1738]:=2.89:
g[1739]:=7.51:
g[1740]:=11.9:
g[1741]:=15.2:
g[1742]:=17.3:
g[1743]:=17.5:
g[1744]:=16.1:
g[1745]:=14.1:
g[1746]:=12.5:
g[1747]:=11.6:
g[1748]:=11.7:
g[1749]:=13.2:
g[1750]:=15.8:
g[1751]:=18.4:
g[1752]:=20.3:
g[1753]:=20.8:
g[1754]:=19.6:
g[1755]:=17.8:
g[1756]:=16.2:
g[1757]:=15.2:
g[1758]:=14.2:
g[1759]:=13:
g[1760]:=11.8:
g[1761]:=10.8:
g[1762]:=9.82:
g[1763]:=8.69:
g[1764]:=7.22:
g[1765]:=5.48:
g[1766]:=3.15:
g[1767]:=-1.93:
g[1768]:=-11.7:
g[1769]:=-23.4:
g[1770]:=-31.6:
g[1771]:=-34.4:
g[1772]:=-34.2:
g[1773]:=-33.2:
g[1774]:=-31.6:
g[1775]:=-29.7:
g[1776]:=-28.6:
g[1777]:=-27.5:
g[1778]:=-23.2:
g[1779]:=-14.7:
g[1780]:=-5.66:
g[1781]:=-0.214:
g[1782]:=1.44:
g[1783]:=1.8:
g[1784]:=2.34:
g[1785]:=2.57:
g[1786]:=1.9:
g[1787]:=0.527:
g[1788]:=-1.1:
g[1789]:=-2.58:
g[1790]:=-3.56:
g[1791]:=-4:
g[1792]:=-4.25:
g[1793]:=-4.75:
g[1794]:=-5.96:
g[1795]:=-7.85:
g[1796]:=-9.16:
g[1797]:=-8.31:
g[1798]:=-5.32:
g[1799]:=-1.64:
g[1800]:=1.56:
g[1801]:=3.83:
g[1802]:=4.27:
g[1803]:=2.04:
g[1804]:=-1.61:
g[1805]:=-4.39:
g[1806]:=-5.52:
g[1807]:=-5.77:
g[1808]:=-5.51:
g[1809]:=-4.08:
g[1810]:=-1.25:
g[1811]:=2.25:
g[1812]:=5.62:
g[1813]:=8.27:
g[1814]:=8.99:
g[1815]:=6.69:
g[1816]:=2.19:
g[1817]:=-2.53:
g[1818]:=-6.2:
g[1819]:=-7.98:
g[1820]:=-6.69:
g[1821]:=-2.35:
g[1822]:=3.14:
g[1823]:=7.94:
g[1824]:=11.6:
g[1825]:=13.8:
g[1826]:=13.4:
g[1827]:=9.98:
g[1828]:=5.29:
g[1829]:=1.55:
g[1830]:=-0.0868:
g[1831]:=0.00431:
g[1832]:=0.572:
g[1833]:=0.572:
g[1834]:=-0.232:
g[1835]:=-1.39:
g[1836]:=-2.37:
g[1837]:=-2.92:
g[1838]:=-3.11:
g[1839]:=-3.25:
g[1840]:=-3.65:
g[1841]:=-4.43:
g[1842]:=-5.43:
g[1843]:=-6.45:
g[1844]:=-7.37:
g[1845]:=-8.16:
g[1846]:=-8.87:
g[1847]:=-9.58:
g[1848]:=-10.3:
g[1849]:=-11.1:
g[1850]:=-11.9:
g[1851]:=-12.7:
g[1852]:=-13.5:
g[1853]:=-14.3:
g[1854]:=-15.1:
g[1855]:=-16.3:
g[1856]:=-17.9:
g[1857]:=-18.9:
g[1858]:=-18:
g[1859]:=-14.8:
g[1860]:=-10.9:
g[1861]:=-7.4:
g[1862]:=-4.71:
g[1863]:=-2.32:
g[1864]:=0.483:
g[1865]:=3.55:
g[1866]:=5.15:
g[1867]:=3.84:
g[1868]:=0.274:
g[1869]:=-3.52:
g[1870]:=-4.86:
g[1871]:=-1.57:
g[1872]:=5.74:
g[1873]:=14.1:
g[1874]:=21.2:
g[1875]:=25.6:
g[1876]:=26.6:
g[1877]:=24.8:
g[1878]:=22.1:
g[1879]:=20:
g[1880]:=17.4:
g[1881]:=12.7:
g[1882]:=6:
g[1883]:=-1.49:
g[1884]:=-8.71:
g[1885]:=-13.9:
g[1886]:=-14.3:
g[1887]:=-9.46:
g[1888]:=-2.23:
g[1889]:=3.53:
g[1890]:=5.56:
g[1891]:=4.44:
g[1892]:=2.72:
g[1893]:=2.65:
g[1894]:=5.18:
g[1895]:=9.71:
g[1896]:=14.7:
g[1897]:=18.8:
g[1898]:=21:
g[1899]:=19.3:
g[1900]:=13.2:
g[1901]:=5.11:
g[1902]:=-1.77:
g[1903]:=-5.24:
g[1904]:=-5.36:
g[1905]:=-4.16:
g[1906]:=-3.65:
g[1907]:=-4.5:
g[1908]:=-6.26:
g[1909]:=-8.29:
g[1910]:=-10.2:
g[1911]:=-11.7:
g[1912]:=-13:
g[1913]:=-14.3:
g[1914]:=-15.5:
g[1915]:=-14.9:
g[1916]:=-10.9:
g[1917]:=-4.21:
g[1918]:=3.13:
g[1919]:=9.38:
g[1920]:=13.2:
g[1921]:=13.8:
g[1922]:=11.9:
g[1923]:=9.86:
g[1924]:=8.93:
g[1925]:=9.37:
g[1926]:=10.7:
g[1927]:=12.3:
g[1928]:=13.3:
g[1929]:=13:
g[1930]:=11:
g[1931]:=7.57:
g[1932]:=3.66:
g[1933]:=-0.376:
g[1934]:=-4.48:
g[1935]:=-8.67:
g[1936]:=-13:
g[1937]:=-16.7:
g[1938]:=-18:
g[1939]:=-15.9:
g[1940]:=-12.1:
g[1941]:=-8.44:
g[1942]:=-5.83:
g[1943]:=-3.77:
g[1944]:=-1.45:
g[1945]:=1.43:
g[1946]:=4.49:
g[1947]:=7.2:
g[1948]:=9.51:
g[1949]:=11.5:
g[1950]:=12.5:
g[1951]:=10.9:
g[1952]:=6.62:
g[1953]:=1.25:
g[1954]:=-3.81:
g[1955]:=-8.15:
g[1956]:=-12.2:
g[1957]:=-16.6:
g[1958]:=-21.2:
g[1959]:=-23.7:
g[1960]:=-21.6:
g[1961]:=-15.3:
g[1962]:=-7.78:
g[1963]:=-1.82:
g[1964]:=1.38:
g[1965]:=2.48:
g[1966]:=3.29:
g[1967]:=5.14:
g[1968]:=8.09:
g[1969]:=11.3:
g[1970]:=13.5:
g[1971]:=14.3:
g[1972]:=14.2:
g[1973]:=14.1:
g[1974]:=14.4:
g[1975]:=15:
g[1976]:=15.8:
g[1977]:=16.7:
g[1978]:=17.9:
g[1979]:=19.3:
g[1980]:=19.8:
g[1981]:=18.7:
g[1982]:=16.8:
g[1983]:=15.4:
g[1984]:=15:
g[1985]:=15.3:
g[1986]:=15:
g[1987]:=13.2:
g[1988]:=9.67:
g[1989]:=5.55:
g[1990]:=2.05:
g[1991]:=-0.361:
g[1992]:=-1.78:
g[1993]:=-1.98:
g[1994]:=-0.827:
g[1995]:=1.05:
g[1996]:=2.82:
g[1997]:=4.17:
g[1998]:=5.33:
g[1999]:=6.16:
g[2000]:=5.45:
g[2001]:=2.19:
g[2002]:=-3:
g[2003]:=-8.72:
g[2004]:=-14.1:
g[2005]:=-19.1:
g[2006]:=-24.1:
g[2007]:=-28:
g[2008]:=-29.8:
g[2009]:=-29.9:
g[2010]:=-29.7:
g[2011]:=-29.7:
g[2012]:=-29.7:
g[2013]:=-28.9:
g[2014]:=-26.9:
g[2015]:=-24:
g[2016]:=-20.7:
g[2017]:=-17.1:
g[2018]:=-12.8:
g[2019]:=-7.65:
g[2020]:=-1.64:
g[2021]:=4.78:
g[2022]:=10.2:
g[2023]:=13.4:
g[2024]:=14.9:
g[2025]:=16:
g[2026]:=17.4:
g[2027]:=18.2:
g[2028]:=18:
g[2029]:=17:
g[2030]:=15.8:
g[2031]:=14.5:
g[2032]:=12.4:
g[2033]:=8.99:
g[2034]:=4.24:
g[2035]:=-1.46:
g[2036]:=-7.48:
g[2037]:=-12.8:
g[2038]:=-16.7:
g[2039]:=-19.7:
g[2040]:=-22.3:
g[2041]:=-23.2:
g[2042]:=-21.1:
g[2043]:=-16.6:
g[2044]:=-11.7:
g[2045]:=-8.02:
g[2046]:=-5.47:
g[2047]:=-3.09:
g[2048]:=-0.144:
g[2049]:=3.57:
g[2050]:=8.09:
g[2051]:=13.1:
g[2052]:=16.8:
g[2053]:=16.2:
g[2054]:=11.2:
g[2055]:=4.51:
g[2056]:=-1.21:
g[2057]:=-5.31:
g[2058]:=-8.7:
g[2059]:=-12.4:
g[2060]:=-16.8:
g[2061]:=-21.4:
g[2062]:=-25.1:
g[2063]:=-26.3:
g[2064]:=-24.5:
g[2065]:=-21.1:
g[2066]:=-17.2:
g[2067]:=-13.2:
g[2068]:=-9.18:
g[2069]:=-5.02:
g[2070]:=-0.518:
g[2071]:=4.33:
g[2072]:=9.39:
g[2073]:=14.4:
g[2074]:=19:
g[2075]:=22.9:
g[2076]:=26.4:
g[2077]:=30:
g[2078]:=33.7:
g[2079]:=36.6:
g[2080]:=36.4:
g[2081]:=32.5:
g[2082]:=26.7:
g[2083]:=21:
g[2084]:=15.5:
g[2085]:=9.04:
g[2086]:=1.15:
g[2087]:=-6.67:
g[2088]:=-12.7:
g[2089]:=-16.9:
g[2090]:=-20.5:
g[2091]:=-24:
g[2092]:=-25.5:
g[2093]:=-23.4:
g[2094]:=-18.5:
g[2095]:=-13.7:
g[2096]:=-11.6:
g[2097]:=-12:
g[2098]:=-13.2:
g[2099]:=-13.5:
g[2100]:=-12.2:
g[2101]:=-8.77:
g[2102]:=-3.64:
g[2103]:=2.02:
g[2104]:=6.96:
g[2105]:=9.61:
g[2106]:=8.68:
g[2107]:=4.89:
g[2108]:=0.589:
g[2109]:=-2.62:
g[2110]:=-4.74:
g[2111]:=-6.67:
g[2112]:=-9.18:
g[2113]:=-12.4:
g[2114]:=-15.7:
g[2115]:=-18.7:
g[2116]:=-21.4:
g[2117]:=-23.4:
g[2118]:=-23.4:
g[2119]:=-20.4:
g[2120]:=-15.5:
g[2121]:=-10.6:
g[2122]:=-6.83:
g[2123]:=-4.14:
g[2124]:=-1.61:
g[2125]:=1.47:
g[2126]:=4.94:
g[2127]:=8:
g[2128]:=10.1:
g[2129]:=11.6:
g[2130]:=13:
g[2131]:=14.6:
g[2132]:=16.4:
g[2133]:=18.4:
g[2134]:=20:
g[2135]:=20.8:
g[2136]:=20:
g[2137]:=17.6:
g[2138]:=14.8:
g[2139]:=12.6:
g[2140]:=11:
g[2141]:=9.63:
g[2142]:=8.22:
g[2143]:=7.1:
g[2144]:=6.51:
g[2145]:=6.27:
g[2146]:=6:
g[2147]:=5.45:
g[2148]:=4.45:
g[2149]:=3.09:
g[2150]:=1.67:
g[2151]:=0.448:
g[2152]:=-0.619:
g[2153]:=-1.7:
g[2154]:=-2.66:
g[2155]:=-2.74:
g[2156]:=-1.4:
g[2157]:=0.923:
g[2158]:=3.33:
g[2159]:=5.33:
g[2160]:=6.99:
g[2161]:=8.65:
g[2162]:=10.6:
g[2163]:=12.7:
g[2164]:=14.5:
g[2165]:=14.9:
g[2166]:=13.8:
g[2167]:=12:
g[2168]:=10.5:
g[2169]:=9.95:
g[2170]:=10.8:
g[2171]:=12.9:
g[2172]:=15.2:
g[2173]:=17.1:
g[2174]:=18.5:
g[2175]:=19.7:
g[2176]:=21:
g[2177]:=22.6:
g[2178]:=24.1:
g[2179]:=24.8:
g[2180]:=23.7:
g[2181]:=21.1:
g[2182]:=17.8:
g[2183]:=13:
g[2184]:=5.12:
g[2185]:=-4.31:
g[2186]:=-11.4:
g[2187]:=-14.8:
g[2188]:=-16.5:
g[2189]:=-18.8:
g[2190]:=-22.4:
g[2191]:=-25.7:
g[2192]:=-26.4:
g[2193]:=-23.9:
g[2194]:=-20.1:
g[2195]:=-16.8:
g[2196]:=-15:
g[2197]:=-14.8:
g[2198]:=-15.3:
g[2199]:=-15.7:
g[2200]:=-15.5:
g[2201]:=-14.8:
g[2202]:=-14:
g[2203]:=-11.7:
g[2204]:=-6.16:
g[2205]:=2.04:
g[2206]:=9.55:
g[2207]:=14.2:
g[2208]:=16.9:
g[2209]:=18.7:
g[2210]:=18.5:
g[2211]:=15.5:
g[2212]:=10.7:
g[2213]:=5.77:
g[2214]:=1.7:
g[2215]:=-1.67:
g[2216]:=-4.9:
g[2217]:=-8.41:
g[2218]:=-12.4:
g[2219]:=-16.5:
g[2220]:=-19.7:
g[2221]:=-20.1:
g[2222]:=-17.6:
g[2223]:=-13.8:
g[2224]:=-10.5:
g[2225]:=-8.31:
g[2226]:=-6.84:
g[2227]:=-5.38:
g[2228]:=-3.43:
g[2229]:=-1.11:
g[2230]:=0.684:
g[2231]:=0.983:
g[2232]:=-0.113:
g[2233]:=-1.63:
g[2234]:=-2.77:
g[2235]:=-3.42:
g[2236]:=-3.87:
g[2237]:=-4.49:
g[2238]:=-5.22:
g[2239]:=-5.46:
g[2240]:=-4.79:
g[2241]:=-3.58:
g[2242]:=-2.45:
g[2243]:=-1.67:
g[2244]:=-1.14:
g[2245]:=-0.586:
g[2246]:=0.166:
g[2247]:=0.939:
g[2248]:=1.24:
g[2249]:=0.823:
g[2250]:=-0.0387:
g[2251]:=-0.682:
g[2252]:=-0.336:
g[2253]:=1.23:
g[2254]:=3.47:
g[2255]:=5.91:
g[2256]:=8.47:
g[2257]:=11.2:
g[2258]:=14:
g[2259]:=16.9:
g[2260]:=19.9:
g[2261]:=22.9:
g[2262]:=25.7:
g[2263]:=25.6:
g[2264]:=19.7:
g[2265]:=9.62:
g[2266]:=0.734:
g[2267]:=-3.73:
g[2268]:=-5.04:
g[2269]:=-6.28:
g[2270]:=-9.2:
g[2271]:=-13.5:
g[2272]:=-18:
g[2273]:=-21.3:
g[2274]:=-22:
g[2275]:=-19.8:
g[2276]:=-16.1:
g[2277]:=-13.1:
g[2278]:=-11.8:
g[2279]:=-12.2:
g[2280]:=-13:
g[2281]:=-13.1:
g[2282]:=-12.6:
g[2283]:=-11.7:
g[2284]:=-10.9:
g[2285]:=-9.96:
g[2286]:=-8.28:
g[2287]:=-5.54:
g[2288]:=-1.87:
g[2289]:=2.35:
g[2290]:=6.66:
g[2291]:=10.7:
g[2292]:=13.8:
g[2293]:=14.9:
g[2294]:=13.6:
g[2295]:=11.6:
g[2296]:=10.3:
g[2297]:=10.2:
g[2298]:=10.6:
g[2299]:=10.7:
g[2300]:=10.2:
g[2301]:=9.59:
g[2302]:=9.51:
g[2303]:=10.3:
g[2304]:=11.7:
g[2305]:=13:
g[2306]:=14.1:
g[2307]:=14.8:
g[2308]:=14.8:
g[2309]:=13.8:
g[2310]:=12.4:
g[2311]:=10.8:
g[2312]:=8.64:
g[2313]:=5.34:
g[2314]:=1.1:
g[2315]:=-3.39:
g[2316]:=-7.3:
g[2317]:=-9.32:
g[2318]:=-8.65:
g[2319]:=-6.31:
g[2320]:=-4.38:
g[2321]:=-4.04:
g[2322]:=-4.85:
g[2323]:=-5.68:
g[2324]:=-5.81:
g[2325]:=-5.28:
g[2326]:=-4.55:
g[2327]:=-4.03:
g[2328]:=-3.83:
g[2329]:=-3.82:
g[2330]:=-3.82:
g[2331]:=-3.49:
g[2332]:=-2.22:
g[2333]:=0.261:
g[2334]:=3.42:
g[2335]:=6.55:
g[2336]:=9.39:
g[2337]:=12.1:
g[2338]:=15:
g[2339]:=17.6:
g[2340]:=18.4:
g[2341]:=16.6:
g[2342]:=13.1:
g[2343]:=9.68:
g[2344]:=7.1:
g[2345]:=5.13:
g[2346]:=3.13:
g[2347]:=0.697:
g[2348]:=-2.17:
g[2349]:=-4.95:
g[2350]:=-6.71:
g[2351]:=-6.98:
g[2352]:=-6.34:
g[2353]:=-5.72:
g[2354]:=-5.58:
g[2355]:=-5.54:
g[2356]:=-4.6:
g[2357]:=-2.17:
g[2358]:=1.25:
g[2359]:=4.74:
g[2360]:=7.84:
g[2361]:=10.4:
g[2362]:=11:
g[2363]:=7.9:
g[2364]:=1.4:
g[2365]:=-5.7:
g[2366]:=-11:
g[2367]:=-13.4:
g[2368]:=-12.5:
g[2369]:=-8.81:
g[2370]:=-4.27:
g[2371]:=-0.529:
g[2372]:=2.18:
g[2373]:=4.64:
g[2374]:=7.01:
g[2375]:=7.88:
g[2376]:=6.09:
g[2377]:=2.45:
g[2378]:=-1.36:
g[2379]:=-4.35:
g[2380]:=-6.54:
g[2381]:=-8.56:
g[2382]:=-11:
g[2383]:=-13.8:
g[2384]:=-17:
g[2385]:=-19.8:
g[2386]:=-20.2:
g[2387]:=-16.7:
g[2388]:=-10.1:
g[2389]:=-3:
g[2390]:=2.98:
g[2391]:=7.87:
g[2392]:=12.6:
g[2393]:=17.1:
g[2394]:=19.1:
g[2395]:=17:
g[2396]:=12.3:
g[2397]:=7.33:
g[2398]:=3.22:
g[2399]:=-0.547:
g[2400]:=-4.8:
g[2401]:=-9.19:
g[2402]:=-11.6:
g[2403]:=-10.3:
g[2404]:=-6.43:
g[2405]:=-2.24:
g[2406]:=0.875:
g[2407]:=3.1:
g[2408]:=5.47:
g[2409]:=8.8:
g[2410]:=13.1:
g[2411]:=17.7:
g[2412]:=22.1:
g[2413]:=26.1:
g[2414]:=29.7:
g[2415]:=31.4:
g[2416]:=29:
g[2417]:=22.1:
g[2418]:=13.3:
g[2419]:=5.17:
g[2420]:=-1.43:
g[2421]:=-7.28:
g[2422]:=-13.5:
g[2423]:=-20.6:
g[2424]:=-28.2:
g[2425]:=-35.1:
g[2426]:=-40.9:
g[2427]:=-44:
g[2428]:=-41.9:
g[2429]:=-33.7:
g[2430]:=-22.7:
g[2431]:=-12.5:
g[2432]:=-4.27:
g[2433]:=2.98:
g[2434]:=10.8:
g[2435]:=19.8:
g[2436]:=29.7:
g[2437]:=39.9:
g[2438]:=47.6:
g[2439]:=48.7:
g[2440]:=42.3:
g[2441]:=32.3:
g[2442]:=23.3:
g[2443]:=16.9:
g[2444]:=11.9:
g[2445]:=6.26:
g[2446]:=-0.827:
g[2447]:=-9.06:
g[2448]:=-16.3:
g[2449]:=-19.1:
g[2450]:=-16.8:
g[2451]:=-11.8:
g[2452]:=-7.47:
g[2453]:=-4.8:
g[2454]:=-3.54:
g[2455]:=-3.91:
g[2456]:=-6.23:
g[2457]:=-9.67:
g[2458]:=-13:
g[2459]:=-15.7:
g[2460]:=-18.1:
g[2461]:=-20.6:
g[2462]:=-22.6:
g[2463]:=-22.8:
g[2464]:=-21.3:
g[2465]:=-19.5:
g[2466]:=-19.2:
g[2467]:=-20.6:
g[2468]:=-22.5:
g[2469]:=-23.9:
g[2470]:=-24.5:
g[2471]:=-24.2:
g[2472]:=-23.2:
g[2473]:=-21.7:
g[2474]:=-19.3:
g[2475]:=-15:
g[2476]:=-8.86:
g[2477]:=-2.22:
g[2478]:=3.44:
g[2479]:=7.17:
g[2480]:=9.29:
g[2481]:=10.7:
g[2482]:=11.8:
g[2483]:=12.7:
g[2484]:=13.3:
g[2485]:=14:
g[2486]:=14.8:
g[2487]:=16.3:
g[2488]:=18.7:
g[2489]:=22.1:
g[2490]:=25.9:
g[2491]:=28.9:
g[2492]:=30.3:
g[2493]:=30.7:
g[2494]:=31.1:
g[2495]:=32.3:
g[2496]:=33.7:
g[2497]:=33.2:
g[2498]:=28.6:
g[2499]:=20.4:
g[2500]:=11.3:
g[2501]:=3.3:
g[2502]:=-3.2:
g[2503]:=-8.27:
g[2504]:=-12.3:
g[2505]:=-15.8:
g[2506]:=-18.2:
g[2507]:=-18:
g[2508]:=-15.4:
g[2509]:=-11.9:
g[2510]:=-8.79:
g[2511]:=-6.43:
g[2512]:=-5.24:
g[2513]:=-6.58:
g[2514]:=-10.9:
g[2515]:=-16.6:
g[2516]:=-21.9:
g[2517]:=-25.7:
g[2518]:=-26.3:
g[2519]:=-22.7:
g[2520]:=-16.5:
g[2521]:=-10.5:
g[2522]:=-6.41:
g[2523]:=-3.9:
g[2524]:=-2.17:
g[2525]:=-0.968:
g[2526]:=-0.214:
g[2527]:=0.428:
g[2528]:=1.79:
g[2529]:=4.9:
g[2530]:=9.59:
g[2531]:=14.2:
g[2532]:=17.3:
g[2533]:=18.4:
g[2534]:=18.5:
g[2535]:=18.8:
g[2536]:=20.1:
g[2537]:=23.1:
g[2538]:=27.7:
g[2539]:=31.9:
g[2540]:=31.4:
g[2541]:=24.2:
g[2542]:=13:
g[2543]:=2.13:
g[2544]:=-6.43:
g[2545]:=-12.7:
g[2546]:=-17.4:
g[2547]:=-21.3:
g[2548]:=-25.4:
g[2549]:=-29:
g[2550]:=-30.1:
g[2551]:=-27.6:
g[2552]:=-23.2:
g[2553]:=-18.9:
g[2554]:=-16:
g[2555]:=-15.6:
g[2556]:=-17.8:
g[2557]:=-21.3:
g[2558]:=-24.5:
g[2559]:=-26.5:
g[2560]:=-27.8:
g[2561]:=-29.1:
g[2562]:=-31:
g[2563]:=-33.2:
g[2564]:=-35.1:
g[2565]:=-36.5:
g[2566]:=-37.3:
g[2567]:=-37.3:
g[2568]:=-36.2:
g[2569]:=-34.6:
g[2570]:=-32:
g[2571]:=-26.3:
g[2572]:=-16.2:
g[2573]:=-3.19:
g[2574]:=9.92:
g[2575]:=21.7:
g[2576]:=32.5:
g[2577]:=43.4:
g[2578]:=52.3:
g[2579]:=53.4:
g[2580]:=44.7:
g[2581]:=31.1:
g[2582]:=18.3:
g[2583]:=8.63:
g[2584]:=0.751:
g[2585]:=-7.64:
g[2586]:=-17:
g[2587]:=-25.9:
g[2588]:=-31.7:
g[2589]:=-31.6:
g[2590]:=-25.8:
g[2591]:=-17.6:
g[2592]:=-10.3:
g[2593]:=-4.94:
g[2594]:=-0.302:
g[2595]:=4.96:
g[2596]:=11.3:
g[2597]:=16.9:
g[2598]:=18:
g[2599]:=13.1:
g[2600]:=5.04:
g[2601]:=-2.46:
g[2602]:=-8.02:
g[2603]:=-12.6:
g[2604]:=-18.5:
g[2605]:=-27.3:
g[2606]:=-36.9:
g[2607]:=-43.3:
g[2608]:=-45.6:
g[2609]:=-45.1:
g[2610]:=-43.1:
g[2611]:=-40.3:
g[2612]:=-37.4:
g[2613]:=-34.7:
g[2614]:=-32:
g[2615]:=-29:
g[2616]:=-25.7:
g[2617]:=-22.5:
g[2618]:=-19.8:
g[2619]:=-16.7:
g[2620]:=-11.8:
g[2621]:=-4.31:
g[2622]:=4.62:
g[2623]:=13.4:
g[2624]:=21.3:
g[2625]:=28.7:
g[2626]:=36.4:
g[2627]:=44.7:
g[2628]:=51.8:
g[2629]:=54.3:
g[2630]:=52.2:
g[2631]:=48.4:
g[2632]:=45.6:
g[2633]:=44:
g[2634]:=42:
g[2635]:=38.4:
g[2636]:=33.3:
g[2637]:=27.6:
g[2638]:=22.8:
g[2639]:=19.9:
g[2640]:=18.9:
g[2641]:=18.7:
g[2642]:=18:
g[2643]:=16.1:
g[2644]:=13.3:
g[2645]:=10.1:
g[2646]:=7.35:
g[2647]:=5.76:
g[2648]:=5.27:
g[2649]:=5.2:
g[2650]:=4.86:
g[2651]:=4.04:
g[2652]:=2.82:
g[2653]:=1.32:
g[2654]:=-0.234:
g[2655]:=-1.68:
g[2656]:=-2.88:
g[2657]:=-3.34:
g[2658]:=-2.57:
g[2659]:=-0.852:
g[2660]:=0.978:
g[2661]:=2.25:
g[2662]:=2.7:
g[2663]:=2.41:
g[2664]:=1.65:
g[2665]:=0.791:
g[2666]:=0.12:
g[2667]:=-0.56:
g[2668]:=-1.88:
g[2669]:=-4.16:
g[2670]:=-7.04:
g[2671]:=-9.93:
g[2672]:=-12.5:
g[2673]:=-14.9:
g[2674]:=-17.1:
g[2675]:=-19.4:
g[2676]:=-21.8:
g[2677]:=-23.6:
g[2678]:=-23.7:
g[2679]:=-21.9:
g[2680]:=-19.3:
g[2681]:=-16.2:
g[2682]:=-12.8:
g[2683]:=-9.28:
g[2684]:=-5.74:
g[2685]:=-2.5:
g[2686]:=-0.17:
g[2687]:=0.914:
g[2688]:=1.14:
g[2689]:=1.26:
g[2690]:=1.7:
g[2691]:=2.43:
g[2692]:=3.44:
g[2693]:=4.83:
g[2694]:=6.6:
g[2695]:=8.29:
g[2696]:=8.6:
g[2697]:=6.21:
g[2698]:=1.58:
g[2699]:=-3.31:
g[2700]:=-6.69:
g[2701]:=-8.31:
g[2702]:=-9.17:
g[2703]:=-9.98:
g[2704]:=-10.6:
g[2705]:=-10.8:
g[2706]:=-10.7:
g[2707]:=-10:
g[2708]:=-8.17:
g[2709]:=-4.77:
g[2710]:=-0.911:
g[2711]:=2.09:
g[2712]:=3.91:
g[2713]:=5.23:
g[2714]:=6.6:
g[2715]:=7.57:
g[2716]:=7.35:
g[2717]:=6:
g[2718]:=4.31:
g[2719]:=2.88:
g[2720]:=1.99:
g[2721]:=2.1:
g[2722]:=3.38:
g[2723]:=5.15:
g[2724]:=6.43:
g[2725]:=6.92:
g[2726]:=7.05:
g[2727]:=7.35:
g[2728]:=8.07:
g[2729]:=8.97:
g[2730]:=9.37:
g[2731]:=8.75:
g[2732]:=7.28:
g[2733]:=5.59:
g[2734]:=4.29:
g[2735]:=4.07:
g[2736]:=5.32:
g[2737]:=7.54:
g[2738]:=9.8:
g[2739]:=11.5:
g[2740]:=12.3:
g[2741]:=12.4:
g[2742]:=12.5:
g[2743]:=13.3:
g[2744]:=15:
g[2745]:=17.1:
g[2746]:=17.9:
g[2747]:=16.4:
g[2748]:=13.5:
g[2749]:=10.7:
g[2750]:=8.14:
g[2751]:=5.58:
g[2752]:=3.07:
g[2753]:=0.877:
g[2754]:=-0.986:
g[2755]:=-2.18:
g[2756]:=-1.8:
g[2757]:=0.248:
g[2758]:=2.65:
g[2759]:=3.98:
g[2760]:=4.07:
g[2761]:=3.79:
g[2762]:=3.93:
g[2763]:=4.66:
g[2764]:=5.66:
g[2765]:=6.7:
g[2766]:=7.9:
g[2767]:=9.48:
g[2768]:=11.4:
g[2769]:=13.3:
g[2770]:=15.2:
g[2771]:=16.8:
g[2772]:=17.7:
g[2773]:=17.3:
g[2774]:=15.8:
g[2775]:=14.2:
g[2776]:=12.8:
g[2777]:=11.7:
g[2778]:=10.4:
g[2779]:=8.81:
g[2780]:=6.99:
g[2781]:=4.74:
g[2782]:=1.75:
g[2783]:=-1.81:
g[2784]:=-5.48:
g[2785]:=-8.86:
g[2786]:=-11.5:
g[2787]:=-13.2:
g[2788]:=-14.4:
g[2789]:=-15.1:
g[2790]:=-14.9:
g[2791]:=-13.8:
g[2792]:=-12.1:
g[2793]:=-9.49:
g[2794]:=-6.13:
g[2795]:=-2.46:
g[2796]:=0.684:
g[2797]:=2.83:
g[2798]:=4.26:
g[2799]:=5.67:
g[2800]:=7.49:
g[2801]:=9.26:
g[2802]:=9.76:
g[2803]:=8.4:
g[2804]:=5.9:
g[2805]:=3.49:
g[2806]:=1.83:
g[2807]:=0.837:
g[2808]:=-0.0665:
g[2809]:=-1.3:
g[2810]:=-3:
g[2811]:=-5.04:
g[2812]:=-7.21:
g[2813]:=-9.32:
g[2814]:=-11.3:
g[2815]:=-12.9:
g[2816]:=-14.2:
g[2817]:=-14.7:
g[2818]:=-14:
g[2819]:=-11.8:
g[2820]:=-8.71:
g[2821]:=-5.43:
g[2822]:=-2.27:
g[2823]:=0.882:
g[2824]:=4.17:
g[2825]:=7.71:
g[2826]:=10.9:
g[2827]:=12.4:
g[2828]:=10.9:
g[2829]:=7.56:
g[2830]:=4.05:
g[2831]:=1.44:
g[2832]:=-0.459:
g[2833]:=-2.37:
g[2834]:=-4.74:
g[2835]:=-7.64:
g[2836]:=-10.7:
g[2837]:=-12.6:
g[2838]:=-12:
g[2839]:=-9.23:
g[2840]:=-5.97:
g[2841]:=-3.87:
g[2842]:=-3.21:
g[2843]:=-3.11:
g[2844]:=-2.66:
g[2845]:=-1.56:
g[2846]:=-0.297:
g[2847]:=0.515:
g[2848]:=0.75:
g[2849]:=0.699:
g[2850]:=0.726:
g[2851]:=0.957:
g[2852]:=1.31:
g[2853]:=1.88:
g[2854]:=2.81:
g[2855]:=4.01:
g[2856]:=5.32:
g[2857]:=6.39:
g[2858]:=6.59:
g[2859]:=5.54:
g[2860]:=3.61:
g[2861]:=1.63:
g[2862]:=0.0252:
g[2863]:=-0.877:
g[2864]:=-0.39:
g[2865]:=1.66:
g[2866]:=4.46:
g[2867]:=7.01:
g[2868]:=9:
g[2869]:=10.7:
g[2870]:=12.6:
g[2871]:=14.5:
g[2872]:=15.1:
g[2873]:=13.6:
g[2874]:=10.8:
g[2875]:=7.91:
g[2876]:=5.63:
g[2877]:=3.77:
g[2878]:=1.64:
g[2879]:=-1.24:
g[2880]:=-4.72:
g[2881]:=-8.31:
g[2882]:=-11.5:
g[2883]:=-13.9:
g[2884]:=-15.5:
g[2885]:=-16.3:
g[2886]:=-16.4:
g[2887]:=-15.9:
g[2888]:=-15.3:
g[2889]:=-14.7:
g[2890]:=-13.8:
g[2891]:=-11.9:
g[2892]:=-9.13:
g[2893]:=-6.39:
g[2894]:=-4.59:
g[2895]:=-3.84:
g[2896]:=-3.47:
g[2897]:=-2.74:
g[2898]:=-1.35:
g[2899]:=0.393:
g[2900]:=2.07:
g[2901]:=3.5:
g[2902]:=4.62:
g[2903]:=5.25:
g[2904]:=5.23:
g[2905]:=4.75:
g[2906]:=4.25:
g[2907]:=3.94:
g[2908]:=3.79:
g[2909]:=3.64:
g[2910]:=3.46:
g[2911]:=3.63:
g[2912]:=4.56:
g[2913]:=6.1:
g[2914]:=7.74:
g[2915]:=9.16:
g[2916]:=10.4:
g[2917]:=11.5:
g[2918]:=12.8:
g[2919]:=14.1:
g[2920]:=14.6:
g[2921]:=13.9:
g[2922]:=12.4:
g[2923]:=10.8:
g[2924]:=9.05:
g[2925]:=6.23:
g[2926]:=2:
g[2927]:=-2.3:
g[2928]:=-5.1:
g[2929]:=-6.34:
g[2930]:=-7.14:
g[2931]:=-8.37:
g[2932]:=-9.69:
g[2933]:=-10.1:
g[2934]:=-9.28:
g[2935]:=-7.77:
g[2936]:=-6.34:
g[2937]:=-5.24:
g[2938]:=-4.54:
g[2939]:=-4.56:
g[2940]:=-5.42:
g[2941]:=-6.74:
g[2942]:=-8:
g[2943]:=-9.01:
g[2944]:=-9.56:
g[2945]:=-9.08:
g[2946]:=-7.25:
g[2947]:=-4.67:
g[2948]:=-2.16:
g[2949]:=-0.0847:
g[2950]:=1.74:
g[2951]:=3.37:
g[2952]:=4.18:
g[2953]:=3.59:
g[2954]:=1.96:
g[2955]:=0.226:
g[2956]:=-1.1:
g[2957]:=-2.11:
g[2958]:=-3.11:
g[2959]:=-4.03:
g[2960]:=-4.27:
g[2961]:=-3.53:
g[2962]:=-2.2:
g[2963]:=-0.888:
g[2964]:=0.123:
g[2965]:=0.95:
g[2966]:=1.82:
g[2967]:=2.82:
g[2968]:=3.71:
g[2969]:=4.18:
g[2970]:=4.25:
g[2971]:=4.19:
g[2972]:=4.22:
g[2973]:=4.38:
g[2974]:=4.74:
g[2975]:=5.36:
g[2976]:=6.19:
g[2977]:=7.09:
g[2978]:=7.76:
g[2979]:=7.49:
g[2980]:=5.83:
g[2981]:=3.2:
g[2982]:=0.651:
g[2983]:=-1.11:
g[2984]:=-2.09:
g[2985]:=-2.84:
g[2986]:=-3.88:
g[2987]:=-5.33:
g[2988]:=-6.95:
g[2989]:=-8.17:
g[2990]:=-8.43:
g[2991]:=-7.71:
g[2992]:=-6.65:
g[2993]:=-5.8:
g[2994]:=-5.29:
g[2995]:=-4.9:
g[2996]:=-4.5:
g[2997]:=-4.26:
g[2998]:=-4.47:
g[2999]:=-5.09:
g[3000]:=-5.81:
g[3001]:=-6.21:
g[3002]:=-6.02:
g[3003]:=-5.36:
g[3004]:=-4.66:
g[3005]:=-4.17:
g[3006]:=-3.86:
g[3007]:=-3.57:
g[3008]:=-2.99:
g[3009]:=-1.73:
g[3010]:=0.0736:
g[3011]:=1.68:
g[3012]:=2.54:
g[3013]:=2.8:
g[3014]:=3.02:
g[3015]:=3.82:
g[3016]:=5.71:
g[3017]:=8.6:
g[3018]:=11.8:
g[3019]:=14.6:
g[3020]:=16.8:
g[3021]:=18.4:
g[3022]:=19.8:
g[3023]:=20.6:
g[3024]:=20.1:
g[3025]:=18.3:
g[3026]:=16:
g[3027]:=14.1:
g[3028]:=12.2:
g[3029]:=9.74:
g[3030]:=6.47:
g[3031]:=2.72:
g[3032]:=-0.877:
g[3033]:=-3.63:
g[3034]:=-5.19:
g[3035]:=-5.72:
g[3036]:=-5.76:
g[3037]:=-5.86:
g[3038]:=-6.27:
g[3039]:=-6.84:
g[3040]:=-7.43:
g[3041]:=-8.21:
g[3042]:=-9.38:
g[3043]:=-10.8:
g[3044]:=-12.3:
g[3045]:=-13.5:
g[3046]:=-13.7:
g[3047]:=-12.5:
g[3048]:=-10.6:
g[3049]:=-8.57:
g[3050]:=-6.81:
g[3051]:=-5:
g[3052]:=-2.85:
g[3053]:=-0.376:
g[3054]:=2.34:
g[3055]:=5.07:
g[3056]:=7.22:
g[3057]:=8.44:
g[3058]:=9.12:
g[3059]:=9.87:
g[3060]:=10.9:
g[3061]:=11.9:
g[3062]:=12.1:
g[3063]:=11.2:
g[3064]:=9.72:
g[3065]:=8.3:
g[3066]:=7.23:
g[3067]:=6.36:
g[3068]:=5.61:
g[3069]:=5.16:
g[3070]:=5.19:
g[3071]:=5.49:
g[3072]:=5.73:
g[3073]:=5.49:
g[3074]:=4.53:
g[3075]:=3.05:
g[3076]:=1.54:
g[3077]:=0.286:
g[3078]:=-0.755:
g[3079]:=-1.65:
g[3080]:=-2.19:
g[3081]:=-2.21:
g[3082]:=-1.9:
g[3083]:=-1.61:
g[3084]:=-1.46:
g[3085]:=-1.49:
g[3086]:=-1.85:
g[3087]:=-2.77:
g[3088]:=-4.1:
g[3089]:=-5.5:
g[3090]:=-6.72:
g[3091]:=-7.77:
g[3092]:=-8.82:
g[3093]:=-9.99:
g[3094]:=-11.2:
g[3095]:=-12.2:
g[3096]:=-12.2:
g[3097]:=-11.2:
g[3098]:=-9.95:
g[3099]:=-8.84:
g[3100]:=-8.06:
g[3101]:=-7.4:
g[3102]:=-6.69:
g[3103]:=-6.23:
g[3104]:=-6.52:
g[3105]:=-7.52:
g[3106]:=-8.76:
g[3107]:=-9.82:
g[3108]:=-10.7:
g[3109]:=-11.4:
g[3110]:=-11.6:
g[3111]:=-10.8:
g[3112]:=-8.76:
g[3113]:=-6.24:
g[3114]:=-3.83:
g[3115]:=-1.58:
g[3116]:=0.731:
g[3117]:=3.26:
g[3118]:=5.99:
g[3119]:=8.82:
g[3120]:=11.7:
g[3121]:=14.1:
g[3122]:=14.8:
g[3123]:=13.3:
g[3124]:=10.5:
g[3125]:=7.71:
g[3126]:=5.66:
g[3127]:=4.09:
g[3128]:=2.44:
g[3129]:=0.646:
g[3130]:=-0.424:
g[3131]:=0.00649:
g[3132]:=1.61:
g[3133]:=3.44:
g[3134]:=4.78:
g[3135]:=5.42:
g[3136]:=5.48:
g[3137]:=5.4:
g[3138]:=5.52:
g[3139]:=5.77:
g[3140]:=5.79:
g[3141]:=5.41:
g[3142]:=4.81:
g[3143]:=4.17:
g[3144]:=3.53:
g[3145]:=2.75:
g[3146]:=1.77:
g[3147]:=0.68:
g[3148]:=-0.415:
g[3149]:=-1.46:
g[3150]:=-2.49:
g[3151]:=-3.59:
g[3152]:=-4.94:
g[3153]:=-6.56:
g[3154]:=-8.3:
g[3155]:=-10:
g[3156]:=-11.6:
g[3157]:=-12.8:
g[3158]:=-13.3:
g[3159]:=-13:
g[3160]:=-12.3:
g[3161]:=-11.1:
g[3162]:=-8.96:
g[3163]:=-6.21:
g[3164]:=-3.34:
g[3165]:=-0.899:
g[3166]:=0.542:
g[3167]:=0.92:
g[3168]:=0.865:
g[3169]:=1.03:
g[3170]:=1.6:
g[3171]:=2.4:
g[3172]:=3.27:
g[3173]:=4.16:
g[3174]:=5.01:
g[3175]:=5.84:
g[3176]:=6.57:
g[3177]:=6.78:
g[3178]:=6.08:
g[3179]:=4.67:
g[3180]:=3.11:
g[3181]:=1.81:
g[3182]:=0.904:
g[3183]:=0.51:
g[3184]:=0.584:
g[3185]:=0.818:
g[3186]:=0.916:
g[3187]:=0.758:
g[3188]:=0.296:
g[3189]:=-0.424:
g[3190]:=-1.22:
g[3191]:=-1.9:
g[3192]:=-2.41:
g[3193]:=-2.7:
g[3194]:=-2.85:
g[3195]:=-2.95:
g[3196]:=-3.13:
g[3197]:=-3.47:
g[3198]:=-3.96:
g[3199]:=-4.54:
g[3200]:=-5.11:
g[3201]:=-5.62:
g[3202]:=-6.09:
g[3203]:=-6.57:
g[3204]:=-7.1:
g[3205]:=-7.87:
g[3206]:=-8.99:
g[3207]:=-10.4:
g[3208]:=-11.8:
g[3209]:=-12.6:
g[3210]:=-12.1:
g[3211]:=-10.7:
g[3212]:=-9.04:
g[3213]:=-7.13:
g[3214]:=-4.86:
g[3215]:=-2.3:
g[3216]:=-0.00445:
g[3217]:=1.3:
g[3218]:=1.51:
g[3219]:=1.28:
g[3220]:=1.27:
g[3221]:=1.71:
g[3222]:=2.47:
g[3223]:=3.32:
g[3224]:=4.01:
g[3225]:=4.18:
g[3226]:=3.56:
g[3227]:=2.32:
g[3228]:=0.981:
g[3229]:=-0.106:
g[3230]:=-0.962:
g[3231]:=-1.81:
g[3232]:=-2.85:
g[3233]:=-4.1:
g[3234]:=-5.46:
g[3235]:=-6.79:
g[3236]:=-7.8:
g[3237]:=-7.9:
g[3238]:=-6.72:
g[3239]:=-4.74:
g[3240]:=-2.77:
g[3241]:=-1.3:
g[3242]:=-0.409:
g[3243]:=0.142:
g[3244]:=0.746:
g[3245]:=1.59:
g[3246]:=2.61:
g[3247]:=3.63:
g[3248]:=4.36:
g[3249]:=4.45:
g[3250]:=3.9:
g[3251]:=3.05:
g[3252]:=2.34:
g[3253]:=1.88:
g[3254]:=1.59:
g[3255]:=1.37:
g[3256]:=1.16:
g[3257]:=0.905:
g[3258]:=0.614:
g[3259]:=0.388:
g[3260]:=0.331:
g[3261]:=0.441:
g[3262]:=0.617:
g[3263]:=0.76:
g[3264]:=0.853:
g[3265]:=0.898:
g[3266]:=0.868:
g[3267]:=0.752:
g[3268]:=0.595:
g[3269]:=0.453:
g[3270]:=0.341:
g[3271]:=0.221:
g[3272]:=-0.0332:
g[3273]:=-0.569:
g[3274]:=-1.38:
g[3275]:=-2.27:
g[3276]:=-3.09:
g[3277]:=-3.81:
g[3278]:=-4.49:
g[3279]:=-5.21:
g[3280]:=-5.81:
g[3281]:=-5.97:
g[3282]:=-5.56:
g[3283]:=-4.84:
g[3284]:=-4.07:
g[3285]:=-3.31:
g[3286]:=-2.51:
g[3287]:=-1.66:
g[3288]:=-0.742:
g[3289]:=0.216:
g[3290]:=1.2:
g[3291]:=2.19:
g[3292]:=3.17:
g[3293]:=3.99:
g[3294]:=4.18:
g[3295]:=3.49:
g[3296]:=2.29:
g[3297]:=1.11:
g[3298]:=0.205:
g[3299]:=-0.446:
g[3300]:=-0.892:
g[3301]:=-1.19:
g[3302]:=-1.47:
g[3303]:=-1.85:
g[3304]:=-2.25:
g[3305]:=-2.47:
g[3306]:=-2.36:
g[3307]:=-2.04:
g[3308]:=-1.67:
g[3309]:=-1.31:
g[3310]:=-0.9:
g[3311]:=-0.441:
g[3312]:=0.0508:
g[3313]:=0.569:
g[3314]:=1.08:
g[3315]:=1.45:
g[3316]:=1.5:
g[3317]:=1.23:
g[3318]:=0.812:
g[3319]:=0.464:
g[3320]:=0.237:
g[3321]:=0.119:
g[3322]:=0.152:
g[3323]:=0.332:
g[3324]:=0.559:
g[3325]:=0.749:
g[3326]:=0.878:
g[3327]:=0.982:
g[3328]:=1.11:
g[3329]:=1.26:
g[3330]:=1.27:
g[3331]:=0.969:
g[3332]:=0.397:
g[3333]:=-0.239:
g[3334]:=-0.802:
g[3335]:=-1.29:
g[3336]:=-1.75:
g[3337]:=-2.22:
g[3338]:=-2.65:
g[3339]:=-2.89:
g[3340]:=-2.83:
g[3341]:=-2.56:
g[3342]:=-2.19:
g[3343]:=-1.62:
g[3344]:=-0.727:
g[3345]:=0.359:
g[3346]:=1.46:
g[3347]:=2.44:
g[3348]:=3.06:
g[3349]:=3.12:
g[3350]:=2.74:
g[3351]:=2.28:
g[3352]:=2.11:
g[3353]:=2.51:
g[3354]:=3.54:
g[3355]:=4.86:
g[3356]:=6.11:
g[3357]:=7.06:
g[3358]:=7.37:
g[3359]:=6.72:
g[3360]:=5.34:
g[3361]:=3.85:
g[3362]:=2.66:
g[3363]:=1.89:
g[3364]:=1.51:
g[3365]:=1.37:
g[3366]:=1.2:
g[3367]:=0.868:
g[3368]:=0.39:
g[3369]:=-0.116:
g[3370]:=-0.541:
g[3371]:=-0.918:
g[3372]:=-1.44:
g[3373]:=-2.28:
g[3374]:=-3.36:
g[3375]:=-4.45:
g[3376]:=-5.17:
g[3377]:=-5.06:
g[3378]:=-4.1:
g[3379]:=-2.8:
g[3380]:=-1.68:
g[3381]:=-0.851:
g[3382]:=-0.174:
g[3383]:=0.422:
g[3384]:=0.833:
g[3385]:=1.02:
g[3386]:=1.09:
g[3387]:=1.16:
g[3388]:=1.28:
g[3389]:=1.41:
g[3390]:=1.51:
g[3391]:=1.61:
g[3392]:=1.9:
g[3393]:=2.64:
g[3394]:=3.71:
g[3395]:=4.62:
g[3396]:=4.88:
g[3397]:=4.51:
g[3398]:=3.92:
g[3399]:=3.52:
g[3400]:=3.37:
g[3401]:=3.35:
g[3402]:=3.27:
g[3403]:=3.06:
g[3404]:=2.9:
g[3405]:=3.1:
g[3406]:=3.72:
g[3407]:=4.54:
g[3408]:=5.29:
g[3409]:=5.9:
g[3410]:=6.29:
g[3411]:=6.3:
g[3412]:=5.88:
g[3413]:=5.28:
g[3414]:=4.75:
g[3415]:=4.39:
g[3416]:=4.15:
g[3417]:=4.02:
g[3418]:=3.92:
g[3419]:=3.77:
g[3420]:=3.57:
g[3421]:=3.37:
g[3422]:=3.17:
g[3423]:=2.92:
g[3424]:=2.34:
g[3425]:=1.25:
g[3426]:=-0.12:
g[3427]:=-1.45:
g[3428]:=-2.63:
g[3429]:=-3.67:
g[3430]:=-4.6:
g[3431]:=-5.45:
g[3432]:=-6.28:
g[3433]:=-7.15:
g[3434]:=-7.98:
g[3435]:=-8.36:
g[3436]:=-8:
g[3437]:=-7.07:
g[3438]:=-6.07:
g[3439]:=-5.29:
g[3440]:=-4.71:
g[3441]:=-4.14:
g[3442]:=-3.46:
g[3443]:=-2.59:
g[3444]:=-1.46:
g[3445]:=-0.0572:
g[3446]:=1.46:
g[3447]:=2.87:
g[3448]:=3.82:
g[3449]:=4.2:
g[3450]:=4.26:
g[3451]:=4.36:
g[3452]:=4.65:
g[3453]:=5.11:
g[3454]:=5.76:
g[3455]:=6.64:
g[3456]:=7.69:
g[3457]:=8.77:
g[3458]:=9.78:
g[3459]:=10.6:
g[3460]:=10.8:
g[3461]:=10.1:
g[3462]:=8.77:
g[3463]:=7.47:
g[3464]:=6.44:
g[3465]:=5.63:
g[3466]:=4.81:
g[3467]:=3.8:
g[3468]:=2.62:
g[3469]:=1.37:
g[3470]:=0.143:
g[3471]:=-1.01:
g[3472]:=-2.07:
g[3473]:=-3.01:
g[3474]:=-3.85:
g[3475]:=-4.67:
g[3476]:=-5.53:
g[3477]:=-6.43:
g[3478]:=-7.35:
g[3479]:=-8.25:
g[3480]:=-9.13:
g[3481]:=-9.98:
g[3482]:=-10.7:
g[3483]:=-10.9:
g[3484]:=-10.7:
g[3485]:=-10.3:
g[3486]:=-9.61:
g[3487]:=-8.7:
g[3488]:=-7.66:
g[3489]:=-6.63:
g[3490]:=-5.64:
g[3491]:=-4.64:
g[3492]:=-3.41:
g[3493]:=-1.7:
g[3494]:=0.453:
g[3495]:=2.75:
g[3496]:=4.92:
g[3497]:=6.68:
g[3498]:=7.86:
g[3499]:=8.62:
g[3500]:=9.23:
g[3501]:=9.65:
g[3502]:=9.74:
g[3503]:=9.56:
g[3504]:=9.3:
g[3505]:=9.06:
g[3506]:=8.74:
g[3507]:=8.14:
g[3508]:=7.22:
g[3509]:=6.15:
g[3510]:=5.13:
g[3511]:=4.19:
g[3512]:=3.24:
g[3513]:=2.11:
g[3514]:=0.785:
g[3515]:=-0.594:
g[3516]:=-1.84:
g[3517]:=-2.87:
g[3518]:=-3.68:
g[3519]:=-4.2:
g[3520]:=-4.37:
g[3521]:=-4.3:
g[3522]:=-4.22:
g[3523]:=-4.24:
g[3524]:=-4.32:
g[3525]:=-4.39:
g[3526]:=-4.52:
g[3527]:=-4.86:
g[3528]:=-5.41:
g[3529]:=-5.85:
g[3530]:=-5.79:
g[3531]:=-5.2:
g[3532]:=-4.46:
g[3533]:=-3.85:
g[3534]:=-3.35:
g[3535]:=-2.72:
g[3536]:=-1.82:
g[3537]:=-0.748:
g[3538]:=0.349:
g[3539]:=1.39:
g[3540]:=2.37:
g[3541]:=3.33:
g[3542]:=4.32:
g[3543]:=5.36:
g[3544]:=6.44:
g[3545]:=7.38:
g[3546]:=7.68:
g[3547]:=7.03:
g[3548]:=5.73:
g[3549]:=4.42:
g[3550]:=3.39:
g[3551]:=2.58:
g[3552]:=1.85:
g[3553]:=1.3:
g[3554]:=1.13:
g[3555]:=1.23:
g[3556]:=1.39:
g[3557]:=1.46:
g[3558]:=1.44:
g[3559]:=1.42:
g[3560]:=1.47:
g[3561]:=1.48:
g[3562]:=1.32:
g[3563]:=0.974:
g[3564]:=0.571:
g[3565]:=0.317:
g[3566]:=0.263:
g[3567]:=0.314:
g[3568]:=0.346:
g[3569]:=0.304:
g[3570]:=0.215:
g[3571]:=0.135:
g[3572]:=0.0883:
g[3573]:=0.08:
g[3574]:=0.0506:
g[3575]:=-0.208:
g[3576]:=-0.868:
g[3577]:=-1.84:
g[3578]:=-2.88:
g[3579]:=-3.81:
g[3580]:=-4.58:
g[3581]:=-4.98:
g[3582]:=-4.66:
g[3583]:=-3.7:
g[3584]:=-2.57:
g[3585]:=-1.61:
g[3586]:=-0.885:
g[3587]:=-0.232:
g[3588]:=0.53:
g[3589]:=1.44:
g[3590]:=2.41:
g[3591]:=3.22:
g[3592]:=3.6:
g[3593]:=3.54:
g[3594]:=3.32:
g[3595]:=3.21:
g[3596]:=3.24:
g[3597]:=3.33:
g[3598]:=3.38:
g[3599]:=3.36:
g[3600]:=3.21:
g[3601]:=2.94:
g[3602]:=2.28:
g[3603]:=1.51:
g[3604]:=0.789:
g[3605]:=0.152:
g[3606]:=-0.45:
g[3607]:=-1.05:
g[3608]:=-1.55:
g[3609]:=-1.76:
g[3610]:=-1.65:
g[3611]:=-1.43:
g[3612]:=-1.28:
g[3613]:=-1.22:
g[3614]:=-1.23:
g[3615]:=-1.31:
g[3616]:=-1.52:
g[3617]:=-1.85:
g[3618]:=-2.21:
g[3619]:=-2.52:
g[3620]:=-2.8:
g[3621]:=-3.08:
g[3622]:=-3.39:
g[3623]:=-3.68:
g[3624]:=-3.78:
g[3625]:=-3.62:
g[3626]:=-3.34:
g[3627]:=-3.06:
g[3628]:=-2.85:
g[3629]:=-2.7:
g[3630]:=-2.59:
g[3631]:=-2.59:
g[3632]:=-2.77:
g[3633]:=-3.08:
g[3634]:=-3.39:
g[3635]:=-3.66:
g[3636]:=-3.92:
g[3637]:=-4.17:
g[3638]:=-4.33:
g[3639]:=-4.25:
g[3640]:=-3.87:
g[3641]:=-3.37:
g[3642]:=-2.9:
g[3643]:=-2.52:
g[3644]:=-2.21:
g[3645]:=-2.02:
g[3646]:=-2.11:
g[3647]:=-2.49:
g[3648]:=-2.95:
g[3649]:=-3.33:
g[3650]:=-3.63:
g[3651]:=-3.9:
g[3652]:=-4.21:
g[3653]:=-4.59:
g[3654]:=-4.9:
g[3655]:=-4.88:
g[3656]:=-4.38:
g[3657]:=-3.56:
g[3658]:=-2.76:
g[3659]:=-2.12:
g[3660]:=-1.6:
g[3661]:=-1.1:
g[3662]:=-0.541:
g[3663]:=0.0895:
g[3664]:=0.727:
g[3665]:=1.27:
g[3666]:=1.69:
g[3667]:=2.04:
g[3668]:=2.39:
g[3669]:=2.78:
g[3670]:=3.21:
g[3671]:=3.67:
g[3672]:=4.22:
g[3673]:=4.9:
g[3674]:=5.65:
g[3675]:=6.39:
g[3676]:=7.07:
g[3677]:=7.72:
g[3678]:=8.29:
g[3679]:=8.76:
g[3680]:=9.14:
g[3681]:=9.41:
g[3682]:=9.55:
g[3683]:=9.6:
g[3684]:=9.64:
g[3685]:=9.7:
g[3686]:=9.76:
g[3687]:=9.74:
g[3688]:=9.56:
g[3689]:=9.24:
g[3690]:=8.9:
g[3691]:=8.6:
g[3692]:=8.36:
g[3693]:=8.14:
g[3694]:=7.89:
g[3695]:=7.56:
g[3696]:=6.99:
g[3697]:=6.15:
g[3698]:=5.18:
g[3699]:=4.25:
g[3700]:=3.44:
g[3701]:=2.81:
g[3702]:=2.48:
g[3703]:=2.38:
g[3704]:=2.36:
g[3705]:=2.26:
g[3706]:=2.07:
g[3707]:=1.86:
g[3708]:=1.66:
g[3709]:=1.41:
g[3710]:=1.12:
g[3711]:=0.802:
g[3712]:=0.491:
g[3713]:=0.198:
g[3714]:=-0.0871:
g[3715]:=-0.374:
g[3716]:=-0.7:
g[3717]:=-1.15:
g[3718]:=-1.75:
g[3719]:=-2.37:
g[3720]:=-2.78:
g[3721]:=-2.88:
g[3722]:=-2.83:
g[3723]:=-2.79:
g[3724]:=-2.81:
g[3725]:=-2.85:
g[3726]:=-2.84:
g[3727]:=-2.79:
g[3728]:=-2.71:
g[3729]:=-2.62:
g[3730]:=-2.56:
g[3731]:=-2.5:
g[3732]:=-2.46:
g[3733]:=-2.4:
g[3734]:=-2.36:
g[3735]:=-2.39:
g[3736]:=-2.56:
g[3737]:=-2.84:
g[3738]:=-3.13:
g[3739]:=-3.39:
g[3740]:=-3.64:
g[3741]:=-3.91:
g[3742]:=-4.22:
g[3743]:=-4.54:
g[3744]:=-4.87:
g[3745]:=-5.18:
g[3746]:=-5.47:
g[3747]:=-5.75:
g[3748]:=-5.97:
g[3749]:=-6.03:
g[3750]:=-5.87:
g[3751]:=-5.59:
g[3752]:=-5.34:
g[3753]:=-5.15:
g[3754]:=-5.01:
g[3755]:=-4.87:
g[3756]:=-4.65:
g[3757]:=-4.29:
g[3758]:=-3.73:
g[3759]:=-3.06:
g[3760]:=-2.42:
g[3761]:=-1.87:
g[3762]:=-1.44:
g[3763]:=-1.09:
g[3764]:=-0.829:
g[3765]:=-0.735:
g[3766]:=-0.842:
g[3767]:=-1.04:
g[3768]:=-1.21:
g[3769]:=-1.32:
g[3770]:=-1.41:
g[3771]:=-1.51:
g[3772]:=-1.64:
g[3773]:=-1.8:
g[3774]:=-1.98:
g[3775]:=-2.2:
g[3776]:=-2.44:
g[3777]:=-2.7:
g[3778]:=-2.93:
g[3779]:=-3.15:
g[3780]:=-3.35:
g[3781]:=-3.49:
g[3782]:=-3.45:
g[3783]:=-3.22:
g[3784]:=-2.9:
g[3785]:=-2.63:
g[3786]:=-2.49:
g[3787]:=-2.49:
g[3788]:=-2.55:
g[3789]:=-2.58:
g[3790]:=-2.56:
g[3791]:=-2.5:
g[3792]:=-2.45:
g[3793]:=-2.43:
g[3794]:=-2.4:
g[3795]:=-2.27:
g[3796]:=-1.97:
g[3797]:=-1.56:
g[3798]:=-1.15:
g[3799]:=-0.8:
g[3800]:=-0.503:
g[3801]:=-0.219:
g[3802]:=0.0442:
g[3803]:=0.247:
g[3804]:=0.391:
g[3805]:=0.511:
g[3806]:=0.633:
g[3807]:=0.766:
g[3808]:=0.895:
g[3809]:=0.946:
g[3810]:=0.829:
g[3811]:=0.549:
g[3812]:=0.221:
g[3813]:=-0.0637:
g[3814]:=-0.29:
g[3815]:=-0.483:
g[3816]:=-0.683:
g[3817]:=-0.909:
g[3818]:=-1.15:
g[3819]:=-1.38:
g[3820]:=-1.56:
g[3821]:=-1.57:
g[3822]:=-1.3:
g[3823]:=-0.819:
g[3824]:=-0.319:
g[3825]:=0.0849:
g[3826]:=0.401:
g[3827]:=0.697:
g[3828]:=1.02:
g[3829]:=1.38:
g[3830]:=1.75:
g[3831]:=2.06:
g[3832]:=2.15:
g[3833]:=1.96:
g[3834]:=1.6:
g[3835]:=1.24:
g[3836]:=0.977:
g[3837]:=0.791:
g[3838]:=0.632:
g[3839]:=0.506:
g[3840]:=0.433:
g[3841]:=0.404:
g[3842]:=0.384:
g[3843]:=0.344:
g[3844]:=0.295:
g[3845]:=0.254:
g[3846]:=0.219:
g[3847]:=0.172:
g[3848]:=0.0858:
g[3849]:=-0.0396:
g[3850]:=-0.172:
g[3851]:=-0.286:
g[3852]:=-0.384:
g[3853]:=-0.468:
g[3854]:=-0.55:
g[3855]:=-0.637:
g[3856]:=-0.716:
g[3857]:=-0.77:
g[3858]:=-0.767:
g[3859]:=-0.703:
g[3860]:=-0.619:
g[3861]:=-0.547:
g[3862]:=-0.495:
g[3863]:=-0.452:
g[3864]:=-0.403:
g[3865]:=-0.346:
g[3866]:=-0.286:
g[3867]:=-0.201:
g[3868]:=-0.0211:
g[3869]:=0.297:
g[3870]:=0.7:
g[3871]:=1.09:
g[3872]:=1.4:
g[3873]:=1.59:
g[3874]:=1.67:
g[3875]:=1.68:
g[3876]:=1.7:
g[3877]:=1.76:
g[3878]:=1.86:
g[3879]:=1.97:
g[3880]:=2.11:
g[3881]:=2.25:
g[3882]:=2.34:
g[3883]:=2.33:
g[3884]:=2.22:
g[3885]:=2.06:
g[3886]:=1.91:
g[3887]:=1.8:
g[3888]:=1.72:
g[3889]:=1.64:
g[3890]:=1.54:
g[3891]:=1.42:
g[3892]:=1.31:
g[3893]:=1.2:
g[3894]:=1.11:
g[3895]:=1.03:
g[3896]:=0.975:
g[3897]:=0.926:
g[3898]:=0.876:
g[3899]:=0.821:
g[3900]:=0.766:
g[3901]:=0.715:
g[3902]:=0.669:
g[3903]:=0.627:
g[3904]:=0.574:
g[3905]:=0.485:
g[3906]:=0.351:
g[3907]:=0.199:
g[3908]:=0.0605:
g[3909]:=-0.0463:
g[3910]:=-0.102:
g[3911]:=-0.101:
g[3912]:=-0.0694:
g[3913]:=-0.0418:
g[3914]:=-0.0331:
g[3915]:=-0.037:
g[3916]:=-0.0397:
g[3917]:=-0.0322:
g[3918]:=-0.0182:
g[3919]:=-0.0132:
g[3920]:=-0.0307:
g[3921]:=-0.0675:
g[3922]:=-0.107:
g[3923]:=-0.138:
g[3924]:=-0.159:
g[3925]:=-0.174:
g[3926]:=-0.19:
g[3927]:=-0.203:
g[3928]:=-0.201:
g[3929]:=-0.179:
g[3930]:=-0.144:
g[3931]:=-0.109:
g[3932]:=-0.0788:
g[3933]:=-0.0521:
g[3934]:=-0.0271:
g[3935]:=-0.00317:
g[3936]:=0.0205:
g[3937]:=0.0429:
g[3938]:=0.0622:
g[3939]:=0.0727:
g[3940]:=0.0679:
g[3941]:=0.0504:
g[3942]:=0.0302:
g[3943]:=0.0152:
g[3944]:=0.00669:
g[3945]:=0.00111:
g[3946]:=-0.00471:
g[3947]:=-0.0114:
g[3948]:=-0.018:
g[3949]:=-0.023:
g[3950]:=-0.0255:
g[3951]:=-0.0248:
g[3952]:=-0.0209:
g[3953]:=-0.0154:
g[3954]:=-0.00974:
g[3955]:=-0.00448:
g[3956]:=0.000799:
g[3957]:=0.00647:
g[3958]:=0.0128:
g[3959]:=0.0198:
g[3960]:=0.0263:
g[3961]:=0.0292:
g[3962]:=0.0264:
g[3963]:=0.0209:
g[3964]:=0.0188:
g[3965]:=0.0283:
g[3966]:=0.0532:
g[3967]:=0.0862:
g[3968]:=0.116:
g[3969]:=0.136:
g[3970]:=0.147:
g[3971]:=0.155:
g[3972]:=0.16:
g[3973]:=0.165:
g[3974]:=0.169:
g[3975]:=0.171:
g[3976]:=0.17:
g[3977]:=0.167:
g[3978]:=0.162:
g[3979]:=0.155:
g[3980]:=0.148:
g[3981]:=0.138:
g[3982]:=0.127:
g[3983]:=0.115:
g[3984]:=0.104:
g[3985]:=0.0954:
g[3986]:=0.0876:
g[3987]:=0.0804:
g[3988]:=0.0737:
g[3989]:=0.0678:
g[3990]:=0.0629:
g[3991]:=0.0589:
g[3992]:=0.0555:
g[3993]:=0.0527:
g[3994]:=0.0504:
g[3995]:=0.0484:
g[3996]:=0.0466:
g[3997]:=0.0446:
g[3998]:=0.0423:
g[3999]:=0.0396:
g[4000]:=0.0365:
4000
#Set up parameters
  xi:=0.05;
  M:= 1.0;      # mass
  R:= 40;         # number of steps
  delta__t:= 0.01;  # Time step
  b:=2*M;
0.5e-1
1.0
40
0.1e-1
2.0
# Set up Arrays for output, and
# insert zeroth entry
T:=Array(0..R):
for j from 0 to R do
T[j]:=0.02+(j)*0.5:
W:=Array(0..R):
W[j]:=(2*3.14/T[j]):
K:=Array(0..R):
K[j]:=M*(W[j])^2:
c:=Array(0..R):
c[j]:=(2*xi*(W[j])):
Khat:=Array(0..R):
Khat[j]:=K[j]+(c[j]*2/delta__t)+(4*M/(delta__t)^2):
a:=Array(0..R):
a[j]:=(4*M/delta__t)+(2*c[j]):
 p:= Array((0..N),0..R):
 for i from 0 to N-1 do
 for j from 0 to R-1 do
u:= Array(0..N,0..R):
 u__dot:= Array(0..N,0..R):
 u__doubledot:= Array(0..N,0..R):
 u[0,j]:= 0:
 u__dot[0,j]:= 0:
 p[i,j]:= M*g[i]:
u__doubledot[0,j]:= p[0,j]/M:
      deltaphat[i,j]:= (p[i+1,j]-p[i,j])+(a[j]*u__dot[i,j])+(b*u__doubledot[i,j]):
      deltau[i,j]:= deltaphat[i,j]/Khat[j]:
      deltau__dot[i,j]:= 200*(deltau[i,j])-(2*u__dot[i,j]):
      deltau__doubledot[i,j]:= 40000*deltau[i,j]-400*u__dot[i,j]-(2*u__doubledot[i.j]):
      u[i+1,j]:=u[i,j]+deltau[i,j]:
u__dot[i+1,j]:=u__dot[i,j]+deltau__dot[i,j]:
u__doubledot[i+1,j]:=u__doubledot[i,j]+deltau__doubledot[i,j]:
0.2e-1
.52
1.02
1.52
2.02
2.52
3.02
3.52
4.02
4.52
5.02
5.52
6.02
6.52
7.02
7.52
8.02
8.52
9.02
9.52
10.02
10.52
11.02
11.52
12.02
12.52
13.02
13.52
14.02
14.52
15.02
15.52
16.02
16.52
17.02
17.52
18.02
18.52
19.02
19.52
20.02
314.0000000
12.07692308
6.156862745
4.131578947
3.108910891
2.492063492
2.079470199
1.784090909
1.562189055
1.389380531
1.250996016
1.137681159
1.043189369
.9631901839
.8945868943
.8351063830
.7830423940
.7370892018
.6962305986
.6596638655
.6267465070
.5969581749
.5698729582
.5451388889
.5224625624
.5015974441
.4823348694
.4644970414
.4479315264
.4325068871
.4181091878
.4046391753
.3920099875
.3801452784
.3689776733
.3584474886
.3485016648
.3390928726
.3301787592
.3217213115
.3136863137
98596.00000
145.8520711
37.90695886
17.06994460
9.665326928
6.210380448
4.324196309
3.182980372
2.440434644
1.930378260
1.564991032
1.294318420
1.088244060
.9277353304
.8002857115
.6974026709
.6131553908
.5433004914
.4847370464
.4351564154
.3928111840
.3563590626
.3247551885
.2971764082
.2729671291
.2515999959
.2326469262
.2157575015
.2006426523
.1870622074
.1748152929
.1637328622
.1536718303
.1445104327
.1361445234
.1284846021
.1214534104
.1149839762
.1090180130
.1035046023
0.9839910340e-1
31.40000000
1.207692308
.6156862744
.4131578948
.3108910892
.2492063492
.2079470200
.1784090909
.1562189055
.1389380531
.1250996016
.1137681159
.1043189369
0.9631901840e-1
0.8945868944e-1
0.8351063830e-1
0.7830423940e-1
0.7370892018e-1
0.6962305986e-1
0.6596638656e-1
0.6267465070e-1
0.5969581748e-1
0.5698729582e-1
0.5451388888e-1
0.5224625624e-1
0.5015974440e-1
0.4823348694e-1
0.4644970414e-1
0.4479315264e-1
0.4325068872e-1
0.4181091878e-1
0.4046391752e-1
0.3920099876e-1
0.3801452784e-1
0.3689776732e-1
0.3584474886e-1
0.3485016648e-1
0.3390928726e-1
0.3301787592e-1
0.3217213116e-1
0.3136863136e-1
144876.0000
40387.39053
40161.04421
40099.70152
40071.84354
40056.05165
40045.91360
40038.86480
40033.68422
40029.71799
40026.58491
40024.04794
40021.95203
40020.19154
40018.69202
40017.39953
40016.27400
40015.28508
40014.40935
40013.62843
40012.92774
40012.29552
40011.72221
40011.19995
40010.72222
40010.28355
40009.87934
40009.50570
40009.15927
40008.83720
40008.53700
40008.25652
40007.99387
40007.74742
40007.51570
40007.29743
40007.09149
40006.89684
40006.71259
40006.53793
40006.37213
462.8000000
402.4153846
401.2313725
400.8263158
400.6217822
400.4984127
400.4158940
400.3568182
400.3124378
400.2778761
400.2501992
400.2275362
400.2086379
400.1926380
400.1789174
400.1670213
400.1566085
400.1474178
400.1392461
400.1319328
400.1253493
400.1193916
400.1139746
400.1090278
400.1044925
400.1003195
400.0964670
400.0928994
400.0895863
400.0865014
400.0836218
400.0809278
400.0784020
400.0760291
400.0737955
400.0716895
400.0697003
400.0678186
400.0660358
400.0643443
400.0627373
Error, Array index out of range
Download project(1)_cei_300.mwproject(1)_cei_300.mw
First 1026 1027 1028 1029 1030 1031 1032 Last Page 1028 of 2461
