Dear friends:
I am facing two problems
1. one is to get solution of the below system of ODE for L=100 (highlited as red) and
2. the other is I want the graph in the form of solid line not poit, asterisk etc.
restart; epsilon := .1; Pr := 1; beta := .1; Sc := 1; S := 1; L := 20;
for i from -L while i <= L do;
a[i] := 1.0*i/L;
for i2 from -L while i2 <= L do;
fw := a[i2];
Eq1[i2] := eval(diff(F(eta), eta, eta, eta)+F(eta)*(diff(F(eta), eta, eta))-(diff(F(eta), eta))^2+S*(epsilon-(diff(F(eta), eta)))+epsilon^2);
Eq2[i2] := eval((diff(G(eta), eta, eta))/Pr-G(eta)*(diff(F(eta), eta))+F(eta)*(diff(G(eta), eta)));
Eq3[i2] := eval(diff(H(eta), eta, eta)+Sc*(F(eta)*(diff(H(eta), eta))-beta*H(eta)));
IC[i2] := F(0) = a[i2], (D(F))(0) = 1, (D(F))(L) = epsilon, G(0) = 1, G(L) = 0, H(0) = 1, H(L) = 0;
dsys1[i2] := {Eq1[i2], Eq2[i2], Eq3[i2], IC[i2]};
dsol1[i2] := dsolve(dsys1[i2], numeric, output = listprocedure, range = 0 .. L);
dsol1x[i2] := subs(dsol1[i2], diff(F(eta), eta, eta));
dsol1y[i2] := subs(dsol1[i2], G(eta));
dsol1z[i2] := subs(dsol1[i2], H(eta)) end do;
for j from -L while j <= L do;
g[j] := eval(-dsol1x[j](0)) end do;
g6 := pointplot({seq([n/L, g[n]], n = -L .. L)}, symbol = asterisk, symbolsize = 15, color = red);
display(g6);
Please see the problem and correct as soon as possible. I am waiting your positive respone.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
Hello! I try to make friends physics package and matrixes. But I am faced with difficulties. To be more specific, to consider a code:
with(Physics):
Coordinates(X);
Setup(tensors = A[mu](X));
PDEtools:-declare(A(X), p0(X), pm(X), pp(X), pt(X), U(X), m5(X))
And then I create a matrix:
pt := proc (X) options operator, arrow; Matrix(2, 2, [[p0(X), sqrt(2)*pp(X)], [sqrt(2)*pm(X), -p0(X)]]) end proc;
It displays as:
Why do p0, pp, pm become function only one variable x1?
Interestingly that maple understands the next matrix:
Nevertheless even for function only one variable derivative works fine:
And I can construct more complicated functions:
But why is only one variable?
When I try this maple retuurns FAIL and does not evaluate the expression.
is(seq(tm[i] < (1/6)*Diameter[rør][i], i = 1 .. 17));
tm is numbers in mm and diameter is also numbers in mm
Diameter[rør] := [273.05*Unit('mm'), 219.08*Unit('mm'), 168.28*Unit('mm'), 114.3*Unit('mm'), 273.05*Unit('mm'), 219.08*Unit('mm'), 1066.8*Unit('mm'), 60.33*Unit('mm'), 219.08*Unit('mm'), 168.28*Unit('mm'), 168.28*Unit('mm'), 141.3*Unit('mm'), 168.28*Unit('mm'), 114.3*Unit('mm'), 114.3*Unit('mm'), 168.28*Unit('mm'), 168.28*Unit('mm')]
tm := 8.982892831*Unit('mm'), 4.189790007*Unit('mm'), 3.913902969*Unit('mm'), 3.620745836*Unit('mm'), 4.482892831*Unit('mm'), 4.189790007*Unit('mm'), 8.793627806*Unit('mm'), 3.327643012*Unit('mm'), 4.189790007*Unit('mm'), 3.913902969*Unit('mm'), 3.913902969*Unit('mm'), 3.767378711*Unit('mm'), 3.913902969*Unit('mm'), 3.620745836*Unit('mm'), 3.620745836*Unit('mm'), 3.913902969*Unit('mm'), 3.913902969*Unit('mm')
please help me with this thank you
Edited.
Fellas
I'm wondering how to produce the graphic in the
https://en.wikipedia.org/wiki/Lazy_caterer's_sequence.
my attempt:
caterers.mw
I've an implicit equation f(x,y,z)=0 resulting in a PLOT3D containing ISOSURFACE structure.
p := plots:-implicitplot3d(f,....)
As stated in docs an ISOSURFACE type of plots can't be exported.
So, question is, has anyone an idea on how to write a file containing points (xyz) from my plot p? Or any other way to export the computed points?
Thanks and regards
JiPé
I will try to explain with an example, lets say i have to solve 2 equations with 2 unknowns
P := solve({3*y+x, 2*x+3+y})
I would then like to do P[1] and P[2] to get the values, but instead it gives me "x=-9/5" which make me unable to use it for things like
P[1] + P[2]
Hope you all understand, and thanks for taking your time to read my problem
It is well known that fsolve usually increases (internally) Digits in order to obtain the desired accuracy.
But in the following example, it seems that fsolve highly exaggerates :-)
N:=40:
Digits:=100:
F:=expand(mul(x-k,k=1..N)):
f:=evalf(F):
S:=[fsolve(f,complex)];
Error, (in fsolve) Digits cannot exceed 38654705646
Note that the bug does not appear if e.g. F:=expand(mul(x-k-I, k=1..N)):
Hi, I'd like to know if is it possible to import questions from Maple TA into Maple and use them in quizes, for example. Your help will be highly appreciated. Thank you.
i have these commands:
with(VectorCalculus);
with(LinearAlgebra);
f := A-B+x^y/y;
g := x^y-y;
Solve({f = 0, g = 0}, {x, y});
              / /                     y    \         \
              | | y                  x     |         |
         Solve|< x  - y = 0, A - B + -- = 0 >, {x, y}|
              | |                    y     |         |
restart; with(plots); with(VectorCalculus); with(LinearAlgebra); f := A-B+x^y/y;  g := x^y-y; Solve({f = 0, g = 0}, {x, y});
but I can't get it to actually solve the equations. what do I do  ?
Hello. I have a problem with DEplot and I hope someone could help me with this:
How I can solve it for P?
P=i^(2)r+(&DifferentialD;)/(&DifferentialD; t) (1/(2)l(tetha)i^(2))+1/(2)i^(2)(&DifferentialD;l(tetha))/(&DifferentialD; theta) w
attach i(t) "corrente", l(t) "induttanza", theta "angular", w "rotary speed"graph of funtions
How to pdeplot Curl(A(x,y,z))=0 in maple
it has A1(x,y,z) , A2(x,y,z) and A3(x,y,z)
I am trying to create a custom component to find the minimum between 3 values.
I know that in Maple it is done by:
l := [5, 2, 3];
min(l[1], l[2], l[3]);
However I could not do the same with a custom component. I provided a screenshot below, where h(1), h(2), and h(3) are my input values and min(h1,h2,h3) is my output.
Thanks in advance,
Canberk
How can I produce the same output with something like alphadeg := alpharad * 180/Pi?
T := proc (p, q, R) alpharad = evalf[5](arccos((1/2)*(p^2+R^2-q^2)/(p*R))), alphadeg = 180*evalf[5](arccos((1/2)*(p^2+R^2-q^2)/(p*R)))/Pi end proc;
T(3, 4, 3.75);
           alpharad = 1.2515, alphadeg = 71.70566805
When I try alphadeg = alpharad * 180/Pi I get
Error, illegal use of an object as a name
Thanks! Les    AB59_20170205_Post.mw
I have a partial differential equation similar to the following:
Equation: f_x(x,y) + f_y(x,y) = f(x,y) + f(x,0),
Boundary value conditions: f(x,10) = f(10,y) = 0.
The solution is that f is identically equal to 0.
However, I am having trouble solving this equation in Maple. I type the following:
pde := diff(f(x, y), x)+diff(f(x, y), y) = f(x, y)+f(x, 0);
bv1 := f(x, 10) = 0;
bv2 := f(10, y) = 0;
solution := pdsolve(pde, {bv1, bv2}, numeric, time = x, range = 0 .. 10);
When Maple tries to evaluate the last expression, I get the error
Error, (in pdsolve/numeric/process_PDEs) PDEs can only contain dependent variables with direct dependence on the independent variables of the problem, got {f(x, 0)}
It seems to have difficulties with the expression "f(x,0)". Is there some trick to typing this in a way that makes Maple interpret it correctly?
Edit: I encounter the same problem, when I try to solve the ODE f'(x) = f(x) + f(0), where f(10) = 0.
Best regards.
First 1048 1049 1050 1051 1052 1053 1054 Last Page 1050 of 2463
