Greetings
How can I get LPSolve to output the unique subsets of {3,1,1,2,2,1} which sum to 5 (no recycling of set values)
partition.mw
(the code is a Yury/Love hybrid).
I have several maple worksheets (from the web) that have discussion blocks mixed within executable blocks.
All the executable blocks are delineated with a single '[' at the left while the discussion blocks do not.
How do I do this?
Tom Dean
So i got this code, im trying to iterate with jacobi and gaussseidel method.
H := HilbertMatrix(n, n, 1); b := Matrix(n, 1, proc (i) options operator, arrow; add(1/(i+j-1), j = 1 .. n) end proc); A := Matrix(n, 1, 1); Multiply(H, A); norm1H := norm(H, 1); norm2H := norm(H, 2); normHinf := norm(H, infinity); norm1b := norm(b, 1); norm2b := norm(b, 2); norminfb := norm(b, infinity); IterativeApproximate(H, initialapprox = Vector(n, 0), tolerance = 10^(-7), maxiterations = 10, method = gaussseidel)
But sadly no iteration gave me an answer, anyone knows wheres my mistake? i really help with this!
thanks in advance
I wish to apply several i-j constraints to an optimization problem that involves minimizing a function x[i,j].
Does anyone know of a simple way to exclude values for i and j? For instance, how do we specify the conditions, i not equal to j, i is not equal to 1, etc.?
Thanks in advance!
Hi all, i wan to write getCoeff() function get coefficient general.
Example
f := a^2*b^2*c^2 + 2*a^2*b^2 + 2*a^2*c^2 + 2*b^2*c^2 + a^2 - 6*a*b - 6*a*c + b^2 - 6*b*c + c^2 + 8
getCoeff(f,a^2*b^2*c^2) return 1.
getCoeff(f,a^2*b^2) return 2.
getCoeff(f,a*b) return -6.
getCoeff(f,a^2) return 1, ...
and how to get coefficients freedom ?
Thank you very much.
can anyone run my code?
please do it and send it for me.
thanks.
with(plottools): with(LinearAlgebra): with(plots):
ode := `assuming`([diff(Y(X), `$`(X, 2))+2*alpha*(diff(Y(X), X))+beta^2*Y(X) = 0], [alpha >= 0, beta >= 0, alpha+beta > 0]):
F := unapply(solve(subs({X = x, Y(X) = y, diff(Y(X), X) = yp, diff(Y(X), `$`(X, 2)) = yz}, ode), yz), x, y, yp):
Fp := unapply(solve(subs({X = x, Y(X) = y, diff(Y(X), X) = yp, diff(Y(X), `$`(X, 2)) = yz, diff(Y(X), `$`(X, 3)) = yt}, diff(ode, X)), yt), x, y, yp, yz):
Ni := seq(i, i = 0 .. 9), 15, 20:
for ni in Ni do
print(ni);
st := time[real]();
f[0, ni] := F(x[0], y[0, ni], yp[0, ni]);
fp[0, ni] := Fp(x[0], y[0, ni], yp[0, ni], f[0, ni]);
f[1, ni] := F(x[1], y[1, ni], yp[1, ni]);
fp[1, ni] := Fp(x[1], y[1, ni], yp[1, ni], f[1, ni]);
y[2, 0] := y[0, ni]+2*h*yp[0, ni]+(6/5)*f[0, ni]*h^2+(4/15)*fp[0, ni]*h^3+(4/5)*f[1, ni]*h^2+(4/15)*fp[1, ni]*h^3;
yp[2, 0] := yp[0, ni]+2*f[0, ni]*h+(2/3)*fp[0, ni]*h^2+(4/3)*fp[1, ni]*h^2;
for j to ni do
f[2, j-1] := F(x[2], y[2, j-1], yp[2, j-1]);
fp[2, j-1] := Fp(x[2], y[2, j-1], yp[2, j-1], f[2, j-1]);
y[2, j] := y[1, ni]+h*yp[1, ni]+(7/20)*f[1, ni]*h^2+(1/20)*fp[1, ni]*h^3+(3/20)*f[2, j-1]*h^2-(1/30)*fp[2, j-1]*h^3;
yp[2, j] := yp[1, ni]+(1/2)*f[1, ni]*h+(1/12)*fp[1, ni]*h^2+(1/2)*f[2, j-1]*h-(1/12)*fp[2, j-1]*h^2;
Ms := Matrix(4, 4); Ms[1, 3] := 1; Ms[2, 4] := 1;
y[2, ni] := collect(algsubs(h*alpha = H1, expand(algsubs(h*beta = H2, expand(y[2, ni])))), {y[0, ni], y[1, ni], yp[0, ni], yp[1, ni]});
Ms[3, 1] := coeff(y[2, ni], y[0, ni]);
Ms[3, 2] := coeff(y[2, ni], yp[0, ni])/h;
Ms[3, 3] := coeff(y[2, ni], y[1, ni]);
Ms[3, 4] := coeff(y[2, ni], yp[1, ni])/h;
hyp[2, ni] := collect(algsubs(h*alpha = H1, expand(algsubs(h*beta = H2, expand(h*yp[2, ni])))), {y[0, ni], y[1, ni], yp[0, ni], yp[1, ni]});
Ms[4, 1] := coeff(hyp[2, ni], y[0, ni]);
Ms[4, 2] := coeff(hyp[2, ni], yp[0, ni])/h;
Ms[4, 3] := coeff(hyp[2, ni], y[1, ni]);
Ms[4, 4] := coeff(hyp[2, ni], yp[1, ni])/h;
sol := Eigenvalues(Ms);
print(time[real]()-st);
st := time[real]();
SR[ni, 1] := implicitplot(max(seq(abs(sol[ii]), ii = 1 .. numelems(sol))) <= 1, H1 = 0 .. 3, H2 = 0 .. 3, filledregions, gridrefine = 3, axes = Boxed, view = [-2 .. 3, -3 .. 3], labels = [H[1], H[2]], labeldirections = ["horizontal", "vertical"]);
SR[ni, 2] := implicitplot(max(seq(abs(sol[ii]), ii = 1 .. numelems(sol))) <= 1, H1 = -2 .. 3, H2 = -2 .. 3, gridrefine = 3, axes = Boxed, view = [-2 .. 3, -3 .. 3], labels = [H[1], H[2]], labeldirections = ["horizontal", "vertical"]);
for i in Ni do
i;
display({SR[i, 1], SR[i, 2], line([-1, 0], [3, 0], color = red, linestyle = dash), line([0, -3], [0, 3], color = red, linestyle = dash)});
display({seq(SR[i, 2], i = 0 .. Ni)});
This is my code
restart; L := [];
for a from -10 to 10 do
for b from -10 to 10 do
for c from -10 to 10 do
k := (-a*b*c+a*b*z+a*c*y+b*c*x)/igcd(a*b, b*c, c*a, a*b*c); if a*b*c <> 0 then L := [op(L), [[a, 0, 0], [0, b, 0], [0, 0, c]], k*signum(lcoeff(k)) = 0] end if end do end do end do; nops(L); L
I think my code was error, because  a from -10 to 10.
[Delta][4*4]*{b}[4*1]={0}
Which {b} is an eigenvector
When I try the example from Maple Help for LPSolve (I use Windows)
with(Optimization);
LPSolve(-4*x-5*y, {0 <= x, 0 <= y, x+2*y <= 6, 5*x+4*y <= 20});
I do not get the same solution like in the example: [-19., [x = 2.66666666666667, y = 1.66666666666667]]
Instead I get
Warning, problem appears to be unbounded
            [0., [x = HFloat(0.0), y = HFloat(0.0)]]
My Professor uses the same version, but with Linux and do not have such problems. Why my installation does not solve the standart Help example?
Let D={ Z=x+I*y,    -Pi*(n+1/2) <= x, y <= Pi*(n+1/2)}
z belong the boundary of the previous square.
I would like to compute the modul of this function  f (z) =  coth(z) using the usual function  cos(x) cos(y), sinh(x) or cosh(y)  and show that | f(z)|  is less than one
Many thanks for any help
Hello, im a total begineer with maple and i need help defining a matrix, i need to get this into a matrix
 anyone knows how could i put this in a matriz of n x 1?   (the one thats only a column)
any help would be greatly appreciated
Thanks in advance!
Hello I was trying to manipulate maple to write a procedure checking a matrix , say A with n rows and n columns. That matrix A given any row/column the sum of the entries for every row and column are equal. For example matrix [(-1,2)(2,-1)], every row and column in this matrix sums to 1. The entries in the matrix can be any real number.
Put x=f1(t1,t2,t3), y=f2(t1,t2,t3), z=f3(t1,t2,t3).
The question is that: How to plot all points of form [x,y,z] with t1 in [a1,b1], t2 in [a2,b2], t3 in [a3,b3].
hi.
please help me for remover this problem.
-Float(infinity)*signum((5.*A3*A1-24.*A2^2)*A1/A2^2)''''
ReducedCantiler.mw
f := -(2/3)*eta^3+(1/2)*eta^2+eta; -1; g := -eta^2+1; -1; h := -eta^2+1; 1; F := proc (eta) options operator, arrow; A1*f end proc; 1; G := proc (eta) options operator, arrow; A2*g end proc; 1; H := proc (eta) options operator, arrow; A3*h end proc
Q1 := diff(F(eta), eta, eta, eta)+.5*H(eta)*((diff(F(eta), eta))^2+F(eta)*(diff(F(eta), eta, eta)))/G(eta)^2+2*(diff(G(eta), eta))*(diff(F(eta), eta, eta))/G(eta)-(diff(H(eta), eta))*(diff(F(eta), eta, eta))/H(eta); 1; Q2 := diff(G(eta), eta, eta)+H(eta)*((diff(F(eta), eta))*G(eta)+.5*F(eta)*(diff(eta, eta)))/G(eta)^2+2*(diff(G(eta), eta))^2/G(eta)-((diff(H(eta), eta))*(diff(H(eta), eta)))/H(eta)+(diff(F(eta), eta, eta))^2-(H(eta)/G(eta))^2; 1; Q3 := diff(H(eta), eta, eta)+(.5*1.3)*H(eta)*(5*(diff(F(eta), eta))*H(eta)+F(eta)*(diff(H(eta), eta)))/G(eta)^2+2*(diff(G(eta), eta))*(diff(H(eta), eta))/G(eta)-(diff(H(eta), eta))^2/H(eta)+(1.3*1.44)*H(eta)*(diff(F(eta), eta, eta))/G(eta)-(1.3*1.92)*(H(eta)/G(eta))^3
-2*A3+.65*A3*(5*A1*(-2*eta^2+eta+1)*A3*(-eta^2+1)-2*A1*(-(2/3)*eta^3+(1/2)*eta^2+eta)*A3*eta)/((-eta^2+1)*A2^2)+4*A3*eta^2/(-eta^2+1)+1.872*A3*A1*(-4*eta+1)/A2-2.496*A3^3/A2^3
Eq1 := int(Q1*f, eta = 0 .. 1);
-0.2600000000e-1*A3*(24.*A1*A2^2-65.*A1*A2*A3+64.*A3^2)/A2^3
sol := solve({Eq1 = 0, Eq2 = 0, Eq3 = 0}, {A1, A2, A3}); J := min(select(`>`, sol, 0))
Error, invalid input: `>` expects 2 arguments, but received 1
A11 := evalf(simplify(sol[1, 1])); A22 := evalf(simplify(sol[1, 2])); A33 := evalf(simplify(sol[1, 3]))
Download ReducedCantiler.mw
Hello.
I've just installed Maple 2015 and when I started it, this happened
It seemed that something was wrong with the graphics or java. But I really don't know what to do next.
Please help me, thank you.
First 1056 1057 1058 1059 1060 1061 1062 Last Page 1058 of 2463
