Say I define the following variables.
These are all nineth roots of unity. An equivalent definition would be:
In fact, the following code shows that aa[i] /a[i] =1 for all i, so one would concluse aa[i]=a[i]:
for i to 9 do
simplify(a[i]/aa[i])
end do
But when I try to check via "Equal":
I get as output
The problem goes even further since one representation is accepted as a solution of a linear equation system while the other is not.
Another curiosity:
gives just the same expression, whereas simplifying the same expression to the third power gives 0.
Guys,
I am not very familiar with Maple and have to solve quite a complex equation.
I have an equation which is complex ,containing I . I split this equation up in Re=0 an Im=0 . I have to get an answer in function of other parameters, in order to plot these... Maybe it s easier if you look at the work sheet
Student(NumericalAnalysis)
(module Student () description "a package to assist with the teaching and learning of standard undergraduate mathematics"; local ModuleLoad, localColors, GetColor, SelectColor, UpdateColor, GetCaption, colorNum, colorDefaults, Defaults, PlotOptionsWindow, InitAnimation, EndAnimation, DoPlayPause, IncrSpd, DecrSpd, Colours, CheckPoint, CheckRange, CheckTextField, CleanFloat, CombineRanges, EvaluateFunction, FindHRange, FindHRange3d, FindVRange, FindVRange3d, GetSpecPoints, EvaluateFunctionNumeric, EvaluateFunctionNumeric3d, VRangeCmp, MaximizePointList, MinimizePointList, FindHRange3dCrossSections, FindVRangeSymbolic, SymEvalFunc, SymLimits, FindAllSpecialPoints, FindHRangeRatPoly, GetRealDomain, GetTextField, GetVariable, IsColour, MapletGenericError, MapletNoInputError, MapletTypeError, ProcessCharacter, ProcessVisual, RequiredError, RemovePlotOptions, mapletColor, mapletDarkColor, mapletLightColor, mapletHelpColor, IsMac, ProcessColorNames; export _pexports, SetColors, SetDefault, SetDefaults, Precalculus, MultivariateCalculus, VectorCalculus, LinearAlgebra, Statistics, Calculus1, NumericalAnalysis, Basics; global x, y, z, r, t, p; option package, `Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2005`; end module)(NumericalAnalysis)
wn := 50
50
Np := 2
w0 := v0*wn
50*v0
V0 := 230*sqrt(2)
230*2^(1/2)
Ep0 := 1.5*V0
345.0*2^(1/2)
delta := 0
phi[q0] := 0
Iq0 := 0
L := proc (p) options operator, arrow; Ls*(p*tau[r]+1)/(p*tau[r]/sigma+1) end proc
Rs := 2.43
2.43
Rr := 2.43
2.43
Lr := 0.12e-1+.237
.249
Ls := Lr
.249
(14)
M := sqrt(.92*Ls^2)
.2388324099
(15)
sigma := 1-M^2/(Ls*Lr)
0.799999996e-1
(16)
tau[r] := sigma*Lr*wn/Rr
.4098765412
(17)
tau[s] := sigma*Ls*wn/Rs
.4098765412
(18)
alpha := tau[r]/tau[s]
1.000000000
(19)
assume(v0, 'real', nu, 'real')
345.0*2^(1/2)
(20)
phi[d0] := Ls*Id0-Ep0/w0
.249*Id0-6.900000000*2^(1/2)/v0
(21)
Vd0 := V0*sin(delta)
Vq0 := V0*cos(delta)
230*2^(1/2)
(23)
Id0 := (Rs*Vd0-wn*v0*Ls*(Vq0-Ep0))/(Ls^2*w0^2+Rs^2)
1431.7500*v0*2^(1/2)/(155.002500*v0^2+5.9049)
(24)
Dp := (Rs+p*wn*L(p))^2+v0*wn^2*L(p)^2
(2.43+12.450*p*(.4098765412*p+1)/(5.123456791*p+1))^2+155.002500*v0*(.4098765412*p+1)^2/(5.123456791*p+1)^2
(25)
simplify(Dp)
(26.04023075*p^4+254.1275544*p^3+(644.8103998+26.04023074*v0)*p^2+(121.014+127.0637772*v0)*p+5.9049+155.0025*v0)/(5.123456791*p+1.)^2
(26)
N := -(3/2)*Np*[[L(p)^2*(Id0*phi[d0]+Iq0*phi[q0])-L(p)*(phi[d0]^2-phi[q0]^2)]*(p^2+v0^2)*wn^2+Rs*[p*L(p)^2*(Id0^2+Iq0^2)-p*(phi[d0]^2+phi[q0]^2)]*wn+Rs^2*[L(p)*Iq0^2+L(p)*Id0^2-Id0*phi[d0]-Iq0*phi[q0]]]
[-7500*[88.76993175*(.4098765412*p+1)^2*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/((5.123456791*p+1)^2*(155.002500*v0^2+5.9049))-.249*(.4098765412*p+1)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2/(5.123456791*p+1)]*(p^2+v0^2)+[-18084126.16*(.4098765412*p+1)*v0^2/((5.123456791*p+1)*(155.002500*v0^2+5.9049)^2)+25363.02172*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/(155.002500*v0^2+5.9049)-92653238.97*p*(.4098765412*p+1)^2*v0^2/((5.123456791*p+1)^2*(155.002500*v0^2+5.9049)^2)+364.5000000*p*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2]]
(27)
char := (p*J*wn^2/Np*p)*Dp+N
1250*p^2*J*((2.43+12.450*p*(.4098765412*p+1)/(5.123456791*p+1))^2+155.002500*v0*(.4098765412*p+1)^2/(5.123456791*p+1)^2)+[-7500*[88.76993175*(.4098765412*p+1)^2*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/((5.123456791*p+1)^2*(155.002500*v0^2+5.9049))-.249*(.4098765412*p+1)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2/(5.123456791*p+1)]*(p^2+v0^2)+[-18084126.16*(.4098765412*p+1)*v0^2/((5.123456791*p+1)*(155.002500*v0^2+5.9049)^2)+25363.02172*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/(155.002500*v0^2+5.9049)-92653238.97*p*(.4098765412*p+1)^2*v0^2/((5.123456791*p+1)^2*(155.002500*v0^2+5.9049)^2)+364.5000000*p*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2]]
(28)
eval(char)
(29)
p := I*nu
I*nu
(30)
R := Re(char)
Re(-1250*nu^2*J*((2.43+(12.450*I)*nu*((.4098765412*I)*nu+1)/((5.123456791*I)*nu+1))^2+155.002500*v0*((.4098765412*I)*nu+1)^2/((5.123456791*I)*nu+1)^2)+[-7500*[88.76993175*((.4098765412*I)*nu+1)^2*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/(((5.123456791*I)*nu+1)^2*(155.002500*v0^2+5.9049))-.249*((.4098765412*I)*nu+1)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2/((5.123456791*I)*nu+1)]*(-nu^2+v0^2)+[-18084126.16*((.4098765412*I)*nu+1)*v0^2/(((5.123456791*I)*nu+1)*(155.002500*v0^2+5.9049)^2)+25363.02172*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/(155.002500*v0^2+5.9049)-(92653238.97*I)*nu*((.4098765412*I)*nu+1)^2*v0^2/(((5.123456791*I)*nu+1)^2*(155.002500*v0^2+5.9049)^2)+(364.5000000*I)*nu*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2]])
(31)
im := Im(char)
Im(-1250*nu^2*J*((2.43+(12.450*I)*nu*((.4098765412*I)*nu+1)/((5.123456791*I)*nu+1))^2+155.002500*v0*((.4098765412*I)*nu+1)^2/((5.123456791*I)*nu+1)^2)+[-7500*[88.76993175*((.4098765412*I)*nu+1)^2*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/(((5.123456791*I)*nu+1)^2*(155.002500*v0^2+5.9049))-.249*((.4098765412*I)*nu+1)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2/((5.123456791*I)*nu+1)]*(-nu^2+v0^2)+[-18084126.16*((.4098765412*I)*nu+1)*v0^2/(((5.123456791*I)*nu+1)*(155.002500*v0^2+5.9049)^2)+25363.02172*v0*2^(1/2)*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)/(155.002500*v0^2+5.9049)-(92653238.97*I)*nu*((.4098765412*I)*nu+1)^2*v0^2/(((5.123456791*I)*nu+1)^2*(155.002500*v0^2+5.9049)^2)+(364.5000000*I)*nu*(356.5057500*v0*2^(1/2)/(155.002500*v0^2+5.9049)-6.900000000*2^(1/2)/v0)^2]])
(32)
simplify(im)
Im(((32550.28842*nu^4*J-(158829.7215*I)*nu^3*J-193753.125*nu^2*J)*v0-32550.28844*nu^6*J+(317659.4430*I)*nu^5*J+806012.9998*nu^4*J-(151267.5000*I)*nu^3*J+(-7381.125*J+[196873.5712*[-177.5398635*((.4098765412*I)*nu+1.)^2*(713.0115000*v0^2+40.74381000)/(((5.123456791*I)*nu+1.)^2*(155.002500*v0^2+5.9049)*(155.0025000*v0^2+5.904900000))-.4979999998*((.4098765412*I)*nu+1)*(713.0115*v0^2+40.74381)^2/(((5.123456791*I)*nu+1.)*v0^2*(155.0025*v0^2+5.9049)^2)]*(-nu^2+v0^2)+[474704866.5*((.4098765412*I)*nu+1)*v0^2/(((5.123456791*I)*nu+1.)*(155.002500*v0^2+5.9049)^2)-26.24980949*(-36168252.32*v0^2-2066772.276)/(155.0025*v0^2+5.9049)^2+(2432129872.*I)*nu*((.4098765412*I)*nu+1.)^2*v0^2/(((5.123456791*I)*nu+1.)^2*(155.002500*v0^2+5.9049)^2)-(19136.11111*I)*nu*(713.0115*v0^2+40.74381)^2/(v0^2*(155.0025*v0^2+5.9049)^2)]])*nu^2+(10.24691358*I)*[-7500*[-177.5398635*((.4098765412*I)*nu+1.)^2*(713.0115000*v0^2+40.74381000)/(((5.123456791*I)*nu+1.)^2*(155.002500*v0^2+5.9049)*(155.0025000*v0^2+5.904900000))-.4979999998*((.4098765412*I)*nu+1)*(713.0115*v0^2+40.74381)^2/(((5.123456791*I)*nu+1.)*v0^2*(155.0025*v0^2+5.9049)^2)]*(-nu^2+v0^2)+[-18084126.16*((.4098765412*I)*nu+1)*v0^2/(((5.123456791*I)*nu+1.)*(155.002500*v0^2+5.9049)^2)+(-36168252.32*v0^2-2066772.276)/(155.0025*v0^2+5.9049)^2-(92653238.97*I)*nu*((.4098765412*I)*nu+1.)^2*v0^2/(((5.123456791*I)*nu+1.)^2*(155.002500*v0^2+5.9049)^2)+(728.9999996*I)*nu*(713.0115*v0^2+40.74381)^2/(v0^2*(155.0025*v0^2+5.9049)^2)]]*nu+[-7500*[-177.5398635*((.4098765412*I)*nu+1.)^2*(713.0115000*v0^2+40.74381000)/(((5.123456791*I)*nu+1.)^2*(155.002500*v0^2+5.9049)*(155.0025000*v0^2+5.904900000))-.4979999998*((.4098765412*I)*nu+1)*(713.0115*v0^2+40.74381)^2/(((5.123456791*I)*nu+1.)*v0^2*(155.0025*v0^2+5.9049)^2)]*(-nu^2+v0^2)+[-18084126.16*((.4098765412*I)*nu+1)*v0^2/(((5.123456791*I)*nu+1.)*(155.002500*v0^2+5.9049)^2)+(-36168252.32*v0^2-2066772.276)/(155.0025*v0^2+5.9049)^2-(92653238.97*I)*nu*((.4098765412*I)*nu+1.)^2*v0^2/(((5.123456791*I)*nu+1.)^2*(155.002500*v0^2+5.9049)^2)+(728.9999996*I)*nu*(713.0115*v0^2+40.74381)^2/(v0^2*(155.0025*v0^2+5.9049)^2)]])/((5.123456791*I)*nu+1.)^2)
(33)
solve(im = 0)
Warning, solve may be ignoring assumptions on the input variables.
Error, (in Engine:-Dispatch) badly formed input to solve: not fully algebraic
Error, (in fsolve) b is in the equation, and is not solved for
-I*b/l
(34)
Download operationele_inductanties.mwoperationele_inductanties.mw
How to find the integral of (x+y)/(x+y+z) over the part of the unit ball  centered at the origin which lies in the positive octant { x>=0 , y>=0, z>=0 } ? Numeric calculations suggest Pi/9.
How to find the double integral of sin(x^2)*cos(y^2) over the disk of radius R which is centered at the origin?
Here is my try
restart; evalf(VectorCalculus:-int(sin(x^2)*cos(y^2), [x, y] = Circle(`<,>`(0, 0), 1), inert), 15);
                       0.722091449378409
identify(%);
                       0.722091449378409
Hello people in mapleprimes,
I want to modify the following expression a to b. For it, I used c code.
But, as seen in d, just using c returns a. Originally, I intended phi being between 0 and 1, so
that 1-phi >0. Isn't any better way to modify a to b? and it is better to have maple sort expression remembering 1-phi to be positive, and to have maple give any priority to it in modifying a to b.
a:=(-2*theta+1)*phi/(phi-1)+theta;
b:=(2*theta-1)*phi/(-phi+1)+theta;
c:=simplify(-1*numer(op(1,aa)))/simplify((-1)*denom(op(1,aa)))+theta;
d:=simplify(c)
(-2*theta+1)*phi/(phi-1) + theta
I will be very glad if you borrow me your idea.
Thank you in advance.
We are trying to use a fortran subroutine in maple using external calling. I was able to get the 'multiply' example working. i.e. through the steps descibed here: http://www.mapleprimes.com/questions/203646-External-Calling-FORTRAN-Dll--Error
My mult.f looks like this:
    subroutine multiply(a,b)
    real a,b,mult
    mult=a*b
    return
    end
It simply takes two arguments (Real), and returns the product. I used the following commands to build the dll:
1. gfortran -c mult.f        ## This creates the object file mult.o, which is used later.
2. gfortran -shared -mrtd -o mult.dll mult.o ## This creates the dll and can be used in maple.
The command in maple looks like this :
mult := define_external("multiply",LIB="C:/shared/mult.dll",FORTRAN,'a'::(float[4]),'b'::(float[4]), RETURN::(float[4]));
And finally,
mult(3., 3.) ## works, if it gives the correct output.
Few things to note here are:
1. The dll has to be generated from inside the Cygwin64 shell, with cygwin64/bin in the system path.
2. This only worked for (some) 64-bit Maple version (Maple 2016 Standard).
The reason, I repeated a working example, was because I tried following the same steps for the more complicated case, however without success so far.  This post explains an approach on how to pass a subroutine as an argument to a fortran subroutine in the dll. http://www.mapleprimes.com/posts/37031-Calling-An-External-Routine-That-Needs However the post is old and the steps did not work for me.
My system is as follows:
1. Fortran file to generate the dll, takefunc.f , takes a subroutine as an argument and calls it.
    subroutine take(func)
    external func
    call func()
    end
2. Fortran driver file to verify that the dll generated through this program works:
    PROGRAM main
    external take, fun
    call take(fun)
    END
    SUBROUTINE fun()
    PRINT *, "This is a nice one"
    END
I want the step 2 to be performed in maple, i.e. fun() should be a maple procedure, and we should be able to use either WRAPPER or second dll to use take() in maple.
I want the process to work with latest maple versions and compilers, Windows7 64-bit or 32-bit (and hopefully later). F77 is fine.
Regret the long post, will keep this post updated if I make any progress. Any guidance in this matter is highly appreciated. Anyway to make define_external spew more debug information will also help.
- Chintan Pathak
Research Scientist,
ChemE, University of Washington.
Hi All,
To get EOM of a specific type of vibrating shell structure, I constructed the Hamilton equation of the system with messy and complex integrand (so many derivatives and variables are included). Now I have to calculate the variation of the Hamilton equation (del(int((T+U-V),t=t0..t1)=0) to get the EOMs and BCs of the system.
Is there anybody to know how to take a variation of such bulky integral in Maple?
Is there anyone to have experience in finding the EOM of shell structure using variational calculus in Maple?
Any comment will be useful.
with(Statistics):
with(Optimization):
Digits:=10:
lambda:=6328*10^(-10);
w0:=0.0005;
a0:=0.0004;
z0:= a0^2/(4*lambda);
N:=(a0^2)/(z0*lambda);
u0:=x->((2/(w0*sqrt(2)))*sqrt(1./Pi))*LaguerreL(0,0.,2.*(x*a0)^2/w0^2)*exp(-(x*a0)^2/w0^2);
u1:=y->evalf(I*2*Pi*N*exp(-I*Pi*N*((a0*y)/a0)^2)*evalf(int(x*u0(x)*exp(-I*Pi*N*x^2)*BesselJ(0,2*Pi*N*(a0*y)*x/a0),x=0..1)));
u2:=r2->evalf(I*2*Pi*N*exp(-I*Pi*N*(r2/a0)^2)*evalf(int(y*u1(y)*exp(-I*Pi*N*y^2)*BesselJ(0,2*Pi*N*r2*y/a0),y=0..1)));
u3:=r3->evalf(I*2*Pi*N*exp(-I*Pi*N*(r3/a0)^2)*evalf(int(z*u2(z)*exp(-I*Pi*N*z^2)*BesselJ(0,2*Pi*N*r3*z/a0),z=0..1)));
 plot(abs(u3(r3)),r3=-0.0008..0.0008);
I have a code to write the equation of the plane passing through three points
with(geom3d):
point(A,1,-1,3):
point(B,-15,-17,11):
point(C,2,1,0):
plane(P,[A,B,C],[x,y,z]):
n:=NormalVector(P):
cdn:=ilcm(op(denom~(n))):
n:=cdn*n:
k:=igcd(n[1],n[2],n[3]):
if n[1]<>0 then sign(n[1])*cdn/k*sort(Equation(P))
elif n[2] <> 0 then sign(n[2])*cdn/k*sort(Equation(P))
else sign(n[3])*cdn/k*sort(Equation(P))
end;
How do I write the equation of the plane passing through list of following three points?
L := [[[-12, 2, -1], [-11, 1, -5], [-10, -2, 3]], [[-12, 2, -1], [-11, 1, -5], [-10, 6, 3]], [[-12, 2, -1], [-11, 1, -5], [-9, 5, -7]], [[-12, 2, -1], [-11, 1, -5], [-9, 8, -4]], [[-12, 2, -1], [-11, 1, -5], [-7, -6, -2]], [[-12, 2, -1], [-11, 1, -5], [-7, -2, -8]], [[-12, 2, -1], [-11, 1, -5], [-7, -2, 6]], [[-12, 2, -1], [-11, 1, -5], [-7, 3, -9]], [[-12, 2, -1], [-11, 1, -5], [-7, 3, 7]], [[-12, 2, -1], [-11, 1, -5], [-7, 6, -8]], [[-12, 2, -1], [-11, 1, -5], [-7, 9, 3]], [[-12, 2, -1], [-11, 1, -5], [-7, 10, -2]], [[-12, 2, -1], [-11, 1, -5], [-6, -4, -7]], [[-12, 2, -1], [-11, 1, -5], [-6, -4, 5]], [[-12, 2, -1], [-11, 1, -5], [-6, 8, -7]], [[-12, 2, -1], [-11, 1, -5], [-6, 8, 5]], [[-12, 2, -1], [-11, 1, -5], [-4, -6, 3]], [[-12, 2, -1], [-11, 1, -5], [-4, -2, -9]], [[-12, 2, -1], [-11, 1, -5], [-4, -2, 7]], [[-12, 2, -1], [-11, 1, -5], [-4, 6, -9]], [[-12, 2, -1], [-11, 1, -5], [-4, 6, 7]], [[-12, 2, -1], [-11, 1, -5], [-4, 10, 3]], [[-12, 2, -1], [-11, 1, -5], [-2, -6, 3]], [[-12, 2, -1], [-11, 1, -5], [-2, 6, -9]], [[-12, 2, -1], [-11, 1, -5], [-2, 6, 7]], [[-12, 2, -1], [-11, 1, -5], [-2, 10, 3]], [[-12, 2, -1], [-11, 1, -5], [3, 5, -7]], [[-12, 2, -1], [-11, 1, -5], [3, 8, -4]], [[-12, 2, -1], [-11, 1, -5], [4, -2, 3]], [[-12, 2, -1], [-11, 1, -5], [4, 6, 3]], [[-12, 2, -1], [-11, 1, -5], [5, 6, -2]], [[-12, 2, -1], [-11, 1, 3], [-10, -2, -5]], [[-12, 2, -1], [-11, 1, 3], [-10, 6, -5]], [[-12, 2, -1], [-11, 1, 3], [-9, 5, -7]], [[-12, 2, -1], [-11, 1, 3], [-9, 8, -4]], [[-12, 2, -1], [-11, 1, 3], [-7, -6, -2]], [[-12, 2, -1], [-11, 1, 3], [-7, -2, -8]], [[-12, 2, -1], [-11, 1, 3], [-7, -2, 6]], [[-12, 2, -1], [-11, 1, 3], [-7, 6, -8]], [[-12, 2, -1], [-11, 1, 3], [-7, 9, -5]]]
Friends
I have plotted some figures and saved them yesterfay!
now once i opened them some nonsence digits appear on the figure! see the picture please. anyone has similar experience? how to solve it!
Dont make me disappointed maple! two days work is invain now !
**I am trying write a procedure (bit(n,k)) that print all the binary sequences with 2 following conditions:
  - Each of the sequences has the length of 'n'. (n elements)
 - k bits of n elements have the value 1. (all the remains have the value 0)
   Example: bit(3,2) and the result is ((101),(110),(011)).
**My code:
bit := proc (n, k)
     local one, index, i, d;
     global A;
     one := 0;
     index := 1;
     A := [seq(0, i = 1 .. n)];
     d := proc (index)
        if one = k or index = n+1 then return NULL; end if;
        for i from 0 to 1 do
              A[index] := i;
              if i = 1 then one := one+1; end if;
              if one = k then print(op(A)); end if;
             d(index+1);
             if i = 1 then one := one-1; A[index] := 0; end if;
     d(1);
>bit(5,1);
result:
0, 0, 0, 0, 1
That 's not the answer for the excercise. What is the problem?
I have a question that I hope someone can help with. We perform extreme value analysis on expressions. My this I mean that we evaluate expressions for each combination of min or max values of each variable in the expression. For example, the expression a*b+c*d has 4 variables and we would evaluate the expression for all of the 16 combinations of a,b,c, and d to determine the worst-case result. I understand that the worst case results may not occur at the extreme values of the variables, but that is a different question.
 What I would like to know is if there is a way to reduce the number of calculations by splitting the expression into independent parts. In the example above, the expression consists of 2 parts a*b and c*d. These parts could be evaluated separately. Each has 2 variables, and each would therefore requires  4 combinations of variables to determine the extreme values of the results. So in this case, the number of calculations is 4+4=8, which is half of the initial 16  runs as would be done with a full-factorial analysis. Also, because each calculation is done on only part of the original expression, each calculation takes less time.
Is there a way to find the independent parts of an arbitrary expression so that each independent part could be evaluated separately to speed processing?
In the right bottom corner of the Maple window, there is data on Time, Bytes, and Available. My task is supposed to perform computation, however the Time data reached the value of 33393.1 s (about 9 hours) and is not being updated (the value does not increase) anymore for at least half an hour. Is this normal or does it mean that something is wrong with my computation process? Windows Task Manager indicates that CPU Usage is 100% and mserver uses about 40-50%. The procedure I use (diffalg(04), Rosenfeld-Groebner) is such that I have no idea how much time the task will require.
I use Maple worksheet mode (not document mode). When I have a long line of code, or when I display some Maple source code, and if the line do not fit the current window size, the line will wrap to the next line, and make it hard to read the code.
Is there a way to configure the setting do that Maple keeps long line on same line and then I can use the horizontal scroll bar if I want to see the full line. This way the code is easier to read for me.
I looked at OPTIONS->DISPLAY and no see no such option. I also looked at few other options.
Here is a screen shot of what  I mean. Line 165 is too long and it wraps for example
Any one know if it possible to see the steps used by the limit() function as one does with many other functions such as dsolve and int ?  This is what I tried
infolevel[limit]:=5;
interface(verboseproc=3);
limit(x^2 *log(x),x=0);
But I see no steps, only the final answer. Are not all Maple functions possible to trace? How does one know which functions can generate trace and which do not?
I am using Maple 2016.1
I wanted to see something like:
let x=1/t, hence expression becomes  (-ln t)/t^2, now taking limit as t->infinity. Applying L'Hopital rule, limit t->infinity of -1/(2 t^2) which gives zero.
I assumed this is something what Maple does internally, (but there are other ways also) and wanted to see what Maple does.
First 1057 1058 1059 1060 1061 1062 1063 Last Page 1059 of 2463
