I was trying to write a procedure that would compute a simple linear equation using the Extended Euclidean Algorithm. I was thinking of a procedure like the following:
solveEeaMatrix := proc (a::list, b::list)
 local c::list;
 c := a -iquo(a[1],b[1])*b;
 print(c);
 while (c[1] <> gcd(a[1],b[1]) do
I am basically stuck at this part as
1) I don't know how to setup a multi-dimensional array that could dynamically grow(as a possible solution).
2) I can't come up with a recursive function that could possibly take care of this.
In short, if I am given for example an equation like: 84*x+203*y = 14
I will transform it into 2 linear equation as follow:
row0 := [203, 0, 1] row1 := [84, 1, 0] Subsequently, I will perform the following:
Where aand b are both lists and arguments of the procedure and cbeing another list and a local variable.
But I don't know how to do the following programmatically:
row3 := row1-iquo(row1[1], row2[1])*row2;
row4 := row2-iquo(row2[1], row3[1])*row3;
row5 := row3-iquo(row3[1], row4[1])*row4;
and so on ...
Any hint would be appreciated.
I have expression h1 as below:
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received shareman
"`u__1`(`xi__1`,`xi__2`,Zeta,t):=`u__0`(`xi__1`,`xi__2`,Zeta,t)+Zeta*`phi__1`(`xi__1`,`xi__2`,t):"
"`u__2`(`xi__1`,`xi__2`,Zeta,t):=`v__0`(`xi__1`,`xi__2`,Zeta,t)+Zeta*`phi__2`(`xi__1`,`xi__2`,t):"
"`u__3`(`xi__1`,`xi__2`,Zeta,t):=`w__0`(`xi__1`,`xi__2`,Zeta,t):"
`&phi;__n` := (diff(v__0(`&xi;__1`, `&xi;__2`, Zeta, t)*a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)-(diff(u__0(`&xi;__1`, `&xi;__2`, Zeta, t)*a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)))/(2*a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*a__2(`&xi;__1`, `&xi;__2`, Zeta, t))
`&varepsilon;0__1` := (diff(u__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)+v__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)+a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*w__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__1)/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;0__2` := (diff(v__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)+u__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)+a__2(`&xi;__1`, `&xi;__2`, Zeta, t)*w__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__2)/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;0__4` := (diff(w__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)+a__2(`&xi;__1`, `&xi;__2`, Zeta, t)*`&phi;__2`(`&xi;__1`, `&xi;__2`, t)-a__2(`&xi;__1`, `&xi;__2`, Zeta, t)*v__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__2)/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;0__5` := (diff(w__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)+a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*`&phi;__1`(`&xi;__1`, `&xi;__2`, t)-a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*u__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__1)/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)
`&omega;0__1` := (diff(v__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)-u__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)-`&phi;__n`
`&omega;0__2` := (diff(u__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)-v__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)+`&phi;__n`
`&varepsilon;1__1` := (diff(`&phi;__1`(`&xi;__1`, `&xi;__2`, t), `&xi;__1`)+`&phi;__2`(`&xi;__1`, `&xi;__2`, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;1__2` := (diff(`&phi;__2`(`&xi;__1`, `&xi;__2`, t), `&xi;__2`)+`&phi;__1`(`&xi;__1`, `&xi;__2`, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)
`&omega;1__1` := (diff(`&phi;__2`(`&xi;__1`, `&xi;__2`, t), `&xi;__1`)+`&phi;__1`(`&xi;__1`, `&xi;__2`, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)-`&phi;__n`/R
`&omega;1__2` := (diff(`&phi;__1`(`&xi;__1`, `&xi;__2`, t), `&xi;__2`)+`&phi;__2`(`&xi;__1`, `&xi;__2`, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)+`&phi;__n`/R
`&varepsilon;__1` := (Zeta*`&varepsilon;1__1`+`&varepsilon;0__1`)/(1+Zeta/R__1)
`&varepsilon;__2` := (Zeta*`&varepsilon;1__2`+`&varepsilon;0__2`)/(1+Zeta/R__2)
`&varepsilon;__4` := `&varepsilon;0__4`/(1+Zeta/R__2)
`&varepsilon;__5` := `&varepsilon;0__5`/(1+Zeta/R__1)
`&varepsilon;__6` := (Zeta*`&omega;1__1`+`&omega;0__1`)/(1+Zeta/R__1)+(Zeta*`&omega;1__2`+`&omega;0__2`)/(1+Zeta/R__2)
epsilon := Matrix([[`&varepsilon;__1`], [`&varepsilon;__2`], [`&varepsilon;__4`], [`&varepsilon;__5`], [`&varepsilon;__6`]])
with(LinearAlgebra)
e__1 := Matrix([[0, 0, 0, e1__15, 0], [0, 0, e1__24, 0, 0], [e1__31, e1__31, 0, 0, 0]])
e__5 := Matrix([[0, 0, 0, e5__15, 0], [0, 0, e5__24, 0, 0], [e5__31, e5__31, 0, 0, 0]])
E__1 := -Matrix([[diff(`&varphi;1`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__1`)], [diff(`&varphi;1`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__2`)], [diff(`&varphi;1`(`&xi;__1`, `&xi;__2`, Zeta), Zeta)]])
E__5 := -Matrix([[diff(`&varphi;5`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__1`)], [diff(`&varphi;5`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__2`)], [diff(`&varphi;5`(`&xi;__1`, `&xi;__2`, Zeta), Zeta)]])
`&epsilon;__1` := Matrix([[`&epsilon;1__11`, 0, 0], [0, `&epsilon;1__22`, 0], [0, 0, `&epsilon;1__33`]])
`&epsilon;` := Matrix([[`&epsilon;5__11`, 0, 0], [0, `&epsilon;5__22`, 0], [0, 0, `&epsilon;5__33`]])
f := Matrix([[f1, f2, f3]])
D__1 := Multiply(e__1, epsilon)+Multiply(`&epsilon;__1`, E__1)
D__5 := Multiply(e__5, epsilon)+Multiply(`&epsilon;__5`, E__5)
h1 := simplify((Multiply(Transpose(E__1), D__1))(1))
(-R__1*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*e1__31*(R__2+Zeta)*(phi__2(xi__1, xi__2, t)*Zeta+v__0(xi__1, xi__2, Zeta, t))*(diff(a__1(xi__1, xi__2, Zeta, t), xi__2))-(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*R__2*e1__31*(R__1+Zeta)*(phi__1(xi__1, xi__2, t)*Zeta+u__0(xi__1, xi__2, Zeta, t))*(diff(a__2(xi__1, xi__2, Zeta, t), xi__1))-a__2(xi__1, xi__2, Zeta, t)*R__1*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*e1__31*(R__2+Zeta)*(diff(u__0(xi__1, xi__2, Zeta, t), xi__1))-a__1(xi__1, xi__2, Zeta, t)*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*R__2*e1__31*(R__1+Zeta)*(diff(v__0(xi__1, xi__2, Zeta, t), xi__2))-a__2(xi__1, xi__2, Zeta, t)*R__1*(diff(varphi1(xi__1, xi__2, Zeta), xi__1))*e1__15*(R__2+Zeta)*(diff(w__0(xi__1, xi__2, Zeta, t), xi__1))-a__1(xi__1, xi__2, Zeta, t)*R__2*(diff(varphi1(xi__1, xi__2, Zeta), xi__2))*e1__24*(R__1+Zeta)*(diff(w__0(xi__1, xi__2, Zeta, t), xi__2))+`&epsilon;1__33`*a__1(xi__1, xi__2, Zeta, t)*a__2(xi__1, xi__2, Zeta, t)*(R__2+Zeta)*(R__1+Zeta)*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))^2-e1__31*(a__2(xi__1, xi__2, Zeta, t)*R__1*Zeta*(R__2+Zeta)*(diff(phi__1(xi__1, xi__2, t), xi__1))+a__1(xi__1, xi__2, Zeta, t)*(R__2*Zeta*(R__1+Zeta)*(diff(phi__2(xi__1, xi__2, t), xi__2))+a__2(xi__1, xi__2, Zeta, t)*w__0(xi__1, xi__2, Zeta, t)*(R__1+R__2+2*Zeta)))*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))+a__2(xi__1, xi__2, Zeta, t)*(`&epsilon;1__11`*(R__2+Zeta)*(R__1+Zeta)*(diff(varphi1(xi__1, xi__2, Zeta), xi__1))^2-e1__15*(R__2+Zeta)*(phi__1(xi__1, xi__2, t)*R__1-u__0(xi__1, xi__2, Zeta, t))*(diff(varphi1(xi__1, xi__2, Zeta), xi__1))+(R__1+Zeta)*(`&epsilon;1__22`*(R__2+Zeta)*(diff(varphi1(xi__1, xi__2, Zeta), xi__2))-e1__24*(phi__2(xi__1, xi__2, t)*R__2-v__0(xi__1, xi__2, Zeta, t)))*(diff(varphi1(xi__1, xi__2, Zeta), xi__2)))*a__1(xi__1, xi__2, Zeta, t))/(a__1(xi__1, xi__2, Zeta, t)*a__2(xi__1, xi__2, Zeta, t)*(R__1+Zeta)*(R__2+Zeta))
Download simplifymore.mw
How can i simplify h1 more in Maple?
I want to calculate the intersection between three circles.
I know that in this case i can calculate intersection of only the first and second equation, but I need this for a interactive component.
The command "intersection"[GEOMETRY] work only with 2 circles.
I did this but it doesn't work.
I used the command line betwen two poin, and i saw the graphic.
The line passes for my two point, but i I would like it started in the first point and finished in the second.
the question is
ODE5:= y(x)*diff(y(x),x,x) + (diff(y(x),x)^2=0
dsolve({ODE5,y(0)=4,D(y)(0)=7},y(x))
and my answer appears to be an integration! which is wrong
the correct answer : 2*(4+14*x)^(1/2)
Could someone tell me what did I do wrong? And how could I get to this result?
Thanks a lot!
guys, need your help. i've been trying to find 9 pamater which are psi1,psi2,psi3,m1,m2,m3,sigma1,sigma2,sigma3. I need to minimize one function. i have datas and several contraints. i will share this with you guys. Really need your help and i'll appreciate any suggestion. Thanks
data:
a(x):=qtopi[x];
this is my objective function:
fungsikerugian := sum((1-(1-(psi1*exp(-((x+1)/m1)^(m1/sigma1))+psi2*(1-exp(-((x+1)/m2)^(-m2/sigma2)))+psi3*exp(exp(-m3/sigma3)-exp((x+1-m3)/sigma3)))/(psi1*exp(-(x/m1)^(m1/sigma1))+psi2*(1-exp(-(x/m2)^(-m2/sigma2)))+psi3*exp(exp(-m3/sigma3)-exp((x-m3)/sigma3))))/a(x))^2, x = 0 .. 111);
these are my contraints
a := psi1+psi2+psi3 = 1;
b := 0 <= exp(-((x+1)/m1)^(m1/sigma1));
c := 1 >= exp(-((x+1)/m1)^(m1/sigma1));
d := 0 <= 1-exp(-((x+1)/m2)^(-m2/sigma2));
e := 1 >= 1-exp(-((x+1)/m2)^(-m2/sigma2));
f := 0 <= exp(exp(-m3/sigma3)-exp((x+1-m3)/sigma3));
g := 1 >= exp(exp(-m3/sigma3)-exp((x+1-m3)/sigma3));
h := 0 <= exp(-(x/m1)^(m1/sigma1));
i := 1 >= exp(-(x/m1)^(m1/sigma1));
j := 0 <= 1-exp(-(x/m2)^(-m2/sigma2));
k := 1 >= 1-exp(-(x/m2)^(-m2/sigma2));
l := 0 <= exp(exp(-m3/sigma3)-exp((x-m3)/sigma3));
m := 1 >= exp(exp(-m3/sigma3)-exp((x-m3)/sigma3));
n := 0 <= 1-(psi1*exp(-((x+1)/m1)^(m1/sigma1))+psi2*(1-exp(-((x+1)/m2)^(-m2/sigma2)))+psi3*exp(exp(-m3/sigma3)-exp((x+1-m3)/sigma3)))/(psi1*exp(-(x/m1)^(m1/sigma1))+psi2*(1-exp(-(x/m2)^(-m2/sigma2)))+psi3*exp(exp(-m3/sigma3)-exp((x-m3)/sigma3)));
o := 1 >= 1-(psi1*exp(-((x+1)/m1)^(m1/sigma1))+psi2*(1-exp(-((x+1)/m2)^(-m2/sigma2)))+psi3*exp(exp(-m3/sigma3)-exp((x+1-m3)/sigma3)))/(psi1*exp(-(x/m1)^(m1/sigma1))+psi2*(1-exp(-(x/m2)^(-m2/sigma2)))+psi3*exp(exp(-m3/sigma3)-exp((x-m3)/sigma3)));
i use this to solve that but seems to not going anywhere
NLPSolve(fungsikerugian, {a, b, c, d, e, f, g, h, i, j, k, l, m, n, o}, assume = nonnegative);
Hello people in mapleprimes,
I am using maple 2016's standard UI.
And, I write save command in the ending place there.
And, while I write a code, whenever I think I had better put a name of an expression on a list in another .mpl file, to refer it later, I scroll down the cursor to the ending of the worksheet, and write the name of the expression, and again I bring the cursor back to the place where I wrote an expression whose name I wrote among the arguments of save.
  But, this is a little inconvenient. I have to find the original place where I had been before I moved to the end of the worksheet. But, on the other hand, using a bookmark seems complicated. Isn't there any better way to go to the place of the save command, which is the end of the worksheet, and to go back to the original place soon.
I hope you will give any hint to me. Thanks in advance.
When I do
seq(a||i,i=1..3); Maple returns   a1, a2, a3
But  seq(a__i,i=1..3);  returns a__i, a__i, a__i
Is there a way to make the second example also return  a__1,a__2,a__3 ?
http://www.maplesoft.com/support/help/Maple/view.aspx?path=worksheet/documenting/2DMathShortcutKeys
thank you,
Maple 2016.2
I am not a math major, so may be I am missing something here. But for this ode:
(diff(y(x),x))^2=4 * y(x)
There ought to be (I think) 2 solutions (other than the singular one y(x)=0), due to the square root. i.e the ode becomes
   diff(y(x),x)= +-  2* sqrt(y(x))
So for the + case, there is one solution, and for the - case, there is another solution. But Maple dsolve only gives one solution (again, ignoring the singular solution for now):
eq:=(diff(y(x),x))^2=4 * y(x);
sol:=dsolve(eq,y(x));
     y(x) = _C1^2-2*_C1*x+x^2
In Mathematica, it gives both solutions
ode = (y'[x])^2 == 4 y[x];
DSolve[ode, y[x], x] // Simplify
    {  {y[x] -> (1/4)*(-2*x + C[1])^2},   {y[x] -> (1/4)*(2*x + C[1])^2}}
Both Maple and Mathematica solutions are correct ofcourse. But my question is why did not Maple give both (non-singular) solutions? and it only gave one?
Maple 2016.2
I'm seeing older posts bubling to the top without any apparent changes.  Perhaps spam is being added to the ends of them and then being deleted is the only thing I can think of.
I want to write a plane passing through a point (in list) and parallel to a plane.
L := [[-14, 2, 3], [-13, -3, 1], [-13, -3, 5], [-13, 0, -2]]:
 with(geom3d):
point(A, L[1]):
 plane(P, 2*x+3*y+z = 0, [x, y, z]):
 n := NormalVector(P):
Equation(plane(Q, [A, n], [x, y, z]));
I tried
t[i] := ([seq])(point(M, pt[]), pt in L):
Equation( plane(Q,t[i],n],[x,y,z]),i=1..nops(L));
It is not true. How can I repair it?
I am trying to use define_external to use a C dll from inside MAPLE. The C dll exports a function that has a argument of type function pointer which has a return type of pointer. The function itself returns pointers.
Pointers are needed as return types as the C function needs to return arrays.
When I try to pass the C function, as maple procedure as the argument, it errs saying "Error, (in rk4_vec) number expected for float[8] parameter, got proc () option remember; table( [( 1 ) = HFloat(1.0), ( 2 ) = HFloat(-0.0) ] ) 'procname(args)' end proc"
rk4_vec is as follows:
rk4_vec := define_external("rk4vec", 't0' :: float[8], 'm' :: integer[4], 'u0' :: ARRAY(1..2,datatype=float[8]), 'dt' :: float[8], 'f' :: PROC('t' :: float[8], 'm' :: integer[4], 'u' :: ARRAY(1..2,datatype=float[8]), 'RETURN' :: REF(float[8])), 'RETURN' ::REF(float[8]), "WRAPPER", LIB="rk4.dll");
rk4vec in C looks like this:
double *rk4vec ( double t0, int m, double u0[], double dt,
  double *f ( double t, int m, double u[] ) )
I am passing as :
rk4vec_test_f := proc(t, n, u)
local uprime :: REF(float[8]);
#uprime := Array(n);
uprime(1) := u(2);
uprime(2) := -u(1);
return uprime;
I have tried the RETURN type on the define_external call as : float[8], ARRAY(1..2, datatype=float[8]) , but that didnt work either. I got the idea of using REF from times2 example on this link.
Any guidance in this matter is highly appreciated.
Attached are the C file, the dll, maple worksheet. Tested on Windows, with 64-bit, Maple 2016 standard. rk4.zip
Funny, I can't seem to find a list of all available units in the help file.
Is there not a listed table of units somewhere?
**edit add**  conversion of units I mean.  ie.  meters, miles, gallons, litres, Pa, etc...
I wish to solve for k interms of x, e is a constant in the equation k=x+e*sin(k). Using the solve function, i got
RootOf(_Z-x-e*sin(_Z)) and using the function allvalues(RootOf(_Z-x-e*sin(_Z))) still gave the same expression in _Z. Please is there a way out because I need the value of  as a substitute to another equation. Any help will be highly appreciated.
Ì am trying to convert this [APOh.txt] originally coded for mathematica to maple. In mathematica i ran into severa problems in ploting the function etc.. Anyhow so far failed. The code calls inputs from the followin text document [APO-48-10.txt] I am new to maple and its still unfamiliar. Is this possible to convert to maple?
First 1054 1055 1056 1057 1058 1059 1060 Last Page 1056 of 2463
