I am going to solve the following systems of ODEs but get the error: Newton iteration is not converging.
Could you please share your idea with me. In the case of AA=-0.2,0,0.2,0.4,...; I could get the solution.
Thank you in advance.
Pr := 2; Le := 2; nn := 2; Nb := .1; Nt := .1; QQ := .1; SS := .1; BB := .1; CC := .1; Ec := .1; MM := .2;AA:=-0.4;
Eq1 := diff(f(eta), `$`(eta, 3))+f(eta).(diff(f(eta), `$`(eta, 2)))-2.*nn/(nn+1).((diff(f(eta), eta))^2)-MM.(diff(f(eta), eta)) = 0; Eq2 := 1/Pr.(diff(theta(eta), `$`(eta, 2)))+f(eta).(diff(theta(eta), eta))-4.*nn/(nn+1).(diff(f(eta), eta)).theta(eta)+Nb.(diff(theta(eta), eta)).(diff(h(eta), eta))+Nt.((diff(theta(eta), eta))^2)+Ec.((diff(f(eta), `$`(eta, 2)))^2)-QQ.theta(eta) = 0;
Eq3 := diff(h(eta), `$`(eta, 2))+Le.f(eta).(diff(h(eta), eta))+Nt/Nb.(diff(theta(eta), `$`(eta, 2))) = 0;
bcs := f(0) = SS, (D(f))(0) = 1+AA.((D@@2)(f))(0), theta(0) = 1+BB.(D(theta))(0), phi(0) = 1+CC.(D(phi))(0), (D(f))(etainf) = 0, theta(etainf) = 0, phi(etainf) = 0
Error, (in dsolve/numeric/ComputeSolution) Newton iteration is not converging
how to translate python code which use scipy, numpy to maple code
import numpy as np
from scipy.sparse.linalg import svds
from functools import partial
def emsvd(Y, k=None, tol=1E-3, maxiter=None):
    Approximate SVD on data with missing values via expectation-maximization
    Inputs:
    Y:          (nobs, ndim) data matrix, missing values denoted by NaN/Inf
    k:          number of singular values/vectors to find (default: k=ndim)
    tol:        convergence tolerance on change in trace norm
    maxiter:    maximum number of EM steps to perform (default: no limit)
    Returns:
    Y_hat:      (nobs, ndim) reconstructed data matrix
    mu_hat:     (ndim,) estimated column means for reconstructed data
    U, s, Vt:   singular values and vectors (see np.linalg.svd and
                scipy.sparse.linalg.svds for details)
    if k is None:
        svdmethod = partial(np.linalg.svd, full_matrices=False)
    else:
        svdmethod = partial(svds, k=k)
    if maxiter is None:
        maxiter = np.inf
    # initialize the missing values to their respective column means
    mu_hat = np.nanmean(Y, axis=0, keepdims=1)
    valid = np.isfinite(Y)
    Y_hat = np.where(valid, Y, mu_hat)
    halt = False
    ii = 1
    v_prev = 0
    while not halt:
        # SVD on filled-in data
        U, s, Vt = svdmethod(Y_hat - mu_hat)
        # impute missing values
        Y_hat[~valid] = (U.dot(np.diag(s)).dot(Vt) + mu_hat)[~valid]
        # update bias parameter
        mu_hat = Y_hat.mean(axis=0, keepdims=1)
        # test convergence using relative change in trace norm
        v = s.sum()
        if ii >= maxiter or ((v - v_prev) / v_prev) < tol:
            halt = True
        ii += 1
        v_prev = v
    return Y_hat, mu_hat, U, s, Vt
hi.how convert root of to explicit form.
w is a imaginary..
123.mw
restart; w := (1/2)*(2*d-5+I*sqrt(4*d-9))/(d-2)
(1/2)*(2*d-5+I*(4*d-9)^(1/2))/(d-2)
{Q1 = RootOf((2*I)*(4*d-9)^(1/2)*_Z*d-((2*d-5+I*(4*d-9)^(1/2))/(d-2).(d*(I*(4*d-9)^(1/2)+1)*_Z/((d-2)*b)))*b*d+2*((2*d-5+I*(4*d-9)^(1/2))/(d-2).(d*(I*(4*d-9)^(1/2)+1)*_Z/((d-2)*b)))*b-2*d*_Z), Q2 = -(1/2)*d*(I*(4*d-9)^(1/2)+1)*RootOf((2*I)*(4*d-9)^(1/2)*_Z*d-((2*d-5+I*(4*d-9)^(1/2))/(d-2).(d*(I*(4*d-9)^(1/2)+1)*_Z/((d-2)*b)))*b*d+2*((2*d-5+I*(4*d-9)^(1/2))/(d-2).(d*(I*(4*d-9)^(1/2)+1)*_Z/((d-2)*b)))*b-2*d*_Z)/((d-2)*b)}
Download 123.mw
Dear Community,
How could I specify a list of random colors using some kind of an RGB function, which then could be used in another command for coloring? I think of something like this:
myColors := [ seq( RGB ( [rint(0,255) , rint(0,255) , rint(0,255)] ) , j = 1 .. 20 ) ] :
which does not work of course :-)  This should produce me a list of 20 random colors.  What would be the right RGB color function?
Tx for the kind help in advance
best regards
Andras
Dear Community,
I generate two vectors and try to plot them one vs. the other ( ZPLOT vs. PREDS )  with the pointplot command. Unfortunately I get the message "points are not in the correct format" ... Probably a minor error, but it is unclear what format Maple expects here? What do I do wrong?
Tx. for the kind help in advance,
best regards
Andras
P.S. Maple file attached
Z_DAK_PROC.mw
Hello people in mapleprimes,
I tried to solve y=x^3 for x, expecting of getting a result of x^(1/3),
through using restart;assume(x::real,y::real);
b:=y=x^3;
solve(b,x);
But, the result was:
Warning, solve may be ignoring assumptions on the input variables.
             (1/3)    1  (1/3)   1    (1/2)  (1/3)
            y     , - - y      + - I 3      y     ,
                      2          2
              - - y      - - I 3      y
                2          2
It means that solve couldn't use the assumption of x and y being real.
On the other hand, reading RealDomain package, y^(1/3) is returned properly:
with(RealDomain):
solve(b,x);
                              (1/3)
                             y
What I want to ask you is
Aren't there ways other than using the RealDomain package, to obtain the solution of y^(1/3)?
I will be very glad if you give me answers.
Best wishes.
taro
I'm new to the physics package - wondering if i can tweak it a bit to look like things i'm used to:
is there a way to make Christoffel symbols print as upper case gamma, instead of  'G'?
KroneckerDelta print as lower case delta, instead of 'd'?
can i make the Schwarzschild metric look like it does in Hartle, Carroll, and others:
-(1 - 2M/r)dt^2 + (1-2M/r)^-1 + r^2(dtheta^2 + sin(theta)^2 dphi^2)
i know about setting the signature in Setup.
i have tried the 'Coordinates' command, but when i give it X=[t,r,theta,phi] i always seem to get back
[t,r,q,f]
i am running maple 2016
many thanks,
larry
I would like to get a symbolic result of each variable x,y and z for the following 3 nonlinear equations. Maple does not respond to the following code at all. (Not even an error report.)
eq1 := x^2+y^2+z^2-134*x+800*y-360*z+31489, 2;
eq2 := x^2+y^2+z^2-934*x+900*y-370*z+321789, 2;
eq3 := x^2+y^2+z^2-614*x+1350*y-1110*z+70048, 97;
solve({eq1, eq2, eq3}, {x, y, z});
P.S: Afterwards my intention is to solve these equaitons numerically for different variable values, and transfer to MatLab in order to plot animations and graphs.
     It is known that ODE boundary value problem is similar to the problem of solving systems of nonlinear equations. Equations are the boundary conditions, and the variables are the values of the initial data.
For example:
y '' = f (x, y, y '), 0 <= x <= 1,
y (0) = Y0, y (1) = Y1;
Where y (1) = Y1 is the equation, and Z0 is variable, (y '(0) = Z0).
     solve () and fsolve () are not directly suitable for such tasks. Directly should work the package of optimization in relation to a system of nonlinear equations. (Perhaps it has already been implemented in Maple.)
Personally, I am very small and unprofessional know Maple and cannot do it. Maybe there is someone who would be interested, and it will try to implement this approach to solving ODE boundary value problems?
I am trying to find a download for the ONEOptimal package for Maple (http://iopscience.iop.org/article/10.1088/0253-6102/61/2/03). I read the article but there is no download link to the file. Does anyone know where I can download the package?
I have a system of equations e.g.
A^2+B*A+C=0
where A,B,C are Matrices and I want to solve for A.
Sure I can write every equations in brakets [..=0], but isn'T it possible to just use the matrix notation?
I've been trying to numerically solve (and plot) this equation. Maple tells me that some matrix is singular - I have no idea, what I can do.
eq := diff(y(x), `$`(x, 3))-(diff(y(x), x))*(diff(y(x), x))+1 = 0;
cond := (D(y))(0) = 0, (D(y))(1) = 1, ((D@@2)(y))(0) = 0
de := dsolve({cond, eq}, y(x), numeric);
Error, (in dsolve/numeric/bvp) matrix is singular
How I can found stabilty of system by Routh, Jury, Liapunov, Nequist on maple?
The array is:
N := vector (20, x -> y[x]);
The maple creat the array
The other is:
Where y[x] are a list
I do plot
plot( M,N);
But the plot is many lines with the value of the array, i want the fist coordenates of the N with fist coordenate for the M in points or line.
Hi Maple community
I'm running an algorithm where a non-linear equation system must be solved, in this case is a 26x26 system.
After 16116 succesful previous computations, fsolve stops giving me results.
I checked why and I was first expecting that, for some reason, the 26x26 system had an error and I ended with something like 25x26 or vice versa. But that was not the case.
So I tried the command solve and it not only worked fine but also gave me two results, but I only need one. I guess I could check for the wrong solution and discard it, but I still wondering why fsolve is failing and if there is anything to help fsolve not to fail.
These are the set of equations if somebody wants to check them:
EQ[16117][1] := W[1, 16117]*(-0.3860115660e-1*HRa[1, 16117]-0.1876793978e-1*ga[1, 16117]+0.7836678184e-1) = 2.040147478*10^6*SR[1, 16118], W[1, 16117]*(-0.3915554290e-1*HRa[1, 16117]-0.1903748329e-1*ga[1, 16117]+0.8260795999e-1) = 3.876387504, W[1, 16117]*(-0.1876794098e-1*HRa[1, 16117]-0.9892449327e-2*ga[1, 16117]+0.3810204607e-1) = 2.040147478*10^6*v[1, 16118], HLa[1, 16117] = .9724029753*ga[1, 16117]+HRa[1, 16117], NRa[1, 16117] = 0.7006679273e-1*HRa[1, 16117]-.1803623678*ga[1, 16117]+1.002451672, NLa[1, 16117] = 0.7006679273e-1*HRa[1, 16117]+.2484955248*ga[1, 16117]+1.002451672, SL[2, 16118] = SR[1, 16118], fra[1, 16117] = HRa[1, 16117]-HLa[2, 16117], fra[1, 16117] = .25*NRa[1, 16117]+.25*NLa[2, 16117], ga[1, 16117] = 0.;
EQ[16117][2] := W[2, 16117]*(-0.3860115660e-1*HRa[2, 16117]-0.1876793978e-1*ga[2, 16117]+0.7836678184e-1) = -2.040147478*10^6*SL[2, 16118]+7.152482840, W[2, 16117]*(-0.3915554290e-1*HRa[2, 16117]-0.1903748329e-1*ga[2, 16117]+0.8260795999e-1) = 3.876387504, W[2, 16117]*(-0.1876794098e-1*HRa[2, 16117]-0.9892449327e-2*ga[2, 16117]+0.3810204607e-1) = -1.983845478*10^6*SL[2, 16118]+5.221405977, HLa[2, 16117] = .9724029753*ga[2, 16117]+HRa[2, 16117], NRa[2, 16117] = 0.7006679273e-1*HRa[2, 16117]-.1803623678*ga[2, 16117]+1.002451672, NLa[2, 16117] = 0.7006679273e-1*HRa[2, 16117]+.2484955248*ga[2, 16117]+1.002451672, SL[3, 16118] = 0.3505865589e-5, fra[2, 16117] = HRa[2, 16117]-HLa[3, 16117];
EQ[16117][3] := W[3, 16117]*(-0.3860115660e-1*HRa[3, 16117]-0.1876793978e-1*ga[3, 16117]+0.7836678184e-1) = -2.040147478*10^6*SL[3, 16118]+10.82168541, W[3, 16117]*(-0.3915554290e-1*HRa[3, 16117]-0.1903748329e-1*ga[3, 16117]+0.8260795999e-1) = 3.876387504, W[3, 16117]*(-0.1876794098e-1*HRa[3, 16117]-0.9892449327e-2*ga[3, 16117]+0.3810204607e-1) = -1.983845478*10^6*SL[3, 16118]+8.751240594, HLa[3, 16117] = .9724029753*ga[3, 16117]+HRa[3, 16117], NRa[3, 16117] = 0.7006679273e-1*HRa[3, 16117]-.1803623678*ga[3, 16117]+1.002451672, NLa[3, 16117] = 0.7006679273e-1*HRa[3, 16117]+.2484955248*ga[3, 16117]+1.002451672, SL[4, 16118] = 0.5304364281e-5, fra[3, 16117] = HRa[3, 16117];
And after these the solving command that I used was:
SOL[j]:=fsolve({seq(EQ[j][n],n=1..N)},indets({entries(EQ[j],nolist)},assignable(name)));
Which returns
SOL[j]:=
As I said, then I tried the solve command:
SOL[j]:=solve({seq(EQ[j][n],n=1..N)},indets({entries(EQ[j],nolist)},assignable(name)));
which returns:
SOL[16117] :=
{HLa[1, 16117] = 1.011251860, HLa[2, 16117] = .5007913055, HLa[3, 16117] = -0.4240068535e-1, HRa[1, 16117] = 1.011251860, HRa[2, 16117] = .8728245835, HRa[3, 16117] = .2686716410, NLa[1, 16117] = 1.073306847, NLa[2, 16117] = .9685353734, NLa[3, 16117] = .9417827567, NRa[1, 16117] = 1.073306847, NRa[2, 16117] = 1.132612831, NRa[3, 16117] = 1.078974668, SL[2, 16118] = 0.1737463747e-5, SL[3, 16118] = 0.3505865589e-5, SL[4, 16118] = 0.5304364281e-5, SR[1, 16118] = 0.1737463747e-5, W[1, 16117] = 90.12372195, W[2, 16117] = 69.57451714, W[3, 16117] = 49.58407210, fra[1, 16117] = .5104605550, fra[2, 16117] = .9152252689, fra[3, 16117] = .2686716410, ga[1, 16117] = 0., ga[2, 16117] = -.3825916698, ga[3, 16117] = -.3199006320, v[1, 16118] = 8.447574110*10^(-7)},
{HLa[1, 16117] = 3.043461992, HLa[2, 16117] = 2.386862361, HLa[3, 16117] = -0.4240068535e-1, HRa[1, 16117] = 3.043461992, HRa[2, 16117] = 1.087485894, HRa[3, 16117] = .2686716410, NLa[1, 16117] = 1.215697293, NLa[2, 16117] = 1.410701230, NLa[3, 16117] = .9417827567, NRa[1, 16117] = 1.215697293, NRa[2, 16117] = .8376385519, NRa[3, 16117] = 1.078974668, SL[2, 16118] = 0.2032780481e-5, SL[3, 16118] = 0.3505865589e-5, SL[4, 16118] = 0.5304364281e-5, SR[1, 16118] = 0.2032780481e-5, W[1, 16117] = -106.0268094, W[2, 16117] = 265.7250566, W[3, 16117] = 49.58407210, fra[1, 16117] = .6565996307, fra[2, 16117] = 1.129886580, fra[3, 16117] = .2686716410, ga[1, 16117] = 0., ga[2, 16117] = 1.336253076, ga[3, 16117] = -.3199006320, v[1, 16118] = 9.883410782*10^(-7)}
Thanks in advance for any recommendations and suggestions.
First 1144 1145 1146 1147 1148 1149 1150 Last Page 1146 of 2463
