I did some hypothesis testing exercises and I cross checked the result with Maple. I just used following vectors for an unpaired test
a := [88, 89, 92, 90, 90];
b := [92, 90, 91, 89, 91];
I ended up with the following solution:
HFloat(1.5225682336585966)
HFloat(-3.122568233658591)
for a 0.95 confidence interval.
Using
TwoSampleTTest(a, b, 0, confidence = .95, summarize = embed)
TwoSampleTTest(a, b, 0, confidence = .975, summarize = embed)
I get following results:
-2.75177 .. 1.15177
-3.13633 .. 1.53633
respectively. I can not explain the discrepancy.
Best regards,
Oliver
PS:
Maple Code in case files won´t be attached.
Unpaired t Test
Unpaired test-test dataset
The se² estimate is given by:
se²=var(a)+var(b)+2*cov(a*b)=var(a)+var(b)
se²=
sigma[a]^2/Na+sigma[b]^2/Nb;
with Na, Nb being the length of vector a and b respectively.
                             2                              2
  sigma[[88, 89, 92, 90, 90]]    sigma[[92, 90, 91, 89, 91]]
               Na                             Nb
sigma[a]^2;
sigma[b]^2;
 are approximated by
S[a]^2;
S[b]^2;
                    S[[88, 89, 92, 90, 90]]
                    S[[92, 90, 91, 89, 91]]
with
S[X]^2;
 defined as
S[X]*`²` = (sum(X[i]-(sum(X[j], j = 1 .. N))/N, i = 1 .. N))^2/N;
                             S[X]
                      /      /         N       \\
                      |  N   |        \        ||
                      | \    |        /    X[j]||
                      | /    |       j = 1     ||
                      |----- |X[i] - ----------||
                      \i = 1 \           N     //
             S[X] ᅡᄇ = ----------------------------
                                   N
with(Statistics);
Sa := Variance(a);
                   HFloat(2.1999999999999993)
Sb := Variance(b);
                   HFloat(1.3000000000000003)
Now we are ready to do hypothesis testing (0.95).
We have (with k=min(Na,Nb)=5):
C = mean(a)-mean(b); Deviation := t_(alpha/a, k-1)*se(Sa/k-Sb/k);
c := Mean(a)-Mean(b); deviation := 2.776*sqrt((1/5)*Variance(a)+(1/5)*Variance(b));
                  HFloat(-0.7999999999999972)
                   HFloat(2.3225682336585938)
upperlimit := c+deviation; lowerlimit := c-deviation;
Execution of built in student test
TwoSampleTTest(a, b, 0, confidence = .95, summarize = embed);
How can I modify the appearance of the arrowheads on the vectors displayed in phaseportrai? In particular, how can I "fill in" the arrowheads so that the arrowhead is not just an outline?
My code is:
phaseportrait([D(x)(t)=-0.4*x(t)+(0.5+4*x(t))*y(t),D(y)(t)=0.4*x(t)-(4.5+4*x(t))*y(t)],[x(t),y(t)],t=0..100,[[x(0)=1,y(0)=0.0]],x=0..1,y=0..0.1,stepsize=0.01,scaling=UNCONSTRAINED,linecolour=BLACK,dirgrid=[17,17],linestyle=1,arrows=SLIM,axes=BOXED);
Hi evrey ones in pdsolve we have these commande to use U(x,t)
> U:= subs(pds:-value(output=listprocedure), u(x,t));
  id like to get du(x,t)/dt
i tried these
U:= subs(pds:-value(output=listprocedure), du(x,t)/dt);  but is not work
thank you
I want to draw  plot y(x) against x but I can't. a, b , _C1 are parameter.
where i can found oscilloscope icon for cisuit simulation?thanks
I am unable to solve the attached optimal control problem,please any one who many help  me in guideing .tnx
unprotect('gamma');
L:=b[1]*c(t)+b[2]*i(t)+w[1]*(u[1])^2/2+w[2]*(u[2])^2/2+w[3]*(u[3])^2/2;
1 2 1 2 1 2
b[1] c(t) + b[2] i(t) + - w[1] u[1] + - w[2] u[2] + - w[3] u[3]
2 2 2
H:=L+lambda[1](t)*((1-p*Psi)*tau+phi* v + delta *r-lambda*(1-u[3])*s-u[1]*varphi*s -mu*s ) +lambda[2](t)*(p*Psi*tau + u[1]*vartheta*s -gamma*lambda* (1-u[3])*v-(mu+phi)*v ) +lambda[3](t)*( (1-u[3])*rho*lambda* (s +gamma*v)+(1-q)* u[2]*eta*i -(mu +beta +chi)*c ) +lambda[4](t)* ((1-rho)*(1-u[3])*lambda*( s +gamma*v) +chi*c - u[2]*eta*i - (mu +alpha )*i) +lambda[5](t)*( beta*c + u[2]*q*eta*i -(mu +delta)*r);
1 2 1 2 1 2
b[1] c(t) + b[2] i(t) + - w[1] u[1] + - w[2] u[2] + - w[3] u[3] + lambda[1](t
2 2 2
) ((1 - p Psi) tau + phi v + delta r - lambda (1 - u[3]) s - u[1] varphi s
- mu s) + lambda[2](t) (p Psi tau + u[1] vartheta s
- gamma lambda (1 - u[3]) v - (mu + phi) v) + lambda[3](t) ((1 - u[3]) rho
lambda (s + gamma v) + (1 - q) u[2] eta i - (mu + beta + chi) c) + lambda[4](t
) ((1 - rho) (1 - u[3]) lambda (s + gamma v) + chi c - u[2] eta i
- (mu + alpha) i) + lambda[5](t) (beta c + u[2] q eta i - (mu + delta) r)
du1:=diff(H,u[1]);
w[1] u[1] - lambda[1](t) varphi s + lambda[2](t) vartheta s
du2:=diff(H,u[2]);du3:=diff(H,u[3]);
w[2] u[2] + lambda[3](t) (1 - q) eta i - lambda[4](t) eta i
+ lambda[5](t) q eta i
w[3] u[3] + lambda[1](t) lambda s + lambda[2](t) gamma lambda v
- lambda[3](t) rho lambda (s + gamma v)
- lambda[4](t) (1 - rho) lambda (s + gamma v)
ddu1 := -A[1] u[1] + psi[1](t) beta x[1] x[3] - psi[2](t) beta x[1] x[3]
ddu2 := -A[2] u[2] - psi[3](t) k x[2]
sol_u1 := solve(du1, u[1]);
s(t) (lambda[1](t) varphi - lambda[2](t) vartheta)
w[1]
sol_u2 := solve(du2, u[2]);sol_u3 := solve(du3, u[3]);
eta i (-lambda[3](t) + lambda[3](t) q + lambda[4](t) - lambda[5](t) q)
w[2]
---- (lambda (-lambda[1](t) s - lambda[2](t) gamma v + lambda[3](t) rho s
w[3]
+ lambda[3](t) rho gamma v + lambda[4](t) s + lambda[4](t) gamma v
- lambda[4](t) rho s - lambda[4](t) rho gamma v))
Dx2:=subs(u[1]= s*(lambda[1](t)*varphi-lambda[2](t)*vartheta)/w[1] ,u[2]= eta*i*(-lambda[3](t)+lambda[3](t)*q+lambda[4](t)-lambda[5](t)*q)/w[2], u[3]=-lambda*(lambda[1](t)*s+lambda[2](t)*gamma*v-lambda[3](t)*rho*s-lambda[3](t)*rho*gamma*v-lambda[4](t)*s-lambda[4](t)*gamma*v+lambda[4](t)*rho*s+lambda[4](t)*rho*gamma*v)/w[3] ,H );
2 2
s (lambda[1](t) varphi - lambda[2](t) vartheta)
b[1] c(t) + b[2] i(t) + -------------------------------------------------
2 w[1]
2 2 2
2 w[2]
1 / 2
------ \lambda (lambda[1](t) s + lambda[2](t) gamma v - lambda[3](t) rho s
2 w[3]
- lambda[3](t) rho gamma v - lambda[4](t) s - lambda[4](t) gamma v
+ lambda[4](t) rho s + lambda[4](t) rho gamma v)^2/ + lambda[1](t) |(1
/ 1
- p Psi) tau + phi v + delta r - lambda |1 + ---- (lambda (lambda[1](t) s
\ w[3]
+ lambda[2](t) gamma v - lambda[3](t) rho s - lambda[3](t) rho gamma v
- lambda[4](t) s - lambda[4](t) gamma v + lambda[4](t) rho s
+ lambda[4](t) rho gamma v))| s
2 \
s (lambda[1](t) varphi - lambda[2](t) vartheta) varphi |
- ------------------------------------------------------- - mu s| +
w[1] /
lambda[2](t) |p Psi tau
s (lambda[1](t) varphi - lambda[2](t) vartheta) vartheta /
+ --------------------------------------------------------- - gamma lambda |1 +
w[1] \
---- (lambda (lambda[1](t) s + lambda[2](t) gamma v - lambda[3](t) rho s
w[3]
+ lambda[4](t) rho s + lambda[4](t) rho gamma v))| v - (mu + phi) v| +
// 1
lambda[3](t) ||1 + ---- (lambda (lambda[1](t) s + lambda[2](t) gamma v
\\ w[3]
- lambda[3](t) rho s - lambda[3](t) rho gamma v - lambda[4](t) s
- lambda[4](t) gamma v + lambda[4](t) rho s + lambda[4](t) rho gamma v))|
1 / 2 2
rho lambda (s + gamma v) + ---- \(1 - q) eta i (-lambda[3](t)
w[2]
+ lambda[3](t) q + lambda[4](t) - lambda[5](t) q)/ - (mu + beta + chi) c| +
| / 1
lambda[4](t) |(1 - rho) |1 + ---- (lambda (lambda[1](t) s
\ \ w[3]
+ lambda[4](t) rho gamma v))| lambda (s + gamma v) + chi c
2 2
w[2]
- (mu + alpha) i| + lambda[5](t) |beta c
2 2
eta i (-lambda[3](t) + lambda[3](t) q + lambda[4](t) - lambda[5](t) q) q
w[2]
- (mu + delta) r|
ode1:=diff(lambda[1](t),t)=-diff(H,s);ode2:=diff(lambda[2](t),t)=-diff(H,v);ode3:=diff(psi[3](t),t)=-diff(H,c);ode4:=diff(lambda[4](t),t)=-diff(H,i);ode5:=diff(lambda[5](t),t)=-diff(H,r);
d
--- lambda[1](t) = -lambda[1](t) (-lambda (1 - u[3]) - u[1] varphi - mu)
dt
- lambda[2](t) u[1] vartheta - lambda[3](t) (1 - u[3]) rho lambda
- lambda[4](t) (1 - rho) (1 - u[3]) lambda
d
--- lambda[2](t) = -lambda[1](t) phi
dt
- lambda[2](t) (-gamma lambda (1 - u[3]) - mu - phi)
- lambda[3](t) (1 - u[3]) rho lambda gamma
- lambda[4](t) (1 - rho) (1 - u[3]) lambda gamma
d
--- psi[3](t) = -lambda[3](t) (-mu - beta - chi) - lambda[4](t) chi
dt
- lambda[5](t) beta
d
--- lambda[4](t) = -lambda[3](t) (1 - q) u[2] eta
dt
- lambda[4](t) (-u[2] eta - mu - alpha) - lambda[5](t) u[2] q eta
d
--- lambda[5](t) = -lambda[1](t) delta - lambda[5](t) (-mu - delta)
dt
#Digits:=10:
unprotect('gamma');
lambda:=0.51:
mu:=0.002:
beta:=0.0115:
delta:=0.003:
alpha:=0.33:
chi:=0.00274:
k:=6.24:
gamma:=0.4:
rho:=0.338:;tau=1000:;Psi:=0.1:;p:=0.6:;phi:=0.001:;eta:=0.001124:q:=0.6:varphi:=0.9:;vatheta:=0.9:
b[1]:=2:;b[2]:=3:;w[1]:=4:;w[2]:=5:;w[3]:=6:
#u[1]:=s(t)*(lambda[1](t)*varphi-lambda[2](t)*vartheta)/w[1]:
#u[2]:=eta*i*(-lambda[3](t)+lambda[3](t)*q+lambda[4](t)-lambda[5](t)*q)/w[2]:;u[3]:=lambda*(-lambda[1](t)*s-lambda[2](t)*gamma*v+lambda[3](t)*rho*s+lambda[3](t)*rho*gamma*v+lambda[4](t)*s+lambda[4](t)*gamma*v-lambda[4](t)*rho*s-lambda[4](t)*rho*gamma*v)/w[3]:
ics := s(0)=8200, v(0)=2800,c(0)=1100,i(0)=1500,r(0)=200,lambda[1](20)=0,lambda[2](20)=0,lambda[3](20)=0,lambda[4](20)=0,lambda[5](20)=0:
ode1:=diff(s(t),t)=(1-p*Psi)*tau+phi* v(t) + delta *r(t)-lambda*(1-u[3])*s(t)-u[1]*varphi*s(t) -mu*s(t),
diff(v(t), t) =p*Psi*tau + u[1]*vartheta*s(t) -gamma*lambda* (1-u[3])*v(t)-(mu+phi)*v(t) ,
diff(c(t), t) =(1-u[3])*rho*lambda* (s(t) +gamma*v(t))+(1-q)* u[2]*eta*i(t) -(mu +beta +chi)*c(t),
diff(i(t), t) =(1-rho)*(1-u[3])*lambda*( s(t) +gamma*v(t)) +chi*c(t) - u[2]*eta*i(t) - (mu +alpha )*i(t),
diff(r(t), t) = beta*c(t) + u[2]*q*eta*i(t) -(mu +delta)*r(t),
diff(lambda[1](t), t) = -lambda[1](t)*(-lambda*(1-u[3])-u[1]*varphi-mu)-lambda[2](t)*u[1]*vartheta-lambda[3](t)*(1-u[3])*rho*lambda-lambda[4](t)*(1-rho)*(1-u[3])*lambda,diff(lambda[2](t),t)=-lambda[1](t)*phi-lambda[2](t)*(-gamma*lambda*(1-u[3])-mu-phi)-lambda[3](t)*(1-u[3])*rho*lambda*gamma-lambda[4](t)*(1-rho)*(1-u[3])*lambda*gamma,diff(lambda[3](t),t)=-lambda[3](t)*(-mu-beta-chi)-lambda[4](t)*chi-lambda[5](t)*beta,diff(lambda[4](t),t)=-lambda[3](t)*(1-q)*u[2]*eta-lambda[4](t)*(-u[2]*eta-mu-alpha)-lambda[5](t)*u[2]*q*eta,diff(lambda[5](t),t)=-lambda[1](t)*delta-lambda[5](t)*(-mu-delta);
d
--- s(t) = (1 - p Psi) tau + phi v(t) + delta r(t) - lambda (1 - u[3]) s(t)
dt
d
- u[1] varphi s(t) - mu s(t), --- v(t) = p Psi tau + u[1] vartheta s(t)
dt
d
- gamma lambda (1 - u[3]) v(t) - (mu + phi) v(t), --- c(t) = (1 - u[3]) rho lambda
dt
(s(t) + gamma v(t)) + (1 - q) u[2] eta - (mu + beta + chi) c(t), 0 = (1
- rho) (1 - u[3]) lambda (s(t) + gamma v(t)) + chi c(t) - u[2] eta - mu
d d
- alpha, --- r(t) = beta c(t) + u[2] q eta - (mu + delta) r(t), ---
dt dt
d
- lambda[4](t) (1 - rho) (1 - u[3]) lambda, --- lambda[2](t) =
dt
-lambda[1](t) phi - lambda[2](t) (-gamma lambda (1 - u[3]) - mu - phi)
d
- lambda[4](t) (1 - rho) (1 - u[3]) lambda gamma, --- lambda[3](t) =
dt
d
-lambda[3](t) (-mu - beta - chi) - lambda[4](t) chi - lambda[5](t) beta, ---
dt
- lambda[4](t) (-u[2] eta - mu - alpha) - lambda[5](t) u[2] q eta,
d
dt
sol := dsolve({c(0) = 0, i(0) = 0, r(0) = .1, s(0) = 0, v(0) = 0, diff(c(t), t) = (1-u[3])*rho*lambda*(s(t)+gamma*v(t))+(1-q)*u[2]*eta*i(t)-(mu+beta+chi)*c(t), diff(i(t), t) = (1-rho)*(1-u[3])*lambda*(s(t)+gamma*v(t))+chi*c(t)-u[2]*eta*i(t)-(mu+alpha)*i(t), diff(r(t), t) = beta*c(t)+u[2]*q*eta*i(t)-(mu+delta)*r(t), diff(s(t), t) = (1-p*Psi)*tau+phi*v(t)+delta*r(t)-lambda*(1-u[3])*s(t)-u[1]*varphi*s(t)-mu*s(t), diff(v(t), t) = p*Psi*tau+u[1]*vartheta*s(t)-gamma*lambda*(1-u[3])*v(t)-(mu+phi)*v(t), diff(lambda[1](t), t) = -lambda[1](t)*(-lambda*(1-u[3])-u[1]*varphi-mu)-lambda[2](t)*u[1]*vartheta-lambda[3](t)*(1-u[3])*rho*lambda-lambda[4](t)*(1-rho)*(1-u[3])*lambda, diff(lambda[2](t), t) = -lambda[1](t)*phi-lambda[2](t)*(-gamma*lambda*(1-u[3])-mu-phi)-lambda[3](t)*(1-u[3])*rho*lambda*gamma-lambda[4](t)*(1-rho)*(1-u[3])*lambda*gamma, diff(lambda[3](t), t) = -lambda[3](t)*(-mu-beta-chi)-lambda[4](t)*chi-lambda[5](t)*beta, diff(lambda[4](t), t) = -lambda[3](t)*(1-q)*u[2]*eta-lambda[4](t)*(-u[2]*eta-mu-alpha)-lambda[5](t)*u[2]*q*eta, diff(lambda[5](t), t) = -lambda[1](t)*delta-lambda[5](t)*(-mu-delta), lambda[1](20) = 0, lambda[2](20) = 0, lambda[3](20) = 0, lambda[4](20) = 0, lambda[5](20) = 0}, type = numeric);
Error, (in dsolve/numeric/process_input) invalid specification of initial conditions, got 1 = 0
sol:=dsolve([ode1,ics],numeric, method = bvp[midrich],maxmesh=500);
dsolve[':-interactive']({});
Error, `:=` unexpected
eq1:=diff(s(t), t)=(1-p*Psi)*tau+phi* v(t) + delta *r(t)-lambda*(1-u[3])*s(t)-u[1]*varphi*s(t) -mu*s(t);
eq2:diff(v(t), t) =p*Psi*tau + u[1]*vartheta*s(t) -gamma*lambda* (1-u[3])*v(t)-(mu+phi)*v(t);
eq3:=diff(c(t), t) =(1-u[3])*rho*lambda* (s(t) +gamma*v(t))+(1-q)* u[2]*eta*i(t) -(mu +beta +chi)*c(t);
eq4:=diff(i(t), t) =(1-rho)*(1-u[3])*lambda*( s(t) +gamma*v(t)) +chi*c(t) - u[2]*eta*i(t) - (mu +alpha )*i(t);
eq5:=diff(r(t), t) = beta*c(t) + u[2]*q*eta*i(t) -(mu +delta)*r(t);
d
dt
d
--- v(t) = p Psi tau + u[1] vartheta s(t) - gamma lambda (1 - u[3]) v(t)
dt
- (mu + phi) v(t)
d
--- c(t) = (1 - u[3]) rho lambda (s(t) + gamma v(t)) + (1 - q) u[2] eta i(t)
dt
d
--- i(t) = (1 - rho) (1 - u[3]) lambda (s(t) + gamma v(t)) + chi c(t)
dt
- u[2] eta i(t) - (mu + alpha) i(t)
d
--- r(t) = beta c(t) + u[2] q eta i(t) - (mu + delta) r(t)
dt
eq6:=diff(Q(t),t)=b[1]*c(t)+b[2]*i(t)+w[1]*(u[1])^2/2+w[2]*(u[2])^2/2+w[3]*(u[3])^2/2;
d 1 2 1 2 1 2
--- Q(t) = b[1] c(t) + b[2] i(t) + - w[1] u[1] + - w[2] u[2] + - w[3] u[3]
dt 2 2 2
ics:=s(0)=8200, v(0)=2800,c(0)=1100,i(0)=1500,r(0)=200,Q(0)=6700;
s(0) = 8200, v(0) = 2800, c(0) = 1100, i(0) = 1500, r(0) = 200, Q(0) = 6700
sol0:=dsolve({eq1,eq2,eq3,eq4,eq5,eq6,ics},type=numeric,stiff=true,'parameters'=[u[1],u[2],u[3]],abserr=1e-15,relerr=1e-12,maxfun=0,range=0..50):
Q0:=6700;
6700
obj:=proc(u)
global sol0,Q0;
local ob1;
try
sol0('parameters'=[u[1],u[2],u[3]]):
ob1:=subs(sol0(20.),Q(t)):
catch :
ob1:=0;
end try;
#ob1:=subs(sol0(20.),Q(t));
if ob1>Q0 then Q0:=ob1;print(Q0,u);end;
ob1;
proc(u) ... end;
obj([1,1,1]);
obj([3,2.5],4);
u0:=Vector(3,[0.,0.,0.],datatype=float[8]);
Vector[column](%id = 85973880)
Q0:=0;
Q0 := 0
with(Optimization);
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize, NLPSolve,
QPSolve]
sol2:=NLPSolve(3,obj,initialpoint=u0,method=nonlinearsimplex,maximize,evaluationlimit=100):
sol0('parameters'=[3.18125786060723, 2.36800986932868]);
sol0(parameters = [3.18125786060723, 2.36800986932868])
for i from 1 to 3 do odeplot(sol0,[t,x[i](t)],0..20,thickness=3,axes=boxed);od;
I want to write the functional Z of J Z = exp(Int(Int(J(x)*Delta(x-y)*J(y), x), y))with Delta(x) = Int(I*exp(-I*k*x)*(1/(k^2-m^2)), k) in terms of the fourier transform of J: J(x) = Int(J(p)*exp(-I*p*x), p).
Actually I'm in Minkowski space and all the integrals should be over 4 dimensions, x,y,k,p should all be four-vectors, but I wanted to keep things short. (The only way I have found to express a 4D integral is using Physics-Intc with the singleparameters of the four vector. Is there a more convenient way to get d^4x?) But still in 1D I cannot solve it.
To find the solution, an exponential of only one integral, is actually pretty easy, since there are integrals over e. g. exp(-I*x*(p-k)) deliver a delta distribution, but I cannot reproduce this in Maple since he doesn't perform the integral over x.
I have found that I can/have to use the command inttrans-fourier to gain the delta distribution, but when I try to use it for the problem mentioned above I run into all kinds of problems. Not to mention that I cannot manage to perform a fourier transformation in 4D.
Does anybody know how to solve this problem? Thanks!
I am using the solve command to solve an equation of the form "linear over quadratic is equal to a constant" where the constant is assumed to be nonzero. This is easily solved by hand, of course, but I to use the solution in other computations. So I asked maple to solve it for me. But when I check maple's solution (i.e. just plug the two solutions in on the left hand side and simplify) maple does not return the original constant. Can anyone help me understand what is going wrong?
Dear Forum,
I am a new Maple user, and its symbolic prowess is really amazing. So we are trying to interface it with a C library. I want to generate some C code through Maple, and am trying the CodeGeneration package.
But the default conversion of C(a, b) is b = C language equivalent of expression a.
Now this should be fine for most purposes, but the C library that we are working with, "ACADOToolkit" in this case, requires the equations to be formatted in a certain way. So, I need the following equation in C:
f << dot(v) == (u-0.2*v*v)/m
Now the LHS part of == is to be hard-coded, but we want to generate the equation on the right using maple. Even if I define an equation as
eq1:= diff(v(t),t)=(u(t)-0.2*v(t)*v(t))/m(t) and then use C(rhs(eq1)), I get the result in the form of cg = u - 0.2 ...., whereas I want this to be assigned to something else, in this case - "f << dot(v)= ".
How can I achieve this ?
Chintan Pathak
Research Scholar,
University of Washington
hello ,
how i can exract value from pdsolve ,i need to use dU(x,R)/dR
thank you
restart; with(plots)
n := 1/3;
1/3
Uu := (3*n+1)*(1-R^((n+1)/n))/(n+1);
-(3/2)*R^4+3/2
eq := Uu*(diff(theta(x, R), x))-4*(diff(R*(diff(theta(x, R), R)), R))/R;
(-(3/2)*R^4+3/2)*(diff(theta(x, R), x))-4*(diff(theta(x, R), R)+R*(diff(diff(theta(x, R), R), R)))/R
IBC := {theta(0, R) = 1, theta(x, 1) = 0, (D[2](theta))(x, 0) = 0};
pds := pdsolve(eq, IBC, numeric);
U := subs(pds:-value(output = listprocedure), theta(x, R));
proc () local tv, xv, solnproc, stype, ndsol, vals; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; Digits := trunc(evalhf(Digits)); solnproc := proc (tv, xv) local INFO, errest, nd, dvars, dary, daryt, daryx, vals, msg, i, j; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; table( [( "soln_procedures" ) = array( 1 .. 1, [( 1 ) = (18446744074366926358)  ] ) ] ) INFO := table( [( "timestep" ) = 0.500000000000000e-1, ( "IBC" ) = b, ( "spaceidx" ) = 2, ( "fdepvars" ) = [theta(x, R)], ( "dependson" ) = [{1}], ( "eqnords" ) = [[1, 2]], ( "intspace" ) = Matrix(21, 1, {(1, 1) = .0, (2, 1) = .0, (3, 1) = .0, (4, 1) = .0, (5, 1) = .0, (6, 1) = .0, (7, 1) = .0, (8, 1) = .0, (9, 1) = .0, (10, 1) = .0, (11, 1) = .0, (12, 1) = .0, (13, 1) = .0, (14, 1) = .0, (15, 1) = .0, (16, 1) = .0, (17, 1) = .0, (18, 1) = .0, (19, 1) = .0, (20, 1) = .0, (21, 1) = .0}, datatype = float[8], order = C_order), ( "solvec2" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "allocspace" ) = 21, ( "solmat_ne" ) = 0, ( "depords" ) = [[1, 2]], ( "BCS", 1 ) = {[[1, 0, 1], b[1, 0, 1]], [[1, 1, 0], b[1, 1, 0]]}, ( "spacepts" ) = 21, ( "solvec3" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "autonomous" ) = true, ( "vectorproc" ) = proc (v, vp, vpp, t, x, k, h, n, vec) local _s1, _s2, _s3, _s4, _s5, _s6, xi; _s3 := 4*k; _s4 := -3*h^2; _s5 := 2*h*k; _s6 := 2*k*h^2; vec[1] := 0; vec[n] := 0; for xi from 2 to n-1 do _s1 := -vp[xi-1]+vp[xi+1]; _s2 := vp[xi-1]-2*vp[xi]+vp[xi+1]; vec[xi] := (_s4*vp[xi]*x[xi]^5+_s2*_s3*x[xi]-_s4*vp[xi]*x[xi]+_s1*_s5)/(_s6*x[xi]) end do end proc, ( "timeidx" ) = 1, ( "extrabcs" ) = [0], ( "pts", R ) = [0, 1], ( "solvec5" ) = 0, ( "timevar" ) = x, ( "t0" ) = 0, ( "solmat_v" ) = Vector(147, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0, (22) = .0, (23) = .0, (24) = .0, (25) = .0, (26) = .0, (27) = .0, (28) = .0, (29) = .0, (30) = .0, (31) = .0, (32) = .0, (33) = .0, (34) = .0, (35) = .0, (36) = .0, (37) = .0, (38) = .0, (39) = .0, (40) = .0, (41) = .0, (42) = .0, (43) = .0, (44) = .0, (45) = .0, (46) = .0, (47) = .0, (48) = .0, (49) = .0, (50) = .0, (51) = .0, (52) = .0, (53) = .0, (54) = .0, (55) = .0, (56) = .0, (57) = .0, (58) = .0, (59) = .0, (60) = .0, (61) = .0, (62) = .0, (63) = .0, (64) = .0, (65) = .0, (66) = .0, (67) = .0, (68) = .0, (69) = .0, (70) = .0, (71) = .0, (72) = .0, (73) = .0, (74) = .0, (75) = .0, (76) = .0, (77) = .0, (78) = .0, (79) = .0, (80) = .0, (81) = .0, (82) = .0, (83) = .0, (84) = .0, (85) = .0, (86) = .0, (87) = .0, (88) = .0, (89) = .0, (90) = .0, (91) = .0, (92) = .0, (93) = .0, (94) = .0, (95) = .0, (96) = .0, (97) = .0, (98) = .0, (99) = .0, (100) = .0, (101) = .0, (102) = .0, (103) = .0, (104) = .0, (105) = .0, (106) = .0, (107) = .0, (108) = .0, (109) = .0, (110) = .0, (111) = .0, (112) = .0, (113) = .0, (114) = .0, (115) = .0, (116) = .0, (117) = .0, (118) = .0, (119) = .0, (120) = .0, (121) = .0, (122) = .0, (123) = .0, (124) = .0, (125) = .0, (126) = .0, (127) = .0, (128) = .0, (129) = .0, (130) = .0, (131) = .0, (132) = .0, (133) = .0, (134) = .0, (135) = .0, (136) = .0, (137) = .0, (138) = .0, (139) = .0, (140) = .0, (141) = .0, (142) = .0, (143) = .0, (144) = .0, (145) = .0, (146) = .0, (147) = .0}, datatype = float[8], order = C_order, attributes = [source_rtable = (Matrix(21, 7, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (9, 1) = .0, (9, 2) = .0, (9, 3) = .0, (9, 4) = .0, (9, 5) = .0, (9, 6) = .0, (9, 7) = .0, (10, 1) = .0, (10, 2) = .0, (10, 3) = .0, (10, 4) = .0, (10, 5) = .0, (10, 6) = .0, (10, 7) = .0, (11, 1) = .0, (11, 2) = .0, (11, 3) = .0, (11, 4) = .0, (11, 5) = .0, (11, 6) = .0, (11, 7) = .0, (12, 1) = .0, (12, 2) = .0, (12, 3) = .0, (12, 4) = .0, (12, 5) = .0, (12, 6) = .0, (12, 7) = .0, (13, 1) = .0, (13, 2) = .0, (13, 3) = .0, (13, 4) = .0, (13, 5) = .0, (13, 6) = .0, (13, 7) = .0, (14, 1) = .0, (14, 2) = .0, (14, 3) = .0, (14, 4) = .0, (14, 5) = .0, (14, 6) = .0, (14, 7) = .0, (15, 1) = .0, (15, 2) = .0, (15, 3) = .0, (15, 4) = .0, (15, 5) = .0, (15, 6) = .0, (15, 7) = .0, (16, 1) = .0, (16, 2) = .0, (16, 3) = .0, (16, 4) = .0, (16, 5) = .0, (16, 6) = .0, (16, 7) = .0, (17, 1) = .0, (17, 2) = .0, (17, 3) = .0, (17, 4) = .0, (17, 5) = .0, (17, 6) = .0, (17, 7) = .0, (18, 1) = .0, (18, 2) = .0, (18, 3) = .0, (18, 4) = .0, (18, 5) = .0, (18, 6) = .0, (18, 7) = .0, (19, 1) = .0, (19, 2) = .0, (19, 3) = .0, (19, 4) = .0, (19, 5) = .0, (19, 6) = .0, (19, 7) = .0, (20, 1) = .0, (20, 2) = .0, (20, 3) = .0, (20, 4) = .0, (20, 5) = .0, (20, 6) = .0, (20, 7) = .0, (21, 1) = .0, (21, 2) = .0, (21, 3) = .0, (21, 4) = .0, (21, 5) = .0, (21, 6) = .0, (21, 7) = .0}, datatype = float[8], order = C_order))]), ( "indepvars" ) = [x, R], ( "maxords" ) = [1, 2], ( "solvec1" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "startup_only" ) = false, ( "solvec4" ) = 0, ( "explicit" ) = false, ( "solmatrix" ) = Matrix(21, 7, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (9, 1) = .0, (9, 2) = .0, (9, 3) = .0, (9, 4) = .0, (9, 5) = .0, (9, 6) = .0, (9, 7) = .0, (10, 1) = .0, (10, 2) = .0, (10, 3) = .0, (10, 4) = .0, (10, 5) = .0, (10, 6) = .0, (10, 7) = .0, (11, 1) = .0, (11, 2) = .0, (11, 3) = .0, (11, 4) = .0, (11, 5) = .0, (11, 6) = .0, (11, 7) = .0, (12, 1) = .0, (12, 2) = .0, (12, 3) = .0, (12, 4) = .0, (12, 5) = .0, (12, 6) = .0, (12, 7) = .0, (13, 1) = .0, (13, 2) = .0, (13, 3) = .0, (13, 4) = .0, (13, 5) = .0, (13, 6) = .0, (13, 7) = .0, (14, 1) = .0, (14, 2) = .0, (14, 3) = .0, (14, 4) = .0, (14, 5) = .0, (14, 6) = .0, (14, 7) = .0, (15, 1) = .0, (15, 2) = .0, (15, 3) = .0, (15, 4) = .0, (15, 5) = .0, (15, 6) = .0, (15, 7) = .0, (16, 1) = .0, (16, 2) = .0, (16, 3) = .0, (16, 4) = .0, (16, 5) = .0, (16, 6) = .0, (16, 7) = .0, (17, 1) = .0, (17, 2) = .0, (17, 3) = .0, (17, 4) = .0, (17, 5) = .0, (17, 6) = .0, (17, 7) = .0, (18, 1) = .0, (18, 2) = .0, (18, 3) = .0, (18, 4) = .0, (18, 5) = .0, (18, 6) = .0, (18, 7) = .0, (19, 1) = .0, (19, 2) = .0, (19, 3) = .0, (19, 4) = .0, (19, 5) = .0, (19, 6) = .0, (19, 7) = .0, (20, 1) = .0, (20, 2) = .0, (20, 3) = .0, (20, 4) = .0, (20, 5) = .0, (20, 6) = .0, (20, 7) = .0, (21, 1) = .0, (21, 2) = .0, (21, 3) = .0, (21, 4) = .0, (21, 5) = .0, (21, 6) = .0, (21, 7) = .0}, datatype = float[8], order = C_order), ( "depvars" ) = [theta], ( "solmat_is" ) = 0, ( "adjusted" ) = false, ( "matrixhf" ) = true, ( "norigdepvars" ) = 1, ( "stages" ) = 1, ( "theta" ) = 1/2, ( "ICS" ) = [1], ( "multidep" ) = [false, false], ( "soltimes" ) = Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]), ( "depeqn" ) = [1], ( "method" ) = theta, ( "depshift" ) = [1], ( "depdords" ) = [[[1, 2]]], ( "matrixproc" ) = proc (v, vp, vpp, t, x, k, h, n, mat) local _s1, _s2, _s3, xi; _s1 := h^2; _s2 := -(3/2)/k; _s3 := (1/2)*(8*k+3*_s1)/(k*h^2); mat[3] := -(3/2)/h; mat[4] := 2/h; mat[5] := -(1/2)/h; mat[7*n-4] := 1; for xi from 2 to n-1 do mat[7*xi-4] := _s2*x[xi]^4+_s3; mat[7*xi-5] := (h-2*x[xi])/(_s1*x[xi]); mat[7*xi-3] := -(h+2*x[xi])/(_s1*x[xi]) end do end proc, ( "solution" ) = Array(1..3, 1..21, 1..1, {(1, 1, 1) = .0, (1, 2, 1) = .0, (1, 3, 1) = .0, (1, 4, 1) = .0, (1, 5, 1) = .0, (1, 6, 1) = .0, (1, 7, 1) = .0, (1, 8, 1) = .0, (1, 9, 1) = .0, (1, 10, 1) = .0, (1, 11, 1) = .0, (1, 12, 1) = .0, (1, 13, 1) = .0, (1, 14, 1) = .0, (1, 15, 1) = .0, (1, 16, 1) = .0, (1, 17, 1) = .0, (1, 18, 1) = .0, (1, 19, 1) = .0, (1, 20, 1) = .0, (1, 21, 1) = .0, (2, 1, 1) = .0, (2, 2, 1) = .0, (2, 3, 1) = .0, (2, 4, 1) = .0, (2, 5, 1) = .0, (2, 6, 1) = .0, (2, 7, 1) = .0, (2, 8, 1) = .0, (2, 9, 1) = .0, (2, 10, 1) = .0, (2, 11, 1) = .0, (2, 12, 1) = .0, (2, 13, 1) = .0, (2, 14, 1) = .0, (2, 15, 1) = .0, (2, 16, 1) = .0, (2, 17, 1) = .0, (2, 18, 1) = .0, (2, 19, 1) = .0, (2, 20, 1) = .0, (2, 21, 1) = .0, (3, 1, 1) = .0, (3, 2, 1) = .0, (3, 3, 1) = .0, (3, 4, 1) = .0, (3, 5, 1) = .0, (3, 6, 1) = .0, (3, 7, 1) = .0, (3, 8, 1) = .0, (3, 9, 1) = .0, (3, 10, 1) = .0, (3, 11, 1) = .0, (3, 12, 1) = .0, (3, 13, 1) = .0, (3, 14, 1) = .0, (3, 15, 1) = .0, (3, 16, 1) = .0, (3, 17, 1) = .0, (3, 18, 1) = .0, (3, 19, 1) = .0, (3, 20, 1) = .0, (3, 21, 1) = .0}, datatype = float[8], order = C_order), ( "totalwidth" ) = 7, ( "rightwidth" ) = 0, ( "solmat_i2" ) = 0, ( "minspcpoints" ) = 4, ( "erroraccum" ) = true, ( "eqndep" ) = [1], ( "errorest" ) = false, ( "banded" ) = true, ( "solspace" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = 1.0}, datatype = float[8]), ( "solmat_i1" ) = 0, ( "timeadaptive" ) = false, ( "spacestep" ) = 0.500000000000000e-1, ( "initialized" ) = false, ( "vectorhf" ) = true, ( "linear" ) = true, ( "spacevar" ) = R, ( "periodic" ) = false, ( "spaceadaptive" ) = false, ( "mixed" ) = false, ( "inputargs" ) = [(-(3/2)*R^4+3/2)*(diff(theta(x, R), x))-4*(diff(theta(x, R), R)+R*(diff(diff(theta(x, R), R), R)))/R, {theta(0, R) = 1, theta(x, 1) = 0, (D[2](theta))(x, 0) = 0}], ( "bandwidth" ) = [1, 3], ( "PDEs" ) = [(-(3/2)*R^4+3/2)*(diff(theta(x, R), x))-4*(diff(theta(x, R), R)+R*(diff(diff(theta(x, R), R), R)))/R], ( "leftwidth" ) = 1 ] ); if xv = "left" then return INFO["solspace"][1] elif xv = "right" then return INFO["solspace"][INFO["spacepts"]] elif tv = "start" then return INFO["t0"] elif not (type(tv, 'numeric') and type(xv, 'numeric')) then error "non-numeric input" end if; if xv < INFO["solspace"][1] or INFO["solspace"][INFO["spacepts"]] < xv then error "requested %1 value must be in the range %2..%3", INFO["spacevar"], INFO["solspace"][1], INFO["solspace"][INFO["spacepts"]] end if; dary := Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]); daryt := 0; daryx := 0; dvars := []; errest := false; nd := nops(INFO["depvars"]); if dary[nd+1] <> tv then try `pdsolve/numeric/evolve_solution`(INFO, tv) catch: msg := StringTools:-FormatMessage(lastexception[2 .. -1]); if tv < INFO["t0"] then error cat("unable to compute solution for %1<%2:
", msg), INFO["timevar"], INFO["failtime"] else error cat("unable to compute solution for %1>%2:
", msg), INFO["timevar"], INFO["failtime"] end if end try end if; if dary[nd+1] <> tv or dary[nd+2] <> xv then `pdsolve/interp2dto0d`(3, INFO["soltimes"], INFO["spacepts"], INFO["solspace"], nops(INFO["depvars"]), INFO["solution"], true, tv, xv, dary); if errest then `pdsolve/interp2dto0d`(3, INFO["soltimes"], INFO["spacepts"], INFO["err_t"], nops(INFO["depvars"]), INFO["solution"], true, tv, xv, daryt); `pdsolve/interp2dto0d`(3, INFO["soltimes"], INFO["spacepts"], INFO["err_x"], nops(INFO["depvars"]), INFO["solution"], true, tv, xv, daryx) end if end if; dary[nd+1] := tv; dary[nd+2] := xv; if dvars = [] then [seq(dary[i], i = 1 .. INFO["norigdepvars"])] else vals := NULL; for i to nops(dvars) do j := eval(dvars[i]); try if errest then vals := vals, evalhf(j(tv, xv, dary, daryt, daryx)) else vals := vals, evalhf(j(tv, xv, dary)) end if catch: userinfo(5, `pdsolve/numeric`, `evalhf failure`); try if errest then vals := vals, j(tv, xv, dary, daryt, daryx) else vals := vals, j(tv, xv, dary) end if catch: vals := vals, undefined end try end try end do; [vals] end if end proc; stype := "1st"; if nargs = 1 then if args[1] = "left" then return solnproc(0, "left") elif args[1] = "right" then return solnproc(0, "right") elif args[1] = "start" then return solnproc("start", 0) else error "too few arguments to solution procedure" end if elif nargs = 2 then if stype = "1st" then tv := evalf(args[1]); xv := evalf(args[2]) else tv := evalf(args[2]); xv := evalf(args[1]) end if; if not (type(tv, 'numeric') and type(xv, 'numeric')) then if procname <> unknown then return ('procname')(args[1 .. nargs]) else ndsol := pointto(solnproc("soln_procedures")[1]); return ('ndsol')(args[1 .. nargs]) end if end if else error "incorrect arguments to solution procedure" end if; vals := solnproc(tv, xv); vals[1] end proc
gg := U(x, 1):
thm := int(U(x, R)*Uu, R = 0 .. 1):
Download U(R)_numériqueg2.mw
I have a confusion between these symbol
Sum , add and sum
If we consider u(n) is a sequence and n integer
and what is the difference between
sum( u(n),n=0..infinity)
Sum(u(n),n=0..infinity)
and sum('u(n)', n=0..infinity)
Many thanks
HI all,
I have
> sol2 := dsolve({odesys, H(0) = 4995, R(0) = 65000, W(0) = 102000, l(0) = 96000}, numeric, method = rosenbrock);
print(`output redirected...`);
proc(x_rosenbrock) ... end;
I want to have a list of my solutions, t, H(t), R(t), W(t), l(t) that I can put into a spreadsheet (.csv, .txt, etc.), for 600 timesteps.
There are some answers out there, but I am confused by them, and have not been able to make it work.
How can I simplify $\sqrt{1−r^2\exp(2i\theta)}$ in Maple. I could do it by hand but I need this type of simplification later for far more complicated expressions.  I allready tried to enter this as a complex number using II, but simplify(...,'symbolic') didn't simplify this expression. Any suggestion?
I have a nonlinear function Q(a,b,c,d,x,y) and I'd like to get the optimum (x*,y*) for different values of (a,b,c,d). The usual sintax:
NLPSolve(Q(10, 1, 5, 2, x,y), x= 0 .. 50, y = 0 .. 50, initialpoint = {x = 2,y= .5}, assume = nonnegative) does not work when Q contains numerical integration, that is evalf (Int). I have no problem with the definite integral evalf(int). The problem is that most of the cases required numerical integration so I need the former expression.
I'd appreciate very much if someone could help me.
how can I check in maple if my variable P is positive (always or only for some certain conditions)
P=(exp(a-1)-exp(g-1))*(b*d*(f-g)-b*g*(a-e)-g*(a-c)*(a-e)))/((a-g)*b*d) + exp(g-1)*(((a-c)*(a-e))/b*d + (a-e)/d + 1)
with assumptions
a>0,b>0,c>0,d>0,e>0,f>0,g>0 and a>c,e,g
I need to prove that P is always positive with that assumptions, how?
First 1145 1146 1147 1148 1149 1150 1151 Last Page 1147 of 2463
