I have encountered a behavior of Maple that I find hard to explain and I am hoping for help. The command
sum(floor((exp(Pi)-Pi)*n)/3^n,n=0..infinity);
was meant to be an example of "High-precision fraud" as in the 1992 paper of Borwein and Borwein, and indeed it gives 29/2 to within 531 digits. But I am unable to make Maple see this; indeed I get with evalf(%,1000)
14.50000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
I find it hard to guess why Maple gets this wrong, actually. The point of the example is that floor((exp(Pi)-Pi)*n)=20*n-1 for many n, but Maple has no problems finding the first failure at n=1112. It must hence be trying something more advanced than just adding up all summands until the tail sum is small enough to satisfy the precision? I guess an alternative approach would indeed be possible since what is being "floored" is relatively simple, but then that seems to be buggy?
Would be very grateful for any assistance!
Best,
Soren Eilers
If you want to introduce the Heun Function to someone who dose not know anything about it (in the simple and not boring terms ), what would you do in the best??
As all of us know there are 5 Heun Functions: HeunB, HeunC, HeunD, HeunG and HeunT...
In the Maple help there is not enough and interesting information, and in the net I found complicated things about HeunT Function!!!
Dear, I want you to send me a simple definition about    HeunT  Function   in just one word page.
of a (concrete/general) triangle, making use of Maple tools in an efficient way?  Mathematica applies the barycentric coordinates and the Dirichlet distribution to this end. More generally, how to efficiently choose a random point in a given bounded region?
i need this equation solve by maple
eql := alap*[(la(a)^4+6*la(a)+1+alap*(la(a)^4-1)/difl1)*la(a)*j(a)-((la(a)^2+1)*(1+2/difl)+la(a)^2-1)*intdj/a^4+[(4*(la(a)^4-1))/difl-8*la(a)^2]*intdj/a^2]-(4*(la(a)^2+1))*intdj/a^4+(4*(la(a)^4-1))*intdj1/a^2 = 0;
Hello all,
I have a hash structure with arrays in a YAML file that I would like to read in Maple.
Does there exist a module, so I can read it?
Any one able to tell me why this won't work?
cc:=proc(M,shift)
local x,string;
string:=expl(M);
for x in string do
cl(x,shift);
end do; end proc;
expl:=proc(S)
Explode(S);
cc(ok,1) returns 'l'
expl works, how come the procedure using expl doesn't explode the message and do the procedure on each letter?
When may program begin the following massage appears
kerenl connectio has been lost
When generating the list of all the permutations of  [$1..10]  we get an error:
combinat[permute]([$ 1 .. 10]);
    Error, (in combinat:-permute) Maple was unable to allocate enough memory to complete this computation. Please see ?alloc
But if the same problem to solve using a simple custom procedure, there is no any problems:
Permute := proc (L::list)
local n;
n := nops(L);
if nops(L) = 1 then return [L[1 .. 1]] else
[seq(seq([op(p[1 .. k-1]), L[1], p[k .. n-1][]], k = 1 .. n), p = Permute(L[2 .. n]))] end if;
L := CodeTools[Usage](Permute([$ 1 .. 10])):
nops(L);
I'm trying to implement the QR algorithm to find the Eigenvalues of the input matrix which will be forwarded to another implementation (of the SVD alg.) to find the singular values. My implementation goes as follows:
1. feeding input: A::Matrix(datatype=float) # a bidiagonal matrix
2. construct input matrix for the QR alg. of matrix A and Z (zeros of size A): C := Matrix([[Z,Transpose(A)],[A,Z]], datatype=float); # therefore C should be symmetric
3. find the eigenvalues of matrix C with an implementation of the QR alg.:
for k from 1 to 400 do
Q, R := QRDecomposition(C);
C:=R.Q;
At this point, the eigenvalues of C should be placed in the diagonal of the matrix, but they're randomly placed around the diagonal, with only ~0 elements (like 2,xxx * 10^(-13)) in the diagonal.
If anyone knows how to resolve this, let the knowledge flow through. Any help will be appriciated, thanks in advance.
Hi, I'm having trouble trying to make a loop stop when a variable hits certain value. No, break doesn't help much as the code is intended to be executed w/ "execute the entire worksheet" command, and break only stops the calculation on this especific execution block (I'm using maple 18 btw).
Any ideas would be highly apreciated.
Dear friends
I use the command "dsolve(`union`(deq, initial), numeric, method = lsode)" for solving a fourth order ODE.
But for some numerical values of the parameters the bellow error is occurred:
" an excessive amount of work (greater than mxstep) was done ".
I have three questions:
1- how can I increase the mxstep from default amount (i.e. 500) to a greater value?
2- how can I ensure that the absolute error is less than 10E-6?
3- when I use lsode which way of numerical solution is applied (Euler,midpoint, rk3, rk4, rkf, heun, ... )?
Thanks a lot for your help
L(1):=[1,2,3]:
L(2):=[A,B,C]:
sum(nops(L(i)),i=1..2):
The real result of the sum is : 6.
Maple's result is : 2.
Yes, Maple gives an error.
But it doesn't matter, Maple is the most extraordinary software of the world !!!
My teacher (im studing Technology Management and Marine engineering) only allow that we use maple if we display the results between calculations. Is that posible:
a := 4;
b := 5;
Instead of :
a+b=9
I want it displayed as:
a+b= 4+5= 9;
or just
4+5 = 9; where a and b are Automatically replaced with the respective values, when i run the !!! button
A lot of my calculations are done by defining the variables in the top.
Any ideas??
Best regards  Carsten Moller
Please check why Maple is not returning location of Minima in following case:
-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x)
plot(-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x), x = -3.2 .. 3.2)
readlib(extrema):
{-0.6447467154e-1, 0.6447467152e-1}
Minima := op(1, {-0.6447467154e-1, 0.6447467152e-1}); 1; Maxima := op(2, {-0.6447467154e-1, 0.6447467152e-1})
-0.6447467154e-1
0.6447467152e-1
minimize(-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x), x = 0 .. 3.5, location)
minimize(-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x), x = 0 .. 3.5, location), {}
Why Maple is not returning location of minima?
Download Location_for_Max_Min.mw
y := 0.11083e-1+0.66489e-1*cos(n*x)+0.22089e-1*cos(2*n*x)+0.8903e-2*cos(3*n*x)-0.293e-3*cos(4*n*x)?
First 1160 1161 1162 1163 1164 1165 1166 Last Page 1162 of 2463
