Hi, here is the code I used to try to generate all invertible 4x4 matrices over the finite field F_2 = {0.1}. However, when I look at the elements of GROUP (see below) all the elements are 4x4 matrices with a 2 in each entry. I don't know why this is?
Also, I need help converting all of the invertible 4x4 matrices in the following way: I want the 4x4 matrices to each be written as a string of length 16 with no spaces, commas or brackets. So for example the matrix
a b c d
e f g h
i j k l
m n o p
becomes abcdefghijklmnop
PRIME := 2;
# the group of invertible 4 x 4 matrices over the field F_p
GROUP := []:
M := Matrix([[a,b,c,d],[x,f,g,h],[y,j,k,l],[m,n,o,p]]):
for a from 0 to PRIME-1 do
for b from 0 to PRIME-1 do
for c from 0 to PRIME-1 do
for d from 0 to PRIME-1 do
for x from 0 to PRIME-1 do
for f from 0 to PRIME-1 do
for g from 0 to PRIME-1 do
for h from 0 to PRIME-1 do
for y from 0 to PRIME-1 do
for j from 0 to PRIME-1 do
for k from 0 to PRIME-1 do
for l from 0 to PRIME-1 do
for m from 0 to PRIME-1 do
for n from 0 to PRIME-1 do
for o from 0 to PRIME-1 do
for p from 0 to PRIME-1 do
if Determinant(M) mod PRIME <> 0 then
GROUP := [ op(GROUP), M ]
fi
od od od od od od od od od od od od od od od od:
nops(GROUP);
20160
GROUP;
Is it possible to subscript within a plot?
for example I have
this in principle is what I want but, the N is cursive while is O is not (and it's a bit shifted to the right, not right next to the [2] !???
Also I didnt find the meanings of mi(),mn(),mo(),mfenced()... in the help documentation which I stumbled across while googling.
for example in this case:
what do I need them for since without the mi it doesnt work?!
Is it possible to use latex notation within the plot options for more convenience?
BTW: When plotting a .ps or .eps the plotting device takes over all the features (like the examples above) but when using png instead it just prints the code behind it ( for example the `#mover(mi("x"),mi("~"))` ) and not would it should lead to
How long will MAPLE 16 and future versions of MAPLE will support running on Windows 7?
MRB
(I hope to defer transferring to Windows 10 until MS stop supporting for Windows 7.)
I am unable to use subs() command when using subscript : I'd like to replace YP__1 with dGx in the equation :
"Eq:= YP__1 = Y__2" (Eq:= YP1=Y2)
 so I have tried : subs({YP__1=dGx},Eq)
But it doesn't work... It give me : YP__1 = Y__2 and I would like to have dGx = Y__2
I have tried also with subs({YP[1]=dGx},Eq) but doesn't work too.
If I am not using subscript, for exemple : Eq:= YP1 = Y2
And do : subs({YP1=dGx},Eq)
That works great...
But I must use subscript __ because Eq is a result from ODEtools (convertsys).
Can you help me please ?
Thanks you very much.
Regards.
Consider the list [x,y,z], say. Does there in Maple exist some fundamental function for querying the position in the list of x,y, and z, respectively? I am unable to locate any such. Such a function can, of course, be constructed, an example being the following:
listPos := (l::list) -> table(zip(`=`,l,[$(1..nops(l))])):
pos := listPos([x,y,z]);
pos[x],
pos[y],
pos[z];
But that seems unsatisfactory. The same question concerning Vectors: Consider Vector([x,y,z]), say. Here, the following code, say, will perform the task:
VectorPos := (V::Vector) -> table([map(rhs = lhs,op(2,V))[]]):
pos := VectorPos(Vector([x,y,z]));
pos[x],
pos[y],
pos[z];
PS: Of course, list and Vectors can be converted into one another, so any one of the codes above can in practice be used to perform both tasks.
The following code is part of my attempt to answer the recent Question about the bifurcation of the map f:= x-> exp(x^2*(a-x)). Two very weird things are happening. They can be seen by applying trace to f. The first is that the input argument to f seems to be changed to a very large integer. The second is that for some real values of a and x, I get imaginary results from this obviously real-valued function. Why are these things happening?
f:= x-> exp(x^2*(a-x)):
trace(f):
Iterate:= proc(a, x0:= 1., n:= 2000)
local A:= hfarray(1..n, [x0]), f:= subs(:-a= a, eval(:-f));
     #evalhf(
          proc(f, A, n)
          local k;
               for k from 2 to n do A[k]:= f(A[k-1]) end do
          end proc
          (f, A, n);
     evalf[4]~(convert(A[1000..], set))
Iterate(1.05);
{--> enter f, args = 4607182418800017408
HFloat(1.0512710963760241)
<-- exit f (now in unknown) = 4607413323290551347}
{--> enter f, args = 4607413323290551347
HFloat(0.9985962074909431)
<-- exit f (now in unknown) = 4607169774561176020}
{--> enter f, args = 4607169774561176020
HFloat(1.0525960836530153)
Iterate(.75);
.754589752755861+.192678397202388*I
<-- exit f (now in unknown) = HFloat(0.7545897527558614)+HFloat(0.19267839720238844)*I}
Error, (in unknown) unable to store 'HFloat(0.7545897527558614)+HFloat(0.19267839720238844)*I' when datatype=float[8]
Download bifurcation.mw
How to show what class of bifurcation is in this function :   exp(x2*(a-x)) ?
I have a long list of two element lists, for example,
A := [ [2,3], [4,5] ,[6,7]];
I want apply '/' to the elements of each sublist.
The result will be
R := [2/3, 4/5, 6/7];
I do not need the list, I could use vectors or matrices.
Is it possible to do this other than by iteration?
Tom Dean
I want to set up a couple of tables. One problem I have is setting up the list of names for the columns.  u0 etc are actual variables. Being trying to use  ` ` and ' ' to stop them evaluating. I have even more problems with  h6 as a name and symbols Sigma etc.
How do you do this so it looks neat and the name preferably doesn`t display the  ` ` or " " or '  '?
"Names:=[`u0`,`u1`,`u2`,`u3`,`Px`,`Py`,`Pz`,`-`,`'g0'`,`'g1'`,`'g2'`,`'g3'`,`-`,`\`&sum;u`^(2)`,`-`\`,&sum;p`^(2)`,`-`,` &sum;g^(2)`]"
Error, unable to delimit strings/identifiers
"Names:=[`u0`,`u1`,`u2`,`u3`,`Px`,`Py`,`Pz`,`-`,`'g0'`,`'g1'`,`'g2'`,`'g3'`,`-`,`\`&sum;u`^2`,`-`\`,&sum;p`^2`,`-`,` &sum;g^2`]"
Download Table_Headers.mw
greatings all,
I want to calculate energy momentum tensor for a given metric. is it possible to calculate it in the physics package?
thanks.
Please find the attached file
The command PolynomialInterpolation doesn't work, I will be appreciate if you can help me
Question.mw
hi.i am a problem for solving this non linear algebric equation.
please help me...thanks
FSOLVE.mw
FSOLVE.mw
With the RationalFunctionTutor generated then modified code (see egn2.mw attached).  Is it possible to make linestyle=spacedash for the two vertical asymtotes?  By selecting the graph and choosing from the plot menu the linestyle can be changed, but is there a way to do this with commands in the program code?
egn2.mw
When I was editing the head of the question (? instead of .), its body disappeared. Please, insert it again.
Regard,
Markiyan Hirnyk
Maple 15.
I have a set of equations I can solve manually, but, solve fails.
eq1 := tgtX[1] = 0;
eq2 := tgtY[2] - y[2]    = m[2]*(tgtX[2]-x[2]);
eq3 := tgtY[3] - y[3]    = m[3]*(tgtX[3]-x[3]);
eq4 := tgtY[4] - y[4]    = m[4]*(tgtX[4]-x[4]);
eq5 := tgtY[2] - tgtY[1] = vy*t[2];
eq6 := tgtY[3] - tgtY[1] = vy*t[3];
eq7 := tgtY[4] - tgtY[1] = vy*t[4];
eq8 := tgtX[2]           = vx*t[2];
eq9 := tgtX[3]           = vx*t[3];
eq10:= tgtX[4]           = vx*t[4];
# solve the equations
eqs  := {eq1,eq2,eq3,eq4,eq5,eq6,eq7,eq8,eq9,eq10};
solvx := solve(eq10,vx);
solvy := solve(eq7,vy);
sol1  := subs(vx=solvx,{eq8,eq9});
sol2  := subs(vy=solvy,{eq5,eq6});
soln  := subs(sol1,{eq2,eq3});
soln  := subs(tgtY[2]=solve(sol2[1],tgtY[2]),soln);
soln  := subs(tgtY[3]=solve(sol2[2],tgtY[3]),soln);
soln  := subs(tgtY[1]=solve(soln[1],tgtY[1]),soln[2]);
soln  := solve({eq4,soln},{tgtX[4],tgtY[4]});
# this returns empty solution
solve(eqs,{tgtX[4],tgtY[4]});
Any ideas?
Tom Dean
First 1162 1163 1164 1165 1166 1167 1168 Last Page 1164 of 2463
